  4. pivCCU nach Update node.js nicht erreichbar
63 Beiträge 7 Kommentatoren 7.5k Aufrufe 4 Beobachtet
  • W wibear
    @thomas-braun sagte in pivCCU nach Update node.js nicht erreichbar:
    Controller "js-controller": 6.0.9 , installed 5.0.19 [Updatable]
    ausgeführt
    @wibear
    Dann ist ioBroker-seitig jetzt alles i.O.
    • W wibear
      iob diag
      Model : Raspberry Pi 4 Model B Rev 1.5
      Docker : false
      Virtualization : none
      Kernel : armv7l
      Userland : 32 bit
      Systemuptime and Load:
      15:51:21 up 35 min, 1 user, load average: 1.13, 0.75, 2.22
      CPU threads: 4
      Copy text starting here:
                              v.2024-05-22
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Tue 2024-08-13 15:51:21 CEST
                 Universal time: Tue 2024-08-13 13:51:21 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      wibear
      HOME=/home/wibear
      GROUPS=wibear adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            3.9G        1.1G        2.2G        1.0M        568M        2.6G
      Swap:            99M          0B         99M
      Total:          4.0G        1.1G        2.3G
      Active iob-Instances:   20
               3885 M total memory
               1134 M used memory
                179 M active memory
               1411 M inactive memory
               2182 M free memory
                 64 M buffer memory
                504 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      top - 15:51:22 up 35 min,  1 user,  load average: 1.13, 0.75, 2.22
      Tasks: 219 total,   3 running, 216 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 25.8 us,  9.7 sy,  0.0 ni, 54.8 id,  6.5 wa,  0.0 hi,  3.2 si,  0.0 st
      MiB Mem :   3885.9 total,   2184.1 free,   1132.9 used,    568.8 buff/cache
      MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2635.5 avail Mem
      *** FAILED SERVICES ***
        UNIT                       LOAD   ACTIVE SUB    DESCRIPTION
      * pivccu-dkms.service        loaded failed failed piVCCU DKMS Modules
      * pivccu-rpi-modules.service loaded failed failed piVCCU RPi Kernel loader
      2 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4       29G   11G   18G  39% /
      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     778M  1.1M  777M   1% /run
      /dev/mmcblk0p1 vfat      255M   63M  193M  25% /boot
      tmpfs          tmpfs     389M     0  389M   0% /run/user/1000
      [Tue Aug 13 15:15:44 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:16:18:C4 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=tty1 root=PARTUUID=e605bf32-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Tue Aug 13 15:15:45 2024] EXT4-fs (mmcblk0p2): mounted filesystem d3104e7d-5f59-47e0-8621-290882475163 ro with ordered data mode. Quota mode: none.
      [Tue Aug 13 15:15:45 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Tue Aug 13 15:15:46 2024] EXT4-fs (mmcblk0p2): re-mounted d3104e7d-5f59-47e0-8621-290882475163 r/w. Quot   Static hostname: iobroker-pi
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.6.44-v7l+
            Architecture: arm
      Installation:           native
      Kernel:                 armv7l
      Userland:               32 bit
      Timezone:               Europe/Berlin (CEST, +0200)
      User-ID:                1000
      Pending OS-Updates:     0
      Pending iob updates:    1
      Nodejs-Installation:
      /usr/bin/nodejs         v20.16.0
      /usr/local/bin/node             v18.18.0
      /usr/local/bin/npm              10.8.2
      /usr/local/bin/npx              10.8.2
      /usr/local/bin/corepack         0.19.0
      Recommended versions are nodejs 20.16.0 and npm 10.8.1
      *** nodejs is NOT correctly installed ***
      Wrong installation path detected. This needs to be fixed.
      Please execute
      iobroker nodejs-update
      to fix these errors.
      MEMORY:
      Mem:            3.9G        1.2G        2.0G        1.0M        649M        2.5G
      Swap:            99M          0B         99M
      Total:          4.0G        1.2G        2.1G
      Active repo(s): stable
      ioBroker Core:          js-controller           5.0.19
                              admin                   7.0.22
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : iobroker-pi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                7401
      States:                 6256
      Size of iob-Database:
      15M     /opt/iobroker/iobroker-data/objects.jsonl
      9.0M    /opt/iobroker/iobroker-data/states.jsonl
      === Mark text until here for copying ===
      wibear@iobroker-pi:~ $ ======== Start marking the full check here =========
      -bash: ========: command not found
      > Skript v.2024-05-22
      > *** BASE SYSTEM ***
      >          Icon name: computer
      >       Architecture: arm
      > Docker          : false
      > Kernel          : armv7l
      > Userland        : 32 bit
      > CPU threads: 4
      > Current issues:
      > No throttling issues detected.
      >                  RTC time: n/a
      />                 Time zone: Europe/Berlin (CEST, +0200)
      > System clock synchronized: yes
      >               NTP service: active
      >           RTC in local TZ: no
      > wibear
      > HOME=/home/wibear
      > User that is running 'js-controller':
      > iobroker
      > HOME=/home/iobroker
      > GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
      > Desktop:
      > Terminal:       tty
      > *** MEMORY ***
      >                total        used        free      shared  buff/cache   available
      > Swap:            99M          0B         99M
      >          3885 M total memory
      >          1134 M used memory
      >           179 M active memory
      >          2182 M free memory
      >            64 M buffer memory
      >           504 M swap cache
      >            99 M total swap
      >             0 M used swap
      >            99 M free swap
      > *** top - Table Of Processes  ***
      > LOAD   = Reflects whether the unit definition was properly loaded.
      > ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      > SUB    = The low-level unit activation state, values depend on unit type.
      > *** FILESYSTEM ***
      > Filesystem     Type      Size  Used Avail Use% Mounted on
      > Messages concerning ext4 filesystem in dmesg:
      > [Tue Aug 13 15:15:46 2024] EXT4-fs (mmcblk0p2): re-mounted d3104e7d-5f59-47e0-8621-290882475163 r/w. Quota mode: none.
      > Show mounted filesystems:
      > TARGET                       SOURCE         FSTYPE     OPTIONS
      > /                            /dev/mmcblk0p2 ext4       rw,noatime
      > |-/dev                       devtmpfs       devtmpfs   rw,relatime,size=1726396k,nr_inodes=34271,mode=755
      > | |-/dev/shm                 tmpfs          tmpfs      rw,nosuid,nodev
      > | |-/dev/pts                 devpts         devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      > | `-/dev/mqueue              mqueue         mqueue     rw,nosuid,nodev,noexec,relatime
      -bash: Skript: command not found
      -bash: node_modules: command not found
      -bash: Static: command not found
      -bash: Icon: command not found
      -bash: command substitution: line 7: syntax error near unexpected token `('
      -bash: command substitution: line 7: `  Operating System: Raspbian GNU/Linux 11 (bullseye)'
      -bash: -/dev/mqueue: No such file or directory
      wibear@iobroker-pi:~ $ |-/proc                      proc           proc       rw,relatime
      -bash: syntax error near unexpected token `|'
      wibear@iobroker-pi:~ $ | `-/proc/sys/fs/binfmt_misc systemd-1      autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
      wibear@iobroker-pi:~ $ |-/sys                       sysfs          sysfs      rw,nosuid,nodev,noexec,relatime
      wibear@iobroker-pi:~ $ | |-/sys/kernel/security     securityfs     securityfs rw,nosuid,nodev,noexec,relatime
      wibear@iobroker-pi:~ $ | |-/sys/fs/cgroup           cgroup2        cgroup2    rw,nosuid,nodev,noexec,relatime
      wibear@iobroker-pi:~ $ | |-/sys/fs/pstore           pstore         pstore     rw,nosuid,nodev,noexec,relatime
      wibear@iobroker-pi:~ $ | |-/sys/fs/bpf              bpf            bpf        rw,nosuid,nodev,noexec,relatime,mode=700
      wibear@iobroker-pi:~ $ | |-/sys/kernel/tracing      tracefs        tracefs    rw,nosuid,nodev,noexec,relatime
      wibear@iobroker-pi:~ $ | |-/sys/kernel/debug        debugfs        debugfs    rw,nosuid,nodev,noexec,relatime
      wibear@iobroker-pi:~ $ | |-/sys/fs/fuse/connections fusectl        fusectl    rw,nosuid,nodev,noexec,relatime
      wibear@iobroker-pi:~ $ | `-/sys/kernel/config       configfs       configfs   rw,nosuid,nodev,noexec,relatime
      wibear@iobroker-pi:~ $ |-/run                       tmpfs          tmpfs      rw,nosuid,nodev,size=795828k,nr_inodes=819200,mode=755
      wibear@iobroker-pi:~ $ | |-/run/lock                tmpfs          tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
      wibear@iobroker-pi:~ $ | |-/run/rpc_pipefs          sunrpc         rpc_pipefs rw,relatime
      wibear@iobroker-pi:~ $ | `-/run/user/1000           tmpfs          tmpfs      rw,nosuid,nodev,relatime,size=397912k,nr_inodes=99478,mode=700,uid=1000,gid=1000
      wibear@iobroker-pi:~ $ |-/boot                      /dev/mmcblk0p1 vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      wibear@iobroker-pi:~ $ `-/var/lib/lxcfs             lxcfs          fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      > Files in neuralgic directories:
      > /var:
      > du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
      > 4.6G    /var/
      > 3.3G    /var/log
      > 2.9G    /var/log/journal/6462312882a642219bbda7aff5f4f5b9
      > 729M    /var/lib
      > Archived and active journals take up 2.8G in the file system.
      > /opt/iobroker/backups:
      > 82M     /opt/iobroker/backups/
      > /opt/iobroker/iobroker-data:
      > 747M    /opt/iobroker/iobroker-data/
      > 594M    /opt/iobroker/iobroker-data/files
      > 441M    /opt/iobroker/iobroker-data/files/javascript.admin
      > 409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      > 408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      > The five largest files in iobroker-data are:
      > 27M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.ce422ec2.js.map
      > 24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      > 8.7M    /opt/iobroker/iobroker-data/states.jsonl
      > 8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
      > USB-Devices by-id:
      > USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id':
      > No Devices found 'by-id'
      > *** NodeJS-Installation ***
      0        : device-reminder > /usr/local/bin/npx              10.8.2
      > nodejs:
      >   Installed: 20.16.0-1nodesource1
      >   Candidate: 20.16.0-1nodesource1
      >   Version table:
      >  *** 20.16.0-1nodesource1 600
      >         500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
      >         100 /var/lib/dpkg/status
      >      20.15.1-1nodesource1 600
      >      20.15.0-1nodesource1 600
      >      20.14.0-1nodesource1 600
      >      20.13.1-1nodesource1 600
      >      20.13.0-1nodesource1 600
      >      20.12.2-1nodesource1 600
      >      20.12.1-1nodesource1 600
      >      20.12.0-1nodesource1 600
      >      20.11.1-1nodesource1 600
      >      20.11.0-1nodesource1 600
      >      20.10.0-1nodesource1 600
      >      20.9.0-1nodesource1 600
      >      20.8.1-1nodesource1 600
      >      20.8.0-1nodesource1 600
      >      20.7.0-1nodesource1 600
      >      20.6.1-1nodesource1 600
      >      20.6.0-1nodesource1 600
      >      20.5.1-1nodesource1 600
      >      20.5.0-1nodesource1 600
      >      20.4.0-1nodesource1 600
      >      20.3.1-1nodesource1 600
      >      20.3.0-1nodesource1 600
      >      20.2.0-1nodesource1 600
      >      20.1.0-1nodesource1 600
      >      20.0.0-1nodesource1 600
      >      12.22.12~dfsg-1~deb11u4 500
      >         500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
      > Temp directories causing npm8 problem: 0
      > No problems detected
      > Errors in npm tree:
      > *** ioBroker-Installation ***
      > ioBroker Status
      > iobroker is running on this host.
      > Objects type: jsonl
      > States  type: jsonl
      > Core adapters versions
      > js-controller:  5.0.19
      > admin:          7.0.22
      > javascript:     8.7.6
      > nodejs modules from github:     1
      > +-- iobroker.vw-connect@0.5.3 (git+ssh://git@github.com/TA2k/ioBroker.vw-connect.git#b5fbfb41f65b8a1efb646e9efb68f1cbd1627d27)
      > Adapter State
      > + system.adapter.alexa2.0                 : alexa2                : iobroker-pi                              -  enabled
      > + system.adapter.backitup.0               : backitup              : iobroker-pi                              -  enabled
      > + system.adapter.device-reminder.0        : device-reminder       : iobroker-pi                              -  enabled
      > + system.adapter.discovery.0              : discovery             : iobroker-pi                              -  enabled
      > + system.adapter.ems-esp.0                : ems-esp               : iobroker-pi                              -  enabled
      > + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker-pi                              -  enabled
      >   system.adapter.habpanel.0               : habpanel              : iobroker-pi                              -  enabled
      > + system.adapter.history.0                : history               : iobroker-pi                              -  enabled
      > + system.adapter.hm-rega.0                : hm-rega               : iobroker-pi                              -  enabled
      >   system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-pi                              -  enabled, port: 18701
      >   system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-pi                              -  enabled, port: 12001
      >   system.adapter.hm-rpc.2                 : hm-rpc                : iobroker-pi                              -  enabled, port: 12010
      > + system.adapter.influxdb.0               : influxdb              : iobroker-pi                              -  enabled, port: 8086
      >   system.adapter.info.0                   : info                  : iobroker-pi                              -  enabled
      > + system.adapter.javascript.0             : javascript            : iobroker-pi                              -  enabled
      > + system.adapter.mqtt.0                   : mqtt                  : iobroker-pi                              -  enabled, port: 1883, bind: 192.168.178.10
      >   system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker-pi                              -  enabled
      > + system.adapter.rpi2.0                   : rpi2                  : iobroker-pi                              -  enabled
      > + system.adapter.shelly.0                 : shelly                : iobroker-pi                              -  enabled, port: 1882, bind: 0.0.0.0
      > + system.adapter.simple-api.0             : simple-api            : iobroker-pi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      > + system.adapter.tr-064.0                 : tr-064                : iobroker-pi                              -  enabled
      >   system.adapter.tuya.0                   : tuya                  : iobroker-pi                              - disabled
      > + system.adapter.vw-connect.0             : vw-connect            : iobroker-pi                              -  enabled
      >   system.adapter.weatherunderground.0     : weatherunderground    : iobroker-pi                              - disabled
      > + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker-pi                              -  enabled
      > + instance is alive
      > Enabled adapters with bindings
      > ioBroker-Repositories
      > stable        : http://download.iobroker.net/sources-dist.json
      > beta          : http://download.iobroker.net/sources-dist-latest.json
      > Installed ioBroker-Instances
      > Used repository: stable
      > Adapter    "admin"        : 7.0.22   , installed 7.0.22
      > Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      > Adapter    "backitup"     : 3.0.16   , installed 3.0.16
      > Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      > Adapter    "discovery"    : 4.5.0    , installed 4.5.0
      > Adapter    "ems-esp"      : 3.5.0    , installed 3.5.0
      > Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
      > Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
      > Adapter    "history"      : 3.0.1    , installed 3.0.1
      > Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      > Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
      > Adapter    "influxdb"     : 4.0.2    , installed 4.0.2
      > Adapter    "javascript"   : 8.7.6    , installed 8.7.6
      > Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      > Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
      > Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
      > Adapter    "shelly"       : 7.0.0    , installed 7.0.0
      > Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      > Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      > Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      > Adapter    "tuya"         : 3.15.0   , installed 3.15.0
      > Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      > Adapter    "web"          : 6.2.5    , installed 6.2.5
      > Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
      > Adapter    "ws"           : 2.6.2    , installed 2.6.2
      > Objects and States
      > Please stand by - This may take a while
      > Objects:        7401
      > States:         6256
      > *** OS-Repositories and Updates ***
      > Hit:1 https://repos.influxdata.com/debian bullseye InRelease
      > Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      > Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
      > Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      > Hit:5 https://packages.grafana.com/oss/deb stable InRelease
      > Hit:6 https://apt.pivccu.de/piVCCU stable InRelease
      > Reading package lists...
      > Pending Updates: 0
      > *** Listening Ports ***
      > Active Internet connections (only servers)
      > Proto Recv-Q Send-Q Local Address           Foreign Address         State       User       Inode      PID/Program name
      > tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        6286       745/influxd
      > tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       8815       1209/io.shelly.0
      > tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6351       884/iobroker.js-con
      > tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       5758       884/iobroker.js-con
      > tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4770       787/sshd: /usr/sbin
      > tcp        0      0 192.168.178.10:1883     0.0.0.0:*               LISTEN      1001       6997       1170/io.mqtt.0
      > tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          4793       814/dnsmasq
      > tcp6       0      0 :::8086                 :::*                    LISTEN      999        4863       745/influxd
      > tcp6       0      0 :::8087                 :::*                    LISTEN      1001       9583       1272/io.simple-api.
      > tcp6       0      0 :::8082                 :::*                    LISTEN      1001       8850       1314/io.web.0
      > tcp6       0      0 :::8081                 :::*                    LISTEN      1001       5806       951/io.admin.0
      > tcp6       0      0 :::3000                 :::*                    LISTEN      111        5756       883/grafana
      48
      > tcp6       0      0 :::22                   :::*                    LISTEN      0          4772       787/sshd: /usr/sbin
      > udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        5445       372/avahi-daemon: r
      > udp        0      0 0.0.0.0:55700           0.0.0.0:*                           108        5447       372/avahi-daemon: r
      > udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          4792       814/dnsmasq
      > udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          4789       814/dnsmasq
      > udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          4602       596/dhclient
      > udp6       0      0 :::5353                 :::*                                108        5446       372/avahi-daemon: r
      > udp6       0      0 :::48974                :::*                                108        5448       372/avahi-daemon: r
      > *** Log File - Last 25 Lines ***
      > 2024-08-13 15:51:30.782  - info: hm-rpc.2 (6575) xmlrpc client is trying to connect to 192.168.178.12:2010/ with ["http://192.168.178.10:12010","iobroker-pi:hm-rpc.2:325a5da9b9959b38a1d02500f5dff733"]
      > 2024-08-13 15:51:30.849  - info: hm-rpc.1 (6586) xmlrpc server is trying to listen on 192.168.178.10:12001
      > 2024-08-13 15:51:30.850  - info: hm-rpc.1 (6586) xmlrpc client is trying to connect to 192.168.178.12:2001/ with ["http://192.168.178.10:12001","iobroker-pi:hm-rpc.1:77e7296879feb3366411ef62aab861bd"]
      > 2024-08-13 15:51:33.949  - error: hm-rpc.2 (6575) Init not possible, going to stop: connect EHOSTUNREACH 192.168.178.12:2010
      > 2024-08-13 15:51:33.957  - error: hm-rpc.1 (6586) Init not possible, going to stop: connect EHOSTUNREACH 192.168.178.12:2001
      > 2024-08-13 15:51:49.143  - info: hm-rpc.0 (6422) binrpc -> 192.168.178.12:8701/ init ["xmlrpc_bin://192.168.178.10:18701",""]
      > 2024-08-13 15:51:49.160  - error: hm-rpc.0 (6422) Cannot call init: [xmlrpc_bin://192.168.178.10:18701, ""] Socket closed before the connection was established
      > 2024-08-13 15:51:49.232  - info: hm-rpc.0 (6422) terminating
      > 2024-08-13 15:51:49.234  - info: hm-rpc.0 (6422) Terminated (NO_ERROR): Without reason
      > 2024-08-13 15:51:49.835  - info: host.iobroker-pi instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
      > 2024-08-13 15:51:49.836  - info: host.iobroker-pi Restart adapter system.adapter.hm-rpc.0 because enabled
      > 2024-08-13 15:51:52.253  - error: hm-rega.0 (2659) CCU 192.168.178.12 unreachable
      > 2024-08-13 15:52:03.933  - error: hm-rpc.2 (6575) Init not possible, going to stop: connect EHOSTUNREACH 192.168.178.12:2010
      > 2024-08-13 15:52:03.935  - error: hm-rpc.1 (6586) Init not possible, going to stop: connect EHOSTUNREACH 192.168.178.12:2001
      > 2024-08-13 15:52:03.960  - info: hm-rpc.1 (6586) xmlrpc -> 192.168.178.12:2001/ init ["http://192.168.178.10:12001",""]
      > 2024-08-13 15:52:03.964  - info: hm-rpc.2 (6575) xmlrpc -> 192.168.178.12:2010/ init ["http://192.168.178.10:12010",""]
      > 2024-08-13 15:52:04.969  - info: hm-rpc.1 (6586) terminating
      > 2024-08-13 15:52:04.971  - info: hm-rpc.1 (6586) Terminated (NO_ERROR): Without reason
      > 2024-08-13 15:52:04.978  - info: hm-rpc.2 (6575) terminating
      > 2024-08-13 15:52:04.980  - info: hm-rpc.2 (6575) Terminated (NO_ERROR): Without reason
      > 2024-08-13 15:52:05.572  - info: host.iobroker-pi instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
      > 2024-08-13 15:52:05.573  - info: host.iobroker-pi Restart adapter system.adapter.hm-rpc.1 because enabled
      > 2024-08-13 15:52:05.618  - info: host.iobroker-pi instance system.adapter.hm-rpc.2 terminated with code 0 (NO_ERROR)
      > 2024-08-13 15:52:05.619  - info: host.iobroker-pi Restart adapter system.adapter.hm-rpc.2 because enabled
      > 2024-08-13 15:52:19.916  - info: host.iobroker-pi instance system.adapter.hm-rpc.0 started with pid 7348
      -bash: -/var/lib/lxcfs: No such file or directory
      -bash: Files: command not found
      -bash: /var:: No such file or directory
      -bash: du:: command not found
      -bash: 4.6G: command not found
      -bash: 3.3G: command not found
      -bash: 2.9G: command not found
      -bash: 729M: command not found
      -bash: Archived: command not found
      -bash: /opt/iobroker/backups:: No such file or directory
      -bash: 82M: command not found
      -bash: /opt/iobroker/iobroker-data:: No such file or directory
      -bash: 747M: command not found
      -bash: 594M: command not found
      -bash: 441M: command not found
      -bash: 409M: command not found
      -bash: 408M: command not found
      -bash: The: command not found
      -bash: 27M: command not found
      -bash: 24M: command not found
      -bash: 15M: command not found
      -bash: 8.7M: command not found
      -bash: USB-Devices: command not found
      -bash: USB-Sticks: command not found
      -bash: No: command not found
      node:internal/modules/cjs/loader:1148
        throw err;
      Error: Cannot find module '/home/wibear/v20.16.0'
          at Module._resolveFilename (node:internal/modules/cjs/loader:1145:15)
          at Module._load (node:internal/modules/cjs/loader:986:27)
          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
          at node:internal/main/run_main_module:28:49 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
      Node.js v20.16.0
      node:internal/modules/cjs/loader:1080
        throw err;
      Error: Cannot find module '/home/wibear/v18.18.0'
          at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
          at Module._load (node:internal/modules/cjs/loader:922:27)
          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:86:12)
          at node:internal/main/run_main_module:23:47 {
        requireStack: []
      Node.js v18.18.0
      npm error code ENOVERSIONS
      npm error No versions available for 10.8.2
      npm error A complete log of this run can be found in: /home/wibear/.npm/_logs/2024-08-13T13_53_15_245Z-debug-0.log
      -bash: nodejs:: command not found
      -bash: Installed:: command not found
      -bash: Candidate:: command not found
      -bash: Version: command not found
      -bash: 500: command not found
      -bash: 100: command not found
      -bash: 20.15.1-1nodesource1: command not found
      -bash: 20.15.0-1nodesource1: command not found
      -bash: 20.14.0-1nodesource1: command not found
      -bash: 20.13.1-1nodesource1: command not found
      -bash: 20.13.0-1nodesource1: command not found
      -bash: 20.12.2-1nodesource1: command not found
      -bash: 20.12.1-1nodesource1: command not found
      -bash: 20.12.0-1nodesource1: command not found
      -bash: 20.11.1-1nodesource1: command not found
      -bash: 20.11.0-1nodesource1: command not found
      -bash: 20.10.0-1nodesource1: command not found
      -bash: 20.9.0-1nodesource1: command not found
      -bash: 20.8.1-1nodesource1: command not found
      -bash: 20.8.0-1nodesource1: command not found
      -bash: 20.7.0-1nodesource1: command not found
      -bash: 20.6.1-1nodesource1: command not found
      -bash: 20.6.0-1nodesource1: command not found
      -bash: 20.5.1-1nodesource1: command not found
      -bash: 20.5.0-1nodesource1: command not found
      -bash: 20.4.0-1nodesource1: command not found
      -bash: 20.3.1-1nodesource1: command not found
      -bash: 20.3.0-1nodesource1: command not found
      -bash: 20.2.0-1nodesource1: command not found
      -bash: 20.1.0-1nodesource1: command not found
      -bash: 20.0.0-1nodesource1: command not found
      -bash: 12.22.12~dfsg-1~deb11u4: command not found
      -bash: Temp: command not found
      -bash: Errors: command not found
      -bash: ioBroker: command not found
      iobroker [command]
      Commands:
        iobroker setup                                               Setup ioBroker
        iobroker start [all|<adapter>.<instance>|<adapter>]          Starts the js-controller or a specified adapter instance or all instances of an adapter
        iobroker stop [<adapter>.<instance>|<adapter>]               stops the js-controller or a specified adapter instance or all instances of an adapter
        iobroker restart [<adapter>.<instance>|<adapter>]            Restarts js-controller or a specified adapter instance or all instances of an adapter  [aliases: r]
        iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
        iobroker info                                                Shows the host info
        iobroker logs [<adapter>]                                    Monitor log
        iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
        iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
        iobroker rebuild [<module>]                                  Rebuild all native modules or path
        iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
        iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
        iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
        iobroker update [<repositoryUrl>]                            Update repository and list adapters
        iobroker upgrade                                             Upgrade management
        iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
        iobroker object                                              Object management  [aliases: o]
        iobroker state                                               State management  [aliases: s]
        iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
        iobroker list <type> [<filter>]                              List all entries, like objects
        iobroker chmod <mode> <file>                                 Change file rights
        iobroker chown <user> <group> <file>                         Change file ownership
        iobroker touch <file>                                        Touch file
        iobroker rm <file>                                           Remove file
        iobroker file                                                File management
        iobroker user                                                User commands
        iobroker group                                               group management
        iobroker host <hostname>                                     Set host to given hostname
        iobroker set <adapter>.<instance>                            Change settings of adapter config
        iobroker license <license.file or license.text>              Update license by given file
        iobroker cert                                                Certificate management
        iobroker clean <yes>                                         Clears all objects and states
        iobroker backup                                              Create backup
        iobroker restore <backup name or path>                       Restore a specified backup
        iobroker validate <backup name or path>                      Validate a specified backup
        iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
        iobroker repo [<name>]                                       Show repo information
        iobroker uuid                                                Show uuid of the installation  [aliases: id]
        iobroker unsetup                                             Reset license, installation secret and language
        iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
        iobroker nodejs-update [<major-version>]                     Upgrade the Node.JS installation to the current LTS
        iobroker multihost                                           Multihost management
        iobroker compact                                             compact group management
        iobroker plugin                                              Plugin management
        iobroker vendor <passphrase> [<vendor.json>]                 Update the vendor information using given passphrase
        iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
      Options:
        --help  Show help  [boolean]
      -bash: Objects: command not found
      -bash: States: command not found
      -bash: Core: command not found
      -bash: js-controller:: command not found
      -bash: admin:: command not found
      -bash: javascript:: command not found
        throw err;
      Error: Cannot find module '/home/wibear/modules'
        requireStack: []
      Node.js v20.16.0
      -bash: command substitution: line 129: syntax error near unexpected token `('
      -bash: command substitution: line 129: `+-- iobroker.vw-connect@0.5.3 (git+ssh://git@github.com/TA2k/ioBroker.vw-connect.git#b5fbfb41f65b8a1efb646e9efb68f1cbd1627d27)'
      -bash: Unknown: command not found
      wibear@iobroker-pi:~ $ ============ Mark until here for C&P =============
      [1] 7854
      -bash: ============: command not found
      -bash: P: command not found
      [1]+  Exit 127                ============ Mark until here for C
      @wibear sagte:
      FAILED SERVICES
      Das hat nichts mit Node.js oder ioBroker zu tun.
      • W Offline
        W Offline
        wibear
        @paul53 Was könnte der Grund für FailedServices sein?
        • W wibear
          @wibear
          systemctl status pivccu-dkms.service
          systemctl status pivccu-rpi-modules.service
          könnte dir das vielleicht verraten. Ansonsten wäre das ein Fall für die Kollegen eine Tür weiter bei pivCCU.
          HomoranH W 2 Antworten Letzte Antwort
            @wibear
            @wibear
            oder mal mit sudo pivccu-info nachsehen
            W 1 Antwort Letzte Antwort
              @wibear
              W Offline
              W Offline
              wibear
              pivCCU zeigt State: STOPPED
              Kann ich das starten?
              • W wibear
                @wibear sagte in pivCCU nach Update node.js nicht erreichbar:
                Das zeigt aber mit Sicherheit noch mehr...
                sudo systemctl start pivccu-dkms.service
                sudo systemctl start pivccu-rpi-modules.service
                  @wibear
                  W Offline
                  W Offline
                  wibear
                  ● pivccu-rpi-modules.service - piVCCU RPi Kernel loader
                       Loaded: loaded (/lib/systemd/system/pivccu-rpi-modules.service; enabled; v>
                       Active: failed (Result: exit-code) since Tue 2024-08-13 16:08:45 CEST; 36m>
                      Process: 727 ExecStart=/var/lib/piVCCU/rpi-modules/ensure_headers.sh (code=>
                     Main PID: 727 (code=exited, status=1/FAILURE)
                          CPU: 15ms
                  Aug 13 16:08:45 iobroker-pi systemd[1]: Starting piVCCU RPi Kernel loader...
                  Aug 13 16:08:45 iobroker-pi ensure_headers.sh[727]: Could not determine kernel >
                  Aug 13 16:08:45 iobroker-pi systemd[1]: pivccu-rpi-modules.service: Main proces>
                  Aug 13 16:08:45 iobroker-pi systemd[1]: pivccu-rpi-modules.service: Failed with>
                  Aug 13 16:08:45 iobroker-pi systemd[1]: Failed to start piVCCU RPi Kernel loade>
                  An wen kann ich mich mit pivCCU wenden?
                  Hilft es, ein pivCCU Backup einzuspielen?
                    W Offline
                    W Offline
                    wibear
                    Job for pivccu-dkms.service failed because the control process exited with error code.
                    See "systemctl status pivccu-dkms.service" and "journalctl -xe" for details.
                    • W wibear
                              CPU: 15ms
                      @wibear
                      Zieh dein Mäusekino breiter. Die Meldungen sind abgeschnitten.
                      Vermutlich nicht, sind das doch Kernel-Module.
                      Vielleicht sind die noch nicht gegen den aktuellen Kernel gebaut worden?
                        @wibear
                        W Offline
                        W Offline
                        wibear
                                CPU: 15ms
                        lines 1-12/12 (END)...skipping...
                             Loaded: loaded (/lib/systemd/system/pivccu-rpi-modules.service; enabled; vendor preset: enabled)
                             Active: failed (Result: exit-code) since Tue 2024-08-13 16:08:45 CEST; 36min ago
                            Process: 727 ExecStart=/var/lib/piVCCU/rpi-modules/ensure_headers.sh (code=exited, status=1/FAILURE)
                                CPU: 15ms
                        Aug 13 16:08:45 iobroker-pi ensure_headers.sh[727]: Could not determine kernel source.
                        Aug 13 16:08:45 iobroker-pi systemd[1]: pivccu-rpi-modules.service: Main process exited, code=exited, status=1/FAILURE
                        Aug 13 16:08:45 iobroker-pi systemd[1]: pivccu-rpi-modules.service: Failed with result 'exit-code'.
                        Aug 13 16:08:45 iobroker-pi systemd[1]: Failed to start piVCCU RPi Kernel loader.
                          @wibear
                          W Offline
                          W Offline
                          wibear
                          Vielleicht sind die noch nicht geggen den aktuellen Kernel gebaut worden?
                          Kann ich da ein downgrade machen?
                          • W wibear
                            Du solltest eher ein Upgrade der pivCCU-Pakete machen, wenn es denn welche gibt.
                            Hier gibt es aber ein paar Hinweise, was man da machen kann:
                            https://alexreinert.github.io/piVCCU/docs/setup/raspberrypi.html
                            W HomoranH 2 Antworten Letzte Antwort
                              W Offline
                              W Offline
                              wibear
                              Habe es schon versucht, es gibt aber momentan keine...
                              • W wibear
                                @wibear
                                Unterstützt pivCCU RaspberryOS 11 überhaupt? Oder wird sich da auf die jeweils aktuelle stable beschränkt?
                                  @wibear
                                  W Offline
                                  W Offline
                                  wibear
                                  @thomas-braun Das weiß ich nicht. Alles was ich gemacht habe war es, node.js upzudaten...
                                  • W wibear
                                    Davon abgesehen, das du das (mit v18) in der Vergangenheit falsch gemacht hast, packt das aber die pivccu-Module nicht an.
                                    • W wibear
                                      immer alles zeigen!
                                      da steht nämlich noch viel mehr wichtiges
                                        W Offline
                                        W Offline
                                        wibear
                                        Es ist noch eine Frage zu INFO Adapter, der auch Fehler bringt. Ist auch nach dem Update aufgetreten.
                                        Was kann das sein?
                                        iobroker npm-install: adapter "info" cannot be installed: Unknown packetName info. Please install packages from outside the repository using npm!
                                        host.iobroker-pi
                                        iobroker npm-install: host.iobroker-pi Unknown packetName info. Please install packages from outside the repository using "iobroker url <url-or-package>"!
                                        host.iobroker-pi
                                        startInstance cannot find adapter "info@2.0.0". Try to install it... 1 attempt
                                        Ro75R Thomas BraunT 2 Antworten Letzte Antwort
                                        • W wibear
                                          Was kann das sein?
                                          host.iobroker-pi
                                          host.iobroker-pi
                                          Ro75R Online
                                          Ro75R Online
                                          Ro75
                                          Der Adapter ist EOL, OUT, AUS ENDE, ... Steht aber in gefühlt 1000 Post's.
                                          Ro75.
