  4. RPI2 Adapter kann nicht installiert werden
    6.4k
167 Beiträge 11 Kommentatoren 13.2k Aufrufe 10 Beobachtet
  • G Gonzokalle
    @crunchip
    martin@RaspberryPi-Iobroker:/opt/iobroker $ sudo npm install -g node-gyp@latest
    npm config set node_gyp $(which node-gyp)
    node-gyp -v
    iobroker add rpi2@latest --unsafe-permissions
    added 63 packages in 4s
    6 packages are looking for funding
      run `npm fund` for details
    npm notice
    npm notice New minor version of npm available! 11.6.2 -> 11.7.0
    npm notice Changelog: https://github.com/npm/cli/releases/tag/v11.7.0
    npm notice To update run: npm install -g npm@11.7.0
    npm notice
    npm error `node_gyp` is not a valid npm option
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-31T11_07_23_201Z-debug-0.log
    v12.1.0
    NPM version: 11.6.2
    Installing iobroker.rpi2@latest... (System call)
    npm error code 6
    npm error path /opt/iobroker/node_modules/opengpio
    npm error command failed
    npm error command sh -c node-gyp rebuild
    npm error (node:266019) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
    npm error (Use `node --trace-deprecation ...` to show where the warning was created)
    npm error gyp ERR! Completion callback never invoked!
    npm error gyp ERR! System Linux 6.12.47+rpt-rpi-2712
    npm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
    npm error gyp ERR! cwd /opt/iobroker/node_modules/opengpio
    npm error gyp ERR! node -v v24.12.0
    npm error gyp ERR! node-gyp -v v7.1.2
    npm error gyp ERR! Node-gyp failed to build your package.
    npm error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-31T11_07_24_740Z-debug-0.log
    host.RaspberryPi-Iobroker Cannot install iobroker.rpi2@latest: 6
    crunchipC Offline
    crunchipC Offline
    #161
    @Gonzokalle probier das nun mal
    cd /opt/iobroker && npm install node-gyp@latest && ls -la node_modules/.bin/node-gyp* && iobroker add rpi2@latest --unsafe-permissions
    G 1 Antwort Letzte Antwort
      Gonzokalle
      schrieb am zuletzt editiert von Gonzokalle
      #162
      @crunchip
      Der rpi2 Adapter ist da. Super.
      Was war denn jetzt der Fehler?
      Wobei kann der passiert sein?
      martin@RaspberryPi-Iobroker:/opt/iobroker $ cd /opt/iobroker && npm install node-gyp@latest && ls -la node_modules/.bin/node-gyp* && iobroker add rpi2@latest --unsafe-permissions
      npm warn deprecated npmlog@4.1.2: This package is no longer supported.
      npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
      npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.
      npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
      npm warn deprecated gauge@2.7.4: This package is no longer supported.
      added 48 packages in 19s
      212 packages are looking for funding
      lrwxrwxrwx 1 iobroker iobroker 27 31. Dez 12:07 node_modules/.bin/node-gyp -> ../node-gyp/bin/node-gyp.js
      lrwxrwxrwx 1 iobroker iobroker 24 27. Dez 10:40 node_modules/.bin/node-gyp-build -> ../node-gyp-build/bin.js
      lrwxrwxrwx 1 iobroker iobroker 29 27. Dez 10:40 node_modules/.bin/node-gyp-build-optional -> ../node-gyp-build/optional.js
      lrwxrwxrwx 1 iobroker iobroker 31 27. Dez 10:40 node_modules/.bin/node-gyp-build-test -> ../node-gyp-build/build-test.js
      NPM version: 11.6.2
      added 34 packages in 21s
      219 packages are looking for funding
      host.RaspberryPi-Iobroker install adapter rpi2@latest
      upload [13] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [12] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [11] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [10] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [9] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [8] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [7] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [6] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [5] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [4] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
      upload [3] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [2] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/jsonConfig.json jsonConfig.json application/json
      upload [1] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/rpi2.png rpi2.png image/png
      upload [0] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/words.js words.js application/javascript
      host.RaspberryPi-Iobroker object system.adapter.rpi2 created/updated
      Updating objects from io-package.json for adapter "rpi2" with version "3.0.2"
      host.RaspberryPi-Iobroker create instance rpi2
      host.RaspberryPi-Iobroker object system.adapter.rpi2.0.alive created
      host.RaspberryPi-Iobroker object system.adapter.rpi2.0.connected created
      host.RaspberryPi-Iobroker object system.adapter.rpi2.0.compactMode created
      host.RaspberryPi-Iobroker object system.adapter.rpi2.0.cpu created
      host.RaspberryPi-Iobroker object system.adapter.rpi2.0.cputime created
      host.RaspberryPi-Iobroker object system.adapter.rpi2.0.memHeapUsed created
      host.RaspberryPi-Iobroker object system.adapter.rpi2.0.memHeapTotal created
      host.RaspberryPi-Iobroker object system.adapter.rpi2.0.memRss created
      host.RaspberryPi-Iobroker object system.adapter.rpi2.0.uptime created
      host.RaspberryPi-Iobroker object system.adapter.rpi2.0.inputCount created
      host.RaspberryPi-Iobroker object system.adapter.rpi2.0.outputCount created
      host.RaspberryPi-Iobroker object system.adapter.rpi2.0.eventLoopLag created
      host.RaspberryPi-Iobroker object system.adapter.rpi2.0.sigKill created
      host.RaspberryPi-Iobroker object system.adapter.rpi2.0.logLevel created
      host.RaspberryPi-Iobroker object system.adapter.rpi2.0 created
      crunchipC 2 Antworten Letzte Antwort
      • G Gonzokalle
        @crunchip
        NPM version: 11.6.2
        crunchipC Offline
        crunchipC Offline
        #163
        @Gonzokalle also läuft es nun
        kannst ja mal den iobroker nochmal neu starten
        • G Gonzokalle
          @crunchip
          NPM version: 11.6.2
          crunchipC Offline
          crunchipC Offline
          #164
          @Gonzokalle
          PROBLEM: opengpio nutzte ./node_modules/.bin/node-gyp → v7.1.2 (Node24 incompatible)
          FIX: npm install node-gyp@latest → .bin Symlink → v12.1.0 → rpi2 SUCCESS!
            @Gonzokalle
            #165
            @crunchip sagte in RPI2 Adapter kann nicht installiert werden:
            ...aber warum??...
            (unabhängig von der jetzt gelösten Situation!)
              ...aber warum??...
              crunchipC Offline
              crunchipC Offline
              #166
              @Homoran sagte in RPI2 Adapter kann nicht installiert werden:
              aber warum??
              gute Frage, konnte ich bisher auch nicht herausfinden
                Gonzokalle
                #167
                @crunchip
                Ja, rpi2 Adapter läuft, Objekte sind auch da.
                Vielen Dank dafür.
                Einen guten Rutsch für Euch.
