  4. Wir empfehlen: Node.js 22.x
    6.8k
370 Beiträge 53 Kommentatoren 92.7k Aufrufe 53 Beobachtet
  • BertDerKleineB BertDerKleine
    Ok, danke.
    Das scheint durchgelaufen zu sein ohne Probleme:
    ioBroker nodejs fixer 2026-01-31
    You requested to install latest version from nodejs v22 tree.
    Your current setup is:
    /usr/bin/nodejs 	v22.22.0
    /usr/bin/node 		v22.22.0
    /usr/bin/npm 		10.9.4
    /usr/bin/npx 		10.9.4
    We found these nodejs versions available for installation:
    nodejs:
      Installed: 22.22.0-1nodesource1
      Candidate: 22.22.0-1nodesource1
      Version table:
     *** 22.22.0-1nodesource1 100
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main arm64 Packages
    Nothing to do - Your installation is using the correct paths.
    You are missing the nodesource.list or
    you want to change your current nodejs version: v22.22.0 ?
    Press <y> to continue or any other key to quit
    Trying to fix your installation now. Please be patient.
    You are running nodejs v22.22.0. Do you want to install latest version from nodejs v.22 tree?
    find: '/run/user/1000/doc': Permission denied
    find: '/run/user/1000/gvfs': Permission denied
    rm: cannot remove '/usr/share/keyrings/nodesource.gpg'$'\n''/etc/apt/keyrings/nodesource.gpg'$'\n''/etc/apt/trusted.gpg.d/nodesource.gpg': No such file or directory
    Stopping ioBroker now
    ioBroker has been stopped
    Removing dfsg-nodejs
    *** These repos are active on your system:
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://deb.debian.org/debian trixie-updates InRelease
    Hit:3 http://phoscon.de/apt/deconz generic InRelease
    Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
    Hit:5 http://deb.debian.org/debian-security trixie-security InRelease
    Reading package lists... Done
    *** Installing ca-certificates, curl and gnupg, just in case they are missing.
    *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
    Package: nodejs
    Pin: origin deb.nodesource.com
    Pin-Priority: 1001
    *** These repos are active after the adjustments:
    Get:6 https://deb.nodesource.com/node_22.x nodistro InRelease [12.1 kB]
    Get:7 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages [9049 B]
    Fetched 21.2 kB in 0s (63.2 kB/s)
    Installing nodejs now!
    Installing latest nodejs v22 release
    SUCCESS!
    v22.22.0 has been installed! You are using the latest nodejs@22 release now!
    COMPATIBILITY CHECK IN PROGRESS (Only a --dry-run! No modules are really changed or added!)
    add fsevents 2.3.3
    add @img/sharp-win32-x64 0.34.5
    add @img/sharp-win32-ia32 0.34.5
    add @img/sharp-win32-arm64 0.34.5
    add @img/sharp-wasm32 0.34.5
    add @img/sharp-linuxmusl-x64 0.34.5
    add @img/sharp-linux-x64 0.34.5
    add @img/sharp-linux-s390x 0.34.5
    add @img/sharp-linux-riscv64 0.34.5
    add @img/sharp-linux-ppc64 0.34.5
    add @img/sharp-linux-arm 0.34.5
    add @img/sharp-libvips-linuxmusl-x64 1.2.4
    add @img/sharp-libvips-linux-x64 1.2.4
    add @img/sharp-libvips-linux-s390x 1.2.4
    add @img/sharp-libvips-linux-riscv64 1.2.4
    add @img/sharp-libvips-linux-ppc64 1.2.4
    add @img/sharp-libvips-linux-arm 1.2.4
    add @img/sharp-libvips-darwin-x64 1.2.4
    add @img/sharp-libvips-darwin-arm64 1.2.4
    add @img/sharp-darwin-x64 0.34.5
    add @img/sharp-darwin-arm64 0.34.5
    add @emnapi/runtime 1.7.1
    added 22 packages in 8s
    309 packages are looking for funding
      run `npm fund` for details
    We tried our best to fix your nodejs. Please run iob diag again to verify.
    *** RESTARTING ioBroker NOW! ***
     Please refresh or restart your browser in a few moments.
    Ein "sudo apt update" danach zeigt jetzt auch keine Fehler mehr.
    Komisch dass der Fehler jetzt überhaupt auftrat, denn vorher gab's den ja nicht.
    #286
    @BertDerKleine sagte in Wir empfehlen: Node.js 22.x:
    Und ein nochmaliges
    iob nodejs-update
    (ohne Major-Release-Angabe) sollte jetzt zu einem doppelten
    'Nothing to do' in grüner Schrift führen.
    (Und auch zum Hinweis die Finger von nvm, n und Co. zu lassen erscheint dann)
      @Thomas-Braun sagte in Wir empfehlen: Node.js 22.x:
      in Computer-'Logik' sogar stimmt.
      aber nur für das alte Vorgehen, was inzwischen durch die aktualisierte Version / Anpassung des Keys wieder hinfällig ist.
      Ein Hinweis darauf wäre von einer Intelligenz zu erwarten gewesen
      #287
      @Homoran sagte in Wir empfehlen: Node.js 22.x:
      nodesource hat sich aber auch ewig Zeit gelassen den key anzupassen. Der wurde ja erst 'kurz vor knapp' veröffentlicht.
      So schnell lernt die KI dann wohl nicht dazu.
      R 1 Antwort Letzte Antwort
        Ich habe eine Frage zum Thema Node.js 22.
        Ich habe meinen iobroker auf einem recht frisch installierten RaspberrypiOS Trixie am Laufen und Node.js ist v22.22.0
        Beim update bekomme ich nun folgendes:
        OK:6 https://deb.nodesource.com/node_22.x nodistro InRelease
        Fehl:6 https://deb.nodesource.com/node_22.x nodistro InRelease
          Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound: No binding signature at time 2026-01-23T18:12:38Z because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
        Alle Pakete sind aktuell.
        Warnung: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. OpenPGP-Signaturüberprüfung fehlgeschlagen: https://deb.nodesource.com/node_22.x nodistro InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound: No binding signature at time 2026-01-23T18:12:38Z because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
        Warnung: Fehlschlag beim Holen von https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound: No binding signature at time 2026-01-23T18:12:38Z because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
        Warnung: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt.
        Die KI meint jetzt:
        NodeSource kann und darf auf deinem System nicht mehr verwendet werden (SHA-1-Signatur).
        nvm ist die offiziell empfohlene Methode für ioBroker, sobald neuere Node-Versionen nötig sind.
        Stimmt letzteres?
        Und gibt es irgendwo ausführliche Anweisungen, was genau man da jetzt am besten macht?
        meuteM Online
        meuteM Online
        meute
        #288
        Ich habe in dem Thread mitgelesen.
        Den gleichen Fehler hatte ich auch.
        Behoben habe ich es auch so:
        Ganz ausführlich:
        iob nodejs-update 22
        und die Rückfragen mit y beantworten.
        Muss das jetzt jeder ioBroker-Nutzer manuell so beheben?
        fraenk for friends Code: MATF103
        • meuteM meute
          Ganz ausführlich:
          #289
          @meute
          Bitte bezeichnet das NICHT als Fehler! Das ist eine strengere Anforderung an die Qualität der Signatur Keys, KEIN Fehler.
          Ja. Oder man setzt sich mit seinem Paketmanager auseinander und zieht den Key manuell rein.
          Irgendwas musst du aber halt machen, sonst kommen keine Updates für Pakete mit veralteten Schlüsseln rein.
            R Online
            R Online
            reutli
            #290
            @Thomas-Braun
            In den meisten Fällen ist es eine Frage des "prompts". Ich habe gerade etwas spezifischer nach einen "iobroker system" gefragt, damm kennt die KI Deine Antworten schon ;o)
            Ganz gute Antwort, wie ich finde ...
            Trotzdem, oder gerade deswegen: VORSICHT mit den halluzinierenden KIs dieser Welt bei solchen Aktionen!
            iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
            *Wer freundlich ist, dem wird freundlich geholfen *
            • R reutli
              @Thomas-Braun
              #291
              @reutli sagte in Wir empfehlen: Node.js 22.x:
              Und die kommt zu 99,9% aus einem Beitrag von mir
                R Online
                R Online
                reutli
                #292
                Eben, auch die KI kann von Dir lernen, nicht nur wir ;o)
                • R reutli
                  #293
                  Irgendwie kann ich der Begeisterung für K(eine) I(ntelligenz) nichts abgewinnen.
                  Um die pseudoschlauen Antworten richtig zu bewerten und einordnen zu können brauchst du zumindest im fraglichen Thema Grundkenntnisse.
                  Ich hab schon mal Code von mir zwecks Verbesserungsvorschlägen durch eine KI gejagt. Wenn es dann einen Aha-Effekt gibt wie "Jetzt wo ich es lese... Na logisch! Verstehe ich und kann das dann künftig selber so machen." macht das ja Sinn. Aber irgendwas einfach nachmachen, weil es die KI ja gesagt hat, wird schon richtig sein, halte ich für brandgefährlich.
                    #294
                    man benötigt erst einmal ausreichend Kenntnisse um den Prompt sauber zu formulieren.
                    Dann braucht es ausreichend Kenntnisse um die Antwort auf Richtigkeit einordnen zu können.
                    Hat man das nicht, läuft einiges möglicherweise so schief und man kann den Grund gar nicht mehr finden.
                    KI ersetzt nicht das notwendige strukturierte Denken!
                    Wenn man das einsetzt, bekommt man es aber fast selber hin.
                    Dieser "Fall" istcein schönes Beidpiel, warum wir KI-Aussagen unbedingt als solche gekennzeichnet haben möchten.
                    • N Offline
                      N Offline
                      noio
                      #295
                      iob nodejs-update reicht aus ....war bei mir so..
                      Greetz
                      • N noio
                        Greetz
                        #296
                        @noio sagte in Wir empfehlen: Node.js 22.x:
                        Aber nur, wenn da nicht schon v22.22.0 läuft.
                        Ansonsten wird der Code für die Korrektur nicht durchlaufen und es kommt die (doppelte) Meldung, dass alles okay ist.
                          R Online
                          R Online
                          reutli
                          schrieb am zuletzt editiert von reutli
                          #297
                          Genau das war mein Ansinnen, das hier zu posten:
                          1. Ohne sauberes Prompting kommt nur Müll raus, was man in so manchen postings hier ja auch sieht.
                          2. KI-Aussagen muss man (technisch) bewerten können und dann ggf. als Anregung verstehen. Ohne strukturiertes Nachdenken für Prompt und Ergebnis ist man "des Todes"
                          3. zum Schmunzeln hat mich die Tatsache gebracht, dass dann aber genau das raus kommt, wass @thomas-braun hier schon lang und breit erklärt hat. Ergo die KI lernt von den wirklich Schlauen 😉
                          Deshalb ist das Forum hier so wichtig, dann kann die KI was sinnvolles lernen 😂
                          Ich erlebe es nicht nur hier jeden Tag: "...die KI hat gesagt..." - wer Kinder hat, der weiß wovon ich rede...
                          • R reutli
                            #298
                            ja, die bots sind hier ziemlich aktiv
                            • J Offline
                              Josh
                              #299
                              Hallo zusammen!
                              Mein node.js bleibt trotz gemeldeten Update 22.22.0 in der WebGUI, auf der Version 22.20.0 stehen. APT meint, dass keine Update vorhanden sind. NPM macht auch kein Update auf die neuste Version.
                              /usr/bin/nodejs         v22.20.0
                              /usr/bin/node           v22.20.0
                              /usr/bin/npm            10.9.3
                              /usr/bin/npx            10.9.3
                              nodejs:
                                Installed: 22.20.0-1nodesource1
                                Candidate: 22.20.0-1nodesource1
                                Version table:
                               *** 22.20.0-1nodesource1 100
                                   20.19.2+dfsg-1 500
                                      500 http://deb.debian.org/debian trixie/main amd64 Packages
                              you want to change your current nodejs version: v22.20.0 ?
                              Wie bringe ich das System dazu das Update durchzuführen?
                              Intel NUC10i5-32GB-1TB_SSD - Proxmox 9.2 - LXC Debian 13
                              RPi3B - ZigBee2MQTT - CC2652P
                              RPi3B - ZigBee2MQTT - CC2538+CC2592
                              node.js 22.22.3 / NPM 10.9.8
                              • J Josh
                                Hallo zusammen!
                                /usr/bin/npm            10.9.3
                                /usr/bin/npx            10.9.3
                                nodejs:
                                  Version table:
                                     20.19.2+dfsg-1 500
                                #300
                                @Josh sagte in Wir empfehlen: Node.js 22.x:
                                Edit: Um genau diese Rückfrage geht es...
                                • J Offline
                                  Josh
                                  #301
                                  och nööö ... doch nicht so einfach ... ich gehe mich jetzt in die Ecke setzen und schäme mich knirsch
                                  Danke für's in die richtige Richtung schupsen :-)
                                  FabioF 1 Antwort Letzte Antwort
                                  -1
                                  • J Josh
                                    FabioF Offline
                                    FabioF Offline
                                    Fabio
                                    schrieb am zuletzt editiert von Fabio
                                    #302
                                    Hallo @thomas-braun,
                                    bei im Admin steht das ich updaten kann.
                                    Aber es geht weder über die Konsole ein Update, noch über ioBroker Admin.
                                    Weißt du was darüber?
                                    Last login: Mon Mar  9 10:54:13 2026 from 192.168.2.3
                                    fabio@nuc:~$ which nodejs && nodejs -v && which node && node -v && which npm &&                                npm -v && apt policy nodejs
                                    /usr/bin/nodejs
                                    v22.22.0
                                    /usr/bin/node
                                    v22.22.0
                                    /usr/bin/npm
                                    10.9.4
                                    nodejs:
                                      Installiert:           22.22.0-1nodesource1
                                      Installationskandidat: 22.22.0-1nodesource1
                                      Versionstabelle:
                                         20.19.2+dfsg-1 500
                                    Herzliche Grüße
                                    Fabio
                                    Iobroker:
                                    • Matter over Thread Hilfe
                                    • FabioF Fabio
                                      /usr/bin/nodejs
                                      v22.22.0
                                      /usr/bin/node
                                      v22.22.0
                                      /usr/bin/npm
                                      10.9.4
                                      nodejs:
                                        Versionstabelle:
                                           20.19.2+dfsg-1 500
                                      Herzliche Grüße
                                      Fabio
                                      #303
                                      @Fabio sagte in Wir empfehlen: Node.js 22.x:
                                      Vermutlich hast du die aktuellen Schlüssel noch nicht eingespielt.
                                      Was sagt ein
                                      sudo apt update
                                      genau?
                                      Das ganz sollte sich aber per
                                      beheben lassen. Rückfragen mit y bestätigen.
                                        Was sagt ein
                                        sudo apt update
                                        genau?
                                        FabioF Offline
                                        FabioF Offline
                                        Fabio
                                        #304
                                        Was sagt ein
                                        sudo apt update
                                        fabio@nuc:~$ sudo apt update
                                        [sudo] Passwort für fabio:
                                        OK:1 http://deb.debian.org/debian trixie InRelease
                                        OK:2 http://security.debian.org/debian-security trixie-security InRelease
                                        OK:3 http://deb.debian.org/debian trixie-updates InRelease
                                        fabio@nuc:~$
                                        Iobroker:
                                        • FabioF Fabio
                                          Was sagt ein
                                          sudo apt update
                                          fabio@nuc:~$
                                          #305
                                          @Fabio
                                          Da fehlt das nodesource Repository komplett.
                                          Versuch erstmal ein
                                          iob nodejs-update
                                          Wenn das nicht funktioniert, dann die gewünschte Major-Version angeben:
                                          Zeig aber mal die Ausgabe von
                                          iob nodejs-update
                                          zuerst, würde mich interessieren wie das in dem Fall reagiert.
