  4. Absturz bei Aktualisierung - Neustart nicht möglich!
    5.2k
139 Beiträge 8 Kommentatoren 19.7k Aufrufe 7 Beobachtet
    @labamba
    Guckstu:
    https://github.com/iobroker-community-adapters/ioBroker.yeelight-2/issues/227
    LaBamba
    #125
    Schaue ich mir mal an!
    Sonst noch einige Fehler
    host.raspberrypi
    2023-08-30 16:47:14.011	error	instance system.adapter.yeelight-2.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi
    2023-08-30 16:47:14.011	error	Caught by controller[0]: }
    host.raspberrypi
    2023-08-30 16:47:14.010	error	Caught by controller[0]: code: 'ERR_INVALID_ARG_TYPE'
    host.raspberrypi
    2023-08-30 16:47:14.010	error	Caught by controller[0]: at processTimers (node:internal/timers:512:7) {
    host.raspberrypi
    2023-08-30 16:47:14.009	error	Caught by controller[0]: at listOnTimeout (node:internal/timers:569:17)
    host.raspberrypi
    2023-08-30 16:47:14.006	error	Caught by controller[0]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.yeelight-2/main.js:490:74)
    host.raspberrypi
    2023-08-30 16:47:14.006	error	Caught by controller[0]: at YeelightSearch.addInitLights (/opt/iobroker/node_modules/iobroker.yeelight-2/yeelight-wifi/build/index.js:104:22)
    host.raspberrypi
    2023-08-30 16:47:14.005	error	Caught by controller[0]: at new Yeelight (/opt/iobroker/node_modules/iobroker.yeelight-2/yeelight-wifi/build/Yeelight.js:126:18)
    host.raspberrypi
    2023-08-30 16:47:14.005	error	Caught by controller[0]: at Socket.connect (node:net:1194:5)
    host.raspberrypi
    2023-08-30 16:47:14.005	error	Caught by controller[0]: at lookupAndConnect (node:net:1225:13)
    host.raspberrypi
    2023-08-30 16:47:14.005	error	Caught by controller[0]: at new NodeError (node:internal/errors:405:5)
    host.raspberrypi
    2023-08-30 16:47:14.004	error	Caught by controller[0]: TypeError: The "options.port" property must be one of type number or string. Received null
    L 1 Antwort Letzte Antwort
      @labamba
      Guckstu:
      LaBamba
      #126
      @DJMarc75
      @Homoran
      @crunchip
      Ein großes Dankeschön für euere Unterstützung!
      Bis auf ein paar Kleinigkeiten läuft der iobroker wieder!
      ... und ich habe viel dabei gelernt!
      • L LaBamba
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        LaBamba
        schrieb am zuletzt editiert von LaBamba
        #127
        @DJMarc75
        @Homoran
        @crunchip
        So noch einige Fehler
        viessmannapi.0
        2023-08-30 21:02:08.916	error	Error: Request failed with status code 404
        viessmannapi.0
        2023-08-30 21:02:08.915	error	Receiving Events
        Ich habe jetzt gesucht, aber weiß wirklich nicht wo ich den Bildschirm ausstellen kann!
        • L LaBamba
          @DJMarc75
          @Homoran
          @crunchip
          viessmannapi.0
          viessmannapi.0
          #128
          @labamba sagte in Absturz bei Aktualisierung - Neustart nicht möglich!:
          sudo raspi-config
          Dann dort im Menü diese Punkte:
          1 System Options
          S5 Boot / Auto Login
          B1 Console
          L 2 Antworten Letzte Antwort
            sudo raspi-config
            1 System Options
            B1 Console
            LaBamba
            #129
            Nach dem update auf Version 2.1 von ViessmannAPI läuft es jetzt erstmal wieder.
              sudo raspi-config
              1 System Options
              B1 Console
              LaBamba
              #130
              Was nimmt man da?
              W CodierknechtC 2 Antworten Letzte Antwort
              • L LaBamba
                Was nimmt man da?
                W Online
                W Online
                Wildbill
                #131
                @labamba Hat @Thomas-Braun doch oben geschrieben. B1 Console.
                Dann fährt der Raspi hoch und startet alle Dienste. Wenn Du einen Bildschirm anschliessen würdest, dann blinkt Dich ein Login-Prompt an. Dann müsstest Du user und passwort eingeben. Aber da Du ja nicht direkt am Raspi arbeitest ist das OK.
                Wenn Du zugreifst, dann ja per SSH, dann meldest Du Dich ja eh an. Also braucht es keine Anmeldung direkt am Raspi nach dem Hochfahren, iobroker läuft dennoch.
                Gruss, Jürgen
                L Thomas BraunT 2 Antworten Letzte Antwort
                • L LaBamba
                  Was nimmt man da?
                  CodierknechtC Offline
                  Codierknecht
                  #132
                  @Wildbill war schneller ;-)
                  HmIP|ZigBee|Tasmota|Unifi
                  Zabbix Certified Specialist
                  W 1 Antwort Letzte Antwort
                  • W Wildbill
                    Gruss, Jürgen
                    LaBamba
                    #133
                    @wildbill
                    @Codierknecht
                    Danke, habe ich überlesen!
                    • CodierknechtC Codierknecht
                      W Online
                      W Online
                      Wildbill
                      schrieb am zuletzt editiert von Wildbill
                      #134
                      @codierknecht Obwohl ich viel mehr getippt hatte als Du. 😊
                      • W Wildbill
                        Gruss, Jürgen
                        #135
                        @wildbill sagte in Absturz bei Aktualisierung - Neustart nicht möglich!:
                        Und man will keine Terminals 'offen' in der Gegend herumstehen haben.
                          LaBamba
                          #136
                          @DJMarc75
                          @Homoran
                          @crunchip
                          dwd.0
                          2023-08-30 22:15:07.759	error	Empty or invalid JSON: Cannot read JSON file: AxiosError: Request failed with status code 404
                          So langsam werden die Probleme weniger.
                          • L LaBamba
                            @DJMarc75
                            @Homoran
                            @crunchip
                            dwd.0
                            #137
                            @labamba ja und? DWD im Netzwerk nicht erreichbar. Die (nicht zurückkommende) Antwort enthält nicht due erwarteten Inhalte
                              LaBamba
                              #138
                              Da es aktuell keine Warnungen gibt oder weil etwas nicht stimmt.
                              • L LaBamba
                                #139
                                @homoran sagte in Absturz bei Aktualisierung - Neustart nicht möglich!:
                                = 404 = page not found
