  4. Absturz bei Aktualisierung - Neustart nicht möglich!
    5.2k
139 Beiträge 8 Kommentatoren 19.7k Aufrufe 7 Beobachtet
  • L LaBamba
    Schaue ich mir mal an!
    Sonst noch einige Fehler
    host.raspberrypi
    2023-08-30 16:47:14.011	error	instance system.adapter.yeelight-2.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi
    2023-08-30 16:47:14.011	error	Caught by controller[0]: }
    host.raspberrypi
    2023-08-30 16:47:14.010	error	Caught by controller[0]: code: 'ERR_INVALID_ARG_TYPE'
    host.raspberrypi
    2023-08-30 16:47:14.010	error	Caught by controller[0]: at processTimers (node:internal/timers:512:7) {
    host.raspberrypi
    2023-08-30 16:47:14.009	error	Caught by controller[0]: at listOnTimeout (node:internal/timers:569:17)
    host.raspberrypi
    2023-08-30 16:47:14.006	error	Caught by controller[0]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.yeelight-2/main.js:490:74)
    host.raspberrypi
    2023-08-30 16:47:14.006	error	Caught by controller[0]: at YeelightSearch.addInitLights (/opt/iobroker/node_modules/iobroker.yeelight-2/yeelight-wifi/build/index.js:104:22)
    host.raspberrypi
    2023-08-30 16:47:14.005	error	Caught by controller[0]: at new Yeelight (/opt/iobroker/node_modules/iobroker.yeelight-2/yeelight-wifi/build/Yeelight.js:126:18)
    host.raspberrypi
    2023-08-30 16:47:14.005	error	Caught by controller[0]: at Socket.connect (node:net:1194:5)
    host.raspberrypi
    2023-08-30 16:47:14.005	error	Caught by controller[0]: at lookupAndConnect (node:net:1225:13)
    host.raspberrypi
    2023-08-30 16:47:14.005	error	Caught by controller[0]: at new NodeError (node:internal/errors:405:5)
    host.raspberrypi
    2023-08-30 16:47:14.004	error	Caught by controller[0]: TypeError: The "options.port" property must be one of type number or string. Received null
    LaBamba
    schrieb am zuletzt editiert von LaBamba
    #127
    @DJMarc75
    @Homoran
    @crunchip
    So noch einige Fehler
    viessmannapi.0
    2023-08-30 21:02:08.916	error	Error: Request failed with status code 404
    viessmannapi.0
    2023-08-30 21:02:08.915	error	Receiving Events
    Ich habe jetzt gesucht, aber weiß wirklich nicht wo ich den Bildschirm ausstellen kann!
    • L LaBamba
      @DJMarc75
      @Homoran
      @crunchip
      viessmannapi.0
      viessmannapi.0
      #128
      @labamba sagte in Absturz bei Aktualisierung - Neustart nicht möglich!:
      sudo raspi-config
      Dann dort im Menü diese Punkte:
      1 System Options
      S5 Boot / Auto Login
      B1 Console
      L 2 Antworten Letzte Antwort
        sudo raspi-config
        1 System Options
        B1 Console
        LaBamba
        #129
        Nach dem update auf Version 2.1 von ViessmannAPI läuft es jetzt erstmal wieder.
          sudo raspi-config
          1 System Options
          B1 Console
          LaBamba
          #130
          Was nimmt man da?
          W CodierknechtC 2 Antworten Letzte Antwort
          • L LaBamba
            Was nimmt man da?
            W Online
            W Online
            Wildbill
            #131
            @labamba Hat @Thomas-Braun doch oben geschrieben. B1 Console.
            Dann fährt der Raspi hoch und startet alle Dienste. Wenn Du einen Bildschirm anschliessen würdest, dann blinkt Dich ein Login-Prompt an. Dann müsstest Du user und passwort eingeben. Aber da Du ja nicht direkt am Raspi arbeitest ist das OK.
            Wenn Du zugreifst, dann ja per SSH, dann meldest Du Dich ja eh an. Also braucht es keine Anmeldung direkt am Raspi nach dem Hochfahren, iobroker läuft dennoch.
            Gruss, Jürgen
            L Thomas BraunT 2 Antworten Letzte Antwort
            • L LaBamba
              Was nimmt man da?
              CodierknechtC Offline
              Codierknecht
              #132
              @Wildbill war schneller ;-)
              HmIP|ZigBee|Tasmota|Unifi
              Zabbix Certified Specialist
              W 1 Antwort Letzte Antwort
              • W Wildbill
                Gruss, Jürgen
                LaBamba
                #133
                @wildbill
                @Codierknecht
                Danke, habe ich überlesen!
                • CodierknechtC Codierknecht
                  W Online
                  W Online
                  Wildbill
                  schrieb am zuletzt editiert von Wildbill
                  #134
                  @codierknecht Obwohl ich viel mehr getippt hatte als Du. 😊
                  • W Wildbill
                    Gruss, Jürgen
                    #135
                    @wildbill sagte in Absturz bei Aktualisierung - Neustart nicht möglich!:
                    Und man will keine Terminals 'offen' in der Gegend herumstehen haben.
                    L 1 Antwort Letzte Antwort
                      LaBamba
                      #136
                      @DJMarc75
                      @Homoran
                      @crunchip
                      dwd.0
                      2023-08-30 22:15:07.759	error	Empty or invalid JSON: Cannot read JSON file: AxiosError: Request failed with status code 404
                      So langsam werden die Probleme weniger.
                      • L LaBamba
                        @DJMarc75
                        @Homoran
                        @crunchip
                        dwd.0
                        #137
                        @labamba ja und? DWD im Netzwerk nicht erreichbar. Die (nicht zurückkommende) Antwort enthält nicht due erwarteten Inhalte
                          LaBamba
                          #138
                          Da es aktuell keine Warnungen gibt oder weil etwas nicht stimmt.
                          • L LaBamba
                            #139
                            @homoran sagte in Absturz bei Aktualisierung - Neustart nicht möglich!:
                            = 404 = page not found
