ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme
idash@ioBrokerVM:~$ iob stop idash@ioBrokerVM:~$ iob fix library: loaded Library version=2023-10-13 ========================================================================== Welcome to the ioBroker installation fixer! Script version: 2023-10-13 You might need to enter your password a couple of times. ========================================================================== ========================================================================== Installing prerequisites (1/5) ========================================================================== [sudo] Passwort für idash: OK:1 http://security.debian.org/debian-security bookworm-security InRelease OK:2 http://deb.debian.org/debian bookworm InRelease OK:3 http://deb.debian.org/debian bookworm-updates InRelease OK:4 https://deb.nodesource.com/node_18.x nodistro InRelease Paketlisten werden gelesen… Fertig ========================================================================== Checking ioBroker user and directory permissions (2/5) ========================================================================== Created /etc/sudoers.d/iobroker Fixing directory permissions... ========================================================================== Check and cleanup npm temporary directories (3/5) ========================================================================== Done. ========================================================================== Database maintenance (4/5) ========================================================================== Checking for uncompressed JSONL databases... This might take a while! Compressing /opt/iobroker/iobroker-data/states.jsonl Compressing /opt/iobroker/iobroker-data/objects.jsonl Compressed 2 JSONL files. Done ========================================================================== Checking autostart (5/5) ========================================================================== Enabling autostart... Autostart enabled! ========================================================================== Your installation was fixed successfully Run iobroker start to start ioBroker again! ========================================================================== idash@ioBrokerVM:~$ cd /home/iobroker idash@ioBrokerVM:/home/iobroker$ sudo -u iobroker npm cache clear --force npm WARN using --force Recommended protections disabled. npm ERR! code ENOTEMPTY npm ERR! syscall rmdir npm ERR! path /home/iobroker/.npm/_cacache npm ERR! errno -39 npm ERR! ENOTEMPTY: directory not empty, rmdir '/home/iobroker/.npm/_cacache' npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-09T13_38_57_713Z-debug-0.log idash@ioBrokerVM:/home/iobroker$Ansonsten die Schritte von Gestern abend noch mal durchgegangen, mit scheinbar selbem Ergebnis:
idash@ioBrokerVM:/home/iobroker$ cd / idash@ioBrokerVM:/$ ls -lah /home/iobroker/.npm/_cacache insgesamt 12K drwxr-xr-x 3 iobroker iobroker 4,0K 9. Nov 14:38 . drwxr-xr-x 7 iobroker iobroker 4,0K 9. Nov 14:38 .. drwxr-xr-x 2 iobroker iobroker 4,0K 9. Nov 14:38 tmp idash@ioBrokerVM:/$ rm -rf /home/iobroker/.npm/_cacache/tmp rm: das Entfernen von '/home/iobroker/.npm/_cacache/tmp/a8c63b11' ist nicht möglich: Keine Berechtigung idash@ioBrokerVM:/$ sudo -u iobroker rm -rf /home/iobroker/.npm/_cacache/tmp idash@ioBrokerVM:/$ cd /home/iobroker idash@ioBrokerVM:/home/iobroker$ sudo -u iobroker npm cache clear --force npm WARN using --force Recommended protections disabled. idash@ioBrokerVM:/home/iobroker$ cd idash@ioBrokerVM:~$ iobroker upgrade ble@0.13.4 Adapter "ble" is not installed. idash@ioBrokerVM:~$ iobroker add ble@0.13.4 --debug NPM version: 9.8.1 Installing iobroker.ble@0.13.4... (System call) npm ERR! code 1 npm ERR! path /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble npm ERR! command failed npm ERR! command sh -c node-gyp-build npm ERR! gyp info it worked if it ends with ok npm ERR! gyp info using node-gyp@7.1.2 npm ERR! gyp info using node@18.18.2 | linux | x64 npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3" npm ERR! (node:2039) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only. npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created) npm ERR! gyp info spawn /usr/bin/python3 npm ERR! gyp info spawn args [ npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py', npm ERR! gyp info spawn args 'binding.gyp', npm ERR! gyp info spawn args '-f', npm ERR! gyp info spawn args 'make', npm ERR! gyp info spawn args '-I', npm ERR! gyp info spawn args '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/build/config.gypi', npm ERR! gyp info spawn args '-I', npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi', npm ERR! gyp info spawn args '-I', npm ERR! gyp info spawn args '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi', npm ERR! gyp info spawn args '-Dlibrary=shared_library', npm ERR! gyp info spawn args '-Dvisibility=default', npm ERR! gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2', npm ERR! gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp', npm ERR! gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib', npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble', npm ERR! gyp info spawn args '-Dnode_engine=v8', npm ERR! gyp info spawn args '--depth=.', npm ERR! gyp info spawn args '--no-parallel', npm ERR! gyp info spawn args '--generator-output', npm ERR! gyp info spawn args 'build', npm ERR! gyp info spawn args '-Goutput_dir=.' npm ERR! gyp info spawn args ] npm ERR! Traceback (most recent call last): npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module> npm ERR! sys.exit(gyp.script_main()) npm ERR! ^^^^^^^^^^^^^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_main npm ERR! return main(sys.argv[1:]) npm ERR! ^^^^^^^^^^^^^^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in main npm ERR! return gyp_main(args) npm ERR! ^^^^^^^^^^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_main npm ERR! [generator, flat_list, targets, data] = Load( npm ERR! ^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Load npm ERR! result = gyp.input.Load( npm ERR! ^^^^^^^^^^^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Load npm ERR! LoadTargetBuildFile( npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFile npm ERR! build_file_data = LoadOneBuildFile( npm ERR! ^^^^^^^^^^^^^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFile npm ERR! build_file_contents = open(build_file_path, "rU").read() npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^ npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gyp npm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1 npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16) npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:517:28) npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:292:12) npm ERR! gyp ERR! System Linux 6.1.0-13-amd64 npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild" npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble npm ERR! gyp ERR! node -v v18.18.2 npm ERR! gyp ERR! node-gyp -v v7.1.2 npm ERR! gyp ERR! not ok npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-09T13_48_08_783Z-debug-0.log npm ERR! code 1 npm ERR! path /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble npm ERR! command failed npm ERR! command sh -c node-gyp-build npm ERR! gyp info it worked if it ends with ok npm ERR! gyp info using node-gyp@7.1.2 npm ERR! gyp info using node@18.18.2 | linux | x64 npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3" npm ERR! (node:2039) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only. npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created) npm ERR! gyp info spawn /usr/bin/python3 npm ERR! gyp info spawn args [ npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py', npm ERR! gyp info spawn args 'binding.gyp', npm ERR! gyp info spawn args '-f', npm ERR! gyp info spawn args 'make', npm ERR! gyp info spawn args '-I', npm ERR! gyp info spawn args '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/build/config.gypi', npm ERR! gyp info spawn args '-I', npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi', npm ERR! gyp info spawn args '-I', npm ERR! gyp info spawn args '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi', npm ERR! gyp info spawn args '-Dlibrary=shared_library', npm ERR! gyp info spawn args '-Dvisibility=default', npm ERR! gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2', npm ERR! gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp', npm ERR! gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib', npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble', npm ERR! gyp info spawn args '-Dnode_engine=v8', npm ERR! gyp info spawn args '--depth=.', npm ERR! gyp info spawn args '--no-parallel', npm ERR! gyp info spawn args '--generator-output', npm ERR! gyp info spawn args 'build', npm ERR! gyp info spawn args '-Goutput_dir=.' npm ERR! gyp info spawn args ] npm ERR! Traceback (most recent call last): npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module> npm ERR! sys.exit(gyp.script_main()) npm ERR! ^^^^^^^^^^^^^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_main npm ERR! return main(sys.argv[1:]) npm ERR! ^^^^^^^^^^^^^^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in main npm ERR! return gyp_main(args) npm ERR! ^^^^^^^^^^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_main npm ERR! [generator, flat_list, targets, data] = Load( npm ERR! ^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Load npm ERR! result = gyp.input.Load( npm ERR! ^^^^^^^^^^^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Load npm ERR! LoadTargetBuildFile( npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFile npm ERR! build_file_data = LoadOneBuildFile( npm ERR! ^^^^^^^^^^^^^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFile npm ERR! build_file_contents = open(build_file_path, "rU").read() npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^ npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gyp npm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1 npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16) npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:517:28) npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:292:12) npm ERR! gyp ERR! System Linux 6.1.0-13-amd64 npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild" npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble npm ERR! gyp ERR! node -v v18.18.2 npm ERR! gyp ERR! node-gyp -v v7.1.2 npm ERR! gyp ERR! not ok npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-09T13_48_08_783Z-debug-0.log host.ioBrokerVM Cannot install iobroker.ble@0.13.4: 1 -
idash@ioBrokerVM:~$ iob stop idash@ioBrokerVM:~$ iob fix library: loaded Library version=2023-10-13 ========================================================================== Welcome to the ioBroker installation fixer! Script version: 2023-10-13 You might need to enter your password a couple of times. ========================================================================== ========================================================================== Installing prerequisites (1/5) ========================================================================== [sudo] Passwort für idash: OK:1 http://security.debian.org/debian-security bookworm-security InRelease OK:2 http://deb.debian.org/debian bookworm InRelease OK:3 http://deb.debian.org/debian bookworm-updates InRelease OK:4 https://deb.nodesource.com/node_18.x nodistro InRelease Paketlisten werden gelesen… Fertig ========================================================================== Checking ioBroker user and directory permissions (2/5) ========================================================================== Created /etc/sudoers.d/iobroker Fixing directory permissions... ========================================================================== Check and cleanup npm temporary directories (3/5) ========================================================================== Done. ========================================================================== Database maintenance (4/5) ========================================================================== Checking for uncompressed JSONL databases... This might take a while! Compressing /opt/iobroker/iobroker-data/states.jsonl Compressing /opt/iobroker/iobroker-data/objects.jsonl Compressed 2 JSONL files. Done ========================================================================== Checking autostart (5/5) ========================================================================== Enabling autostart... Autostart enabled! ========================================================================== Your installation was fixed successfully Run iobroker start to start ioBroker again! ========================================================================== idash@ioBrokerVM:~$ cd /home/iobroker idash@ioBrokerVM:/home/iobroker$ sudo -u iobroker npm cache clear --force npm WARN using --force Recommended protections disabled. npm ERR! code ENOTEMPTY npm ERR! syscall rmdir npm ERR! path /home/iobroker/.npm/_cacache npm ERR! errno -39 npm ERR! ENOTEMPTY: directory not empty, rmdir '/home/iobroker/.npm/_cacache' npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-09T13_38_57_713Z-debug-0.log idash@ioBrokerVM:/home/iobroker$@gismoh sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
https://forum.iobroker.net/topic/57337/fehler-25-217-oder-enotempty-bei-adapter-install-update/1
idash@ioBrokerVM:~$ find "/opt/iobroker/node_modules" -type d -iname ".*-????????" ! -iname ".local-chromium" -exec rm -rf "{}" \; &> /dev/null idash@ioBrokerVM:~$ausgeführt, mal sehen
idash@ioBrokerVM:~$ iobroker add ble@0.13.4 --debug NPM version: 9.8.1 Installing iobroker.ble@0.13.4... (System call) npm ERR! code 1 npm ERR! path /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble npm ERR! command failed npm ERR! command sh -c node-gyp-build npm ERR! gyp info it worked if it ends with ok npm ERR! gyp info using node-gyp@7.1.2 npm ERR! gyp info using node@18.18.2 | linux | x64 npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3" npm ERR! (node:2237) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only. npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created) npm ERR! gyp info spawn /usr/bin/python3 npm ERR! gyp info spawn args [ npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py', npm ERR! gyp info spawn args 'binding.gyp', npm ERR! gyp info spawn args '-f', npm ERR! gyp info spawn args 'make', npm ERR! gyp info spawn args '-I', npm ERR! gyp info spawn args '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/build/config.gypi', npm ERR! gyp info spawn args '-I', npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi', npm ERR! gyp info spawn args '-I', npm ERR! gyp info spawn args '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi', npm ERR! gyp info spawn args '-Dlibrary=shared_library', npm ERR! gyp info spawn args '-Dvisibility=default', npm ERR! gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2', npm ERR! gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp', npm ERR! gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib', npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble', npm ERR! gyp info spawn args '-Dnode_engine=v8', npm ERR! gyp info spawn args '--depth=.', npm ERR! gyp info spawn args '--no-parallel', npm ERR! gyp info spawn args '--generator-output', npm ERR! gyp info spawn args 'build', npm ERR! gyp info spawn args '-Goutput_dir=.' npm ERR! gyp info spawn args ] npm ERR! Traceback (most recent call last): npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module> npm ERR! sys.exit(gyp.script_main()) npm ERR! ^^^^^^^^^^^^^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_main npm ERR! return main(sys.argv[1:]) npm ERR! ^^^^^^^^^^^^^^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in main npm ERR! return gyp_main(args) npm ERR! ^^^^^^^^^^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_main npm ERR! [generator, flat_list, targets, data] = Load( npm ERR! ^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Load npm ERR! result = gyp.input.Load( npm ERR! ^^^^^^^^^^^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Load npm ERR! LoadTargetBuildFile( npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFile npm ERR! build_file_data = LoadOneBuildFile( npm ERR! ^^^^^^^^^^^^^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFile npm ERR! build_file_contents = open(build_file_path, "rU").read() npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^ npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gyp npm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1 npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16) npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:517:28) npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:292:12) npm ERR! gyp ERR! System Linux 6.1.0-13-amd64 npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild" npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble npm ERR! gyp ERR! node -v v18.18.2 npm ERR! gyp ERR! node-gyp -v v7.1.2 npm ERR! gyp ERR! not ok npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-09T14_34_50_758Z-debug-0.log npm ERR! code 1 npm ERR! path /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble npm ERR! command failed npm ERR! command sh -c node-gyp-build npm ERR! gyp info it worked if it ends with ok npm ERR! gyp info using node-gyp@7.1.2 npm ERR! gyp info using node@18.18.2 | linux | x64 npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3" npm ERR! (node:2237) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only. npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created) npm ERR! gyp info spawn /usr/bin/python3 npm ERR! gyp info spawn args [ npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py', npm ERR! gyp info spawn args 'binding.gyp', npm ERR! gyp info spawn args '-f', npm ERR! gyp info spawn args 'make', npm ERR! gyp info spawn args '-I', npm ERR! gyp info spawn args '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/build/config.gypi', npm ERR! gyp info spawn args '-I', npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi', npm ERR! gyp info spawn args '-I', npm ERR! gyp info spawn args '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi', npm ERR! gyp info spawn args '-Dlibrary=shared_library', npm ERR! gyp info spawn args '-Dvisibility=default', npm ERR! gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2', npm ERR! gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp', npm ERR! gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib', npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble', npm ERR! gyp info spawn args '-Dnode_engine=v8', npm ERR! gyp info spawn args '--depth=.', npm ERR! gyp info spawn args '--no-parallel', npm ERR! gyp info spawn args '--generator-output', npm ERR! gyp info spawn args 'build', npm ERR! gyp info spawn args '-Goutput_dir=.' npm ERR! gyp info spawn args ] npm ERR! Traceback (most recent call last): npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module> npm ERR! sys.exit(gyp.script_main()) npm ERR! ^^^^^^^^^^^^^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_main npm ERR! return main(sys.argv[1:]) npm ERR! ^^^^^^^^^^^^^^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in main npm ERR! return gyp_main(args) npm ERR! ^^^^^^^^^^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_main npm ERR! [generator, flat_list, targets, data] = Load( npm ERR! ^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Load npm ERR! result = gyp.input.Load( npm ERR! ^^^^^^^^^^^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Load npm ERR! LoadTargetBuildFile( npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFile npm ERR! build_file_data = LoadOneBuildFile( npm ERR! ^^^^^^^^^^^^^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFile npm ERR! build_file_contents = open(build_file_path, "rU").read() npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^ npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gyp npm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1 npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16) npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:517:28) npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:292:12) npm ERR! gyp ERR! System Linux 6.1.0-13-amd64 npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild" npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble npm ERR! gyp ERR! node -v v18.18.2 npm ERR! gyp ERR! node-gyp -v v7.1.2 npm ERR! gyp ERR! not ok npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-09T14_34_50_758Z-debug-0.log host.ioBrokerVM Cannot install iobroker.ble@0.13.4: 1 idash@ioBrokerVM:~$ -
idash@ioBrokerVM:~$ iobroker add ble@0.13.4 --debug NPM version: 9.8.1 Installing iobroker.ble@0.13.4... (System call) npm ERR! code 1 npm ERR! path /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble npm ERR! command failed npm ERR! command sh -c node-gyp-build npm ERR! gyp info it worked if it ends with ok npm ERR! gyp info using node-gyp@7.1.2 npm ERR! gyp info using node@18.18.2 | linux | x64 npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3" npm ERR! (node:2237) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only. npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created) npm ERR! gyp info spawn /usr/bin/python3 npm ERR! gyp info spawn args [ npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py', npm ERR! gyp info spawn args 'binding.gyp', npm ERR! gyp info spawn args '-f', npm ERR! gyp info spawn args 'make', npm ERR! gyp info spawn args '-I', npm ERR! gyp info spawn args '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/build/config.gypi', npm ERR! gyp info spawn args '-I', npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi', npm ERR! gyp info spawn args '-I', npm ERR! gyp info spawn args '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi', npm ERR! gyp info spawn args '-Dlibrary=shared_library', npm ERR! gyp info spawn args '-Dvisibility=default', npm ERR! gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2', npm ERR! gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp', npm ERR! gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib', npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble', npm ERR! gyp info spawn args '-Dnode_engine=v8', npm ERR! gyp info spawn args '--depth=.', npm ERR! gyp info spawn args '--no-parallel', npm ERR! gyp info spawn args '--generator-output', npm ERR! gyp info spawn args 'build', npm ERR! gyp info spawn args '-Goutput_dir=.' npm ERR! gyp info spawn args ] npm ERR! Traceback (most recent call last): npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module> npm ERR! sys.exit(gyp.script_main()) npm ERR! ^^^^^^^^^^^^^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_main npm ERR! return main(sys.argv[1:]) npm ERR! ^^^^^^^^^^^^^^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in main npm ERR! return gyp_main(args) npm ERR! ^^^^^^^^^^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_main npm ERR! [generator, flat_list, targets, data] = Load( npm ERR! ^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Load npm ERR! result = gyp.input.Load( npm ERR! ^^^^^^^^^^^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Load npm ERR! LoadTargetBuildFile( npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFile npm ERR! build_file_data = LoadOneBuildFile( npm ERR! ^^^^^^^^^^^^^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFile npm ERR! build_file_contents = open(build_file_path, "rU").read() npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^ npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gyp npm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1 npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16) npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:517:28) npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:292:12) npm ERR! gyp ERR! System Linux 6.1.0-13-amd64 npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild" npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble npm ERR! gyp ERR! node -v v18.18.2 npm ERR! gyp ERR! node-gyp -v v7.1.2 npm ERR! gyp ERR! not ok npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-09T14_34_50_758Z-debug-0.log npm ERR! code 1 npm ERR! path /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble npm ERR! command failed npm ERR! command sh -c node-gyp-build npm ERR! gyp info it worked if it ends with ok npm ERR! gyp info using node-gyp@7.1.2 npm ERR! gyp info using node@18.18.2 | linux | x64 npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3" npm ERR! (node:2237) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only. npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created) npm ERR! gyp info spawn /usr/bin/python3 npm ERR! gyp info spawn args [ npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py', npm ERR! gyp info spawn args 'binding.gyp', npm ERR! gyp info spawn args '-f', npm ERR! gyp info spawn args 'make', npm ERR! gyp info spawn args '-I', npm ERR! gyp info spawn args '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/build/config.gypi', npm ERR! gyp info spawn args '-I', npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi', npm ERR! gyp info spawn args '-I', npm ERR! gyp info spawn args '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi', npm ERR! gyp info spawn args '-Dlibrary=shared_library', npm ERR! gyp info spawn args '-Dvisibility=default', npm ERR! gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2', npm ERR! gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp', npm ERR! gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib', npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble', npm ERR! gyp info spawn args '-Dnode_engine=v8', npm ERR! gyp info spawn args '--depth=.', npm ERR! gyp info spawn args '--no-parallel', npm ERR! gyp info spawn args '--generator-output', npm ERR! gyp info spawn args 'build', npm ERR! gyp info spawn args '-Goutput_dir=.' npm ERR! gyp info spawn args ] npm ERR! Traceback (most recent call last): npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module> npm ERR! sys.exit(gyp.script_main()) npm ERR! ^^^^^^^^^^^^^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_main npm ERR! return main(sys.argv[1:]) npm ERR! ^^^^^^^^^^^^^^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in main npm ERR! return gyp_main(args) npm ERR! ^^^^^^^^^^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_main npm ERR! [generator, flat_list, targets, data] = Load( npm ERR! ^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Load npm ERR! result = gyp.input.Load( npm ERR! ^^^^^^^^^^^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Load npm ERR! LoadTargetBuildFile( npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFile npm ERR! build_file_data = LoadOneBuildFile( npm ERR! ^^^^^^^^^^^^^^^^^ npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFile npm ERR! build_file_contents = open(build_file_path, "rU").read() npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^ npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gyp npm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1 npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16) npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:517:28) npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:292:12) npm ERR! gyp ERR! System Linux 6.1.0-13-amd64 npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild" npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble npm ERR! gyp ERR! node -v v18.18.2 npm ERR! gyp ERR! node-gyp -v v7.1.2 npm ERR! gyp ERR! not ok npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-09T14_34_50_758Z-debug-0.log host.ioBrokerVM Cannot install iobroker.ble@0.13.4: 1 idash@ioBrokerVM:~$@gismoh zeig mal die Ausgabe
iob diag
von beiden Systemen, Raspberry und Vm -
mal sehen
was machst du denn jetzt schon wieder?
der
iob fixist doch gar nicht durchgelaufen! -
Laut deinem Link ist doch dieser Befehl im iob fix enthalten?Das ganze ist ab sofort im ioBroker Fixer inkludiert, daher sollte unter Linux iob fix reichen!!dies wurde oben bereits getätigt
und brach ab mit isnotempty
@crunchip
neue VM (vor erneutem iob fix)======== Start marking the full check here ========= Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: ioBrokerVM Icon name: computer-vm Chassis: vm 🖴 Virtualization: kvm Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.1.0-13-amd64 Architecture: x86-64 Hardware Vendor: QEMU Hardware Model: Standard PC _i440FX + PIIX, 1996_ Firmware Version: rel-1.16.2-0-gea1b7a073390-prebuilt.qemu.org model name : QEMU Virtual CPU version 2.5+ Docker : false Virtualization : kvm Kernel : x86_64 Userland : amd64 Systemuptime and Load: 15:40:50 up 1:05, 2 users, load average: 0.16, 0.04, 0.01 CPU threads: 2 *** Time and Time Zones *** Local time: Thu 2023-11-09 15:40:50 CET Universal time: Thu 2023-11-09 14:40:50 UTC RTC time: Thu 2023-11-09 14:40:50 Time zone: Europe/Berlin (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** idash /home/idash idash adm dialout sudo plugdev users input netdev iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 4.1G 384M 3.4G 507K 574M 3.7G Swap: 1.0G 0B 1.0G Total: 5.1G 384M 4.4G 3915 M total memory 367 M used memory 222 M active memory 251 M inactive memory 3248 M free memory 67 M buffer memory 480 M swap cache 974 M total swap 0 M used swap 974 M free swap *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * iobroker.service loaded failed failed ioBroker Server LOAD = Reflects whether the unit definition was properly loaded. ACTIVE = The high-level unit activation state, i.e. generalization of SUB. SUB = The low-level unit activation state, values depend on unit type. 1 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 1.9G 0 1.9G 0% /dev tmpfs tmpfs 392M 500K 392M 1% /run /dev/sda1 ext4 31G 3.6G 26G 13% / tmpfs tmpfs 2.0G 0 2.0G 0% /dev/shm tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs tmpfs 392M 0 392M 0% /run/user/1002 Messages concerning ext4 filesystem in dmesg: [Thu Nov 9 14:35:44 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none. [Thu Nov 9 14:35:45 2023] EXT4-fs (sda1): re-mounted. Quota mode: none. Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/sda1 ext4 rw,relatime,errors=remount-ro Files in neuralgic directories: /var: 455M /var/ 248M /var/cache 240M /var/cache/apt 169M /var/lib 164M /var/cache/apt/archives Archived and active journals take up 24.0M in the file system. /opt/iobroker/backups: 5.8M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 189M /opt/iobroker/iobroker-data/ 157M /opt/iobroker/iobroker-data/files 52M /opt/iobroker/iobroker-data/files/javascript.admin 34M /opt/iobroker/iobroker-data/files/javascript.admin/static 33M /opt/iobroker/iobroker-data/files/javascript.admin/static/js The five largest files in iobroker-data are: 27M /opt/iobroker/iobroker-data/objects.jsonl 19M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map 8.2M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js 7.2M /opt/iobroker/iobroker-data/files/ham.admin/static/js/main.8080bc0b.js.map 7.1M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map find: '/dev/serial/by-id/': No such file or directory USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': *** NodeJS-Installation *** /usr/bin/nodejs v18.18.2 /usr/bin/node v18.18.2 /usr/bin/npm 9.8.1 /usr/bin/npx 9.8.1 /usr/bin/corepack 0.19.0 nodejs: Installed: 18.18.2-1nodesource1 Candidate: 18.18.2-1nodesource1 Version table: *** 18.18.2-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 18.18.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.18.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.17.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.17.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.16.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.16.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.15.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.2-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.13.0+dfsg1-1 500 500 http://deb.debian.org/debian bookworm/main amd64 Packages 18.13.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.12.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.11.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.10.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.9.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.9.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.8.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.7.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.6.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.5.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.4.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.3.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.2.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.1.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.0.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status iobroker is not running on this host. Objects type: jsonl States type: jsonl Core adapters versions js-controller: 5.0.12 admin: 6.8.0 javascript: 7.1.4 Adapters from github: 0 Adapter State system.adapter.admin.0 : admin : ioBrokerVM - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin system.adapter.alarm.0 : alarm : ioBrokerVM - disabled system.adapter.alexa2.0 : alexa2 : ioBrokerVM - disabled system.adapter.backitup.0 : backitup : ioBrokerVM - enabled system.adapter.daikin-cloud.0 : daikin-cloud : ioBrokerVM - disabled system.adapter.daswetter.0 : daswetter : ioBrokerVM - disabled system.adapter.deconz.0 : deconz : ioBrokerVM - disabled, port: 8090 system.adapter.device-reminder.0 : device-reminder : ioBrokerVM - disabled system.adapter.discovery.0 : discovery : ioBrokerVM - disabled system.adapter.ecovacs-deebot.0 : ecovacs-deebot : ioBrokerVM - disabled system.adapter.enigma2.0 : enigma2 : ioBrokerVM - disabled system.adapter.fb-checkpresence.0 : fb-checkpresence : ioBrokerVM - disabled system.adapter.fiat.0 : fiat : ioBrokerVM - disabled system.adapter.flot.0 : flot : ioBrokerVM - disabled system.adapter.fullybrowser.0 : fullybrowser : ioBrokerVM - disabled system.adapter.go-e.0 : go-e : ioBrokerVM - disabled system.adapter.go-e.1 : go-e : ioBrokerVM - disabled system.adapter.ham.0 : ham : ioBrokerVM - disabled system.adapter.harmony.0 : harmony : ioBrokerVM - disabled system.adapter.hue-extended.0 : hue-extended : ioBrokerVM - disabled system.adapter.hue.0 : hue : ioBrokerVM - disabled, port: 443 system.adapter.icons-mfd-svg.0 : icons-mfd-svg : ioBrokerVM - disabled system.adapter.influxdb.0 : influxdb : ioBrokerVM - disabled, port: 8086 system.adapter.info.0 : info : ioBrokerVM - disabled system.adapter.iot.0 : iot : ioBrokerVM - disabled system.adapter.javascript.0 : javascript : ioBrokerVM - disabled system.adapter.meross.0 : meross : ioBrokerVM - disabled system.adapter.mihome-vacuum.0 : mihome-vacuum : ioBrokerVM - disabled, port: 54321 system.adapter.mihome-vacuum.2 : mihome-vacuum : ioBrokerVM - disabled, port: 54321 system.adapter.mobile.0 : mobile : ioBrokerVM - disabled system.adapter.openweathermap.0 : openweathermap : ioBrokerVM - disabled system.adapter.pi-hole.0 : pi-hole : ioBrokerVM - disabled system.adapter.pushover.0 : pushover : ioBrokerVM - disabled system.adapter.pvforecast.0 : pvforecast : ioBrokerVM - disabled system.adapter.radar2.0 : radar2 : ioBrokerVM - disabled system.adapter.shelly.0 : shelly : ioBrokerVM - disabled, port: 1882, bind: 0.0.0.0 system.adapter.shelly.1 : shelly : ioBrokerVM - disabled, port: 1882, bind: 0.0.0.0 system.adapter.smartcontrol.0 : smartcontrol : ioBrokerVM - disabled system.adapter.socketio.0 : socketio : ioBrokerVM - disabled, port: 8084, bind: 0.0.0.0, run as: admin system.adapter.sonoff.0 : sonoff : ioBrokerVM - disabled, port: 1883, bind: 0.0.0.0 system.adapter.tado.0 : tado : ioBrokerVM - disabled system.adapter.telegram.0 : telegram : ioBrokerVM - disabled, port: 8443, bind: 0.0.0.0 system.adapter.tibberlink.0 : tibberlink : ioBrokerVM - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : ioBrokerVM - disabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : ioBrokerVM - disabled system.adapter.vis-material-advanced.0 : vis-material-advanced : ioBrokerVM - disabled system.adapter.vis-metro.0 : vis-metro : ioBrokerVM - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : ioBrokerVM - disabled system.adapter.vis.0 : vis : ioBrokerVM - disabled system.adapter.weatherunderground.0 : weatherunderground : ioBrokerVM - disabled system.adapter.web.0 : web : ioBrokerVM - disabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.worx.0 : worx : ioBrokerVM - disabled + instance is alive Enabled adapters with bindings system.adapter.admin.0 : admin : ioBrokerVM - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin ioBroker-Repositories Stable (default): http://iobroker.live/repo/sources-dist.json Beta (latest) : http://download.iobroker.net/sources-dist-latest.json Active repo(s): Stable (default) Installed ioBroker-Instances Used repository: Stable (default) Adapter "admin" : 6.12.0 , installed 6.8.0 [Updatable] Adapter "alarm" : 3.4.0 , installed 3.3.13 [Updatable] Adapter "alexa2" : 3.25.2 , installed 3.23.2 [Updatable] Adapter "backitup" : 2.8.7 , installed 2.8.1 [Updatable] Adapter "daikin-cloud" : 0.3.0 , installed 0.3.0 Adapter "daswetter" : 3.1.10 , installed 3.1.10 Adapter "deconz" : 1.3.21 , installed 1.3.21 Adapter "device-reminder": 3.0.0 , installed 1.2.9 [Updatable] Adapter "discovery" : 3.1.0 , installed 3.1.0 Adapter "ecovacs-deebot": 1.4.13 , installed 1.4.13 Adapter "fb-checkpresence": 1.2.2 , installed 1.2.2 Adapter "fiat" : 0.0.8 , installed 0.0.8 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "fullybrowser" : 2.2.0 , installed 2.1.2 [Updatable] Adapter "go-e" : 1.0.27 , installed 1.0.27 Adapter "ham" : 5.3.1 , installed 5.3.1 Adapter "harmony" : 1.2.2 , installed 1.2.2 Adapter "hue" : 3.10.1 , installed 3.10.0 [Updatable] Adapter "hue-extended" : 2.0.0 , installed 2.0.0 Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0 Adapter "influxdb" : 3.2.0 , installed 3.2.0 Adapter "info" : 2.0.0 , installed 2.0.0 Adapter "iot" : 1.14.5 , installed 1.14.5 Adapter "javascript" : 7.1.4 , installed 7.1.4 Controller "js-controller": 5.0.12 , installed 5.0.12 Adapter "meross" : 1.15.1 , installed 1.15.1 Adapter "mihome-vacuum": 4.0.0 , installed 4.0.0 Adapter "mobile" : 1.0.1 , installed 1.0.1 Adapter "openweathermap": 0.3.9 , installed 0.3.9 Adapter "pi-hole" : 1.3.6 , installed 1.3.6 Adapter "pushover" : 3.0.3 , installed 3.0.3 Adapter "pvforecast" : 2.9.0 , installed 2.8.1 [Updatable] Adapter "radar2" : 2.0.8 , installed 2.0.7 [Updatable] Adapter "shelly" : 6.6.1 , installed 6.4.1 [Updatable] Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "smartcontrol" : 2.0.1 , installed 2.0.1 Copy text starting here: ======================= SUMMARY ======================= v.2023-10-10 Static hostname: ioBrokerVM Icon name: computer-vm Chassis: vm 🖴 Virtualization: kvm Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.1.0-13-amd64 Architecture: x86-64 Hardware Vendor: QEMU Hardware Model: Standard PC _i440FX + PIIX, 1996_ Firmware Version: rel-1.16.2-0-gea1b7a073390-prebuilt.qemu.org Installation: kvm Kernel: x86_64 Userland: amd64 Timezone: Europe/Berlin (CET, +0100) User-ID: 1002 X-Server: false Boot Target: graphical.target Pending OS-Updates: 0 Pending iob updates: 16 Nodejs-Installation: /usr/bin/nodejs v18.18.2 /usr/bin/node v18.18.2 /usr/bin/npm 9.8.1 /usr/bin/npx 9.8.1 /usr/bin/corepack 0.19.0 Recommended versions are nodejs 18.18.2 and npm 9.8.1 Your nodejs installation is correct MEMORY: total used free shared buff/cache available Mem: 4.1G 418M 3.4G 512K 590M 3.7G Swap: 1.0G 0B 1.0G Total: 5.1G 418M 4.4G Active iob-Instances: 1 Active repo(s): Stable (default) ioBroker Core: js-controller 5.0.12 admin 6.8.0 ioBroker Status: iobroker is not running on this host. Objects type: jsonl States type: jsonl Status admin and web instance: system.adapter.admin.0 : admin : ioBrokerVM - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin system.adapter.web.0 : web : ioBrokerVM - disabled, port: 8082, bind: 0.0.0.0, run as: admin Objects: 32918 States: 20853 Size of iob-Database: 35M /opt/iobroker/iobroker-data/objects.jsonl 4.9M /opt/iobroker/iobroker-data/states.jsonl =================== END OF SUMMARY ==================== === Mark text until here for copying === -
@crunchip
full ist unvollständig
wie kommen die ganzen Adapter da rein wenn das eine neue VM ist?
iob fix sieht für mich "normal" aus -sehe dort keine Fehlermeldung.
(gerade erneut gemacht)idash@ioBrokerVM:~$ iob stop idash@ioBrokerVM:~$ iob fix library: loaded Library version=2023-10-13 ========================================================================== Welcome to the ioBroker installation fixer! Script version: 2023-10-13 You might need to enter your password a couple of times. ========================================================================== ========================================================================== Installing prerequisites (1/5) ========================================================================== [sudo] Passwort für idash: OK:1 http://security.debian.org/debian-security bookworm-security InRelease OK:2 http://deb.debian.org/debian bookworm InRelease OK:3 http://deb.debian.org/debian bookworm-updates InRelease OK:4 https://deb.nodesource.com/node_18.x nodistro InRelease Paketlisten werden gelesen… Fertig ========================================================================== Checking ioBroker user and directory permissions (2/5) ========================================================================== Created /etc/sudoers.d/iobroker Fixing directory permissions... ========================================================================== Check and cleanup npm temporary directories (3/5) ========================================================================== Done. ========================================================================== Database maintenance (4/5) ========================================================================== Checking for uncompressed JSONL databases... This might take a while! Compressing /opt/iobroker/iobroker-data/states.jsonl Compressing /opt/iobroker/iobroker-data/objects.jsonl Compressed 2 JSONL files. Done ========================================================================== Checking autostart (5/5) ========================================================================== Enabling autostart... Autostart enabled! ========================================================================== Your installation was fixed successfully Run iobroker start to start ioBroker again! ========================================================================== idash@ioBrokerVM:~$ iob start -
@crunchip
neue VM (vor erneutem iob fix)======== Start marking the full check here ========= Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: ioBrokerVM Icon name: computer-vm Chassis: vm 🖴 Virtualization: kvm Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.1.0-13-amd64 Architecture: x86-64 Hardware Vendor: QEMU Hardware Model: Standard PC _i440FX + PIIX, 1996_ Firmware Version: rel-1.16.2-0-gea1b7a073390-prebuilt.qemu.org model name : QEMU Virtual CPU version 2.5+ Docker : false Virtualization : kvm Kernel : x86_64 Userland : amd64 Systemuptime and Load: 15:40:50 up 1:05, 2 users, load average: 0.16, 0.04, 0.01 CPU threads: 2 *** Time and Time Zones *** Local time: Thu 2023-11-09 15:40:50 CET Universal time: Thu 2023-11-09 14:40:50 UTC RTC time: Thu 2023-11-09 14:40:50 Time zone: Europe/Berlin (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** idash /home/idash idash adm dialout sudo plugdev users input netdev iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 4.1G 384M 3.4G 507K 574M 3.7G Swap: 1.0G 0B 1.0G Total: 5.1G 384M 4.4G 3915 M total memory 367 M used memory 222 M active memory 251 M inactive memory 3248 M free memory 67 M buffer memory 480 M swap cache 974 M total swap 0 M used swap 974 M free swap *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * iobroker.service loaded failed failed ioBroker Server LOAD = Reflects whether the unit definition was properly loaded. ACTIVE = The high-level unit activation state, i.e. generalization of SUB. SUB = The low-level unit activation state, values depend on unit type. 1 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 1.9G 0 1.9G 0% /dev tmpfs tmpfs 392M 500K 392M 1% /run /dev/sda1 ext4 31G 3.6G 26G 13% / tmpfs tmpfs 2.0G 0 2.0G 0% /dev/shm tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs tmpfs 392M 0 392M 0% /run/user/1002 Messages concerning ext4 filesystem in dmesg: [Thu Nov 9 14:35:44 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none. [Thu Nov 9 14:35:45 2023] EXT4-fs (sda1): re-mounted. Quota mode: none. Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/sda1 ext4 rw,relatime,errors=remount-ro Files in neuralgic directories: /var: 455M /var/ 248M /var/cache 240M /var/cache/apt 169M /var/lib 164M /var/cache/apt/archives Archived and active journals take up 24.0M in the file system. /opt/iobroker/backups: 5.8M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 189M /opt/iobroker/iobroker-data/ 157M /opt/iobroker/iobroker-data/files 52M /opt/iobroker/iobroker-data/files/javascript.admin 34M /opt/iobroker/iobroker-data/files/javascript.admin/static 33M /opt/iobroker/iobroker-data/files/javascript.admin/static/js The five largest files in iobroker-data are: 27M /opt/iobroker/iobroker-data/objects.jsonl 19M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map 8.2M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js 7.2M /opt/iobroker/iobroker-data/files/ham.admin/static/js/main.8080bc0b.js.map 7.1M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map find: '/dev/serial/by-id/': No such file or directory USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': *** NodeJS-Installation *** /usr/bin/nodejs v18.18.2 /usr/bin/node v18.18.2 /usr/bin/npm 9.8.1 /usr/bin/npx 9.8.1 /usr/bin/corepack 0.19.0 nodejs: Installed: 18.18.2-1nodesource1 Candidate: 18.18.2-1nodesource1 Version table: *** 18.18.2-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 18.18.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.18.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.17.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.17.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.16.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.16.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.15.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.2-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.13.0+dfsg1-1 500 500 http://deb.debian.org/debian bookworm/main amd64 Packages 18.13.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.12.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.11.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.10.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.9.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.9.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.8.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.7.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.6.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.5.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.4.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.3.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.2.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.1.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.0.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status iobroker is not running on this host. Objects type: jsonl States type: jsonl Core adapters versions js-controller: 5.0.12 admin: 6.8.0 javascript: 7.1.4 Adapters from github: 0 Adapter State system.adapter.admin.0 : admin : ioBrokerVM - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin system.adapter.alarm.0 : alarm : ioBrokerVM - disabled system.adapter.alexa2.0 : alexa2 : ioBrokerVM - disabled system.adapter.backitup.0 : backitup : ioBrokerVM - enabled system.adapter.daikin-cloud.0 : daikin-cloud : ioBrokerVM - disabled system.adapter.daswetter.0 : daswetter : ioBrokerVM - disabled system.adapter.deconz.0 : deconz : ioBrokerVM - disabled, port: 8090 system.adapter.device-reminder.0 : device-reminder : ioBrokerVM - disabled system.adapter.discovery.0 : discovery : ioBrokerVM - disabled system.adapter.ecovacs-deebot.0 : ecovacs-deebot : ioBrokerVM - disabled system.adapter.enigma2.0 : enigma2 : ioBrokerVM - disabled system.adapter.fb-checkpresence.0 : fb-checkpresence : ioBrokerVM - disabled system.adapter.fiat.0 : fiat : ioBrokerVM - disabled system.adapter.flot.0 : flot : ioBrokerVM - disabled system.adapter.fullybrowser.0 : fullybrowser : ioBrokerVM - disabled system.adapter.go-e.0 : go-e : ioBrokerVM - disabled system.adapter.go-e.1 : go-e : ioBrokerVM - disabled system.adapter.ham.0 : ham : ioBrokerVM - disabled system.adapter.harmony.0 : harmony : ioBrokerVM - disabled system.adapter.hue-extended.0 : hue-extended : ioBrokerVM - disabled system.adapter.hue.0 : hue : ioBrokerVM - disabled, port: 443 system.adapter.icons-mfd-svg.0 : icons-mfd-svg : ioBrokerVM - disabled system.adapter.influxdb.0 : influxdb : ioBrokerVM - disabled, port: 8086 system.adapter.info.0 : info : ioBrokerVM - disabled system.adapter.iot.0 : iot : ioBrokerVM - disabled system.adapter.javascript.0 : javascript : ioBrokerVM - disabled system.adapter.meross.0 : meross : ioBrokerVM - disabled system.adapter.mihome-vacuum.0 : mihome-vacuum : ioBrokerVM - disabled, port: 54321 system.adapter.mihome-vacuum.2 : mihome-vacuum : ioBrokerVM - disabled, port: 54321 system.adapter.mobile.0 : mobile : ioBrokerVM - disabled system.adapter.openweathermap.0 : openweathermap : ioBrokerVM - disabled system.adapter.pi-hole.0 : pi-hole : ioBrokerVM - disabled system.adapter.pushover.0 : pushover : ioBrokerVM - disabled system.adapter.pvforecast.0 : pvforecast : ioBrokerVM - disabled system.adapter.radar2.0 : radar2 : ioBrokerVM - disabled system.adapter.shelly.0 : shelly : ioBrokerVM - disabled, port: 1882, bind: 0.0.0.0 system.adapter.shelly.1 : shelly : ioBrokerVM - disabled, port: 1882, bind: 0.0.0.0 system.adapter.smartcontrol.0 : smartcontrol : ioBrokerVM - disabled system.adapter.socketio.0 : socketio : ioBrokerVM - disabled, port: 8084, bind: 0.0.0.0, run as: admin system.adapter.sonoff.0 : sonoff : ioBrokerVM - disabled, port: 1883, bind: 0.0.0.0 system.adapter.tado.0 : tado : ioBrokerVM - disabled system.adapter.telegram.0 : telegram : ioBrokerVM - disabled, port: 8443, bind: 0.0.0.0 system.adapter.tibberlink.0 : tibberlink : ioBrokerVM - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : ioBrokerVM - disabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : ioBrokerVM - disabled system.adapter.vis-material-advanced.0 : vis-material-advanced : ioBrokerVM - disabled system.adapter.vis-metro.0 : vis-metro : ioBrokerVM - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : ioBrokerVM - disabled system.adapter.vis.0 : vis : ioBrokerVM - disabled system.adapter.weatherunderground.0 : weatherunderground : ioBrokerVM - disabled system.adapter.web.0 : web : ioBrokerVM - disabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.worx.0 : worx : ioBrokerVM - disabled + instance is alive Enabled adapters with bindings system.adapter.admin.0 : admin : ioBrokerVM - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin ioBroker-Repositories Stable (default): http://iobroker.live/repo/sources-dist.json Beta (latest) : http://download.iobroker.net/sources-dist-latest.json Active repo(s): Stable (default) Installed ioBroker-Instances Used repository: Stable (default) Adapter "admin" : 6.12.0 , installed 6.8.0 [Updatable] Adapter "alarm" : 3.4.0 , installed 3.3.13 [Updatable] Adapter "alexa2" : 3.25.2 , installed 3.23.2 [Updatable] Adapter "backitup" : 2.8.7 , installed 2.8.1 [Updatable] Adapter "daikin-cloud" : 0.3.0 , installed 0.3.0 Adapter "daswetter" : 3.1.10 , installed 3.1.10 Adapter "deconz" : 1.3.21 , installed 1.3.21 Adapter "device-reminder": 3.0.0 , installed 1.2.9 [Updatable] Adapter "discovery" : 3.1.0 , installed 3.1.0 Adapter "ecovacs-deebot": 1.4.13 , installed 1.4.13 Adapter "fb-checkpresence": 1.2.2 , installed 1.2.2 Adapter "fiat" : 0.0.8 , installed 0.0.8 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "fullybrowser" : 2.2.0 , installed 2.1.2 [Updatable] Adapter "go-e" : 1.0.27 , installed 1.0.27 Adapter "ham" : 5.3.1 , installed 5.3.1 Adapter "harmony" : 1.2.2 , installed 1.2.2 Adapter "hue" : 3.10.1 , installed 3.10.0 [Updatable] Adapter "hue-extended" : 2.0.0 , installed 2.0.0 Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0 Adapter "influxdb" : 3.2.0 , installed 3.2.0 Adapter "info" : 2.0.0 , installed 2.0.0 Adapter "iot" : 1.14.5 , installed 1.14.5 Adapter "javascript" : 7.1.4 , installed 7.1.4 Controller "js-controller": 5.0.12 , installed 5.0.12 Adapter "meross" : 1.15.1 , installed 1.15.1 Adapter "mihome-vacuum": 4.0.0 , installed 4.0.0 Adapter "mobile" : 1.0.1 , installed 1.0.1 Adapter "openweathermap": 0.3.9 , installed 0.3.9 Adapter "pi-hole" : 1.3.6 , installed 1.3.6 Adapter "pushover" : 3.0.3 , installed 3.0.3 Adapter "pvforecast" : 2.9.0 , installed 2.8.1 [Updatable] Adapter "radar2" : 2.0.8 , installed 2.0.7 [Updatable] Adapter "shelly" : 6.6.1 , installed 6.4.1 [Updatable] Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "smartcontrol" : 2.0.1 , installed 2.0.1 Copy text starting here: ======================= SUMMARY ======================= v.2023-10-10 Static hostname: ioBrokerVM Icon name: computer-vm Chassis: vm 🖴 Virtualization: kvm Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.1.0-13-amd64 Architecture: x86-64 Hardware Vendor: QEMU Hardware Model: Standard PC _i440FX + PIIX, 1996_ Firmware Version: rel-1.16.2-0-gea1b7a073390-prebuilt.qemu.org Installation: kvm Kernel: x86_64 Userland: amd64 Timezone: Europe/Berlin (CET, +0100) User-ID: 1002 X-Server: false Boot Target: graphical.target Pending OS-Updates: 0 Pending iob updates: 16 Nodejs-Installation: /usr/bin/nodejs v18.18.2 /usr/bin/node v18.18.2 /usr/bin/npm 9.8.1 /usr/bin/npx 9.8.1 /usr/bin/corepack 0.19.0 Recommended versions are nodejs 18.18.2 and npm 9.8.1 Your nodejs installation is correct MEMORY: total used free shared buff/cache available Mem: 4.1G 418M 3.4G 512K 590M 3.7G Swap: 1.0G 0B 1.0G Total: 5.1G 418M 4.4G Active iob-Instances: 1 Active repo(s): Stable (default) ioBroker Core: js-controller 5.0.12 admin 6.8.0 ioBroker Status: iobroker is not running on this host. Objects type: jsonl States type: jsonl Status admin and web instance: system.adapter.admin.0 : admin : ioBrokerVM - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin system.adapter.web.0 : web : ioBrokerVM - disabled, port: 8082, bind: 0.0.0.0, run as: admin Objects: 32918 States: 20853 Size of iob-Database: 35M /opt/iobroker/iobroker-data/objects.jsonl 4.9M /opt/iobroker/iobroker-data/states.jsonl =================== END OF SUMMARY ==================== === Mark text until here for copying ===@gismoh sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
Fährst du noch all diese alten versionen auf dem alten System?
Edit
Vllt mal dein altes system auf stand bringen.
Update's..
iob fix
Und dann ein backup ziehen
Und dann die Ausgabe von iob diag nochmal -
Edit
Update's..
iob fix
Und dann die Ausgabe von iob diag nochmal@crunchip
okay - werd ich versuchen.
hatte die alte maschine nicht mehr weiter geupdated, da ich vor kurzer Zeit mal den Admin geupdatet hatte, und dann iob "Tot" war, ich also keinen zugriff mehr hatte. Aber in der Zwischenzeit bin ich dort auf Bullseye hoch gegangen.Werd ich mich also nachher noch mal ranmachen ;)
@crunchip
Das zeigt dir dann auch der diag an
@crunchip
Mist - vorhin aufgefallen, der iobroker im Docker läuft noch auf Buster.
War mir sicher, das ich geupdatet hätte .... hatte wohl nur den Pi an sich auf Bullseye gebracht aber nicht den iobroker-container
Hoffe das klappt auch.
Zumindest habe ich den ioBroker selber und den Adaptern nun updates verpasst. -
das Ergebnis vom (alten) Pi:
Copy text starting here: ======================= SUMMARY ======================= v.2023-10-10 /home/iobroker/.diag.sh: line 457: hostnamectl: command not found Installation: Kernel: armv7l Userland: armhf /home/iobroker/.diag.sh: line 466: timedatectl: command not found Timezone: User-ID: 1001 X-Server: false /home/iobroker/.diag.sh: line 473: systemctl: command not found Boot Target: Pending OS-Updates: 60 error: failed switching to "iobroker": operation not permitted Pending iob updates: 0 Nodejs-Installation: /usr/bin/nodejs v18.17.1 /usr/bin/node v18.17.1 /usr/bin/npm 9.6.7 /usr/bin/npx 9.6.7 /usr/bin/corepack 0.18.0 Recommended versions are nodejs and npm Your nodejs installation is correct MEMORY: total used free shared buff/cache available Mem: 7.9G 1.9G 4.9G 1.0M 1.1G 5.8G Swap: 99M 0B 99M Total: 8.0G 1.9G 5.0G error: failed switching to "iobroker": operation not permitted Active iob-Instances: 0 error: failed switching to "iobroker": operation not permitted error: failed switching to "iobroker": operation not permitted ioBroker Core: js-controller error: failed switching to "iobroker": operation not permitted admin error: failed switching to "iobroker": operation not permitted ioBroker Status: Status admin and web instance: error: failed switching to "iobroker": operation not permitted Objects: 0 States: 0 Size of iob-Database: 40M /opt/iobroker/iobroker-data/objects.jsonl 17M /opt/iobroker/iobroker-data/objects.json.migrated 17M /opt/iobroker/iobroker-data/objects.json.bak.migrated 16K /opt/iobroker/iobroker-data/objects.json.old 31M /opt/iobroker/iobroker-data/states.jsonl 2.3M /opt/iobroker/iobroker-data/states.json.migrated 2.3M /opt/iobroker/iobroker-data/states.json.bak.migrated 2.0M /opt/iobroker/iobroker-data/states.json.old =================== END OF SUMMARY ==================== === Mark text until here for copying === -
Copy text starting here: ======================= SUMMARY ======================= v.2023-10-10 /home/iobroker/.diag.sh: line 457: hostnamectl: command not found Installation: Kernel: armv7l Userland: armhf /home/iobroker/.diag.sh: line 466: timedatectl: command not found Timezone: User-ID: 1001 X-Server: false /home/iobroker/.diag.sh: line 473: systemctl: command not found Boot Target: Pending OS-Updates: 60 error: failed switching to "iobroker": operation not permitted Pending iob updates: 0 Nodejs-Installation: /usr/bin/nodejs v18.17.1 /usr/bin/node v18.17.1 /usr/bin/npm 9.6.7 /usr/bin/npx 9.6.7 /usr/bin/corepack 0.18.0 Recommended versions are nodejs and npm Your nodejs installation is correct MEMORY: total used free shared buff/cache available Mem: 7.9G 1.9G 4.9G 1.0M 1.1G 5.8G Swap: 99M 0B 99M Total: 8.0G 1.9G 5.0G error: failed switching to "iobroker": operation not permitted Active iob-Instances: 0 error: failed switching to "iobroker": operation not permitted error: failed switching to "iobroker": operation not permitted ioBroker Core: js-controller error: failed switching to "iobroker": operation not permitted admin error: failed switching to "iobroker": operation not permitted ioBroker Status: Status admin and web instance: error: failed switching to "iobroker": operation not permitted Objects: 0 States: 0 Size of iob-Database: 40M /opt/iobroker/iobroker-data/objects.jsonl 17M /opt/iobroker/iobroker-data/objects.json.migrated 17M /opt/iobroker/iobroker-data/objects.json.bak.migrated 16K /opt/iobroker/iobroker-data/objects.json.old 31M /opt/iobroker/iobroker-data/states.jsonl 2.3M /opt/iobroker/iobroker-data/states.json.migrated 2.3M /opt/iobroker/iobroker-data/states.json.bak.migrated 2.0M /opt/iobroker/iobroker-data/states.json.old =================== END OF SUMMARY ==================== === Mark text until here for copying ===Der muss aber sehr alt sein, wenn die Kommandos da gar nicht funktionieren.
leider, ich gelobe Besserung.
Hatte wohl meist nur die iob updates gemacht -.-bei
sudo apt updatespuckt er mir direkt eine Fehlermeldung wegen eines key´s raus.
idash@raspberrypi:/opt/iobroker$ sudo apt update [sudo] password for idash: Hit:1 http://security.debian.org/debian-security buster/updates InRelease Hit:2 http://deb.debian.org/debian buster InRelease Hit:3 http://deb.debian.org/debian buster-updates InRelease Get:4 https://repos.influxdata.com/debian buster InRelease [7.047 B] Get:5 https://deb.nodesource.com/node_18.x buster InRelease [4.584 B] Err:4 https://repos.influxdata.com/debian buster InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E Fetched 11,6 kB in 2s (5.507 B/s) Reading package lists... Done Building dependency tree Reading state information... Done 60 packages can be upgraded. Run 'apt list --upgradable' to see them. W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E W: Some index files failed to download. They have been ignored, or old ones used instead. idash@raspberrypi:/opt/iobroker$Daher ersteinmal nicht weiter gemacht.
