  4. RPI2 Adapter kann nicht installiert werden
    6.4k
167 Beiträge 11 Kommentatoren 13.2k Aufrufe 10 Beobachtet
  • G Gonzokalle
    @Thomas-Braun sagte in RPI2 Adapter kann nicht installiert werden:
    [Sun Dec 28 16:16:09 2025] EXT4-fs (nvme0n1p2): orphan cleanup on readonly fs
    Ich hatte mit sudo reboot neu gestartet. Kann daher der Eintrag kommen?
    Das sieht wieder schlecht aus.
    Vielleicht sollte ich Trixie einfach nochmal neu aufspielen.
    martin@RaspberryPi-Iobroker:~ $  iobroker url iobroker.rpi2@latest  --debug
    install iobroker.rpi2@latest
    NPM version: 11.6.2
    Installing iobroker.rpi2@latest... (System call)
    npm warn deprecated npmlog@4.1.2: This package is no longer supported.
    npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
    npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.
    npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
    npm warn deprecated gauge@2.7.4: This package is no longer supported.
    > iobroker.rpi2@3.0.2 preinstall
    > bash ./preinstall-check.sh
    Checking package: libgpiod-dev >= 2.2
    libgpiod-dev version OK: 2.2.1-2+deb13u1
    > @stoprocent/bluetooth-hci-socket@1.5.2 install
    > node-gyp-build
    > @stoprocent/noble@1.19.1 install
    > node-gyp-build
    gyp info it worked if it ends with ok
    gyp info using node-gyp@7.1.2
    gyp info using node@24.12.0 | linux | arm64
    (node:5501) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
    (Use `node --trace-deprecation ...` to show where the warning was created)
    gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"
    gyp ERR! Completion callback never invoked!
    gyp ERR! System Linux 6.12.47+rpt-rpi-2712
    gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/@stoprocent/noble
    gyp ERR! node -v v24.12.0
    gyp ERR! node-gyp -v v7.1.2
    gyp ERR! Node-gyp failed to build your package.
    gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
    > authenticate-pam@1.0.5 install
    > node-gyp rebuild
    (node:5517) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
    gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
    > cpu-features@0.0.10 install
    > node buildcheck.js > buildcheck.gypi && node-gyp rebuild
    (node:5550) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
    gyp ERR! cwd /opt/iobroker/node_modules/cpu-features
    > diskusage@1.2.0 install
    > node-gyp rebuild
    (node:5564) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
    gyp ERR! cwd /opt/iobroker/node_modules/diskusage
    > node-dht-sensor@0.4.5 install
    > node-gyp configure
    (node:5580) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
    gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "configure"
    gyp ERR! cwd /opt/iobroker/node_modules/node-dht-sensor
    > opengpio@2.0.2 install
    > node-gyp rebuild
    (node:5594) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
    gyp ERR! cwd /opt/iobroker/node_modules/opengpio
    npm error code 6
    npm error path /opt/iobroker/node_modules/opengpio
    npm error command failed
    npm error command sh -c node-gyp rebuild
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-28T16_00_16_769Z-debug-0.log
    npm error code 6
    host.RaspberryPi-Iobroker Cannot install iobroker.rpi2@latest: 6
    martin@RaspberryPi-Iobroker:~ $ ^C
    #97
    @Gonzokalle sagte in RPI2 Adapter kann nicht installiert werden:
    nein!
    Da gibt es defekte Dateien, und verwa7ste Reste, die nicht mehr zugeordnet werden können.
    aber nur auf eine neue Speicherkarte
    G 1 Antwort Letzte Antwort
      Grundsätzlich nicht. Dann hat der Datenträger wohl 'nen Schuß.
      Tausch den baldmöglichst aus.
      Auf einem fitten Datenträger.
      Die Meldungen kommen aber nicht vom OS, sondern von npm bzw. node-gyp.
      Keine Ahnung, was da bei dir schief ist.
      Das buildenvironment ist aber okay?
      sudo apt install build-essential python3-dev python3-pip
      versuchen.
      Gonzokalle
      #98
      @Thomas-Braun
      martin@RaspberryPi-Iobroker:~ $ sudo apt install build-essential python3-dev python3-pip
      build-essential ist schon die neueste Version (12.12).
      python3-dev ist schon die neueste Version (3.13.5-1).
      python3-dev wurde als manuell installiert festgelegt.
      python3-pip ist schon die neueste Version (25.1.1+dfsg-1+rpt1).
      python3-pip wurde als manuell installiert festgelegt.
      Zusammenfassung:
        Aktualisiere: 0, Installiere: 0, Entferne: 0, Aktualisiere nicht: 0
      • G Gonzokalle
        @Thomas-Braun
        Zusammenfassung:
        #99
        @Gonzokalle
        Und schmeiß den
        system.adapter.terminal.0
        raus. Der funktioniert seit Jahren nicht mehr richtig.
        iob del terminal --debug
          nein!
          Gonzokalle
          #100
          @Homoran
          Ist ne NVME SSD 1TB von Samsung.
          Erst ein Jahr alt.
          • crunchipC Offline
            crunchipC Offline
            #101
            ich würde, wenn der rpi2 unbedingt benötigt wird, eher wieder zurück auf nodejs20 gehen und hoffen, dass bis April 26 das Problem gelöst wird.
            • G Gonzokalle
              @Homoran
              Erst ein Jahr alt.
              #102
              Erst ein Jahr alt.
              und immer ordentlich runtergefahren / unmounted?
              oder auch mal einfach abgezogen / Stecker raus?
              BTW wo und wie ist die angeschlossen
                #103
                @crunchip sagte in RPI2 Adapter kann nicht installiert werden:
                Nur das Problem kommt nicht vom rpi2 direkt. Hier läuft der nämlich auf nodejs 20 - 25 einwandfrei auf RaspberryOS 13 'Trixie'.
                Da hängt noch irgendwas in der Build Pipeline. Deswegen will ich auch den terminal-Adapter loswerden, der wird ja schon geraume Zeit nicht mehr gepflegt.
                  crunchipC Offline
                  crunchipC Offline
                  #104
                  der Build Pipeline
                  node-gyp 7.1.2 zu alt für Node 22 → cflags-Fehler
                    der Build Pipeline
                    #105
                    @crunchip
                    Das sollte aber eigentlich via nodejs/npm in jeweils passender Version mitgeschleppt werden:
                    echad@chet:/opt/iobroker $ npm ls -g node-gyp
                    /usr/lib
                    └─┬ npm@11.6.2
                      ├─┬ @npmcli/run-script@10.0.0
                      │ └── node-gyp@11.4.2 deduped
                      └── node-gyp@11.4.2
                      Erst ein Jahr alt.
                      Gonzokalle
                      #106
                      @Homoran
                      Nur mal Sudo reboot gemacht.
                      Den Raspi hatte ich ein Jahr nicht gesehen.
                      Nur, wenn mal Stromausfall war. Vielleicht 2 mal Im Jahr.
                      Hiermit beschrieben
                      Das ist im Rasppi
                      • G Gonzokalle
                        @Homoran
                        Hiermit beschrieben
                        Das ist im Rasppi
                        #107
                        Stromausfälle schrotten Datenträger.
                        Auch bei nur 2x im Jahr.
                        Was sagt
                        npm ls -g node-gyp
                          Was sagt
                          npm ls -g node-gyp
                          Gonzokalle
                          #108
                          @Thomas-Braun
                          Habe schon mit dem Energieversorger geschimpft.
                          martin@RaspberryPi-Iobroker:~ $ npm ls -g node-gyp
                          /usr/lib
                          └─┬ npm@11.6.2
                            └── node-gyp@11.4.2
                          • G Gonzokalle
                            @Thomas-Braun
                            /usr/lib
                            └─┬ npm@11.6.2
                              └── node-gyp@11.4.2
                            #109
                            @Gonzokalle
                            Und im Verzeichnis?
                            cd /opt/iobroker && npm ls node-gyp
                            Haste jetzt den Adapter terminal rausgeworfen?
                            Wenn ja, dann ein
                            npm i
                            in /opt/iobroker
                              @crunchip
                              /usr/lib
                              └─┬ npm@11.6.2
                                └── node-gyp@11.4.2
                              crunchipC Offline
                              crunchipC Offline
                              #110
                              soweit ich jetzt nachgelesen habe
                              1. npm ls -g node-gyp → GLOBAL Store (npm CLI braucht es)
                              2. npm i rpi2 → LOKAL installiert node-gyp@7.1.2 (wegen noble/opengpio)
                              3. npm sucht ./node_modules/.bin/node-gyp → findet 7.1.2 → verwendet ES!
                              4. Global 11.4.2 wird ignoriert (scoped project)
                                #111
                                @crunchip
                                Das kann nicht sein, denn:
                                echad@chet:/opt/iobroker $ npm ls node-gyp
                                iobroker.inst@3.0.0 /opt/iobroker
                                └── (empty)
                                node-gyp ist nur global installiert. Jedenfalls sollte es das.
                                  @Gonzokalle
                                  Und im Verzeichnis?
                                  Wenn ja, dann ein
                                  npm i
                                  in /opt/iobroker
                                  Gonzokalle
                                  schrieb am zuletzt editiert von Gonzokalle
                                  #112
                                  @Thomas-Braun
                                  imartin@RaspberryPi-Iobroker:~ $ cd /opt/iobroker && npm ls node-gyp
                                  └── (empty)
                                  Ja, ist rausgeflogen.
                                  martin@RaspberryPi-Iobroker:/opt/iobroker $ npm i
                                  up to date in 4s
                                  206 packages are looking for funding
                                    run `npm fund` for details
                                  • G Gonzokalle
                                    @Thomas-Braun
                                    └── (empty)
                                    up to date in 4s
                                    #113
                                    @Gonzokalle Bitte immer die Ein- wie Ausgaben zeigen.
                                    Woher soll ich denn jetzt sehen wo die Meldung (empty) nun herkommt?
                                    npm cache clear --force
                                    Vollständige Ein- wie Ausgaben...
                                      Gonzokalle
                                      #114
                                      @Thomas-Braun
                                      Habe ich oben geändert
                                      martin@RaspberryPi-Iobroker:/opt/iobroker $ npm cache clear --force
                                      npm warn using --force Recommended protections disabled.
                                      NPM version: 11.6.2
                                      > node-gyp-build
                                      > node-gyp-build
                                      (node:10253) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                                      (node:10286) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                                      > node-gyp rebuild
                                      (node:10300) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                                      > node-gyp configure
                                      (node:10316) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                                      > node-gyp rebuild
                                      (node:10330) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                                      npm error code 6
                                      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-28T17_51_41_550Z-debug-0.log
                                      npm error code 6
                                      • G Gonzokalle
                                        @Thomas-Braun
                                        NPM version: 11.6.2
                                        > node-gyp-build
                                        > node-gyp-build
                                        > node-gyp rebuild
                                        > node-gyp configure
                                        > node-gyp rebuild
                                        npm error code 6
                                        npm error code 6
                                        #115
                                        Keine Ahnung wo sich die Kiste diese Version herzieht.
                                        • G Gonzokalle
                                          @Thomas-Braun
                                          NPM version: 11.6.2
                                          > node-gyp-build
                                          > node-gyp-build
                                          > node-gyp rebuild
                                          > node-gyp configure
                                          > node-gyp rebuild
                                          npm error code 6
                                          npm error code 6
                                          #116
                                          @Gonzokalle
                                          ls -l /opt/iobroker/node_modules/.bin/
