  4. RPI2 Adapter kann nicht installiert werden
    6.4k
167 Beiträge 11 Kommentatoren 13.2k Aufrufe 10 Beobachtet
    @Gonzokalle mach noch ein
    find /opt/iobroker /home/iobroker -name "*node-gyp*7*" 2>/dev/null
    Gonzokalle
    #150
    @crunchip
    martin@RaspberryPi-Iobroker:~ $ find /opt/iobroker /home/iobroker -name "*node-gyp*7*" 2>/dev/null
    • G Gonzokalle
      @crunchip
      crunchipC Offline
      crunchipC Offline
      #151
      @Gonzokalle dann probier es mal so
      cd /opt/iobroker
      npm install -g node-gyp@latest && npm config set node_gyp $(which node-gyp) && node-gyp -v && iobroker add rpi2@latest --unsafe-permissions
      G 1 Antwort Letzte Antwort
        cd /opt/iobroker
        Gonzokalle
        #152
        @crunchip
        martin@RaspberryPi-Iobroker:~ $ cd /opt/iobroker
        npm error code EACCES
        npm error syscall mkdir
        npm error path /usr/lib/node_modules/node-gyp
        npm error errno -13
        npm error Error: EACCES: permission denied, mkdir '/usr/lib/node_modules/node-gyp'
        npm error     at async mkdir (node:internal/fs/promises:861:10)
        npm error     at async /usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:576:20
        npm error     at async Promise.allSettled (index 0)
        npm error     at async [reifyPackages] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:313:11)
        npm error     at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:125:5)
        npm error     at async Install.exec (/usr/lib/node_modules/npm/lib/commands/install.js:150:5)
        npm error     at async Npm.exec (/usr/lib/node_modules/npm/lib/npm.js:208:9)
        npm error     at async module.exports (/usr/lib/node_modules/npm/lib/cli/entry.js:67:5) {
        npm error   errno: -13,
        npm error   code: 'EACCES',
        npm error   syscall: 'mkdir',
        npm error   path: '/usr/lib/node_modules/node-gyp'
        npm error }
        npm error
        npm error The operation was rejected by your operating system.
        npm error It is likely you do not have the permissions to access this file as the current user
        npm error
        npm error If you believe this might be a permissions issue, please double-check the
        npm error permissions of the file and its containing directories, or try running
        npm error the command again as root/Administrator.
        npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-31T10_12_56_377Z-debug-0.log
        martin@RaspberryPi-Iobroker:/opt/iobroker $
        crunchipC HomoranH 2 Antworten Letzte Antwort
        • G Gonzokalle
          @crunchip
          npm error errno -13
          npm error }
          npm error
          npm error
          crunchipC Offline
          crunchipC Offline
          #153
          @Gonzokalle
          sudo npm install -g node-gyp@latest
          node-gyp -v
          • G Gonzokalle
            @crunchip
            npm error errno -13
            npm error }
            npm error
            npm error
            #154
            @Gonzokalle sagte in RPI2 Adapter kann nicht installiert werden:
            das passt ja zu
            @crunchip sagte in RPI2 Adapter kann nicht installiert werden:
            kann es möglicherweise an fehlenden Schreibrechten liegen bei user martin?
            Welche Rechte müsste martin denn haben?
              das passt ja zu
              crunchipC Offline
              crunchipC Offline
              #155
              @Homoran Global npm braucht sudo für /usr/lib/node_modules/
                @Gonzokalle
                node-gyp -v
                #156
                @crunchip ehrlich?
                npm mit sudo??
                nicht dass ich weiss wovon ich rede 😉
                aber ich denke das soll man nicht (und dann noch global)
                  #157
                  @crunchip ok!
                  dann vergiss auch meinen letzten Post
                    @crunchip ehrlich?
                    npm mit sudo??
                    crunchipC Offline
                    crunchipC Offline
                    #158
                    @Homoran sagte in RPI2 Adapter kann nicht installiert werden:
                    sollte man auch eigentlich nicht
                      Gonzokalle
                      #159
                      @crunchip
                      martin@RaspberryPi-Iobroker:/opt/iobroker $ sudo npm install -g node-gyp@latest
                      node-gyp -v
                      added 63 packages in 4s
                      6 packages are looking for funding
                        run `npm fund` for details
                      npm notice
                      npm notice New minor version of npm available! 11.6.2 -> 11.7.0
                      npm notice Changelog: https://github.com/npm/cli/releases/tag/v11.7.0
                      npm notice To update run: npm install -g npm@11.7.0
                      npm notice
                      npm error `node_gyp` is not a valid npm option
                      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-31T11_07_23_201Z-debug-0.log
                      v12.1.0
                      NPM version: 11.6.2
                      Installing iobroker.rpi2@latest... (System call)
                      npm error code 6
                      npm error path /opt/iobroker/node_modules/opengpio
                      npm error command failed
                      npm error command sh -c node-gyp rebuild
                      npm error (node:266019) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                      npm error (Use `node --trace-deprecation ...` to show where the warning was created)
                      npm error gyp ERR! Completion callback never invoked!
                      npm error gyp ERR! System Linux 6.12.47+rpt-rpi-2712
                      npm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
                      npm error gyp ERR! cwd /opt/iobroker/node_modules/opengpio
                      npm error gyp ERR! node -v v24.12.0
                      npm error gyp ERR! node-gyp -v v7.1.2
                      npm error gyp ERR! Node-gyp failed to build your package.
                      npm error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
                      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-31T11_07_24_740Z-debug-0.log
                      host.RaspberryPi-Iobroker Cannot install iobroker.rpi2@latest: 6
                      HomoranH crunchipC 2 Antworten Letzte Antwort
                      • G Gonzokalle
                        @crunchip
                        node-gyp -v
                        npm notice
                        npm notice
                        v12.1.0
                        NPM version: 11.6.2
                        npm error code 6
                        #160
                        ich denke da muss ein Bindestrich hin
                        @crunchip ??
                        • G Gonzokalle
                          @crunchip
                          node-gyp -v
                          npm notice
                          npm notice
                          v12.1.0
                          NPM version: 11.6.2
                          npm error code 6
                          crunchipC Offline
                          crunchipC Offline
                          #161
                          @Gonzokalle probier das nun mal
                          cd /opt/iobroker && npm install node-gyp@latest && ls -la node_modules/.bin/node-gyp* && iobroker add rpi2@latest --unsafe-permissions
                            Gonzokalle
                            schrieb am zuletzt editiert von Gonzokalle
                            #162
                            @crunchip
                            Der rpi2 Adapter ist da. Super.
                            Was war denn jetzt der Fehler?
                            Wobei kann der passiert sein?
                            martin@RaspberryPi-Iobroker:/opt/iobroker $ cd /opt/iobroker && npm install node-gyp@latest && ls -la node_modules/.bin/node-gyp* && iobroker add rpi2@latest --unsafe-permissions
                            npm warn deprecated npmlog@4.1.2: This package is no longer supported.
                            npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
                            npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.
                            npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
                            npm warn deprecated gauge@2.7.4: This package is no longer supported.
                            added 48 packages in 19s
                            212 packages are looking for funding
                            lrwxrwxrwx 1 iobroker iobroker 27 31. Dez 12:07 node_modules/.bin/node-gyp -> ../node-gyp/bin/node-gyp.js
                            lrwxrwxrwx 1 iobroker iobroker 24 27. Dez 10:40 node_modules/.bin/node-gyp-build -> ../node-gyp-build/bin.js
                            lrwxrwxrwx 1 iobroker iobroker 29 27. Dez 10:40 node_modules/.bin/node-gyp-build-optional -> ../node-gyp-build/optional.js
                            lrwxrwxrwx 1 iobroker iobroker 31 27. Dez 10:40 node_modules/.bin/node-gyp-build-test -> ../node-gyp-build/build-test.js
                            NPM version: 11.6.2
                            added 34 packages in 21s
                            219 packages are looking for funding
                            host.RaspberryPi-Iobroker install adapter rpi2@latest
                            upload [13] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/de/translations.json i18n/de/translations.json application/json
                            upload [12] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/en/translations.json i18n/en/translations.json application/json
                            upload [11] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/es/translations.json i18n/es/translations.json application/json
                            upload [10] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                            upload [9] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/it/translations.json i18n/it/translations.json application/json
                            upload [8] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                            upload [7] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                            upload [6] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                            upload [5] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                            upload [4] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                            upload [3] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                            upload [2] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/jsonConfig.json jsonConfig.json application/json
                            upload [1] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/rpi2.png rpi2.png image/png
                            upload [0] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/words.js words.js application/javascript
                            host.RaspberryPi-Iobroker object system.adapter.rpi2 created/updated
                            Updating objects from io-package.json for adapter "rpi2" with version "3.0.2"
                            host.RaspberryPi-Iobroker create instance rpi2
                            host.RaspberryPi-Iobroker object system.adapter.rpi2.0.alive created
                            host.RaspberryPi-Iobroker object system.adapter.rpi2.0.connected created
                            host.RaspberryPi-Iobroker object system.adapter.rpi2.0.compactMode created
                            host.RaspberryPi-Iobroker object system.adapter.rpi2.0.cpu created
                            host.RaspberryPi-Iobroker object system.adapter.rpi2.0.cputime created
                            host.RaspberryPi-Iobroker object system.adapter.rpi2.0.memHeapUsed created
                            host.RaspberryPi-Iobroker object system.adapter.rpi2.0.memHeapTotal created
                            host.RaspberryPi-Iobroker object system.adapter.rpi2.0.memRss created
                            host.RaspberryPi-Iobroker object system.adapter.rpi2.0.uptime created
                            host.RaspberryPi-Iobroker object system.adapter.rpi2.0.inputCount created
                            host.RaspberryPi-Iobroker object system.adapter.rpi2.0.outputCount created
                            host.RaspberryPi-Iobroker object system.adapter.rpi2.0.eventLoopLag created
                            host.RaspberryPi-Iobroker object system.adapter.rpi2.0.sigKill created
                            host.RaspberryPi-Iobroker object system.adapter.rpi2.0.logLevel created
                            host.RaspberryPi-Iobroker object system.adapter.rpi2.0 created
                            • G Gonzokalle
                              @crunchip
                              NPM version: 11.6.2
                              crunchipC Offline
                              crunchipC Offline
                              #163
                              @Gonzokalle also läuft es nun
                              kannst ja mal den iobroker nochmal neu starten
                              • G Gonzokalle
                                @crunchip
                                NPM version: 11.6.2
                                crunchipC Offline
                                crunchipC Offline
                                #164
                                @Gonzokalle
                                PROBLEM: opengpio nutzte ./node_modules/.bin/node-gyp → v7.1.2 (Node24 incompatible)
                                FIX: npm install node-gyp@latest → .bin Symlink → v12.1.0 → rpi2 SUCCESS!
                                  @Gonzokalle
                                  #165
                                  ...aber warum??...
                                  (unabhängig von der jetzt gelösten Situation!)
                                    ...aber warum??...
                                    crunchipC Offline
                                    crunchipC Offline
                                    #166
                                    aber warum??
                                    gute Frage, konnte ich bisher auch nicht herausfinden
                                      Gonzokalle
                                      #167
                                      @crunchip
                                      Ja, rpi2 Adapter läuft, Objekte sind auch da.
                                      Vielen Dank dafür.
                                      Einen guten Rutsch für Euch.
