  4. Absturz bei Aktualisierung - Neustart nicht möglich!
    3.2k
139 Beiträge 8 Kommentatoren 19.0k Aufrufe 7 Beobachtet
  • L LaBamba
    @ thomas-braun
    Erstmal ist alles durchgelaufen.
    Soweit ganz gut!
    Bei node-red fehlen ein paar Paletten.
    In der Bib ist nichts zu finden.
    LaBamba
    #121
    Node-Red Problem gelöst!
      @labamba sagte in Absturz bei Aktualisierung - Neustart nicht möglich!:
      yeelight 2.1 Adapter stürzt ständig ab.
      Ohne was zu sagen? Wie frech!
      LaBamba
      #122
      yeelight-2.1
      2023-08-30 16:34:02.933	error	Exception-Code: ERR_SOCKET_CLOSED_BEFORE_CONNECTION: Socket closed before the connection was established
      yeelight-2.1
      2023-08-30 16:34:02.932	error	Error: Socket closed before the connection was established at new NodeError (node:internal/errors:405:5) at Socket.onClose (node:net:912:10) at Object.onceWrapper (node:events:629:26) at Socket.emit (node:events:526:35) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:323:12)
      yeelight-2.1
      2023-08-30 16:34:02.930	error	unhandled promise rejection: Socket closed before the connection was established
      yeelight-2.1
      2023-08-30 16:34:02.929	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      yeelight-2.1
      2023-08-30 16:34:02.581	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      yeelight-2.1
      2023-08-30 16:34:02.519	error	Exception-Code: ERR_INVALID_ARG_TYPE: The "options.port" property must be one of type number or string. Received null
      yeelight-2.1
      2023-08-30 16:34:02.517	error	TypeError: The "options.port" property must be one of type number or string. Received null at new NodeError (node:internal/errors:405:5) at lookupAndConnect (node:net:1225:13) at Socket.connect (node:net:1194:5) at new Yeelight (/opt/iobroker/node_modules/iobroker.yeelight-2/yeelight-wifi/build/Yeelight.js:126:18) at YeelightSearch.addInitLights (/opt/iobroker/node_modules/iobroker.yeelight-2/yeelight-wifi/build/index.js:104:22) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.yeelight-2/main.js:490:74) at listOnTimeout (node:internal/timers:569:17) at processTimers (node:internal/timers:512:7)
      yeelight-2.1
      2023-08-30 16:34:02.516	error	uncaught exception: The "options.port" property must be one of type number or string. Received null
      yeelight-2.1
      2023-08-30 16:33:58.884	error	Try to create device with empty name!
      • DJMarc75D DJMarc75
        Soweit ganz gut!
        Und wieder mal die Ausgabe von
        iob diag
        bitte - langsam nervts Dich daran zu erinnern ;)
        LaBamba
        schrieb am zuletzt editiert von LaBamba
        #123
        @djmarc75 said in Absturz bei Aktualisierung - Neustart nicht möglich!:
        iob diag
                             v.2023-04-16
        Operatingsystem:        Debian GNU/Linux 11 (bullseye)
        Kernel:                 6.1.21-v8+
        Installation:           Native
        Timezone:               Europe/Berlin (CEST, +0200)
        User-ID:                1000
        X-Server:               true
        Pending OS-Updates:     0
        Pending iob updates:    26
        Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                /usr/bin/node           v18.17.1
                                /usr/bin/npm            9.6.7
                                /usr/bin/npx            9.6.7
        Recommended versions are nodejs 18.x.y and npm 9.x.y
        MEMORY:
        Mem:            3.8G        2.7G        361M         34M        754M        951M
        Swap:            99M        1.0M         98M
        Total:          3.9G        2.7G        460M
        Active iob-Instances:   27
        Active repo(s): beta
        ioBroker Core:          js-controller           4.0.24
                                admin                   6.4.3
        Objects type: jsonl
        States  type: jsonl
        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 192.168.178.59, run as: admin
          system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi                              - disabled
        Objects:                20804
        States:                 28568
        Size of iob-Database:
        38M     /opt/iobroker/iobroker-data/objects.jsonl
        39M     /opt/iobroker/iobroker-data/states.jsonl
        Sorry so viel zu tun! Reicht dir das?
        • L LaBamba
          yeelight-2.1
          yeelight-2.1
          yeelight-2.1
          yeelight-2.1
          yeelight-2.1
          yeelight-2.1
          yeelight-2.1
          yeelight-2.1
          yeelight-2.1
          #124
          @labamba
          Guckstu:
          https://github.com/iobroker-community-adapters/ioBroker.yeelight-2/issues/227
          L 2 Antworten Letzte Antwort
            @labamba
            Guckstu:
            LaBamba
            #125
            Schaue ich mir mal an!
            Sonst noch einige Fehler
            host.raspberrypi
            2023-08-30 16:47:14.011	error	instance system.adapter.yeelight-2.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
            host.raspberrypi
            2023-08-30 16:47:14.011	error	Caught by controller[0]: }
            host.raspberrypi
            2023-08-30 16:47:14.010	error	Caught by controller[0]: code: 'ERR_INVALID_ARG_TYPE'
            host.raspberrypi
            2023-08-30 16:47:14.010	error	Caught by controller[0]: at processTimers (node:internal/timers:512:7) {
            host.raspberrypi
            2023-08-30 16:47:14.009	error	Caught by controller[0]: at listOnTimeout (node:internal/timers:569:17)
            host.raspberrypi
            2023-08-30 16:47:14.006	error	Caught by controller[0]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.yeelight-2/main.js:490:74)
            host.raspberrypi
            2023-08-30 16:47:14.006	error	Caught by controller[0]: at YeelightSearch.addInitLights (/opt/iobroker/node_modules/iobroker.yeelight-2/yeelight-wifi/build/index.js:104:22)
            host.raspberrypi
            2023-08-30 16:47:14.005	error	Caught by controller[0]: at new Yeelight (/opt/iobroker/node_modules/iobroker.yeelight-2/yeelight-wifi/build/Yeelight.js:126:18)
            host.raspberrypi
            2023-08-30 16:47:14.005	error	Caught by controller[0]: at Socket.connect (node:net:1194:5)
            host.raspberrypi
            2023-08-30 16:47:14.005	error	Caught by controller[0]: at lookupAndConnect (node:net:1225:13)
            host.raspberrypi
            2023-08-30 16:47:14.005	error	Caught by controller[0]: at new NodeError (node:internal/errors:405:5)
            host.raspberrypi
            2023-08-30 16:47:14.004	error	Caught by controller[0]: TypeError: The "options.port" property must be one of type number or string. Received null
            L 1 Antwort Letzte Antwort
              @labamba
              Guckstu:
              LaBamba
              #126
              @DJMarc75
              @Homoran
              @crunchip
              Ein großes Dankeschön für euere Unterstützung!
              Bis auf ein paar Kleinigkeiten läuft der iobroker wieder!
              ... und ich habe viel dabei gelernt!
              • L LaBamba
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                LaBamba
                #127
                @DJMarc75
                @Homoran
                @crunchip
                So noch einige Fehler
                viessmannapi.0
                2023-08-30 21:02:08.916	error	Error: Request failed with status code 404
                viessmannapi.0
                2023-08-30 21:02:08.915	error	Receiving Events
                Ich habe jetzt gesucht, aber weiß wirklich nicht wo ich den Bildschirm ausstellen kann!
                • L LaBamba
                  @DJMarc75
                  @Homoran
                  @crunchip
                  viessmannapi.0
                  viessmannapi.0
                  #128
                  sudo raspi-config
                  Dann dort im Menü diese Punkte:
                  1 System Options
                  S5 Boot / Auto Login
                  B1 Console
                    sudo raspi-config
                    1 System Options
                    B1 Console
                    LaBamba
                    #129
                    Nach dem update auf Version 2.1 von ViessmannAPI läuft es jetzt erstmal wieder.
                      sudo raspi-config
                      1 System Options
                      B1 Console
                      LaBamba
                      #130
                      Was nimmt man da?
                      W CodierknechtC 2 Antworten Letzte Antwort
                      • L LaBamba
                        Was nimmt man da?
                        W Online
                        W Online
                        Wildbill
                        #131
                        @labamba Hat @Thomas-Braun doch oben geschrieben. B1 Console.
                        Dann fährt der Raspi hoch und startet alle Dienste. Wenn Du einen Bildschirm anschliessen würdest, dann blinkt Dich ein Login-Prompt an. Dann müsstest Du user und passwort eingeben. Aber da Du ja nicht direkt am Raspi arbeitest ist das OK.
                        Wenn Du zugreifst, dann ja per SSH, dann meldest Du Dich ja eh an. Also braucht es keine Anmeldung direkt am Raspi nach dem Hochfahren, iobroker läuft dennoch.
                        Gruss, Jürgen
                        L Thomas BraunT 2 Antworten Letzte Antwort
                        • L LaBamba
                          Was nimmt man da?
                          CodierknechtC Online
                          Codierknecht
                          #132
                          @Wildbill war schneller ;-)
                          HmIP|ZigBee|Tasmota|Unifi
                          Zabbix Certified Specialist
                          W 1 Antwort Letzte Antwort
                          • W Wildbill
                            Gruss, Jürgen
                            LaBamba
                            #133
                            @wildbill
                            @Codierknecht
                            Danke, habe ich überlesen!
                            • CodierknechtC Codierknecht
                              W Online
                              W Online
                              Wildbill
                              schrieb am zuletzt editiert von Wildbill
                              #134
                              @codierknecht Obwohl ich viel mehr getippt hatte als Du. 😊
                              • W Wildbill
                                Gruss, Jürgen
                                #135
                                @wildbill sagte in Absturz bei Aktualisierung - Neustart nicht möglich!:
                                Und man will keine Terminals 'offen' in der Gegend herumstehen haben.
                                  LaBamba
                                  #136
                                  @DJMarc75
                                  @Homoran
                                  @crunchip
                                  dwd.0
                                  2023-08-30 22:15:07.759	error	Empty or invalid JSON: Cannot read JSON file: AxiosError: Request failed with status code 404
                                  So langsam werden die Probleme weniger.
                                  • L LaBamba
                                    @DJMarc75
                                    @Homoran
                                    @crunchip
                                    dwd.0
                                    HomoranH Offline
                                    HomoranH Offline
                                    #137
                                    @labamba ja und? DWD im Netzwerk nicht erreichbar. Die (nicht zurückkommende) Antwort enthält nicht due erwarteten Inhalte
                                      LaBamba
                                      #138
                                      Da es aktuell keine Warnungen gibt oder weil etwas nicht stimmt.
                                      • L LaBamba
                                        HomoranH Offline
                                        HomoranH Offline
                                        #139
                                        @homoran sagte in Absturz bei Aktualisierung - Neustart nicht möglich!:
                                        = 404 = page not found
