  3. Einsteigerfragen
  4. ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme
    6.7k
267 Beiträge 8 Kommentatoren 63.7k Aufrufe 8 Beobachtet
  • G Gismoh
    @crunchip
    nach
    iob logs --watch
    ist ioBroker seit über 20 min mit der Backup-Einspielung durch.
    Habe nun auch direkt wieder einen "Nicht root" User angelegt ;)
    Gismoh
    #133
    idash@ioBrokerVM:~$ iobroker add ble@0.13.4 --debug
    NPM version: 9.8.1
    Installing iobroker.ble@0.13.4... (System call)
    npm ERR! code 1
    npm ERR! path /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble
    npm ERR! command failed
    npm ERR! command sh -c node-gyp-build
    npm ERR! gyp info it worked if it ends with ok
    npm ERR! gyp info using node-gyp@7.1.2
    npm ERR! gyp info using node@18.18.2 | linux | x64
    npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
    npm ERR! (node:2880) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
    npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)
    npm ERR! gyp info spawn /usr/bin/python3
    npm ERR! gyp info spawn args [
    npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
    npm ERR! gyp info spawn args   'binding.gyp',
    npm ERR! gyp info spawn args   '-f',
    npm ERR! gyp info spawn args   'make',
    npm ERR! gyp info spawn args   '-I',
    npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/build/config.gypi',
    npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
    npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi',
    npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
    npm ERR! gyp info spawn args   '-Dvisibility=default',
    npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2',
    npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
    npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib',
    npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble',
    npm ERR! gyp info spawn args   '-Dnode_engine=v8',
    npm ERR! gyp info spawn args   '--depth=.',
    npm ERR! gyp info spawn args   '--no-parallel',
    npm ERR! gyp info spawn args   '--generator-output',
    npm ERR! gyp info spawn args   'build',
    npm ERR! gyp info spawn args   '-Goutput_dir=.'
    npm ERR! gyp info spawn args ]
    npm ERR! Traceback (most recent call last):
    npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>
    npm ERR!     sys.exit(gyp.script_main())
    npm ERR!              ^^^^^^^^^^^^^^^^^
    npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_main
    npm ERR!     return main(sys.argv[1:])
    npm ERR!            ^^^^^^^^^^^^^^^^^^
    npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in main
    npm ERR!     return gyp_main(args)
    npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_main
    npm ERR!     [generator, flat_list, targets, data] = Load(
    npm ERR!                                             ^^^^^
    npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Load
    npm ERR!     result = gyp.input.Load(
    npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Load
    npm ERR!     LoadTargetBuildFile(
    npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFile
    npm ERR!     build_file_data = LoadOneBuildFile(
    npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFile
    npm ERR!     build_file_contents = open(build_file_path, "rU").read()
    npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^
    npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gyp
    npm ERR! gyp ERR! configure error
    npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1
    npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)
    npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:517:28)
    npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:292:12)
    npm ERR! gyp ERR! System Linux 6.1.0-13-amd64
    npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble
    npm ERR! gyp ERR! node -v v18.18.2
    npm ERR! gyp ERR! node-gyp -v v7.1.2
    npm ERR! gyp ERR! not ok
    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-09T10_08_33_310Z-debug-0.log
    npm ERR! code 1
    npm ERR!                                             ^^^^^
    host.ioBrokerVM Cannot install iobroker.ble@0.13.4: 1
    idash@ioBrokerVM:~$
    ioBroker auf: Lenovo ThinkCentre M910Q Tiny i5-7500T 16 GB mit proxmox in VM (Bookworm)
    • G Gismoh
      @crunchip
      Guten Morgen,
      kann ich gerne mache, mit einer "rest-Hoffnung".
      Allerdings sehe ich selber als Laie keinen großen unterschied zur Vorgehensweise von gestern,
      dort hatte ich ja auf dem alten System den ble entfernt -
      und auf dem neuen System den ble belassen. Leider wurde der bestehende ble auf dem neuen System mit dem Backup entfernt.
      Werde ich aber gerne ausprobieren, mache vorher noch einer Sicherung der jetzigen VM - für den Fall das evtl. jemand dort noch mal ansetzen mag -und kann ja nicht schaden.
      Spiele dann nun wieder die Sicherung von der Erstinstallation auf der neuen Maschine ein, wo ioBroker frisch installiert wurde, deinstalliere außer admin und backitup die Adapter und spiele dann das gestrige Backup von der alten Maschine (Raspi) ein, wo ich das ble deinstalliert hatte.
      Melde mich dann nach "Verzug" wieder ;)
      crunchipC Offline
      crunchipC Offline
      #134
      @gismoh sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
      welche Adapter?
      du sollst den iobroker frisch aufsetzen, nichts deinstallieren.
      vom alten iobroker ein backup machen, aber vorher den ble deinstallieren, damit dein backup ohne ble kommt und du anschließend diesen in deinem neuen iobroker frisch einpflegen kannst
      sonst schleifst du dein node-gyp Problem ja weiter mit
      G 1 Antwort Letzte Antwort
        welche Adapter?
        Gismoh
        schrieb am zuletzt editiert von Gismoh
        #135
        @crunchip
        Na, hatte noch einen adapter zum Test drin und eben discovery , welche ich vor dem backup gelöscht hatte.
        Habe es nun aber wieder frisch aufgesetzt.
        Und das Backup wird wieder eingespielt - die ohne ble (wie gestern).
        • G Gismoh
          @crunchip
          crunchipC Offline
          crunchipC Offline
          #136
          Ohne Adapter oder nur ohne Instanz?
            Gismoh
            #137
            @crunchip
            hatte beides deinstalliert also 1x unter Instanz, und 1x unter Adapter.
            Oder sollte ich nur eines von beiden rausnehmen?
            • G Gismoh
              @crunchip
              Gismoh
              #138
              iob logs --watch:
              2023-11-09 14:05:41.577  - info: host.ioBrokerVM iobroker npm-install: upload [4] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/simplemde.min.js lib/js/simplemde.min.js application/javascript
              2023-11-09 14:05:41.588  - info: host.ioBrokerVM iobroker npm-install: upload [3] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/systemInformation.js lib/js/systemInformation.js application/javascript
              2023-11-09 14:05:41.591  - info: host.ioBrokerVM iobroker npm-install: upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/updateAdapter.js lib/js/updateAdapter.js application/javascript
              2023-11-09 14:05:41.595  - info: host.ioBrokerVM iobroker npm-install: upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/tab_m.html tab_m.html text/html
              2023-11-09 14:05:41.598  - info: host.ioBrokerVM iobroker npm-install: upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/words.js words.js application/javascript
              2023-11-09 14:05:41.726  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.info created/updated
              2023-11-09 14:05:42.798  - info: host.ioBrokerVM iobroker npm-install: exit 0
              2023-11-09 14:05:43.798  - warn: host.ioBrokerVM startInstance cannot find adapter "iot@1.14.5". Try to install it... 1 attempt
              2023-11-09 14:05:43.799  - info: host.ioBrokerVM iobroker install iot@1.14.5 using installedFrom
              2023-11-09 14:05:45.448  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
              2023-11-09 14:05:45.449  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.iot@1.14.5... (System call)
              2023-11-09 14:05:56.266  - info: host.ioBrokerVM iobroker npm-install: added 82 packages in 11s
              2023-11-09 14:05:56.267  - info: host.ioBrokerVM iobroker npm-install: 124 packages are looking for funding
              2023-11-09 14:05:56.270  - info: host.ioBrokerVM iobroker npm-install:   run `npm fund` for details
              2023-11-09 14:05:56.298  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter iot@1.14.5
              2023-11-09 14:05:57.781  - info: host.ioBrokerVM iobroker npm-install: upload [132] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
              2023-11-09 14:06:02.982  - info: host.ioBrokerVM iobroker npm-install: upload [100] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Cold Water.937aad5fa21b0c20a856.svg static/media/Cold Water.937aad5fa21b0c20a856.svg image/svg+xml
              2023-11-09 14:06:03.012  - info: host.ioBrokerVM iobroker npm-install: upload [90] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Doorstep.10630b759b4867a10776.svg static/media/Doorstep.10630b759b4867a10776.svg image/svg+xml
              2023-11-09 14:06:03.038  - info: host.ioBrokerVM iobroker npm-install: upload [80] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Garage Doors.0c2a1cfca7ad1ea59625.svg static/media/Garage Doors.0c2a1cfca7ad1ea59625.svg image/svg+xml
              2023-11-09 14:06:03.065  - info: host.ioBrokerVM iobroker npm-install: upload [70] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Handle.3de1d1320fc3ce2f9712.svg static/media/Handle.3de1d1320fc3ce2f9712.svg image/svg+xml
              2023-11-09 14:06:03.091  - info: host.ioBrokerVM iobroker npm-install: upload [60] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Laundry Room.58da550dff0173676e02.svg static/media/Laundry Room.58da550dff0173676e02.svg image/svg+xml
              2023-11-09 14:06:03.118  - info: host.ioBrokerVM iobroker npm-install: upload [50] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Music.67bc6063cb601642fd74.svg static/media/Music.67bc6063cb601642fd74.svg image/svg+xml
              2023-11-09 14:06:03.145  - info: host.ioBrokerVM iobroker npm-install: upload [40] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Pump.a6035507cddbe7db5f6a.svg static/media/Pump.a6035507cddbe7db5f6a.svg image/svg+xml
              2023-11-09 14:06:03.173  - info: host.ioBrokerVM iobroker npm-install: upload [30] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/SmokeDetector.8222f77cb07030a409ee.svg static/media/SmokeDetector.8222f77cb07030a409ee.svg image/svg+xml
              2023-11-09 14:06:03.202  - info: host.ioBrokerVM iobroker npm-install: upload [20] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Temperature Sensors.75d805988a6b77b231d8.svg static/media/Temperature Sensors.75d805988a6b77b231d8.svg image/svg+xml
              2023-11-09 14:06:03.205  - info: host.ioBrokerVM iobroker npm-install: upload [19] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Terrace.d71d07d9290674f2ca20.svg static/media/Terrace.d71d07d9290674f2ca20.svg image/svg+xml
              2023-11-09 14:06:03.209  - info: host.ioBrokerVM iobroker npm-install: upload [18] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
              2023-11-09 14:06:03.212  - info: host.ioBrokerVM iobroker npm-install: upload [17] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Tv.4e9745a548e57bfac0c7.svg static/media/Tv.4e9745a548e57bfac0c7.svg image/svg+xml
              2023-11-09 14:06:03.216  - info: host.ioBrokerVM iobroker npm-install: upload [16] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Upstairs.441813e54e0daca0882d.svg static/media/Upstairs.441813e54e0daca0882d.svg image/svg+xml
              2023-11-09 14:06:03.219  - info: host.ioBrokerVM iobroker npm-install: upload [15] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml
              2023-11-09 14:06:03.222  - info: host.ioBrokerVM iobroker npm-install: upload [14] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Ventilation.c31761d86d67e245ac92.svg static/media/Ventilation.c31761d86d67e245ac92.svg image/svg+xml
              2023-11-09 14:06:03.226  - info: host.ioBrokerVM iobroker npm-install: upload [13] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Wardrobe.e8019970a2b51412cfdc.svg static/media/Wardrobe.e8019970a2b51412cfdc.svg image/svg+xml
              2023-11-09 14:06:03.230  - info: host.ioBrokerVM iobroker npm-install: upload [12] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Washing Machines.577f3acdb3cef002b523.svg static/media/Washing Machines.577f3acdb3cef002b523.svg image/svg+xml
              2023-11-09 14:06:03.234  - info: host.ioBrokerVM iobroker npm-install: upload [11] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Washroom.bfb54196f381f36de9d6.svg static/media/Washroom.bfb54196f381f36de9d6.svg image/svg+xml
              2023-11-09 14:06:03.239  - info: host.ioBrokerVM iobroker npm-install: upload [10] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Water Consumption.68891649591cc2434c5b.svg static/media/Water Consumption.68891649591cc2434c5b.svg image/svg+xml
              2023-11-09 14:06:03.242  - info: host.ioBrokerVM iobroker npm-install: upload [9] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Water Heater.7e4bb4d99a5213f24d08.svg static/media/Water Heater.7e4bb4d99a5213f24d08.svg image/svg+xml
              2023-11-09 14:06:03.246  - info: host.ioBrokerVM iobroker npm-install: upload [8] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Water.f50411984c5c24fa574d.svg static/media/Water.f50411984c5c24fa574d.svg image/svg+xml
              2023-11-09 14:06:03.250  - info: host.ioBrokerVM iobroker npm-install: upload [7] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Wc.83604dd2daafb67067dd.svg static/media/Wc.83604dd2daafb67067dd.svg image/svg+xml
              2023-11-09 14:06:03.253  - info: host.ioBrokerVM iobroker npm-install: upload [6] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Weather.e91dae647698d48365e3.svg static/media/Weather.e91dae647698d48365e3.svg image/svg+xml
              2023-11-09 14:06:03.257  - info: host.ioBrokerVM iobroker npm-install: upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Window.421664f57c35e5109aa2.svg static/media/Window.421664f57c35e5109aa2.svg image/svg+xml
              2023-11-09 14:06:03.260  - info: host.ioBrokerVM iobroker npm-install: upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Windscreen.6058448bf63f72dd5036.svg static/media/Windscreen.6058448bf63f72dd5036.svg image/svg+xml
              2023-11-09 14:06:03.263  - info: host.ioBrokerVM iobroker npm-install: upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
              2023-11-09 14:06:03.267  - info: host.ioBrokerVM iobroker npm-install: upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Workspace.97d73e419d966bfb6428.svg static/media/Workspace.97d73e419d966bfb6428.svg image/svg+xml
              2023-11-09 14:06:03.270  - info: host.ioBrokerVM iobroker npm-install: upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/names.3a7dae0bd6b8b03b280f.txt static/media/names.3a7dae0bd6b8b03b280f.txt text/plain
              2023-11-09 14:06:03.273  - info: host.ioBrokerVM iobroker npm-install: upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
              2023-11-09 14:06:03.402  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.iot created/updated
              2023-11-09 14:06:04.578  - info: host.ioBrokerVM iobroker npm-install: exit 0
              2023-11-09 14:06:05.579  - warn: host.ioBrokerVM startInstance cannot find adapter "mobile@1.0.1". Try to install it... 1 attempt
              2023-11-09 14:06:05.579  - info: host.ioBrokerVM iobroker install mobile@1.0.1 using installedFrom
              2023-11-09 14:06:07.137  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
              2023-11-09 14:06:07.138  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.mobile@1.0.1... (System call)
              2023-11-09 14:06:11.607  - info: host.ioBrokerVM iobroker npm-install: added 2 packages in 4s
              2023-11-09 14:06:11.608  - info: host.ioBrokerVM iobroker npm-install:
              2023-11-09 14:06:11.608  - info: host.ioBrokerVM iobroker npm-install: 124 packages are looking for funding
              2023-11-09 14:06:11.608  - info: host.ioBrokerVM iobroker npm-install:   run `npm fund` for details
              2023-11-09 14:06:11.629  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter mobile@1.0.1
              2023-11-09 14:06:11.635  - info: host.ioBrokerVM iobroker npm-install: upload [1] mobile.admin /opt/iobroker/node_modules/iobroker.mobile/admin/index.html index.html text/html
              2023-11-09 14:06:11.708  - info: host.ioBrokerVM iobroker npm-install: upload [0] mobile.admin /opt/iobroker/node_modules/iobroker.mobile/admin/mobile.png mobile.png image/png
              2023-11-09 14:06:11.749  - info: host.ioBrokerVM iobroker npm-install: upload [69] mobile /opt/iobroker/node_modules/iobroker.mobile/www/cache.manifest cache.manifest text/cache-manifest
              2023-11-09 14:06:11.780  - info: host.ioBrokerVM iobroker npm-install: upload [60] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/blind0.png img/blind0.png image/png
              2023-11-09 14:06:11.805  - info: host.ioBrokerVM iobroker npm-install: upload [50] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/blind90.png img/blind90.png image/png
              2023-11-09 14:06:11.830  - info: host.ioBrokerVM iobroker npm-install: upload [40] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/rgb-green.png img/rgb-green.png image/png
              2023-11-09 14:06:11.854  - info: host.ioBrokerVM iobroker npm-install: upload [30] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/windowClosed.png img/windowClosed.png image/png
              2023-11-09 14:06:11.880  - info: host.ioBrokerVM iobroker npm-install: upload [20] mobile /opt/iobroker/node_modules/iobroker.mobile/www/js/i18n/nl/translations.json js/i18n/nl/translations.json application/json
              2023-11-09 14:06:11.884  - info: host.ioBrokerVM iobroker npm-install: upload [19] mobile /opt/iobroker/node_modules/iobroker.mobile/www/js/i18n/pl/translations.json js/i18n/pl/translations.json application/json
              2023-11-09 14:06:11.887  - info: host.ioBrokerVM iobroker npm-install: upload [18] mobile /opt/iobroker/node_modules/iobroker.mobile/www/js/i18n/pt/translations.json js/i18n/pt/translations.json application/json
              2023-11-09 14:06:11.891  - info: host.ioBrokerVM iobroker npm-install: upload [17] mobile /opt/iobroker/node_modules/iobroker.mobile/www/js/i18n/ru/translations.json js/i18n/ru/translations.json application/json
              2023-11-09 14:06:11.894  - info: host.ioBrokerVM iobroker npm-install: upload [16] mobile /opt/iobroker/node_modules/iobroker.mobile/www/js/i18n/zh-cn/translations.json js/i18n/zh-cn/translations.json application/json
              2023-11-09 14:06:11.897  - info: host.ioBrokerVM iobroker npm-install: upload [15] mobile /opt/iobroker/node_modules/iobroker.mobile/www/js/mobile.js js/mobile.js application/javascript
              2023-11-09 14:06:11.901  - info: host.ioBrokerVM iobroker npm-install: upload [14] mobile /opt/iobroker/node_modules/iobroker.mobile/www/js/words.js js/words.js application/javascript
              2023-11-09 14:06:11.906  - info: host.ioBrokerVM iobroker npm-install: upload [13] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/css/default/images/ajax-loader.gif lib/css/default/images/ajax-loader.gif image/gif
              2023-11-09 14:06:11.909  - info: host.ioBrokerVM iobroker npm-install: upload [12] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/css/default/jquery.mobile.icons.min.css lib/css/default/jquery.mobile.icons.min.css text/css
              2023-11-09 14:06:11.914  - info: host.ioBrokerVM iobroker npm-install: upload [11] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/css/default/jquery.mobile.min.css lib/css/default/jquery.mobile.min.css text/css
              2023-11-09 14:06:11.917  - info: host.ioBrokerVM iobroker npm-install: upload [10] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/css/grey/images/ajax-loader.gif lib/css/grey/images/ajax-loader.gif image/gif
              2023-11-09 14:06:11.921  - info: host.ioBrokerVM iobroker npm-install: upload [9] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/css/grey/jquery.mobile.icons.min.css lib/css/grey/jquery.mobile.icons.min.css text/css
              2023-11-09 14:06:11.926  - info: host.ioBrokerVM iobroker npm-install: upload [8] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/css/grey/jquery.mobile.min.css lib/css/grey/jquery.mobile.min.css text/css
              2023-11-09 14:06:11.930  - info: host.ioBrokerVM iobroker npm-install: upload [7] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/css/jquery.mobile.structure-1.4.5.min.css lib/css/jquery.mobile.structure-1.4.5.min.css text/css
              2023-11-09 14:06:11.933  - info: host.ioBrokerVM iobroker npm-install: upload [6] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/css/light/jquery.mobile.icons.min.css lib/css/light/jquery.mobile.icons.min.css text/css
              2023-11-09 14:06:11.937  - info: host.ioBrokerVM iobroker npm-install: upload [5] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/css/light/jquery.mobile.min.css lib/css/light/jquery.mobile.min.css text/css
              2023-11-09 14:06:11.940  - info: host.ioBrokerVM iobroker npm-install: upload [4] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/js/jquery.mobile-1.4.5.min.js lib/js/jquery.mobile-1.4.5.min.js application/javascript
              2023-11-09 14:06:11.944  - info: host.ioBrokerVM iobroker npm-install: upload [3] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/js/jquery.mobile-1.4.5.min.map lib/js/jquery.mobile-1.4.5.min.map application/json
              2023-11-09 14:06:11.949  - info: host.ioBrokerVM iobroker npm-install: upload [2] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/js/jquery.ui.touch-punch.min.js lib/js/jquery.ui.touch-punch.min.js application/javascript
              2023-11-09 14:06:11.952  - info: host.ioBrokerVM iobroker npm-install: upload [1] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/js/loStorage.min.js lib/js/loStorage.min.js application/javascript
              2023-11-09 14:06:11.955  - info: host.ioBrokerVM iobroker npm-install: upload [0] mobile /opt/iobroker/node_modules/iobroker.mobile/www/offline.html offline.html text/html
              2023-11-09 14:06:12.050  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.mobile created/updated
              2023-11-09 14:06:12.097  - info: host.ioBrokerVM iobroker npm-install: Update "system.adapter.mobile.0"
              2023-11-09 14:06:13.120  - info: host.ioBrokerVM iobroker npm-install: exit 0
              2023-11-09 14:06:14.120  - warn: host.ioBrokerVM startInstance cannot find adapter "pi-hole@1.3.6". Try to install it... 1 attempt
              2023-11-09 14:06:14.121  - info: host.ioBrokerVM iobroker install pi-hole@1.3.6 using installedFrom
              2023-11-09 14:06:15.736  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1Installing iobroker.pi-hole@1.3.6... (System call)
              2023-11-09 14:06:21.920  - info: host.ioBrokerVM iobroker npm-install: added 14 packages in 6s
              2023-11-09 14:06:21.921  - info: host.ioBrokerVM iobroker npm-install:
              2023-11-09 14:06:21.922  - info: host.ioBrokerVM iobroker npm-install: 129 packages are looking for funding
              2023-11-09 14:06:21.922  - info: host.ioBrokerVM iobroker npm-install:   run `npm fund` for details
              2023-11-09 14:06:21.943  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter pi-hole@1.3.6
              2023-11-09 14:06:22.013  - info: host.ioBrokerVM iobroker npm-install: upload [4] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/admin.d.ts admin.d.ts video/mp2t
              2023-11-09 14:06:22.021  - info: host.ioBrokerVM iobroker npm-install: upload [3] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/index_m.html index_m.html text/html
              2023-11-09 14:06:22.024  - info: host.ioBrokerVM iobroker npm-install: upload [2] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/pi-hole.png pi-hole.png image/png
              2023-11-09 14:06:22.028  - info: host.ioBrokerVM iobroker npm-install: upload [1] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/style.css style.css text/css
              2023-11-09 14:06:22.031  - info: host.ioBrokerVM iobroker npm-install: upload [0] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/words.js words.js application/javascript
              2023-11-09 14:06:22.045  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.pi-hole created/updated
              2023-11-09 14:06:23.108  - info: host.ioBrokerVM iobroker npm-install: exit 0
              2023-11-09 14:06:24.109  - warn: host.ioBrokerVM startInstance cannot find adapter "pvforecast@2.8.1". Try to install it... 1 attempt
              2023-11-09 14:06:24.109  - info: host.ioBrokerVM iobroker install pvforecast@2.8.1 using installedFrom
              2023-11-09 14:06:25.728  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1Installing iobroker.pvforecast@2.8.1... (System call)
              2023-11-09 14:06:30.535  - info: host.ioBrokerVM iobroker npm-install: added 4 packages in 5s129 packages are looking for funding  run `npm fund` for details
              2023-11-09 14:06:30.556  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter pvforecast@2.8.1
              2023-11-09 14:06:30.631  - info: host.ioBrokerVM iobroker npm-install: upload [14] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/de/translations.json i18n/de/translations.json application/json
              2023-11-09 14:06:30.638  - info: host.ioBrokerVM iobroker npm-install: upload [13] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/en/translations.json i18n/en/translations.json application/json
              2023-11-09 14:06:30.642  - info: host.ioBrokerVM iobroker npm-install: upload [12] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/es/translations.json i18n/es/translations.json application/json
              2023-11-09 14:06:30.645  - info: host.ioBrokerVM iobroker npm-install: upload [11] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
              2023-11-09 14:06:30.649  - info: host.ioBrokerVM iobroker npm-install: upload [10] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/it/translations.json i18n/it/translations.json application/json
              2023-11-09 14:06:30.652  - info: host.ioBrokerVM iobroker npm-install: upload [9] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
              2023-11-09 14:06:30.656  - info: host.ioBrokerVM iobroker npm-install: upload [8] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
              2023-11-09 14:06:30.659  - info: host.ioBrokerVM iobroker npm-install: upload [7] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
              2023-11-09 14:06:30.663  - info: host.ioBrokerVM iobroker npm-install: upload [6] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
              2023-11-09 14:06:30.667  - info: host.ioBrokerVM iobroker npm-install: upload [5] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
              2023-11-09 14:06:30.670  - info: host.ioBrokerVM iobroker npm-install: upload [4] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
              2023-11-09 14:06:30.673  - info: host.ioBrokerVM iobroker npm-install: upload [3] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/img/Azimuth.png img/Azimuth.png image/png
              2023-11-09 14:06:30.678  - info: host.ioBrokerVM iobroker npm-install: upload [2] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/jsonConfig.json jsonConfig.json application/json
              2023-11-09 14:06:30.681  - info: host.ioBrokerVM iobroker npm-install: upload [1] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/pvforecast.png pvforecast.png image/png
              2023-11-09 14:06:30.685  - info: host.ioBrokerVM iobroker npm-install: upload [0] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/style.css style.css text/css
              2023-11-09 14:06:30.778  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.pvforecast created/updated
              2023-11-09 14:06:31.844  - info: host.ioBrokerVM iobroker npm-install: exit 0
              2023-11-09 14:06:32.845  - warn: host.ioBrokerVM startInstance cannot find adapter "smartcontrol@2.0.1". Try to install it... 1 attempt
              2023-11-09 14:06:32.845  - info: host.ioBrokerVM iobroker install smartcontrol@2.0.1 using installedFrom
              2023-11-09 14:06:34.428  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
              2023-11-09 14:06:34.430  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.smartcontrol@2.0.1... (System call)
              2023-11-09 14:06:39.890  - info: host.ioBrokerVM iobroker npm-install: added 15 packages in 5s
              2023-11-09 14:06:39.891  - info: host.ioBrokerVM iobroker npm-install:
              2023-11-09 14:06:39.891  - info: host.ioBrokerVM iobroker npm-install: 140 packages are looking for funding
              2023-11-09 14:06:39.892  - info: host.ioBrokerVM iobroker npm-install:   run `npm fund` for details
              2023-11-09 14:06:39.915  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter smartcontrol@2.0.1
              2023-11-09 14:06:39.991  - info: host.ioBrokerVM iobroker npm-install: upload [81] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/admin.d.ts admin.d.ts video/mp2t
              2023-11-09 14:06:39.999  - info: host.ioBrokerVM iobroker npm-install: upload [80] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/doc-md/img/check_box-24px.svg doc-md/img/check_box-24px.svg image/svg+xml
              2023-11-09 14:06:40.036  - info: host.ioBrokerVM iobroker npm-install: upload [70] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/doc-md/img/table-zones_select-target-devices-overwrite.gif doc-md/img/table-zones_select-target-devices-overwrite.gif image/gif
              2023-11-09 14:06:40.065  - info: host.ioBrokerVM iobroker npm-install: upload [60] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/doc-md/table-target-devices_de.md doc-md/table-target-devices_de.md text/markdown
              2023-11-09 14:06:40.093  - info: host.ioBrokerVM iobroker npm-install: upload [50] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/doc-md/table-trigger-times_de.md doc-md/table-trigger-times_de.md text/markdown
              2023-11-09 14:06:40.120  - info: host.ioBrokerVM iobroker npm-install: upload [40] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/fancytree/skin-lion/vline-rtl.gif fancytree/skin-lion/vline-rtl.gif image/gif
              2023-11-09 14:06:40.145  - info: host.ioBrokerVM iobroker npm-install: upload [30] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
              2023-11-09 14:06:40.172  - info: host.ioBrokerVM iobroker npm-install: upload [20] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/option-screenshots/tab-target-devices.png img/option-screenshots/tab-target-devices.png image/png
              2023-11-09 14:06:40.175  - info: host.ioBrokerVM iobroker npm-install: upload [19] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/option-screenshots/tab-triggers-motion.png img/option-screenshots/tab-triggers-motion.png image/png
              2023-11-09 14:06:40.179  - info: host.ioBrokerVM iobroker npm-install: upload [18] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/option-screenshots/tab-triggers-other.png img/option-screenshots/tab-triggers-other.png image/png
              2023-11-09 14:06:40.182  - info: host.ioBrokerVM iobroker npm-install: upload [17] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/option-screenshots/tab-triggers-time.png img/option-screenshots/tab-triggers-time.png image/png
              2023-11-09 14:06:40.186  - info: host.ioBrokerVM iobroker npm-install: upload [16] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/option-screenshots/tab-zones-execution.png img/option-screenshots/tab-zones-execution.png image/png
              2023-11-09 14:06:40.189  - info: host.ioBrokerVM iobroker npm-install: upload [15] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/option-screenshots/tab-zones.png img/option-screenshots/tab-zones.png image/png
              2023-11-09 14:06:40.193  - info: host.ioBrokerVM iobroker npm-install: upload [14] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/sc_always.png img/sc_always.png image/png
              2023-11-09 14:06:40.196  - info: host.ioBrokerVM iobroker npm-install: upload [13] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/select-target-devices-overwrite.gif img/select-target-devices-overwrite.gif image/gif
              2023-11-09 14:06:40.199  - info: host.ioBrokerVM iobroker npm-install: upload [12] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/smartControl_options1.gif img/smartControl_options1.gif image/gif
              2023-11-09 14:06:40.213  - info: host.ioBrokerVM iobroker npm-install: upload [11] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/smartControl_options_dropdown.gif img/smartControl_options_dropdown.gif image/gif
              2023-11-09 14:06:40.217  - info: host.ioBrokerVM iobroker npm-install: upload [10] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/smartControl_options_dropdown_2.gif img/smartControl_options_dropdown_2.gif image/gif
              2023-11-09 14:06:40.221  - info: host.ioBrokerVM iobroker npm-install: upload [9] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/index_m.html index_m.html text/html
              2023-11-09 14:06:40.225  - info: host.ioBrokerVM iobroker npm-install: upload [8] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/index_m.js index_m.js application/javascript
              2023-11-09 14:06:40.228  - info: host.ioBrokerVM iobroker npm-install: upload [7] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/smartcontrol-banner.png smartcontrol-banner.png image/png
              2023-11-09 14:06:40.232  - info: host.ioBrokerVM iobroker npm-install: upload [6] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/smartcontrol.png smartcontrol.png image/png
              2023-11-09 14:06:40.235  - info: host.ioBrokerVM iobroker npm-install: upload [5] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/style.css style.css text/css
              2023-11-09 14:06:40.239  - info: host.ioBrokerVM iobroker npm-install: upload [4] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/tsconfig.json tsconfig.json application/json
              2023-11-09 14:06:40.243  - info: host.ioBrokerVM iobroker npm-install: upload [3] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/words.js words.js application/javascript
              2023-11-09 14:06:40.247  - info: host.ioBrokerVM iobroker npm-install: upload [2] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/zero-md/readme.txt zero-md/readme.txt text/plain
              2023-11-09 14:06:40.250  - info: host.ioBrokerVM iobroker npm-install: upload [1] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/zero-md/webcomponents-loader.min.js zero-md/webcomponents-loader.min.js application/javascript
              2023-11-09 14:06:40.253  - info: host.ioBrokerVM iobroker npm-install: upload [0] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/zero-md/zero-md.min.js.js zero-md/zero-md.min.js.js application/javascript
              2023-11-09 14:06:40.344  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.smartcontrol created/updated
              2023-11-09 14:06:41.412  - info: host.ioBrokerVM iobroker npm-install: exit 0
              2023-11-09 14:06:42.412  - warn: host.ioBrokerVM startInstance cannot find adapter "socketio@6.5.5". Try to install it... 1 attempt
              2023-11-09 14:06:42.413  - info: host.ioBrokerVM iobroker install socketio@6.5.5 using installedFrom
              2023-11-09 14:06:44.040  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1Installing iobroker.socketio@6.5.5... (System call)
              2023-11-09 14:06:49.603  - info: host.ioBrokerVM iobroker npm-install: added 41 packages in 5s140 packages are looking for funding  run `npm fund` for details
              2023-11-09 14:06:49.624  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter socketio@6.5.5
              2023-11-09 14:06:49.697  - info: host.ioBrokerVM iobroker npm-install: upload [11] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/de/translations.json i18n/de/translations.json application/json
              2023-11-09 14:06:49.704  - info: host.ioBrokerVM iobroker npm-install: upload [10] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/en/translations.json i18n/en/translations.json application/json
              2023-11-09 14:06:49.707  - info: host.ioBrokerVM iobroker npm-install: upload [9] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/es/translations.json i18n/es/translations.json application/json
              2023-11-09 14:06:49.710  - info: host.ioBrokerVM iobroker npm-install: upload [8] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
              2023-11-09 14:06:49.714  - info: host.ioBrokerVM iobroker npm-install: upload [7] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/it/translations.json i18n/it/translations.json application/json
              2023-11-09 14:06:49.717  - info: host.ioBrokerVM iobroker npm-install: upload [6] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
              2023-11-09 14:06:49.721  - info: host.ioBrokerVM iobroker npm-install: upload [5] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
              2023-11-09 14:06:49.724  - info: host.ioBrokerVM iobroker npm-install: upload [4] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
              2023-11-09 14:06:49.727  - info: host.ioBrokerVM iobroker npm-install: upload [3] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
              2023-11-09 14:06:49.730  - info: host.ioBrokerVM iobroker npm-install: upload [2] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
              2023-11-09 14:06:49.733  - info: host.ioBrokerVM iobroker npm-install: upload [1] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/jsonConfig.json jsonConfig.json application/json
              2023-11-09 14:06:49.736  - info: host.ioBrokerVM iobroker npm-install: upload [0] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/socketio.png socketio.png image/png
              2023-11-09 14:06:49.857  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.socketio created/updated
              2023-11-09 14:06:50.920  - info: host.ioBrokerVM iobroker npm-install: exit 0
              2023-11-09 14:06:51.921  - warn: host.ioBrokerVM startInstance cannot find adapter "tado@0.4.9". Try to install it... 1 attempt
              2023-11-09 14:06:51.921  - info: host.ioBrokerVM iobroker install tado@0.4.9 using installedFrom
              2023-11-09 14:06:53.545  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
              2023-11-09 14:06:53.546  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.tado@0.4.9... (System call)
              2023-11-09 14:07:07.999  - info: host.ioBrokerVM iobroker npm-install:
              2023-11-09 14:07:08.000  - info: host.ioBrokerVM iobroker npm-install: added 27 packages in 14s149 packages are looking for funding  run `npm fund` for details
              2023-11-09 14:07:08.023  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter tado@0.4.9
              2023-11-09 14:07:08.098  - info: host.ioBrokerVM iobroker npm-install: upload [6] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/admin.d.ts admin.d.ts video/mp2t
              2023-11-09 14:07:08.105  - info: host.ioBrokerVM iobroker npm-install: upload [5] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/button.png button.png image/png
              2023-11-09 14:07:08.109  - info: host.ioBrokerVM iobroker npm-install: upload [4] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/index_m.html index_m.html text/html
              2023-11-09 14:07:08.112  - info: host.ioBrokerVM iobroker npm-install: upload [3] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/jsonConfig.json jsonConfig.json application/json
              2023-11-09 14:07:08.115  - info: host.ioBrokerVM iobroker npm-install: upload [2] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/style.css style.css text/css
              2023-11-09 14:07:08.121  - info: host.ioBrokerVM iobroker npm-install: upload [1] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/tado.png tado.png image/png
              2023-11-09 14:07:08.125  - info: host.ioBrokerVM iobroker npm-install: upload [0] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/words.js words.js application/javascript
              2023-11-09 14:07:08.225  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.tado created/updated
              2023-11-09 14:07:09.286  - info: host.ioBrokerVM iobroker npm-install: exit 0
              2023-11-09 14:07:10.286  - warn: host.ioBrokerVM startInstance cannot find adapter "tibberlink@1.0.0". Try to install it... 1 attempt
              2023-11-09 14:07:10.286  - info: host.ioBrokerVM iobroker install tibberlink@1.0.0 using installedFrom
              2023-11-09 14:07:11.896  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
              2023-11-09 14:07:11.897  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.tibberlink@1.0.0... (System call)
              2023-11-09 14:07:17.244  - info: host.ioBrokerVM iobroker npm-install: added 2 packages in 5s149 packages are looking for funding  run `npm fund` for details
              2023-11-09 14:07:17.264  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter tibberlink@1.0.0
              2023-11-09 14:07:17.337  - info: host.ioBrokerVM iobroker npm-install: upload [12] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/de/translations.json i18n/de/translations.json application/json
              2023-11-09 14:07:17.345  - info: host.ioBrokerVM iobroker npm-install: upload [11] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/en/translations.json i18n/en/translations.json application/json
              2023-11-09 14:07:17.348  - info: host.ioBrokerVM iobroker npm-install: upload [10] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/es/translations.json i18n/es/translations.json application/json
              2023-11-09 14:07:17.351  - info: host.ioBrokerVM iobroker npm-install: upload [9] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
              2023-11-09 14:07:17.355  - info: host.ioBrokerVM iobroker npm-install: upload [8] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/it/translations.json i18n/it/translations.json application/json
              2023-11-09 14:07:17.359  - info: host.ioBrokerVM iobroker npm-install: upload [7] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
              2023-11-09 14:07:17.362  - info: host.ioBrokerVM iobroker npm-install: upload [6] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
              2023-11-09 14:07:17.366  - info: host.ioBrokerVM iobroker npm-install: upload [5] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
              2023-11-09 14:07:17.369  - info: host.ioBrokerVM iobroker npm-install: upload [4] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
              2023-11-09 14:07:17.373  - info: host.ioBrokerVM iobroker npm-install: upload [3] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
              2023-11-09 14:07:17.376  - info: host.ioBrokerVM iobroker npm-install: upload [2] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
              2023-11-09 14:07:17.379  - info: host.ioBrokerVM iobroker npm-install: upload [1] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/jsonConfig.json jsonConfig.json application/json
              2023-11-09 14:07:17.383  - info: host.ioBrokerVM iobroker npm-install: upload [0] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/tibberlink.png tibberlink.png image/png
              2023-11-09 14:07:17.476  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.tibberlink created/updated
              2023-11-09 14:07:18.536  - info: host.ioBrokerVM iobroker npm-install: exit 0
              2023-11-09 14:07:19.536  - warn: host.ioBrokerVM startInstance cannot find adapter "vis-hqwidgets@1.4.0". Try to install it... 1 attempt
              2023-11-09 14:07:19.537  - info: host.ioBrokerVM iobroker install vis-hqwidgets@1.4.0 using installedFrom
              2023-11-09 14:07:21.131  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1Installing iobroker.vis-hqwidgets@1.4.0... (System call)
              2023-11-09 14:07:25.562  - info: host.ioBrokerVM iobroker npm-install: added 1 package in 4s149 packages are looking for funding  run `npm fund` for details
              2023-11-09 14:07:25.582  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter vis-hqwidgets@1.4.0
              2023-11-09 14:07:25.653  - info: host.ioBrokerVM iobroker npm-install: upload [1] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/hqwidgets.png hqwidgets.png image/png
              2023-11-09 14:07:25.660  - info: host.ioBrokerVM iobroker npm-install: upload [0] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/index.html index.html text/html
              2023-11-09 14:07:25.667  - info: host.ioBrokerVM iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-hqwidgets/www" was not found! Nothing was uploaded or deleted.
              2023-11-09 14:07:25.785  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.vis-hqwidgets created/updated
              2023-11-09 14:07:26.849  - info: host.ioBrokerVM iobroker npm-install: exit 0
              2023-11-09 14:07:27.849  - warn: host.ioBrokerVM startInstance cannot find adapter "vis-jqui-mfd@1.0.12". Try to install it... 1 attempt
              2023-11-09 14:07:27.850  - info: host.ioBrokerVM iobroker install vis-jqui-mfd@1.0.12 using installedFrom
              2023-11-09 14:07:29.442  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
              2023-11-09 14:07:29.444  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis-jqui-mfd@1.0.12... (System call)
              2023-11-09 14:07:33.873  - info: host.ioBrokerVM iobroker npm-install: added 1 package in 4s
              2023-11-09 14:07:33.874  - info: host.ioBrokerVM iobroker npm-install:
              2023-11-09 14:07:33.874  - info: host.ioBrokerVM iobroker npm-install: 149 packages are looking for funding
              2023-11-09 14:07:33.875  - info: host.ioBrokerVM iobroker npm-install:   run `npm fund` for details
              2023-11-09 14:07:33.898  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter vis-jqui-mfd@1.0.12
              2023-11-09 14:07:33.968  - info: host.ioBrokerVM iobroker npm-install: upload [0] vis-jqui-mfd.admin /opt/iobroker/node_modules/iobroker.vis-jqui-mfd/admin/jqui-mfd.png jqui-mfd.png image/png
              2023-11-09 14:07:33.976  - info: host.ioBrokerVM iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-jqui-mfd/www" was not found! Nothing was uploaded or deleted.
              2023-11-09 14:07:34.095  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.vis-jqui-mfd created/updated
              2023-11-09 14:07:34.142  - info: host.ioBrokerVM iobroker npm-install: Update "system.adapter.vis-jqui-mfd.0"
              2023-11-09 14:07:35.159  - info: host.ioBrokerVM iobroker npm-install: exit 0
              2023-11-09 14:07:36.160  - warn: host.ioBrokerVM startInstance cannot find adapter "vis-material-advanced@1.7.4". Try to install it... 1 attempt
              2023-11-09 14:07:36.160  - info: host.ioBrokerVM iobroker install vis-material-advanced@1.7.4 using installedFrom
              2023-11-09 14:07:37.726  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
              2023-11-09 14:07:37.726  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis-material-advanced@1.7.4... (System call)
              2023-11-09 14:07:42.344  - info: host.ioBrokerVM iobroker npm-install: added 1 package in 4s
              2023-11-09 14:07:42.345  - info: host.ioBrokerVM iobroker npm-install:
              2023-11-09 14:07:42.345  - info: host.ioBrokerVM iobroker npm-install: 149 packages are looking for funding
              2023-11-09 14:07:42.345  - info: host.ioBrokerVM iobroker npm-install:   run `npm fund` for details
              2023-11-09 14:07:42.370  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter vis-material-advanced@1.7.4
              2023-11-09 14:07:42.445  - info: host.ioBrokerVM iobroker npm-install: upload [1] vis-material-advanced.admin /opt/iobroker/node_modules/iobroker.vis-material-advanced/admin/vis-material-advanced.png vis-material-advanced.png image/png
              2023-11-09 14:07:42.451  - info: host.ioBrokerVM iobroker npm-install: upload [0] vis-material-advanced.admin /opt/iobroker/node_modules/iobroker.vis-material-advanced/admin/words.js words.js application/javascript
              2023-11-09 14:07:42.455  - info: host.ioBrokerVM iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-material-advanced/www" was not found! Nothing was uploaded or deleted.
              2023-11-09 14:07:42.575  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.vis-material-advanced created/updated
              2023-11-09 14:07:43.640  - info: host.ioBrokerVM iobroker npm-install: exit 0
              2023-11-09 14:07:44.641  - warn: host.ioBrokerVM startInstance cannot find adapter "vis-metro@1.2.0". Try to install it... 1 attempt
              2023-11-09 14:07:44.641  - info: host.ioBrokerVM iobroker install vis-metro@1.2.0 using installedFrom
              2023-11-09 14:07:46.237  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
              2023-11-09 14:07:46.239  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis-metro@1.2.0... (System call)
              2023-11-09 14:07:50.907  - info: host.ioBrokerVM iobroker npm-install: added 3 packages in 4s149 packages are looking for funding  run `npm fund` for details
              2023-11-09 14:07:50.930  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter vis-metro@1.2.0
              2023-11-09 14:07:51.001  - info: host.ioBrokerVM iobroker npm-install: upload [1] vis-metro.admin /opt/iobroker/node_modules/iobroker.vis-metro/admin/index.html index.html text/html
              2023-11-09 14:07:51.008  - info: host.ioBrokerVM iobroker npm-install: upload [0] vis-metro.admin /opt/iobroker/node_modules/iobroker.vis-metro/admin/metro.png metro.png image/png
              2023-11-09 14:07:51.013  - info: host.ioBrokerVM iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-metro/www" was not found! Nothing was uploaded or deleted.
              2023-11-09 14:07:51.132  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.vis-metro created/updated
              2023-11-09 14:07:52.192  - info: host.ioBrokerVM iobroker npm-install: exit 0
              2023-11-09 14:07:53.193  - warn: host.ioBrokerVM startInstance cannot find adapter "vis-timeandweather@1.2.2". Try to install it... 1 attempt
              2023-11-09 14:07:53.193  - info: host.ioBrokerVM iobroker install vis-timeandweather@1.2.2 using installedFrom
              2023-11-09 14:07:54.800  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1Installing iobroker.vis-timeandweather@1.2.2... (System call)
              2023-11-09 14:07:59.358  - info: host.ioBrokerVM iobroker npm-install: added 2 packages in 4s149 packages are looking for funding  run `npm fund` for details
              2023-11-09 14:07:59.378  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter vis-timeandweather@1.2.2
              2023-11-09 14:07:59.448  - info: host.ioBrokerVM iobroker npm-install: upload [1] vis-timeandweather.admin /opt/iobroker/node_modules/iobroker.vis-timeandweather/admin/index.html index.html text/html
              2023-11-09 14:07:59.455  - info: host.ioBrokerVM iobroker npm-install: upload [0] vis-timeandweather.admin /opt/iobroker/node_modules/iobroker.vis-timeandweather/admin/timeandweather.png timeandweather.png image/png
              2023-11-09 14:07:59.461  - info: host.ioBrokerVM iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-timeandweather/www" was not found! Nothing was uploaded or deleted.
              2023-11-09 14:07:59.579  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.vis-timeandweather created/updated
              2023-11-09 14:08:00.640  - info: host.ioBrokerVM iobroker npm-install: exit 0
              2023-11-09 14:08:01.641  - warn: host.ioBrokerVM startInstance cannot find adapter "vis@1.4.16". Try to install it... 1 attempt
              2023-11-09 14:08:01.641  - info: host.ioBrokerVM iobroker install vis@1.4.16 using installedFrom
              2023-11-09 14:08:03.252  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1Installing iobroker.vis@1.4.16... (System call)
              2023-11-09 14:08:07.741  - info: vis.0 (14808) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.12
              2023-11-09 14:08:07.936  - info: vis.0 (14808) vis license is OK.
              2023-11-09 14:08:08.132  - error: vis.0 (14808) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              2023-11-09 14:08:08.133  - error: vis.0 (14808) unhandled promise rejection: Not exists
              2023-11-09 14:08:08.133  - error: vis.0 (14808) Error: Not exists
                  at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:854:19)
                  at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:891:59)
                  at process.processImmediate (node:internal/timers:478:21)
              2023-11-09 14:08:08.134  - error: vis.0 (14808) Not exists
              2023-11-09 14:08:08.638  - info: vis.0 (14808) terminating
              2023-11-09 14:08:08.639  - warn: vis.0 (14808) Terminated (UNCAUGHT_EXCEPTION): Without reason
              2023-11-09 14:08:09.330  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-09T13_08_03_548Z-debug-0.log
              2023-11-09 14:08:09.330  - error: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM Cannot install iobroker.vis@1.4.16: 6
              2023-11-09 14:08:10.348  - info: host.ioBrokerVM iobroker npm-install: exit 25
              2023-11-09 14:08:11.349  - warn: host.ioBrokerVM startInstance cannot find adapter "web@4.3.0". Try to install it... 1 attempt
              2023-11-09 14:08:11.349  - info: host.ioBrokerVM iobroker install web@4.3.0 using installedFrom
              2023-11-09 14:08:13.009  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
              2023-11-09 14:08:13.011  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.web@4.3.0... (System call)
              2023-11-09 14:08:19.346  - info: host.ioBrokerVM iobroker npm-install: added 12 packages in 6s150 packages are looking for funding  run `npm fund` for details
              2023-11-09 14:08:19.371  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter web@4.3.0
              2023-11-09 14:08:19.442  - info: host.ioBrokerVM iobroker npm-install: upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
              2023-11-09 14:08:19.449  - info: host.ioBrokerVM iobroker npm-install: upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
              2023-11-09 14:08:19.454  - info: host.ioBrokerVM iobroker npm-install: upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
              2023-11-09 14:08:19.457  - info: host.ioBrokerVM iobroker npm-install: upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/manifest.json manifest.json application/json
              2023-11-09 14:08:19.461  - info: host.ioBrokerVM iobroker npm-install: upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
              2023-11-09 14:08:19.465  - info: host.ioBrokerVM iobroker npm-install: upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json
              2023-11-09 14:08:19.468  - info: host.ioBrokerVM iobroker npm-install: upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
              2023-11-09 14:08:19.471  - info: host.ioBrokerVM iobroker npm-install: upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
              2023-11-09 14:08:19.474  - info: host.ioBrokerVM iobroker npm-install: upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js static/js/2.b1d56998.chunk.js application/javascript
              2023-11-09 14:08:19.488  - info: host.ioBrokerVM iobroker npm-install: upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.LICENSE.txt static/js/2.b1d56998.chunk.js.LICENSE.txt text/plain
              2023-11-09 14:08:19.491  - info: host.ioBrokerVM iobroker npm-install: upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.map static/js/2.b1d56998.chunk.js.map application/json
              2023-11-09 14:08:19.822  - info: host.ioBrokerVM iobroker npm-install: upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js static/js/main.034751df.chunk.js application/javascript
              2023-11-09 14:08:19.834  - info: host.ioBrokerVM iobroker npm-install: upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js.map static/js/main.034751df.chunk.js.map application/json
              2023-11-09 14:08:19.838  - info: host.ioBrokerVM iobroker npm-install: upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js static/js/runtime-main.7278cf1c.js application/javascript
              2023-11-09 14:08:19.840  - info: host.ioBrokerVM iobroker npm-install: upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js.map static/js/runtime-main.7278cf1c.js.map application/json
              2023-11-09 14:08:19.843  - info: host.ioBrokerVM iobroker npm-install: upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/le.eb63b1db.png static/media/le.eb63b1db.png image/png
              2023-11-09 14:08:19.847  - info: host.ioBrokerVM iobroker npm-install: upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
              2023-11-09 14:08:19.902  - info: host.ioBrokerVM iobroker npm-install: upload [396] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
              2023-11-09 14:08:20.034  - info: host.ioBrokerVM iobroker npm-install: upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png image/png
              2023-11-09 14:08:20.187  - info: host.ioBrokerVM iobroker npm-install: upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css text/css
              2023-11-09 14:08:20.343  - info: host.ioBrokerVM iobroker npm-install: upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png image/png
              2023-11-09 14:08:20.507  - info: host.ioBrokerVM iobroker npm-install: upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png image/png
              2023-11-09 14:08:20.681  - info: host.ioBrokerVM iobroker npm-install: upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png image/png
              2023-11-09 14:08:20.854  - info: host.ioBrokerVM iobroker npm-install: upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png image/png
              2023-11-09 14:08:20.886  - info: host.ioBrokerVM iobroker npm-install: upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png image/png
              2023-11-09 14:08:20.921  - info: host.ioBrokerVM iobroker npm-install: upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png image/png
              2023-11-09 14:08:20.953  - info: host.ioBrokerVM iobroker npm-install: upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png image/png
              2023-11-09 14:08:20.986  - info: host.ioBrokerVM iobroker npm-install: upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png image/png
              2023-11-09 14:08:21.019  - info: host.ioBrokerVM iobroker npm-install: upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css text/css
              2023-11-09 14:08:21.070  - info: host.ioBrokerVM iobroker npm-install: upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png image/png
              2023-11-09 14:08:21.106  - info: host.ioBrokerVM iobroker npm-install: upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/theme.css lib/css/themes/jquery-ui/vader/theme.css text/css
              2023-11-09 14:08:21.147  - info: host.ioBrokerVM iobroker npm-install: upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.js lib/js/jquery-1.11.2.min.js application/javascript
              2023-11-09 14:08:21.152  - info: host.ioBrokerVM iobroker npm-install: upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.map lib/js/jquery-1.11.2.min.map application/json
              2023-11-09 14:08:21.158  - info: host.ioBrokerVM iobroker npm-install: upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.js lib/js/jquery-3.2.1.min.js application/javascript
              2023-11-09 14:08:21.163  - info: host.ioBrokerVM iobroker npm-install: upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.map lib/js/jquery-3.2.1.min.map application/json
              2023-11-09 14:08:21.167  - info: host.ioBrokerVM iobroker npm-install: upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.10.3.full.min.js lib/js/jquery-ui-1.10.3.full.min.js application/javascript
              2023-11-09 14:08:21.172  - info: host.ioBrokerVM iobroker npm-install: upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.3.full.min.js lib/js/jquery-ui-1.11.3.full.min.js application/javascript
              2023-11-09 14:08:21.176  - info: host.ioBrokerVM iobroker npm-install: upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.4.full.min.js lib/js/jquery-ui-1.11.4.full.min.js application/javascript
              2023-11-09 14:08:21.183  - info: host.ioBrokerVM iobroker npm-install: upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.1.11.2.slider.min.js lib/js/jquery-ui.1.11.2.slider.min.js application/javascript
              2023-11-09 14:08:21.188  - info: host.ioBrokerVM iobroker npm-install: upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.min.js lib/js/jquery-ui.min.js application/javascript
              2023-11-09 14:08:21.192  - info: host.ioBrokerVM iobroker npm-install: upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js lib/js/jquery.fancytree-all.min.js application/javascript
              2023-11-09 14:08:21.214  - info: host.ioBrokerVM iobroker npm-install: upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js.map lib/js/jquery.fancytree-all.min.js.map application/json
              2023-11-09 14:08:21.221  - info: host.ioBrokerVM iobroker npm-install: upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.jqGrid-4.5.4.min.js lib/js/jquery.jqGrid-4.5.4.min.js application/javascript
              2023-11-09 14:08:21.226  - info: host.ioBrokerVM iobroker npm-install: upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/loStorage.js lib/js/loStorage.js application/javascript
              2023-11-09 14:08:21.230  - info: host.ioBrokerVM iobroker npm-install: upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js lib/js/materialize.js application/javascript
              2023-11-09 14:08:21.235  - info: host.ioBrokerVM iobroker npm-install: upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js.map lib/js/materialize.js.map application/json
              2023-11-09 14:08:21.244  - info: host.ioBrokerVM iobroker npm-install: upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/selectID.js lib/js/selectID.js application/javascript
              2023-11-09 14:08:21.253  - info: host.ioBrokerVM iobroker npm-install: upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
              2023-11-09 14:08:21.258  - info: host.ioBrokerVM iobroker npm-install: upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/socket.io.js lib/js/socket.io.js application/javascript
              2023-11-09 14:08:21.279  - info: host.ioBrokerVM iobroker npm-install: upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/translate.js lib/js/translate.js application/javascript
              2023-11-09 14:08:21.283  - info: host.ioBrokerVM iobroker npm-install: upload [1] web /opt/iobroker/node_modules/iobroker.web/www/login/favicon.ico login/favicon.ico image/vnd.microsoft.icon
              2023-11-09 14:08:21.288  - info: host.ioBrokerVM iobroker npm-install: upload [0] web /opt/iobroker/node_modules/iobroker.web/www/login/index.html login/index.html text/html
              2023-11-09 14:08:21.380  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.web created/updated
              2023-11-09 14:08:22.442  - info: host.ioBrokerVM iobroker npm-install: exit 0
              2023-11-09 14:08:23.443  - warn: host.ioBrokerVM startInstance cannot find adapter "worx@2.3.2". Try to install it... 1 attempt
              2023-11-09 14:08:23.443  - info: host.ioBrokerVM iobroker install worx@2.3.2 using installedFrom
              2023-11-09 14:08:25.057  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
              2023-11-09 14:08:25.059  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.worx@2.3.2... (System call)
              2023-11-09 14:08:35.767  - info: host.ioBrokerVM iobroker npm-install:
              2023-11-09 14:08:35.767  - info: host.ioBrokerVM iobroker npm-install: added 42 packages in 10s152 packages are looking for funding  run `npm fund` for details
              2023-11-09 14:08:35.799  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter worx@2.3.2
              2023-11-09 14:08:35.874  - info: host.ioBrokerVM iobroker npm-install: upload [13] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/de/translations.json i18n/de/translations.json application/json
              2023-11-09 14:08:35.882  - info: host.ioBrokerVM iobroker npm-install: upload [12] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/en/translations.json i18n/en/translations.json application/json
              2023-11-09 14:08:35.885  - info: host.ioBrokerVM iobroker npm-install: upload [11] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/es/translations.json i18n/es/translations.json application/json
              2023-11-09 14:08:35.889  - info: host.ioBrokerVM iobroker npm-install: upload [10] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
              2023-11-09 14:08:35.892  - info: host.ioBrokerVM iobroker npm-install: upload [9] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/it/translations.json i18n/it/translations.json application/json
              2023-11-09 14:08:35.896  - info: host.ioBrokerVM iobroker npm-install: upload [8] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
              2023-11-09 14:08:35.899  - info: host.ioBrokerVM iobroker npm-install: upload [7] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
              2023-11-09 14:08:35.903  - info: host.ioBrokerVM iobroker npm-install: upload [6] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
              2023-11-09 14:08:35.906  - info: host.ioBrokerVM iobroker npm-install: upload [5] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
              2023-11-09 14:08:35.910  - info: host.ioBrokerVM iobroker npm-install: upload [4] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
              2023-11-09 14:08:35.913  - info: host.ioBrokerVM iobroker npm-install: upload [3] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
              2023-11-09 14:08:35.916  - info: host.ioBrokerVM iobroker npm-install: upload [2] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/index_m.html index_m.html text/html
              2023-11-09 14:08:35.919  - info: host.ioBrokerVM iobroker npm-install: upload [1] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/jsonConfig.json jsonConfig.json application/json
              2023-11-09 14:08:35.922  - info: host.ioBrokerVM iobroker npm-install: upload [0] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/worx.png worx.png image/png
              2023-11-09 14:08:36.035  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.worx created/updated
              2023-11-09 14:08:37.095  - info: host.ioBrokerVM iobroker npm-install: exit 0
              2023-11-09 14:08:38.095  - warn: host.ioBrokerVM startInstance cannot find adapter "vis@1.4.16". Try to install it... 2 attempt
              2023-11-09 14:08:38.096  - info: host.ioBrokerVM iobroker install vis@1.4.16 using installedFrom
              2023-11-09 14:08:39.715  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
              2023-11-09 14:08:39.716  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
              2023-11-09 14:08:43.855  - info: vis.0 (15120) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.12
              2023-11-09 14:08:44.030  - info: vis.0 (15120) vis license is OK.
              2023-11-09 14:08:44.198  - error: vis.0 (15120) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              2023-11-09 14:08:44.198  - error: vis.0 (15120) unhandled promise rejection: Not exists
              2023-11-09 14:08:44.199  - error: vis.0 (15120) Error: Not exists
              2023-11-09 14:08:44.199  - error: vis.0 (15120) Not exists
              2023-11-09 14:08:44.704  - info: vis.0 (15120) terminating
              2023-11-09 14:08:44.705  - warn: vis.0 (15120) Terminated (UNCAUGHT_EXCEPTION): Without reason
              2023-11-09 14:08:45.368  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-09T13_08_40_023Z-debug-0.log
              2023-11-09 14:08:45.369  - error: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM Cannot install iobroker.vis@1.4.16: 6
              2023-11-09 14:08:46.386  - info: host.ioBrokerVM iobroker npm-install: exit 25
              2023-11-09 14:08:47.386  - warn: host.ioBrokerVM startInstance cannot find adapter "vis@1.4.16". Try to install it... 3 attempt
              2023-11-09 14:08:47.387  - info: host.ioBrokerVM iobroker install vis@1.4.16 using installedVersion
              2023-11-09 14:08:48.955  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1Installing iobroker.vis@1.4.16... (System call)
              2023-11-09 14:08:53.034  - info: vis.0 (15229) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.12
              2023-11-09 14:08:53.235  - info: vis.0 (15229) vis license is OK.
              2023-11-09 14:08:53.414  - error: vis.0 (15229) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              2023-11-09 14:08:53.414  - error: vis.0 (15229) unhandled promise rejection: Not exists
              2023-11-09 14:08:53.415  - error: vis.0 (15229) Error: Not exists
              2023-11-09 14:08:53.415  - error: vis.0 (15229) Not exists
              2023-11-09 14:08:53.921  - info: vis.0 (15229) terminating
              2023-11-09 14:08:53.921  - warn: vis.0 (15229) Terminated (UNCAUGHT_EXCEPTION): Without reason
              2023-11-09 14:08:54.553  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-09T13_08_49_301Z-debug-0.log
              2023-11-09 14:08:54.554  - error: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM Cannot install iobroker.vis@1.4.16: 6
              2023-11-09 14:08:55.571  - info: host.ioBrokerVM iobroker npm-install: exit 25
              2023-11-09 14:08:56.572  - warn: host.ioBrokerVM startInstance cannot find adapter "vis@1.4.16". Try to install it... 4 attempt
              2023-11-09 14:08:56.572  - info: host.ioBrokerVM iobroker install vis@1.4.16 using installedVersion
              2023-11-09 14:08:58.196  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
              2023-11-09 14:08:58.196  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
              2023-11-09 14:09:02.223  - info: vis.0 (15338) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.12
              2023-11-09 14:09:02.401  - info: vis.0 (15338) vis license is OK.
              2023-11-09 14:09:02.571  - error: vis.0 (15338) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              2023-11-09 14:09:02.572  - error: vis.0 (15338) unhandled promise rejection: Not exists
              2023-11-09 14:09:02.573  - error: vis.0 (15338) Error: Not exists
              2023-11-09 14:09:02.573  - error: vis.0 (15338) Not exists
              2023-11-09 14:09:03.076  - info: vis.0 (15338) terminating
              2023-11-09 14:09:03.077  - warn: vis.0 (15338) Terminated (UNCAUGHT_EXCEPTION): Without reason
              2023-11-09 14:09:03.768  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-09T13_08_58_507Z-debug-0.log
              2023-11-09 14:09:03.769  - error: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM Cannot install iobroker.vis@1.4.16: 6
              2023-11-09 14:09:04.788  - info: host.ioBrokerVM iobroker npm-install: exit 25
              2023-11-09 14:09:05.788  - error: host.ioBrokerVM Cannot download and install adapter "vis@1.4.16". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
              ioBroker auf: Lenovo ThinkCentre M910Q Tiny i5-7500T 16 GB mit proxmox in VM (Bookworm)
              G 1 Antwort Letzte Antwort
              • G Gismoh
                iob logs --watch:
                2023-11-09 14:05:41.577  - info: host.ioBrokerVM iobroker npm-install: upload [4] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/simplemde.min.js lib/js/simplemde.min.js application/javascript
                2023-11-09 14:05:41.588  - info: host.ioBrokerVM iobroker npm-install: upload [3] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/systemInformation.js lib/js/systemInformation.js application/javascript
                2023-11-09 14:05:41.591  - info: host.ioBrokerVM iobroker npm-install: upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/updateAdapter.js lib/js/updateAdapter.js application/javascript
                2023-11-09 14:05:41.595  - info: host.ioBrokerVM iobroker npm-install: upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/tab_m.html tab_m.html text/html
                2023-11-09 14:05:41.598  - info: host.ioBrokerVM iobroker npm-install: upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/words.js words.js application/javascript
                2023-11-09 14:05:41.726  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.info created/updated
                2023-11-09 14:05:42.798  - info: host.ioBrokerVM iobroker npm-install: exit 0
                2023-11-09 14:05:43.798  - warn: host.ioBrokerVM startInstance cannot find adapter "iot@1.14.5". Try to install it... 1 attempt
                2023-11-09 14:05:43.799  - info: host.ioBrokerVM iobroker install iot@1.14.5 using installedFrom
                2023-11-09 14:05:45.448  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                2023-11-09 14:05:45.449  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.iot@1.14.5... (System call)
                2023-11-09 14:05:56.266  - info: host.ioBrokerVM iobroker npm-install: added 82 packages in 11s
                2023-11-09 14:05:56.267  - info: host.ioBrokerVM iobroker npm-install: 124 packages are looking for funding
                2023-11-09 14:05:56.270  - info: host.ioBrokerVM iobroker npm-install:   run `npm fund` for details
                2023-11-09 14:05:56.298  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter iot@1.14.5
                2023-11-09 14:05:57.781  - info: host.ioBrokerVM iobroker npm-install: upload [132] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
                2023-11-09 14:06:02.982  - info: host.ioBrokerVM iobroker npm-install: upload [100] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Cold Water.937aad5fa21b0c20a856.svg static/media/Cold Water.937aad5fa21b0c20a856.svg image/svg+xml
                2023-11-09 14:06:03.012  - info: host.ioBrokerVM iobroker npm-install: upload [90] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Doorstep.10630b759b4867a10776.svg static/media/Doorstep.10630b759b4867a10776.svg image/svg+xml
                2023-11-09 14:06:03.038  - info: host.ioBrokerVM iobroker npm-install: upload [80] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Garage Doors.0c2a1cfca7ad1ea59625.svg static/media/Garage Doors.0c2a1cfca7ad1ea59625.svg image/svg+xml
                2023-11-09 14:06:03.065  - info: host.ioBrokerVM iobroker npm-install: upload [70] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Handle.3de1d1320fc3ce2f9712.svg static/media/Handle.3de1d1320fc3ce2f9712.svg image/svg+xml
                2023-11-09 14:06:03.091  - info: host.ioBrokerVM iobroker npm-install: upload [60] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Laundry Room.58da550dff0173676e02.svg static/media/Laundry Room.58da550dff0173676e02.svg image/svg+xml
                2023-11-09 14:06:03.118  - info: host.ioBrokerVM iobroker npm-install: upload [50] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Music.67bc6063cb601642fd74.svg static/media/Music.67bc6063cb601642fd74.svg image/svg+xml
                2023-11-09 14:06:03.145  - info: host.ioBrokerVM iobroker npm-install: upload [40] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Pump.a6035507cddbe7db5f6a.svg static/media/Pump.a6035507cddbe7db5f6a.svg image/svg+xml
                2023-11-09 14:06:03.173  - info: host.ioBrokerVM iobroker npm-install: upload [30] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/SmokeDetector.8222f77cb07030a409ee.svg static/media/SmokeDetector.8222f77cb07030a409ee.svg image/svg+xml
                2023-11-09 14:06:03.202  - info: host.ioBrokerVM iobroker npm-install: upload [20] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Temperature Sensors.75d805988a6b77b231d8.svg static/media/Temperature Sensors.75d805988a6b77b231d8.svg image/svg+xml
                2023-11-09 14:06:03.205  - info: host.ioBrokerVM iobroker npm-install: upload [19] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Terrace.d71d07d9290674f2ca20.svg static/media/Terrace.d71d07d9290674f2ca20.svg image/svg+xml
                2023-11-09 14:06:03.209  - info: host.ioBrokerVM iobroker npm-install: upload [18] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
                2023-11-09 14:06:03.212  - info: host.ioBrokerVM iobroker npm-install: upload [17] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Tv.4e9745a548e57bfac0c7.svg static/media/Tv.4e9745a548e57bfac0c7.svg image/svg+xml
                2023-11-09 14:06:03.216  - info: host.ioBrokerVM iobroker npm-install: upload [16] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Upstairs.441813e54e0daca0882d.svg static/media/Upstairs.441813e54e0daca0882d.svg image/svg+xml
                2023-11-09 14:06:03.219  - info: host.ioBrokerVM iobroker npm-install: upload [15] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml
                2023-11-09 14:06:03.222  - info: host.ioBrokerVM iobroker npm-install: upload [14] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Ventilation.c31761d86d67e245ac92.svg static/media/Ventilation.c31761d86d67e245ac92.svg image/svg+xml
                2023-11-09 14:06:03.226  - info: host.ioBrokerVM iobroker npm-install: upload [13] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Wardrobe.e8019970a2b51412cfdc.svg static/media/Wardrobe.e8019970a2b51412cfdc.svg image/svg+xml
                2023-11-09 14:06:03.230  - info: host.ioBrokerVM iobroker npm-install: upload [12] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Washing Machines.577f3acdb3cef002b523.svg static/media/Washing Machines.577f3acdb3cef002b523.svg image/svg+xml
                2023-11-09 14:06:03.234  - info: host.ioBrokerVM iobroker npm-install: upload [11] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Washroom.bfb54196f381f36de9d6.svg static/media/Washroom.bfb54196f381f36de9d6.svg image/svg+xml
                2023-11-09 14:06:03.239  - info: host.ioBrokerVM iobroker npm-install: upload [10] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Water Consumption.68891649591cc2434c5b.svg static/media/Water Consumption.68891649591cc2434c5b.svg image/svg+xml
                2023-11-09 14:06:03.242  - info: host.ioBrokerVM iobroker npm-install: upload [9] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Water Heater.7e4bb4d99a5213f24d08.svg static/media/Water Heater.7e4bb4d99a5213f24d08.svg image/svg+xml
                2023-11-09 14:06:03.246  - info: host.ioBrokerVM iobroker npm-install: upload [8] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Water.f50411984c5c24fa574d.svg static/media/Water.f50411984c5c24fa574d.svg image/svg+xml
                2023-11-09 14:06:03.250  - info: host.ioBrokerVM iobroker npm-install: upload [7] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Wc.83604dd2daafb67067dd.svg static/media/Wc.83604dd2daafb67067dd.svg image/svg+xml
                2023-11-09 14:06:03.253  - info: host.ioBrokerVM iobroker npm-install: upload [6] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Weather.e91dae647698d48365e3.svg static/media/Weather.e91dae647698d48365e3.svg image/svg+xml
                2023-11-09 14:06:03.257  - info: host.ioBrokerVM iobroker npm-install: upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Window.421664f57c35e5109aa2.svg static/media/Window.421664f57c35e5109aa2.svg image/svg+xml
                2023-11-09 14:06:03.260  - info: host.ioBrokerVM iobroker npm-install: upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Windscreen.6058448bf63f72dd5036.svg static/media/Windscreen.6058448bf63f72dd5036.svg image/svg+xml
                2023-11-09 14:06:03.263  - info: host.ioBrokerVM iobroker npm-install: upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
                2023-11-09 14:06:03.267  - info: host.ioBrokerVM iobroker npm-install: upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Workspace.97d73e419d966bfb6428.svg static/media/Workspace.97d73e419d966bfb6428.svg image/svg+xml
                2023-11-09 14:06:03.270  - info: host.ioBrokerVM iobroker npm-install: upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/names.3a7dae0bd6b8b03b280f.txt static/media/names.3a7dae0bd6b8b03b280f.txt text/plain
                2023-11-09 14:06:03.273  - info: host.ioBrokerVM iobroker npm-install: upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                2023-11-09 14:06:03.402  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.iot created/updated
                2023-11-09 14:06:04.578  - info: host.ioBrokerVM iobroker npm-install: exit 0
                2023-11-09 14:06:05.579  - warn: host.ioBrokerVM startInstance cannot find adapter "mobile@1.0.1". Try to install it... 1 attempt
                2023-11-09 14:06:05.579  - info: host.ioBrokerVM iobroker install mobile@1.0.1 using installedFrom
                2023-11-09 14:06:07.137  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                2023-11-09 14:06:07.138  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.mobile@1.0.1... (System call)
                2023-11-09 14:06:11.607  - info: host.ioBrokerVM iobroker npm-install: added 2 packages in 4s
                2023-11-09 14:06:11.608  - info: host.ioBrokerVM iobroker npm-install:
                2023-11-09 14:06:11.608  - info: host.ioBrokerVM iobroker npm-install: 124 packages are looking for funding
                2023-11-09 14:06:11.608  - info: host.ioBrokerVM iobroker npm-install:   run `npm fund` for details
                2023-11-09 14:06:11.629  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter mobile@1.0.1
                2023-11-09 14:06:11.635  - info: host.ioBrokerVM iobroker npm-install: upload [1] mobile.admin /opt/iobroker/node_modules/iobroker.mobile/admin/index.html index.html text/html
                2023-11-09 14:06:11.708  - info: host.ioBrokerVM iobroker npm-install: upload [0] mobile.admin /opt/iobroker/node_modules/iobroker.mobile/admin/mobile.png mobile.png image/png
                2023-11-09 14:06:11.749  - info: host.ioBrokerVM iobroker npm-install: upload [69] mobile /opt/iobroker/node_modules/iobroker.mobile/www/cache.manifest cache.manifest text/cache-manifest
                2023-11-09 14:06:11.780  - info: host.ioBrokerVM iobroker npm-install: upload [60] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/blind0.png img/blind0.png image/png
                2023-11-09 14:06:11.805  - info: host.ioBrokerVM iobroker npm-install: upload [50] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/blind90.png img/blind90.png image/png
                2023-11-09 14:06:11.830  - info: host.ioBrokerVM iobroker npm-install: upload [40] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/rgb-green.png img/rgb-green.png image/png
                2023-11-09 14:06:11.854  - info: host.ioBrokerVM iobroker npm-install: upload [30] mobile /opt/iobroker/node_modules/iobroker.mobile/www/img/windowClosed.png img/windowClosed.png image/png
                2023-11-09 14:06:11.880  - info: host.ioBrokerVM iobroker npm-install: upload [20] mobile /opt/iobroker/node_modules/iobroker.mobile/www/js/i18n/nl/translations.json js/i18n/nl/translations.json application/json
                2023-11-09 14:06:11.884  - info: host.ioBrokerVM iobroker npm-install: upload [19] mobile /opt/iobroker/node_modules/iobroker.mobile/www/js/i18n/pl/translations.json js/i18n/pl/translations.json application/json
                2023-11-09 14:06:11.887  - info: host.ioBrokerVM iobroker npm-install: upload [18] mobile /opt/iobroker/node_modules/iobroker.mobile/www/js/i18n/pt/translations.json js/i18n/pt/translations.json application/json
                2023-11-09 14:06:11.891  - info: host.ioBrokerVM iobroker npm-install: upload [17] mobile /opt/iobroker/node_modules/iobroker.mobile/www/js/i18n/ru/translations.json js/i18n/ru/translations.json application/json
                2023-11-09 14:06:11.894  - info: host.ioBrokerVM iobroker npm-install: upload [16] mobile /opt/iobroker/node_modules/iobroker.mobile/www/js/i18n/zh-cn/translations.json js/i18n/zh-cn/translations.json application/json
                2023-11-09 14:06:11.897  - info: host.ioBrokerVM iobroker npm-install: upload [15] mobile /opt/iobroker/node_modules/iobroker.mobile/www/js/mobile.js js/mobile.js application/javascript
                2023-11-09 14:06:11.901  - info: host.ioBrokerVM iobroker npm-install: upload [14] mobile /opt/iobroker/node_modules/iobroker.mobile/www/js/words.js js/words.js application/javascript
                2023-11-09 14:06:11.906  - info: host.ioBrokerVM iobroker npm-install: upload [13] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/css/default/images/ajax-loader.gif lib/css/default/images/ajax-loader.gif image/gif
                2023-11-09 14:06:11.909  - info: host.ioBrokerVM iobroker npm-install: upload [12] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/css/default/jquery.mobile.icons.min.css lib/css/default/jquery.mobile.icons.min.css text/css
                2023-11-09 14:06:11.914  - info: host.ioBrokerVM iobroker npm-install: upload [11] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/css/default/jquery.mobile.min.css lib/css/default/jquery.mobile.min.css text/css
                2023-11-09 14:06:11.917  - info: host.ioBrokerVM iobroker npm-install: upload [10] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/css/grey/images/ajax-loader.gif lib/css/grey/images/ajax-loader.gif image/gif
                2023-11-09 14:06:11.921  - info: host.ioBrokerVM iobroker npm-install: upload [9] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/css/grey/jquery.mobile.icons.min.css lib/css/grey/jquery.mobile.icons.min.css text/css
                2023-11-09 14:06:11.926  - info: host.ioBrokerVM iobroker npm-install: upload [8] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/css/grey/jquery.mobile.min.css lib/css/grey/jquery.mobile.min.css text/css
                2023-11-09 14:06:11.930  - info: host.ioBrokerVM iobroker npm-install: upload [7] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/css/jquery.mobile.structure-1.4.5.min.css lib/css/jquery.mobile.structure-1.4.5.min.css text/css
                2023-11-09 14:06:11.933  - info: host.ioBrokerVM iobroker npm-install: upload [6] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/css/light/jquery.mobile.icons.min.css lib/css/light/jquery.mobile.icons.min.css text/css
                2023-11-09 14:06:11.937  - info: host.ioBrokerVM iobroker npm-install: upload [5] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/css/light/jquery.mobile.min.css lib/css/light/jquery.mobile.min.css text/css
                2023-11-09 14:06:11.940  - info: host.ioBrokerVM iobroker npm-install: upload [4] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/js/jquery.mobile-1.4.5.min.js lib/js/jquery.mobile-1.4.5.min.js application/javascript
                2023-11-09 14:06:11.944  - info: host.ioBrokerVM iobroker npm-install: upload [3] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/js/jquery.mobile-1.4.5.min.map lib/js/jquery.mobile-1.4.5.min.map application/json
                2023-11-09 14:06:11.949  - info: host.ioBrokerVM iobroker npm-install: upload [2] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/js/jquery.ui.touch-punch.min.js lib/js/jquery.ui.touch-punch.min.js application/javascript
                2023-11-09 14:06:11.952  - info: host.ioBrokerVM iobroker npm-install: upload [1] mobile /opt/iobroker/node_modules/iobroker.mobile/www/lib/js/loStorage.min.js lib/js/loStorage.min.js application/javascript
                2023-11-09 14:06:11.955  - info: host.ioBrokerVM iobroker npm-install: upload [0] mobile /opt/iobroker/node_modules/iobroker.mobile/www/offline.html offline.html text/html
                2023-11-09 14:06:12.050  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.mobile created/updated
                2023-11-09 14:06:12.097  - info: host.ioBrokerVM iobroker npm-install: Update "system.adapter.mobile.0"
                2023-11-09 14:06:13.120  - info: host.ioBrokerVM iobroker npm-install: exit 0
                2023-11-09 14:06:14.120  - warn: host.ioBrokerVM startInstance cannot find adapter "pi-hole@1.3.6". Try to install it... 1 attempt
                2023-11-09 14:06:14.121  - info: host.ioBrokerVM iobroker install pi-hole@1.3.6 using installedFrom
                2023-11-09 14:06:15.736  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1Installing iobroker.pi-hole@1.3.6... (System call)
                2023-11-09 14:06:21.920  - info: host.ioBrokerVM iobroker npm-install: added 14 packages in 6s
                2023-11-09 14:06:21.921  - info: host.ioBrokerVM iobroker npm-install:
                2023-11-09 14:06:21.922  - info: host.ioBrokerVM iobroker npm-install: 129 packages are looking for funding
                2023-11-09 14:06:21.922  - info: host.ioBrokerVM iobroker npm-install:   run `npm fund` for details
                2023-11-09 14:06:21.943  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter pi-hole@1.3.6
                2023-11-09 14:06:22.013  - info: host.ioBrokerVM iobroker npm-install: upload [4] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/admin.d.ts admin.d.ts video/mp2t
                2023-11-09 14:06:22.021  - info: host.ioBrokerVM iobroker npm-install: upload [3] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/index_m.html index_m.html text/html
                2023-11-09 14:06:22.024  - info: host.ioBrokerVM iobroker npm-install: upload [2] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/pi-hole.png pi-hole.png image/png
                2023-11-09 14:06:22.028  - info: host.ioBrokerVM iobroker npm-install: upload [1] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/style.css style.css text/css
                2023-11-09 14:06:22.031  - info: host.ioBrokerVM iobroker npm-install: upload [0] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/words.js words.js application/javascript
                2023-11-09 14:06:22.045  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.pi-hole created/updated
                2023-11-09 14:06:23.108  - info: host.ioBrokerVM iobroker npm-install: exit 0
                2023-11-09 14:06:24.109  - warn: host.ioBrokerVM startInstance cannot find adapter "pvforecast@2.8.1". Try to install it... 1 attempt
                2023-11-09 14:06:24.109  - info: host.ioBrokerVM iobroker install pvforecast@2.8.1 using installedFrom
                2023-11-09 14:06:25.728  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1Installing iobroker.pvforecast@2.8.1... (System call)
                2023-11-09 14:06:30.535  - info: host.ioBrokerVM iobroker npm-install: added 4 packages in 5s129 packages are looking for funding  run `npm fund` for details
                2023-11-09 14:06:30.556  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter pvforecast@2.8.1
                2023-11-09 14:06:30.631  - info: host.ioBrokerVM iobroker npm-install: upload [14] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/de/translations.json i18n/de/translations.json application/json
                2023-11-09 14:06:30.638  - info: host.ioBrokerVM iobroker npm-install: upload [13] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/en/translations.json i18n/en/translations.json application/json
                2023-11-09 14:06:30.642  - info: host.ioBrokerVM iobroker npm-install: upload [12] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/es/translations.json i18n/es/translations.json application/json
                2023-11-09 14:06:30.645  - info: host.ioBrokerVM iobroker npm-install: upload [11] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                2023-11-09 14:06:30.649  - info: host.ioBrokerVM iobroker npm-install: upload [10] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/it/translations.json i18n/it/translations.json application/json
                2023-11-09 14:06:30.652  - info: host.ioBrokerVM iobroker npm-install: upload [9] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                2023-11-09 14:06:30.656  - info: host.ioBrokerVM iobroker npm-install: upload [8] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                2023-11-09 14:06:30.659  - info: host.ioBrokerVM iobroker npm-install: upload [7] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                2023-11-09 14:06:30.663  - info: host.ioBrokerVM iobroker npm-install: upload [6] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                2023-11-09 14:06:30.667  - info: host.ioBrokerVM iobroker npm-install: upload [5] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                2023-11-09 14:06:30.670  - info: host.ioBrokerVM iobroker npm-install: upload [4] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                2023-11-09 14:06:30.673  - info: host.ioBrokerVM iobroker npm-install: upload [3] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/img/Azimuth.png img/Azimuth.png image/png
                2023-11-09 14:06:30.678  - info: host.ioBrokerVM iobroker npm-install: upload [2] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/jsonConfig.json jsonConfig.json application/json
                2023-11-09 14:06:30.681  - info: host.ioBrokerVM iobroker npm-install: upload [1] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/pvforecast.png pvforecast.png image/png
                2023-11-09 14:06:30.685  - info: host.ioBrokerVM iobroker npm-install: upload [0] pvforecast.admin /opt/iobroker/node_modules/iobroker.pvforecast/admin/style.css style.css text/css
                2023-11-09 14:06:30.778  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.pvforecast created/updated
                2023-11-09 14:06:31.844  - info: host.ioBrokerVM iobroker npm-install: exit 0
                2023-11-09 14:06:32.845  - warn: host.ioBrokerVM startInstance cannot find adapter "smartcontrol@2.0.1". Try to install it... 1 attempt
                2023-11-09 14:06:32.845  - info: host.ioBrokerVM iobroker install smartcontrol@2.0.1 using installedFrom
                2023-11-09 14:06:34.428  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                2023-11-09 14:06:34.430  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.smartcontrol@2.0.1... (System call)
                2023-11-09 14:06:39.890  - info: host.ioBrokerVM iobroker npm-install: added 15 packages in 5s
                2023-11-09 14:06:39.891  - info: host.ioBrokerVM iobroker npm-install:
                2023-11-09 14:06:39.891  - info: host.ioBrokerVM iobroker npm-install: 140 packages are looking for funding
                2023-11-09 14:06:39.892  - info: host.ioBrokerVM iobroker npm-install:   run `npm fund` for details
                2023-11-09 14:06:39.915  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter smartcontrol@2.0.1
                2023-11-09 14:06:39.991  - info: host.ioBrokerVM iobroker npm-install: upload [81] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/admin.d.ts admin.d.ts video/mp2t
                2023-11-09 14:06:39.999  - info: host.ioBrokerVM iobroker npm-install: upload [80] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/doc-md/img/check_box-24px.svg doc-md/img/check_box-24px.svg image/svg+xml
                2023-11-09 14:06:40.036  - info: host.ioBrokerVM iobroker npm-install: upload [70] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/doc-md/img/table-zones_select-target-devices-overwrite.gif doc-md/img/table-zones_select-target-devices-overwrite.gif image/gif
                2023-11-09 14:06:40.065  - info: host.ioBrokerVM iobroker npm-install: upload [60] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/doc-md/table-target-devices_de.md doc-md/table-target-devices_de.md text/markdown
                2023-11-09 14:06:40.093  - info: host.ioBrokerVM iobroker npm-install: upload [50] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/doc-md/table-trigger-times_de.md doc-md/table-trigger-times_de.md text/markdown
                2023-11-09 14:06:40.120  - info: host.ioBrokerVM iobroker npm-install: upload [40] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/fancytree/skin-lion/vline-rtl.gif fancytree/skin-lion/vline-rtl.gif image/gif
                2023-11-09 14:06:40.145  - info: host.ioBrokerVM iobroker npm-install: upload [30] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                2023-11-09 14:06:40.172  - info: host.ioBrokerVM iobroker npm-install: upload [20] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/option-screenshots/tab-target-devices.png img/option-screenshots/tab-target-devices.png image/png
                2023-11-09 14:06:40.175  - info: host.ioBrokerVM iobroker npm-install: upload [19] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/option-screenshots/tab-triggers-motion.png img/option-screenshots/tab-triggers-motion.png image/png
                2023-11-09 14:06:40.179  - info: host.ioBrokerVM iobroker npm-install: upload [18] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/option-screenshots/tab-triggers-other.png img/option-screenshots/tab-triggers-other.png image/png
                2023-11-09 14:06:40.182  - info: host.ioBrokerVM iobroker npm-install: upload [17] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/option-screenshots/tab-triggers-time.png img/option-screenshots/tab-triggers-time.png image/png
                2023-11-09 14:06:40.186  - info: host.ioBrokerVM iobroker npm-install: upload [16] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/option-screenshots/tab-zones-execution.png img/option-screenshots/tab-zones-execution.png image/png
                2023-11-09 14:06:40.189  - info: host.ioBrokerVM iobroker npm-install: upload [15] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/option-screenshots/tab-zones.png img/option-screenshots/tab-zones.png image/png
                2023-11-09 14:06:40.193  - info: host.ioBrokerVM iobroker npm-install: upload [14] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/sc_always.png img/sc_always.png image/png
                2023-11-09 14:06:40.196  - info: host.ioBrokerVM iobroker npm-install: upload [13] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/select-target-devices-overwrite.gif img/select-target-devices-overwrite.gif image/gif
                2023-11-09 14:06:40.199  - info: host.ioBrokerVM iobroker npm-install: upload [12] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/smartControl_options1.gif img/smartControl_options1.gif image/gif
                2023-11-09 14:06:40.213  - info: host.ioBrokerVM iobroker npm-install: upload [11] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/smartControl_options_dropdown.gif img/smartControl_options_dropdown.gif image/gif
                2023-11-09 14:06:40.217  - info: host.ioBrokerVM iobroker npm-install: upload [10] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/img/smartControl_options_dropdown_2.gif img/smartControl_options_dropdown_2.gif image/gif
                2023-11-09 14:06:40.221  - info: host.ioBrokerVM iobroker npm-install: upload [9] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/index_m.html index_m.html text/html
                2023-11-09 14:06:40.225  - info: host.ioBrokerVM iobroker npm-install: upload [8] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/index_m.js index_m.js application/javascript
                2023-11-09 14:06:40.228  - info: host.ioBrokerVM iobroker npm-install: upload [7] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/smartcontrol-banner.png smartcontrol-banner.png image/png
                2023-11-09 14:06:40.232  - info: host.ioBrokerVM iobroker npm-install: upload [6] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/smartcontrol.png smartcontrol.png image/png
                2023-11-09 14:06:40.235  - info: host.ioBrokerVM iobroker npm-install: upload [5] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/style.css style.css text/css
                2023-11-09 14:06:40.239  - info: host.ioBrokerVM iobroker npm-install: upload [4] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/tsconfig.json tsconfig.json application/json
                2023-11-09 14:06:40.243  - info: host.ioBrokerVM iobroker npm-install: upload [3] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/words.js words.js application/javascript
                2023-11-09 14:06:40.247  - info: host.ioBrokerVM iobroker npm-install: upload [2] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/zero-md/readme.txt zero-md/readme.txt text/plain
                2023-11-09 14:06:40.250  - info: host.ioBrokerVM iobroker npm-install: upload [1] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/zero-md/webcomponents-loader.min.js zero-md/webcomponents-loader.min.js application/javascript
                2023-11-09 14:06:40.253  - info: host.ioBrokerVM iobroker npm-install: upload [0] smartcontrol.admin /opt/iobroker/node_modules/iobroker.smartcontrol/admin/zero-md/zero-md.min.js.js zero-md/zero-md.min.js.js application/javascript
                2023-11-09 14:06:40.344  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.smartcontrol created/updated
                2023-11-09 14:06:41.412  - info: host.ioBrokerVM iobroker npm-install: exit 0
                2023-11-09 14:06:42.412  - warn: host.ioBrokerVM startInstance cannot find adapter "socketio@6.5.5". Try to install it... 1 attempt
                2023-11-09 14:06:42.413  - info: host.ioBrokerVM iobroker install socketio@6.5.5 using installedFrom
                2023-11-09 14:06:44.040  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1Installing iobroker.socketio@6.5.5... (System call)
                2023-11-09 14:06:49.603  - info: host.ioBrokerVM iobroker npm-install: added 41 packages in 5s140 packages are looking for funding  run `npm fund` for details
                2023-11-09 14:06:49.624  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter socketio@6.5.5
                2023-11-09 14:06:49.697  - info: host.ioBrokerVM iobroker npm-install: upload [11] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/de/translations.json i18n/de/translations.json application/json
                2023-11-09 14:06:49.704  - info: host.ioBrokerVM iobroker npm-install: upload [10] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/en/translations.json i18n/en/translations.json application/json
                2023-11-09 14:06:49.707  - info: host.ioBrokerVM iobroker npm-install: upload [9] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/es/translations.json i18n/es/translations.json application/json
                2023-11-09 14:06:49.710  - info: host.ioBrokerVM iobroker npm-install: upload [8] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                2023-11-09 14:06:49.714  - info: host.ioBrokerVM iobroker npm-install: upload [7] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/it/translations.json i18n/it/translations.json application/json
                2023-11-09 14:06:49.717  - info: host.ioBrokerVM iobroker npm-install: upload [6] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                2023-11-09 14:06:49.721  - info: host.ioBrokerVM iobroker npm-install: upload [5] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                2023-11-09 14:06:49.724  - info: host.ioBrokerVM iobroker npm-install: upload [4] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                2023-11-09 14:06:49.727  - info: host.ioBrokerVM iobroker npm-install: upload [3] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                2023-11-09 14:06:49.730  - info: host.ioBrokerVM iobroker npm-install: upload [2] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                2023-11-09 14:06:49.733  - info: host.ioBrokerVM iobroker npm-install: upload [1] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/jsonConfig.json jsonConfig.json application/json
                2023-11-09 14:06:49.736  - info: host.ioBrokerVM iobroker npm-install: upload [0] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/socketio.png socketio.png image/png
                2023-11-09 14:06:49.857  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.socketio created/updated
                2023-11-09 14:06:50.920  - info: host.ioBrokerVM iobroker npm-install: exit 0
                2023-11-09 14:06:51.921  - warn: host.ioBrokerVM startInstance cannot find adapter "tado@0.4.9". Try to install it... 1 attempt
                2023-11-09 14:06:51.921  - info: host.ioBrokerVM iobroker install tado@0.4.9 using installedFrom
                2023-11-09 14:06:53.545  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                2023-11-09 14:06:53.546  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.tado@0.4.9... (System call)
                2023-11-09 14:07:07.999  - info: host.ioBrokerVM iobroker npm-install:
                2023-11-09 14:07:08.000  - info: host.ioBrokerVM iobroker npm-install: added 27 packages in 14s149 packages are looking for funding  run `npm fund` for details
                2023-11-09 14:07:08.023  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter tado@0.4.9
                2023-11-09 14:07:08.098  - info: host.ioBrokerVM iobroker npm-install: upload [6] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/admin.d.ts admin.d.ts video/mp2t
                2023-11-09 14:07:08.105  - info: host.ioBrokerVM iobroker npm-install: upload [5] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/button.png button.png image/png
                2023-11-09 14:07:08.109  - info: host.ioBrokerVM iobroker npm-install: upload [4] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/index_m.html index_m.html text/html
                2023-11-09 14:07:08.112  - info: host.ioBrokerVM iobroker npm-install: upload [3] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/jsonConfig.json jsonConfig.json application/json
                2023-11-09 14:07:08.115  - info: host.ioBrokerVM iobroker npm-install: upload [2] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/style.css style.css text/css
                2023-11-09 14:07:08.121  - info: host.ioBrokerVM iobroker npm-install: upload [1] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/tado.png tado.png image/png
                2023-11-09 14:07:08.125  - info: host.ioBrokerVM iobroker npm-install: upload [0] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/words.js words.js application/javascript
                2023-11-09 14:07:08.225  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.tado created/updated
                2023-11-09 14:07:09.286  - info: host.ioBrokerVM iobroker npm-install: exit 0
                2023-11-09 14:07:10.286  - warn: host.ioBrokerVM startInstance cannot find adapter "tibberlink@1.0.0". Try to install it... 1 attempt
                2023-11-09 14:07:10.286  - info: host.ioBrokerVM iobroker install tibberlink@1.0.0 using installedFrom
                2023-11-09 14:07:11.896  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                2023-11-09 14:07:11.897  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.tibberlink@1.0.0... (System call)
                2023-11-09 14:07:17.244  - info: host.ioBrokerVM iobroker npm-install: added 2 packages in 5s149 packages are looking for funding  run `npm fund` for details
                2023-11-09 14:07:17.264  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter tibberlink@1.0.0
                2023-11-09 14:07:17.337  - info: host.ioBrokerVM iobroker npm-install: upload [12] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/de/translations.json i18n/de/translations.json application/json
                2023-11-09 14:07:17.345  - info: host.ioBrokerVM iobroker npm-install: upload [11] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/en/translations.json i18n/en/translations.json application/json
                2023-11-09 14:07:17.348  - info: host.ioBrokerVM iobroker npm-install: upload [10] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/es/translations.json i18n/es/translations.json application/json
                2023-11-09 14:07:17.351  - info: host.ioBrokerVM iobroker npm-install: upload [9] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                2023-11-09 14:07:17.355  - info: host.ioBrokerVM iobroker npm-install: upload [8] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/it/translations.json i18n/it/translations.json application/json
                2023-11-09 14:07:17.359  - info: host.ioBrokerVM iobroker npm-install: upload [7] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                2023-11-09 14:07:17.362  - info: host.ioBrokerVM iobroker npm-install: upload [6] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                2023-11-09 14:07:17.366  - info: host.ioBrokerVM iobroker npm-install: upload [5] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                2023-11-09 14:07:17.369  - info: host.ioBrokerVM iobroker npm-install: upload [4] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                2023-11-09 14:07:17.373  - info: host.ioBrokerVM iobroker npm-install: upload [3] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                2023-11-09 14:07:17.376  - info: host.ioBrokerVM iobroker npm-install: upload [2] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                2023-11-09 14:07:17.379  - info: host.ioBrokerVM iobroker npm-install: upload [1] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/jsonConfig.json jsonConfig.json application/json
                2023-11-09 14:07:17.383  - info: host.ioBrokerVM iobroker npm-install: upload [0] tibberlink.admin /opt/iobroker/node_modules/iobroker.tibberlink/admin/tibberlink.png tibberlink.png image/png
                2023-11-09 14:07:17.476  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.tibberlink created/updated
                2023-11-09 14:07:18.536  - info: host.ioBrokerVM iobroker npm-install: exit 0
                2023-11-09 14:07:19.536  - warn: host.ioBrokerVM startInstance cannot find adapter "vis-hqwidgets@1.4.0". Try to install it... 1 attempt
                2023-11-09 14:07:19.537  - info: host.ioBrokerVM iobroker install vis-hqwidgets@1.4.0 using installedFrom
                2023-11-09 14:07:21.131  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1Installing iobroker.vis-hqwidgets@1.4.0... (System call)
                2023-11-09 14:07:25.562  - info: host.ioBrokerVM iobroker npm-install: added 1 package in 4s149 packages are looking for funding  run `npm fund` for details
                2023-11-09 14:07:25.582  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter vis-hqwidgets@1.4.0
                2023-11-09 14:07:25.653  - info: host.ioBrokerVM iobroker npm-install: upload [1] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/hqwidgets.png hqwidgets.png image/png
                2023-11-09 14:07:25.660  - info: host.ioBrokerVM iobroker npm-install: upload [0] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/index.html index.html text/html
                2023-11-09 14:07:25.667  - info: host.ioBrokerVM iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-hqwidgets/www" was not found! Nothing was uploaded or deleted.
                2023-11-09 14:07:25.785  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.vis-hqwidgets created/updated
                2023-11-09 14:07:26.849  - info: host.ioBrokerVM iobroker npm-install: exit 0
                2023-11-09 14:07:27.849  - warn: host.ioBrokerVM startInstance cannot find adapter "vis-jqui-mfd@1.0.12". Try to install it... 1 attempt
                2023-11-09 14:07:27.850  - info: host.ioBrokerVM iobroker install vis-jqui-mfd@1.0.12 using installedFrom
                2023-11-09 14:07:29.442  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                2023-11-09 14:07:29.444  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis-jqui-mfd@1.0.12... (System call)
                2023-11-09 14:07:33.873  - info: host.ioBrokerVM iobroker npm-install: added 1 package in 4s
                2023-11-09 14:07:33.874  - info: host.ioBrokerVM iobroker npm-install:
                2023-11-09 14:07:33.874  - info: host.ioBrokerVM iobroker npm-install: 149 packages are looking for funding
                2023-11-09 14:07:33.875  - info: host.ioBrokerVM iobroker npm-install:   run `npm fund` for details
                2023-11-09 14:07:33.898  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter vis-jqui-mfd@1.0.12
                2023-11-09 14:07:33.968  - info: host.ioBrokerVM iobroker npm-install: upload [0] vis-jqui-mfd.admin /opt/iobroker/node_modules/iobroker.vis-jqui-mfd/admin/jqui-mfd.png jqui-mfd.png image/png
                2023-11-09 14:07:33.976  - info: host.ioBrokerVM iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-jqui-mfd/www" was not found! Nothing was uploaded or deleted.
                2023-11-09 14:07:34.095  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.vis-jqui-mfd created/updated
                2023-11-09 14:07:34.142  - info: host.ioBrokerVM iobroker npm-install: Update "system.adapter.vis-jqui-mfd.0"
                2023-11-09 14:07:35.159  - info: host.ioBrokerVM iobroker npm-install: exit 0
                2023-11-09 14:07:36.160  - warn: host.ioBrokerVM startInstance cannot find adapter "vis-material-advanced@1.7.4". Try to install it... 1 attempt
                2023-11-09 14:07:36.160  - info: host.ioBrokerVM iobroker install vis-material-advanced@1.7.4 using installedFrom
                2023-11-09 14:07:37.726  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                2023-11-09 14:07:37.726  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis-material-advanced@1.7.4... (System call)
                2023-11-09 14:07:42.344  - info: host.ioBrokerVM iobroker npm-install: added 1 package in 4s
                2023-11-09 14:07:42.345  - info: host.ioBrokerVM iobroker npm-install:
                2023-11-09 14:07:42.345  - info: host.ioBrokerVM iobroker npm-install: 149 packages are looking for funding
                2023-11-09 14:07:42.345  - info: host.ioBrokerVM iobroker npm-install:   run `npm fund` for details
                2023-11-09 14:07:42.370  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter vis-material-advanced@1.7.4
                2023-11-09 14:07:42.445  - info: host.ioBrokerVM iobroker npm-install: upload [1] vis-material-advanced.admin /opt/iobroker/node_modules/iobroker.vis-material-advanced/admin/vis-material-advanced.png vis-material-advanced.png image/png
                2023-11-09 14:07:42.451  - info: host.ioBrokerVM iobroker npm-install: upload [0] vis-material-advanced.admin /opt/iobroker/node_modules/iobroker.vis-material-advanced/admin/words.js words.js application/javascript
                2023-11-09 14:07:42.455  - info: host.ioBrokerVM iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-material-advanced/www" was not found! Nothing was uploaded or deleted.
                2023-11-09 14:07:42.575  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.vis-material-advanced created/updated
                2023-11-09 14:07:43.640  - info: host.ioBrokerVM iobroker npm-install: exit 0
                2023-11-09 14:07:44.641  - warn: host.ioBrokerVM startInstance cannot find adapter "vis-metro@1.2.0". Try to install it... 1 attempt
                2023-11-09 14:07:44.641  - info: host.ioBrokerVM iobroker install vis-metro@1.2.0 using installedFrom
                2023-11-09 14:07:46.237  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                2023-11-09 14:07:46.239  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis-metro@1.2.0... (System call)
                2023-11-09 14:07:50.907  - info: host.ioBrokerVM iobroker npm-install: added 3 packages in 4s149 packages are looking for funding  run `npm fund` for details
                2023-11-09 14:07:50.930  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter vis-metro@1.2.0
                2023-11-09 14:07:51.001  - info: host.ioBrokerVM iobroker npm-install: upload [1] vis-metro.admin /opt/iobroker/node_modules/iobroker.vis-metro/admin/index.html index.html text/html
                2023-11-09 14:07:51.008  - info: host.ioBrokerVM iobroker npm-install: upload [0] vis-metro.admin /opt/iobroker/node_modules/iobroker.vis-metro/admin/metro.png metro.png image/png
                2023-11-09 14:07:51.013  - info: host.ioBrokerVM iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-metro/www" was not found! Nothing was uploaded or deleted.
                2023-11-09 14:07:51.132  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.vis-metro created/updated
                2023-11-09 14:07:52.192  - info: host.ioBrokerVM iobroker npm-install: exit 0
                2023-11-09 14:07:53.193  - warn: host.ioBrokerVM startInstance cannot find adapter "vis-timeandweather@1.2.2". Try to install it... 1 attempt
                2023-11-09 14:07:53.193  - info: host.ioBrokerVM iobroker install vis-timeandweather@1.2.2 using installedFrom
                2023-11-09 14:07:54.800  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1Installing iobroker.vis-timeandweather@1.2.2... (System call)
                2023-11-09 14:07:59.358  - info: host.ioBrokerVM iobroker npm-install: added 2 packages in 4s149 packages are looking for funding  run `npm fund` for details
                2023-11-09 14:07:59.378  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter vis-timeandweather@1.2.2
                2023-11-09 14:07:59.448  - info: host.ioBrokerVM iobroker npm-install: upload [1] vis-timeandweather.admin /opt/iobroker/node_modules/iobroker.vis-timeandweather/admin/index.html index.html text/html
                2023-11-09 14:07:59.455  - info: host.ioBrokerVM iobroker npm-install: upload [0] vis-timeandweather.admin /opt/iobroker/node_modules/iobroker.vis-timeandweather/admin/timeandweather.png timeandweather.png image/png
                2023-11-09 14:07:59.461  - info: host.ioBrokerVM iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-timeandweather/www" was not found! Nothing was uploaded or deleted.
                2023-11-09 14:07:59.579  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.vis-timeandweather created/updated
                2023-11-09 14:08:00.640  - info: host.ioBrokerVM iobroker npm-install: exit 0
                2023-11-09 14:08:01.641  - warn: host.ioBrokerVM startInstance cannot find adapter "vis@1.4.16". Try to install it... 1 attempt
                2023-11-09 14:08:01.641  - info: host.ioBrokerVM iobroker install vis@1.4.16 using installedFrom
                2023-11-09 14:08:03.252  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1Installing iobroker.vis@1.4.16... (System call)
                2023-11-09 14:08:07.741  - info: vis.0 (14808) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.12
                2023-11-09 14:08:07.936  - info: vis.0 (14808) vis license is OK.
                2023-11-09 14:08:08.132  - error: vis.0 (14808) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2023-11-09 14:08:08.133  - error: vis.0 (14808) unhandled promise rejection: Not exists
                2023-11-09 14:08:08.133  - error: vis.0 (14808) Error: Not exists
                    at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:854:19)
                    at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:891:59)
                    at process.processImmediate (node:internal/timers:478:21)
                2023-11-09 14:08:08.134  - error: vis.0 (14808) Not exists
                2023-11-09 14:08:08.638  - info: vis.0 (14808) terminating
                2023-11-09 14:08:08.639  - warn: vis.0 (14808) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2023-11-09 14:08:09.330  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-09T13_08_03_548Z-debug-0.log
                2023-11-09 14:08:09.330  - error: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM Cannot install iobroker.vis@1.4.16: 6
                2023-11-09 14:08:10.348  - info: host.ioBrokerVM iobroker npm-install: exit 25
                2023-11-09 14:08:11.349  - warn: host.ioBrokerVM startInstance cannot find adapter "web@4.3.0". Try to install it... 1 attempt
                2023-11-09 14:08:11.349  - info: host.ioBrokerVM iobroker install web@4.3.0 using installedFrom
                2023-11-09 14:08:13.009  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                2023-11-09 14:08:13.011  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.web@4.3.0... (System call)
                2023-11-09 14:08:19.346  - info: host.ioBrokerVM iobroker npm-install: added 12 packages in 6s150 packages are looking for funding  run `npm fund` for details
                2023-11-09 14:08:19.371  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter web@4.3.0
                2023-11-09 14:08:19.442  - info: host.ioBrokerVM iobroker npm-install: upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
                2023-11-09 14:08:19.449  - info: host.ioBrokerVM iobroker npm-install: upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                2023-11-09 14:08:19.454  - info: host.ioBrokerVM iobroker npm-install: upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
                2023-11-09 14:08:19.457  - info: host.ioBrokerVM iobroker npm-install: upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/manifest.json manifest.json application/json
                2023-11-09 14:08:19.461  - info: host.ioBrokerVM iobroker npm-install: upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
                2023-11-09 14:08:19.465  - info: host.ioBrokerVM iobroker npm-install: upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json
                2023-11-09 14:08:19.468  - info: host.ioBrokerVM iobroker npm-install: upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
                2023-11-09 14:08:19.471  - info: host.ioBrokerVM iobroker npm-install: upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
                2023-11-09 14:08:19.474  - info: host.ioBrokerVM iobroker npm-install: upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js static/js/2.b1d56998.chunk.js application/javascript
                2023-11-09 14:08:19.488  - info: host.ioBrokerVM iobroker npm-install: upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.LICENSE.txt static/js/2.b1d56998.chunk.js.LICENSE.txt text/plain
                2023-11-09 14:08:19.491  - info: host.ioBrokerVM iobroker npm-install: upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.map static/js/2.b1d56998.chunk.js.map application/json
                2023-11-09 14:08:19.822  - info: host.ioBrokerVM iobroker npm-install: upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js static/js/main.034751df.chunk.js application/javascript
                2023-11-09 14:08:19.834  - info: host.ioBrokerVM iobroker npm-install: upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js.map static/js/main.034751df.chunk.js.map application/json
                2023-11-09 14:08:19.838  - info: host.ioBrokerVM iobroker npm-install: upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js static/js/runtime-main.7278cf1c.js application/javascript
                2023-11-09 14:08:19.840  - info: host.ioBrokerVM iobroker npm-install: upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js.map static/js/runtime-main.7278cf1c.js.map application/json
                2023-11-09 14:08:19.843  - info: host.ioBrokerVM iobroker npm-install: upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/le.eb63b1db.png static/media/le.eb63b1db.png image/png
                2023-11-09 14:08:19.847  - info: host.ioBrokerVM iobroker npm-install: upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
                2023-11-09 14:08:19.902  - info: host.ioBrokerVM iobroker npm-install: upload [396] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
                2023-11-09 14:08:20.034  - info: host.ioBrokerVM iobroker npm-install: upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png image/png
                2023-11-09 14:08:20.187  - info: host.ioBrokerVM iobroker npm-install: upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css text/css
                2023-11-09 14:08:20.343  - info: host.ioBrokerVM iobroker npm-install: upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png image/png
                2023-11-09 14:08:20.507  - info: host.ioBrokerVM iobroker npm-install: upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png image/png
                2023-11-09 14:08:20.681  - info: host.ioBrokerVM iobroker npm-install: upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png image/png
                2023-11-09 14:08:20.854  - info: host.ioBrokerVM iobroker npm-install: upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png image/png
                2023-11-09 14:08:20.886  - info: host.ioBrokerVM iobroker npm-install: upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png image/png
                2023-11-09 14:08:20.921  - info: host.ioBrokerVM iobroker npm-install: upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png image/png
                2023-11-09 14:08:20.953  - info: host.ioBrokerVM iobroker npm-install: upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png image/png
                2023-11-09 14:08:20.986  - info: host.ioBrokerVM iobroker npm-install: upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png image/png
                2023-11-09 14:08:21.019  - info: host.ioBrokerVM iobroker npm-install: upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css text/css
                2023-11-09 14:08:21.070  - info: host.ioBrokerVM iobroker npm-install: upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png image/png
                2023-11-09 14:08:21.106  - info: host.ioBrokerVM iobroker npm-install: upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/theme.css lib/css/themes/jquery-ui/vader/theme.css text/css
                2023-11-09 14:08:21.147  - info: host.ioBrokerVM iobroker npm-install: upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.js lib/js/jquery-1.11.2.min.js application/javascript
                2023-11-09 14:08:21.152  - info: host.ioBrokerVM iobroker npm-install: upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.map lib/js/jquery-1.11.2.min.map application/json
                2023-11-09 14:08:21.158  - info: host.ioBrokerVM iobroker npm-install: upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.js lib/js/jquery-3.2.1.min.js application/javascript
                2023-11-09 14:08:21.163  - info: host.ioBrokerVM iobroker npm-install: upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.map lib/js/jquery-3.2.1.min.map application/json
                2023-11-09 14:08:21.167  - info: host.ioBrokerVM iobroker npm-install: upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.10.3.full.min.js lib/js/jquery-ui-1.10.3.full.min.js application/javascript
                2023-11-09 14:08:21.172  - info: host.ioBrokerVM iobroker npm-install: upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.3.full.min.js lib/js/jquery-ui-1.11.3.full.min.js application/javascript
                2023-11-09 14:08:21.176  - info: host.ioBrokerVM iobroker npm-install: upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.4.full.min.js lib/js/jquery-ui-1.11.4.full.min.js application/javascript
                2023-11-09 14:08:21.183  - info: host.ioBrokerVM iobroker npm-install: upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.1.11.2.slider.min.js lib/js/jquery-ui.1.11.2.slider.min.js application/javascript
                2023-11-09 14:08:21.188  - info: host.ioBrokerVM iobroker npm-install: upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.min.js lib/js/jquery-ui.min.js application/javascript
                2023-11-09 14:08:21.192  - info: host.ioBrokerVM iobroker npm-install: upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js lib/js/jquery.fancytree-all.min.js application/javascript
                2023-11-09 14:08:21.214  - info: host.ioBrokerVM iobroker npm-install: upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js.map lib/js/jquery.fancytree-all.min.js.map application/json
                2023-11-09 14:08:21.221  - info: host.ioBrokerVM iobroker npm-install: upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.jqGrid-4.5.4.min.js lib/js/jquery.jqGrid-4.5.4.min.js application/javascript
                2023-11-09 14:08:21.226  - info: host.ioBrokerVM iobroker npm-install: upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/loStorage.js lib/js/loStorage.js application/javascript
                2023-11-09 14:08:21.230  - info: host.ioBrokerVM iobroker npm-install: upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js lib/js/materialize.js application/javascript
                2023-11-09 14:08:21.235  - info: host.ioBrokerVM iobroker npm-install: upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js.map lib/js/materialize.js.map application/json
                2023-11-09 14:08:21.244  - info: host.ioBrokerVM iobroker npm-install: upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/selectID.js lib/js/selectID.js application/javascript
                2023-11-09 14:08:21.253  - info: host.ioBrokerVM iobroker npm-install: upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
                2023-11-09 14:08:21.258  - info: host.ioBrokerVM iobroker npm-install: upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/socket.io.js lib/js/socket.io.js application/javascript
                2023-11-09 14:08:21.279  - info: host.ioBrokerVM iobroker npm-install: upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/translate.js lib/js/translate.js application/javascript
                2023-11-09 14:08:21.283  - info: host.ioBrokerVM iobroker npm-install: upload [1] web /opt/iobroker/node_modules/iobroker.web/www/login/favicon.ico login/favicon.ico image/vnd.microsoft.icon
                2023-11-09 14:08:21.288  - info: host.ioBrokerVM iobroker npm-install: upload [0] web /opt/iobroker/node_modules/iobroker.web/www/login/index.html login/index.html text/html
                2023-11-09 14:08:21.380  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.web created/updated
                2023-11-09 14:08:22.442  - info: host.ioBrokerVM iobroker npm-install: exit 0
                2023-11-09 14:08:23.443  - warn: host.ioBrokerVM startInstance cannot find adapter "worx@2.3.2". Try to install it... 1 attempt
                2023-11-09 14:08:23.443  - info: host.ioBrokerVM iobroker install worx@2.3.2 using installedFrom
                2023-11-09 14:08:25.057  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                2023-11-09 14:08:25.059  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.worx@2.3.2... (System call)
                2023-11-09 14:08:35.767  - info: host.ioBrokerVM iobroker npm-install:
                2023-11-09 14:08:35.767  - info: host.ioBrokerVM iobroker npm-install: added 42 packages in 10s152 packages are looking for funding  run `npm fund` for details
                2023-11-09 14:08:35.799  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM install adapter worx@2.3.2
                2023-11-09 14:08:35.874  - info: host.ioBrokerVM iobroker npm-install: upload [13] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/de/translations.json i18n/de/translations.json application/json
                2023-11-09 14:08:35.882  - info: host.ioBrokerVM iobroker npm-install: upload [12] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/en/translations.json i18n/en/translations.json application/json
                2023-11-09 14:08:35.885  - info: host.ioBrokerVM iobroker npm-install: upload [11] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/es/translations.json i18n/es/translations.json application/json
                2023-11-09 14:08:35.889  - info: host.ioBrokerVM iobroker npm-install: upload [10] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                2023-11-09 14:08:35.892  - info: host.ioBrokerVM iobroker npm-install: upload [9] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/it/translations.json i18n/it/translations.json application/json
                2023-11-09 14:08:35.896  - info: host.ioBrokerVM iobroker npm-install: upload [8] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                2023-11-09 14:08:35.899  - info: host.ioBrokerVM iobroker npm-install: upload [7] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                2023-11-09 14:08:35.903  - info: host.ioBrokerVM iobroker npm-install: upload [6] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                2023-11-09 14:08:35.906  - info: host.ioBrokerVM iobroker npm-install: upload [5] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                2023-11-09 14:08:35.910  - info: host.ioBrokerVM iobroker npm-install: upload [4] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                2023-11-09 14:08:35.913  - info: host.ioBrokerVM iobroker npm-install: upload [3] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                2023-11-09 14:08:35.916  - info: host.ioBrokerVM iobroker npm-install: upload [2] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/index_m.html index_m.html text/html
                2023-11-09 14:08:35.919  - info: host.ioBrokerVM iobroker npm-install: upload [1] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/jsonConfig.json jsonConfig.json application/json
                2023-11-09 14:08:35.922  - info: host.ioBrokerVM iobroker npm-install: upload [0] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/worx.png worx.png image/png
                2023-11-09 14:08:36.035  - info: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM object system.adapter.worx created/updated
                2023-11-09 14:08:37.095  - info: host.ioBrokerVM iobroker npm-install: exit 0
                2023-11-09 14:08:38.095  - warn: host.ioBrokerVM startInstance cannot find adapter "vis@1.4.16". Try to install it... 2 attempt
                2023-11-09 14:08:38.096  - info: host.ioBrokerVM iobroker install vis@1.4.16 using installedFrom
                2023-11-09 14:08:39.715  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                2023-11-09 14:08:39.716  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
                2023-11-09 14:08:43.855  - info: vis.0 (15120) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.12
                2023-11-09 14:08:44.030  - info: vis.0 (15120) vis license is OK.
                2023-11-09 14:08:44.198  - error: vis.0 (15120) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2023-11-09 14:08:44.198  - error: vis.0 (15120) unhandled promise rejection: Not exists
                2023-11-09 14:08:44.199  - error: vis.0 (15120) Error: Not exists
                2023-11-09 14:08:44.199  - error: vis.0 (15120) Not exists
                2023-11-09 14:08:44.704  - info: vis.0 (15120) terminating
                2023-11-09 14:08:44.705  - warn: vis.0 (15120) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2023-11-09 14:08:45.368  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-09T13_08_40_023Z-debug-0.log
                2023-11-09 14:08:45.369  - error: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM Cannot install iobroker.vis@1.4.16: 6
                2023-11-09 14:08:46.386  - info: host.ioBrokerVM iobroker npm-install: exit 25
                2023-11-09 14:08:47.386  - warn: host.ioBrokerVM startInstance cannot find adapter "vis@1.4.16". Try to install it... 3 attempt
                2023-11-09 14:08:47.387  - info: host.ioBrokerVM iobroker install vis@1.4.16 using installedVersion
                2023-11-09 14:08:48.955  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1Installing iobroker.vis@1.4.16... (System call)
                2023-11-09 14:08:53.034  - info: vis.0 (15229) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.12
                2023-11-09 14:08:53.235  - info: vis.0 (15229) vis license is OK.
                2023-11-09 14:08:53.414  - error: vis.0 (15229) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2023-11-09 14:08:53.414  - error: vis.0 (15229) unhandled promise rejection: Not exists
                2023-11-09 14:08:53.415  - error: vis.0 (15229) Error: Not exists
                2023-11-09 14:08:53.415  - error: vis.0 (15229) Not exists
                2023-11-09 14:08:53.921  - info: vis.0 (15229) terminating
                2023-11-09 14:08:53.921  - warn: vis.0 (15229) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2023-11-09 14:08:54.553  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-09T13_08_49_301Z-debug-0.log
                2023-11-09 14:08:54.554  - error: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM Cannot install iobroker.vis@1.4.16: 6
                2023-11-09 14:08:55.571  - info: host.ioBrokerVM iobroker npm-install: exit 25
                2023-11-09 14:08:56.572  - warn: host.ioBrokerVM startInstance cannot find adapter "vis@1.4.16". Try to install it... 4 attempt
                2023-11-09 14:08:56.572  - info: host.ioBrokerVM iobroker install vis@1.4.16 using installedVersion
                2023-11-09 14:08:58.196  - info: host.ioBrokerVM iobroker npm-install: NPM version: 9.8.1
                2023-11-09 14:08:58.196  - info: host.ioBrokerVM iobroker npm-install: Installing iobroker.vis@1.4.16... (System call)
                2023-11-09 14:09:02.223  - info: vis.0 (15338) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.12
                2023-11-09 14:09:02.401  - info: vis.0 (15338) vis license is OK.
                2023-11-09 14:09:02.571  - error: vis.0 (15338) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2023-11-09 14:09:02.572  - error: vis.0 (15338) unhandled promise rejection: Not exists
                2023-11-09 14:09:02.573  - error: vis.0 (15338) Error: Not exists
                2023-11-09 14:09:02.573  - error: vis.0 (15338) Not exists
                2023-11-09 14:09:03.076  - info: vis.0 (15338) terminating
                2023-11-09 14:09:03.077  - warn: vis.0 (15338) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2023-11-09 14:09:03.768  - error: host.ioBrokerVM iobroker npm-install: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-09T13_08_58_507Z-debug-0.log
                2023-11-09 14:09:03.769  - error: host.ioBrokerVM iobroker npm-install: host.ioBrokerVM Cannot install iobroker.vis@1.4.16: 6
                2023-11-09 14:09:04.788  - info: host.ioBrokerVM iobroker npm-install: exit 25
                2023-11-09 14:09:05.788  - error: host.ioBrokerVM Cannot download and install adapter "vis@1.4.16". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
                Gismoh
                #139
                idash@ioBrokerVM:~$ iob stop
                idash@ioBrokerVM:~$ iob fix
                library: loaded
                Library version=2023-10-13
                    Welcome to the ioBroker installation fixer!
                    Script version: 2023-10-13
                    You might need to enter your password a couple of times.
                    Installing prerequisites (1/5)
                [sudo] Passwort für idash:
                OK:1 http://security.debian.org/debian-security bookworm-security InRelease
                OK:2 http://deb.debian.org/debian bookworm InRelease
                OK:3 http://deb.debian.org/debian bookworm-updates InRelease
                OK:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Checking ioBroker user and directory permissions (2/5)
                    Check and cleanup npm temporary directories (3/5)
                Done.
                    Database maintenance (4/5)
                Checking for uncompressed JSONL databases... This might take a while!
                Compressing /opt/iobroker/iobroker-data/states.jsonl
                Compressing /opt/iobroker/iobroker-data/objects.jsonl
                Compressed 2 JSONL files. Done
                    Checking autostart (5/5)
                Enabling autostart...
                Autostart enabled!
                    Your installation was fixed successfully
                    Run iobroker start to start ioBroker again!
                idash@ioBrokerVM:~$ cd /home/iobroker
                idash@ioBrokerVM:/home/iobroker$ sudo -u iobroker npm cache clear --force
                npm WARN using --force Recommended protections disabled.
                npm ERR! code ENOTEMPTY
                npm ERR! syscall rmdir
                npm ERR! path /home/iobroker/.npm/_cacache
                npm ERR! errno -39
                npm ERR! ENOTEMPTY: directory not empty, rmdir '/home/iobroker/.npm/_cacache'
                npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-09T13_38_57_713Z-debug-0.log
                ioBroker auf: Lenovo ThinkCentre M910Q Tiny i5-7500T 16 GB mit proxmox in VM (Bookworm)
                G HomoranH 2 Antworten Letzte Antwort
                • G Gismoh
                  library: loaded
                  Done.
                  Autostart enabled!
                  npm ERR! errno -39
                  Gismoh
                  schrieb am zuletzt editiert von Gismoh
                  #140
                  Ansonsten die Schritte von Gestern abend noch mal durchgegangen, mit scheinbar selbem Ergebnis:
                  idash@ioBrokerVM:/home/iobroker$ cd /
                  idash@ioBrokerVM:/$ ls -lah /home/iobroker/.npm/_cacache
                  insgesamt 12K
                  drwxr-xr-x 3 iobroker iobroker 4,0K  9. Nov 14:38 .
                  drwxr-xr-x 7 iobroker iobroker 4,0K  9. Nov 14:38 ..
                  drwxr-xr-x 2 iobroker iobroker 4,0K  9. Nov 14:38 tmp
                  idash@ioBrokerVM:/$ rm -rf /home/iobroker/.npm/_cacache/tmp
                  rm: das Entfernen von '/home/iobroker/.npm/_cacache/tmp/a8c63b11' ist nicht möglich: Keine Berechtigung
                  idash@ioBrokerVM:/$ sudo -u iobroker rm -rf /home/iobroker/.npm/_cacache/tmp
                  idash@ioBrokerVM:/$ cd /home/iobroker
                  idash@ioBrokerVM:~$ iobroker upgrade ble@0.13.4
                  Adapter "ble"            is not installed.
                  idash@ioBrokerVM:~$ iobroker add ble@0.13.4 --debug
                  NPM version: 9.8.1
                  Installing iobroker.ble@0.13.4... (System call)
                  npm ERR! code 1
                  npm ERR! path /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble
                  npm ERR! command sh -c node-gyp-build
                  npm ERR! gyp info it worked if it ends with ok
                  npm ERR! gyp info using node-gyp@7.1.2
                  npm ERR! gyp info using node@18.18.2 | linux | x64
                  npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
                  npm ERR! (node:2039) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
                  npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)
                  npm ERR! gyp info spawn /usr/bin/python3
                  npm ERR! gyp info spawn args [
                  npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
                  npm ERR! gyp info spawn args   'binding.gyp',
                  npm ERR! gyp info spawn args   '-f',
                  npm ERR! gyp info spawn args   'make',
                  npm ERR! gyp info spawn args   '-I',
                  npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/build/config.gypi',
                  npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
                  npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi',
                  npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
                  npm ERR! gyp info spawn args   '-Dvisibility=default',
                  npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2',
                  npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
                  npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib',
                  npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble',
                  npm ERR! gyp info spawn args   '-Dnode_engine=v8',
                  npm ERR! gyp info spawn args   '--depth=.',
                  npm ERR! gyp info spawn args   '--no-parallel',
                  npm ERR! gyp info spawn args   '--generator-output',
                  npm ERR! gyp info spawn args   'build',
                  npm ERR! gyp info spawn args   '-Goutput_dir=.'
                  npm ERR! gyp info spawn args ]
                  npm ERR! Traceback (most recent call last):
                  npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>
                  npm ERR!     sys.exit(gyp.script_main())
                  npm ERR!              ^^^^^^^^^^^^^^^^^
                  npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_main
                  npm ERR!     return main(sys.argv[1:])
                  npm ERR!            ^^^^^^^^^^^^^^^^^^
                  npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in main
                  npm ERR!     return gyp_main(args)
                  npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_main
                  npm ERR!     [generator, flat_list, targets, data] = Load(
                  npm ERR!                                             ^^^^^
                  npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Load
                  npm ERR!     result = gyp.input.Load(
                  npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Load
                  npm ERR!     LoadTargetBuildFile(
                  npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFile
                  npm ERR!     build_file_data = LoadOneBuildFile(
                  npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFile
                  npm ERR!     build_file_contents = open(build_file_path, "rU").read()
                  npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^
                  npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gyp
                  npm ERR! gyp ERR! configure error
                  npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1
                  npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)
                  npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:517:28)
                  npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                  npm ERR! gyp ERR! System Linux 6.1.0-13-amd64
                  npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                  npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble
                  npm ERR! gyp ERR! node -v v18.18.2
                  npm ERR! gyp ERR! node-gyp -v v7.1.2
                  npm ERR! gyp ERR! not ok
                  npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-09T13_48_08_783Z-debug-0.log
                  npm ERR! code 1
                  npm ERR!                                             ^^^^^
                  host.ioBrokerVM Cannot install iobroker.ble@0.13.4: 1
                  • G Gismoh
                    library: loaded
                    Done.
                    Autostart enabled!
                    npm ERR! errno -39
                    #141
                    @gismoh sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
                    https://forum.iobroker.net/topic/57337/fehler-25-217-oder-enotempty-bei-adapter-install-update/1
                    G 1 Antwort Letzte Antwort
                      Gismoh
                      #142
                      idash@ioBrokerVM:~$ find "/opt/iobroker/node_modules" -type d -iname ".*-????????" ! -iname ".local-chromium" -exec rm -rf "{}" \; &> /dev/null
                      idash@ioBrokerVM:~$
                      ausgeführt, mal sehen
                      NPM version: 9.8.1
                      npm ERR! code 1
                      npm ERR! (node:2237) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
                      npm ERR!                                             ^^^^^
                      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-09T14_34_50_758Z-debug-0.log
                      npm ERR! code 1
                      npm ERR!                                             ^^^^^
                      idash@ioBrokerVM:~$
                      crunchipC HomoranH 2 Antworten Letzte Antwort
                      • G Gismoh
                        idash@ioBrokerVM:~$
                        NPM version: 9.8.1
                        npm ERR! code 1
                        npm ERR!                                             ^^^^^
                        npm ERR! code 1
                        npm ERR!                                             ^^^^^
                        idash@ioBrokerVM:~$
                        crunchipC Offline
                        crunchipC Offline
                        #143
                        @gismoh zeig mal die Ausgabe
                        iob diag
                        von beiden Systemen, Raspberry und Vm
                        G 3 Antworten Letzte Antwort
                        • G Gismoh
                          idash@ioBrokerVM:~$
                          NPM version: 9.8.1
                          npm ERR! code 1
                          npm ERR!                                             ^^^^^
                          npm ERR! code 1
                          npm ERR!                                             ^^^^^
                          idash@ioBrokerVM:~$
                          #144
                          mal sehen
                          was machst du denn jetzt schon wieder?
                          der iob fix ist doch gar nicht durchgelaufen!
                            mal sehen
                            Gismoh
                            #145
                            Laut deinem Link ist doch dieser Befehl im iob fix enthalten?
                            Das ganze ist ab sofort im ioBroker Fixer inkludiert, daher sollte unter Linux iob fix reichen!!
                            dies wurde oben bereits getätigt
                            • G Gismoh
                              #146
                              und brach ab mit isnotempty
                              G 2 Antworten Letzte Antwort
                                Gismoh
                                #147
                                @homoran okay - hatte mich auf das bezogen:
                                dann mache ich es nochmal
                                  iob diag
                                  Gismoh
                                  #148
                                  @crunchip
                                  neue VM (vor erneutem iob fix)
                                  Skript v.2023-10-10
                                  *** BASE SYSTEM ***
                                   Static hostname: ioBrokerVM
                                         Icon name: computer-vm
                                           Chassis: vm 🖴
                                    Virtualization: kvm
                                            Kernel: Linux 6.1.0-13-amd64
                                      Architecture: x86-64
                                   Hardware Vendor: QEMU
                                    Hardware Model: Standard PC _i440FX + PIIX, 1996_
                                  Firmware Version: rel-1.16.2-0-gea1b7a073390-prebuilt.qemu.org
                                  model name      : QEMU Virtual CPU version 2.5+
                                  Docker          : false
                                  Virtualization  : kvm
                                  Kernel          : x86_64
                                  Userland        : amd64
                                  Systemuptime and Load:
                                   15:40:50 up  1:05,  2 users,  load average: 0.16, 0.04, 0.01
                                  CPU threads: 2
                                  *** Time and Time Zones ***
                                                 Local time: Thu 2023-11-09 15:40:50 CET
                                             Universal time: Thu 2023-11-09 14:40:50 UTC
                                                   RTC time: Thu 2023-11-09 14:40:50
                                                NTP service: active
                                            RTC in local TZ: no
                                  *** User and Groups ***
                                  idash
                                  /home/idash
                                  idash adm dialout sudo plugdev users input netdev iobroker
                                  *** X-Server-Setup ***
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Mem:            4.1G        384M        3.4G        507K        574M        3.7G
                                  Swap:           1.0G          0B        1.0G
                                  Total:          5.1G        384M        4.4G
                                           3915 M total memory
                                            367 M used memory
                                            222 M active memory
                                            251 M inactive memory
                                           3248 M free memory
                                             67 M buffer memory
                                            480 M swap cache
                                            974 M total swap
                                              0 M used swap
                                            974 M free swap
                                  *** FAILED SERVICES ***
                                    UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                                  * iobroker.service loaded failed failed ioBroker Server
                                  1 loaded units listed.
                                  *** FILESYSTEM ***
                                  udev           devtmpfs  1.9G     0  1.9G   0% /dev
                                  tmpfs          tmpfs     392M  500K  392M   1% /run
                                  /dev/sda1      ext4       31G  3.6G   26G  13% /
                                  tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
                                  tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                                  tmpfs          tmpfs     392M     0  392M   0% /run/user/1002
                                  [Thu Nov  9 14:35:44 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                                  [Thu Nov  9 14:35:45 2023] EXT4-fs (sda1): re-mounted. Quota mode: none.
                                  TARGET SOURCE    FSTYPE OPTIONS
                                  /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
                                  /var:
                                  455M    /var/
                                  248M    /var/cache
                                  240M    /var/cache/apt
                                  169M    /var/lib
                                  164M    /var/cache/apt/archives
                                  Archived and active journals take up 24.0M in the file system.
                                  /opt/iobroker/backups:
                                  5.8M    /opt/iobroker/backups/
                                  /opt/iobroker/iobroker-data:
                                  189M    /opt/iobroker/iobroker-data/
                                  157M    /opt/iobroker/iobroker-data/files
                                  52M     /opt/iobroker/iobroker-data/files/javascript.admin
                                  34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                                  33M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                  27M     /opt/iobroker/iobroker-data/objects.jsonl
                                  19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
                                  8.2M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js
                                  7.2M    /opt/iobroker/iobroker-data/files/ham.admin/static/js/main.8080bc0b.js.map
                                  7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
                                  find: '/dev/serial/by-id/': No such file or directory
                                  USB-Devices by-id:
                                  *** NodeJS-Installation ***
                                  /usr/bin/nodejs         v18.18.2
                                  /usr/bin/node           v18.18.2
                                  /usr/bin/npm            9.8.1
                                  /usr/bin/npx            9.8.1
                                  /usr/bin/corepack       0.19.0
                                  nodejs:
                                    Installed: 18.18.2-1nodesource1
                                    Candidate: 18.18.2-1nodesource1
                                    Version table:
                                   *** 18.18.2-1nodesource1 500
                                          500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                       18.18.1-1nodesource1 500
                                       18.18.0-1nodesource1 500
                                       18.17.1-1nodesource1 500
                                       18.17.0-1nodesource1 500
                                       18.16.1-1nodesource1 500
                                       18.16.0-1nodesource1 500
                                       18.15.0-1nodesource1 500
                                       18.14.2-1nodesource1 500
                                       18.14.1-1nodesource1 500
                                       18.14.0-1nodesource1 500
                                       18.13.0+dfsg1-1 500
                                          500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                       18.13.0-1nodesource1 500
                                       18.12.0-1nodesource1 500
                                       18.11.0-1nodesource1 500
                                       18.10.0-1nodesource1 500
                                       18.9.1-1nodesource1 500
                                       18.9.0-1nodesource1 500
                                       18.8.0-1nodesource1 500
                                       18.7.0-1nodesource1 500
                                       18.6.0-1nodesource1 500
                                       18.5.0-1nodesource1 500
                                       18.4.0-1nodesource1 500
                                       18.3.0-1nodesource1 500
                                       18.2.0-1nodesource1 500
                                       18.1.0-1nodesource1 500
                                       18.0.0-1nodesource1 500
                                  No problems detected
                                  Errors in npm tree:
                                  *** ioBroker-Installation ***
                                  ioBroker Status
                                  iobroker is not running on this host.
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Core adapters versions
                                  admin:          6.8.0
                                  javascript:     7.1.4
                                  Adapters from github:   0
                                  Adapter State
                                    system.adapter.admin.0                  : admin                 : ioBrokerVM                               -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                    system.adapter.alarm.0                  : alarm                 : ioBrokerVM                               - disabled
                                    system.adapter.alexa2.0                 : alexa2                : ioBrokerVM                               - disabled
                                    system.adapter.backitup.0               : backitup              : ioBrokerVM                               -  enabled
                                    system.adapter.daikin-cloud.0           : daikin-cloud          : ioBrokerVM                               - disabled
                                    system.adapter.daswetter.0              : daswetter             : ioBrokerVM                               - disabled
                                    system.adapter.deconz.0                 : deconz                : ioBrokerVM                               - disabled, port: 8090
                                    system.adapter.device-reminder.0        : device-reminder       : ioBrokerVM                               - disabled
                                    system.adapter.discovery.0              : discovery             : ioBrokerVM                               - disabled
                                    system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : ioBrokerVM                               - disabled
                                    system.adapter.enigma2.0                : enigma2               : ioBrokerVM                               - disabled
                                    system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBrokerVM                               - disabled
                                    system.adapter.fiat.0                   : fiat                  : ioBrokerVM                               - disabled
                                    system.adapter.flot.0                   : flot                  : ioBrokerVM                               - disabled
                                    system.adapter.fullybrowser.0           : fullybrowser          : ioBrokerVM                               - disabled
                                    system.adapter.go-e.0                   : go-e                  : ioBrokerVM                               - disabled
                                    system.adapter.go-e.1                   : go-e                  : ioBrokerVM                               - disabled
                                    system.adapter.ham.0                    : ham                   : ioBrokerVM                               - disabled
                                    system.adapter.harmony.0                : harmony               : ioBrokerVM                               - disabled
                                    system.adapter.hue-extended.0           : hue-extended          : ioBrokerVM                               - disabled
                                    system.adapter.hue.0                    : hue                   : ioBrokerVM                               - disabled, port: 443
                                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBrokerVM                               - disabled
                                    system.adapter.influxdb.0               : influxdb              : ioBrokerVM                               - disabled, port: 8086
                                    system.adapter.info.0                   : info                  : ioBrokerVM                               - disabled
                                    system.adapter.iot.0                    : iot                   : ioBrokerVM                               - disabled
                                    system.adapter.javascript.0             : javascript            : ioBrokerVM                               - disabled
                                    system.adapter.meross.0                 : meross                : ioBrokerVM                               - disabled
                                    system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBrokerVM                               - disabled, port: 54321
                                    system.adapter.mihome-vacuum.2          : mihome-vacuum         : ioBrokerVM                               - disabled, port: 54321
                                    system.adapter.mobile.0                 : mobile                : ioBrokerVM                               - disabled
                                    system.adapter.openweathermap.0         : openweathermap        : ioBrokerVM                               - disabled
                                    system.adapter.pi-hole.0                : pi-hole               : ioBrokerVM                               - disabled
                                    system.adapter.pushover.0               : pushover              : ioBrokerVM                               - disabled
                                    system.adapter.pvforecast.0             : pvforecast            : ioBrokerVM                               - disabled
                                    system.adapter.radar2.0                 : radar2                : ioBrokerVM                               - disabled
                                    system.adapter.shelly.0                 : shelly                : ioBrokerVM                               - disabled, port: 1882, bind: 0.0.0.0
                                    system.adapter.shelly.1                 : shelly                : ioBrokerVM                               - disabled, port: 1882, bind: 0.0.0.0
                                    system.adapter.smartcontrol.0           : smartcontrol          : ioBrokerVM                               - disabled
                                    system.adapter.socketio.0               : socketio              : ioBrokerVM                               - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                                    system.adapter.sonoff.0                 : sonoff                : ioBrokerVM                               - disabled, port: 1883, bind: 0.0.0.0
                                    system.adapter.tado.0                   : tado                  : ioBrokerVM                               - disabled
                                    system.adapter.telegram.0               : telegram              : ioBrokerVM                               - disabled, port: 8443, bind: 0.0.0.0
                                    system.adapter.tibberlink.0             : tibberlink            : ioBrokerVM                               - disabled
                                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBrokerVM                               - disabled
                                    system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBrokerVM                               - disabled
                                    system.adapter.vis-material-advanced.0  : vis-material-advanced : ioBrokerVM                               - disabled
                                    system.adapter.vis-metro.0              : vis-metro             : ioBrokerVM                               - disabled
                                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBrokerVM                               - disabled
                                    system.adapter.vis.0                    : vis                   : ioBrokerVM                               - disabled
                                    system.adapter.weatherunderground.0     : weatherunderground    : ioBrokerVM                               - disabled
                                    system.adapter.web.0                    : web                   : ioBrokerVM                               - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                                    system.adapter.worx.0                   : worx                  : ioBrokerVM                               - disabled
                                  + instance is alive
                                  ioBroker-Repositories
                                  Stable (default): http://iobroker.live/repo/sources-dist.json
                                  Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                                  Installed ioBroker-Instances
                                  Adapter    "admin"        : 6.12.0   , installed 6.8.0  [Updatable]
                                  Adapter    "alarm"        : 3.4.0    , installed 3.3.13 [Updatable]
                                  Adapter    "alexa2"       : 3.25.2   , installed 3.23.2 [Updatable]
                                  Adapter    "backitup"     : 2.8.7    , installed 2.8.1  [Updatable]
                                  Adapter    "daikin-cloud" : 0.3.0    , installed 0.3.0
                                  Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                                  Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                                  Adapter    "device-reminder": 3.0.0  , installed 1.2.9  [Updatable]
                                  Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
                                  Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
                                  Adapter    "fiat"         : 0.0.8    , installed 0.0.8
                                  Adapter    "fullybrowser" : 2.2.0    , installed 2.1.2  [Updatable]
                                  Adapter    "go-e"         : 1.0.27   , installed 1.0.27
                                  Adapter    "ham"          : 5.3.1    , installed 5.3.1
                                  Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                                  Adapter    "hue"          : 3.10.1   , installed 3.10.0 [Updatable]
                                  Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
                                  Adapter    "info"         : 2.0.0    , installed 2.0.0
                                  Adapter    "iot"          : 1.14.5   , installed 1.14.5
                                  Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                                  Controller "js-controller": 5.0.12   , installed 5.0.12
                                  Adapter    "meross"       : 1.15.1   , installed 1.15.1
                                  Adapter    "mihome-vacuum": 4.0.0    , installed 4.0.0
                                  Adapter    "openweathermap": 0.3.9   , installed 0.3.9
                                  Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
                                  Adapter    "pushover"     : 3.0.3    , installed 3.0.3
                                  Adapter    "pvforecast"   : 2.9.0    , installed 2.8.1  [Updatable]
                                  Adapter    "radar2"       : 2.0.8    , installed 2.0.7  [Updatable]
                                  Adapter    "shelly"       : 6.6.1    , installed 6.4.1  [Updatable]
                                  Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
                                  Copy text starting here:
                                                          v.2023-10-10
                                           Chassis: vm 🖴
                                    Virtualization: kvm
                                  Installation:           kvm
                                  Kernel:                 x86_64
                                  Userland:               amd64
                                  Timezone:               Europe/Berlin (CET, +0100)
                                  User-ID:                1002
                                  X-Server:               false
                                  Pending OS-Updates:     0
                                  Pending iob updates:    16
                                  Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                                          /usr/bin/npm            9.8.1
                                                          /usr/bin/npx            9.8.1
                                  Recommended versions are nodejs 18.18.2 and npm 9.8.1
                                  MEMORY:
                                  Mem:            4.1G        418M        3.4G        512K        590M        3.7G
                                  Swap:           1.0G          0B        1.0G
                                  Total:          5.1G        418M        4.4G
                                  Active iob-Instances:   1
                                  ioBroker Core:          js-controller           5.0.12
                                                          admin                   6.8.0
                                  ioBroker Status:        iobroker is not running on this host.
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Objects:                32918
                                  States:                 20853
                                  Size of iob-Database:
                                  35M     /opt/iobroker/iobroker-data/objects.jsonl
                                  4.9M    /opt/iobroker/iobroker-data/states.jsonl
                                  === Mark text until here for copying ===
                                  HomoranH crunchipC 2 Antworten Letzte Antwort
                                  • G Gismoh
                                    @crunchip
                                    Skript v.2023-10-10
                                    *** BASE SYSTEM ***
                                             Chassis: vm 🖴
                                      Virtualization: kvm
                                    Docker          : false
                                    Kernel          : x86_64
                                    Userland        : amd64
                                    CPU threads: 2
                                                  NTP service: active
                                              RTC in local TZ: no
                                    idash
                                    /home/idash
                                    X-Server:       false
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Swap:           1.0G          0B        1.0G
                                             3915 M total memory
                                              367 M used memory
                                              222 M active memory
                                             3248 M free memory
                                               67 M buffer memory
                                              480 M swap cache
                                              974 M total swap
                                                0 M used swap
                                              974 M free swap
                                    *** FILESYSTEM ***
                                    /var:
                                    455M    /var/
                                    248M    /var/cache
                                    240M    /var/cache/apt
                                    169M    /var/lib
                                    USB-Devices by-id:
                                    /usr/bin/npm            9.8.1
                                    /usr/bin/npx            9.8.1
                                    nodejs:
                                      Version table:
                                         18.13.0+dfsg1-1 500
                                    Errors in npm tree:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    admin:          6.8.0
                                    javascript:     7.1.4
                                    Adapter State
                                    + instance is alive
                                                            v.2023-10-10
                                             Chassis: vm 🖴
                                      Virtualization: kvm
                                    Installation:           kvm
                                    Kernel:                 x86_64
                                    Userland:               amd64
                                    User-ID:                1002
                                    X-Server:               false
                                                            /usr/bin/npm            9.8.1
                                                            /usr/bin/npx            9.8.1
                                    MEMORY:
                                    Swap:           1.0G          0B        1.0G
                                                            admin                   6.8.0
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Objects:                32918
                                    States:                 20853
                                    #149
                                    full ist unvollständig
                                    wie kommen die ganzen Adapter da rein wenn das eine neue VM ist?
                                      Gismoh
                                      #150
                                      Ich sollte doch das Backup einspielen. Dies hatte ich auch getan, auf der frischen Maschine (VM) ohne backup läuft ja der ble!
                                      Oder sind die Adpater ungewöhnlich, wenn man das backup von backitup einspielt?
                                        Gismoh
                                        #151
                                        iob fix sieht für mich "normal" aus -sehe dort keine Fehlermeldung.
                                        (gerade erneut gemacht)
                                        library: loaded
                                        Done.
                                        Autostart enabled!
                                        idash@ioBrokerVM:~$ iob start
                                          iob diag
                                          Gismoh
                                          #152
                                          @crunchip
                                          iob diag
                                          von der "alten" installation dauert noch, muss dort im Docker erst noch nen neuen User erstellen. Da ich dort ran muss, ziehe ich erst noch ein Sicherung der SD-Karte.
