  4. RPI2 Adapter kann nicht installiert werden
    6.4k
167 Beiträge 11 Kommentatoren 13.2k Aufrufe 10 Beobachtet
  • G Gonzokalle
    @Thomas-Braun
    Ich mache einfach was du sagst..
    martin@RaspberryPi-Iobroker:/opt/iobroker $ iob stop
    martin@RaspberryPi-Iobroker:/opt/iobroker $ rm /opt/iobroker/package-lock.json
    martin@RaspberryPi-Iobroker:/opt/iobroker $ cd /opt/iobroker/
    martin@RaspberryPi-Iobroker:/opt/iobroker $ npm i
    npm warn deprecated npmlog@4.1.2: This package is no longer supported.
    npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
    npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.
    npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
    npm warn deprecated gauge@2.7.4: This package is no longer supported.
    changed 1 package in 25s
    206 packages are looking for funding
      run `npm fund` for details
    martin@RaspberryPi-Iobroker:/opt/iobroker $ iob start
    #142
    @Gonzokalle
    Dann versuch jetzt nochmal
    iobroker url iobroker.rpi2@latest  --debug
    G 1 Antwort Letzte Antwort
      @Gonzokalle
      Gonzokalle
      #143
      @Thomas-Braun
      martin@RaspberryPi-Iobroker:/opt/iobroker $ iobroker url iobroker.rpi2@latest  --debug
      install iobroker.rpi2@latest
      NPM version: 11.6.2
      Installing iobroker.rpi2@latest... (System call)
      > iobroker.rpi2@3.0.2 preinstall
      > bash ./preinstall-check.sh
      Checking package: libgpiod-dev >= 2.2
      libgpiod-dev version OK: 2.2.1-2+deb13u1
      > @stoprocent/bluetooth-hci-socket@1.5.2 install
      > node-gyp-build
      > @stoprocent/noble@1.19.1 install
      > node-gyp-build
      gyp info it worked if it ends with ok
      gyp info using node-gyp@7.1.2
      gyp info using node@24.12.0 | linux | arm64
      (node:149664) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
      (Use `node --trace-deprecation ...` to show where the warning was created)
      gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"
      gyp ERR! Completion callback never invoked!
      gyp ERR! System Linux 6.12.47+rpt-rpi-2712
      gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/@stoprocent/noble
      gyp ERR! node -v v24.12.0
      gyp ERR! node-gyp -v v7.1.2
      gyp ERR! Node-gyp failed to build your package.
      gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
      > cpu-features@0.0.10 install
      > node buildcheck.js > buildcheck.gypi && node-gyp rebuild
      (node:149699) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
      gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/cpu-features
      > diskusage@1.2.0 install
      > node-gyp rebuild
      (node:149713) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
      gyp ERR! cwd /opt/iobroker/node_modules/diskusage
      > node-dht-sensor@0.4.5 install
      > node-gyp configure
      (node:149727) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
      gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "configure"
      gyp ERR! cwd /opt/iobroker/node_modules/node-dht-sensor
      > opengpio@2.0.2 install
      > node-gyp rebuild
      (node:149741) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
      gyp ERR! cwd /opt/iobroker/node_modules/opengpio
      npm error code 6
      npm error path /opt/iobroker/node_modules/opengpio
      npm error command failed
      npm error command sh -c node-gyp rebuild
      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-30T10_03_38_431Z-debug-0.log
      npm error code 6
      host.RaspberryPi-Iobroker Cannot install iobroker.rpi2@latest: 6
      • G Gonzokalle
        @Thomas-Braun
        NPM version: 11.6.2
        > node-gyp-build
        > node-gyp-build
        > node-gyp rebuild
        > node-gyp configure
        > node-gyp rebuild
        npm error code 6
        npm error code 6
        #144
        @Gonzokalle sagte in RPI2 Adapter kann nicht installiert werden:
        Da isser wieder.
        Keine Ahnung wo das immer herkommt.
          Da isser wieder.
          crunchipC Offline
          crunchipC Offline
          #145
          @Thomas-Braun sagte in RPI2 Adapter kann nicht installiert werden:
          kann es möglicherweise an fehlenden Schreibrechten liegen bei user martin?
          nen test mit
          cd /opt/iobroker
          echo "=== BEFORE rm ===" && ls -la node_modules/node-gyp* 2>/dev/null || echo "NO node-gyp"
          rm -v node_modules/node-gyp* 2>/dev/null && echo "rm VERBOSE OK" || echo "**EACCES!**"
          echo "=== AFTER rm ===" && ls -la node_modules/node-gyp* 2>/dev/null || echo "GONE!"
            nen test mit
            cd /opt/iobroker
            Gonzokalle
            #146
            @crunchip
            martin@RaspberryPi-Iobroker:~ $ cd /opt/iobroker
            === BEFORE rm ===
            insgesamt 80
            drwxrwxr-x+   2 iobroker iobroker  4096 27. Dez 10:39 .
            drwxrwxr-x+ 765 iobroker iobroker 32768 30. Dez 12:09 ..
            -rwxrwxr-x+   1 iobroker iobroker  2094 27. Dez 10:39 bin.js
            -rwxrwxr-x+   1 iobroker iobroker   398 27. Dez 10:39 build-test.js
            -rw-rw-r--+   1 iobroker iobroker   390 27. Dez 10:39 index.js
            -rw-rw-r--+   1 iobroker iobroker  1079 27. Dez 10:39 LICENSE
            -rw-rw-r--+   1 iobroker iobroker  6078 27. Dez 10:39 node-gyp-build.js
            -rwxrwxr-x+   1 iobroker iobroker   143 27. Dez 10:39 optional.js
            -rw-rw-r--+   1 iobroker iobroker  1004 27. Dez 10:39 package.json
            -rw-rw-r--+   1 iobroker iobroker  2485 27. Dez 10:39 README.md
            -rw-rw-r--+   1 iobroker iobroker   193 27. Dez 10:39 SECURITY.md
            rm -v node_modules/node-gyp* 2>/dev/null && echo "rm VERBOSE OK" || echo "**EACCES"=== BEFORE rm ===" && ls -la node_modules/node-gyp* 2> /dev/null || echo "NO node-gyp"*"
            **EACCES=== BEFORE rm === && ls -la node_modules/node-gyp* 2> /dev/null || echo NO node-gyp*
            === AFTER rm ===
            insgesamt 80
            • G Gonzokalle
              @crunchip
              === BEFORE rm ===
              insgesamt 80
              === AFTER rm ===
              insgesamt 80
              crunchipC Offline
              crunchipC Offline
              #147
              @Gonzokalle zeig mal die Ausgabe von
              cd /opt/iobroker
              echo '=== VERSIONS ==='
              node -v && npm -v
              echo '=== PATH & GLOBAL ==='
              which node-gyp && node-gyp -v 2>/dev/null || echo 'NO GLOBAL!'
              echo '=== NPM INTERNAL ==='
              npm exec node-gyp -v 2>/dev/null || echo 'NO npm internal!'
              echo '=== NPM CONFIG ==='
              npm config get node_gyp || echo 'NO npm config!'
              echo '=== .BIN SYMLINKS ==='
              ls -la node_modules/.bin/node-gyp* 2>/dev/null || echo 'NO .bin!'
              echo '=== DEPENDENCY TREE ==='
              npm ls node-gyp --depth=0 2>/dev/null || echo 'NO LOCAL deps!'
              echo '=== NPX CACHE ==='
              npm config get cache
              ls -la ~/.npm/_npx/node-gyp* 2>/dev/null || echo 'NO npx cache!'
                cd /opt/iobroker
                node -v && npm -v
                Gonzokalle
                #148
                @crunchip
                node -v && npm -v
                === VERSIONS ===
                v24.12.0
                11.6.2
                NO GLOBAL!
                11.6.2
                === NPM CONFIG ===
                undefined
                lrwxrwxrwx 1 iobroker iobroker 24 27. Dez 10:40 node_modules/.bin/node-gyp-build -> ../node-gyp-build/bin.js
                lrwxrwxrwx 1 iobroker iobroker 29 27. Dez 10:40 node_modules/.bin/node-gyp-build-optional -> ../node-gyp-build/optional.js
                lrwxrwxrwx 1 iobroker iobroker 31 27. Dez 10:40 node_modules/.bin/node-gyp-build-test -> ../node-gyp-build/build-test.js
                iobroker.inst@3.0.0 /opt/iobroker
                └── (empty)
                NO LOCAL deps!
                === NPX CACHE ===
                /home/iobroker/.npm
                NO npx cache!
                • G Gonzokalle
                  @crunchip
                  node -v && npm -v
                  === VERSIONS ===
                  v24.12.0
                  11.6.2
                  NO GLOBAL!
                  11.6.2
                  === NPM CONFIG ===
                  undefined
                  └── (empty)
                  NO LOCAL deps!
                  === NPX CACHE ===
                  /home/iobroker/.npm
                  NO npx cache!
                  crunchipC Offline
                  crunchipC Offline
                  #149
                  @Gonzokalle mach noch ein
                  find /opt/iobroker /home/iobroker -name "*node-gyp*7*" 2>/dev/null
                    Gonzokalle
                    #150
                    @crunchip
                    martin@RaspberryPi-Iobroker:~ $ find /opt/iobroker /home/iobroker -name "*node-gyp*7*" 2>/dev/null
                    • G Gonzokalle
                      @crunchip
                      crunchipC Offline
                      crunchipC Offline
                      #151
                      @Gonzokalle dann probier es mal so
                      cd /opt/iobroker
                      npm install -g node-gyp@latest && npm config set node_gyp $(which node-gyp) && node-gyp -v && iobroker add rpi2@latest --unsafe-permissions
                        cd /opt/iobroker
                        Gonzokalle
                        #152
                        @crunchip
                        npm error code EACCES
                        npm error syscall mkdir
                        npm error path /usr/lib/node_modules/node-gyp
                        npm error errno -13
                        npm error Error: EACCES: permission denied, mkdir '/usr/lib/node_modules/node-gyp'
                        npm error     at async mkdir (node:internal/fs/promises:861:10)
                        npm error     at async /usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:576:20
                        npm error     at async Promise.allSettled (index 0)
                        npm error     at async [reifyPackages] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:313:11)
                        npm error     at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:125:5)
                        npm error     at async Install.exec (/usr/lib/node_modules/npm/lib/commands/install.js:150:5)
                        npm error     at async Npm.exec (/usr/lib/node_modules/npm/lib/npm.js:208:9)
                        npm error     at async module.exports (/usr/lib/node_modules/npm/lib/cli/entry.js:67:5) {
                        npm error   errno: -13,
                        npm error   code: 'EACCES',
                        npm error   syscall: 'mkdir',
                        npm error   path: '/usr/lib/node_modules/node-gyp'
                        npm error }
                        npm error
                        npm error The operation was rejected by your operating system.
                        npm error It is likely you do not have the permissions to access this file as the current user
                        npm error
                        npm error If you believe this might be a permissions issue, please double-check the
                        npm error permissions of the file and its containing directories, or try running
                        npm error the command again as root/Administrator.
                        npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-31T10_12_56_377Z-debug-0.log
                        crunchipC HomoranH 2 Antworten Letzte Antwort
                        • G Gonzokalle
                          @crunchip
                          npm error errno -13
                          npm error }
                          npm error
                          npm error
                          crunchipC Offline
                          crunchipC Offline
                          #153
                          @Gonzokalle
                          sudo npm install -g node-gyp@latest
                          node-gyp -v
                          • G Gonzokalle
                            @crunchip
                            npm error errno -13
                            npm error }
                            npm error
                            npm error
                            #154
                            das passt ja zu
                            @crunchip sagte in RPI2 Adapter kann nicht installiert werden:
                            Welche Rechte müsste martin denn haben?
                              das passt ja zu
                              crunchipC Offline
                              crunchipC Offline
                              #155
                              @Homoran Global npm braucht sudo für /usr/lib/node_modules/
                                @Gonzokalle
                                node-gyp -v
                                #156
                                @crunchip ehrlich?
                                npm mit sudo??
                                nicht dass ich weiss wovon ich rede 😉
                                aber ich denke das soll man nicht (und dann noch global)
                                  #157
                                  @crunchip ok!
                                  dann vergiss auch meinen letzten Post
                                    @crunchip ehrlich?
                                    npm mit sudo??
                                    crunchipC Offline
                                    crunchipC Offline
                                    #158
                                    @Homoran sagte in RPI2 Adapter kann nicht installiert werden:
                                    sollte man auch eigentlich nicht
                                      Gonzokalle
                                      #159
                                      @crunchip
                                      martin@RaspberryPi-Iobroker:/opt/iobroker $ sudo npm install -g node-gyp@latest
                                      node-gyp -v
                                      added 63 packages in 4s
                                      npm notice
                                      npm notice New minor version of npm available! 11.6.2 -> 11.7.0
                                      npm notice Changelog: https://github.com/npm/cli/releases/tag/v11.7.0
                                      npm notice To update run: npm install -g npm@11.7.0
                                      npm notice
                                      npm error `node_gyp` is not a valid npm option
                                      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-31T11_07_23_201Z-debug-0.log
                                      v12.1.0
                                      NPM version: 11.6.2
                                      npm error code 6
                                      npm error (node:266019) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                                      npm error (Use `node --trace-deprecation ...` to show where the warning was created)
                                      npm error gyp ERR! Completion callback never invoked!
                                      npm error gyp ERR! System Linux 6.12.47+rpt-rpi-2712
                                      npm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
                                      npm error gyp ERR! cwd /opt/iobroker/node_modules/opengpio
                                      npm error gyp ERR! node -v v24.12.0
                                      npm error gyp ERR! node-gyp -v v7.1.2
                                      npm error gyp ERR! Node-gyp failed to build your package.
                                      npm error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
                                      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-31T11_07_24_740Z-debug-0.log
                                      HomoranH crunchipC 2 Antworten Letzte Antwort
                                      • G Gonzokalle
                                        @crunchip
                                        node-gyp -v
                                        npm notice
                                        npm notice
                                        v12.1.0
                                        NPM version: 11.6.2
                                        npm error code 6
                                        #160
                                        ich denke da muss ein Bindestrich hin
                                        @crunchip ??
                                        • G Gonzokalle
                                          @crunchip
                                          node-gyp -v
                                          npm notice
                                          npm notice
                                          v12.1.0
                                          NPM version: 11.6.2
                                          npm error code 6
                                          crunchipC Offline
                                          crunchipC Offline
                                          #161
                                          @Gonzokalle probier das nun mal
                                          cd /opt/iobroker && npm install node-gyp@latest && ls -la node_modules/.bin/node-gyp* && iobroker add rpi2@latest --unsafe-permissions
