  4. RPI2 Adapter kann nicht installiert werden
    6.4k
167 Beiträge 11 Kommentatoren 13.2k Aufrufe 10 Beobachtet
  • G Gonzokalle
    @Thomas-Braun
    martin@RaspberryPi-Iobroker:/opt/iobroker $ iobroker url iobroker.rpi2@latest  --debug
    install iobroker.rpi2@latest
    NPM version: 11.6.2
    Installing iobroker.rpi2@latest... (System call)
    npm warn deprecated npmlog@4.1.2: This package is no longer supported.
    npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
    npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.
    npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
    npm warn deprecated gauge@2.7.4: This package is no longer supported.
    > iobroker.rpi2@3.0.2 preinstall
    > bash ./preinstall-check.sh
    Checking package: libgpiod-dev >= 2.2
    libgpiod-dev version OK: 2.2.1-2+deb13u1
    > @stoprocent/bluetooth-hci-socket@1.5.2 install
    > node-gyp-build
    > @stoprocent/noble@1.19.1 install
    > node-gyp-build
    gyp info it worked if it ends with ok
    gyp info using node-gyp@7.1.2
    gyp info using node@24.12.0 | linux | arm64
    (node:149664) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
    (Use `node --trace-deprecation ...` to show where the warning was created)
    gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"
    gyp ERR! Completion callback never invoked!
    gyp ERR! System Linux 6.12.47+rpt-rpi-2712
    gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/@stoprocent/noble
    gyp ERR! node -v v24.12.0
    gyp ERR! node-gyp -v v7.1.2
    gyp ERR! Node-gyp failed to build your package.
    gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
    > cpu-features@0.0.10 install
    > node buildcheck.js > buildcheck.gypi && node-gyp rebuild
    (node:149699) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
    gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/cpu-features
    > diskusage@1.2.0 install
    > node-gyp rebuild
    (node:149713) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
    gyp ERR! cwd /opt/iobroker/node_modules/diskusage
    > node-dht-sensor@0.4.5 install
    > node-gyp configure
    (node:149727) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
    gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "configure"
    gyp ERR! cwd /opt/iobroker/node_modules/node-dht-sensor
    > opengpio@2.0.2 install
    > node-gyp rebuild
    (node:149741) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
    gyp ERR! cwd /opt/iobroker/node_modules/opengpio
    npm error code 6
    npm error path /opt/iobroker/node_modules/opengpio
    npm error command failed
    npm error command sh -c node-gyp rebuild
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-30T10_03_38_431Z-debug-0.log
    npm error code 6
    host.RaspberryPi-Iobroker Cannot install iobroker.rpi2@latest: 6
    #144
    @Gonzokalle sagte in RPI2 Adapter kann nicht installiert werden:
    Da isser wieder.
    Keine Ahnung wo das immer herkommt.
      Da isser wieder.
      crunchipC Offline
      crunchipC Offline
      #145
      @Thomas-Braun sagte in RPI2 Adapter kann nicht installiert werden:
      kann es möglicherweise an fehlenden Schreibrechten liegen bei user martin?
      nen test mit
      cd /opt/iobroker
      echo "=== BEFORE rm ===" && ls -la node_modules/node-gyp* 2>/dev/null || echo "NO node-gyp"
      rm -v node_modules/node-gyp* 2>/dev/null && echo "rm VERBOSE OK" || echo "**EACCES!**"
      echo "=== AFTER rm ===" && ls -la node_modules/node-gyp* 2>/dev/null || echo "GONE!"
      G 1 Antwort Letzte Antwort
        nen test mit
        cd /opt/iobroker
        Gonzokalle
        #146
        @crunchip
        martin@RaspberryPi-Iobroker:~ $ cd /opt/iobroker
        === BEFORE rm ===
        insgesamt 80
        drwxrwxr-x+   2 iobroker iobroker  4096 27. Dez 10:39 .
        drwxrwxr-x+ 765 iobroker iobroker 32768 30. Dez 12:09 ..
        -rwxrwxr-x+   1 iobroker iobroker  2094 27. Dez 10:39 bin.js
        -rwxrwxr-x+   1 iobroker iobroker   398 27. Dez 10:39 build-test.js
        -rw-rw-r--+   1 iobroker iobroker   390 27. Dez 10:39 index.js
        -rw-rw-r--+   1 iobroker iobroker  1079 27. Dez 10:39 LICENSE
        -rw-rw-r--+   1 iobroker iobroker  6078 27. Dez 10:39 node-gyp-build.js
        -rwxrwxr-x+   1 iobroker iobroker   143 27. Dez 10:39 optional.js
        -rw-rw-r--+   1 iobroker iobroker  1004 27. Dez 10:39 package.json
        -rw-rw-r--+   1 iobroker iobroker  2485 27. Dez 10:39 README.md
        -rw-rw-r--+   1 iobroker iobroker   193 27. Dez 10:39 SECURITY.md
        rm -v node_modules/node-gyp* 2>/dev/null && echo "rm VERBOSE OK" || echo "**EACCES"=== BEFORE rm ===" && ls -la node_modules/node-gyp* 2> /dev/null || echo "NO node-gyp"*"
        **EACCES=== BEFORE rm === && ls -la node_modules/node-gyp* 2> /dev/null || echo NO node-gyp*
        === AFTER rm ===
        insgesamt 80
        • G Gonzokalle
          @crunchip
          === BEFORE rm ===
          insgesamt 80
          === AFTER rm ===
          insgesamt 80
          crunchipC Offline
          crunchipC Offline
          #147
          @Gonzokalle zeig mal die Ausgabe von
          cd /opt/iobroker
          echo '=== VERSIONS ==='
          node -v && npm -v
          echo '=== PATH & GLOBAL ==='
          which node-gyp && node-gyp -v 2>/dev/null || echo 'NO GLOBAL!'
          echo '=== NPM INTERNAL ==='
          npm exec node-gyp -v 2>/dev/null || echo 'NO npm internal!'
          echo '=== NPM CONFIG ==='
          npm config get node_gyp || echo 'NO npm config!'
          echo '=== .BIN SYMLINKS ==='
          ls -la node_modules/.bin/node-gyp* 2>/dev/null || echo 'NO .bin!'
          echo '=== DEPENDENCY TREE ==='
          npm ls node-gyp --depth=0 2>/dev/null || echo 'NO LOCAL deps!'
          echo '=== NPX CACHE ==='
          npm config get cache
          ls -la ~/.npm/_npx/node-gyp* 2>/dev/null || echo 'NO npx cache!'
            cd /opt/iobroker
            node -v && npm -v
            Gonzokalle
            #148
            @crunchip
            node -v && npm -v
            === VERSIONS ===
            v24.12.0
            11.6.2
            NO GLOBAL!
            11.6.2
            === NPM CONFIG ===
            undefined
            lrwxrwxrwx 1 iobroker iobroker 24 27. Dez 10:40 node_modules/.bin/node-gyp-build -> ../node-gyp-build/bin.js
            lrwxrwxrwx 1 iobroker iobroker 29 27. Dez 10:40 node_modules/.bin/node-gyp-build-optional -> ../node-gyp-build/optional.js
            lrwxrwxrwx 1 iobroker iobroker 31 27. Dez 10:40 node_modules/.bin/node-gyp-build-test -> ../node-gyp-build/build-test.js
            iobroker.inst@3.0.0 /opt/iobroker
            └── (empty)
            NO LOCAL deps!
            === NPX CACHE ===
            /home/iobroker/.npm
            NO npx cache!
            • G Gonzokalle
              @crunchip
              node -v && npm -v
              === VERSIONS ===
              v24.12.0
              11.6.2
              NO GLOBAL!
              11.6.2
              === NPM CONFIG ===
              undefined
              └── (empty)
              NO LOCAL deps!
              === NPX CACHE ===
              /home/iobroker/.npm
              NO npx cache!
              crunchipC Offline
              crunchipC Offline
              #149
              @Gonzokalle mach noch ein
              find /opt/iobroker /home/iobroker -name "*node-gyp*7*" 2>/dev/null
                Gonzokalle
                #150
                @crunchip
                martin@RaspberryPi-Iobroker:~ $ find /opt/iobroker /home/iobroker -name "*node-gyp*7*" 2>/dev/null
                • G Gonzokalle
                  @crunchip
                  crunchipC Offline
                  crunchipC Offline
                  #151
                  @Gonzokalle dann probier es mal so
                  cd /opt/iobroker
                  npm install -g node-gyp@latest && npm config set node_gyp $(which node-gyp) && node-gyp -v && iobroker add rpi2@latest --unsafe-permissions
                    cd /opt/iobroker
                    Gonzokalle
                    #152
                    @crunchip
                    npm error code EACCES
                    npm error syscall mkdir
                    npm error path /usr/lib/node_modules/node-gyp
                    npm error errno -13
                    npm error Error: EACCES: permission denied, mkdir '/usr/lib/node_modules/node-gyp'
                    npm error     at async mkdir (node:internal/fs/promises:861:10)
                    npm error     at async /usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:576:20
                    npm error     at async Promise.allSettled (index 0)
                    npm error     at async [reifyPackages] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:313:11)
                    npm error     at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:125:5)
                    npm error     at async Install.exec (/usr/lib/node_modules/npm/lib/commands/install.js:150:5)
                    npm error     at async Npm.exec (/usr/lib/node_modules/npm/lib/npm.js:208:9)
                    npm error     at async module.exports (/usr/lib/node_modules/npm/lib/cli/entry.js:67:5) {
                    npm error   errno: -13,
                    npm error   code: 'EACCES',
                    npm error   syscall: 'mkdir',
                    npm error   path: '/usr/lib/node_modules/node-gyp'
                    npm error }
                    npm error
                    npm error The operation was rejected by your operating system.
                    npm error It is likely you do not have the permissions to access this file as the current user
                    npm error
                    npm error If you believe this might be a permissions issue, please double-check the
                    npm error permissions of the file and its containing directories, or try running
                    npm error the command again as root/Administrator.
                    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-31T10_12_56_377Z-debug-0.log
                    crunchipC HomoranH 2 Antworten Letzte Antwort
                    • G Gonzokalle
                      @crunchip
                      npm error errno -13
                      npm error }
                      npm error
                      npm error
                      crunchipC Offline
                      crunchipC Offline
                      #153
                      @Gonzokalle
                      sudo npm install -g node-gyp@latest
                      node-gyp -v
                      • G Gonzokalle
                        @crunchip
                        npm error errno -13
                        npm error }
                        npm error
                        npm error
                        #154
                        das passt ja zu
                        @crunchip sagte in RPI2 Adapter kann nicht installiert werden:
                        Welche Rechte müsste martin denn haben?
                          das passt ja zu
                          crunchipC Offline
                          crunchipC Offline
                          #155
                          @Homoran Global npm braucht sudo für /usr/lib/node_modules/
                            @Gonzokalle
                            node-gyp -v
                            #156
                            @crunchip ehrlich?
                            npm mit sudo??
                            nicht dass ich weiss wovon ich rede 😉
                            aber ich denke das soll man nicht (und dann noch global)
                              #157
                              @crunchip ok!
                              dann vergiss auch meinen letzten Post
                                @crunchip ehrlich?
                                npm mit sudo??
                                crunchipC Offline
                                crunchipC Offline
                                #158
                                @Homoran sagte in RPI2 Adapter kann nicht installiert werden:
                                sollte man auch eigentlich nicht
                                  Gonzokalle
                                  #159
                                  @crunchip
                                  martin@RaspberryPi-Iobroker:/opt/iobroker $ sudo npm install -g node-gyp@latest
                                  node-gyp -v
                                  added 63 packages in 4s
                                  6 packages are looking for funding
                                    run `npm fund` for details
                                  npm notice
                                  npm notice New minor version of npm available! 11.6.2 -> 11.7.0
                                  npm notice Changelog: https://github.com/npm/cli/releases/tag/v11.7.0
                                  npm notice To update run: npm install -g npm@11.7.0
                                  npm notice
                                  npm error `node_gyp` is not a valid npm option
                                  npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-31T11_07_23_201Z-debug-0.log
                                  v12.1.0
                                  NPM version: 11.6.2
                                  npm error code 6
                                  npm error (node:266019) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                                  npm error (Use `node --trace-deprecation ...` to show where the warning was created)
                                  npm error gyp ERR! Completion callback never invoked!
                                  npm error gyp ERR! System Linux 6.12.47+rpt-rpi-2712
                                  npm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
                                  npm error gyp ERR! cwd /opt/iobroker/node_modules/opengpio
                                  npm error gyp ERR! node -v v24.12.0
                                  npm error gyp ERR! node-gyp -v v7.1.2
                                  npm error gyp ERR! Node-gyp failed to build your package.
                                  npm error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
                                  npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-31T11_07_24_740Z-debug-0.log
                                  HomoranH crunchipC 2 Antworten Letzte Antwort
                                  • G Gonzokalle
                                    @crunchip
                                    node-gyp -v
                                    npm notice
                                    npm notice
                                    v12.1.0
                                    NPM version: 11.6.2
                                    npm error code 6
                                    #160
                                    ich denke da muss ein Bindestrich hin
                                    @crunchip ??
                                    • G Gonzokalle
                                      @crunchip
                                      node-gyp -v
                                      npm notice
                                      npm notice
                                      v12.1.0
                                      NPM version: 11.6.2
                                      npm error code 6
                                      crunchipC Offline
                                      crunchipC Offline
                                      #161
                                      @Gonzokalle probier das nun mal
                                      cd /opt/iobroker && npm install node-gyp@latest && ls -la node_modules/.bin/node-gyp* && iobroker add rpi2@latest --unsafe-permissions
                                        Gonzokalle
                                        schrieb am zuletzt editiert von Gonzokalle
                                        #162
                                        @crunchip
                                        Der rpi2 Adapter ist da. Super.
                                        Was war denn jetzt der Fehler?
                                        Wobei kann der passiert sein?
                                        martin@RaspberryPi-Iobroker:/opt/iobroker $ cd /opt/iobroker && npm install node-gyp@latest && ls -la node_modules/.bin/node-gyp* && iobroker add rpi2@latest --unsafe-permissions
                                        added 48 packages in 19s
                                        212 packages are looking for funding
                                        lrwxrwxrwx 1 iobroker iobroker 27 31. Dez 12:07 node_modules/.bin/node-gyp -> ../node-gyp/bin/node-gyp.js
                                        NPM version: 11.6.2
                                        added 34 packages in 21s
                                        219 packages are looking for funding
                                        host.RaspberryPi-Iobroker install adapter rpi2@latest
                                        upload [13] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                        upload [12] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                        upload [11] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                        upload [10] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                        upload [9] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                        upload [8] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                        upload [7] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                        upload [6] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                        upload [5] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                        upload [4] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                        upload [3] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                        upload [2] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/jsonConfig.json jsonConfig.json application/json
                                        upload [1] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/rpi2.png rpi2.png image/png
                                        upload [0] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/words.js words.js application/javascript
                                        host.RaspberryPi-Iobroker object system.adapter.rpi2 created/updated
                                        Updating objects from io-package.json for adapter "rpi2" with version "3.0.2"
                                        host.RaspberryPi-Iobroker create instance rpi2
                                        host.RaspberryPi-Iobroker object system.adapter.rpi2.0.alive created
                                        host.RaspberryPi-Iobroker object system.adapter.rpi2.0.connected created
                                        host.RaspberryPi-Iobroker object system.adapter.rpi2.0.compactMode created
                                        host.RaspberryPi-Iobroker object system.adapter.rpi2.0.cpu created
                                        host.RaspberryPi-Iobroker object system.adapter.rpi2.0.cputime created
                                        host.RaspberryPi-Iobroker object system.adapter.rpi2.0.memHeapUsed created
                                        host.RaspberryPi-Iobroker object system.adapter.rpi2.0.memHeapTotal created
                                        host.RaspberryPi-Iobroker object system.adapter.rpi2.0.memRss created
                                        host.RaspberryPi-Iobroker object system.adapter.rpi2.0.uptime created
                                        host.RaspberryPi-Iobroker object system.adapter.rpi2.0.inputCount created
                                        host.RaspberryPi-Iobroker object system.adapter.rpi2.0.outputCount created
                                        host.RaspberryPi-Iobroker object system.adapter.rpi2.0.eventLoopLag created
                                        host.RaspberryPi-Iobroker object system.adapter.rpi2.0.sigKill created
                                        host.RaspberryPi-Iobroker object system.adapter.rpi2.0.logLevel created
                                        host.RaspberryPi-Iobroker object system.adapter.rpi2.0 created
                                        • G Gonzokalle
                                          @crunchip
                                          NPM version: 11.6.2
                                          crunchipC Offline
                                          crunchipC Offline
                                          #163
                                          @Gonzokalle also läuft es nun
                                          kannst ja mal den iobroker nochmal neu starten
