  4. Wir empfehlen: Node.js 22.x
    5.8k
370 Beiträge 53 Kommentatoren 86.7k Aufrufe 53 Beobachtet
  • BertDerKleineB Offline
    BertDerKleine
    #281
    Ok, danke.
    Das scheint durchgelaufen zu sein ohne Probleme:
    ioBroker nodejs fixer 2026-01-31
    You requested to install latest version from nodejs v22 tree.
    Your current setup is:
    /usr/bin/nodejs 	v22.22.0
    /usr/bin/node 		v22.22.0
    /usr/bin/npm 		10.9.4
    /usr/bin/npx 		10.9.4
    We found these nodejs versions available for installation:
    nodejs:
      Installed: 22.22.0-1nodesource1
      Candidate: 22.22.0-1nodesource1
      Version table:
     *** 22.22.0-1nodesource1 100
            100 /var/lib/dpkg/status
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main arm64 Packages
    Nothing to do - Your installation is using the correct paths.
    You are missing the nodesource.list or
    you want to change your current nodejs version: v22.22.0 ?
    Press <y> to continue or any other key to quit
    Trying to fix your installation now. Please be patient.
    You are running nodejs v22.22.0. Do you want to install latest version from nodejs v.22 tree?
    find: '/run/user/1000/doc': Permission denied
    find: '/run/user/1000/gvfs': Permission denied
    rm: cannot remove '/usr/share/keyrings/nodesource.gpg'$'\n''/etc/apt/keyrings/nodesource.gpg'$'\n''/etc/apt/trusted.gpg.d/nodesource.gpg': No such file or directory
    Stopping ioBroker now
    ioBroker has been stopped
    Removing dfsg-nodejs
    *** These repos are active on your system:
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://deb.debian.org/debian trixie-updates InRelease
    Hit:3 http://phoscon.de/apt/deconz generic InRelease
    Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
    Hit:5 http://deb.debian.org/debian-security trixie-security InRelease
    Reading package lists... Done
    *** Installing ca-certificates, curl and gnupg, just in case they are missing.
    *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
    Package: nodejs
    Pin: origin deb.nodesource.com
    Pin-Priority: 1001
    *** These repos are active after the adjustments:
    Get:6 https://deb.nodesource.com/node_22.x nodistro InRelease [12.1 kB]
    Get:7 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages [9049 B]
    Fetched 21.2 kB in 0s (63.2 kB/s)
    Installing nodejs now!
    Installing latest nodejs v22 release
    SUCCESS!
    v22.22.0 has been installed! You are using the latest nodejs@22 release now!
    COMPATIBILITY CHECK IN PROGRESS (Only a --dry-run! No modules are really changed or added!)
    add fsevents 2.3.3
    add @img/sharp-win32-x64 0.34.5
    add @img/sharp-win32-ia32 0.34.5
    add @img/sharp-win32-arm64 0.34.5
    add @img/sharp-wasm32 0.34.5
    add @img/sharp-linuxmusl-x64 0.34.5
    add @img/sharp-linux-x64 0.34.5
    add @img/sharp-linux-s390x 0.34.5
    add @img/sharp-linux-riscv64 0.34.5
    add @img/sharp-linux-ppc64 0.34.5
    add @img/sharp-linux-arm 0.34.5
    add @img/sharp-libvips-linuxmusl-x64 1.2.4
    add @img/sharp-libvips-linux-x64 1.2.4
    add @img/sharp-libvips-linux-s390x 1.2.4
    add @img/sharp-libvips-linux-riscv64 1.2.4
    add @img/sharp-libvips-linux-ppc64 1.2.4
    add @img/sharp-libvips-linux-arm 1.2.4
    add @img/sharp-libvips-darwin-x64 1.2.4
    add @img/sharp-libvips-darwin-arm64 1.2.4
    add @img/sharp-darwin-x64 0.34.5
    add @img/sharp-darwin-arm64 0.34.5
    add @emnapi/runtime 1.7.1
    added 22 packages in 8s
    309 packages are looking for funding
      run `npm fund` for details
    We tried our best to fix your nodejs. Please run iob diag again to verify.
    *** RESTARTING ioBroker NOW! ***
     Please refresh or restart your browser in a few moments.
    Ein "sudo apt update" danach zeigt jetzt auch keine Fehler mehr.
    Komisch dass der Fehler jetzt überhaupt auftrat, denn vorher gab's den ja nicht.
    • BertDerKleineB BertDerKleine
      Ok, danke.
      /usr/bin/npm 		10.9.4
      /usr/bin/npx 		10.9.4
      nodejs:
        Version table:
           20.19.2+dfsg-1 500
      Package: nodejs
      Pin-Priority: 1001
      SUCCESS!
      add fsevents 2.3.3
      #282
      @BertDerKleine sagte in Wir empfehlen: Node.js 22.x:
      Doch... Das ist schon seit geraumer Zeit angekündigt gewesen, das zum 01. Februar die alten Schlüssel nicht mehr verwendet werden können. Die Meldung sah so aus:
      W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
      Siehe auch hier:
      https://forum.iobroker.net/topic/83744/nodesource-repo-openpgp-signature-verification-failed
      Das ganze ist auch kein Fehler, das ist den aktualisierten Anforderungen an die signatur keys geschuldet.
        Siehe auch hier:
        #283
        @Thomas-Braun Mal wieder interessant was sich eine so genannte KI da wieder zusammenreimt:
        NodeSource kann und darf auf deinem System nicht mehr verwendet werden
          #284
          @Homoran
          (seufz) Ja...
          Wobei der erste Teil
          NodeSource kann und darf auf deinem System nicht mehr verwendet werden (SHA-1-Signatur).
          in Computer-'Logik' sogar stimmt. Die veraltete Signatur verhindert/verbietet eine Installation von aktuellen von nodesource gebackenen Paketen. Der zweite Teil ist natürlich katastrophaler Unsinn.
          nvm ist die offiziell empfohlene Methode für ioBroker, sobald neuere Node-Versionen nötig sind.
          Das Gegenteil ist der Fall. Finger weg von 'nvm', 'n' und sonstigen Vorgehen ein nodejs auf das System zuklatschen.
            @Homoran
            (seufz) Ja...
            #285
            @Thomas-Braun sagte in Wir empfehlen: Node.js 22.x:
            aber nur für das alte Vorgehen, was inzwischen durch die aktualisierte Version / Anpassung des Keys wieder hinfällig ist.
            Ein Hinweis darauf wäre von einer Intelligenz zu erwarten gewesen
              Ok, danke.
              /usr/bin/npm 		10.9.4
              /usr/bin/npx 		10.9.4
              nodejs:
                Version table:
                   20.19.2+dfsg-1 500
              Package: nodejs
              Pin-Priority: 1001
              SUCCESS!
              add fsevents 2.3.3
              #286
              Und ein nochmaliges
              iob nodejs-update
              (ohne Major-Release-Angabe) sollte jetzt zu einem doppelten
              'Nothing to do' in grüner Schrift führen.
              (Und auch zum Hinweis die Finger von nvm, n und Co. zu lassen erscheint dann)
                #287
                @Homoran sagte in Wir empfehlen: Node.js 22.x:
                nodesource hat sich aber auch ewig Zeit gelassen den key anzupassen. Der wurde ja erst 'kurz vor knapp' veröffentlicht.
                So schnell lernt die KI dann wohl nicht dazu.
                R 1 Antwort Letzte Antwort
                  Ich habe eine Frage zum Thema Node.js 22.
                  Ich habe meinen iobroker auf einem recht frisch installierten RaspberrypiOS Trixie am Laufen und Node.js ist v22.22.0
                  Beim update bekomme ich nun folgendes:
                  OK:6 https://deb.nodesource.com/node_22.x nodistro InRelease
                  Fehl:6 https://deb.nodesource.com/node_22.x nodistro InRelease
                    Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound: No binding signature at time 2026-01-23T18:12:38Z because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
                  Alle Pakete sind aktuell.
                  Warnung: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. OpenPGP-Signaturüberprüfung fehlgeschlagen: https://deb.nodesource.com/node_22.x nodistro InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound: No binding signature at time 2026-01-23T18:12:38Z because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
                  Warnung: Fehlschlag beim Holen von https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound: No binding signature at time 2026-01-23T18:12:38Z because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
                  Warnung: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt.
                  Die KI meint jetzt:
                  Stimmt letzteres?
                  Und gibt es irgendwo ausführliche Anweisungen, was genau man da jetzt am besten macht?
                  meuteM Online
                  meuteM Online
                  meute
                  #288
                  Ich habe in dem Thread mitgelesen.
                  Den gleichen Fehler hatte ich auch.
                  Behoben habe ich es auch so:
                  Ganz ausführlich:
                  iob nodejs-update 22
                  und die Rückfragen mit y beantworten.
                  Muss das jetzt jeder ioBroker-Nutzer manuell so beheben?
                  fraenk for friends Code: MATF103
                  • meuteM meute
                    Ganz ausführlich:
                    #289
                    @meute
                    Bitte bezeichnet das NICHT als Fehler! Das ist eine strengere Anforderung an die Qualität der Signatur Keys, KEIN Fehler.
                    Ja. Oder man setzt sich mit seinem Paketmanager auseinander und zieht den Key manuell rein.
                    Irgendwas musst du aber halt machen, sonst kommen keine Updates für Pakete mit veralteten Schlüsseln rein.
                      reutli
                      #290
                      @Thomas-Braun
                      In den meisten Fällen ist es eine Frage des "prompts". Ich habe gerade etwas spezifischer nach einen "iobroker system" gefragt, damm kennt die KI Deine Antworten schon ;o)
                      Ganz gute Antwort, wie ich finde ...
                      Trotzdem, oder gerade deswegen: VORSICHT mit den halluzinierenden KIs dieser Welt bei solchen Aktionen!
                      iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
                      *Wer freundlich ist, dem wird freundlich geholfen *
                      • R reutli
                        @Thomas-Braun
                        #291
                        @reutli sagte in Wir empfehlen: Node.js 22.x:
                        Und die kommt zu 99,9% aus einem Beitrag von mir
                          reutli
                          #292
                          Eben, auch die KI kann von Dir lernen, nicht nur wir ;o)
                          • R reutli
                            #293
                            Irgendwie kann ich der Begeisterung für K(eine) I(ntelligenz) nichts abgewinnen.
                            Um die pseudoschlauen Antworten richtig zu bewerten und einordnen zu können brauchst du zumindest im fraglichen Thema Grundkenntnisse.
                            Ich hab schon mal Code von mir zwecks Verbesserungsvorschlägen durch eine KI gejagt. Wenn es dann einen Aha-Effekt gibt wie "Jetzt wo ich es lese... Na logisch! Verstehe ich und kann das dann künftig selber so machen." macht das ja Sinn. Aber irgendwas einfach nachmachen, weil es die KI ja gesagt hat, wird schon richtig sein, halte ich für brandgefährlich.
                              #294
                              man benötigt erst einmal ausreichend Kenntnisse um den Prompt sauber zu formulieren.
                              Dann braucht es ausreichend Kenntnisse um die Antwort auf Richtigkeit einordnen zu können.
                              Hat man das nicht, läuft einiges möglicherweise so schief und man kann den Grund gar nicht mehr finden.
                              KI ersetzt nicht das notwendige strukturierte Denken!
                              Wenn man das einsetzt, bekommt man es aber fast selber hin.
                              Dieser "Fall" istcein schönes Beidpiel, warum wir KI-Aussagen unbedingt als solche gekennzeichnet haben möchten.
                              • N Offline
                                N Offline
                                noio
                                #295
                                iob nodejs-update reicht aus ....war bei mir so..
                                Greetz
                                • N noio
                                  Greetz
                                  #296
                                  @noio sagte in Wir empfehlen: Node.js 22.x:
                                  Aber nur, wenn da nicht schon v22.22.0 läuft.
                                  Ansonsten wird der Code für die Korrektur nicht durchlaufen und es kommt die (doppelte) Meldung, dass alles okay ist.
                                    reutli
                                    schrieb am zuletzt editiert von reutli
                                    #297
                                    Genau das war mein Ansinnen, das hier zu posten:
                                    1. Ohne sauberes Prompting kommt nur Müll raus, was man in so manchen postings hier ja auch sieht.
                                    2. KI-Aussagen muss man (technisch) bewerten können und dann ggf. als Anregung verstehen. Ohne strukturiertes Nachdenken für Prompt und Ergebnis ist man "des Todes"
                                    3. zum Schmunzeln hat mich die Tatsache gebracht, dass dann aber genau das raus kommt, wass @thomas-braun hier schon lang und breit erklärt hat. Ergo die KI lernt von den wirklich Schlauen 😉
                                    Deshalb ist das Forum hier so wichtig, dann kann die KI was sinnvolles lernen 😂
                                    Ich erlebe es nicht nur hier jeden Tag: "...die KI hat gesagt..." - wer Kinder hat, der weiß wovon ich rede...
                                    • R reutli
                                      #298
                                      ja, die bots sind hier ziemlich aktiv
                                      • J Offline
                                        Josh
                                        #299
                                        Hallo zusammen!
                                        Mein node.js bleibt trotz gemeldeten Update 22.22.0 in der WebGUI, auf der Version 22.20.0 stehen. APT meint, dass keine Update vorhanden sind. NPM macht auch kein Update auf die neuste Version.
                                        /usr/bin/nodejs         v22.20.0
                                        /usr/bin/node           v22.20.0
                                        /usr/bin/npm            10.9.3
                                        /usr/bin/npx            10.9.3
                                        nodejs:
                                          Installed: 22.20.0-1nodesource1
                                          Candidate: 22.20.0-1nodesource1
                                          Version table:
                                         *** 22.20.0-1nodesource1 100
                                             20.19.2+dfsg-1 500
                                                500 http://deb.debian.org/debian trixie/main amd64 Packages
                                        you want to change your current nodejs version: v22.20.0 ?
                                        Wie bringe ich das System dazu das Update durchzuführen?
                                        Intel NUC10i5-32GB-1TB_SSD - Proxmox 9.2 - LXC Debian 13
                                        RPi3B - ZigBee2MQTT - CC2652P
                                        RPi3B - ZigBee2MQTT - CC2538+CC2592
                                        node.js 22.22.3 / NPM 10.9.8
                                        • J Josh
                                          Hallo zusammen!
                                          /usr/bin/npm            10.9.3
                                          /usr/bin/npx            10.9.3
                                          nodejs:
                                            Version table:
                                               20.19.2+dfsg-1 500
                                          #300
                                          @Josh sagte in Wir empfehlen: Node.js 22.x:
                                          Edit: Um genau diese Rückfrage geht es...
