  4. Test Adapter iobroker.Zigbee 1.10.10
    1.0k
    6.1k
190 Beiträge 19 Kommentatoren 48.3k Aufrufe 23 Beobachtet
  • arteckA arteck
    @amg_666 du hst ein gruppen Problem....
    installier mal bitte
    https://github.com/ioBroker/ioBroker.zigbee/tarball/group-problem
    und Poste mal aus dem log
    PROBLEM1
    und PROBLEM2
    oder am besten das LOG nach dem Adapter start
    amg_666A Offline
    amg_666A Offline
    amg_666
    #101
    @arteck Also ich habe jetzt die Gruppe 901 gelöscht (k.A. ob das was bringt, weil IKEA Devices habe ich auch) und dann habe ich die anderen Gruppen gelöscht, danach neu angelegt und Devices den Gruppen wieder zugeordnet, das hat aber nix gebracht:
    zigbee.2
    	2024-11-07 15:08:30.594	warn	DeviceAvailability:Failed to ping 0x84fd27fffe9b5e43 TRADFRI Signal Repeater
    zigbee.2
    	2024-11-07 15:08:18.790	warn	PROBLEM2: group_2 {"id":"transition_time","name":"Transition time","role":"state","write":true,"read":false,"type":"number","unit":"sec","isOption":true,"readable":true,"writable":true}
    zigbee.2
    	2024-11-07 15:08:18.790	warn	PROBLEM2: group_2 {"id":"colortemp_move","prop":"color_temp_move","name":"Colortemp change","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50,"readable":true,"writable":true}
    zigbee.2
    	2024-11-07 15:08:18.790	warn	PROBLEM2: group_2 {"id":"brightness_move","prop":"brightness_move","name":"Dimming","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50,"readable":true,"writable":true}
    zigbee.2
    	2024-11-07 15:08:18.790	warn	PROBLEM2: group_2 {"id":"color","prop":"color","name":"Color","role":"level.color.rgb","write":true,"read":true,"type":"string"}
    zigbee.2
    	2024-11-07 15:08:18.789	warn	PROBLEM2: group_2 {"id":"colortemp","prop":"color_temp","name":"Color temperature","role":"level.color.temperature","write":true,"read":true,"type":"number"}
    zigbee.2
    	2024-11-07 15:08:18.789	warn	PROBLEM2: group_2 {"id":"brightness","name":"Brightness","role":"level.dimmer","write":true,"read":true,"type":"number","unit":"","min":0,"max":100}
    zigbee.2
    	2024-11-07 15:08:18.789	warn	PROBLEM2: group_2 {"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true}
    zigbee.2
    	2024-11-07 15:08:18.788	warn	PROBLEM2: group_2 {"id":"brightness_step","prop":"brightness_step","name":"Brightness stepping","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50}
    zigbee.2
    	2024-11-07 15:08:18.780	warn	PROBLEM2: group_1 {"id":"transition_time","name":"Transition time","role":"state","write":true,"read":false,"type":"number","unit":"sec","isOption":true,"readable":true,"writable":true}
    zigbee.2
    	2024-11-07 15:08:18.780	warn	PROBLEM2: group_1 {"id":"colortemp_move","prop":"color_temp_move","name":"Colortemp change","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50,"readable":true,"writable":true}
    zigbee.2
    	2024-11-07 15:08:18.780	warn	PROBLEM2: group_1 {"id":"brightness_move","prop":"brightness_move","name":"Dimming","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50,"readable":true,"writable":true}
    zigbee.2
    	2024-11-07 15:08:18.780	warn	PROBLEM2: group_1 {"id":"color","prop":"color","name":"Color","role":"level.color.rgb","write":true,"read":true,"type":"string"}
    zigbee.2
    	2024-11-07 15:08:18.780	warn	PROBLEM2: group_1 {"id":"colortemp","prop":"color_temp","name":"Color temperature","role":"level.color.temperature","write":true,"read":true,"type":"number"}
    zigbee.2
    	2024-11-07 15:08:18.779	warn	PROBLEM2: group_1 {"id":"brightness","name":"Brightness","role":"level.dimmer","write":true,"read":true,"type":"number","unit":"","min":0,"max":100}
    zigbee.2
    	2024-11-07 15:08:18.779	warn	PROBLEM2: group_1 {"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true}
    zigbee.2
    	2024-11-07 15:08:18.779	warn	PROBLEM2: group_1 {"id":"brightness_step","prop":"brightness_step","name":"Brightness stepping","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50}
    zigbee.2
    	2024-11-07 15:08:18.759	warn	PROBLEM1: {"1":"Gartenlampe","2":"Wuerfel"}
    zigbee.2
    	2024-11-07 15:08:18.754	warn	ERROR : icon path not found /opt/iobroker/node_modules/iobroker.zigbee/admin/img/L1(ZW).png
    zigbee.2
    	2024-11-07 15:08:18.656	info	debug devices set to []
    zigbee.2
    	2024-11-07 15:08:18.572	warn	download icon from https://www.zigbee2mqtt.io/images/devices/L1-ZW-.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/L1(ZW).png
    zigbee.2
    	2024-11-07 15:08:18.525	info	Zigbee started
    Noch eine Frage: Er meckert ja auch diverse fehlende icons an, gibts da eine elegante Methode, die upzudaten oder muss ich das einzeln manuell machen?
    • amg_666A amg_666
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      arteckA Offline
      arteckA Offline
      arteck
      #102
      @amg_666 ok die gruppen scheinen ok zu sein.. dann wird nur das icon download schuld an der miesere sein .. ich korrigier das mal..
      kannst dann wieder auf die Normale version...
      Die Icons werden automaschtisch nac dem Namen gesucht und runtergeladen aus dem zigbee2mqtt.. kann aber sein dass da der Name anders ist .. dann kommt kein icon runnter
      ich kann die manuell nachpflegen, muss aber dazu die info Kachel haben
      • arteckA arteck
        amg_666A Offline
        amg_666A Offline
        amg_666
        #103
        @arteck ich hab mittlerweile mal "iob file sync" gemacht, im Adapter werden mir alle Kacheln mit Symbol angezeigt. Soll ich mal die "normale" zigbee Version ausprobieren? Ich hab jetzt noch die von dir bereitgestellte Testversion am laufen
        • amg_666A amg_666
          arteckA Offline
          arteckA Offline
          arteck
          #104
          @amg_666 es kommt morgen eine .13 nimm die
          sonst müllt der adapter dir das LOG file zu
          • arteckA arteck
            amg_666A Offline
            amg_666A Offline
            amg_666
            #105
            @arteck Alles klar, Ergebnis werde ich hier posten...
            • amg_666A amg_666
              amg_666A Offline
              amg_666A Offline
              amg_666
              schrieb am zuletzt editiert von amg_666
              #106
              @arteck Die 10.13 hab ich heute installiert, lief durch und Adapter ist grün, aber er meckert immer noch ein paar fehlende Icons an
              zigbee.2
              	2024-11-11 10:33:30.313	warn	ERROR : icon path not found /opt/iobroker/node_modules/iobroker.zigbee/admin/img/L1(ZW).png
              zigbee.2
              	2024-11-11 10:33:30.093	info	debug devices set to []
              zigbee.2
              	2024-11-11 10:33:29.978	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS0502B.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS0502B.png
              zigbee.2
              	2024-11-11 10:33:29.970	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
              zigbee.2
              	2024-11-11 10:33:29.963	warn	download icon from https://www.zigbee2mqtt.io/images/devices/L1-ZW-.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/L1(ZW).png
              zigbee.2
              	2024-11-11 10:33:29.953	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
              zigbee.2
              	2024-11-11 10:33:29.945	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
              zigbee.2
              	2024-11-11 10:33:29.939	warn	download icon from https://www.zigbee2mqtt.io/images/devices/MCCGQ14LM.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/MCCGQ14LM.png
              zigbee.2
              	2024-11-11 10:33:29.932	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
              zigbee.2
              	2024-11-11 10:33:29.915	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
              zigbee.2
              	2024-11-11 10:33:29.910	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
              zigbee.2
              	2024-11-11 10:33:29.903	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
              zigbee.2
              	2024-11-11 10:33:29.883	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_3.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_3.png
              zigbee.2
              	2024-11-11 10:33:29.873	info	Zigbee started
              Ich setze mehrere LED Controller ein, hier zum Beispiel
              Und hier wird derselbe Controller verwendet, aber das Icon ist offensichtlich nicht da (da steht auch ein falscher Model-Typ in der Kachel)
              ? AsgothianA 2 Antworten Letzte Antwort
              • amg_666A amg_666
                zigbee.2
                zigbee.2
                zigbee.2
                zigbee.2
                zigbee.2
                zigbee.2
                zigbee.2
                zigbee.2
                zigbee.2
                zigbee.2
                zigbee.2
                zigbee.2
                zigbee.2
                zigbee.2
                #107
                @arteck
                version 1.10.13 laeuft hier einwandfrei, ich musste nach der Installation ein "iob upload zigbee"' machen, damit er sich die Icons in der Objectansicht holt, da hatten ein paar gefehlt.
                Danach etwas gewartet, die Objectansicht neu aktualisiert, und die Icons sind alle da.
                • amg_666A amg_666
                  zigbee.2
                  zigbee.2
                  zigbee.2
                  zigbee.2
                  zigbee.2
                  zigbee.2
                  zigbee.2
                  zigbee.2
                  zigbee.2
                  zigbee.2
                  zigbee.2
                  zigbee.2
                  zigbee.2
                  zigbee.2
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  #108
                  @amg_666 zeig mal die Info - Seite der beiden kacheln.
                  • AsgothianA Asgothian
                    amg_666A Offline
                    amg_666A Offline
                    amg_666
                    #109
                    @asgothian Die stehen oben in meinem Post, beides sind "WZ1 Zigbee 2CH LED Controller":
                    Hier ist alles ok, wobei mir das Modell TS0502B nichts sagt:
                    Hier meckert er im Protokoll die Grafik an (L1(ZW) not found) ist aber derselbe Devicetyp, auch ein WZ1 LED Controller:
                    • amg_666A amg_666
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      #110
                      @amg_666 nein, die sind nicht gemeint, auf den Kacheln ist das blaue (i). Ich will sehen was kommt wenn du da drauf gehst.
                      A.
                        A.
                        amg_666A Offline
                        amg_666A Offline
                        amg_666
                        #111
                        @asgothian
                        "Nicht ok Device"
                        "ok Device"
                        AsgothianA arteckA 2 Antworten Letzte Antwort
                        • amg_666A amg_666
                          @asgothian
                          "Nicht ok Device"
                          "ok Device"
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          #112
                          @amg_666 ein Blick drauf zeigt das es sich nicht um baugleiche Geräte handelt - sie melden sich mit unterschiedlichen manufacturer tags am Netz an.
                          Willkommen in der Welt von TuYa.
                          • amg_666A amg_666
                            @asgothian
                            "Nicht ok Device"
                            "ok Device"
                            arteckA Offline
                            arteckA Offline
                            arteck
                            #113
                            @amg_666 nur weil die gleich aussehen heisst es nicht das diese gleich sind..
                            • arteckA arteck
                              amg_666A Offline
                              amg_666A Offline
                              amg_666
                              #114
                              @arteck ok, das habe ich verstanden. Und was kann ich jetzt in Bezug auf das fehlende Icon machen? Kann man das irgendwie manuell "nachladen" ?
                              • arteckA Offline
                                arteckA Offline
                                arteck
                                #115
                                ihr und eure Icons... damit hab ich mir kein gefallen getan...
                                installier nochmal von GIT und upload nicht vergessen
                                amg_666A S 2 Antworten Letzte Antwort
                                • arteckA arteck
                                  amg_666A Offline
                                  amg_666A Offline
                                  amg_666
                                  #116
                                  @arteck Hi, DANKE für deine Unterstützung und deine Geduld :-)
                                  Ich hab von github installiert, danach war alles gut, upload über Konsole war gar nicht nötig
                                  • arteckA arteck
                                    S Abwesend
                                    S Abwesend
                                    Shadowhunter23
                                    schrieb am zuletzt editiert von Shadowhunter23
                                    #117
                                    @arteck @Asgothian
                                    1.10.13
                                    Zur Info:
                                    zigbee.2
                                    2024-11-20 18:36:05.056	info	DeviceConfigure successful 0x08ddebfffea99da5 TRVZB
                                    zigbee.2
                                    2024-11-20 18:35:55.829	warn	Object zigbee.2.08ddebfffea99da5.mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" This will throw an error up from js-controller version 7.0.0!
                                    zigbee.2
                                    2024-11-20 18:35:55.826	warn	Object 08ddebfffea99da5.mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" This will throw an error up from js-controller version 7.0.0!
                                    zigbee.2
                                    2024-11-20 18:35:55.818	info	-> Configuring 0x08ddebfffea99da5 TRVZB
                                    zigbee.2
                                    2024-11-20 18:35:55.817	info	Device '0x08ddebfffea99da5' is supported, identified as: SONOFF Zigbee thermostatic radiator valve (TRVZB)
                                    Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
                                    ioBroker Backup Analyzer
                                    • S Shadowhunter23
                                      @arteck @Asgothian
                                      1.10.13
                                      Zur Info:
                                      zigbee.2
                                      zigbee.2
                                      zigbee.2
                                      zigbee.2
                                      zigbee.2
                                      arteckA Offline
                                      arteckA Offline
                                      arteck
                                      #118
                                      @shadowhunter23 jao auch schon woanders gesehen...
                                      der DP mode muss anders gefüllt werden
                                      • arteckA arteck
                                        S Abwesend
                                        S Abwesend
                                        Shadowhunter23
                                        #119
                                        @arteck
                                        Das kommt vom Gerät bei der Einrichtung. Lässt sich also nicht im Adapter ändern?
                                        • S Shadowhunter23
                                          @arteck
                                          arteckA Offline
                                          arteckA Offline
                                          arteck
                                          #120
                                          @shadowhunter23das konvertieren wir um.. ist ein Bug im adapter
