  4. pivCCU nach Update node.js nicht erreichbar
63 Beiträge 7 Kommentatoren 7.5k Aufrufe 4 Beobachtet
  • W wibear
    Nach reboot:
    Skript v.2024-05-22
    *** BASE SYSTEM ***
       Static hostname: iobroker-pi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.6.44-v7l+
          Architecture: arm
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : 32 bit
    Systemuptime and Load:
     16:10:24 up 1 min,  1 user,  load average: 2.37, 1.01, 0.38
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Tue 2024-08-13 16:10:25 CEST
               Universal time: Tue 2024-08-13 14:10:25 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    wibear
    HOME=/home/wibear
    GROUPS=wibear adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            3.9G        1.0G        2.3G        1.0M        519M        2.7G
    Swap:            99M          0B         99M
    Total:          4.0G        1.0G        2.4G
    Active iob-Instances:   10
             3885 M total memory
             1016 M used memory
              156 M active memory
             1281 M inactive memory
             2349 M free memory
               48 M buffer memory
              471 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    top - 16:10:25 up 1 min,  1 user,  load average: 2.37, 1.01, 0.38
    Tasks: 202 total,   1 running, 201 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 16.7 us,  3.0 sy,  0.0 ni, 80.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3885.9 total,   2349.2 free,   1016.4 used,    520.2 buff/cache
    MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2742.4 avail Mem
    *** FAILED SERVICES ***
      UNIT                       LOAD   ACTIVE SUB    DESCRIPTION
    * pivccu-dkms.service        loaded failed failed piVCCU DKMS Modules
    * pivccu-rpi-modules.service loaded failed failed piVCCU RPi Kernel loader
    2 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       29G   11G   18G  39% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     778M  1.1M  777M   1% /run
    /dev/mmcblk0p1 vfat      255M   63M  193M  25% /boot
    tmpfs          tmpfs     389M     0  389M   0% /run/user/1000
    [Tue Aug 13 16:08:37 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:16:18:C4 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=tty1 root=PARTUUID=e605bf32-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Tue Aug 13 16:08:38 2024] EXT4-fs (mmcblk0p2): mounted filesystem d3104e7d-5f59-47e0-8621-290882475163 ro with ordered data mode. Quota mode: none.
    [Tue Aug 13 16:08:38 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Tue Aug 13 16:08:39 2024] EXT4-fs (mmcblk0p2): re-mounted d3104e7d-5f59-47e0-8621-290882475163 r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET                       SOURCE         FSTYPE     OPTIONS
    /                            /dev/mmcblk0p2 ext4       rw,noatime
    |-/dev                       devtmpfs       devtmpfs   rw,relatime,size=1726396k,nr_inodes=34271,mode=755
    | |-/dev/shm                 tmpfs          tmpfs      rw,nosuid,nodev
    | |-/dev/pts                 devpts         devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
    | `-/dev/mqueue              mqueue         mqueue     rw,nosuid,nodev,noexec,relatime
    |-/proc                      proc           proc       rw,relatime
    | `-/proc/sys/fs/binfmt_misc systemd-1      autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
    |-/sys                       sysfs          sysfs      rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/security     securityfs     securityfs rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/cgroup           cgroup2        cgroup2    rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/pstore           pstore         pstore     rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/bpf              bpf            bpf        rw,nosuid,nodev,noexec,relatime,mode=700
    | |-/sys/kernel/tracing      tracefs        tracefs    rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/debug        debugfs        debugfs    rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/config       configfs       configfs   rw,nosuid,nodev,noexec,relatime
    | `-/sys/fs/fuse/connections fusectl        fusectl    rw,nosuid,nodev,noexec,relatime
    |-/run                       tmpfs          tmpfs      rw,nosuid,nodev,size=795828k,nr_inodes=819200,mode=755
    | |-/run/lock                tmpfs          tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
    | |-/run/rpc_pipefs          sunrpc         rpc_pipefs rw,relatime
    | `-/run/user/1000           tmpfs          tmpfs      rw,nosuid,nodev,relatime,size=397912k,nr_inodes=99478,mode=700,uid=1000,gid=1000
    |-/boot                      /dev/mmcblk0p1 vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/var/lib/lxcfs             lxcfs          fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    /var:
    du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
    4.7G    /var/
    3.3G    /var/log
    2.9G    /var/log/journal/6462312882a642219bbda7aff5f4f5b9
    734M    /var/lib
    Archived and active journals take up 2.8G in the file system.
    /opt/iobroker/backups:
    82M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    752M    /opt/iobroker/iobroker-data/
    594M    /opt/iobroker/iobroker-data/files
    441M    /opt/iobroker/iobroker-data/files/javascript.admin
    409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    27M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.ce422ec2.js.map
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    18M     /opt/iobroker/iobroker-data/objects.jsonl
    12M     /opt/iobroker/iobroker-data/states.jsonl
    8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.16.0
    /usr/bin/node           v20.16.0
    /usr/bin/npm            10.8.1
    /usr/bin/npx            10.8.1
    /usr/bin/corepack       0.28.2
    nodejs:
      Installed: 20.16.0-1nodesource1
      Candidate: 20.16.0-1nodesource1
      Version table:
     *** 20.16.0-1nodesource1 600
            500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
         20.15.1-1nodesource1 600
         20.15.0-1nodesource1 600
         20.14.0-1nodesource1 600
         20.13.1-1nodesource1 600
         20.13.0-1nodesource1 600
         20.12.2-1nodesource1 600
         20.12.1-1nodesource1 600
         20.12.0-1nodesource1 600
         20.11.1-1nodesource1 600
         20.11.0-1nodesource1 600
         20.10.0-1nodesource1 600
         20.9.0-1nodesource1 600
         20.8.1-1nodesource1 600
         20.8.0-1nodesource1 600
         20.7.0-1nodesource1 600
         20.6.1-1nodesource1 600
         20.6.0-1nodesource1 600
         20.5.1-1nodesource1 600
         20.5.0-1nodesource1 600
         20.4.0-1nodesource1 600
         20.3.1-1nodesource1 600
         20.3.0-1nodesource1 600
         20.2.0-1nodesource1 600
         20.1.0-1nodesource1 600
         20.0.0-1nodesource1 600
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.19
    admin:          7.0.22
    javascript:     8.7.6
    nodejs modules from github:     1
    +-- iobroker.vw-connect@0.5.3 (git+ssh://git@github.com/TA2k/ioBroker.vw-connect.git#b5fbfb41f65b8a1efb646e9efb68f1cbd1627d27)
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : iobroker-pi                              -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker-pi                              -  enabled
      system.adapter.device-reminder.0        : device-reminder       : iobroker-pi                              -  enabled
      system.adapter.discovery.0              : discovery             : iobroker-pi                              -  enabled
      system.adapter.ems-esp.0                : ems-esp               : iobroker-pi                              -  enabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker-pi                              -  enabled
      system.adapter.habpanel.0               : habpanel              : iobroker-pi                              -  enabled
    + system.adapter.history.0                : history               : iobroker-pi                              -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker-pi                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-pi                              -  enabled, port: 18701
      system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-pi                              -  enabled, port: 12001
      system.adapter.hm-rpc.2                 : hm-rpc                : iobroker-pi                              -  enabled, port: 12010
    + system.adapter.influxdb.0               : influxdb              : iobroker-pi                              -  enabled, port: 8086
      system.adapter.info.0                   : info                  : iobroker-pi                              -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker-pi                              -  enabled
      system.adapter.mqtt.0                   : mqtt                  : iobroker-pi                              -  enabled, port: 1883, bind: 192.168.178.10
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker-pi                              -  enabled
      system.adapter.rpi2.0                   : rpi2                  : iobroker-pi                              -  enabled
      system.adapter.shelly.0                 : shelly                : iobroker-pi                              -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.simple-api.0             : simple-api            : iobroker-pi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.tr-064.0                 : tr-064                : iobroker-pi                              -  enabled
      system.adapter.tuya.0                   : tuya                  : iobroker-pi                              - disabled
      system.adapter.vw-connect.0             : vw-connect            : iobroker-pi                              -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : iobroker-pi                              - disabled
      system.adapter.web.0                    : web                   : iobroker-pi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker-pi                              -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.0.22   , installed 7.0.22
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "backitup"     : 3.0.16   , installed 3.0.16
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "discovery"    : 4.5.0    , installed 4.5.0
    Adapter    "ems-esp"      : 3.5.0    , installed 3.5.0
    Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
    Adapter    "javascript"   : 8.7.6    , installed 8.7.6
    Controller "js-controller": 6.0.9    , installed 5.0.19 [Updatable]
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
    Adapter    "shelly"       : 7.0.0    , installed 7.0.0
    Adapter    "tuya"         : 3.15.0   , installed 3.15.0
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Objects and States
    Objects:        7430
    States:         6295
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 https://repos.influxdata.com/debian bullseye InRelease
    Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:4 https://packages.grafana.com/oss/deb stable InRelease
    Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
    Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          6228       814/dnsmasq
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6194       785/sshd: /usr/sbin
    tcp        0      0 192.168.178.10:12001    0.0.0.0:*               LISTEN      1001       12319      1854/io.hm-rpc.1
    tcp        0      0 192.168.178.10:12010    0.0.0.0:*               LISTEN      1001       12330      1869/io.hm-rpc.2
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       9377       1407/io.shelly.0
    tcp        0      0 192.168.178.10:1883     0.0.0.0:*               LISTEN      1001       8528       1324/io.mqtt.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       7195       905/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       5644       905/iobroker.js-con
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        6272       730/influxd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          6196       785/sshd: /usr/sbin
    tcp6       0      0 :::3000                 :::*                    LISTEN      111        5642       904/grafana
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        6362       730/influxd
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       6952       1464/io.simple-api.
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       7769       1483/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7239       990/io.admin.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        787        337/avahi-daemon: r
    udp        0      0 0.0.0.0:47656           0.0.0.0:*                           108        789        337/avahi-daemon: r
    udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          6227       814/dnsmasq
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          6224       814/dnsmasq
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          897        598/dhclient
    udp6       0      0 :::5353                 :::*                                108        788        337/avahi-daemon: r
    udp6       0      0 :::34059                :::*                                108        790        337/avahi-daemon: r
    2024-08-13 16:10:57.691  - info: hm-rpc.1 (1854) starting. Version 1.17.0 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v20.16.0, js-controller: 5.0.19
    2024-08-13 16:10:58.329  - info: hm-rpc.1 (1854) xmlrpc server is trying to listen on 192.168.178.10:12001
    2024-08-13 16:10:58.342  - info: hm-rpc.1 (1854) xmlrpc client is trying to connect to 192.168.178.12:2001/ with ["http://192.168.178.10:12001","iobroker-pi:hm-rpc.1:d56a41b7e622f59142e1fdc67550700c"]
    2024-08-13 16:10:59.322  - info: shelly.0 (1407) [MQTT] Client Close:  (shelly1pmminig3 / shelly1pmminig3-5432044f4ff4 / shelly1pmminig3#5432044f4ff4#1) (false)
    2024-08-13 16:10:59.922  - error: shelly.0 (1407) [MQTT] Unable to get mqttprefix of client with id "shelly1pmminig3-5432044f4ff4"
    2024-08-13 16:11:00.713  - info: hm-rpc.2 (1869) starting. Version 1.17.0 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v20.16.0, js-controller: 5.0.19
    2024-08-13 16:11:00.868  - info: shelly.0 (1407) [MQTT] Client Close: 192.168.178.78 (shellyplusplugs / shellyplusplugs-d4d4dae85f70 / shellyplusplugs#d4d4dae85f70#1) (false)
    2024-08-13 16:11:00.928  - error: shelly.0 (1407) [MQTT] Error in function setMqttPrefixHttp (Gen 1) for  (undefined / undefined / undefined): TypeError: Cannot read properties of undefined (reading 'replace')
    2024-08-13 16:11:00.929  - error: shelly.0 (1407) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-d4d4dae85f70"
    2024-08-13 16:11:01.071  - info: hm-rpc.2 (1869) xmlrpc server is trying to listen on 192.168.178.10:12010
    2024-08-13 16:11:01.077  - info: hm-rpc.2 (1869) xmlrpc client is trying to connect to 192.168.178.12:2010/ with ["http://192.168.178.10:12010","iobroker-pi:hm-rpc.2:03c58894ec83886e7c67f29e17b46f89"]
    2024-08-13 16:11:01.519  - error: hm-rpc.2 (1869) Init not possible, going to stop: connect EHOSTUNREACH 192.168.178.12:2010
    2024-08-13 16:11:01.525  - error: hm-rpc.1 (1854) Init not possible, going to stop: connect EHOSTUNREACH 192.168.178.12:2001
    2024-08-13 16:11:02.712  - info: ems-esp.0 (1426) ems  : energy polling every 10 minutes
    2024-08-13 16:11:02.713  - info: ems-esp.0 (1426) ems  : polling every 15 secs
    2024-08-13 16:11:10.056  - info: fb-checkpresence.0 (1726) createFbDeviceObjects finished successfully
    2024-08-13 16:11:10.058  - info: fb-checkpresence.0 (1726) states successfully subscribed
    2024-08-13 16:11:10.059  - info: fb-checkpresence.0 (1726) loop successfully started
    2024-08-13 16:11:20.232  - info: hm-rpc.0 (1791) binrpc -> 192.168.178.12:8701/ init ["xmlrpc_bin://192.168.178.10:18701",""]
    2024-08-13 16:11:20.238  - error: hm-rpc.0 (1791) Cannot call init: [xmlrpc_bin://192.168.178.10:18701, ""] Socket closed before the connection was established
    2024-08-13 16:11:20.246  - info: hm-rpc.0 (1791) terminating
    2024-08-13 16:11:20.248  - info: hm-rpc.0 (1791) Terminated (NO_ERROR): Without reason
    2024-08-13 16:11:20.853  - info: host.iobroker-pi instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
    2024-08-13 16:11:20.854  - info: host.iobroker-pi Restart adapter system.adapter.hm-rpc.0 because enabled
    2024-08-13 16:11:23.334  - error: hm-rega.0 (1231) CCU 192.168.178.12 unreachable
    Meister MopperM Online
    Meister Mopper
    @wibear
    Es ist dir doch oben schon einmal gelungen, klopp bitte die lange Fassung in </> (codetags) hier rein.
    Das ist sonst grottenschlecht zu lesen.
    Proxmox und HA ...
    W Thomas BraunT 3 Antworten Letzte Antwort
    • W wibear
      Nach reboot:
      Skript v.2024-05-22
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm
      Docker          : false
      Kernel          : armv7l
      Userland        : 32 bit
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      wibear
      HOME=/home/wibear
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               3885 M total memory
               1016 M used memory
                156 M active memory
               2349 M free memory
                 48 M buffer memory
                471 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      *** FILESYSTEM ***
      /var:
      4.7G    /var/
      3.3G    /var/log
      734M    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            10.8.1
      /usr/bin/npx            10.8.1
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          7.0.22
      javascript:     8.7.6
      Adapter State
      + instance is alive
      Objects and States
      Objects:        7430
      States:         6295
      Pending Updates: 0
      @wibear sagte in pivCCU nach Update node.js nicht erreichbar:
      Da klemmt es. Hat aber nix mit nodejs oder dem ioBroker zu tun, da werden die pivCCU Module nicht geladen.
      Und wo du einmal dran bist:
      iob stop
      iob update
      iob upgrade self
      iob start
      W 1 Antwort Letzte Antwort
        @wibear
        W Offline
        W Offline
        wibear
        @meister-mopper sagte in pivCCU nach Update node.js nicht erreichbar:
                                v.2024-05-22
                 Icon name: computer
              Architecture: arm
        Kernel:                 armv7l
        Userland:               32 bit
        User-ID:                1000
        Pending OS-Updates:     0
        Pending iob updates:    1
        Nodejs-Installation:
        /usr/bin/npm            10.8.1
        /usr/bin/npx            10.8.1
        Recommended versions are nodejs 20.16.0 and npm 10.8.1
        MEMORY:
        Mem:            3.9G        945M        2.3G        1.0M        604M        2.8G
        Swap:            99M          0B         99M
        Total:          4.0G        945M        2.4G
        Active iob-Instances:   21
        ioBroker Core:          js-controller           5.0.19
                                admin                   7.0.22
        Objects type: jsonl
        States  type: jsonl
        + system.adapter.web.0                    : web                   : iobroker-pi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        Objects:                7430
        States:                 6297
        Size of iob-Database:
        9.6M    /opt/iobroker/iobroker-data/objects.jsonl
        13M     /opt/iobroker/iobroker-data/states.jsonl
          @wibear
          Die Ausgabe von iob diag hat die schon dabei. Muss nur kopiert und eingefügt werden.
          Jetzt sind zwei CodeTags drumherum, das ist auch falsch.
            @wibear
            W Offline
            W Offline
            wibear
            Ist es besser?
            Skript v.2024-05-22
            *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm
            Docker          : false
            Kernel          : armv7l
            Userland        : 32 bit
             16:21:41 up 13 min,  1 user,  load average: 1.00, 1.08, 0.80
            CPU threads: 4
            Current issues:
                           Local time: Tue 2024-08-13 16:21:42 CEST
                       Universal time: Tue 2024-08-13 14:21:42 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            wibear
            HOME=/home/wibear
            iobroker
            HOME=/home/iobroker
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            3.9G        941M        2.3G        1.0M        626M        2.8G
            Swap:            99M          0B         99M
            Total:          4.0G        941M        2.4G
                     3885 M total memory
                      942 M used memory
                      230 M active memory
                     1233 M inactive memory
                     2317 M free memory
                       76 M buffer memory
                      550 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            top - 16:21:42 up 13 min,  1 user,  load average: 1.00, 1.08, 0.80
            Tasks: 194 total,   1 running, 193 sleeping,   0 stopped,   0 zombie
            %Cpu(s): 30.0 us, 11.4 sy,  0.0 ni, 52.9 id,  4.3 wa,  0.0 hi,  1.4 si,  0.0 st
            MiB Mem :   3885.9 total,   2316.9 free,    942.0 used,    627.0 buff/cache
            MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2817.4 avail Mem
            *** FILESYSTEM ***
            /var:
            4.7G    /var/
            3.3G    /var/log
            738M    /var/lib
            746M    /opt/iobroker/iobroker-data/
            USB-Devices by-id:
            /usr/bin/npm            10.8.1
            /usr/bin/npx            10.8.1
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          7.0.22
            javascript:     8.7.6
            Adapter State
            + system.adapter.device-reminder.0        : device-reminder       : iobroker-pi                              -  enabled
            + system.adapter.discovery.0              : discovery             : iobroker-pi                              -  enabled
            + system.adapter.ems-esp.0                : ems-esp               : iobroker-pi                              -  enabled
            + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker-pi                              -  enabled
            + system.adapter.mqtt.0                   : mqtt                  : iobroker-pi                              -  enabled, port: 1883, bind: 192.168.178.10
            + system.adapter.rpi2.0                   : rpi2                  : iobroker-pi                              -  enabled
            + system.adapter.shelly.0                 : shelly                : iobroker-pi                              -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.simple-api.0             : simple-api            : iobroker-pi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            + system.adapter.tr-064.0                 : tr-064                : iobroker-pi                              -  enabled
            + system.adapter.vw-connect.0             : vw-connect            : iobroker-pi                              -  enabled
            + instance is alive
            Objects and States
            Objects:        7430
            States:         6279
            Hit:1 https://repos.influxdata.com/debian bullseye InRelease
            Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
            Hit:6 https://packages.grafana.com/oss/deb stable InRelease
            Pending Updates: 0
            tcp        0      0 192.168.178.10:12001    0.0.0.0:*               LISTEN      1001       39110      5590/io.hm-rpc.1
            tcp        0      0 192.168.178.10:12010    0.0.0.0:*               LISTEN      1001       36706      5591/io.hm-rpc.2
            2024-08-13 16:21:48.384  - info: hm-rpc.2 (4770) Terminated (NO_ERROR): Without reason
            2024-08-13 16:21:49.099  - info: host.iobroker-pi instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
            2024-08-13 16:21:49.099  - info: host.iobroker-pi Restart adapter system.adapter.hm-rpc.1 because enabled
            2024-08-13 16:21:49.099  - info: host.iobroker-pi instance system.adapter.hm-rpc.2 terminated with code 0 (NO_ERROR)
            2024-08-13 16:21:49.100  - info: host.iobroker-pi Restart adapter system.adapter.hm-rpc.2 because enabled
            2024-08-13 16:21:49.884  - info: hm-rpc.0 (5004) starting. Version 1.17.0 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v20.16.0, js-controller: 5.0.19
            2024-08-13 16:21:50.185  - info: hm-rpc.0 (5004) binrpc server is trying to listen on 192.168.178.10:18701
            2024-08-13 16:21:50.187  - info: hm-rpc.0 (5004) binrpc client is trying to connect to 192.168.178.12:8701/ with ["xmlrpc_bin://192.168.178.10:18701","iobroker-pi:hm-rpc.0:586ced57dee52ef270bfb61be9f07a73"]
            2024-08-13 16:21:50.457  - error: hm-rpc.0 (5004) Init not possible, going to stop: connect EHOSTUNREACH 192.168.178.12:8701
            2024-08-13 16:21:50.461  - error: hm-rega.0 (1231) CCU 192.168.178.12 unreachable
            2024-08-13 16:22:19.230  - info: host.iobroker-pi instance system.adapter.hm-rpc.1 started with pid 5590
            2024-08-13 16:22:19.243  - info: host.iobroker-pi instance system.adapter.hm-rpc.2 started with pid 5591
            2024-08-13 16:22:20.462  - info: hm-rpc.0 (5004) binrpc -> 192.168.178.12:8701/ init ["xmlrpc_bin://192.168.178.10:18701",""]
            2024-08-13 16:22:20.481  - error: hm-rpc.0 (5004) Cannot call init: [xmlrpc_bin://192.168.178.10:18701, ""] Socket closed before the connection was established
            2024-08-13 16:22:20.542  - info: hm-rpc.0 (5004) terminating
            2024-08-13 16:22:20.544  - info: hm-rpc.0 (5004) Terminated (NO_ERROR): Without reason
            2024-08-13 16:22:21.115  - info: host.iobroker-pi instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
            2024-08-13 16:22:23.573  - error: hm-rega.0 (1231) CCU 192.168.178.12 unreachable
            2024-08-13 16:22:21.116  - info: host.iobroker-pi Restart adapter system.adapter.hm-rpc.0 because enabled
            2024-08-13 16:22:25.483  - info: hm-rpc.1 (5590) starting. Version 1.17.0 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v20.16.0, js-controller: 5.0.19
            2024-08-13 16:22:25.516  - info: hm-rpc.2 (5591) starting. Version 1.17.0 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v20.16.0, js-controller: 5.0.19
            2024-08-13 16:22:25.834  - info: hm-rpc.1 (5590) xmlrpc server is trying to listen on 192.168.178.10:12001
            2024-08-13 16:22:25.835  - info: hm-rpc.1 (5590) xmlrpc client is trying to connect to 192.168.178.12:2001/ with ["http://192.168.178.10:12001","iobroker-pi:hm-rpc.1:b7e0bbb00b214da627cd2ac33e1e6a94"]
            2024-08-13 16:22:25.863  - info: hm-rpc.2 (5591) xmlrpc server is trying to listen on 192.168.178.10:12010
            2024-08-13 16:22:25.865  - info: hm-rpc.2 (5591) xmlrpc client is trying to connect to 192.168.178.12:2010/ with ["http://192.168.178.10:12010","iobroker-pi:hm-rpc.2:53dc961ed27d3c18a140cba29ed780cc"]
            • W wibear
              Ist es besser?
              Skript v.2024-05-22
              *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm
              Docker          : false
              Kernel          : armv7l
              Userland        : 32 bit
              CPU threads: 4
              Current issues:
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              wibear
              HOME=/home/wibear
              iobroker
              HOME=/home/iobroker
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:            99M          0B         99M
                       3885 M total memory
                        942 M used memory
                        230 M active memory
                       2317 M free memory
                         76 M buffer memory
                        550 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              *** FILESYSTEM ***
              /var:
              4.7G    /var/
              3.3G    /var/log
              738M    /var/lib
              USB-Devices by-id:
              /usr/bin/npm            10.8.1
              /usr/bin/npx            10.8.1
              nodejs:
                Version table:
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          7.0.22
              javascript:     8.7.6
              Adapter State
              + instance is alive
              Objects and States
              Objects:        7430
              States:         6279
              Pending Updates: 0
              DJMarc75D Offline
              DJMarc75D Offline
              DJMarc75
              Ist es besser?
              Wie Du vielleicht selbst siehst - nein ;)
              Lehrling seit 1975 !!!
              • DJMarc75D DJMarc75
                Ist es besser?
                @djmarc75 sagte in pivCCU nach Update node.js nicht erreichbar:
                Ist es besser?
                jetzt, ja!
                im ersten hab ich nicht alle versteckten code-tags finden und fixen können
                EDIT: Jetzt aber!
                  iob stop
                  iob update
                  iob upgrade self
                  iob start
                  W Offline
                  W Offline
                  wibear
                  @thomas-braun sagte in pivCCU nach Update node.js nicht erreichbar:
                  ausgeführt
                  • W wibear
                    ausgeführt
                    @wibear
                    Dann ist ioBroker-seitig jetzt alles i.O.
                    • W wibear
                      iob diag
                      Docker : false
                      Kernel : armv7l
                      Userland : 32 bit
                      15:51:21 up 35 min, 1 user, load average: 1.13, 0.75, 2.22
                      CPU threads: 4
                      Copy text starting here:
                                              v.2024-05-22
                      Current issues:
                                     Local time: Tue 2024-08-13 15:51:21 CEST
                                 Universal time: Tue 2024-08-13 13:51:21 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      wibear
                      HOME=/home/wibear
                      iobroker
                      HOME=/home/iobroker
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            3.9G        1.1G        2.2G        1.0M        568M        2.6G
                      Swap:            99M          0B         99M
                      Total:          4.0G        1.1G        2.3G
                      Active iob-Instances:   20
                               3885 M total memory
                               1134 M used memory
                                179 M active memory
                               1411 M inactive memory
                               2182 M free memory
                                 64 M buffer memory
                                504 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      top - 15:51:22 up 35 min,  1 user,  load average: 1.13, 0.75, 2.22
                      Tasks: 219 total,   3 running, 216 sleeping,   0 stopped,   0 zombie
                      %Cpu(s): 25.8 us,  9.7 sy,  0.0 ni, 54.8 id,  6.5 wa,  0.0 hi,  3.2 si,  0.0 st
                      MiB Mem :   3885.9 total,   2184.1 free,   1132.9 used,    568.8 buff/cache
                      MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2635.5 avail Mem
                      *** FILESYSTEM ***
                      [Tue Aug 13 15:15:44 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:16:18:C4 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=tty1 root=PARTUUID=e605bf32-02 rootfstype=ext4 fsck.repair=yes rootwait
                      [Tue Aug 13 15:15:45 2024] EXT4-fs (mmcblk0p2): mounted filesystem d3104e7d-5f59-47e0-8621-290882475163 ro with ordered data mode. Quota mode: none.
                      [Tue Aug 13 15:15:45 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                      [Tue Aug 13 15:15:46 2024] EXT4-fs (mmcblk0p2): re-mounted d3104e7d-5f59-47e0-8621-290882475163 r/w. Quot   Static hostname: iobroker-pi
                               Icon name: computer
                            Architecture: arm
                      Kernel:                 armv7l
                      Userland:               32 bit
                      User-ID:                1000
                      /usr/local/bin/node             v18.18.0
                      /usr/local/bin/npm              10.8.2
                      /usr/local/bin/npx              10.8.2
                      /usr/local/bin/corepack         0.19.0
                      *** nodejs is NOT correctly installed ***
                      Wrong installation path detected. This needs to be fixed.
                      Please execute
                      iobroker nodejs-update
                      to fix these errors.
                      MEMORY:
                      Mem:            3.9G        1.2G        2.0G        1.0M        649M        2.5G
                      Swap:            99M          0B         99M
                      Total:          4.0G        1.2G        2.1G
                                              admin                   7.0.22
                      Objects type: jsonl
                      States  type: jsonl
                      Objects:                7401
                      States:                 6256
                      15M     /opt/iobroker/iobroker-data/objects.jsonl
                      9.0M    /opt/iobroker/iobroker-data/states.jsonl
                      === Mark text until here for copying ===
                      wibear@iobroker-pi:~ $ ======== Start marking the full check here =========
                      -bash: ========: command not found
                      > Skript v.2024-05-22
                      > *** BASE SYSTEM ***
                      >          Icon name: computer
                      >       Architecture: arm
                      > Docker          : false
                      > Kernel          : armv7l
                      > Userland        : 32 bit
                      > CPU threads: 4
                      > Current issues:
                      > No throttling issues detected.
                      >                  RTC time: n/a
                      />                 Time zone: Europe/Berlin (CEST, +0200)
                      > System clock synchronized: yes
                      >               NTP service: active
                      >           RTC in local TZ: no
                      > wibear
                      > HOME=/home/wibear
                      > User that is running 'js-controller':
                      > iobroker
                      > HOME=/home/iobroker
                      > GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                      > Desktop:
                      > Terminal:       tty
                      > *** MEMORY ***
                      >                total        used        free      shared  buff/cache   available
                      > Swap:            99M          0B         99M
                      >          3885 M total memory
                      >          1134 M used memory
                      >           179 M active memory
                      >          2182 M free memory
                      >            64 M buffer memory
                      >           504 M swap cache
                      >            99 M total swap
                      >             0 M used swap
                      >            99 M free swap
                      > *** top - Table Of Processes  ***
                      > LOAD   = Reflects whether the unit definition was properly loaded.
                      > ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                      > SUB    = The low-level unit activation state, values depend on unit type.
                      > *** FILESYSTEM ***
                      > Filesystem     Type      Size  Used Avail Use% Mounted on
                      > Messages concerning ext4 filesystem in dmesg:
                      > [Tue Aug 13 15:15:46 2024] EXT4-fs (mmcblk0p2): re-mounted d3104e7d-5f59-47e0-8621-290882475163 r/w. Quota mode: none.
                      -bash: Skript: command not found
                      -bash: node_modules: command not found
                      -bash: Static: command not found
                      -bash: Icon: command not found
                      -bash: command substitution: line 7: syntax error near unexpected token `('
                      -bash: command substitution: line 7: `  Operating System: Raspbian GNU/Linux 11 (bullseye)'
                      -bash: -/dev/mqueue: No such file or directory
                      wibear@iobroker-pi:~ $ |-/proc                      proc           proc       rw,relatime
                      -bash: syntax error near unexpected token `|'
                      wibear@iobroker-pi:~ $ | `-/proc/sys/fs/binfmt_misc systemd-1      autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                      wibear@iobroker-pi:~ $ |-/sys                       sysfs          sysfs      rw,nosuid,nodev,noexec,relatime
                      wibear@iobroker-pi:~ $ | |-/sys/kernel/security     securityfs     securityfs rw,nosuid,nodev,noexec,relatime
                      wibear@iobroker-pi:~ $ | |-/sys/fs/cgroup           cgroup2        cgroup2    rw,nosuid,nodev,noexec,relatime
                      wibear@iobroker-pi:~ $ | |-/sys/fs/pstore           pstore         pstore     rw,nosuid,nodev,noexec,relatime
                      wibear@iobroker-pi:~ $ | |-/sys/fs/bpf              bpf            bpf        rw,nosuid,nodev,noexec,relatime,mode=700
                      wibear@iobroker-pi:~ $ | |-/sys/kernel/tracing      tracefs        tracefs    rw,nosuid,nodev,noexec,relatime
                      wibear@iobroker-pi:~ $ | |-/sys/kernel/debug        debugfs        debugfs    rw,nosuid,nodev,noexec,relatime
                      wibear@iobroker-pi:~ $ | |-/sys/fs/fuse/connections fusectl        fusectl    rw,nosuid,nodev,noexec,relatime
                      wibear@iobroker-pi:~ $ | `-/sys/kernel/config       configfs       configfs   rw,nosuid,nodev,noexec,relatime
                      wibear@iobroker-pi:~ $ |-/run                       tmpfs          tmpfs      rw,nosuid,nodev,size=795828k,nr_inodes=819200,mode=755
                      wibear@iobroker-pi:~ $ | |-/run/lock                tmpfs          tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
                      wibear@iobroker-pi:~ $ | |-/run/rpc_pipefs          sunrpc         rpc_pipefs rw,relatime
                      wibear@iobroker-pi:~ $ | `-/run/user/1000           tmpfs          tmpfs      rw,nosuid,nodev,relatime,size=397912k,nr_inodes=99478,mode=700,uid=1000,gid=1000
                      wibear@iobroker-pi:~ $ |-/boot                      /dev/mmcblk0p1 vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                      wibear@iobroker-pi:~ $ `-/var/lib/lxcfs             lxcfs          fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                      > Files in neuralgic directories:
                      > /var:
                      > 4.6G    /var/
                      > 3.3G    /var/log
                      > 729M    /var/lib
                      > 747M    /opt/iobroker/iobroker-data/
                      > The five largest files in iobroker-data are:
                      > 8.7M    /opt/iobroker/iobroker-data/states.jsonl
                      > USB-Devices by-id:
                      > USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id':
                      0        : device-reminder > /usr/local/bin/npx              10.8.2
                      > nodejs:
                      >   Version table:
                      > Temp directories causing npm8 problem: 0
                      > Errors in npm tree:
                      > ioBroker Status
                      > iobroker is running on this host.
                      > Objects type: jsonl
                      > States  type: jsonl
                      > admin:          7.0.22
                      > javascript:     8.7.6
                      > Adapter State
                      > + instance is alive
                      > Enabled adapters with bindings
                      > stable        : http://download.iobroker.net/sources-dist.json
                      > beta          : http://download.iobroker.net/sources-dist-latest.json
                      > Adapter    "history"      : 3.0.1    , installed 3.0.1
                      > Adapter    "influxdb"     : 4.0.2    , installed 4.0.2
                      > Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                      > Objects and States
                      > Please stand by - This may take a while
                      > Objects:        7401
                      > States:         6256
                      > *** OS-Repositories and Updates ***
                      > Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                      > Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                      > Hit:5 https://packages.grafana.com/oss/deb stable InRelease
                      > Hit:6 https://apt.pivccu.de/piVCCU stable InRelease
                      > Pending Updates: 0
                      > Active Internet connections (only servers)
                      > Proto Recv-Q Send-Q Local Address           Foreign Address         State       User       Inode      PID/Program name
                      > tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        6286       745/influxd
                      > tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       8815       1209/io.shelly.0
                      > tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6351       884/iobroker.js-con
                      > tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       5758       884/iobroker.js-con
                      > tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4770       787/sshd: /usr/sbin
                      > tcp        0      0 192.168.178.10:1883     0.0.0.0:*               LISTEN      1001       6997       1170/io.mqtt.0
                      > tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          4793       814/dnsmasq
                      > tcp6       0      0 :::8086                 :::*                    LISTEN      999        4863       745/influxd
                      > tcp6       0      0 :::8087                 :::*                    LISTEN      1001       9583       1272/io.simple-api.
                      > tcp6       0      0 :::8082                 :::*                    LISTEN      1001       8850       1314/io.web.0
                      > tcp6       0      0 :::8081                 :::*                    LISTEN      1001       5806       951/io.admin.0
                      > tcp6       0      0 :::3000                 :::*                    LISTEN      111        5756       883/grafana
                      48
                      > tcp6       0      0 :::22                   :::*                    LISTEN      0          4772       787/sshd: /usr/sbin
                      > udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        5445       372/avahi-daemon: r
                      > udp        0      0 0.0.0.0:55700           0.0.0.0:*                           108        5447       372/avahi-daemon: r
                      > udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          4792       814/dnsmasq
                      > udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          4789       814/dnsmasq
                      > udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          4602       596/dhclient
                      > udp6       0      0 :::5353                 :::*                                108        5446       372/avahi-daemon: r
                      > udp6       0      0 :::48974                :::*                                108        5448       372/avahi-daemon: r
                      > *** Log File - Last 25 Lines ***
                      > 2024-08-13 15:51:30.782  - info: hm-rpc.2 (6575) xmlrpc client is trying to connect to 192.168.178.12:2010/ with ["http://192.168.178.10:12010","iobroker-pi:hm-rpc.2:325a5da9b9959b38a1d02500f5dff733"]
                      > 2024-08-13 15:51:30.849  - info: hm-rpc.1 (6586) xmlrpc server is trying to listen on 192.168.178.10:12001
                      > 2024-08-13 15:51:30.850  - info: hm-rpc.1 (6586) xmlrpc client is trying to connect to 192.168.178.12:2001/ with ["http://192.168.178.10:12001","iobroker-pi:hm-rpc.1:77e7296879feb3366411ef62aab861bd"]
                      > 2024-08-13 15:51:33.949  - error: hm-rpc.2 (6575) Init not possible, going to stop: connect EHOSTUNREACH 192.168.178.12:2010
                      > 2024-08-13 15:51:33.957  - error: hm-rpc.1 (6586) Init not possible, going to stop: connect EHOSTUNREACH 192.168.178.12:2001
                      > 2024-08-13 15:51:49.143  - info: hm-rpc.0 (6422) binrpc -> 192.168.178.12:8701/ init ["xmlrpc_bin://192.168.178.10:18701",""]
                      > 2024-08-13 15:51:49.160  - error: hm-rpc.0 (6422) Cannot call init: [xmlrpc_bin://192.168.178.10:18701, ""] Socket closed before the connection was established
                      > 2024-08-13 15:51:49.232  - info: hm-rpc.0 (6422) terminating
                      > 2024-08-13 15:51:49.234  - info: hm-rpc.0 (6422) Terminated (NO_ERROR): Without reason
                      > 2024-08-13 15:51:49.835  - info: host.iobroker-pi instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
                      > 2024-08-13 15:51:49.836  - info: host.iobroker-pi Restart adapter system.adapter.hm-rpc.0 because enabled
                      > 2024-08-13 15:51:52.253  - error: hm-rega.0 (2659) CCU 192.168.178.12 unreachable
                      > 2024-08-13 15:52:03.933  - error: hm-rpc.2 (6575) Init not possible, going to stop: connect EHOSTUNREACH 192.168.178.12:2010
                      > 2024-08-13 15:52:03.935  - error: hm-rpc.1 (6586) Init not possible, going to stop: connect EHOSTUNREACH 192.168.178.12:2001
                      > 2024-08-13 15:52:03.960  - info: hm-rpc.1 (6586) xmlrpc -> 192.168.178.12:2001/ init ["http://192.168.178.10:12001",""]
                      > 2024-08-13 15:52:03.964  - info: hm-rpc.2 (6575) xmlrpc -> 192.168.178.12:2010/ init ["http://192.168.178.10:12010",""]
                      > 2024-08-13 15:52:04.969  - info: hm-rpc.1 (6586) terminating
                      > 2024-08-13 15:52:04.971  - info: hm-rpc.1 (6586) Terminated (NO_ERROR): Without reason
                      > 2024-08-13 15:52:04.978  - info: hm-rpc.2 (6575) terminating
                      > 2024-08-13 15:52:04.980  - info: hm-rpc.2 (6575) Terminated (NO_ERROR): Without reason
                      > 2024-08-13 15:52:05.572  - info: host.iobroker-pi instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
                      > 2024-08-13 15:52:05.573  - info: host.iobroker-pi Restart adapter system.adapter.hm-rpc.1 because enabled
                      > 2024-08-13 15:52:05.618  - info: host.iobroker-pi instance system.adapter.hm-rpc.2 terminated with code 0 (NO_ERROR)
                      > 2024-08-13 15:52:05.619  - info: host.iobroker-pi Restart adapter system.adapter.hm-rpc.2 because enabled
                      > 2024-08-13 15:52:19.916  - info: host.iobroker-pi instance system.adapter.hm-rpc.0 started with pid 7348
                      -bash: -/var/lib/lxcfs: No such file or directory
                      -bash: Files: command not found
                      -bash: /var:: No such file or directory
                      -bash: du:: command not found
                      -bash: 4.6G: command not found
                      -bash: 3.3G: command not found
                      -bash: 2.9G: command not found
                      -bash: 729M: command not found
                      -bash: Archived: command not found
                      -bash: /opt/iobroker/backups:: No such file or directory
                      -bash: 82M: command not found
                      -bash: /opt/iobroker/iobroker-data:: No such file or directory
                      -bash: 747M: command not found
                      -bash: 594M: command not found
                      -bash: 441M: command not found
                      -bash: 409M: command not found
                      -bash: 408M: command not found
                      -bash: The: command not found
                      -bash: 27M: command not found
                      -bash: 24M: command not found
                      -bash: 15M: command not found
                      -bash: 8.7M: command not found
                      -bash: USB-Devices: command not found
                      -bash: USB-Sticks: command not found
                      -bash: No: command not found
                      node:internal/modules/cjs/loader:1148
                        throw err;
                      Error: Cannot find module '/home/wibear/v20.16.0'
                          at Module._resolveFilename (node:internal/modules/cjs/loader:1145:15)
                          at Module._load (node:internal/modules/cjs/loader:986:27)
                          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
                          at node:internal/main/run_main_module:28:49 {
                        code: 'MODULE_NOT_FOUND',
                        requireStack: []
                      Node.js v20.16.0
                      node:internal/modules/cjs/loader:1080
                        throw err;
                      Error: Cannot find module '/home/wibear/v18.18.0'
                          at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
                          at Module._load (node:internal/modules/cjs/loader:922:27)
                          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:86:12)
                          at node:internal/main/run_main_module:23:47 {
                        requireStack: []
                      Node.js v18.18.0
                      npm error code ENOVERSIONS
                      npm error No versions available for 10.8.2
                      npm error A complete log of this run can be found in: /home/wibear/.npm/_logs/2024-08-13T13_53_15_245Z-debug-0.log
                      -bash: nodejs:: command not found
                      -bash: Installed:: command not found
                      -bash: Candidate:: command not found
                      -bash: Version: command not found
                      -bash: 500: command not found
                      -bash: 100: command not found
                      -bash: 20.15.1-1nodesource1: command not found
                      -bash: 20.15.0-1nodesource1: command not found
                      -bash: 20.14.0-1nodesource1: command not found
                      -bash: 20.13.1-1nodesource1: command not found
                      -bash: 20.13.0-1nodesource1: command not found
                      -bash: 20.12.2-1nodesource1: command not found
                      -bash: 20.12.1-1nodesource1: command not found
                      -bash: 20.12.0-1nodesource1: command not found
                      -bash: 20.11.1-1nodesource1: command not found
                      -bash: 20.11.0-1nodesource1: command not found
                      -bash: 20.10.0-1nodesource1: command not found
                      -bash: 20.9.0-1nodesource1: command not found
                      -bash: 20.8.1-1nodesource1: command not found
                      -bash: 20.8.0-1nodesource1: command not found
                      -bash: 20.7.0-1nodesource1: command not found
                      -bash: 20.6.1-1nodesource1: command not found
                      -bash: 20.6.0-1nodesource1: command not found
                      -bash: 20.5.1-1nodesource1: command not found
                      -bash: 20.5.0-1nodesource1: command not found
                      -bash: 20.4.0-1nodesource1: command not found
                      -bash: 20.3.1-1nodesource1: command not found
                      -bash: 20.3.0-1nodesource1: command not found
                      -bash: 20.2.0-1nodesource1: command not found
                      -bash: 20.1.0-1nodesource1: command not found
                      -bash: 20.0.0-1nodesource1: command not found
                      -bash: 12.22.12~dfsg-1~deb11u4: command not found
                      -bash: Temp: command not found
                      -bash: Errors: command not found
                      -bash: ioBroker: command not found
                      iobroker [command]
                      Commands:
                        iobroker setup                                               Setup ioBroker
                        iobroker start [all|<adapter>.<instance>|<adapter>]          Starts the js-controller or a specified adapter instance or all instances of an adapter
                        iobroker stop [<adapter>.<instance>|<adapter>]               stops the js-controller or a specified adapter instance or all instances of an adapter
                        iobroker restart [<adapter>.<instance>|<adapter>]            Restarts js-controller or a specified adapter instance or all instances of an adapter  [aliases: r]
                        iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
                        iobroker info                                                Shows the host info
                        iobroker logs [<adapter>]                                    Monitor log
                        iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
                        iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
                        iobroker rebuild [<module>]                                  Rebuild all native modules or path
                        iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
                        iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
                        iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
                        iobroker update [<repositoryUrl>]                            Update repository and list adapters
                        iobroker upgrade                                             Upgrade management
                        iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
                        iobroker object                                              Object management  [aliases: o]
                        iobroker state                                               State management  [aliases: s]
                        iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
                        iobroker list <type> [<filter>]                              List all entries, like objects
                        iobroker chmod <mode> <file>                                 Change file rights
                        iobroker chown <user> <group> <file>                         Change file ownership
                        iobroker touch <file>                                        Touch file
                        iobroker rm <file>                                           Remove file
                        iobroker file                                                File management
                        iobroker user                                                User commands
                        iobroker group                                               group management
                        iobroker host <hostname>                                     Set host to given hostname
                        iobroker set <adapter>.<instance>                            Change settings of adapter config
                        iobroker license <license.file or license.text>              Update license by given file
                        iobroker cert                                                Certificate management
                        iobroker clean <yes>                                         Clears all objects and states
                        iobroker backup                                              Create backup
                        iobroker restore <backup name or path>                       Restore a specified backup
                        iobroker validate <backup name or path>                      Validate a specified backup
                        iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
                        iobroker repo [<name>]                                       Show repo information
                        iobroker uuid                                                Show uuid of the installation  [aliases: id]
                        iobroker unsetup                                             Reset license, installation secret and language
                        iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
                        iobroker nodejs-update [<major-version>]                     Upgrade the Node.JS installation to the current LTS
                        iobroker multihost                                           Multihost management
                        iobroker compact                                             compact group management
                        iobroker plugin                                              Plugin management
                        iobroker vendor <passphrase> [<vendor.json>]                 Update the vendor information using given passphrase
                        iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
                      Options:
                        --help  Show help  [boolean]
                      -bash: Objects: command not found
                      -bash: States: command not found
                      -bash: Core: command not found
                      -bash: js-controller:: command not found
                      -bash: admin:: command not found
                      -bash: javascript:: command not found
                        throw err;
                      Error: Cannot find module '/home/wibear/modules'
                        requireStack: []
                      Node.js v20.16.0
                      -bash: command substitution: line 129: syntax error near unexpected token `('
                      -bash: command substitution: line 129: `+-- iobroker.vw-connect@0.5.3 (git+ssh://git@github.com/TA2k/ioBroker.vw-connect.git#b5fbfb41f65b8a1efb646e9efb68f1cbd1627d27)'
                      -bash: Unknown: command not found
                      wibear@iobroker-pi:~ $ ============ Mark until here for C&P =============
                      [1] 7854
                      -bash: ============: command not found
                      -bash: P: command not found
                      [1]+  Exit 127                ============ Mark until here for C
                      @wibear sagte:
                      FAILED SERVICES
                      Das hat nichts mit Node.js oder ioBroker zu tun.
                      • W Offline
                        W Offline
                        wibear
                        @paul53 Was könnte der Grund für FailedServices sein?
                        • W wibear
                          @wibear
                          systemctl status pivccu-dkms.service
                          systemctl status pivccu-rpi-modules.service
                          könnte dir das vielleicht verraten. Ansonsten wäre das ein Fall für die Kollegen eine Tür weiter bei pivCCU.
                          HomoranH W 2 Antworten Letzte Antwort
                            @wibear
                            @wibear
                            oder mal mit sudo pivccu-info nachsehen
                              @wibear
                              W Offline
                              W Offline
                              wibear
                              pivCCU zeigt State: STOPPED
                              Kann ich das starten?
                              • W wibear
                                Das zeigt aber mit Sicherheit noch mehr...
                                sudo systemctl start pivccu-dkms.service
                                sudo systemctl start pivccu-rpi-modules.service
                                  @wibear
                                  W Offline
                                  W Offline
                                  wibear
                                  ● pivccu-rpi-modules.service - piVCCU RPi Kernel loader
                                       Loaded: loaded (/lib/systemd/system/pivccu-rpi-modules.service; enabled; v>
                                       Active: failed (Result: exit-code) since Tue 2024-08-13 16:08:45 CEST; 36m>
                                      Process: 727 ExecStart=/var/lib/piVCCU/rpi-modules/ensure_headers.sh (code=>
                                     Main PID: 727 (code=exited, status=1/FAILURE)
                                          CPU: 15ms
                                  Aug 13 16:08:45 iobroker-pi systemd[1]: Starting piVCCU RPi Kernel loader...
                                  Aug 13 16:08:45 iobroker-pi ensure_headers.sh[727]: Could not determine kernel >
                                  Aug 13 16:08:45 iobroker-pi systemd[1]: pivccu-rpi-modules.service: Main proces>
                                  Aug 13 16:08:45 iobroker-pi systemd[1]: pivccu-rpi-modules.service: Failed with>
                                  Aug 13 16:08:45 iobroker-pi systemd[1]: Failed to start piVCCU RPi Kernel loade>
                                  An wen kann ich mich mit pivCCU wenden?
                                  Hilft es, ein pivCCU Backup einzuspielen?
                                    W Offline
                                    W Offline
                                    wibear
                                    Job for pivccu-dkms.service failed because the control process exited with error code.
                                    See "systemctl status pivccu-dkms.service" and "journalctl -xe" for details.
                                    • W wibear
                                              CPU: 15ms
                                      @wibear
                                      Zieh dein Mäusekino breiter. Die Meldungen sind abgeschnitten.
                                      Vermutlich nicht, sind das doch Kernel-Module.
                                      Vielleicht sind die noch nicht gegen den aktuellen Kernel gebaut worden?
                                        @wibear
                                        W Offline
                                        W Offline
                                        wibear
                                                CPU: 15ms
                                        lines 1-12/12 (END)...skipping...
                                             Loaded: loaded (/lib/systemd/system/pivccu-rpi-modules.service; enabled; vendor preset: enabled)
                                             Active: failed (Result: exit-code) since Tue 2024-08-13 16:08:45 CEST; 36min ago
                                            Process: 727 ExecStart=/var/lib/piVCCU/rpi-modules/ensure_headers.sh (code=exited, status=1/FAILURE)
                                                CPU: 15ms
                                        Aug 13 16:08:45 iobroker-pi ensure_headers.sh[727]: Could not determine kernel source.
                                        Aug 13 16:08:45 iobroker-pi systemd[1]: pivccu-rpi-modules.service: Main process exited, code=exited, status=1/FAILURE
                                        Aug 13 16:08:45 iobroker-pi systemd[1]: pivccu-rpi-modules.service: Failed with result 'exit-code'.
                                        Aug 13 16:08:45 iobroker-pi systemd[1]: Failed to start piVCCU RPi Kernel loader.
                                          @wibear
                                          W Offline
                                          W Offline
                                          wibear
                                          Vielleicht sind die noch nicht geggen den aktuellen Kernel gebaut worden?
                                          Kann ich da ein downgrade machen?
