  4. TESTER gesucht / Backup auf Fritz.nas - node 18.18.0
    6.3k
204 Beiträge 10 Kommentatoren 40.3k Aufrufe 13 Beobachtet
  • O SO O S
    Copy text starting here:
                         v.2023-06-20
       Static hostname: iobroker
             Icon name: computer
            Machine ID: 6cdd9ef1128b465193e49cc4ea80f5af
               Boot ID: 41b5da8e46ba4fd897de0fa6a4711922
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Installation:           native
    Kernel:                 aarch64
    Userland:               arm64
    Timezone:               Europe/Berlin (CEST, +0200)
    User-ID:                1000
    X-Server:               false
    Boot Target:            multi-user.target
    Pending OS-Updates:     0
    Pending iob updates:    1
    Nodejs-Installation:    /usr/bin/nodejs         v18.18.0
                            /usr/bin/node           v18.18.0
                            /usr/bin/npm            9.8.1
                            /usr/bin/npx            9.8.1
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            3.8G        1.5G        1.3G        1.0M        949M        2.2G
    Swap:            99M          0B         99M
    Total:          3.9G        1.5G        1.4G
    Active iob-Instances:   21
    ioBroker Core:          js-controller           5.0.12
                            admin                   6.10.1
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : iobroker
    + system.adapter.web.0                    : web                   : iobroker
    Objects:                6978
    States:                 12775
    Size of iob-Database:
    27M     /opt/iobroker/iobroker-data/objects.jsonl
    2.6M    /opt/iobroker/iobroker-data/states.jsonl
    [s=]
     ======== Start marking the full check here =========
    Skript v.2023-06-20
    *** BASE SYSTEM ***
    Icon name: computer
    Architecture: arm64
    Model : Raspberry Pi 4 Model B Rev 1.2
    Docker : false
    Virtualization : none
    Kernel : aarch64
    Userland : arm64
    Systemuptime and Load:
    18:48:07 up 4:55, 1 user, load average: 1.04, 1.14, 1.28
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=62.3'C
    volt=0.8438V
    *** Time and Time Zones ***
    Local time: Tue 2023-10-03 18:48:07 CEST
    Universal time: Tue 2023-10-03 16:48:07 UTC
    RTC time: n/a
    NTP service: active
    RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server: false
    Desktop:
    Terminal: tty
    *** MEMORY ***
    total used free shared buff/cache available
    Mem: 3.8G 1.5G 1.4G 1.0M 948M 2.2G
    Swap: 99M 0B 99M
    Total: 3.9G 1.5G 1.5G
         3793 M total memory
         1492 M used memory
         1502 M active memory
          766 M inactive memory
         1352 M free memory
          118 M buffer memory
          830 M swap cache
           99 M total swap
            0 M used swap
           99 M free swap
    Raspberry only:
    oom events: 0
    lifetime oom required: 0 Mbytes
    total time in oom handler: 0 ms
    max time spent in oom handler: 0 ms
    *** FILESYSTEM ***
    Filesystem Type Size Used Avail Use% Mounted on
    /dev/root ext4 28G 3.2G 24G 12% /
    devtmpfs devtmpfs 1.7G 0 1.7G 0% /dev
    tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm
    tmpfs tmpfs 759M 1.2M 758M 1% /run
    tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
    /dev/sdb1 vfat 255M 31M 225M 13% /boot
    //fritz.box/fritz.nas/intenso/iobroker cifs 961G 521G 441G 55% /opt/iobroker/backups
    tmpfs tmpfs 380M 0 380M 0% /run/user/1000
    [Tue Oct 3 13:52:15 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=E4:5F:01:05:E5:E6 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 console=ttyS0,115200 console=tty1 root=PARTUUID=85bcf00a-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Tue Oct 3 13:52:18 2023] EXT4-fs (sdb2): mounted filesystem with ordered data mode. Quota mode: none.
    [Tue Oct 3 13:52:18 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:18.
    [Tue Oct 3 13:52:20 2023] EXT4-fs (sdb2): re-mounted. Quota mode: none.
    Show mounted filesystems (real ones only):
    TARGET SOURCE FSTYPE OPTIONS
    / /dev/sdb2 ext4 rw,noatime
    |-/boot /dev/sdb1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/opt/iobroker/backups //fritz.box/fritz.nas/intenso/iobroker cifs rw,relatime,vers=3.1.1,cache=strict,username=IoBroker2,uid=1001,noforceuid,gid=1001,noforcegid,addr=192.168.178.1,file_mode=0777,dir_mode=0777,soft,nounix,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=5
    /var:
    563M /var/
    209M /var/cache
    204M /var/cache/apt
    147M /var/lib
    123M /var/lib/apt
    Archived and active journals take up 104.0M in the file system.
    /opt/iobroker/backups:
    129M /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    203M /opt/iobroker/iobroker-data/
    165M /opt/iobroker/iobroker-data/files
    52M /opt/iobroker/iobroker-data/files/javascript.admin
    34M /opt/iobroker/iobroker-data/files/javascript.admin/static
    33M /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    21M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js.map
    19M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    8.3M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js
    8.2M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js
    *** NodeJS-Installation ***
    /usr/bin/npm 9.8.1
    /usr/bin/npx 9.8.1
    nodejs:
    Installed: 18.18.0-1nodesource1
    Candidate: 18.18.0-1nodesource1
    Version table:
    *** 18.18.0-1nodesource1 1001
    500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
    100 /var/lib/dpkg/status
    18.17.1-1nodesource1 1001
    18.17.0-1nodesource1 1001
    18.16.1-1nodesource1 1001
    18.16.0-1nodesource1 1001
    18.15.0-1nodesource1 1001
    18.14.2-1nodesource1 1001
    18.14.1-1nodesource1 1001
    18.14.0-1nodesource1 1001
    18.13.0-1nodesource1 1001
    18.12.0-1nodesource1 1001
    18.11.0-1nodesource1 1001
    18.10.0-1nodesource1 1001
    18.9.1-1nodesource1 1001
    18.9.0-1nodesource1 1001
    18.8.0-1nodesource1 1001
    18.7.0-1nodesource1 1001
    18.6.0-1nodesource1 1001
    18.5.0-1nodesource1 1001
    18.4.0-1nodesource1 1001
    18.3.0-1nodesource1 1001
    18.2.0-1nodesource1 1001
    18.1.0-1nodesource1 1001
    18.0.0-1nodesource1 1001
    12.22.12~dfsg-1~deb11u4 500
    500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    12.22.12~dfsg-1~deb11u3 500
    500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States type: jsonl
    No configuration change needed.
    Multihost discovery server: disabled
    Discovery authentication: enabled
    Persistent activation: disabled
    Objects: jsonl on 0.0.0.0
    States: jsonl on 0.0.0.0
    Core adapters versions
    js-controller: 5.0.12
    admin: 6.10.1
    javascript: 7.1.4
    Adapters from github: 0
    Adapter State
    • system.adapter.admin.0 : admin : iobroker - enabled, port: 7777, bind: 0.0.0.0, run as: admin
    • system.adapter.alexa2.0 : alexa2 : iobroker - enabled
    • system.adapter.backitup.0 : backitup : iobroker - enabled
    • system.adapter.discovery.0 : discovery : iobroker - enabled
      system.adapter.flot.0 : flot : iobroker - enabled
    • system.adapter.fritzbox.0 : fritzbox : iobroker - enabled
    • system.adapter.fritzdect.0 : fritzdect : iobroker - enabled
    • system.adapter.history.0 : history : iobroker - enabled
    • system.adapter.info.0 : info : iobroker - enabled
    • system.adapter.iot.0 : iot : iobroker - enabled
    • system.adapter.javascript.0 : javascript : iobroker - enabled
      system.adapter.mobile.0 : mobile : iobroker - enabled
    • system.adapter.net-tools.0 : net-tools : iobroker - enabled
    • system.adapter.octoprint.0 : octoprint : iobroker - enabled
    • system.adapter.ping.0 : ping : iobroker - enabled
    • system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1882, bind: 0.0.0.0
    • system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1884, bind: 0.0.0.0
    • system.adapter.tankerkoenig.0 : tankerkoenig : iobroker - enabled
    • system.adapter.telegram.0 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0
    • system.adapter.tr-064.0 : tr-064 : iobroker - enabled
      system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : iobroker - enabled
      system.adapter.vis-fancyswitch.0 : vis-fancyswitch : iobroker - enabled
      system.adapter.vis-hqwidgets.0 : vis-hqwidgets : iobroker - enabled
      system.adapter.vis-justgage.0 : vis-justgage : iobroker - enabled
      system.adapter.vis.0 : vis : iobroker - enabled
    • system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin
    • system.adapter.ws.0 : ws : iobroker - enabled, port: 8085, bind: 0.0.0.0, run as: admin
    • instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Installed ioBroker-Instances
    Adapter "admin" : 6.10.1 , installed 6.10.1
    Adapter "alexa2" : 3.25.2 , installed 3.25.2
    Adapter "backitup" : 2.8.1 , installed 2.8.1
    Adapter "discovery" : 3.1.0 , installed 3.1.0
    Adapter "flot" : 1.12.0 , installed 1.12.0
    Adapter "fritzbox" : 0.5.0 , installed 0.5.0
    Adapter "fritzdect" : 2.3.1 , installed 2.3.1
    Adapter "history" : 2.2.6 , installed 2.2.6
    Adapter "info" : 2.0.0 , installed 2.0.0
    Adapter "iot" : 1.14.5 , installed 1.14.5
    Adapter "javascript" : 7.1.4 , installed 7.1.4
    Controller "js-controller": 5.0.12 , installed 5.0.12
    Adapter "mobile" : 1.0.1 , installed 1.0.1
    Adapter "net-tools" : 0.2.0 , installed 0.2.0
    Adapter "octoprint" : 4.0.0 , installed 4.0.0
    Adapter "ping" : 1.6.2 , installed 1.6.2
    Adapter "shelly" : 6.4.1 , installed 6.4.1
    Adapter "simple-api" : 2.7.2 , installed 2.7.2
    Adapter "socketio" : 6.5.5 , installed 6.5.5
    Adapter "sonoff" : 2.5.3 , installed 2.5.3
    Adapter "tankerkoenig" : 3.3.7 , installed 3.3.7
    Adapter "telegram" : 1.16.0 , installed 1.16.0
    Adapter "tr-064" : 4.2.18 , installed 4.2.18
    Adapter "vis" : 1.4.16 , installed 1.4.16
    Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1
    Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0
    Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0
    Adapter "vis-justgage" : 1.0.2 , installed 1.0.2
    Adapter "web" : 6.1.2 , installed 6.1.0 [Updatable]
    Adapter "ws" : 2.5.5 , installed 2.5.5
    Objects and States
    Objects: 6978
    States: 12775
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
    tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 15401 544/sshd: /usr/sbin
    tcp 0 0 0.0.0.0:9001 0.0.0.0:* LISTEN 1001 531479 28146/iobroker.js-c
    tcp 0 0 0.0.0.0:9000 0.0.0.0:* LISTEN 1001 531484 28146/iobroker.js-c
    tcp 0 0 0.0.0.0:1884 0.0.0.0:* LISTEN 1001 530826 28332/io.sonoff.0
    tcp6 0 0 :::22 :::* LISTEN 0 15403 544/sshd: /usr/sbin
    tcp6 0 0 :::8082 :::* LISTEN 1001 533936 28695/io.web.0
    tcp6 0 0 :::8085 :::* LISTEN 1001 534754 28728/io.ws.0
    tcp6 0 0 :::7777 :::* LISTEN 1001 531536 28172/io.admin.0
    udp 0 0 0.0.0.0:55170 0.0.0.0:* 1001 619670 28311/io.shelly.0
    udp 0 0 0.0.0.0:68 0.0.0.0:* 0 12530 810/dhcpcd
    udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 14543 399/avahi-daemon: r
    udp 0 0 0.0.0.0:58602 0.0.0.0:* 108 14545 399/avahi-daemon: r
    udp 0 0 0.0.0.0:5683 0.0.0.0:* 1001 531837 28311/io.shelly.0
    udp6 0 0 :::546 :::* 0 15429 810/dhcpcd
    udp6 0 0 :::5353 :::* 108 14544 399/avahi-daemon: r
    udp6 0 0 :::42372 :::* 108 14546 399/avahi-daemon: r
    2023-10-03 18:12:13.047 - info: admin.0 (28172) ==> Connected system.user.admin from ::ffff:192.168.178.205
    2023-10-03 18:12:14.080 - info: net-tools.0 (28559) starting. Version 0.2.0 in /opt/iobroker/node_modules/iobroker.net-tools, node: v18.18.0, js-controller: 5.0.12
    2023-10-03 18:12:14.436 - info: net-tools.0 (28559) Scanning for open ports (20, 21, 22, 23, 25, 53, 80, 110, 119, 123, 143, 161, 162, 194, 443, 445, 3306, 3389, 5900, 6379, 8080, 8443, 9090, 9200, 9999) at localhost, please wait
    2023-10-03 18:12:15.808 - info: admin.0 (28172) ==> Connected system.user.admin from ::ffff:192.168.178.205
    2023-10-03 18:12:16.743 - info: net-tools.0 (28559) Port scan finished
    2023-10-03 18:12:21.610 - info: tankerkoenig.0 (28637) starting. Version 3.3.7 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v18.18.0, js-controller: 5.0.12
    2023-10-03 18:12:21.704 - info: tankerkoenig.0 (28637) Adapter is already in daemon mode
    2023-10-03 18:12:21.706 - warn: tankerkoenig.0 (28637) Sync time was too short (5). New sync time is 10 min
    2023-10-03 18:12:21.708 - info: tankerkoenig.0 (28637) Sync time set to 10 minutes or 600000 ms
    2023-10-03 18:12:24.672 - info: vis.0 (28658) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.0, js-controller: 5.0.12
    2023-10-03 18:12:25.224 - info: vis.0 (28658) vis license is OK.
    2023-10-03 18:12:28.304 - info: vis.0 (28658) Terminated (NO_ERROR): Without reason
    2023-10-03 18:12:29.942 - info: web.0 (28695) starting. Version 6.1.0 in /opt/iobroker/node_modules/iobroker.web, node: v18.18.0, js-controller: 5.0.12
    2023-10-03 18:12:30.679 - info: web.0 (28695) socket.io server listening on port 8082
    2023-10-03 18:12:30.703 - info: web.0 (28695) http server listening on port 8082
    2023-10-03 18:12:32.633 - info: ws.0 (28728) starting. Version 2.5.5 in /opt/iobroker/node_modules/iobroker.ws, node: v18.18.0, js-controller: 5.0.12
    2023-10-03 18:12:32.745 - warn: ws.0 (28728) Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
    2023-10-03 18:12:32.772 - info: ws.0 (28728) socket.io server listening on port 8085
    2023-10-03 18:12:40.622 - info: info.0 (28749) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.18.0, js-controller: 5.0.12
    2023-10-03 18:12:41.016 - info: info.0 (28749) Reading/updating systemdata.
    2023-10-03 18:12:45.286 - info: tankerkoenig.0 (28637) Start first request
    2023-10-03 18:12:45.312 - info: info.0 (28749) cpu Temp res = {"main":66.218,"cores":[],"max":66.218,"socket":[],"chipset":null}
    2023-10-03 18:16:19.824 - info: admin.0 (28172) ==> Connected system.user.admin from ::ffff:192.168.178.205
    2023-10-03 18:16:27.936 - info: admin.0 (28172) ==> Connected system.user.admin from ::ffff:192.168.178.205
    2023-10-03 18:29:49.271 - info: admin.0 (28172) ==> Connected system.user.admin from ::ffff:192.168.178.205
    Backitup bei node 18.17.1: 6,7 MB
    Backitup bei node 18.18.0: 16 KB
    O SO Offline
    O SO Offline
    O S
    @o-s
    Besser habe ich es nicht gekonnt!
    Gruß Otto
    • F Online
      F Online
      fastfoot
      ui, sind ja doch einige mit Fehlern. Ich bin gerade dabei ein Skript zu schreiben welches neben dem derzeitigen Verfahren(backitup/iobroker cli) auch eine evtl. Lösung anbieten soll. Diese Lösung ist zur Zeit noch nicht wirklich brauchbar da sie mehr Zeit benötigt, dient aber dazu zu prüfen ob der Fehler damit erstmal weg ist. Das Skript erstellt kein Backup sondern nutzt nur dessen Mechanismus, es werden auch keine Änderungen am System vorgenommen, man könnte es also auch in einer Produktivumgebung nutzen
      Ich hoffe es finden sich einige die Lust zum Testen haben, am Ende wird das hoffentlich gute Ergebnis als Grundlage für einen PR verwendet welcher dann das Problem im iobroker fixt.
      schonmal Danke im Voraus, stay tuned
      iobroker läuft unter Docker auf Windows (WSL2)
      F 1 Antwort Letzte Antwort
      • F fastfoot
        F Online
        F Online
        fastfoot
        schrieb am zuletzt editiert von fastfoot
        hier das Skript für diejenigen die testen wollen
        • das Skript läuft nur auf Linux Systemen
        • das Skript ist für die cifs Verbindung zur Fritz Box konzipiert
          • für andere Systeme kann der mount-Befehl aus dem LOG des backitup Adapters gelesen werden
        • LXC Container benötigen für cifs den Privileged Mode
        • Docker Container benötigen Privileged Mode oder
          • cap_add:
            • SYS_ADMIN
            • DAC_READ_SEARCH
        Kleine Anleitung zur Erstellung und Aufruf
        • Das Skript muss in /opt/iobroker erstellt werden, wegen der Pfade
        • Der Name ist egal, z.B. cifs_test.js, die Endung .js ist wichtig
        • Die Einstellungen in den Zeilen 33-37 vornehmen
        • Aufruf von der Konsole in /opt/iobroker mit node cifs_test
        • umount und mount erfolgen im Skript
        "use strict";
         * Name:    cifs.js
         * Zweck:   Dient ausschliesslich dem Test von Fehlern im Zusammenhang mit
         *          cifs(smb) mit Fritz Box, Node >= 18.18.0 und BackitUp-Adapter
         *          bzw. iobroker-cli(iob backup)
         * Datum:   2023-10-08
         * Author:  @fastfoot
         * Forum:   https://forum.iobroker.net/post/1054910
        const fs_extra_1 = require("fs-extra");
        const path_1 = require("path");
        const promisify_child_process_1 = require("promisify-child-process");
        const { pipeline } = require("node:stream/promises");
        const tar_1 = require("tar");
        const zlib = require("node:zlib");
        const os = require("os");
        const { exit } = require("process");
        const { createWriteStream } = require("fs");
        if (os.platform != "linux") {
          console.log("This script can only work under Linux OS, terminating now...");
          exit(1);
        //                                 fixe Einstellungen, möglichst nicht ändern
        const tmpDir = "/opt/iobroker/node_modules"; // simuliert den tmp Ordner des Backitup-Adapters, NICHT ändern!
        const targetDir = "/opt/iobroker/backups"; // Standard Ordner für Backup Dateien, NICHT ändern!
        const fritzNasShare = "//fritz.box/fritz.nas"; // Standard Share der FritzBox, NICHT ändern!
        //                                 Einstellungen
        const fritzNasDir = "Backup"; // Individueller Ordner des Fritz!NAS
        const fritzPasswd = "iobrokertest"; // Passwort
        const fritzUser = "iobroker"; // User
        const fritzSMBVers = "3.1.1"; // gültige SMB Version ("1.0","2.0","3.0","3.0.2","3.1.1")oder ""
        const noserverinoOpt = true; // Verwendung noserverino Option true/false
        //                                           Ab hier Finger weg!
        const umountCmd = `sudo umount ${targetDir}`;
        const mountCmd = `sudo mount -t cifs -o username=${fritzUser},password=${fritzPasswd}${
          noserverinoOpt ? ",noserverino" : ""
        },rw,file_mode=0777,dir_mode=0777${
          fritzSMBVers ? ",vers=3.1.1" : ""
        } ${fritzNasShare}/${fritzNasDir} ${targetDir}`;
        test();
        async function test() {
          console.log("Copy output from below \n\n```");
          try {
            const { stdout } = await promisify_child_process_1.exec(umountCmd);
            console.log(`${targetDir} unmounted`);
          } catch (e) {
            console.log("umount not possible");
          try {
            await promisify_child_process_1.exec(mountCmd);
            console.log(`${fritzNasShare}/${fritzNasDir} mounted into ${targetDir}\n`);
          } catch (e) {
            console.log("mount not possible: " + e + "\n");
          try {
            let res1 = await alternative2(`test_pipeline_compressed_tar.tar.gz`, true);
            console.log(`file ${res1} done`);
            await countFilesInTar(res1);
            res1 = await alternative3(`test_pipeline_compressed_zlib.tar.gz`, false);
            res1 = await alternative4(`test_pipeline_uncompressed.tar`, false);
              `ls -lt ${targetDir}/test_*`
            console.log(`listing of created files in ${targetDir}\n` + stdout);
          } catch (e) {
            console.log(e);
          console.error("```\n\nEnd of output to copy");
        function standard(name, compression) {
          return new Promise((resolve, reject) => {
            const f = fs_extra_1.createWriteStream(`${targetDir}/${name}`);
            f.on("finish", () => {
              resolve(path_1.normalize(name));
            f.on("error", (e) => {
              console.error("error! : " + e);
              reject("Fehler im Stream");
            try {
              tar_1
                .create({ gzip: compression, cwd: `${tmpDir}/` }, [
                  "iobroker.js-controller",
                .pipe(f);
              console.log(`file ${name} created`);
            } catch (e) {
              reject(e);
        function alternative(name, compression = true) {
            try {
              tar_1
                .create(
                    //file: `${targetDir}/${name}`,
                    file: `${name}`,
                    gzip: compression,
                    cwd: `${tmpDir}/`,
                  ["iobroker.js-controller"]
                .then(async () => {
                  await promisify_child_process_1.exec(`mv ${name} ${targetDir}`);
            } catch (e) {
              reject(e);
        function alternative2(name, compression = true) {
          return new Promise(async (resolve, reject) => {
            try {
              await pipeline(
                tar_1.create(
                    gzip: compression,
                    cwd: `${tmpDir}/`,
                //zlib.createGzip(),
                fs_extra_1.createWriteStream(`${targetDir}/${name}`),
              resolve(name);
            } catch (e) {
              reject(e);
        function alternative3(name, compression = true) {
            try {
              await pipeline(
                tar_1.create(
                    gzip: compression,
                    cwd: `${tmpDir}/`,
                zlib.createGzip(),
              resolve(name);
            } catch (e) {
              reject(e);
        function alternative4(name, compression = true) {
            //const f = fs_extra_1.createWriteStream(`${targetDir}/${name}`);
            //f.on("finish", () => {
            //  resolve(path_1.normalize(name));
            //f.on("error", (e) => {
            //  console.error("error! : " + e);
            //  reject("Fehler im Stream");
            try {
              await pipeline(
                tar_1.create(
                    //file: `${name}`,
                    gzip: compression,
                    cwd: `${tmpDir}/`,
              resolve(name);
            } catch (e) {
              reject(e);
        async function countFilesInTar(name) {
          let { stdout } = await promisify_child_process_1.exec(
            `tar -tf ${targetDir}/${name}|wc -l`
          console.log(`number of files in ${name}: ${stdout}`);
        Bei Fagen, fragen!
        R O SO 3 Antworten Letzte Antwort
        • F fastfoot
            • cap_add:
              • SYS_ADMIN
              • DAC_READ_SEARCH
          "use strict";
           * Name:    cifs.js
           * Datum:   2023-10-08
           * Author:  @fastfoot
            exit(1);
          //                                 Einstellungen
          test();
            try {
            } catch (e) {
            try {
            } catch (e) {
            try {
            } catch (e) {
              console.log(e);
              try {
                tar_1
                  .pipe(f);
              } catch (e) {
                reject(e);
              try {
                tar_1
                  .create(
                      file: `${name}`,
                      gzip: compression,
                      cwd: `${tmpDir}/`,
                  .then(async () => {
              } catch (e) {
                reject(e);
              try {
                await pipeline(
                  tar_1.create(
                      gzip: compression,
                      cwd: `${tmpDir}/`,
                resolve(name);
              } catch (e) {
                reject(e);
              try {
                await pipeline(
                  tar_1.create(
                      gzip: compression,
                      cwd: `${tmpDir}/`,
                  zlib.createGzip(),
                resolve(name);
              } catch (e) {
                reject(e);
              try {
                await pipeline(
                  tar_1.create(
                      //file: `${name}`,
                      gzip: compression,
                      cwd: `${tmpDir}/`,
                resolve(name);
              } catch (e) {
                reject(e);
          Bei Fagen, fragen!
          Radi
          schrieb am zuletzt editiert von Radi
          @fastfoot sagte in TESTER gesucht / Backup auf Fritz.nas - node 18.18.0:
          node cifs_test
          Hier mal die Ausgabe deines Testscripts auf meinem System:
          /opt/iobroker/backups unmounted
          //192.168.69.254/fritz.nas/Volume/backup2 mounted into /opt/iobroker/backups
          file test_standard.tar.gz created
          file test_standard.tar.gz done
          number of files in test_standard.tar.gz: 0
          file test_nocompression.tar created
          file test_nocompression.tar done
          number of files in test_nocompression.tar: 5
          file test_alternative.tar.gz created
          file test_alternative.tar.gz done
          number of files in test_alternative.tar.gz: 0
          listing of created files in /opt/iobroker/backups
          -rwxrwxrwx 1 root root  16384  4. Okt 09:01 /opt/iobroker/backups/test_alternative.tar.gz
          -rwxrwxrwx 1 root root 251392  4. Okt 09:01 /opt/iobroker/backups/test_nocompression.tar
          -rwxrwxrwx 1 root root  16394  4. Okt 09:01 /opt/iobroker/backups/test_standard.tar.gz
          Ich hoffe, es hilft weiter, den Fehler einzugrenzen.
          Achtung, habe den Artikel noch mal bearbeitet.
          • F fastfoot
              • cap_add:
                • SYS_ADMIN
                • DAC_READ_SEARCH
            "use strict";
             * Name:    cifs.js
             * Datum:   2023-10-08
             * Author:  @fastfoot
              exit(1);
            //                                 Einstellungen
            test();
              try {
              } catch (e) {
              try {
              } catch (e) {
              try {
              } catch (e) {
                console.log(e);
                try {
                  tar_1
                    .pipe(f);
                } catch (e) {
                  reject(e);
                try {
                  tar_1
                    .create(
                        file: `${name}`,
                        gzip: compression,
                        cwd: `${tmpDir}/`,
                    .then(async () => {
                } catch (e) {
                  reject(e);
                try {
                  await pipeline(
                    tar_1.create(
                        gzip: compression,
                        cwd: `${tmpDir}/`,
                  resolve(name);
                } catch (e) {
                  reject(e);
                try {
                  await pipeline(
                    tar_1.create(
                        gzip: compression,
                        cwd: `${tmpDir}/`,
                    zlib.createGzip(),
                  resolve(name);
                } catch (e) {
                  reject(e);
                try {
                  await pipeline(
                    tar_1.create(
                        //file: `${name}`,
                        gzip: compression,
                        cwd: `${tmpDir}/`,
                  resolve(name);
                } catch (e) {
                  reject(e);
            Bei Fagen, fragen!
            O SO Offline
            O SO Offline
            O S
            @fastfoot
            Hier meine Ausgabe deines Testscriptes:
            umount not possible
            mount not possible: Error: Command failed: sudo mount -t cifs -o username=iobroker,password=iobrokertest,noserverino,rw,file_mode=0777,dir_mode=0777,vers=3.1.1 //fritz.box/fritz.nas/Backup /opt/iobroker/backups
            mount error(13): Permission denied
            Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
            number of files in test_standard.tar.gz: 155
            number of files in test_nocompression.tar: 155
            number of files in test_alternative.tar.gz: 155
            -rw-rw-r--+ 1 pi pi 10724080 Oct 4 12:50 /opt/iobroker/backups/test_alternative.tar.gz
            -rw-rw-r--+ 1 pi pi 41432576 Oct 4 12:50 /opt/iobroker/backups/test_nocompression.tar
            -rw-rw-r--+ 1 pi pi 10724080 Oct 4 12:50 /opt/iobroker/backups/test_standard.tar.gz
            Gruß Otto
            • F fastfoot
                • cap_add:
                  • SYS_ADMIN
                  • DAC_READ_SEARCH
              "use strict";
               * Name:    cifs.js
               * Datum:   2023-10-08
               * Author:  @fastfoot
                exit(1);
              //                                 Einstellungen
              test();
                try {
                } catch (e) {
                try {
                } catch (e) {
                try {
                } catch (e) {
                  console.log(e);
                  try {
                    tar_1
                      .pipe(f);
                  } catch (e) {
                    reject(e);
                  try {
                    tar_1
                      .create(
                          file: `${name}`,
                          gzip: compression,
                          cwd: `${tmpDir}/`,
                      .then(async () => {
                  } catch (e) {
                    reject(e);
                  try {
                    await pipeline(
                      tar_1.create(
                          gzip: compression,
                          cwd: `${tmpDir}/`,
                    resolve(name);
                  } catch (e) {
                    reject(e);
                  try {
                    await pipeline(
                      tar_1.create(
                          gzip: compression,
                          cwd: `${tmpDir}/`,
                      zlib.createGzip(),
                    resolve(name);
                  } catch (e) {
                    reject(e);
                  try {
                    await pipeline(
                      tar_1.create(
                          //file: `${name}`,
                          gzip: compression,
                          cwd: `${tmpDir}/`,
                    resolve(name);
                  } catch (e) {
                    reject(e);
              Bei Fagen, fragen!
              O SO Offline
              O SO Offline
              O S
              @fastfoot
              hier die korrigierte Fassung:
              umount not possible
              //fritz.box/fritz.nas/intenso/iobroker mounted into /opt/iobroker/backups
              -rwxrwxrwx 1 root root 10724083 Oct 4 13:36 /opt/iobroker/backups/test_alternative.tar.gz
              -rwxrwxrwx 1 root root 41432576 Oct 4 13:35 /opt/iobroker/backups/test_nocompression.tar
              -rwxrwxrwx 1 root root 10724083 Oct 4 13:35 /opt/iobroker/backups/test_standard.tar.gz
              • R Radi
                node cifs_test
                F Online
                F Online
                fastfoot
                @radi Das sieht mir sehr nach Schrott aus, ich denke da werden die falschen Parameter für das mounten benutzt. Bitte schau mal in deinen Backitup Adapter welche Settings du da benutzt, es geht um die SMB version und die noserverino Option, einzustellen im Skript in den Zeilen 36 + 37
                bitte abändern und nochmal laufen lassen
                • O SO O S
                  @fastfoot
                  umount not possible
                  F Online
                  F Online
                  fastfoot
                  @o-s sagte in TESTER gesucht / Backup auf Fritz.nas - node 18.18.0:
                  Das sieht aber nicht nach irgendwelchen Problemen aus. Falls Du im Backitup Adapter Probleme hast dann passe dort mal die SMB - Version und die noserverino entsprechend den Einstellungen im Skript an und lasse nochmal ein Backup über den Adapter laufen
                  O SO Thomas BraunT 2 Antworten Letzte Antwort
                  • F fastfoot
                    O SO Offline
                    O SO Offline
                    O S
                    @fastfoot
                    Bei diesen Einstellungen erhalte ich:
                    • F fastfoot
                      @fastfoot
                      umount not possible
                      //fritz.box/fritz.nas/Hitachi-HTS545012B9SA00-01/iobbackups/chet mounted into /opt/iobroker/backups
                      number of files in test_nocompression.tar: 0
                      -rwxrwxrwx 1 root root  16384 Oct  4 17:32 /opt/iobroker/backups/test_alternative.tar.gz
                      -rwxrwxrwx 1 root root 251392 Oct  4 17:32 /opt/iobroker/backups/test_nocompression.tar
                      -rwxrwxrwx 1 root root  16384 Oct  4 17:32 /opt/iobroker/backups/test_standard.tar.gz
                      Von mir auch nochmal.
                      mount schaut so aus:
                      //fritz.box/fritz.nas/Hitachi-HTS545012B9SA00-01/iobbackups/chet on /opt/iobroker/backups type cifs (rw,relatime,vers=3.1.1,cache=strict,username=iobroker,uid=0,noforceuid,gid=0,noforcegid,addr=2a02:0908:0391:30e0:1eed:6fff:fe57:f042,file_mode=0777,dir_mode=0777,soft,nounix,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=5)
                      • O SO O S
                        @fastfoot
                        F Online
                        F Online
                        fastfoot
                        @o-s ok, 16KB im Fehlerfall ist das eigentlich erwartete Ergebnis. Was mich sehr wundert ist dass beim Skript alles funktioniert. Das Skript verwendet zum Erstellen der Testdateien die gleiche Methodik wie der Adapter und sollte deshalb auch einen Fehler zumindest bei der test_standard.tar.gz zeigen. Was mich dennoch wundert ist die geringe Anzahl an Files.
                        • Nutzt du als tmpDir = "/opt/iobroker/node_modules"; ?
                        • welche controller version iob -v ?
                        • welche Backitup Version?
                        Ich ändere später noch das Skript um mehr Infos zu bekommen
                        O SO 1 Antwort Letzte Antwort
                          @fastfoot
                          umount not possible
                          F Online
                          F Online
                          fastfoot
                          @thomas-braun ist das die gleiche Config mit der wir die Tage getestet hatten? Da hatte nämlich sowohl die alternative Methode als auch die unkomprimierte Version funktioniert. Die unkomprimierte Version ist zwar grösser aber ich denke mal dass sie auch korrupt ist(tar -tf backups/test_nocompression.tar).
                          Hier mein Output mit aktuellem js-controller
                          //fritz.box/fritz.nas/Backup mounted into /opt/iobroker/backups
                          number of files in test_standard.tar.gz: 292
                          number of files in test_nocompression.tar: 292
                          number of files in test_alternative.tar.gz: 292
                          -rwxrwxrwx 1 root root  7109435 Okt  4 18:02 /opt/iobroker/backups/test_alternative.tar.gz
                          -rwxrwxrwx 1 root root 42487808 Okt  4 18:02 /opt/iobroker/backups/test_nocompression.tar
                          -rwxrwxrwx 1 root root  7109456 Okt  4 18:02 /opt/iobroker/backups/test_standard.tar.gz
                          • F fastfoot
                            Ja, im Grund schon. Ich mounte über die fstab allerdings mit smbcredentials statt user/pw, aber das sollte keinen Unterschied machen, die Freigabe landet ja im Mountpunkt.
                            • F fastfoot
                              O SO Offline
                              O SO Offline
                              O S
                              @fastfoot
                              Ich nutze opt/iobroker/node_modules
                              Controller: 5.0.12
                              Backitup: 2.8.1
                              • O SO O S
                                @fastfoot
                                Controller: 5.0.12
                                Backitup: 2.8.1
                                F Online
                                F Online
                                fastfoot
                                @fastfoot
                                Controller: 5.0.12
                                Backitup: 2.8.1
                                ja das passt, es gibt in der Beta eine 2.8.2 aber ich glaube nicht dass das einen Unterschied macht.
                                Das macht mich erstmal etwas rarlos...
                                • F fastfoot
                                  @fastfoot
                                  Output des check-skripts, anschließen manuelles backup in das lokale FS.
                                  echad@chet:/opt/iobroker $ ls -lAh backups/
                                  total 280K
                                  -rwxrwxrwx 1 root root    0 Oct  4 18:16 01_FREIGABE_FRITZ_NAS
                                  -rwxrwxrwx 1 root root  16K Oct  4 18:17 test_alternative.tar.gz
                                  -rwxrwxrwx 1 root root 246K Oct  4 18:17 test_nocompression.tar
                                  -rwxrwxrwx 1 root root  16K Oct  4 18:17 test_standard.tar.gz
                                  echad@chet:/opt/iobroker $ sudo umount /opt/iobroker/backups
                                  echad@chet:/opt/iobroker $ iob backup
                                  host.chet 8105 states saved
                                  host.chet 9932 objects saved
                                  Backup created: /opt/iobroker/backups/2023_10_04-18_18_01_backupiobroker.tar.gz
                                  This backup can only be restored with js-controller version up from 4.1
                                  total 5.8M
                                  -rw-rw-r--+ 1 iobroker iobroker 5.8M Oct  4 18:18 2023_10_04-18_18_01_backupiobroker.tar.gz
                                  • simatecS Online
                                    simatecS Online
                                    simatec
                                    Wir können für den Anfang erstmal festhalten, dass es nicht an Backitup liegt und mir aktuell bekannt, nur in Verbindung mit der FRITZ!Box die Probleme auftreten.
                                    Wäre gut, wenn andere ohne Fritz NAS hier auch noch Ihre Ergebnisse teilen könnten. So können wir gezielt eingrenzen..
                                    @Thomas-Braun
                                    Hast du noch ne Idee, ob wir im Mount noch zusätzliche Parameter testen können?
                                    • Besuche meine Github Seite
                                    • HowTo Restore ioBroker
                                    Thomas BraunT F 2 Antworten Letzte Antwort
                                      F Online
                                      F Online
                                      fastfoot
                                      @thomas-braun sagte in TESTER gesucht / Backup auf Fritz.nas - node 18.18.0:
                                      ich dachte da eher an andere(ältere) Hardware. Für die Alternate Methode habe ich ne Erklärung, wir hatten mit Erstellen und dann kopieren getestet, jetzt schreibe ich das gleich in den mount, werde ich ändern. Aber uncompressed im Adapter hatte funktioniert und mit Skript nicht.
                                      Wenn der Mount immer besteht, wie handelst du das im Adapter, der mounted doch auch immer? Dazu könntest du aber NAS/COPY ausschalten und 'normal' ein Backup machen, geht ja dann als Standard in den mountpoint. Als Alternative dazu NAS/COPY von cifs auf copy umstellen und als Pfad /opt/iobroker/backups einstellen. Wäre interessant zu sehen ob das einen Unterschied macht.
                                      OT: Wie sieht denn der Eintrag im fstab aus? incl. der smb-credentials bitte, ohne PW narürlich
                                        @fastfoot
                                        total 280K
                                        total 5.8M
                                        simatecS Online
                                        simatecS Online
                                        simatec
                                        Kannst du mal bitte den Mount manuell setzen und die Optionen probieren?
                                        • cache: Die Deaktivierung des Caches cache=none kann helfen, falls die SMB-Freigaben nicht korrekt eingehangen werden.
                                        • nobrl: Deaktivierung der Bytebereich-Sperrung (Byte-Range Lock). Einige Programme kommen mit dem Byte-Range Lock nicht zurecht und können deshalb auf gemountete SMB-Freigaben trotz korrekter Berechtigungen nicht schreiben. Abhilfe schafft hier die Mount-Option nobrl.
                                        • simatecS simatec
                                          @Thomas-Braun
                                          @simatec sagte in TESTER gesucht / Backup auf Fritz.nas - node 18.18.0:
                                          Ich bin komplett ratlos. Es muss aber mit tar und/oder gzip in Verbindung stehen. Bereits gepackte Backup kann ich z. B. auf die Freigabe schieben.
