  4. RPI2 Adapter kann nicht installiert werden
    6.4k
167 Beiträge 11 Kommentatoren 13.2k Aufrufe 10 Beobachtet
  • G Gonzokalle
    @Thomas-Braun
    Desktop ist aus
    Eusec ist aus dem Repo
    Log ausgeschaltet
    ```bash
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: RaspberryPi-Iobroker
           Icon name: computer
              Kernel: Linux 6.12.47+rpt-rpi-2712
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 5 Model B Rev 1.0
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     16:31:10 up 15 min,  2 users,  load average: 1.62, 0.64, 0.33
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Sun 2025-12-28 16:31:10 CET
               Universal time: Sun 2025-12-28 15:31:10 UTC
                     RTC time: Sun 2025-12-28 15:31:10
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    martin
    HOME=/home/martin
    GROUPS=martin adm dialout cdrom sudo audio video plugdev games users netdev gpio i2c spi render input iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/martin
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Display-Manager:        * lightdm.service - Light Display Manager
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            8.5G        3.2G        4.2G         26M        1.2G        5.3G
    Swap:           2.1G          0B        2.1G
    Total:           10G        3.2G        6.3G
    Active iob-Instances:   30
             8063 M total memory
             3021 M used memory
             2865 M active memory
              758 M inactive memory
             3985 M free memory
              131 M buffer memory
             1035 M swap cache
             2047 M total swap
                0 M used swap
             2047 M free swap
    top - 16:31:10 up 15 min,  2 users,  load average: 1.62, 0.64, 0.33
    Tasks: 221 total,   2 running, 219 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 25.0 us,  6.8 sy,  0.0 ni, 65.9 id,  0.0 wa,  0.0 hi,  2.3 si,  0.0 st
    MiB Mem :   8063.0 total,   3984.8 free,   3022.7 used,   1167.7 buff/cache
    MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   5040.3 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     1.6G   16M  1.6G   1% /run
    /dev/nvme0n1p2 ext4      917G   11G  869G   2% /
    tmpfs          tmpfs     4.0G   32K  4.0G   1% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    tmpfs          tmpfs     4.0G  9.3M  4.0G   1% /tmp
    /dev/nvme0n1p1 vfat      510M   86M  425M  17% /boot/firmware
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    tmpfs          tmpfs     807M  240K  807M   1% /run/user/1000
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA10.service
    [Sun Dec 28 16:16:07 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 iommu_dma_numa_policy=interleave smsc95xx.macaddr=2C:CF:67:82:17:A3 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=e4c2f3ef-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
    [Sun Dec 28 16:16:09 2025] EXT4-fs (nvme0n1p2): orphan cleanup on readonly fs
    [Sun Dec 28 16:16:09 2025] EXT4-fs (nvme0n1p2): mounted filesystem d6944274-f2f7-4644-96a4-213c3b367f5c ro with ordered data mode. Quota mode: none.
    [Sun Dec 28 16:16:09 2025] EXT4-fs (nvme0n1p2): re-mounted d6944274-f2f7-4644-96a4-213c3b367f5c r/w.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/nvme0n1p2 ext4   rw,noatime
    `-/boot/firmware /dev/nvme0n1p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.5G    /var/
    251M    /var/cache
    238M    /var/cache/apt
    221M    /var/lib
    154M    /var/lib/apt
    Archived and active journals take up 9.3M in the file system.
    /opt/iobroker/backups:
    98M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    982M    /opt/iobroker/iobroker-data/
    496M    /opt/iobroker/iobroker-data/history
    319M    /opt/iobroker/iobroker-data/files
    124M    /opt/iobroker/iobroker-data/backup-objects
    67M     /opt/iobroker/iobroker-data/files/echarts.admin
    35M     /opt/iobroker/iobroker-data/objects.jsonl
    26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
    26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.70a15e1f.js.map
    18M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.5fe9c7da.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-SHK_JeeLink_LaCrosse-if00-port0
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2469419-if00
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v24.12.0
    /usr/bin/node           v24.12.0
    /usr/bin/npm            11.6.2
    /usr/bin/npx            11.6.2
    /usr/bin/corepack       0.34.5
    nodejs:
      Installed: 24.12.0-1nodesource1
      Candidate: 24.12.0-1nodesource1
      Version table:
     *** 24.12.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages
         24.11.1-1nodesource1 1001
         24.11.0-1nodesource1 1001
         24.10.0-1nodesource1 1001
         24.9.0-1nodesource1 1001
         24.8.0-1nodesource1 1001
         24.7.0-1nodesource1 1001
         24.6.0-1nodesource1 1001
         24.5.0-1nodesource1 1001
         24.4.1-1nodesource1 1001
         24.4.0-1nodesource1 1001
         24.3.0-1nodesource1 1001
         24.1.0-1nodesource1 1001
         24.0.2-1nodesource1 1001
         24.0.1-1nodesource1 1001
         24.0.0-1nodesource1 1001
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    RaspberryPi-Iobroker RaspberryPi-Iobroker (version: 7.0.7, hostname: RaspberryPi-Iobroker, alive, uptime: 902)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.19
    javascript:     9.0.11
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : RaspberryPi-Iobroker                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.backitup.0               : backitup              : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.device-watcher.0         : device-watcher        : RaspberryPi-Iobroker                     -  enabled
      system.adapter.devices.0                : devices               : RaspberryPi-Iobroker                     - disabled
    + system.adapter.echarts.0                : echarts               : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.eusec.0                  : eusec                 : RaspberryPi-Iobroker                     -  enabled
      system.adapter.flot.0                   : flot                  : RaspberryPi-Iobroker                     - disabled
    + system.adapter.fullybrowser.0           : fullybrowser          : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.history.0                : history               : RaspberryPi-Iobroker                     -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : RaspberryPi-Iobroker                     - disabled
    + system.adapter.iot.0                    : iot                   : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.iqontrol.0               : iqontrol              : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.iqontrol.1               : iqontrol              : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.javascript.0             : javascript            : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.jeelink.0                : jeelink               : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : RaspberryPi-Iobroker                     -  enabled, port: 1884, bind: 0.0.0.0
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.opendtu.0                : opendtu               : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.opendtu.1                : opendtu               : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.radar2.0                 : radar2                : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.reolink.0                : reolink               : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.reolink.1                : reolink               : RaspberryPi-Iobroker                     -  enabled
      system.adapter.reolink.2                : reolink               : RaspberryPi-Iobroker                     - disabled
    + system.adapter.reolink.3                : reolink               : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.shelly.0                 : shelly                : RaspberryPi-Iobroker                     -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.smartgarden.0            : smartgarden           : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.sonoff.0                 : sonoff                : RaspberryPi-Iobroker                     -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.telegram.0               : telegram              : RaspberryPi-Iobroker                     -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.terminal.0               : terminal              : RaspberryPi-Iobroker                     -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.web.0                    : web                   : RaspberryPi-Iobroker                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.wled.0                   : wled                  : RaspberryPi-Iobroker                     -  enabled
    + system.adapter.zigbee.0                 : zigbee                : RaspberryPi-Iobroker                     -  enabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2469419-if00
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.19   , installed 7.7.19
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "backitup"     : 3.3.10   , installed 3.3.10
    Adapter    "device-watcher": 2.13.1  , installed 2.13.1
    Adapter    "devices"      : 1.2.8    , installed 1.2.8
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
    Adapter    "eusec"        : 2.0.3    , installed 2.0.3
    Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
    Adapter    "iot"          : 5.0.7    , installed 5.0.7
    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
    Adapter    "javascript"   : 9.0.11   , installed 9.0.11
    Adapter    "jeelink"      : 1.2.5    , installed 1.2.5
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "netatmo-crawler": 1.1.0  , installed 1.1.0
    Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
    Adapter    "radar2"       : 2.4.0    , installed 2.4.0
    Adapter    "reolink"      : 1.2.3    , installed 1.2.3
    Adapter    "shelly"       : 10.4.1   , installed 10.4.1
    Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "wled"         : 0.7.2    , installed 0.7.2
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Adapter    "zigbee"       : 3.1.5    , installed 3.2.5
    Objects and States
    Objects:        6930
    States:         5930
    W: https://deb.nodesource.com/node_24.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://archive.raspberrypi.com/debian trixie InRelease
    Hit:3 http://deb.debian.org/debian trixie-updates InRelease
    Hit:4 http://deb.debian.org/debian-security trixie-security InRelease
    Hit:5 https://deb.nodesource.com/node_24.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       10519      958/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       10514      958/iobroker.js-con
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          9375       957/cupsd
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4355       1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11285      980/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       12414      1705/io.shelly.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       14349      1725/io.sonoff.0
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       11224      1613/io.mqtt.0
    tcp6       0      0 :::3000                 :::*                    LISTEN      1001       11205      1598/io.fullybrowse
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       12958      1993/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       11398      1033/io.admin.0
    tcp6       0      0 :::8088                 :::*                    LISTEN      1001       12911      1973/io.terminal.0
    tcp6       0      0 :::111                  :::*                    LISTEN      0          4356       1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          11293      980/sshd: /usr/sbin
    tcp6       0      0 :::21                   :::*                    LISTEN      0          9142       968/vsftpd
    tcp6       0      0 :::8554                 :::*                    LISTEN      1001       11179      1589/go2rtc
    tcp6       0      0 :::8555                 :::*                    LISTEN      1001       11180      1589/go2rtc
    tcp6       0      0 :::5900                 :::*                    LISTEN      985        7569       1001/wayvnc
    tcp6       0      0 :::1984                 :::*                    LISTEN      1001       8133       1589/go2rtc
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          9374       957/cupsd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       12986      2011/io.wled.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        7190       712/avahi-daemon: r
    udp        0      0 0.0.0.0:36000           0.0.0.0:*                           101        7192       712/avahi-daemon: r
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       11994      1662/io.radar2.0
    udp        0      0 0.0.0.0:32838           0.0.0.0:*                           1001       11176      1574/io.eusec.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          444        1/init
    udp6       0      0 :::5353                 :::*                                101        7191       712/avahi-daemon: r
    udp6       0      0 :::111                  :::*                                0          445        1/init
    udp6       0      0 :::8555                 :::*                                1001       11181      1589/go2rtc
    udp6       0      0 :::41681                :::*                                101        7193       712/avahi-daemon: r
    2025-12-28 16:20:49.009  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 in version "1.1.0" started with pid 2171
    2025-12-28 16:20:53.255  - info: javascript.0 (1169) script.js.Temperaturen_&_Luftfeuchtigkeit.Temp_Terrasse_Status_an_Telegram: telegram: 🌡️ Terrasse unter 5°C
    2025-12-28 16:20:59.220  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 having pid 2171 terminated with code 0 (NO_ERROR)
    2025-12-28 16:21:55.020  - warn: radar2.0 (1662) scanDelay increased to 116.421 seconds, delayAway to 5 minutes!
    2025-12-28 16:25:49.009  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 in version "1.1.0" started with pid 2871
    2025-12-28 16:25:55.257  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 having pid 2871 terminated with code 0 (NO_ERROR)
    2025-12-28 16:28:21.781  - info: device-watcher.0 (1554) Das folgende Gerät ist nicht mehr erreichbar:
    Zigbee:  Licht Terrasse (16:17)
    2025-12-28 16:30:01.968  - info: device-watcher.0 (1554) Das folgende Gerät ist nicht mehr erreichbar:
    WLED:  WLED-Matrix-2 (16:18)
    2025-12-28 16:30:02.060  - info: device-watcher.0 (1554) Das folgende Gerät ist nicht mehr erreichbar:
    WLED:  WLED-Stab-1 (330 Tage)
    2025-12-28 16:30:02.120  - info: device-watcher.0 (1554) Das folgende Gerät ist nicht mehr erreichbar:
    WLED:  WLED-Dachrinne (16:18)
    2025-12-28 16:30:02.173  - info: device-watcher.0 (1554) Das folgende Gerät ist nicht mehr erreichbar:
    WLED:  WLED-Hütte (169 Tage)
    2025-12-28 16:30:02.229  - info: device-watcher.0 (1554) Das folgende Gerät ist nicht mehr erreichbar:
    WLED:  WLED-Matrix-1 (16:18)
    2025-12-28 16:30:02.283  - info: device-watcher.0 (1554) Das folgende Gerät ist nicht mehr erreichbar:
    WLED:  WLED-Stab-2 (330 Tage)
    2025-12-28 16:30:07.398  - info: device-watcher.0 (1554) Das folgende Gerät ist nicht mehr erreichbar:
    WLED:  WLED-SoundReactive (528 Tage)
    2025-12-28 16:30:49.009  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 in version "1.1.0" started with pid 3660
    2025-12-28 16:30:52.090  - info: javascript.0 (1169) script.js.Temperaturen_&_Luftfeuchtigkeit.Temp_Terrasse_Status_an_Telegram: telegram: 🌡️ Terrasse unter 0°C
    2025-12-28 16:31:00.387  - info: host.RaspberryPi-Iobroker instance system.adapter.netatmo-crawler.0 having pid 3660 terminated with code 0 (NO_ERROR)
    iob diag has finished.
    #94
    @Gonzokalle sagte in RPI2 Adapter kann nicht installiert werden:
    Ganz frischer Eintrag. Wenn du sauber gebootet hast, dann darf diese Meldung auf einem gesunden Datenträger nicht erscheinen.
    Das ist dann ein starker Hinweis auf einen Defekt.
    HINT:
    Wird ein 'false positive' sein, ich sehe nur nicht warum. Den Code habe ich aber in einer kommenden Version von iob diag an der Stelle geändert.
    Jetzt installier den rpi2 mal:
     iobroker url iobroker.rpi2@latest  --debug
    Edit: Sollte dann so aussehen:
    echad@chet:/opt/iobroker $ iobroker url iobroker.rpi2@latest --debug
    install iobroker.rpi2@latest
    NPM version: 11.6.2
    Installing iobroker.rpi2@latest... (System call)
    up to date in 9s
    254 packages are looking for funding
      run `npm fund` for details
    upload [13] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [12] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [11] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [10] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [9] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [8] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [7] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [6] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [5] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [4] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    upload [3] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [2] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/jsonConfig.json jsonConfig.json application/json
    upload [1] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/rpi2.png rpi2.png image/png
    upload [0] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/words.js words.js application/javascript
    Updating objects from io-package.json for adapter "rpi2" with version "3.0.2"
    G 1 Antwort Letzte Antwort
      HINT:
      NPM version: 11.6.2
      up to date in 9s
      Gonzokalle
      #95
      @Thomas-Braun sagte in RPI2 Adapter kann nicht installiert werden:
      Ich hatte mit sudo reboot neu gestartet. Kann daher der Eintrag kommen?
      Das sieht wieder schlecht aus.
      Vielleicht sollte ich Trixie einfach nochmal neu aufspielen.
      martin@RaspberryPi-Iobroker:~ $  iobroker url iobroker.rpi2@latest  --debug
      NPM version: 11.6.2
      npm warn deprecated npmlog@4.1.2: This package is no longer supported.
      npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
      npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.
      npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
      npm warn deprecated gauge@2.7.4: This package is no longer supported.
      > iobroker.rpi2@3.0.2 preinstall
      > bash ./preinstall-check.sh
      Checking package: libgpiod-dev >= 2.2
      libgpiod-dev version OK: 2.2.1-2+deb13u1
      > @stoprocent/bluetooth-hci-socket@1.5.2 install
      > node-gyp-build
      > @stoprocent/noble@1.19.1 install
      > node-gyp-build
      gyp info it worked if it ends with ok
      gyp info using node-gyp@7.1.2
      gyp info using node@24.12.0 | linux | arm64
      (node:5501) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
      (Use `node --trace-deprecation ...` to show where the warning was created)
      gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"
      gyp ERR! Completion callback never invoked!
      gyp ERR! System Linux 6.12.47+rpt-rpi-2712
      gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/@stoprocent/noble
      gyp ERR! node -v v24.12.0
      gyp ERR! node-gyp -v v7.1.2
      gyp ERR! Node-gyp failed to build your package.
      gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
      > authenticate-pam@1.0.5 install
      > node-gyp rebuild
      (node:5517) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
      gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
      > cpu-features@0.0.10 install
      > node buildcheck.js > buildcheck.gypi && node-gyp rebuild
      (node:5550) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
      gyp ERR! cwd /opt/iobroker/node_modules/cpu-features
      > diskusage@1.2.0 install
      > node-gyp rebuild
      (node:5564) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
      gyp ERR! cwd /opt/iobroker/node_modules/diskusage
      > node-dht-sensor@0.4.5 install
      > node-gyp configure
      (node:5580) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
      gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "configure"
      gyp ERR! cwd /opt/iobroker/node_modules/node-dht-sensor
      > opengpio@2.0.2 install
      > node-gyp rebuild
      (node:5594) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
      gyp ERR! cwd /opt/iobroker/node_modules/opengpio
      npm error code 6
      npm error path /opt/iobroker/node_modules/opengpio
      npm error command failed
      npm error command sh -c node-gyp rebuild
      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-28T16_00_16_769Z-debug-0.log
      npm error code 6
      host.RaspberryPi-Iobroker Cannot install iobroker.rpi2@latest: 6
      martin@RaspberryPi-Iobroker:~ $ ^C
      • G Gonzokalle
        NPM version: 11.6.2
        > node-gyp-build
        > node-gyp-build
        > node-gyp rebuild
        > node-gyp rebuild
        > node-gyp configure
        > node-gyp rebuild
        npm error code 6
        npm error code 6
        #96
        Grundsätzlich nicht. Dann hat der Datenträger wohl 'nen Schuß.
        Tausch den baldmöglichst aus.
        Auf einem fitten Datenträger.
        Die Meldungen kommen aber nicht vom OS, sondern von npm bzw. node-gyp.
        Keine Ahnung, was da bei dir schief ist.
        Das buildenvironment ist aber okay?
        sudo apt install build-essential python3-dev python3-pip
        versuchen.
        • G Gonzokalle
          NPM version: 11.6.2
          > node-gyp-build
          > node-gyp-build
          > node-gyp rebuild
          > node-gyp rebuild
          > node-gyp configure
          > node-gyp rebuild
          npm error code 6
          npm error code 6
          #97
          nein!
          Da gibt es defekte Dateien, und verwa7ste Reste, die nicht mehr zugeordnet werden können.
          aber nur auf eine neue Speicherkarte
            versuchen.
            Gonzokalle
            #98
            @Thomas-Braun
            martin@RaspberryPi-Iobroker:~ $ sudo apt install build-essential python3-dev python3-pip
            build-essential ist schon die neueste Version (12.12).
            python3-dev ist schon die neueste Version (3.13.5-1).
            python3-dev wurde als manuell installiert festgelegt.
            python3-pip ist schon die neueste Version (25.1.1+dfsg-1+rpt1).
            python3-pip wurde als manuell installiert festgelegt.
            Zusammenfassung:
              Aktualisiere: 0, Installiere: 0, Entferne: 0, Aktualisiere nicht: 0
            • G Gonzokalle
              @Thomas-Braun
              Zusammenfassung:
              #99
              @Gonzokalle
              Und schmeiß den
              raus. Der funktioniert seit Jahren nicht mehr richtig.
              iob del terminal --debug
                nein!
                Gonzokalle
                #100
                @Homoran
                Ist ne NVME SSD 1TB von Samsung.
                Erst ein Jahr alt.
                • crunchipC Abwesend
                  crunchipC Abwesend
                  #101
                  ich würde, wenn der rpi2 unbedingt benötigt wird, eher wieder zurück auf nodejs20 gehen und hoffen, dass bis April 26 das Problem gelöst wird.
                  • G Gonzokalle
                    @Homoran
                    Erst ein Jahr alt.
                    #102
                    Erst ein Jahr alt.
                    und immer ordentlich runtergefahren / unmounted?
                    oder auch mal einfach abgezogen / Stecker raus?
                    BTW wo und wie ist die angeschlossen
                      #103
                      @crunchip sagte in RPI2 Adapter kann nicht installiert werden:
                      Nur das Problem kommt nicht vom rpi2 direkt. Hier läuft der nämlich auf nodejs 20 - 25 einwandfrei auf RaspberryOS 13 'Trixie'.
                      Da hängt noch irgendwas in der Build Pipeline. Deswegen will ich auch den terminal-Adapter loswerden, der wird ja schon geraume Zeit nicht mehr gepflegt.
                        crunchipC Abwesend
                        crunchipC Abwesend
                        #104
                        der Build Pipeline
                        node-gyp 7.1.2 zu alt für Node 22 → cflags-Fehler
                          der Build Pipeline
                          #105
                          @crunchip
                          Das sollte aber eigentlich via nodejs/npm in jeweils passender Version mitgeschleppt werden:
                          echad@chet:/opt/iobroker $ npm ls -g node-gyp
                          /usr/lib
                          └─┬ npm@11.6.2
                            ├─┬ @npmcli/run-script@10.0.0
                            │ └── node-gyp@11.4.2 deduped
                            └── node-gyp@11.4.2
                            Erst ein Jahr alt.
                            Gonzokalle
                            #106
                            @Homoran
                            Nur mal Sudo reboot gemacht.
                            Den Raspi hatte ich ein Jahr nicht gesehen.
                            Nur, wenn mal Stromausfall war. Vielleicht 2 mal Im Jahr.
                            Hiermit beschrieben
                            Das ist im Rasppi
                            • G Gonzokalle
                              @Homoran
                              Hiermit beschrieben
                              Das ist im Rasppi
                              #107
                              Stromausfälle schrotten Datenträger.
                              Auch bei nur 2x im Jahr.
                              Was sagt
                              npm ls -g node-gyp
                                Was sagt
                                npm ls -g node-gyp
                                Gonzokalle
                                #108
                                @Thomas-Braun
                                Habe schon mit dem Energieversorger geschimpft.
                                martin@RaspberryPi-Iobroker:~ $ npm ls -g node-gyp
                                /usr/lib
                                └─┬ npm@11.6.2
                                  └── node-gyp@11.4.2
                                • G Gonzokalle
                                  @Thomas-Braun
                                  /usr/lib
                                  └─┬ npm@11.6.2
                                    └── node-gyp@11.4.2
                                  #109
                                  @Gonzokalle
                                  Und im Verzeichnis?
                                  cd /opt/iobroker && npm ls node-gyp
                                  Haste jetzt den Adapter terminal rausgeworfen?
                                  Wenn ja, dann ein
                                  npm i
                                  in /opt/iobroker
                                    @crunchip
                                    /usr/lib
                                    └─┬ npm@11.6.2
                                      └── node-gyp@11.4.2
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    #110
                                    soweit ich jetzt nachgelesen habe
                                    1. npm ls -g node-gyp → GLOBAL Store (npm CLI braucht es)
                                    2. npm i rpi2 → LOKAL installiert node-gyp@7.1.2 (wegen noble/opengpio)
                                    3. npm sucht ./node_modules/.bin/node-gyp → findet 7.1.2 → verwendet ES!
                                    4. Global 11.4.2 wird ignoriert (scoped project)
                                      #111
                                      @crunchip
                                      Das kann nicht sein, denn:
                                      echad@chet:/opt/iobroker $ npm ls node-gyp
                                      iobroker.inst@3.0.0 /opt/iobroker
                                      └── (empty)
                                      node-gyp ist nur global installiert. Jedenfalls sollte es das.
                                        @Gonzokalle
                                        Und im Verzeichnis?
                                        Wenn ja, dann ein
                                        npm i
                                        in /opt/iobroker
                                        Gonzokalle
                                        schrieb am zuletzt editiert von Gonzokalle
                                        #112
                                        @Thomas-Braun
                                        imartin@RaspberryPi-Iobroker:~ $ cd /opt/iobroker && npm ls node-gyp
                                        └── (empty)
                                        Ja, ist rausgeflogen.
                                        martin@RaspberryPi-Iobroker:/opt/iobroker $ npm i
                                        up to date in 4s
                                        206 packages are looking for funding
                                        • G Gonzokalle
                                          @Thomas-Braun
                                          └── (empty)
                                          up to date in 4s
                                          #113
                                          @Gonzokalle Bitte immer die Ein- wie Ausgaben zeigen.
                                          Woher soll ich denn jetzt sehen wo die Meldung (empty) nun herkommt?
                                          npm cache clear --force
                                          Vollständige Ein- wie Ausgaben...
