  4. RPI2 Adapter kann nicht installiert werden
    6.4k
167 Beiträge 11 Kommentatoren 13.2k Aufrufe 10 Beobachtet
  • G Gonzokalle
    @Homoran
    Sieht doch ganz gut aus.
    ```bash
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: RaspberryPi-Iobroker
           Icon name: computer
              Kernel: Linux 6.12.47+rpt-rpi-2712
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 5 Model B Rev 1.0
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     15:20:50 up 22:21,  3 users,  load average: 0.53, 0.59, 0.53
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Sun 2025-12-28 15:20:50 CET
               Universal time: Sun 2025-12-28 14:20:50 UTC
                     RTC time: Sun 2025-12-28 14:20:50
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    martin
    HOME=/home/martin
    GROUPS=martin adm dialout cdrom sudo audio video plugdev games users netdev gpio i2c spi render input iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/martin
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         true
    Display-Manager:        * lightdm.service - Light Display Manager
    Desktop:
    Session:                tty
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:            8.5G        3.5G        2.1G         57M        3.0G        4.9G
    Swap:           2.1G          0B        2.1G
    Total:           10G        3.5G        4.3G
    Active iob-Instances:   30
             8063 M total memory
             3358 M used memory
             3263 M active memory
             2224 M inactive memory
             2028 M free memory
              305 M buffer memory
             2511 M swap cache
             2047 M total swap
                0 M used swap
             2047 M free swap
    top - 15:20:51 up 22:21,  3 users,  load average: 0.53, 0.59, 0.53
    Tasks: 248 total,   1 running, 247 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 11.9 us,  2.4 sy,  0.0 ni, 85.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8063.0 total,   2023.0 free,   3364.2 used,   2817.4 buff/cache
    MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   4698.9 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     1.6G   15M  1.6G   1% /run
    /dev/nvme0n1p2 ext4      917G   11G  869G   2% /
    tmpfs          tmpfs     4.0G  368K  4.0G   1% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    tmpfs          tmpfs     4.0G   19M  4.0G   1% /tmp
    /dev/nvme0n1p1 vfat      510M   86M  425M  17% /boot/firmware
    tmpfs          tmpfs     807M  256K  807M   1% /run/user/1000
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA10.service
    [Sat Dec 27 16:58:55 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 iommu_dma_numa_policy=interleave smsc95xx.macaddr=2C:CF:67:82:17:A3 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=e4c2f3ef-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
    [Sat Dec 27 16:58:56 2025] EXT4-fs (nvme0n1p2): orphan cleanup on readonly fs
    [Sat Dec 27 16:58:56 2025] EXT4-fs (nvme0n1p2): mounted filesystem d6944274-f2f7-4644-96a4-213c3b367f5c ro with ordered data mode. Quota mode: none.
    [Sat Dec 27 16:58:57 2025] EXT4-fs (nvme0n1p2): re-mounted d6944274-f2f7-4644-96a4-213c3b367f5c r/w.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/nvme0n1p2 ext4   rw,noatime
    `-/boot/firmware /dev/nvme0n1p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.5G    /var/
    251M    /var/cache
    238M    /var/cache/apt
    221M    /var/lib
    154M    /var/lib/apt
    Archived and active journals take up 8M in the file system.
    /opt/iobroker/backups:
    98M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    988M    /opt/iobroker/iobroker-data/
    496M    /opt/iobroker/iobroker-data/history
    319M    /opt/iobroker/iobroker-data/files
    124M    /opt/iobroker/iobroker-data/backup-objects
    67M     /opt/iobroker/iobroker-data/files/echarts.admin
    42M     /opt/iobroker/iobroker-data/objects.jsonl
    26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
    26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.70a15e1f.js.map
    18M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.5fe9c7da.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-SHK_JeeLink_LaCrosse-if00-port0
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2469419-if00
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v24.12.0
    /usr/bin/node           v24.12.0
    /usr/bin/npm            11.6.2
    /usr/bin/npx            11.6.2
    /usr/bin/corepack       0.34.5
    nodejs:
      Installed: 24.12.0-1nodesource1
      Candidate: 24.12.0-1nodesource1
      Version table:
     *** 24.12.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages
         24.11.1-1nodesource1 1001
         24.11.0-1nodesource1 1001
         24.10.0-1nodesource1 1001
         24.9.0-1nodesource1 1001
         24.8.0-1nodesource1 1001
         24.7.0-1nodesource1 1001
         24.6.0-1nodesource1 1001
         24.5.0-1nodesource1 1001
         24.4.1-1nodesource1 1001
         24.4.0-1nodesource1 1001
         24.3.0-1nodesource1 1001
         24.1.0-1nodesource1 1001
         24.0.2-1nodesource1 1001
         24.0.1-1nodesource1 1001
         24.0.0-1nodesource1 1001
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    RaspberryPi-Iobroker RaspberryPi-Iobroker (version: 7.0.7, hostname: RaspberryPi-Iobroker, alive, uptime: 7712)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.19
    javascript:     9.0.11
    nodejs modules from github:     1
    +-- iobroker.eusec@2.0.3 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.eusec.git#f625cbb12aea40dcf6faf11a17d93328f069b753)
    Adapter State
    + system.adapter.admin.0                  : admin                 : RaspberryPi-Iobroker                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.backitup.0               : backitup              : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.device-watcher.0         : device-watcher        : RaspberryPi-Iobroker                     -  enabled
      system.adapter.devices.0                : devices               : RaspberryPi-Iobroker                     - disabled
    + system.adapter.echarts.0                : echarts               : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.eusec.0                  : eusec                 : RaspberryPi-Iobroker                     -  enabled
      system.adapter.flot.0                   : flot                  : RaspberryPi-Iobroker                     - disabled
    + system.adapter.fullybrowser.0           : fullybrowser          : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.history.0                : history               : RaspberryPi-Iobroker                     -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : RaspberryPi-Iobroker                     - disabled
    + system.adapter.iot.0                    : iot                   : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.iqontrol.0               : iqontrol              : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.iqontrol.1               : iqontrol              : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.javascript.0             : javascript            : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.jeelink.0                : jeelink               : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : RaspberryPi-Iobroker                     -  enabled, port: 1884, bind: 0.0.0.0
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.opendtu.0                : opendtu               : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.opendtu.1                : opendtu               : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.radar2.0                 : radar2                : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.reolink.0                : reolink               : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.reolink.1                : reolink               : RaspberryPi-Iobroker                     -  enabled
      system.adapter.reolink.2                : reolink               : RaspberryPi-Iobroker                     - disabled
    + system.adapter.reolink.3                : reolink               : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.shelly.0                 : shelly                : RaspberryPi-Iobroker                     -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.smartgarden.0            : smartgarden           : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.sonoff.0                 : sonoff                : RaspberryPi-Iobroker                     -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.telegram.0               : telegram              : RaspberryPi-Iobroker                     -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.terminal.0               : terminal              : RaspberryPi-Iobroker                     -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.web.0                    : web                   : RaspberryPi-Iobroker                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.wled.0                   : wled                  : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.zigbee.0                 : zigbee                : RaspberryPi-Iobroker                     -  enabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2469419-if00
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.19   , installed 7.7.19
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "backitup"     : 3.3.10   , installed 3.3.10
    Adapter    "device-watcher": 2.13.1  , installed 2.13.1
    Adapter    "devices"      : 1.2.8    , installed 1.2.8
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
    Adapter    "eusec"        : 2.0.3    , installed 2.0.3
    Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
    Adapter    "iot"          : 5.0.7    , installed 5.0.7
    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
    Adapter    "javascript"   : 9.0.11   , installed 9.0.11
    Adapter    "jeelink"      : 1.2.5    , installed 1.2.5
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "netatmo-crawler": 1.1.0  , installed 1.1.0
    Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
    Adapter    "radar2"       : 2.4.0    , installed 2.4.0
    Adapter    "reolink"      : 1.2.3    , installed 1.2.3
    Adapter    "shelly"       : 10.4.1   , installed 10.4.1
    Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "wled"         : 0.7.2    , installed 0.7.2
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Adapter    "zigbee"       : 3.1.5    , installed 3.2.5
    Objects and States
    Objects:        6945
    States:         5883
    W: https://deb.nodesource.com/node_24.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://archive.raspberrypi.com/debian trixie InRelease
    Hit:3 http://deb.debian.org/debian trixie-updates InRelease
    Hit:4 http://deb.debian.org/debian-security trixie-security InRelease
    Hit:5 https://deb.nodesource.com/node_24.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       1679096    51906/io.mqtt.0
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       1679168    51999/io.shelly.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       1681214    52018/io.sonoff.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1679520    51393/iobroker.js-c
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1679525    51393/iobroker.js-c
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          589619     18907/cupsd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          10440      1000/sshd: /usr/sbi
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4716       1/init
    tcp6       0      0 :::1984                 :::*                    LISTEN      1001       1681677    51883/go2rtc
    tcp6       0      0 :::5900                 :::*                    LISTEN      985        8967       1014/wayvnc
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          589618     18907/cupsd
    tcp6       0      0 :::8554                 :::*                    LISTEN      1001       1679923    51883/go2rtc
    tcp6       0      0 :::8555                 :::*                    LISTEN      1001       1681679    51883/go2rtc
    tcp6       0      0 :::21                   :::*                    LISTEN      0          8913       1001/vsftpd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          10442      1000/sshd: /usr/sbi
    tcp6       0      0 :::111                  :::*                    LISTEN      0          138        1/init
    tcp6       0      0 :::8088                 :::*                    LISTEN      1001       1682622    52264/io.terminal.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1679579    51415/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1683698    52283/io.web.0
    tcp6       0      0 :::3000                 :::*                    LISTEN      1001       1681715    51891/io.fullybrows
    udp        0      0 0.0.0.0:49674           0.0.0.0:*                           101        769        710/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1682326    52303/io.wled.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        767        710/avahi-daemon: r
    udp        0      0 0.0.0.0:35232           0.0.0.0:*                           1001       1681024    51868/io.eusec.0
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       1681089    51951/io.radar2.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          137        1/init
    udp6       0      0 :::5353                 :::*                                101        768        710/avahi-daemon: r
    udp6       0      0 :::48540                :::*                                101        770        710/avahi-daemon: r
    udp6       0      0 :::111                  :::*                                0          4717       1/init
    udp6       0      0 :::8555                 :::*                                1001       1681680    51883/go2rtc
    2025-12-28 15:19:31.127  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: WR2000 ist noch gesperrt
    2025-12-28 15:19:41.213  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 14 ▫ 13<>15 ▫ 14
    2025-12-28 15:19:41.213  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
    2025-12-28 15:19:51.098  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: WR600 auf 34% (200W)
    2025-12-28 15:19:51.098  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 14 ▫ 13<>15 ▫ 15
    2025-12-28 15:19:51.098  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
    2025-12-28 15:20:01.124  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 15 ▫ 14<>17 ▫ 14
    2025-12-28 15:20:01.124  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
    2025-12-28 15:20:11.163  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 14 ▫ 13<>15 ▫ 15
    2025-12-28 15:20:11.163  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
    2025-12-28 15:20:21.095  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 14 ▫ 13<>15 ▫ 16
    2025-12-28 15:20:31.167  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 16 ▫ 14<>18 ▫ 16
    2025-12-28 15:20:31.167  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
    2025-12-28 15:20:41.125  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 16 ▫ 14<>18 ▫ 14
    2025-12-28 15:20:41.125  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
    2025-12-28 15:20:49.009  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 in version "1.1.0" started with pid 57839
    2025-12-28 15:20:51.177  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 16 ▫ 14<>18 ▫ 14
    2025-12-28 15:20:51.178  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
    2025-12-28 15:21:01.159  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 16 ▫ 14<>18 ▫ 14
    2025-12-28 15:21:01.159  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
    2025-12-28 15:21:01.601  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 having pid 57839 terminated with code 0 (NO_ERROR)
    2025-12-28 15:21:11.348  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 16 ▫ 14<>18 ▫ 14
    2025-12-28 15:21:11.348  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
    2025-12-28 15:21:21.491  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: 16 ▫ 14<>18 ▫ 15
    2025-12-28 15:21:21.491  - info: javascript.0 (51489) script.js.PV:_Null_2_WR_autoSperre: keine Änderung, Limit WR2000 bleibt gleich
    iob diag has finished.
    #91
    @Gonzokalle sagte in RPI2 Adapter kann nicht installiert werden:
    Stell das auf Kommandozeilenbetrieb (multi-user) um.
    Mit dem Dateisystem stimmt was nicht. Es sollten keine orphans beseitigt werden müssen. Nicht bei einem sauberen Bootvorgang.
    Installier den eusec-Adapter nochmal aus dem Repo, nicht aus dem GitHub.
    Mach das Null_2_WR_autoSperre-Skript weniger geschwätzig. Das kübelt dir ja das komplette Log dicht.
    G 1 Antwort Letzte Antwort
    • G Gonzokalle
      @Homoran
      ```bash
      Script v.2025-08-09
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                    NTP service: active
                RTC in local TZ: no
      martin
      HOME=/home/martin
      iobroker
      HOME=/home/iobroker
      Desktop:
      Session:                tty
      *** MEMORY ***
      Swap:           2.1G          0B        2.1G
               8063 M total memory
               3358 M used memory
               2028 M free memory
                305 M buffer memory
               2511 M swap cache
               2047 M total swap
                  0 M used swap
               2047 M free swap
      *** FILESYSTEM ***
      /var:
      2.5G    /var/
      251M    /var/cache
      238M    /var/cache/apt
      221M    /var/lib
      154M    /var/lib/apt
      USB-Devices by-id:
      HINT:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            11.6.2
      /usr/bin/npx            11.6.2
      nodejs:
        Version table:
           20.19.2+dfsg-1 500
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.7.19
      javascript:     9.0.11
      Adapter State
      + instance is alive
      Objects and States
      Objects:        6945
      States:         5883
      Pending Updates: 0
      #92
      was nodejs v24 angeht, ja!
      aber
      den brauchst du nur, wenn daran eine visu direkt am Server gezeigt werden soll
      stell das um, das verhindert mögliche Probleme.
      und am schlimmsten
      De7n Dateisystem hat einen Schuss!
      womöglich kommen deine Probleme daher
        Gonzokalle
        #93
        @Thomas-Braun
        Desktop ist aus
        Eusec ist aus dem Repo
        Log ausgeschaltet
        ```bash
        Script v.2025-08-09
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        OS is similar to:
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
         16:31:10 up 15 min,  2 users,  load average: 1.62, 0.64, 0.33
        CPU threads: 4
        Current issues:
                       Local time: Sun 2025-12-28 16:31:10 CET
                   Universal time: Sun 2025-12-28 15:31:10 UTC
                         RTC time: Sun 2025-12-28 15:31:10
                      NTP service: active
                  RTC in local TZ: no
        martin
        HOME=/home/martin
        iobroker
        HOME=/home/iobroker
        Display-Server:         false
        Desktop:
        Session:                tty
        *** MEMORY ***
        Mem:            8.5G        3.2G        4.2G         26M        1.2G        5.3G
        Swap:           2.1G          0B        2.1G
        Total:           10G        3.2G        6.3G
                 8063 M total memory
                 3021 M used memory
                 2865 M active memory
                  758 M inactive memory
                 3985 M free memory
                  131 M buffer memory
                 1035 M swap cache
                 2047 M total swap
                    0 M used swap
                 2047 M free swap
        top - 16:31:10 up 15 min,  2 users,  load average: 1.62, 0.64, 0.33
        Tasks: 221 total,   2 running, 219 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 25.0 us,  6.8 sy,  0.0 ni, 65.9 id,  0.0 wa,  0.0 hi,  2.3 si,  0.0 st
        MiB Mem :   8063.0 total,   3984.8 free,   3022.7 used,   1167.7 buff/cache
        MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   5040.3 avail Mem
        *** FILESYSTEM ***
        tmpfs          tmpfs     1.6G   16M  1.6G   1% /run
        tmpfs          tmpfs     4.0G   32K  4.0G   1% /dev/shm
        tmpfs          tmpfs     4.0G  9.3M  4.0G   1% /tmp
        tmpfs          tmpfs     807M  240K  807M   1% /run/user/1000
        [Sun Dec 28 16:16:07 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 iommu_dma_numa_policy=interleave smsc95xx.macaddr=2C:CF:67:82:17:A3 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=e4c2f3ef-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
        [Sun Dec 28 16:16:09 2025] EXT4-fs (nvme0n1p2): orphan cleanup on readonly fs
        [Sun Dec 28 16:16:09 2025] EXT4-fs (nvme0n1p2): mounted filesystem d6944274-f2f7-4644-96a4-213c3b367f5c ro with ordered data mode. Quota mode: none.
        [Sun Dec 28 16:16:09 2025] EXT4-fs (nvme0n1p2): re-mounted d6944274-f2f7-4644-96a4-213c3b367f5c r/w.
        /var:
        2.5G    /var/
        251M    /var/cache
        238M    /var/cache/apt
        221M    /var/lib
        154M    /var/lib/apt
        Archived and active journals take up 9.3M in the file system.
        982M    /opt/iobroker/iobroker-data/
        35M     /opt/iobroker/iobroker-data/objects.jsonl
        USB-Devices by-id:
        HINT:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            11.6.2
        /usr/bin/npx            11.6.2
        nodejs:
          Version table:
             20.19.2+dfsg-1 500
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        RaspberryPi-Iobroker RaspberryPi-Iobroker (version: 7.0.7, hostname: RaspberryPi-Iobroker, alive, uptime: 902)
        admin:          7.7.19
        javascript:     9.0.11
        nodejs modules from github:     0
        Adapter State
        + instance is alive
        Objects and States
        Objects:        6930
        States:         5930
        Pending Updates: 0
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       10519      958/iobroker.js-con
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       10514      958/iobroker.js-con
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          9375       957/cupsd
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4355       1/init
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11285      980/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       12414      1705/io.shelly.0
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       14349      1725/io.sonoff.0
        tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       11224      1613/io.mqtt.0
        tcp6       0      0 :::3000                 :::*                    LISTEN      1001       11205      1598/io.fullybrowse
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       12958      1993/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       11398      1033/io.admin.0
        tcp6       0      0 :::8088                 :::*                    LISTEN      1001       12911      1973/io.terminal.0
        tcp6       0      0 :::111                  :::*                    LISTEN      0          4356       1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          11293      980/sshd: /usr/sbin
        tcp6       0      0 :::21                   :::*                    LISTEN      0          9142       968/vsftpd
        tcp6       0      0 :::8554                 :::*                    LISTEN      1001       11179      1589/go2rtc
        tcp6       0      0 :::8555                 :::*                    LISTEN      1001       11180      1589/go2rtc
        tcp6       0      0 :::5900                 :::*                    LISTEN      985        7569       1001/wayvnc
        tcp6       0      0 :::1984                 :::*                    LISTEN      1001       8133       1589/go2rtc
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          9374       957/cupsd
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       12986      2011/io.wled.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        7190       712/avahi-daemon: r
        udp        0      0 0.0.0.0:36000           0.0.0.0:*                           101        7192       712/avahi-daemon: r
        udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       11994      1662/io.radar2.0
        udp        0      0 0.0.0.0:32838           0.0.0.0:*                           1001       11176      1574/io.eusec.0
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          444        1/init
        udp6       0      0 :::5353                 :::*                                101        7191       712/avahi-daemon: r
        udp6       0      0 :::111                  :::*                                0          445        1/init
        udp6       0      0 :::8555                 :::*                                1001       11181      1589/go2rtc
        udp6       0      0 :::41681                :::*                                101        7193       712/avahi-daemon: r
        2025-12-28 16:20:49.009  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 in version "1.1.0" started with pid 2171
        2025-12-28 16:20:53.255  - info: javascript.0 (1169) script.js.Temperaturen_&_Luftfeuchtigkeit.Temp_Terrasse_Status_an_Telegram: telegram: 🌡️ Terrasse unter 5°C
        2025-12-28 16:20:59.220  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 having pid 2171 terminated with code 0 (NO_ERROR)
        2025-12-28 16:21:55.020  - warn: radar2.0 (1662) scanDelay increased to 116.421 seconds, delayAway to 5 minutes!
        2025-12-28 16:25:49.009  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 in version "1.1.0" started with pid 2871
        2025-12-28 16:25:55.257  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 having pid 2871 terminated with code 0 (NO_ERROR)
        2025-12-28 16:28:21.781  - info: device-watcher.0 (1554) Das folgende Gerät ist nicht mehr erreichbar:
        Zigbee:  Licht Terrasse (16:17)
        2025-12-28 16:30:01.968  - info: device-watcher.0 (1554) Das folgende Gerät ist nicht mehr erreichbar:
        WLED:  WLED-Matrix-2 (16:18)
        2025-12-28 16:30:02.060  - info: device-watcher.0 (1554) Das folgende Gerät ist nicht mehr erreichbar:
        WLED:  WLED-Stab-1 (330 Tage)
        2025-12-28 16:30:02.120  - info: device-watcher.0 (1554) Das folgende Gerät ist nicht mehr erreichbar:
        WLED:  WLED-Dachrinne (16:18)
        2025-12-28 16:30:02.173  - info: device-watcher.0 (1554) Das folgende Gerät ist nicht mehr erreichbar:
        WLED:  WLED-Hütte (169 Tage)
        2025-12-28 16:30:02.229  - info: device-watcher.0 (1554) Das folgende Gerät ist nicht mehr erreichbar:
        WLED:  WLED-Matrix-1 (16:18)
        2025-12-28 16:30:02.283  - info: device-watcher.0 (1554) Das folgende Gerät ist nicht mehr erreichbar:
        WLED:  WLED-Stab-2 (330 Tage)
        2025-12-28 16:30:07.398  - info: device-watcher.0 (1554) Das folgende Gerät ist nicht mehr erreichbar:
        WLED:  WLED-SoundReactive (528 Tage)
        2025-12-28 16:30:49.009  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 in version "1.1.0" started with pid 3660
        2025-12-28 16:30:52.090  - info: javascript.0 (1169) script.js.Temperaturen_&_Luftfeuchtigkeit.Temp_Terrasse_Status_an_Telegram: telegram: 🌡️ Terrasse unter 0°C
        2025-12-28 16:31:00.387  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 having pid 3660 terminated with code 0 (NO_ERROR)
        • G Gonzokalle
          @Thomas-Braun
          Desktop ist aus
          Log ausgeschaltet
          ```bash
          Script v.2025-08-09
          *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
          OS is similar to:
          Docker          : false
          Kernel          : aarch64
          Userland        : 64 bit
          CPU threads: 4
          Current issues:
                        NTP service: active
                    RTC in local TZ: no
          martin
          HOME=/home/martin
          iobroker
          HOME=/home/iobroker
          Desktop:
          Session:                tty
          *** MEMORY ***
          Swap:           2.1G          0B        2.1G
                   8063 M total memory
                   3021 M used memory
                   3985 M free memory
                    131 M buffer memory
                   1035 M swap cache
                   2047 M total swap
                      0 M used swap
                   2047 M free swap
          *** FILESYSTEM ***
          /var:
          2.5G    /var/
          251M    /var/cache
          238M    /var/cache/apt
          221M    /var/lib
          154M    /var/lib/apt
          USB-Devices by-id:
          HINT:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            11.6.2
          /usr/bin/npx            11.6.2
          nodejs:
            Version table:
               20.19.2+dfsg-1 500
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.7.19
          javascript:     9.0.11
          Adapter State
          + instance is alive
          Objects and States
          Objects:        6930
          States:         5930
          Pending Updates: 0
          #94
          Ganz frischer Eintrag. Wenn du sauber gebootet hast, dann darf diese Meldung auf einem gesunden Datenträger nicht erscheinen.
          Das ist dann ein starker Hinweis auf einen Defekt.
          HINT:
          Wird ein 'false positive' sein, ich sehe nur nicht warum. Den Code habe ich aber in einer kommenden Version von iob diag an der Stelle geändert.
          Jetzt installier den rpi2 mal:
           iobroker url iobroker.rpi2@latest  --debug
          Edit: Sollte dann so aussehen:
          echad@chet:/opt/iobroker $ iobroker url iobroker.rpi2@latest --debug
          install iobroker.rpi2@latest
          NPM version: 11.6.2
          Installing iobroker.rpi2@latest... (System call)
          up to date in 9s
          254 packages are looking for funding
            run `npm fund` for details
          upload [13] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/de/translations.json i18n/de/translations.json application/json
          upload [12] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/en/translations.json i18n/en/translations.json application/json
          upload [11] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/es/translations.json i18n/es/translations.json application/json
          upload [10] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
          upload [9] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/it/translations.json i18n/it/translations.json application/json
          upload [8] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
          upload [7] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
          upload [6] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
          upload [5] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
          upload [4] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
          upload [3] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
          upload [2] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/jsonConfig.json jsonConfig.json application/json
          upload [1] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/rpi2.png rpi2.png image/png
          upload [0] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/words.js words.js application/javascript
          Updating objects from io-package.json for adapter "rpi2" with version "3.0.2"
            HINT:
            NPM version: 11.6.2
            up to date in 9s
            Gonzokalle
            #95
            @Thomas-Braun sagte in RPI2 Adapter kann nicht installiert werden:
            Ich hatte mit sudo reboot neu gestartet. Kann daher der Eintrag kommen?
            Das sieht wieder schlecht aus.
            Vielleicht sollte ich Trixie einfach nochmal neu aufspielen.
            martin@RaspberryPi-Iobroker:~ $  iobroker url iobroker.rpi2@latest  --debug
            NPM version: 11.6.2
            npm warn deprecated npmlog@4.1.2: This package is no longer supported.
            npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
            npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.
            npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
            npm warn deprecated gauge@2.7.4: This package is no longer supported.
            > iobroker.rpi2@3.0.2 preinstall
            > bash ./preinstall-check.sh
            Checking package: libgpiod-dev >= 2.2
            libgpiod-dev version OK: 2.2.1-2+deb13u1
            > @stoprocent/bluetooth-hci-socket@1.5.2 install
            > node-gyp-build
            > @stoprocent/noble@1.19.1 install
            > node-gyp-build
            gyp info it worked if it ends with ok
            gyp info using node-gyp@7.1.2
            gyp info using node@24.12.0 | linux | arm64
            (node:5501) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
            (Use `node --trace-deprecation ...` to show where the warning was created)
            gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"
            gyp ERR! Completion callback never invoked!
            gyp ERR! System Linux 6.12.47+rpt-rpi-2712
            gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
            gyp ERR! cwd /opt/iobroker/node_modules/@stoprocent/noble
            gyp ERR! node -v v24.12.0
            gyp ERR! node-gyp -v v7.1.2
            gyp ERR! Node-gyp failed to build your package.
            gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
            > authenticate-pam@1.0.5 install
            > node-gyp rebuild
            (node:5517) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
            gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
            gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
            > cpu-features@0.0.10 install
            > node buildcheck.js > buildcheck.gypi && node-gyp rebuild
            (node:5550) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
            gyp ERR! cwd /opt/iobroker/node_modules/cpu-features
            > diskusage@1.2.0 install
            > node-gyp rebuild
            (node:5564) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
            gyp ERR! cwd /opt/iobroker/node_modules/diskusage
            > node-dht-sensor@0.4.5 install
            > node-gyp configure
            (node:5580) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
            gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "configure"
            gyp ERR! cwd /opt/iobroker/node_modules/node-dht-sensor
            > opengpio@2.0.2 install
            > node-gyp rebuild
            (node:5594) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
            gyp ERR! cwd /opt/iobroker/node_modules/opengpio
            npm error code 6
            npm error path /opt/iobroker/node_modules/opengpio
            npm error command failed
            npm error command sh -c node-gyp rebuild
            npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-28T16_00_16_769Z-debug-0.log
            npm error code 6
            host.RaspberryPi-Iobroker Cannot install iobroker.rpi2@latest: 6
            martin@RaspberryPi-Iobroker:~ $ ^C
            • G Gonzokalle
              NPM version: 11.6.2
              > node-gyp-build
              > node-gyp-build
              > node-gyp rebuild
              > node-gyp rebuild
              > node-gyp configure
              > node-gyp rebuild
              npm error code 6
              npm error code 6
              #96
              Grundsätzlich nicht. Dann hat der Datenträger wohl 'nen Schuß.
              Tausch den baldmöglichst aus.
              Auf einem fitten Datenträger.
              Die Meldungen kommen aber nicht vom OS, sondern von npm bzw. node-gyp.
              Keine Ahnung, was da bei dir schief ist.
              Das buildenvironment ist aber okay?
              sudo apt install build-essential python3-dev python3-pip
              versuchen.
              • G Gonzokalle
                NPM version: 11.6.2
                > node-gyp-build
                > node-gyp-build
                > node-gyp rebuild
                > node-gyp rebuild
                > node-gyp configure
                > node-gyp rebuild
                npm error code 6
                npm error code 6
                #97
                nein!
                Da gibt es defekte Dateien, und verwa7ste Reste, die nicht mehr zugeordnet werden können.
                aber nur auf eine neue Speicherkarte
                  versuchen.
                  Gonzokalle
                  #98
                  @Thomas-Braun
                  martin@RaspberryPi-Iobroker:~ $ sudo apt install build-essential python3-dev python3-pip
                  build-essential ist schon die neueste Version (12.12).
                  python3-dev ist schon die neueste Version (3.13.5-1).
                  python3-dev wurde als manuell installiert festgelegt.
                  python3-pip ist schon die neueste Version (25.1.1+dfsg-1+rpt1).
                  python3-pip wurde als manuell installiert festgelegt.
                  Zusammenfassung:
                    Aktualisiere: 0, Installiere: 0, Entferne: 0, Aktualisiere nicht: 0
                  • G Gonzokalle
                    @Thomas-Braun
                    Zusammenfassung:
                    #99
                    @Gonzokalle
                    Und schmeiß den
                    raus. Der funktioniert seit Jahren nicht mehr richtig.
                    iob del terminal --debug
                      nein!
                      Gonzokalle
                      #100
                      @Homoran
                      Ist ne NVME SSD 1TB von Samsung.
                      Erst ein Jahr alt.
                      • crunchipC Abwesend
                        crunchipC Abwesend
                        #101
                        ich würde, wenn der rpi2 unbedingt benötigt wird, eher wieder zurück auf nodejs20 gehen und hoffen, dass bis April 26 das Problem gelöst wird.
                        • G Gonzokalle
                          @Homoran
                          Erst ein Jahr alt.
                          #102
                          Erst ein Jahr alt.
                          und immer ordentlich runtergefahren / unmounted?
                          oder auch mal einfach abgezogen / Stecker raus?
                          BTW wo und wie ist die angeschlossen
                            #103
                            @crunchip sagte in RPI2 Adapter kann nicht installiert werden:
                            Nur das Problem kommt nicht vom rpi2 direkt. Hier läuft der nämlich auf nodejs 20 - 25 einwandfrei auf RaspberryOS 13 'Trixie'.
                            Da hängt noch irgendwas in der Build Pipeline. Deswegen will ich auch den terminal-Adapter loswerden, der wird ja schon geraume Zeit nicht mehr gepflegt.
                              crunchipC Abwesend
                              crunchipC Abwesend
                              #104
                              der Build Pipeline
                              node-gyp 7.1.2 zu alt für Node 22 → cflags-Fehler
                                der Build Pipeline
                                #105
                                @crunchip
                                Das sollte aber eigentlich via nodejs/npm in jeweils passender Version mitgeschleppt werden:
                                echad@chet:/opt/iobroker $ npm ls -g node-gyp
                                /usr/lib
                                └─┬ npm@11.6.2
                                  ├─┬ @npmcli/run-script@10.0.0
                                  │ └── node-gyp@11.4.2 deduped
                                  └── node-gyp@11.4.2
                                  Erst ein Jahr alt.
                                  Gonzokalle
                                  #106
                                  @Homoran
                                  Nur mal Sudo reboot gemacht.
                                  Den Raspi hatte ich ein Jahr nicht gesehen.
                                  Nur, wenn mal Stromausfall war. Vielleicht 2 mal Im Jahr.
                                  Hiermit beschrieben
                                  Das ist im Rasppi
                                  • G Gonzokalle
                                    @Homoran
                                    Hiermit beschrieben
                                    Das ist im Rasppi
                                    #107
                                    Stromausfälle schrotten Datenträger.
                                    Auch bei nur 2x im Jahr.
                                    Was sagt
                                    npm ls -g node-gyp
                                      Was sagt
                                      npm ls -g node-gyp
                                      Gonzokalle
                                      #108
                                      @Thomas-Braun
                                      Habe schon mit dem Energieversorger geschimpft.
                                      martin@RaspberryPi-Iobroker:~ $ npm ls -g node-gyp
                                      /usr/lib
                                      └─┬ npm@11.6.2
                                        └── node-gyp@11.4.2
                                      • G Gonzokalle
                                        @Thomas-Braun
                                        /usr/lib
                                        └─┬ npm@11.6.2
                                          └── node-gyp@11.4.2
                                        #109
                                        @Gonzokalle
                                        Und im Verzeichnis?
                                        cd /opt/iobroker && npm ls node-gyp
                                        Haste jetzt den Adapter terminal rausgeworfen?
                                        Wenn ja, dann ein
                                        npm i
                                        in /opt/iobroker
                                          @crunchip
                                          /usr/lib
                                          └─┬ npm@11.6.2
                                            └── node-gyp@11.4.2
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          #110
                                          soweit ich jetzt nachgelesen habe
                                          1. npm ls -g node-gyp → GLOBAL Store (npm CLI braucht es)
                                          2. npm i rpi2 → LOKAL installiert node-gyp@7.1.2 (wegen noble/opengpio)
                                          3. npm sucht ./node_modules/.bin/node-gyp → findet 7.1.2 → verwendet ES!
                                          4. Global 11.4.2 wird ignoriert (scoped project)
