  4. pivCCU nach Update node.js nicht erreichbar
63 Beiträge 7 Kommentatoren 7.5k Aufrufe 4 Beobachtet
  • W wibear
    Passt es so?
                            v.2024-05-22
       Static hostname: iobroker-pi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.6.44-v7l+
          Architecture: arm
    Kernel:                 armv7l
    Userland:               32 bit
    User-ID:                1000
    Display-Server:         false
    Boot Target:            multi-user.target
    Pending OS-Updates:     0
    Pending iob updates:    1
    Nodejs-Installation:
    /usr/bin/nodejs         v20.16.0
    /usr/bin/node           v20.16.0
    /usr/bin/npm            10.8.1
    /usr/bin/npx            10.8.1
    /usr/bin/corepack       0.28.2
    Recommended versions are nodejs  and npm
    MEMORY:
    Mem:            3.9G        1.0G        2.2G        1.0M        704M        2.8G
    Swap:            99M          0B         99M
    Total:          4.0G        1.0G        2.3G
    Active iob-Instances:   6
    Active repo(s): stable
    ioBroker Core:          js-controller           5.0.19
                            admin                   7.0.22
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.web.0                    : web                   : iobroker-pi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects:                7430
    States:                 6249
    Size of iob-Database:
    17M     /opt/iobroker/iobroker-data/objects.jsonl
    11M     /opt/iobroker/iobroker-data/states.jsonl
    === Mark text until here for copying ===
    wibear@iobroker-pi:~ $ b nodejs-update 20
    -bash: b: command not found
    @wibear
    Starte die Kiste mal komplett durch und dann gibst du uns die Langfassung.
    W 1 Antwort Letzte Antwort
      @wibear
      W Offline
      W Offline
      wibear
      Nach reboot:
      Skript v.2024-05-22
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : 32 bit
      Systemuptime and Load:
       16:10:24 up 1 min,  1 user,  load average: 2.37, 1.01, 0.38
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Tue 2024-08-13 16:10:25 CEST
                 Universal time: Tue 2024-08-13 14:10:25 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      wibear
      HOME=/home/wibear
      GROUPS=wibear adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** Display-Server-Setup ***
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            3.9G        1.0G        2.3G        1.0M        519M        2.7G
      Swap:            99M          0B         99M
      Total:          4.0G        1.0G        2.4G
      Active iob-Instances:   10
               3885 M total memory
               1016 M used memory
                156 M active memory
               1281 M inactive memory
               2349 M free memory
                 48 M buffer memory
                471 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      top - 16:10:25 up 1 min,  1 user,  load average: 2.37, 1.01, 0.38
      Tasks: 202 total,   1 running, 201 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 16.7 us,  3.0 sy,  0.0 ni, 80.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3885.9 total,   2349.2 free,   1016.4 used,    520.2 buff/cache
      MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2742.4 avail Mem
      *** FAILED SERVICES ***
        UNIT                       LOAD   ACTIVE SUB    DESCRIPTION
      * pivccu-dkms.service        loaded failed failed piVCCU DKMS Modules
      * pivccu-rpi-modules.service loaded failed failed piVCCU RPi Kernel loader
      2 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4       29G   11G   18G  39% /
      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs          tmpfs     778M  1.1M  777M   1% /run
      /dev/mmcblk0p1 vfat      255M   63M  193M  25% /boot
      tmpfs          tmpfs     389M     0  389M   0% /run/user/1000
      [Tue Aug 13 16:08:37 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:16:18:C4 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=tty1 root=PARTUUID=e605bf32-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Tue Aug 13 16:08:38 2024] EXT4-fs (mmcblk0p2): mounted filesystem d3104e7d-5f59-47e0-8621-290882475163 ro with ordered data mode. Quota mode: none.
      [Tue Aug 13 16:08:38 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Tue Aug 13 16:08:39 2024] EXT4-fs (mmcblk0p2): re-mounted d3104e7d-5f59-47e0-8621-290882475163 r/w. Quota mode: none.
      Show mounted filesystems:
      TARGET                       SOURCE         FSTYPE     OPTIONS
      /                            /dev/mmcblk0p2 ext4       rw,noatime
      |-/dev                       devtmpfs       devtmpfs   rw,relatime,size=1726396k,nr_inodes=34271,mode=755
      | |-/dev/shm                 tmpfs          tmpfs      rw,nosuid,nodev
      | |-/dev/pts                 devpts         devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | `-/dev/mqueue              mqueue         mqueue     rw,nosuid,nodev,noexec,relatime
      |-/proc                      proc           proc       rw,relatime
      | `-/proc/sys/fs/binfmt_misc systemd-1      autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
      |-/sys                       sysfs          sysfs      rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security     securityfs     securityfs rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup           cgroup2        cgroup2    rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/pstore           pstore         pstore     rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/bpf              bpf            bpf        rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/tracing      tracefs        tracefs    rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/debug        debugfs        debugfs    rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/config       configfs       configfs   rw,nosuid,nodev,noexec,relatime
      | `-/sys/fs/fuse/connections fusectl        fusectl    rw,nosuid,nodev,noexec,relatime
      |-/run                       tmpfs          tmpfs      rw,nosuid,nodev,size=795828k,nr_inodes=819200,mode=755
      | |-/run/lock                tmpfs          tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
      | |-/run/rpc_pipefs          sunrpc         rpc_pipefs rw,relatime
      | `-/run/user/1000           tmpfs          tmpfs      rw,nosuid,nodev,relatime,size=397912k,nr_inodes=99478,mode=700,uid=1000,gid=1000
      |-/boot                      /dev/mmcblk0p1 vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      `-/var/lib/lxcfs             lxcfs          fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      /var:
      du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
      4.7G    /var/
      3.3G    /var/log
      2.9G    /var/log/journal/6462312882a642219bbda7aff5f4f5b9
      734M    /var/lib
      Archived and active journals take up 2.8G in the file system.
      /opt/iobroker/backups:
      82M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      752M    /opt/iobroker/iobroker-data/
      594M    /opt/iobroker/iobroker-data/files
      441M    /opt/iobroker/iobroker-data/files/javascript.admin
      409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      27M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.ce422ec2.js.map
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      18M     /opt/iobroker/iobroker-data/objects.jsonl
      12M     /opt/iobroker/iobroker-data/states.jsonl
      8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/npm            10.8.1
      /usr/bin/npx            10.8.1
      nodejs:
        Installed: 20.16.0-1nodesource1
        Candidate: 20.16.0-1nodesource1
        Version table:
       *** 20.16.0-1nodesource1 600
              500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
           20.15.1-1nodesource1 600
           20.15.0-1nodesource1 600
           20.14.0-1nodesource1 600
           20.13.1-1nodesource1 600
           20.13.0-1nodesource1 600
           20.12.2-1nodesource1 600
           20.12.1-1nodesource1 600
           20.12.0-1nodesource1 600
           20.11.1-1nodesource1 600
           20.11.0-1nodesource1 600
           20.10.0-1nodesource1 600
           20.9.0-1nodesource1 600
           20.8.1-1nodesource1 600
           20.8.0-1nodesource1 600
           20.7.0-1nodesource1 600
           20.6.1-1nodesource1 600
           20.6.0-1nodesource1 600
           20.5.1-1nodesource1 600
           20.5.0-1nodesource1 600
           20.4.0-1nodesource1 600
           20.3.1-1nodesource1 600
           20.3.0-1nodesource1 600
           20.2.0-1nodesource1 600
           20.1.0-1nodesource1 600
           20.0.0-1nodesource1 600
           12.22.12~dfsg-1~deb11u4 500
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.19
      admin:          7.0.22
      javascript:     8.7.6
      nodejs modules from github:     1
      +-- iobroker.vw-connect@0.5.3 (git+ssh://git@github.com/TA2k/ioBroker.vw-connect.git#b5fbfb41f65b8a1efb646e9efb68f1cbd1627d27)
      Adapter State
      + system.adapter.alexa2.0                 : alexa2                : iobroker-pi                              -  enabled
      + system.adapter.backitup.0               : backitup              : iobroker-pi                              -  enabled
        system.adapter.device-reminder.0        : device-reminder       : iobroker-pi                              -  enabled
        system.adapter.discovery.0              : discovery             : iobroker-pi                              -  enabled
        system.adapter.ems-esp.0                : ems-esp               : iobroker-pi                              -  enabled
        system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker-pi                              -  enabled
        system.adapter.habpanel.0               : habpanel              : iobroker-pi                              -  enabled
      + system.adapter.history.0                : history               : iobroker-pi                              -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : iobroker-pi                              -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-pi                              -  enabled, port: 18701
        system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-pi                              -  enabled, port: 12001
        system.adapter.hm-rpc.2                 : hm-rpc                : iobroker-pi                              -  enabled, port: 12010
      + system.adapter.influxdb.0               : influxdb              : iobroker-pi                              -  enabled, port: 8086
        system.adapter.info.0                   : info                  : iobroker-pi                              -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker-pi                              -  enabled
        system.adapter.mqtt.0                   : mqtt                  : iobroker-pi                              -  enabled, port: 1883, bind: 192.168.178.10
        system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker-pi                              -  enabled
        system.adapter.rpi2.0                   : rpi2                  : iobroker-pi                              -  enabled
        system.adapter.shelly.0                 : shelly                : iobroker-pi                              -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.simple-api.0             : simple-api            : iobroker-pi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.tr-064.0                 : tr-064                : iobroker-pi                              -  enabled
        system.adapter.tuya.0                   : tuya                  : iobroker-pi                              - disabled
        system.adapter.vw-connect.0             : vw-connect            : iobroker-pi                              -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : iobroker-pi                              - disabled
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker-pi                              -  enabled
      + instance is alive
      ioBroker-Repositories
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.0.22   , installed 7.0.22
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 3.0.16   , installed 3.0.16
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "discovery"    : 4.5.0    , installed 4.5.0
      Adapter    "ems-esp"      : 3.5.0    , installed 3.5.0
      Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
      Adapter    "javascript"   : 8.7.6    , installed 8.7.6
      Controller "js-controller": 6.0.9    , installed 5.0.19 [Updatable]
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
      Adapter    "shelly"       : 7.0.0    , installed 7.0.0
      Adapter    "tuya"         : 3.15.0   , installed 3.15.0
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "web"          : 6.2.5    , installed 6.2.5
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
      Objects and States
      Objects:        7430
      States:         6295
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 https://repos.influxdata.com/debian bullseye InRelease
      Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:4 https://packages.grafana.com/oss/deb stable InRelease
      Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
      Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          6228       814/dnsmasq
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6194       785/sshd: /usr/sbin
      tcp        0      0 192.168.178.10:12001    0.0.0.0:*               LISTEN      1001       12319      1854/io.hm-rpc.1
      tcp        0      0 192.168.178.10:12010    0.0.0.0:*               LISTEN      1001       12330      1869/io.hm-rpc.2
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       9377       1407/io.shelly.0
      tcp        0      0 192.168.178.10:1883     0.0.0.0:*               LISTEN      1001       8528       1324/io.mqtt.0
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       7195       905/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       5644       905/iobroker.js-con
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        6272       730/influxd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          6196       785/sshd: /usr/sbin
      tcp6       0      0 :::3000                 :::*                    LISTEN      111        5642       904/grafana
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        6362       730/influxd
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       6952       1464/io.simple-api.
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       7769       1483/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7239       990/io.admin.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        787        337/avahi-daemon: r
      udp        0      0 0.0.0.0:47656           0.0.0.0:*                           108        789        337/avahi-daemon: r
      udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          6227       814/dnsmasq
      udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          6224       814/dnsmasq
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          897        598/dhclient
      udp6       0      0 :::5353                 :::*                                108        788        337/avahi-daemon: r
      udp6       0      0 :::34059                :::*                                108        790        337/avahi-daemon: r
      2024-08-13 16:10:57.691  - info: hm-rpc.1 (1854) starting. Version 1.17.0 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v20.16.0, js-controller: 5.0.19
      2024-08-13 16:10:58.329  - info: hm-rpc.1 (1854) xmlrpc server is trying to listen on 192.168.178.10:12001
      2024-08-13 16:10:58.342  - info: hm-rpc.1 (1854) xmlrpc client is trying to connect to 192.168.178.12:2001/ with ["http://192.168.178.10:12001","iobroker-pi:hm-rpc.1:d56a41b7e622f59142e1fdc67550700c"]
      2024-08-13 16:10:59.322  - info: shelly.0 (1407) [MQTT] Client Close:  (shelly1pmminig3 / shelly1pmminig3-5432044f4ff4 / shelly1pmminig3#5432044f4ff4#1) (false)
      2024-08-13 16:10:59.922  - error: shelly.0 (1407) [MQTT] Unable to get mqttprefix of client with id "shelly1pmminig3-5432044f4ff4"
      2024-08-13 16:11:00.713  - info: hm-rpc.2 (1869) starting. Version 1.17.0 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v20.16.0, js-controller: 5.0.19
      2024-08-13 16:11:00.868  - info: shelly.0 (1407) [MQTT] Client Close: 192.168.178.78 (shellyplusplugs / shellyplusplugs-d4d4dae85f70 / shellyplusplugs#d4d4dae85f70#1) (false)
      2024-08-13 16:11:00.928  - error: shelly.0 (1407) [MQTT] Error in function setMqttPrefixHttp (Gen 1) for  (undefined / undefined / undefined): TypeError: Cannot read properties of undefined (reading 'replace')
      2024-08-13 16:11:00.929  - error: shelly.0 (1407) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-d4d4dae85f70"
      2024-08-13 16:11:01.071  - info: hm-rpc.2 (1869) xmlrpc server is trying to listen on 192.168.178.10:12010
      2024-08-13 16:11:01.077  - info: hm-rpc.2 (1869) xmlrpc client is trying to connect to 192.168.178.12:2010/ with ["http://192.168.178.10:12010","iobroker-pi:hm-rpc.2:03c58894ec83886e7c67f29e17b46f89"]
      2024-08-13 16:11:01.519  - error: hm-rpc.2 (1869) Init not possible, going to stop: connect EHOSTUNREACH 192.168.178.12:2010
      2024-08-13 16:11:01.525  - error: hm-rpc.1 (1854) Init not possible, going to stop: connect EHOSTUNREACH 192.168.178.12:2001
      2024-08-13 16:11:02.712  - info: ems-esp.0 (1426) ems  : energy polling every 10 minutes
      2024-08-13 16:11:02.713  - info: ems-esp.0 (1426) ems  : polling every 15 secs
      2024-08-13 16:11:10.056  - info: fb-checkpresence.0 (1726) createFbDeviceObjects finished successfully
      2024-08-13 16:11:10.058  - info: fb-checkpresence.0 (1726) states successfully subscribed
      2024-08-13 16:11:10.059  - info: fb-checkpresence.0 (1726) loop successfully started
      2024-08-13 16:11:20.232  - info: hm-rpc.0 (1791) binrpc -> 192.168.178.12:8701/ init ["xmlrpc_bin://192.168.178.10:18701",""]
      2024-08-13 16:11:20.238  - error: hm-rpc.0 (1791) Cannot call init: [xmlrpc_bin://192.168.178.10:18701, ""] Socket closed before the connection was established
      2024-08-13 16:11:20.246  - info: hm-rpc.0 (1791) terminating
      2024-08-13 16:11:20.248  - info: hm-rpc.0 (1791) Terminated (NO_ERROR): Without reason
      2024-08-13 16:11:20.853  - info: host.iobroker-pi instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
      2024-08-13 16:11:20.854  - info: host.iobroker-pi Restart adapter system.adapter.hm-rpc.0 because enabled
      2024-08-13 16:11:23.334  - error: hm-rega.0 (1231) CCU 192.168.178.12 unreachable
      Meister MopperM Thomas BraunT 2 Antworten Letzte Antwort
      • W wibear
        Nach reboot:
        Skript v.2024-05-22
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm
        Docker          : false
        Kernel          : armv7l
        Userland        : 32 bit
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        wibear
        HOME=/home/wibear
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M          0B         99M
                 3885 M total memory
                 1016 M used memory
                  156 M active memory
                 2349 M free memory
                   48 M buffer memory
                  471 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        *** FILESYSTEM ***
        /var:
        4.7G    /var/
        3.3G    /var/log
        734M    /var/lib
        USB-Devices by-id:
        /usr/bin/npm            10.8.1
        /usr/bin/npx            10.8.1
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          7.0.22
        javascript:     8.7.6
        Adapter State
        + instance is alive
        Objects and States
        Objects:        7430
        States:         6295
        Pending Updates: 0
        Meister MopperM Online
        Meister Mopper
        @wibear
        Es ist dir doch oben schon einmal gelungen, klopp bitte die lange Fassung in </> (codetags) hier rein.
        Das ist sonst grottenschlecht zu lesen.
        Proxmox und HA ...
        W Thomas BraunT 3 Antworten Letzte Antwort
        • W wibear
          Nach reboot:
          Skript v.2024-05-22
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm
          Docker          : false
          Kernel          : armv7l
          Userland        : 32 bit
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          wibear
          HOME=/home/wibear
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:            99M          0B         99M
                   3885 M total memory
                   1016 M used memory
                    156 M active memory
                   2349 M free memory
                     48 M buffer memory
                    471 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          *** FILESYSTEM ***
          /var:
          4.7G    /var/
          3.3G    /var/log
          734M    /var/lib
          USB-Devices by-id:
          /usr/bin/npm            10.8.1
          /usr/bin/npx            10.8.1
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          7.0.22
          javascript:     8.7.6
          Adapter State
          + instance is alive
          Objects and States
          Objects:        7430
          States:         6295
          Pending Updates: 0
          @wibear sagte in pivCCU nach Update node.js nicht erreichbar:
          Da klemmt es. Hat aber nix mit nodejs oder dem ioBroker zu tun, da werden die pivCCU Module nicht geladen.
          Und wo du einmal dran bist:
          iob stop
          iob update
          iob upgrade self
          iob start
            @wibear
            W Offline
            W Offline
            wibear
            @meister-mopper sagte in pivCCU nach Update node.js nicht erreichbar:
                                    v.2024-05-22
                     Icon name: computer
                  Architecture: arm
            Kernel:                 armv7l
            Userland:               32 bit
            User-ID:                1000
            /usr/bin/npm            10.8.1
            /usr/bin/npx            10.8.1
            Recommended versions are nodejs 20.16.0 and npm 10.8.1
            MEMORY:
            Mem:            3.9G        945M        2.3G        1.0M        604M        2.8G
            Swap:            99M          0B         99M
            Total:          4.0G        945M        2.4G
            Active iob-Instances:   21
                                    admin                   7.0.22
            Objects type: jsonl
            States  type: jsonl
            + system.adapter.web.0                    : web                   : iobroker-pi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            Objects:                7430
            States:                 6297
            9.6M    /opt/iobroker/iobroker-data/objects.jsonl
            13M     /opt/iobroker/iobroker-data/states.jsonl
              @wibear
              Die Ausgabe von iob diag hat die schon dabei. Muss nur kopiert und eingefügt werden.
              Jetzt sind zwei CodeTags drumherum, das ist auch falsch.
                @wibear
                W Offline
                W Offline
                wibear
                Ist es besser?
                Skript v.2024-05-22
                *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm
                Docker          : false
                Kernel          : armv7l
                Userland        : 32 bit
                 16:21:41 up 13 min,  1 user,  load average: 1.00, 1.08, 0.80
                CPU threads: 4
                Current issues:
                               Local time: Tue 2024-08-13 16:21:42 CEST
                           Universal time: Tue 2024-08-13 14:21:42 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                wibear
                HOME=/home/wibear
                iobroker
                HOME=/home/iobroker
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:            3.9G        941M        2.3G        1.0M        626M        2.8G
                Swap:            99M          0B         99M
                Total:          4.0G        941M        2.4G
                         3885 M total memory
                          942 M used memory
                          230 M active memory
                         1233 M inactive memory
                         2317 M free memory
                           76 M buffer memory
                          550 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                top - 16:21:42 up 13 min,  1 user,  load average: 1.00, 1.08, 0.80
                Tasks: 194 total,   1 running, 193 sleeping,   0 stopped,   0 zombie
                %Cpu(s): 30.0 us, 11.4 sy,  0.0 ni, 52.9 id,  4.3 wa,  0.0 hi,  1.4 si,  0.0 st
                MiB Mem :   3885.9 total,   2316.9 free,    942.0 used,    627.0 buff/cache
                MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2817.4 avail Mem
                *** FILESYSTEM ***
                /var:
                4.7G    /var/
                3.3G    /var/log
                738M    /var/lib
                746M    /opt/iobroker/iobroker-data/
                USB-Devices by-id:
                /usr/bin/npm            10.8.1
                /usr/bin/npx            10.8.1
                nodejs:
                  Version table:
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          7.0.22
                javascript:     8.7.6
                Adapter State
                + system.adapter.device-reminder.0        : device-reminder       : iobroker-pi                              -  enabled
                + system.adapter.discovery.0              : discovery             : iobroker-pi                              -  enabled
                + system.adapter.ems-esp.0                : ems-esp               : iobroker-pi                              -  enabled
                + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker-pi                              -  enabled
                + system.adapter.mqtt.0                   : mqtt                  : iobroker-pi                              -  enabled, port: 1883, bind: 192.168.178.10
                + system.adapter.rpi2.0                   : rpi2                  : iobroker-pi                              -  enabled
                + system.adapter.shelly.0                 : shelly                : iobroker-pi                              -  enabled, port: 1882, bind: 0.0.0.0
                + system.adapter.simple-api.0             : simple-api            : iobroker-pi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                + system.adapter.tr-064.0                 : tr-064                : iobroker-pi                              -  enabled
                + system.adapter.vw-connect.0             : vw-connect            : iobroker-pi                              -  enabled
                + instance is alive
                Objects and States
                Objects:        7430
                States:         6279
                Hit:1 https://repos.influxdata.com/debian bullseye InRelease
                Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                Hit:6 https://packages.grafana.com/oss/deb stable InRelease
                Pending Updates: 0
                tcp        0      0 192.168.178.10:12001    0.0.0.0:*               LISTEN      1001       39110      5590/io.hm-rpc.1
                tcp        0      0 192.168.178.10:12010    0.0.0.0:*               LISTEN      1001       36706      5591/io.hm-rpc.2
                2024-08-13 16:21:48.384  - info: hm-rpc.2 (4770) Terminated (NO_ERROR): Without reason
                2024-08-13 16:21:49.099  - info: host.iobroker-pi instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
                2024-08-13 16:21:49.099  - info: host.iobroker-pi Restart adapter system.adapter.hm-rpc.1 because enabled
                2024-08-13 16:21:49.099  - info: host.iobroker-pi instance system.adapter.hm-rpc.2 terminated with code 0 (NO_ERROR)
                2024-08-13 16:21:49.100  - info: host.iobroker-pi Restart adapter system.adapter.hm-rpc.2 because enabled
                2024-08-13 16:21:49.884  - info: hm-rpc.0 (5004) starting. Version 1.17.0 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v20.16.0, js-controller: 5.0.19
                2024-08-13 16:21:50.185  - info: hm-rpc.0 (5004) binrpc server is trying to listen on 192.168.178.10:18701
                2024-08-13 16:21:50.187  - info: hm-rpc.0 (5004) binrpc client is trying to connect to 192.168.178.12:8701/ with ["xmlrpc_bin://192.168.178.10:18701","iobroker-pi:hm-rpc.0:586ced57dee52ef270bfb61be9f07a73"]
                2024-08-13 16:21:50.457  - error: hm-rpc.0 (5004) Init not possible, going to stop: connect EHOSTUNREACH 192.168.178.12:8701
                2024-08-13 16:21:50.461  - error: hm-rega.0 (1231) CCU 192.168.178.12 unreachable
                2024-08-13 16:22:19.230  - info: host.iobroker-pi instance system.adapter.hm-rpc.1 started with pid 5590
                2024-08-13 16:22:19.243  - info: host.iobroker-pi instance system.adapter.hm-rpc.2 started with pid 5591
                2024-08-13 16:22:20.462  - info: hm-rpc.0 (5004) binrpc -> 192.168.178.12:8701/ init ["xmlrpc_bin://192.168.178.10:18701",""]
                2024-08-13 16:22:20.481  - error: hm-rpc.0 (5004) Cannot call init: [xmlrpc_bin://192.168.178.10:18701, ""] Socket closed before the connection was established
                2024-08-13 16:22:20.542  - info: hm-rpc.0 (5004) terminating
                2024-08-13 16:22:20.544  - info: hm-rpc.0 (5004) Terminated (NO_ERROR): Without reason
                2024-08-13 16:22:21.115  - info: host.iobroker-pi instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
                2024-08-13 16:22:23.573  - error: hm-rega.0 (1231) CCU 192.168.178.12 unreachable
                2024-08-13 16:22:21.116  - info: host.iobroker-pi Restart adapter system.adapter.hm-rpc.0 because enabled
                2024-08-13 16:22:25.483  - info: hm-rpc.1 (5590) starting. Version 1.17.0 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v20.16.0, js-controller: 5.0.19
                2024-08-13 16:22:25.516  - info: hm-rpc.2 (5591) starting. Version 1.17.0 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v20.16.0, js-controller: 5.0.19
                2024-08-13 16:22:25.834  - info: hm-rpc.1 (5590) xmlrpc server is trying to listen on 192.168.178.10:12001
                2024-08-13 16:22:25.835  - info: hm-rpc.1 (5590) xmlrpc client is trying to connect to 192.168.178.12:2001/ with ["http://192.168.178.10:12001","iobroker-pi:hm-rpc.1:b7e0bbb00b214da627cd2ac33e1e6a94"]
                2024-08-13 16:22:25.863  - info: hm-rpc.2 (5591) xmlrpc server is trying to listen on 192.168.178.10:12010
                2024-08-13 16:22:25.865  - info: hm-rpc.2 (5591) xmlrpc client is trying to connect to 192.168.178.12:2010/ with ["http://192.168.178.10:12010","iobroker-pi:hm-rpc.2:53dc961ed27d3c18a140cba29ed780cc"]
                • W wibear
                  Ist es besser?
                  Skript v.2024-05-22
                  *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm
                  Docker          : false
                  Kernel          : armv7l
                  Userland        : 32 bit
                  CPU threads: 4
                  Current issues:
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  wibear
                  HOME=/home/wibear
                  iobroker
                  HOME=/home/iobroker
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Swap:            99M          0B         99M
                           3885 M total memory
                            942 M used memory
                            230 M active memory
                           2317 M free memory
                             76 M buffer memory
                            550 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  *** FILESYSTEM ***
                  /var:
                  4.7G    /var/
                  3.3G    /var/log
                  738M    /var/lib
                  USB-Devices by-id:
                  /usr/bin/npm            10.8.1
                  /usr/bin/npx            10.8.1
                  nodejs:
                    Version table:
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          7.0.22
                  javascript:     8.7.6
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        7430
                  States:         6279
                  Pending Updates: 0
                  DJMarc75D Offline
                  DJMarc75D Offline
                  DJMarc75
                  Ist es besser?
                  Wie Du vielleicht selbst siehst - nein ;)
                  Lehrling seit 1975 !!!
                  • DJMarc75D DJMarc75
                    Ist es besser?
                    @djmarc75 sagte in pivCCU nach Update node.js nicht erreichbar:
                    Ist es besser?
                    jetzt, ja!
                    im ersten hab ich nicht alle versteckten code-tags finden und fixen können
                    EDIT: Jetzt aber!
                      iob stop
                      iob update
                      iob upgrade self
                      iob start
                      W Offline
                      W Offline
                      wibear
                      @thomas-braun sagte in pivCCU nach Update node.js nicht erreichbar:
                      ausgeführt
                      • W wibear
                        ausgeführt
                        @wibear
                        Dann ist ioBroker-seitig jetzt alles i.O.
                        • W wibear
                          iob diag
                          Docker : false
                          Kernel : armv7l
                          Userland : 32 bit
                          15:51:21 up 35 min, 1 user, load average: 1.13, 0.75, 2.22
                          CPU threads: 4
                          Copy text starting here:
                                                  v.2024-05-22
                          Current issues:
                                         Local time: Tue 2024-08-13 15:51:21 CEST
                                     Universal time: Tue 2024-08-13 13:51:21 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          wibear
                          HOME=/home/wibear
                          iobroker
                          HOME=/home/iobroker
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:            3.9G        1.1G        2.2G        1.0M        568M        2.6G
                          Swap:            99M          0B         99M
                          Total:          4.0G        1.1G        2.3G
                          Active iob-Instances:   20
                                   3885 M total memory
                                   1134 M used memory
                                    179 M active memory
                                   1411 M inactive memory
                                   2182 M free memory
                                     64 M buffer memory
                                    504 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          top - 15:51:22 up 35 min,  1 user,  load average: 1.13, 0.75, 2.22
                          Tasks: 219 total,   3 running, 216 sleeping,   0 stopped,   0 zombie
                          %Cpu(s): 25.8 us,  9.7 sy,  0.0 ni, 54.8 id,  6.5 wa,  0.0 hi,  3.2 si,  0.0 st
                          MiB Mem :   3885.9 total,   2184.1 free,   1132.9 used,    568.8 buff/cache
                          MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2635.5 avail Mem
                          *** FILESYSTEM ***
                          [Tue Aug 13 15:15:44 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:16:18:C4 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=tty1 root=PARTUUID=e605bf32-02 rootfstype=ext4 fsck.repair=yes rootwait
                          [Tue Aug 13 15:15:45 2024] EXT4-fs (mmcblk0p2): mounted filesystem d3104e7d-5f59-47e0-8621-290882475163 ro with ordered data mode. Quota mode: none.
                          [Tue Aug 13 15:15:45 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                          [Tue Aug 13 15:15:46 2024] EXT4-fs (mmcblk0p2): re-mounted d3104e7d-5f59-47e0-8621-290882475163 r/w. Quot   Static hostname: iobroker-pi
                                   Icon name: computer
                                Architecture: arm
                          Kernel:                 armv7l
                          Userland:               32 bit
                          User-ID:                1000
                          /usr/local/bin/node             v18.18.0
                          /usr/local/bin/npm              10.8.2
                          /usr/local/bin/npx              10.8.2
                          /usr/local/bin/corepack         0.19.0
                          *** nodejs is NOT correctly installed ***
                          Wrong installation path detected. This needs to be fixed.
                          Please execute
                          iobroker nodejs-update
                          to fix these errors.
                          MEMORY:
                          Mem:            3.9G        1.2G        2.0G        1.0M        649M        2.5G
                          Swap:            99M          0B         99M
                          Total:          4.0G        1.2G        2.1G
                                                  admin                   7.0.22
                          Objects type: jsonl
                          States  type: jsonl
                          Objects:                7401
                          States:                 6256
                          15M     /opt/iobroker/iobroker-data/objects.jsonl
                          9.0M    /opt/iobroker/iobroker-data/states.jsonl
                          wibear@iobroker-pi:~ $ ======== Start marking the full check here =========
                          -bash: ========: command not found
                          > Skript v.2024-05-22
                          > *** BASE SYSTEM ***
                          >          Icon name: computer
                          >       Architecture: arm
                          > Docker          : false
                          > Kernel          : armv7l
                          > Userland        : 32 bit
                          > CPU threads: 4
                          > Current issues:
                          > No throttling issues detected.
                          >                  RTC time: n/a
                          />                 Time zone: Europe/Berlin (CEST, +0200)
                          > System clock synchronized: yes
                          >               NTP service: active
                          >           RTC in local TZ: no
                          > wibear
                          > HOME=/home/wibear
                          > User that is running 'js-controller':
                          > iobroker
                          > HOME=/home/iobroker
                          > GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                          > Desktop:
                          > Terminal:       tty
                          > *** MEMORY ***
                          >                total        used        free      shared  buff/cache   available
                          > Swap:            99M          0B         99M
                          >          3885 M total memory
                          >          1134 M used memory
                          >           179 M active memory
                          >          2182 M free memory
                          >            64 M buffer memory
                          >           504 M swap cache
                          >            99 M total swap
                          >             0 M used swap
                          >            99 M free swap
                          > *** top - Table Of Processes  ***
                          > LOAD   = Reflects whether the unit definition was properly loaded.
                          > ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                          > SUB    = The low-level unit activation state, values depend on unit type.
                          > *** FILESYSTEM ***
                          > Filesystem     Type      Size  Used Avail Use% Mounted on
                          > Messages concerning ext4 filesystem in dmesg:
                          > [Tue Aug 13 15:15:46 2024] EXT4-fs (mmcblk0p2): re-mounted d3104e7d-5f59-47e0-8621-290882475163 r/w. Quota mode: none.
                          -bash: Skript: command not found
                          -bash: node_modules: command not found
                          -bash: Static: command not found
                          -bash: Icon: command not found
                          -bash: command substitution: line 7: syntax error near unexpected token `('
                          -bash: command substitution: line 7: `  Operating System: Raspbian GNU/Linux 11 (bullseye)'
                          -bash: -/dev/mqueue: No such file or directory
                          wibear@iobroker-pi:~ $ |-/proc                      proc           proc       rw,relatime
                          -bash: syntax error near unexpected token `|'
                          wibear@iobroker-pi:~ $ | `-/proc/sys/fs/binfmt_misc systemd-1      autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                          wibear@iobroker-pi:~ $ |-/sys                       sysfs          sysfs      rw,nosuid,nodev,noexec,relatime
                          wibear@iobroker-pi:~ $ | |-/sys/kernel/security     securityfs     securityfs rw,nosuid,nodev,noexec,relatime
                          wibear@iobroker-pi:~ $ | |-/sys/fs/cgroup           cgroup2        cgroup2    rw,nosuid,nodev,noexec,relatime
                          wibear@iobroker-pi:~ $ | |-/sys/fs/pstore           pstore         pstore     rw,nosuid,nodev,noexec,relatime
                          wibear@iobroker-pi:~ $ | |-/sys/fs/bpf              bpf            bpf        rw,nosuid,nodev,noexec,relatime,mode=700
                          wibear@iobroker-pi:~ $ | |-/sys/kernel/tracing      tracefs        tracefs    rw,nosuid,nodev,noexec,relatime
                          wibear@iobroker-pi:~ $ | |-/sys/kernel/debug        debugfs        debugfs    rw,nosuid,nodev,noexec,relatime
                          wibear@iobroker-pi:~ $ | |-/sys/fs/fuse/connections fusectl        fusectl    rw,nosuid,nodev,noexec,relatime
                          wibear@iobroker-pi:~ $ | `-/sys/kernel/config       configfs       configfs   rw,nosuid,nodev,noexec,relatime
                          wibear@iobroker-pi:~ $ |-/run                       tmpfs          tmpfs      rw,nosuid,nodev,size=795828k,nr_inodes=819200,mode=755
                          wibear@iobroker-pi:~ $ | |-/run/lock                tmpfs          tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
                          wibear@iobroker-pi:~ $ | |-/run/rpc_pipefs          sunrpc         rpc_pipefs rw,relatime
                          wibear@iobroker-pi:~ $ | `-/run/user/1000           tmpfs          tmpfs      rw,nosuid,nodev,relatime,size=397912k,nr_inodes=99478,mode=700,uid=1000,gid=1000
                          wibear@iobroker-pi:~ $ |-/boot                      /dev/mmcblk0p1 vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                          wibear@iobroker-pi:~ $ `-/var/lib/lxcfs             lxcfs          fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                          > Files in neuralgic directories:
                          > /var:
                          > 4.6G    /var/
                          > 3.3G    /var/log
                          > 729M    /var/lib
                          > 747M    /opt/iobroker/iobroker-data/
                          > The five largest files in iobroker-data are:
                          > 8.7M    /opt/iobroker/iobroker-data/states.jsonl
                          > USB-Devices by-id:
                          > USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id':
                          0        : device-reminder > /usr/local/bin/npx              10.8.2
                          > nodejs:
                          >   Version table:
                          > Temp directories causing npm8 problem: 0
                          > Errors in npm tree:
                          > ioBroker Status
                          > iobroker is running on this host.
                          > Objects type: jsonl
                          > States  type: jsonl
                          > admin:          7.0.22
                          > javascript:     8.7.6
                          > Adapter State
                          > + instance is alive
                          > Enabled adapters with bindings
                          > stable        : http://download.iobroker.net/sources-dist.json
                          > beta          : http://download.iobroker.net/sources-dist-latest.json
                          > Adapter    "history"      : 3.0.1    , installed 3.0.1
                          > Adapter    "influxdb"     : 4.0.2    , installed 4.0.2
                          > Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                          > Objects and States
                          > Please stand by - This may take a while
                          > Objects:        7401
                          > States:         6256
                          > *** OS-Repositories and Updates ***
                          > Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                          > Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                          > Hit:5 https://packages.grafana.com/oss/deb stable InRelease
                          > Hit:6 https://apt.pivccu.de/piVCCU stable InRelease
                          > Pending Updates: 0
                          > Active Internet connections (only servers)
                          > Proto Recv-Q Send-Q Local Address           Foreign Address         State       User       Inode      PID/Program name
                          > tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        6286       745/influxd
                          > tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       8815       1209/io.shelly.0
                          > tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6351       884/iobroker.js-con
                          > tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       5758       884/iobroker.js-con
                          > tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4770       787/sshd: /usr/sbin
                          > tcp        0      0 192.168.178.10:1883     0.0.0.0:*               LISTEN      1001       6997       1170/io.mqtt.0
                          > tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          4793       814/dnsmasq
                          > tcp6       0      0 :::8086                 :::*                    LISTEN      999        4863       745/influxd
                          > tcp6       0      0 :::8087                 :::*                    LISTEN      1001       9583       1272/io.simple-api.
                          > tcp6       0      0 :::8082                 :::*                    LISTEN      1001       8850       1314/io.web.0
                          > tcp6       0      0 :::8081                 :::*                    LISTEN      1001       5806       951/io.admin.0
                          > tcp6       0      0 :::3000                 :::*                    LISTEN      111        5756       883/grafana
                          48
                          > tcp6       0      0 :::22                   :::*                    LISTEN      0          4772       787/sshd: /usr/sbin
                          > udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        5445       372/avahi-daemon: r
                          > udp        0      0 0.0.0.0:55700           0.0.0.0:*                           108        5447       372/avahi-daemon: r
                          > udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          4792       814/dnsmasq
                          > udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          4789       814/dnsmasq
                          > udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          4602       596/dhclient
                          > udp6       0      0 :::5353                 :::*                                108        5446       372/avahi-daemon: r
                          > udp6       0      0 :::48974                :::*                                108        5448       372/avahi-daemon: r
                          > *** Log File - Last 25 Lines ***
                          > 2024-08-13 15:51:30.782  - info: hm-rpc.2 (6575) xmlrpc client is trying to connect to 192.168.178.12:2010/ with ["http://192.168.178.10:12010","iobroker-pi:hm-rpc.2:325a5da9b9959b38a1d02500f5dff733"]
                          > 2024-08-13 15:51:30.849  - info: hm-rpc.1 (6586) xmlrpc server is trying to listen on 192.168.178.10:12001
                          > 2024-08-13 15:51:30.850  - info: hm-rpc.1 (6586) xmlrpc client is trying to connect to 192.168.178.12:2001/ with ["http://192.168.178.10:12001","iobroker-pi:hm-rpc.1:77e7296879feb3366411ef62aab861bd"]
                          > 2024-08-13 15:51:33.949  - error: hm-rpc.2 (6575) Init not possible, going to stop: connect EHOSTUNREACH 192.168.178.12:2010
                          > 2024-08-13 15:51:33.957  - error: hm-rpc.1 (6586) Init not possible, going to stop: connect EHOSTUNREACH 192.168.178.12:2001
                          > 2024-08-13 15:51:49.143  - info: hm-rpc.0 (6422) binrpc -> 192.168.178.12:8701/ init ["xmlrpc_bin://192.168.178.10:18701",""]
                          > 2024-08-13 15:51:49.160  - error: hm-rpc.0 (6422) Cannot call init: [xmlrpc_bin://192.168.178.10:18701, ""] Socket closed before the connection was established
                          > 2024-08-13 15:51:49.232  - info: hm-rpc.0 (6422) terminating
                          > 2024-08-13 15:51:49.234  - info: hm-rpc.0 (6422) Terminated (NO_ERROR): Without reason
                          > 2024-08-13 15:51:49.835  - info: host.iobroker-pi instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
                          > 2024-08-13 15:51:49.836  - info: host.iobroker-pi Restart adapter system.adapter.hm-rpc.0 because enabled
                          > 2024-08-13 15:51:52.253  - error: hm-rega.0 (2659) CCU 192.168.178.12 unreachable
                          > 2024-08-13 15:52:03.933  - error: hm-rpc.2 (6575) Init not possible, going to stop: connect EHOSTUNREACH 192.168.178.12:2010
                          > 2024-08-13 15:52:03.935  - error: hm-rpc.1 (6586) Init not possible, going to stop: connect EHOSTUNREACH 192.168.178.12:2001
                          > 2024-08-13 15:52:03.960  - info: hm-rpc.1 (6586) xmlrpc -> 192.168.178.12:2001/ init ["http://192.168.178.10:12001",""]
                          > 2024-08-13 15:52:03.964  - info: hm-rpc.2 (6575) xmlrpc -> 192.168.178.12:2010/ init ["http://192.168.178.10:12010",""]
                          > 2024-08-13 15:52:04.969  - info: hm-rpc.1 (6586) terminating
                          > 2024-08-13 15:52:04.971  - info: hm-rpc.1 (6586) Terminated (NO_ERROR): Without reason
                          > 2024-08-13 15:52:04.978  - info: hm-rpc.2 (6575) terminating
                          > 2024-08-13 15:52:04.980  - info: hm-rpc.2 (6575) Terminated (NO_ERROR): Without reason
                          > 2024-08-13 15:52:05.572  - info: host.iobroker-pi instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
                          > 2024-08-13 15:52:05.573  - info: host.iobroker-pi Restart adapter system.adapter.hm-rpc.1 because enabled
                          > 2024-08-13 15:52:05.618  - info: host.iobroker-pi instance system.adapter.hm-rpc.2 terminated with code 0 (NO_ERROR)
                          > 2024-08-13 15:52:05.619  - info: host.iobroker-pi Restart adapter system.adapter.hm-rpc.2 because enabled
                          > 2024-08-13 15:52:19.916  - info: host.iobroker-pi instance system.adapter.hm-rpc.0 started with pid 7348
                          -bash: -/var/lib/lxcfs: No such file or directory
                          -bash: Files: command not found
                          -bash: /var:: No such file or directory
                          -bash: du:: command not found
                          -bash: 4.6G: command not found
                          -bash: 3.3G: command not found
                          -bash: 2.9G: command not found
                          -bash: 729M: command not found
                          -bash: Archived: command not found
                          -bash: /opt/iobroker/backups:: No such file or directory
                          -bash: 82M: command not found
                          -bash: /opt/iobroker/iobroker-data:: No such file or directory
                          -bash: 747M: command not found
                          -bash: 594M: command not found
                          -bash: 441M: command not found
                          -bash: 409M: command not found
                          -bash: 408M: command not found
                          -bash: The: command not found
                          -bash: 27M: command not found
                          -bash: 24M: command not found
                          -bash: 15M: command not found
                          -bash: 8.7M: command not found
                          -bash: USB-Devices: command not found
                          -bash: USB-Sticks: command not found
                          -bash: No: command not found
                          node:internal/modules/cjs/loader:1148
                            throw err;
                          Error: Cannot find module '/home/wibear/v20.16.0'
                              at Module._resolveFilename (node:internal/modules/cjs/loader:1145:15)
                              at Module._load (node:internal/modules/cjs/loader:986:27)
                              at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
                              at node:internal/main/run_main_module:28:49 {
                            code: 'MODULE_NOT_FOUND',
                            requireStack: []
                          Node.js v20.16.0
                          node:internal/modules/cjs/loader:1080
                            throw err;
                          Error: Cannot find module '/home/wibear/v18.18.0'
                              at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
                              at Module._load (node:internal/modules/cjs/loader:922:27)
                              at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:86:12)
                              at node:internal/main/run_main_module:23:47 {
                            requireStack: []
                          Node.js v18.18.0
                          npm error code ENOVERSIONS
                          npm error No versions available for 10.8.2
                          npm error A complete log of this run can be found in: /home/wibear/.npm/_logs/2024-08-13T13_53_15_245Z-debug-0.log
                          -bash: nodejs:: command not found
                          -bash: Installed:: command not found
                          -bash: Candidate:: command not found
                          -bash: Version: command not found
                          -bash: 500: command not found
                          -bash: 100: command not found
                          -bash: 20.15.1-1nodesource1: command not found
                          -bash: 20.15.0-1nodesource1: command not found
                          -bash: 20.14.0-1nodesource1: command not found
                          -bash: 20.13.1-1nodesource1: command not found
                          -bash: 20.13.0-1nodesource1: command not found
                          -bash: 20.12.2-1nodesource1: command not found
                          -bash: 20.12.1-1nodesource1: command not found
                          -bash: 20.12.0-1nodesource1: command not found
                          -bash: 20.11.1-1nodesource1: command not found
                          -bash: 20.11.0-1nodesource1: command not found
                          -bash: 20.10.0-1nodesource1: command not found
                          -bash: 20.9.0-1nodesource1: command not found
                          -bash: 20.8.1-1nodesource1: command not found
                          -bash: 20.8.0-1nodesource1: command not found
                          -bash: 20.7.0-1nodesource1: command not found
                          -bash: 20.6.1-1nodesource1: command not found
                          -bash: 20.6.0-1nodesource1: command not found
                          -bash: 20.5.1-1nodesource1: command not found
                          -bash: 20.5.0-1nodesource1: command not found
                          -bash: 20.4.0-1nodesource1: command not found
                          -bash: 20.3.1-1nodesource1: command not found
                          -bash: 20.3.0-1nodesource1: command not found
                          -bash: 20.2.0-1nodesource1: command not found
                          -bash: 20.1.0-1nodesource1: command not found
                          -bash: 20.0.0-1nodesource1: command not found
                          -bash: 12.22.12~dfsg-1~deb11u4: command not found
                          -bash: Temp: command not found
                          -bash: Errors: command not found
                          -bash: ioBroker: command not found
                          iobroker [command]
                          Commands:
                            iobroker setup                                               Setup ioBroker
                            iobroker start [all|<adapter>.<instance>|<adapter>]          Starts the js-controller or a specified adapter instance or all instances of an adapter
                            iobroker stop [<adapter>.<instance>|<adapter>]               stops the js-controller or a specified adapter instance or all instances of an adapter
                            iobroker restart [<adapter>.<instance>|<adapter>]            Restarts js-controller or a specified adapter instance or all instances of an adapter  [aliases: r]
                            iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
                            iobroker info                                                Shows the host info
                            iobroker logs [<adapter>]                                    Monitor log
                            iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
                            iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
                            iobroker rebuild [<module>]                                  Rebuild all native modules or path
                            iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
                            iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
                            iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
                            iobroker update [<repositoryUrl>]                            Update repository and list adapters
                            iobroker upgrade                                             Upgrade management
                            iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
                            iobroker object                                              Object management  [aliases: o]
                            iobroker state                                               State management  [aliases: s]
                            iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
                            iobroker list <type> [<filter>]                              List all entries, like objects
                            iobroker chmod <mode> <file>                                 Change file rights
                            iobroker chown <user> <group> <file>                         Change file ownership
                            iobroker touch <file>                                        Touch file
                            iobroker rm <file>                                           Remove file
                            iobroker file                                                File management
                            iobroker user                                                User commands
                            iobroker group                                               group management
                            iobroker host <hostname>                                     Set host to given hostname
                            iobroker set <adapter>.<instance>                            Change settings of adapter config
                            iobroker license <license.file or license.text>              Update license by given file
                            iobroker cert                                                Certificate management
                            iobroker clean <yes>                                         Clears all objects and states
                            iobroker backup                                              Create backup
                            iobroker restore <backup name or path>                       Restore a specified backup
                            iobroker validate <backup name or path>                      Validate a specified backup
                            iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
                            iobroker repo [<name>]                                       Show repo information
                            iobroker uuid                                                Show uuid of the installation  [aliases: id]
                            iobroker unsetup                                             Reset license, installation secret and language
                            iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
                            iobroker nodejs-update [<major-version>]                     Upgrade the Node.JS installation to the current LTS
                            iobroker multihost                                           Multihost management
                            iobroker compact                                             compact group management
                            iobroker plugin                                              Plugin management
                            iobroker vendor <passphrase> [<vendor.json>]                 Update the vendor information using given passphrase
                            iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
                          Options:
                            --help  Show help  [boolean]
                          -bash: Objects: command not found
                          -bash: States: command not found
                          -bash: Core: command not found
                          -bash: js-controller:: command not found
                          -bash: admin:: command not found
                          -bash: javascript:: command not found
                            throw err;
                          Error: Cannot find module '/home/wibear/modules'
                            requireStack: []
                          Node.js v20.16.0
                          -bash: command substitution: line 129: syntax error near unexpected token `('
                          -bash: command substitution: line 129: `+-- iobroker.vw-connect@0.5.3 (git+ssh://git@github.com/TA2k/ioBroker.vw-connect.git#b5fbfb41f65b8a1efb646e9efb68f1cbd1627d27)'
                          -bash: Unknown: command not found
                          wibear@iobroker-pi:~ $ ============ Mark until here for C&P =============
                          [1] 7854
                          -bash: ============: command not found
                          -bash: P: command not found
                          [1]+  Exit 127                ============ Mark until here for C
                          @wibear sagte:
                          FAILED SERVICES
                          Das hat nichts mit Node.js oder ioBroker zu tun.
                          • W Offline
                            W Offline
                            wibear
                            @paul53 Was könnte der Grund für FailedServices sein?
                            • W wibear
                              @wibear
                              systemctl status pivccu-dkms.service
                              systemctl status pivccu-rpi-modules.service
                              könnte dir das vielleicht verraten. Ansonsten wäre das ein Fall für die Kollegen eine Tür weiter bei pivCCU.
                              HomoranH W 2 Antworten Letzte Antwort
                                @wibear
                                @wibear
                                oder mal mit sudo pivccu-info nachsehen
                                  @wibear
                                  W Offline
                                  W Offline
                                  wibear
                                  pivCCU zeigt State: STOPPED
                                  Kann ich das starten?
                                  • W wibear
                                    Das zeigt aber mit Sicherheit noch mehr...
                                    sudo systemctl start pivccu-dkms.service
                                    sudo systemctl start pivccu-rpi-modules.service
                                      @wibear
                                      W Offline
                                      W Offline
                                      wibear
                                      ● pivccu-rpi-modules.service - piVCCU RPi Kernel loader
                                           Loaded: loaded (/lib/systemd/system/pivccu-rpi-modules.service; enabled; v>
                                           Active: failed (Result: exit-code) since Tue 2024-08-13 16:08:45 CEST; 36m>
                                          Process: 727 ExecStart=/var/lib/piVCCU/rpi-modules/ensure_headers.sh (code=>
                                         Main PID: 727 (code=exited, status=1/FAILURE)
                                              CPU: 15ms
                                      Aug 13 16:08:45 iobroker-pi systemd[1]: Starting piVCCU RPi Kernel loader...
                                      Aug 13 16:08:45 iobroker-pi ensure_headers.sh[727]: Could not determine kernel >
                                      Aug 13 16:08:45 iobroker-pi systemd[1]: pivccu-rpi-modules.service: Main proces>
                                      Aug 13 16:08:45 iobroker-pi systemd[1]: pivccu-rpi-modules.service: Failed with>
                                      Aug 13 16:08:45 iobroker-pi systemd[1]: Failed to start piVCCU RPi Kernel loade>
                                      An wen kann ich mich mit pivCCU wenden?
                                      Hilft es, ein pivCCU Backup einzuspielen?
                                        W Offline
                                        W Offline
                                        wibear
                                        Job for pivccu-dkms.service failed because the control process exited with error code.
                                        See "systemctl status pivccu-dkms.service" and "journalctl -xe" for details.
                                        • W wibear
                                                  CPU: 15ms
                                          @wibear
                                          Zieh dein Mäusekino breiter. Die Meldungen sind abgeschnitten.
                                          Vermutlich nicht, sind das doch Kernel-Module.
                                          Vielleicht sind die noch nicht gegen den aktuellen Kernel gebaut worden?
