  3. Einsteigerfragen
  4. ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme
    5.3k
267 Beiträge 8 Kommentatoren 59.1k Aufrufe 8 Beobachtet
  • G Gismoh
    idash@ioBrokerVM:~$ iob stop
    idash@ioBrokerVM:~$ iob fix
    library: loaded
    Library version=2023-10-13
        Welcome to the ioBroker installation fixer!
        Script version: 2023-10-13
        You might need to enter your password a couple of times.
        Installing prerequisites (1/5)
    [sudo] Passwort für idash:
    OK:1 http://security.debian.org/debian-security bookworm-security InRelease
    OK:2 http://deb.debian.org/debian bookworm InRelease
    OK:3 http://deb.debian.org/debian bookworm-updates InRelease
    OK:4 https://deb.nodesource.com/node_18.x nodistro InRelease
        Checking ioBroker user and directory permissions (2/5)
    Created /etc/sudoers.d/iobroker
        Check and cleanup npm temporary directories (3/5)
    Done.
        Database maintenance (4/5)
    Checking for uncompressed JSONL databases... This might take a while!
    Compressing /opt/iobroker/iobroker-data/states.jsonl
    Compressing /opt/iobroker/iobroker-data/objects.jsonl
    Compressed 2 JSONL files. Done
        Checking autostart (5/5)
    Enabling autostart...
    Autostart enabled!
    idash@ioBrokerVM:~$ cd /home/iobroker
    idash@ioBrokerVM:/home/iobroker$ sudo -u iobroker npm cache clear --force
    npm WARN using --force Recommended protections disabled.
    npm ERR! code ENOTEMPTY
    npm ERR! syscall rmdir
    npm ERR! path /home/iobroker/.npm/_cacache
    npm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rmdir '/home/iobroker/.npm/_cacache'
    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-09T13_38_57_713Z-debug-0.log
    #141
    @gismoh sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
    https://forum.iobroker.net/topic/57337/fehler-25-217-oder-enotempty-bei-adapter-install-update/1
    G 1 Antwort Letzte Antwort
      Gismoh
      schrieb am zuletzt editiert von Gismoh
      #142
      idash@ioBrokerVM:~$ find "/opt/iobroker/node_modules" -type d -iname ".*-????????" ! -iname ".local-chromium" -exec rm -rf "{}" \; &> /dev/null
      idash@ioBrokerVM:~$
      ausgeführt, mal sehen
      idash@ioBrokerVM:~$ iobroker add ble@0.13.4 --debug
      NPM version: 9.8.1
      Installing iobroker.ble@0.13.4... (System call)
      npm ERR! code 1
      npm ERR! path /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble
      npm ERR! command failed
      npm ERR! command sh -c node-gyp-build
      npm ERR! gyp info it worked if it ends with ok
      npm ERR! gyp info using node-gyp@7.1.2
      npm ERR! gyp info using node@18.18.2 | linux | x64
      npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
      npm ERR! (node:2237) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
      npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)
      npm ERR! gyp info spawn /usr/bin/python3
      npm ERR! gyp info spawn args [
      npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
      npm ERR! gyp info spawn args   'binding.gyp',
      npm ERR! gyp info spawn args   '-f',
      npm ERR! gyp info spawn args   'make',
      npm ERR! gyp info spawn args   '-I',
      npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/build/config.gypi',
      npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
      npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi',
      npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
      npm ERR! gyp info spawn args   '-Dvisibility=default',
      npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2',
      npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
      npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib',
      npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble',
      npm ERR! gyp info spawn args   '-Dnode_engine=v8',
      npm ERR! gyp info spawn args   '--depth=.',
      npm ERR! gyp info spawn args   '--no-parallel',
      npm ERR! gyp info spawn args   '--generator-output',
      npm ERR! gyp info spawn args   'build',
      npm ERR! gyp info spawn args   '-Goutput_dir=.'
      npm ERR! gyp info spawn args ]
      npm ERR! Traceback (most recent call last):
      npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>
      npm ERR!     sys.exit(gyp.script_main())
      npm ERR!              ^^^^^^^^^^^^^^^^^
      npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_main
      npm ERR!     return main(sys.argv[1:])
      npm ERR!            ^^^^^^^^^^^^^^^^^^
      npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in main
      npm ERR!     return gyp_main(args)
      npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_main
      npm ERR!     [generator, flat_list, targets, data] = Load(
      npm ERR!                                             ^^^^^
      npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Load
      npm ERR!     result = gyp.input.Load(
      npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Load
      npm ERR!     LoadTargetBuildFile(
      npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFile
      npm ERR!     build_file_data = LoadOneBuildFile(
      npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFile
      npm ERR!     build_file_contents = open(build_file_path, "rU").read()
      npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^
      npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gyp
      npm ERR! gyp ERR! configure error
      npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1
      npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)
      npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:517:28)
      npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:292:12)
      npm ERR! gyp ERR! System Linux 6.1.0-13-amd64
      npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble
      npm ERR! gyp ERR! node -v v18.18.2
      npm ERR! gyp ERR! node-gyp -v v7.1.2
      npm ERR! gyp ERR! not ok
      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-09T14_34_50_758Z-debug-0.log
      npm ERR! code 1
      npm ERR!                                             ^^^^^
      host.ioBrokerVM Cannot install iobroker.ble@0.13.4: 1
      idash@ioBrokerVM:~$
      ioBroker auf: Lenovo ThinkCentre M910Q Tiny i5-7500T 16 GB mit proxmox in VM (Bookworm)
      crunchipC HomoranH 2 Antworten Letzte Antwort
      • G Gismoh
        idash@ioBrokerVM:~$
        NPM version: 9.8.1
        npm ERR! code 1
        npm ERR!                                             ^^^^^
        npm ERR! code 1
        npm ERR!                                             ^^^^^
        idash@ioBrokerVM:~$
        crunchipC Offline
        crunchipC Offline
        #143
        @gismoh zeig mal die Ausgabe
        iob diag
        von beiden Systemen, Raspberry und Vm
        G 3 Antworten Letzte Antwort
        • G Gismoh
          idash@ioBrokerVM:~$
          NPM version: 9.8.1
          npm ERR! code 1
          npm ERR!                                             ^^^^^
          npm ERR! code 1
          npm ERR!                                             ^^^^^
          idash@ioBrokerVM:~$
          #144
          mal sehen
          was machst du denn jetzt schon wieder?
          der iob fix ist doch gar nicht durchgelaufen!
            mal sehen
            Gismoh
            #145
            Laut deinem Link ist doch dieser Befehl im iob fix enthalten?
            Das ganze ist ab sofort im ioBroker Fixer inkludiert, daher sollte unter Linux iob fix reichen!!
            dies wurde oben bereits getätigt
            • G Gismoh
              #146
              und brach ab mit isnotempty
              G 2 Antworten Letzte Antwort
                Gismoh
                #147
                @homoran okay - hatte mich auf das bezogen:
                dann mache ich es nochmal
                  iob diag
                  Gismoh
                  #148
                  @crunchip
                  neue VM (vor erneutem iob fix)
                  ======== Start marking the full check here =========
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                   Static hostname: ioBrokerVM
                         Icon name: computer-vm
                           Chassis: vm 🖴
                    Virtualization: kvm
                            Kernel: Linux 6.1.0-13-amd64
                      Architecture: x86-64
                   Hardware Vendor: QEMU
                    Hardware Model: Standard PC _i440FX + PIIX, 1996_
                  Firmware Version: rel-1.16.2-0-gea1b7a073390-prebuilt.qemu.org
                  model name      : QEMU Virtual CPU version 2.5+
                  Docker          : false
                  Virtualization  : kvm
                  Kernel          : x86_64
                  Userland        : amd64
                  Systemuptime and Load:
                   15:40:50 up  1:05,  2 users,  load average: 0.16, 0.04, 0.01
                  CPU threads: 2
                  *** Time and Time Zones ***
                                 Local time: Thu 2023-11-09 15:40:50 CET
                             Universal time: Thu 2023-11-09 14:40:50 UTC
                                   RTC time: Thu 2023-11-09 14:40:50
                                NTP service: active
                            RTC in local TZ: no
                  *** User and Groups ***
                  idash
                  /home/idash
                  idash adm dialout sudo plugdev users input netdev iobroker
                  *** X-Server-Setup ***
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            4.1G        384M        3.4G        507K        574M        3.7G
                  Swap:           1.0G          0B        1.0G
                  Total:          5.1G        384M        4.4G
                           3915 M total memory
                            367 M used memory
                            222 M active memory
                            251 M inactive memory
                           3248 M free memory
                             67 M buffer memory
                            480 M swap cache
                            974 M total swap
                              0 M used swap
                            974 M free swap
                  *** FAILED SERVICES ***
                    UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                  * iobroker.service loaded failed failed ioBroker Server
                  1 loaded units listed.
                  *** FILESYSTEM ***
                  udev           devtmpfs  1.9G     0  1.9G   0% /dev
                  tmpfs          tmpfs     392M  500K  392M   1% /run
                  /dev/sda1      ext4       31G  3.6G   26G  13% /
                  tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
                  tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                  tmpfs          tmpfs     392M     0  392M   0% /run/user/1002
                  [Thu Nov  9 14:35:44 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                  [Thu Nov  9 14:35:45 2023] EXT4-fs (sda1): re-mounted. Quota mode: none.
                  Show mounted filesystems \(real ones only\):
                  TARGET SOURCE    FSTYPE OPTIONS
                  /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
                  /var:
                  455M    /var/
                  248M    /var/cache
                  240M    /var/cache/apt
                  169M    /var/lib
                  164M    /var/cache/apt/archives
                  Archived and active journals take up 24.0M in the file system.
                  /opt/iobroker/backups:
                  5.8M    /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  189M    /opt/iobroker/iobroker-data/
                  157M    /opt/iobroker/iobroker-data/files
                  52M     /opt/iobroker/iobroker-data/files/javascript.admin
                  34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                  33M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                  27M     /opt/iobroker/iobroker-data/objects.jsonl
                  19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
                  8.2M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js
                  7.2M    /opt/iobroker/iobroker-data/files/ham.admin/static/js/main.8080bc0b.js.map
                  7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
                  find: '/dev/serial/by-id/': No such file or directory
                  USB-Devices by-id:
                  USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs         v18.18.2
                  /usr/bin/node           v18.18.2
                  /usr/bin/npm            9.8.1
                  /usr/bin/npx            9.8.1
                  /usr/bin/corepack       0.19.0
                  nodejs:
                    Installed: 18.18.2-1nodesource1
                    Candidate: 18.18.2-1nodesource1
                    Version table:
                   *** 18.18.2-1nodesource1 500
                          500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                          100 /var/lib/dpkg/status
                       18.18.1-1nodesource1 500
                       18.18.0-1nodesource1 500
                       18.17.1-1nodesource1 500
                       18.17.0-1nodesource1 500
                       18.16.1-1nodesource1 500
                       18.16.0-1nodesource1 500
                       18.15.0-1nodesource1 500
                       18.14.2-1nodesource1 500
                       18.14.1-1nodesource1 500
                       18.14.0-1nodesource1 500
                       18.13.0+dfsg1-1 500
                          500 http://deb.debian.org/debian bookworm/main amd64 Packages
                       18.13.0-1nodesource1 500
                       18.12.0-1nodesource1 500
                       18.11.0-1nodesource1 500
                       18.10.0-1nodesource1 500
                       18.9.1-1nodesource1 500
                       18.9.0-1nodesource1 500
                       18.8.0-1nodesource1 500
                       18.7.0-1nodesource1 500
                       18.6.0-1nodesource1 500
                       18.5.0-1nodesource1 500
                       18.4.0-1nodesource1 500
                       18.3.0-1nodesource1 500
                       18.2.0-1nodesource1 500
                       18.1.0-1nodesource1 500
                       18.0.0-1nodesource1 500
                  No problems detected
                  Errors in npm tree:
                  *** ioBroker-Installation ***
                  ioBroker Status
                  iobroker is not running on this host.
                  Objects type: jsonl
                  States  type: jsonl
                  Core adapters versions
                  js-controller:  5.0.12
                  admin:          6.8.0
                  javascript:     7.1.4
                  Adapters from github:   0
                  Adapter State
                    system.adapter.admin.0                  : admin                 : ioBrokerVM                               -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                    system.adapter.alarm.0                  : alarm                 : ioBrokerVM                               - disabled
                    system.adapter.alexa2.0                 : alexa2                : ioBrokerVM                               - disabled
                    system.adapter.backitup.0               : backitup              : ioBrokerVM                               -  enabled
                    system.adapter.daikin-cloud.0           : daikin-cloud          : ioBrokerVM                               - disabled
                    system.adapter.daswetter.0              : daswetter             : ioBrokerVM                               - disabled
                    system.adapter.deconz.0                 : deconz                : ioBrokerVM                               - disabled, port: 8090
                    system.adapter.device-reminder.0        : device-reminder       : ioBrokerVM                               - disabled
                    system.adapter.discovery.0              : discovery             : ioBrokerVM                               - disabled
                    system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : ioBrokerVM                               - disabled
                    system.adapter.enigma2.0                : enigma2               : ioBrokerVM                               - disabled
                    system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBrokerVM                               - disabled
                    system.adapter.fiat.0                   : fiat                  : ioBrokerVM                               - disabled
                    system.adapter.flot.0                   : flot                  : ioBrokerVM                               - disabled
                    system.adapter.fullybrowser.0           : fullybrowser          : ioBrokerVM                               - disabled
                    system.adapter.go-e.0                   : go-e                  : ioBrokerVM                               - disabled
                    system.adapter.go-e.1                   : go-e                  : ioBrokerVM                               - disabled
                    system.adapter.ham.0                    : ham                   : ioBrokerVM                               - disabled
                    system.adapter.harmony.0                : harmony               : ioBrokerVM                               - disabled
                    system.adapter.hue-extended.0           : hue-extended          : ioBrokerVM                               - disabled
                    system.adapter.hue.0                    : hue                   : ioBrokerVM                               - disabled, port: 443
                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBrokerVM                               - disabled
                    system.adapter.influxdb.0               : influxdb              : ioBrokerVM                               - disabled, port: 8086
                    system.adapter.info.0                   : info                  : ioBrokerVM                               - disabled
                    system.adapter.iot.0                    : iot                   : ioBrokerVM                               - disabled
                    system.adapter.javascript.0             : javascript            : ioBrokerVM                               - disabled
                    system.adapter.meross.0                 : meross                : ioBrokerVM                               - disabled
                    system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBrokerVM                               - disabled, port: 54321
                    system.adapter.mihome-vacuum.2          : mihome-vacuum         : ioBrokerVM                               - disabled, port: 54321
                    system.adapter.mobile.0                 : mobile                : ioBrokerVM                               - disabled
                    system.adapter.openweathermap.0         : openweathermap        : ioBrokerVM                               - disabled
                    system.adapter.pi-hole.0                : pi-hole               : ioBrokerVM                               - disabled
                    system.adapter.pushover.0               : pushover              : ioBrokerVM                               - disabled
                    system.adapter.pvforecast.0             : pvforecast            : ioBrokerVM                               - disabled
                    system.adapter.radar2.0                 : radar2                : ioBrokerVM                               - disabled
                    system.adapter.shelly.0                 : shelly                : ioBrokerVM                               - disabled, port: 1882, bind: 0.0.0.0
                    system.adapter.shelly.1                 : shelly                : ioBrokerVM                               - disabled, port: 1882, bind: 0.0.0.0
                    system.adapter.smartcontrol.0           : smartcontrol          : ioBrokerVM                               - disabled
                    system.adapter.socketio.0               : socketio              : ioBrokerVM                               - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                    system.adapter.sonoff.0                 : sonoff                : ioBrokerVM                               - disabled, port: 1883, bind: 0.0.0.0
                    system.adapter.tado.0                   : tado                  : ioBrokerVM                               - disabled
                    system.adapter.telegram.0               : telegram              : ioBrokerVM                               - disabled, port: 8443, bind: 0.0.0.0
                    system.adapter.tibberlink.0             : tibberlink            : ioBrokerVM                               - disabled
                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBrokerVM                               - disabled
                    system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBrokerVM                               - disabled
                    system.adapter.vis-material-advanced.0  : vis-material-advanced : ioBrokerVM                               - disabled
                    system.adapter.vis-metro.0              : vis-metro             : ioBrokerVM                               - disabled
                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBrokerVM                               - disabled
                    system.adapter.vis.0                    : vis                   : ioBrokerVM                               - disabled
                    system.adapter.weatherunderground.0     : weatherunderground    : ioBrokerVM                               - disabled
                    system.adapter.web.0                    : web                   : ioBrokerVM                               - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                    system.adapter.worx.0                   : worx                  : ioBrokerVM                               - disabled
                  + instance is alive
                  ioBroker-Repositories
                  Stable (default): http://iobroker.live/repo/sources-dist.json
                  Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                  Installed ioBroker-Instances
                  Adapter    "admin"        : 6.12.0   , installed 6.8.0  [Updatable]
                  Adapter    "alarm"        : 3.4.0    , installed 3.3.13 [Updatable]
                  Adapter    "alexa2"       : 3.25.2   , installed 3.23.2 [Updatable]
                  Adapter    "backitup"     : 2.8.7    , installed 2.8.1  [Updatable]
                  Adapter    "daikin-cloud" : 0.3.0    , installed 0.3.0
                  Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                  Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                  Adapter    "device-reminder": 3.0.0  , installed 1.2.9  [Updatable]
                  Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                  Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
                  Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
                  Adapter    "fiat"         : 0.0.8    , installed 0.0.8
                  Adapter    "fullybrowser" : 2.2.0    , installed 2.1.2  [Updatable]
                  Adapter    "go-e"         : 1.0.27   , installed 1.0.27
                  Adapter    "ham"          : 5.3.1    , installed 5.3.1
                  Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                  Adapter    "hue"          : 3.10.1   , installed 3.10.0 [Updatable]
                  Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
                  Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
                  Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                  Adapter    "info"         : 2.0.0    , installed 2.0.0
                  Adapter    "iot"          : 1.14.5   , installed 1.14.5
                  Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                  Controller "js-controller": 5.0.12   , installed 5.0.12
                  Adapter    "meross"       : 1.15.1   , installed 1.15.1
                  Adapter    "mihome-vacuum": 4.0.0    , installed 4.0.0
                  Adapter    "mobile"       : 1.0.1    , installed 1.0.1
                  Adapter    "openweathermap": 0.3.9   , installed 0.3.9
                  Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
                  Adapter    "pushover"     : 3.0.3    , installed 3.0.3
                  Adapter    "pvforecast"   : 2.9.0    , installed 2.8.1  [Updatable]
                  Adapter    "radar2"       : 2.0.8    , installed 2.0.7  [Updatable]
                  Adapter    "shelly"       : 6.6.1    , installed 6.4.1  [Updatable]
                  Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
                  Copy text starting here:
                                          v.2023-10-10
                           Chassis: vm 🖴
                    Virtualization: kvm
                  Installation:           kvm
                  Kernel:                 x86_64
                  Userland:               amd64
                  Timezone:               Europe/Berlin (CET, +0100)
                  User-ID:                1002
                  X-Server:               false
                  Pending OS-Updates:     0
                  Pending iob updates:    16
                  Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                          /usr/bin/npm            9.8.1
                                          /usr/bin/npx            9.8.1
                  Recommended versions are nodejs 18.18.2 and npm 9.8.1
                  MEMORY:
                  Mem:            4.1G        418M        3.4G        512K        590M        3.7G
                  Swap:           1.0G          0B        1.0G
                  Total:          5.1G        418M        4.4G
                  Active iob-Instances:   1
                  ioBroker Core:          js-controller           5.0.12
                                          admin                   6.8.0
                  ioBroker Status:        iobroker is not running on this host.
                  Objects type: jsonl
                  States  type: jsonl
                  Objects:                32918
                  States:                 20853
                  Size of iob-Database:
                  35M     /opt/iobroker/iobroker-data/objects.jsonl
                  4.9M    /opt/iobroker/iobroker-data/states.jsonl
                  === Mark text until here for copying ===
                  HomoranH crunchipC 2 Antworten Letzte Antwort
                  • G Gismoh
                    @crunchip
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                             Chassis: vm 🖴
                      Virtualization: kvm
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : amd64
                    CPU threads: 2
                                  NTP service: active
                              RTC in local TZ: no
                    idash
                    /home/idash
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Swap:           1.0G          0B        1.0G
                             3915 M total memory
                              367 M used memory
                              222 M active memory
                             3248 M free memory
                               67 M buffer memory
                              480 M swap cache
                              974 M total swap
                                0 M used swap
                              974 M free swap
                    *** FILESYSTEM ***
                    /var:
                    455M    /var/
                    248M    /var/cache
                    240M    /var/cache/apt
                    169M    /var/lib
                    USB-Devices by-id:
                    /usr/bin/npm            9.8.1
                    /usr/bin/npx            9.8.1
                    nodejs:
                      Version table:
                         18.13.0+dfsg1-1 500
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.8.0
                    javascript:     7.1.4
                    Adapter State
                    + instance is alive
                                            v.2023-10-10
                             Chassis: vm 🖴
                      Virtualization: kvm
                    Installation:           kvm
                    Kernel:                 x86_64
                    Userland:               amd64
                    User-ID:                1002
                    X-Server:               false
                                            /usr/bin/npm            9.8.1
                                            /usr/bin/npx            9.8.1
                    MEMORY:
                    Swap:           1.0G          0B        1.0G
                                            admin                   6.8.0
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                32918
                    States:                 20853
                    #149
                    full ist unvollständig
                    wie kommen die ganzen Adapter da rein wenn das eine neue VM ist?
                      Gismoh
                      #150
                      Ich sollte doch das Backup einspielen. Dies hatte ich auch getan, auf der frischen Maschine (VM) ohne backup läuft ja der ble!
                      Oder sind die Adpater ungewöhnlich, wenn man das backup von backitup einspielt?
                        Gismoh
                        #151
                        iob fix sieht für mich "normal" aus -sehe dort keine Fehlermeldung.
                        (gerade erneut gemacht)
                        library: loaded
                        Done.
                        Autostart enabled!
                        idash@ioBrokerVM:~$ iob start
                          iob diag
                          Gismoh
                          #152
                          @crunchip
                          iob diag
                          von der "alten" installation dauert noch, muss dort im Docker erst noch nen neuen User erstellen. Da ich dort ran muss, ziehe ich erst noch ein Sicherung der SD-Karte.
                          • G Gismoh
                            @crunchip
                            Skript v.2023-10-10
                            *** BASE SYSTEM ***
                                     Chassis: vm 🖴
                              Virtualization: kvm
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : amd64
                            CPU threads: 2
                                          NTP service: active
                                      RTC in local TZ: no
                            idash
                            /home/idash
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Swap:           1.0G          0B        1.0G
                                     3915 M total memory
                                      367 M used memory
                                      222 M active memory
                                     3248 M free memory
                                       67 M buffer memory
                                      480 M swap cache
                                      974 M total swap
                                        0 M used swap
                                      974 M free swap
                            *** FILESYSTEM ***
                            /var:
                            455M    /var/
                            248M    /var/cache
                            240M    /var/cache/apt
                            169M    /var/lib
                            USB-Devices by-id:
                            /usr/bin/npm            9.8.1
                            /usr/bin/npx            9.8.1
                            nodejs:
                              Version table:
                                 18.13.0+dfsg1-1 500
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.8.0
                            javascript:     7.1.4
                            Adapter State
                            + instance is alive
                                                    v.2023-10-10
                                     Chassis: vm 🖴
                              Virtualization: kvm
                            Installation:           kvm
                            Kernel:                 x86_64
                            Userland:               amd64
                            User-ID:                1002
                            X-Server:               false
                                                    /usr/bin/npm            9.8.1
                                                    /usr/bin/npx            9.8.1
                            MEMORY:
                            Swap:           1.0G          0B        1.0G
                                                    admin                   6.8.0
                            Objects type: jsonl
                            States  type: jsonl
                            Objects:                32918
                            States:                 20853
                            crunchipC Offline
                            crunchipC Offline
                            #153
                            Fährst du noch all diese alten versionen auf dem alten System?
                            Edit
                            Vllt mal dein altes system auf stand bringen.
                            Update's..
                            iob fix
                            Und dann ein backup ziehen
                            Und dann die Ausgabe von iob diag nochmal
                              Edit
                              Update's..
                              iob fix
                              Gismoh
                              #154
                              @crunchip
                              okay - werd ich versuchen.
                              hatte die alte maschine nicht mehr weiter geupdated, da ich vor kurzer Zeit mal den Admin geupdatet hatte, und dann iob "Tot" war, ich also keinen zugriff mehr hatte. Aber in der Zwischenzeit bin ich dort auf Bullseye hoch gegangen.
                              Werd ich mich also nachher noch mal ranmachen ;)
                              • G Gismoh
                                @crunchip
                                crunchipC Offline
                                crunchipC Offline
                                #155
                                Das zeigt dir dann auch der diag an
                                  Gismoh
                                  #156
                                  @crunchip
                                  Mist - vorhin aufgefallen, der iobroker im Docker läuft noch auf Buster.
                                  War mir sicher, das ich geupdatet hätte .... hatte wohl nur den Pi an sich auf Bullseye gebracht aber nicht den iobroker-container 😕
                                  Hoffe das klappt auch.
                                  Zumindest habe ich den ioBroker selber und den Adaptern nun updates verpasst.
                                    Gismoh
                                    #157
                                    @crunchip
                                    das Ergebnis vom (alten) Pi:
                                                            v.2023-10-10
                                    /home/iobroker/.diag.sh: line 457: hostnamectl: command not found
                                    Installation:
                                    Kernel:                 armv7l
                                    Userland:               armhf
                                    /home/iobroker/.diag.sh: line 466: timedatectl: command not found
                                    Timezone:
                                    User-ID:                1001
                                    X-Server:               false
                                    /home/iobroker/.diag.sh: line 473: systemctl: command not found
                                    Boot Target:
                                    Pending OS-Updates:     60
                                    error: failed switching to "iobroker": operation not permitted
                                    Pending iob updates:    0
                                    Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                                            /usr/bin/node           v18.17.1
                                                            /usr/bin/npm            9.6.7
                                                            /usr/bin/npx            9.6.7
                                                            /usr/bin/corepack       0.18.0
                                    Recommended versions are nodejs  and npm
                                    MEMORY:
                                    Mem:           7.9G        1.9G        4.9G        1.0M        1.1G        5.8G
                                    Swap:           99M          0B         99M
                                    Total:         8.0G        1.9G        5.0G
                                    Active iob-Instances:   0
                                                            admin
                                    ioBroker Status:
                                    Objects:                0
                                    States:                 0
                                    40M     /opt/iobroker/iobroker-data/objects.jsonl
                                    17M     /opt/iobroker/iobroker-data/objects.json.migrated
                                    17M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                    16K     /opt/iobroker/iobroker-data/objects.json.old
                                    31M     /opt/iobroker/iobroker-data/states.jsonl
                                    2.3M    /opt/iobroker/iobroker-data/states.json.migrated
                                    2.3M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                    2.0M    /opt/iobroker/iobroker-data/states.json.old
                                    • G Gismoh
                                      @crunchip
                                                              v.2023-10-10
                                      Installation:
                                      Kernel:                 armv7l
                                      Userland:               armhf
                                      Timezone:
                                      User-ID:                1001
                                      X-Server:               false
                                      Boot Target:
                                                              /usr/bin/npm            9.6.7
                                                              /usr/bin/npx            9.6.7
                                      MEMORY:
                                      Swap:           99M          0B         99M
                                                              admin
                                      ioBroker Status:
                                      Objects:                0
                                      States:                 0
                                      #158
                                      @gismoh
                                      Der muss aber sehr alt sein, wenn die Kommandos da gar nicht funktionieren.
                                        @gismoh
                                        Gismoh
                                        #159
                                        leider, ich gelobe Besserung.
                                        Hatte wohl meist nur die iob updates gemacht -.-
                                        bei
                                        sudo apt update
                                        spuckt er mir direkt eine Fehlermeldung wegen eines key´s raus.
                                        idash@raspberrypi:/opt/iobroker$ sudo apt update
                                        [sudo] password for idash:
                                        Hit:1 http://security.debian.org/debian-security buster/updates InRelease
                                        Hit:2 http://deb.debian.org/debian buster InRelease
                                        Hit:3 http://deb.debian.org/debian buster-updates InRelease
                                        Get:4 https://repos.influxdata.com/debian buster InRelease [7.047 B]
                                        Get:5 https://deb.nodesource.com/node_18.x buster InRelease [4.584 B]
                                        Err:4 https://repos.influxdata.com/debian buster InRelease
                                          The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                                        Fetched 11,6 kB in 2s (5.507 B/s)
                                        Reading package lists... Done
                                        Building dependency tree
                                        60 packages can be upgraded. Run 'apt list --upgradable' to see them.
                                        W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                                        W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                                        W: Some index files failed to download. They have been ignored, or old ones used instead.
                                        Daher ersteinmal nicht weiter gemacht.
                                        • G Gismoh
                                          bei
                                          sudo apt update
                                          crunchipC Offline
                                          crunchipC Offline
                                          #160
                                          Findest du Anleitung auf Thomas Profil
                                          Oder du kommentierst sie einfach aus in der repo list, brauchst ja eigentlich nimmer. Dann würden zumindest die updates für buster durchlaufen
                                          Allerdings sieht deine Ausgabe von diag nicht gerade prickelnd aus
