  4. Noch ein Zigbee Problem....
    5.2k
137 Beiträge 7 Kommentatoren 24.7k Aufrufe 5 Beobachtet
  • B brokeling
    @djmarc75
    Summary:
                         v.2023-04-16
    Operatingsystem:        Raspbian GNU/Linux 10 (buster)
    Kernel:                 5.10.103-v7l+
    Installation:           Native
    Timezone:               Europe/Berlin (CEST, +0200)
    User-ID:                1000
    X-Server:               false
    Boot Target:            multi-user.target
    Pending OS-Updates:     8
    Pending iob updates:    5
    Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                            /usr/bin/node           v18.17.1
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:           3.8G        1.6G        1.2G        8.0M        921M        2.0G
    Swap:           99M          0B         99M
    Total:         3.9G        1.6G        1.3G
    Active iob-Instances:   33
    Active repo(s): beta
    ioBroker Core:          js-controller           5.0.11
                            admin                   6.7.2
    Objects type: jsonl
    States  type: redis
    + system.adapter.admin.1                  : admin                 : raspi                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.web.0                    : web                   : raspi                                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects:                17066
    States:                 12808
    Size of iob-Database:
    22M     /opt/iobroker/iobroker-data/objects.jsonl
    8.4M    /opt/iobroker/iobroker-data/objects.json.migrated
    8.4M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    12K     /opt/iobroker/iobroker-data/objects.json.old
    41M     /opt/iobroker/iobroker-data/states.json.old
    41M     /opt/iobroker/iobroker-data/states.json.bak
    0       /opt/iobroker/iobroker-data/states.json
    lange Version:
    ======== Start marking the full check here =========
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Architecture    : armv7l
    Docker          : false
    Virtualization  : none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 10 (buster)
    Release:        10
    Codename:       buster
    PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="10"
    VERSION="10 (buster)"
    VERSION_CODENAME=buster
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     14:19:25 up 5 min,  1 user,  load average: 4.56, 4.04, 1.85
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=64.2'C
    volt=0.8375V
    *** Time and Time Zones ***
                   Local time: Thu 2023-08-17 14:19:25 CEST
               Universal time: Thu 2023-08-17 12:19:25 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           3.8G        1.6G        1.3G        8.0M        918M        2.1G
    Swap:           99M          0B         99M
    Total:         3.9G        1.6G        1.4G
             3786 M total memory
             1568 M used memory
              363 M active memory
             1974 M inactive memory
             1298 M free memory
              109 M buffer memory
              809 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    lifetime oom required: 0 Mbytes
    total time in oom handler: 0 ms
    max time spent in oom handler: 0 ms
    *** FILESYSTEM ***
    /dev/root      ext4      117G   17G   94G  16% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
    tmpfs          tmpfs     1.9G  8.6M  1.9G   1% /run
    tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
    /dev/sdb1      ext4      113G   71G   37G  66% /backup
    /dev/sda1      vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     379M     0  379M   0% /run/user/1000
    [Thu Aug 17 14:13:40 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:40:0F:7D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Thu Aug 17 14:13:42 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    [Thu Aug 17 14:13:42 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Thu Aug 17 14:13:43 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
    [Thu Aug 17 14:13:46 2023] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)
    Show mounted filesystems (real ones only):
    TARGET        SOURCE    FSTYPE OPTIONS
    /             /dev/sda2 ext4   rw,noatime,stripe=8191
    |-/sys/fs/bpf none      bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    |-/backup     /dev/sdb1 ext4   rw,noatime
    `-/boot       /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    5.8G    /var/
    3.4G    /var/cache
    3.3G    /var/cache/apt/archives
    3.3G    /var/cache/apt
    2.4G    /var/lib
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    2.9G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.1G    /opt/iobroker/iobroker-data/
    541M    /opt/iobroker/iobroker-data/backup-objects
    383M    /opt/iobroker/iobroker-data/files
    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js.map
    *** NodeJS-Installation ***
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
            100 /var/lib/dpkg/status
         16.20.2-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
         14.21.3-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
         12.22.12-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: redis
    MULTIHOSTSERVICE/enabled: false
    Core adapters versions
    js-controller:  5.0.11
    admin:          6.7.2
    javascript:     7.1.4
    Adapters from github:   3
    Adapter State
      system.adapter.alias-manager.0          : alias-manager         : raspi                                    -  enabled
    + system.adapter.backitup.0               : backitup              : raspi                                    -  enabled
    + system.adapter.chromecast.0             : chromecast            : raspi                                    -  enabled
    + system.adapter.cloud.0                  : cloud                 : raspi                                    -  enabled
      system.adapter.deconz.0                 : deconz                : raspi                                    - disabled, port: 80
      system.adapter.devices.0                : devices               : raspi                                    -  enabled
    + system.adapter.discovery.0              : discovery             : raspi                                    -  enabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspi                                    - disabled
      system.adapter.feiertage.0              : feiertage             : raspi                                    -  enabled
      system.adapter.flot.0                   : flot                  : raspi                                    -  enabled
      system.adapter.fritzdect.0              : fritzdect             : raspi                                    - disabled
      system.adapter.hue-extended.0           : hue-extended          : raspi                                    - disabled
      system.adapter.hue.0                    : hue                   : raspi                                    - disabled, port: 443
      system.adapter.ical.0                   : ical                  : raspi                                    -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : raspi                                    -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspi                                    -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspi                                    -  enabled
      system.adapter.iqontrol.0               : iqontrol              : raspi                                    - disabled
    + system.adapter.javascript.0             : javascript            : raspi                                    -  enabled
      system.adapter.luftdaten.0              : luftdaten             : raspi                                    -  enabled
      system.adapter.luftdaten.1              : luftdaten             : raspi                                    -  enabled
      system.adapter.mqtt.0                   : mqtt                  : raspi                                    - disabled, port: 1884, bind: 0.0.0.0
    + system.adapter.net-tools.0              : net-tools             : raspi                                    -  enabled
    + system.adapter.netatmo-crawler.0        : netatmo-crawler       : raspi                                    -  enabled
    + system.adapter.nuki.0                   : nuki                  : raspi                                    -  enabled
    + system.adapter.onvif.0                  : onvif                 : raspi                                    -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
    + system.adapter.ping.0                   : ping                  : raspi                                    -  enabled
    + system.adapter.pushover.0               : pushover              : raspi                                    -  enabled
    + system.adapter.reolink.0                : reolink               : raspi                                    -  enabled
    + system.adapter.reolink.1                : reolink               : raspi                                    -  enabled
    + system.adapter.reolink.2                : reolink               : raspi                                    -  enabled
    + system.adapter.reolink.3                : reolink               : raspi                                    -  enabled
    + system.adapter.reolink.4                : reolink               : raspi                                    -  enabled
      system.adapter.samsung_tizen.0          : samsung_tizen         : raspi                                    -  enabled, port: 8002
    + system.adapter.sayit.0                  : sayit                 : raspi                                    -  enabled
    + system.adapter.sayit.1                  : sayit                 : raspi                                    -  enabled
    + system.adapter.sayit.2                  : sayit                 : raspi                                    -  enabled
    + system.adapter.sayit.3                  : sayit                 : raspi                                    -  enabled
    + system.adapter.sayit.4                  : sayit                 : raspi                                    -  enabled
    + system.adapter.sayit.5                  : sayit                 : raspi                                    -  enabled
    + system.adapter.shelly.0                 : shelly                : raspi                                    -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : raspi                                    -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.smartcontrol.0           : smartcontrol          : raspi                                    - disabled
    + system.adapter.sonoff.0                 : sonoff                : raspi                                    -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : raspi                                    -  enabled
    + system.adapter.spotify-premium.0        : spotify-premium       : raspi                                    -  enabled
    + system.adapter.sql.0                    : sql                   : raspi                                    -  enabled, port: 0
      system.adapter.statistics.0             : statistics            : raspi                                    -  enabled
    + system.adapter.telegram.0               : telegram              : raspi                                    -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.text2command.0           : text2command          : raspi                                    - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspi                                    -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspi                                    -  enabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspi                                    -  enabled
      system.adapter.vis-history.0            : vis-history           : raspi                                    -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspi                                    -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspi                                    -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspi                                    -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : raspi                                    -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspi                                    -  enabled
      system.adapter.vis-metro.0              : vis-metro             : raspi                                    -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : raspi                                    -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspi                                    -  enabled
      system.adapter.vis.0                    : vis                   : raspi                                    -  enabled
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspi                                    -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspi                                    -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.18__Embed_with_CMSIS-DAP_L1100GB8-if00
    + instance is alive
    ioBroker-Repositories
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 6.8.3    , installed 6.7.2  [Updatable]
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "asterisk"     : 1.0.6    , installed 1.0.6
    Adapter    "backitup"     : 2.7.0    , installed 2.6.23 [Updatable]
    Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "countdown"    : 2.1.0    , installed 2.0.1  [Updatable]
    Adapter    "deconz"       : 1.3.21   , installed 1.3.21
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "digitalstrom" : 2.3.0    , installed 2.3.0
    Adapter    "discovery"    : 3.2.0    , installed 3.2.0
    Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "hue"          : 3.9.6    , installed 3.9.3  [Updatable]
    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "info"         : 1.9.26   , installed 1.9.26
    Adapter    "iqontrol"     : 2.3.0    , installed 2.2.0  [Updatable]
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.11   , installed 5.0.11
    Adapter    "luftdaten"    : 3.0.0    , installed 3.0.0
    Adapter    "moma"         : 1.2.9    , installed 1.2.9
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "mydlink"      : 1.3.2    , installed 1.3.2
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
    Adapter    "nuki"         : 1.6.0    , installed 1.6.0
    Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
    Adapter    "octoprint"    : 5.0.1    , installed 5.0.1
    Adapter    "onvif"        : 1.0.5    , installed 1.0.5
    Adapter    "owntracks"    : 1.0.5    , installed 1.0.5
    Adapter    "paw"          : 0.3.2    , installed 0.3.2
    Adapter    "ph803w"       : 1.1.1    , installed 1.1.1
    Adapter    "pushover"     : 3.0.4    , installed 3.0.4
    Adapter    "samsung"      : 0.5.11   , installed 0.5.11
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "smartcontrol" : 1.3.2    , installed 1.3.2
    Adapter    "socketio"     : 6.5.2    , installed 6.5.2
    Adapter    "sonoff"       : 2.5.7    , installed 2.5.7
    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
    Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
    Adapter    "sql"          : 2.2.0    , installed 2.2.0
    Adapter    "statistics"   : 2.3.0    , installed 2.3.0
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
    Adapter    "vis"          : 1.4.16   , installed 1.4.16
    Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
    Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
    Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
    Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
    Adapter    "web"          : 6.1.0    , installed 6.1.0
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "wiobrowser"   : 2.0.1    , installed 2.0.1
    Adapter    "ws"           : 2.5.3    , installed 2.5.3
    Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
    Objects and States
    Objects:        17066
    States:         12808
    Hit:1 http://phoscon.de/apt/deconz buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 http://archive.raspberrypi.org/debian buster InRelease
    Hit:4 https://deb.nodesource.com/node_12.x buster InRelease
    Hit:5 https://deb.nodesource.com/node_14.x buster InRelease
    Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
    Hit:7 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 8
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:8080          0.0.0.0:*               LISTEN      119        19462      568/motion
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       18473      374/deCONZ
    tcp        0      0 0.0.0.0:8083            0.0.0.0:*               LISTEN      119        18490      568/motion
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20173      709/sshd
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          18483      388/cupsd
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       22385      1418/io.sonoff.0
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       17607      374/deCONZ
    tcp        0      0 192.168.178.53:9092     0.0.0.0:*               LISTEN      1001       28921      2139/io.nuki.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18204      736/iobroker.js-con
    tcp        0      0 0.0.0.0:3306            0.0.0.0:*               LISTEN      110        20247      764/mysqld
    tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      118        17803      717/redis-server 0.
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18345      1042/io.admin.1
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       25805      1789/io.web.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          20175      709/sshd
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       31564      3271/io.simple-api.
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          18482      388/cupsd
    tcp6       0      0 ::1:6379                :::*                    LISTEN      118        17804      717/redis-server 0.
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       24368      1753/io.shelly.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16243      698/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          17398      491/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       24971      1499/io.chromecast.
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16027      382/avahi-daemon: r
    udp        0      0 0.0.0.0:55070           0.0.0.0:*                           108        16029      382/avahi-daemon: r
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       17630      374/deCONZ
    udp6       0      0 :::546                  :::*                                0          16265      698/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        16028      382/avahi-daemon: r
    udp6       0      0 :::49038                :::*                                108        16030      382/avahi-daemon: r
    2023-08-17 14:20:07.253  - info: netatmo-crawler.0 (7697) Getting data for stationid:70:ee:50:29:08:fe
    2023-08-17 14:20:08.850  - info: netatmo-crawler.0 (7697) Getting data for stationid:70:ee:50:3f:34:04
    2023-08-17 14:20:09.919  - info: netatmo-crawler.0 (7697) Getting data for stationid:70:ee:50:52:e9:96
    2023-08-17 14:20:10.497  - info: javascript.0 (1115) script.js.common.Akustischer_Alarm____Steuerung_Haus._Alarmauslösung_Cams: Alarm durch Reolink
    2023-08-17 14:20:10.952  - info: netatmo-crawler.0 (7697) Getting data for stationid:70:ee:50:05:53:68
    2023-08-17 14:20:12.503  - info: netatmo-crawler.0 (7697) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2023-08-17 14:20:13.056  - info: host.raspi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-08-17 14:20:15.074  - info: javascript.0 (1115) script.js.common.Akustischer_Alarm____Steuerung_Haus._Alarmauslösung_Cams: Alarm durch Reolink
    2023-08-17 14:20:33.803  - info: vis.0 (8140) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.17.1, js-controller: 5.0.11
    2023-08-17 14:20:34.515  - info: vis.0 (8140) vis license is OK.
    2023-08-17 14:20:34.919  - info: sayit.0 (8113) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.sayit, node: v18.17.1, js-controller: 5.0.11
    2023-08-17 14:20:34.934  - info: sayit.0 (8113) Install process. Upload files and stop.
    2023-08-17 14:20:34.937  - info: sayit.0 (8113) Upload announce mp3 files
    2023-08-17 14:20:35.236  - info: sayit.0 (8113) stopping...
    2023-08-17 14:20:35.243  - info: sayit.0 (8113) terminating
    2023-08-17 14:20:35.287  - info: sayit.0 (8113) Terminated (NO_ERROR): Without reason
    2023-08-17 14:20:35.745  - info: sayit.0 (8113) terminating
    2023-08-17 14:20:35.831  - info: sayit.0 (8113) stopping...
    2023-08-17 14:20:36.803  - info: vis.0 (8140) Terminated (NO_ERROR): Without reason
    2023-08-17 14:20:41.997  - info: vis-google-fonts.0 (8334) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.vis-google-fonts, node: v18.17.1, js-controller: 5.0.11
    2023-08-17 14:20:42.567  - info: javascript.0 (1115) script.js.common.Akustischer_Alarm____Steuerung_Haus._Alarmauslösung_Cams: Alarm durch Reolink
    2023-08-17 14:20:42.796  - info: vis-google-fonts.0 (8334) Terminated (NO_ERROR): Without reason
    2023-08-17 14:20:46.080  - info: javascript.0 (1115) script.js.common.Akustischer_Alarm____Steuerung_Haus._Alarmauslösung_Cams: Alarm durch Reolink
    2023-08-17 14:20:54.716  - info: javascript.0 (1115) script.js.common.Akustischer_Alarm____Steuerung_Haus._Alarmauslösung_Cams: Alarm durch Reolink
    2023-08-17 14:21:06.846  - info: javascript.0 (1115) script.js.common.Akustischer_Alarm____Steuerung_Haus._Alarmauslösung_Cams: Alarm durch Reolink
    iob diag has finished.
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    @brokeling bitte auch die lange Version in Codetags packen ;)
    Lehrling seit 1975 !!!
      @brokeling sagte in Noch ein Zigbee Problem....:
      Ich habe jetzt auch ein Zigbee Problem, das mit einem Update zusammenhängen könnte.
      Moin,
      vielleicht solltest Du nochmals genauer beschreiben, was Du gemacht hast, also welche Updates und wie!
      Dann einmal auch die Langfassung von
      iob diag
      Dann den Adapter mal im Debug Mode starten.
      Das senetry für den Adapter ausschalten.
      VG
      Bernd
      brokeling
      @dp20eic
      Adapter Neustart mit senetry aus, folgende logs:
      zigbee.0
      2023-08-17 14:25:05.278	info	Installed Version: iobroker.zigbee@1.8.23
      zigbee.0
      2023-08-17 14:25:05.278	error	Error herdsman start
      zigbee.0
      2023-08-17 14:25:05.277	error	Failed to start Zigbee
      zigbee.0
      2023-08-17 14:25:05.276	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.18__Embed_with_CMSIS-DAP_L1100GB8-if00'"
      zigbee.0
      2023-08-17 14:25:05.264	info	Starting Zigbee npm ...
      zigbee.0
      2023-08-17 14:25:05.263	info	Try to reconnect. 1 attempts left
      netatmo-crawler.0
      2023-08-17 14:25:05.038	info	Getting data for stationid:70:ee:50:3f:34:04
      netatmo-crawler.0
      2023-08-17 14:25:04.148	info	Getting data for stationid:70:ee:50:29:08:fe
      netatmo-crawler.0
      2023-08-17 14:25:04.053	info	starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.11
      host.raspi
      2023-08-17 14:25:00.054	info	instance system.adapter.netatmo-crawler.0 started with pid 12682
      zigbee.0
      2023-08-17 14:24:55.262	info	Installed Version: iobroker.zigbee@1.8.23
      zigbee.0
      2023-08-17 14:24:55.261	error	Error herdsman start
      zigbee.0
      2023-08-17 14:24:55.260	error	Failed to start Zigbee
      zigbee.0
      2023-08-17 14:24:55.259	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.18__Embed_with_CMSIS-DAP_L1100GB8-if00'"
      zigbee.0
      2023-08-17 14:24:54.480	info	Starting Zigbee npm ...
      zigbee.0
      2023-08-17 14:24:54.477	info	delete old Backup files. keep only last 10
      zigbee.0
      2023-08-17 14:24:54.334	info	starting. Version 1.8.23 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.17.1, js-controller: 5.0.11
      host.raspi
      2023-08-17 14:24:48.573	info	instance system.adapter.zigbee.0 started with pid 12524
      host.raspi
      2023-08-17 14:24:46.855	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      host.raspi
      2023-08-17 14:24:46.307	info	stopInstance system.adapter.zigbee.0 killing pid 1469
      zigbee.0
      2023-08-17 14:24:46.224	info	debug devices set to []
      zigbee.0
      2023-08-17 14:24:46.159	info	terminating
      zigbee.0
      2023-08-17 14:24:46.158	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      zigbee.0
      2023-08-17 14:24:46.157	info	terminating
      zigbee.0
      2023-08-17 14:24:46.156	warn	Failed to stop zigbee during startup
      zigbee.0
      2023-08-17 14:24:46.127	info	Zigbee: disabling joining new devices.
      zigbee.0
      2023-08-17 14:24:45.313	info	cleaned everything up...
      zigbee.0
      2023-08-17 14:24:45.306	info	Got terminate signal TERMINATE_YOURSELF
      host.raspi
      2023-08-17 14:24:45.304	info	stopInstance system.adapter.zigbee.0 send kill signal
      host.raspi
      2023-08-17 14:24:45.296	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
      ? 1 Antwort Letzte Antwort
      • B brokeling
        @djmarc75
        Summary:
                             v.2023-04-16
        User-ID:                1000
        X-Server:               false
                                /usr/bin/npm            9.6.7
                                /usr/bin/npx            9.6.7
        MEMORY:
        Swap:           99M          0B         99M
                                admin                   6.7.2
        Objects type: jsonl
        States  type: redis
        Objects:                17066
        States:                 12808
        lange Version:
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Docker          : false
        Release:        10
        Codename:       buster
        VERSION_ID="10"
        ID=raspbian
        ID_LIKE=debian
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        temp=64.2'C
        volt=0.8375V
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        /home/pi
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           99M          0B         99M
                 3786 M total memory
                 1568 M used memory
                  363 M active memory
                 1298 M free memory
                  109 M buffer memory
                  809 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        5.8G    /var/
        3.4G    /var/cache
        3.3G    /var/cache/apt
        2.4G    /var/lib
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: redis
        admin:          6.7.2
        javascript:     7.1.4
        Adapter State
        + instance is alive
        Objects and States
        Objects:        17066
        States:         12808
        Pending Updates: 8
        DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        So auf die Schnelle:
        alt
        Da läuft was aus dem Ruder
        volt=0.8375V
        Original Netzteil ?
        Warum ? Da kann es noch Problemchen geben.
        Pending Updates: 8
        mal updaten
        • B brokeling
          @dp20eic
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          netatmo-crawler.0
          netatmo-crawler.0
          netatmo-crawler.0
          host.raspi
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          host.raspi
          host.raspi
          host.raspi
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          host.raspi
          host.raspi
          Moin,
          ist das korrekt, bei Dir,
          was kommt, wenn Du, ein ls auf das Verzeichnis machst?
          ls -la /dev/serial/by-id/
          Bei mir sieht das so aus
          # ls -la /dev/serial/by-id/
          total 0
          lrwxrwxrwx 1 root root  13 Aug 17 10:46 usb-Texas_Instruments_XDS110__03.00.00.12__Embed_with_CMSIS-DAP_L1100FRC-if00 -> ../../ttyACM0
          lrwxrwxrwx 1 root root  13 Aug 17 10:46 usb-Texas_Instruments_XDS110__03.00.00.12__Embed_with_CMSIS-DAP_L1100FRC-if03 -> ../../ttyACM1
          VG
          Bernd
          B 1 Antwort Letzte Antwort
            brokeling
            @djmarc75
            na, ich mach doch immer schön brav die updates
            sudo apt update
            sudo apt dist-upgrade
            warum ist dann nicht die neueste Version drauf?
            Dann Netzteil: Da habt ihr mich wieder. Ich hatte es umgesteckt auf eine USV.
            Ich habe es SOFORT wieder zurück auf das ORIGINAL.
            Und was ist mit dem js-controller: 5.0.11?
            Ist der nicht stable?
            Hab gerade gesehen, der ist ja noch ganz jung...
            Ich führe regelmäßig diese Routine durch:
            iobroker stop
            iobroker update
            iobroker upgrade self
            iobroker upgrade
            iobroker start
            DJMarc75D Thomas BraunT B 3 Antworten Letzte Antwort
              Moin,
              total 0
              VG
              Bernd
              brokeling
              schrieb am zuletzt editiert von brokeling
              @dp20eic
              pi@raspi:~ $ ls -la /dev/serial/by-id/
              insgesamt 0
              drwxr-xr-x 2 root root 80 Aug 17 14:13 .
              drwxr-xr-x 4 root root 80 Aug 17 14:13 ..
              lrwxrwxrwx 1 root root 13 Aug 17 14:13 usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100GB8-if00 -> ../../ttyACM0
              lrwxrwxrwx 1 root root 13 Aug 17 14:13 usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100GB8-if03 -> ../../ttyACM1
              pi@raspi:~ $
              Die Zahlen stimmen nicht überein.
              Muss ich die im Adapter ändern? 18->26?
              • B brokeling
                @djmarc75
                sudo apt update
                iobroker stop
                iobroker update
                iobroker upgrade
                iobroker start
                DJMarc75D Offline
                DJMarc75D Offline
                DJMarc75
                Das führt lediglich dazu dass Du den Host auf Beta upgradest.
                Warum auch immer man den Tester spielen will 🤔
                • B brokeling
                  @djmarc75
                  sudo apt update
                  iobroker stop
                  iobroker update
                  iobroker upgrade
                  iobroker start
                  Weil Ugrades der Distribution nicht so funktionieren.
                  Da muss man anders herangehen. So z. B.
                  https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
                  • B brokeling
                    @dp20eic
                    insgesamt 0
                    pi@raspi:~ $
                    Moin,
                    genau, es sollte schon so da stehen, wie es auch im Dateisystem steht ;)
                    VG
                    Bernd
                      Moin,
                      VG
                      Bernd
                      brokeling
                      @dp20eic
                      zigbee jetzt auf alle Fälle grün 👍
                        brokeling
                        das bullseye update mache ich dann gleich.
                        • B brokeling
                          @djmarc75
                          Summary:
                                               v.2023-04-16
                          User-ID:                1000
                          X-Server:               false
                                                  /usr/bin/npm            9.6.7
                                                  /usr/bin/npx            9.6.7
                          MEMORY:
                          Swap:           99M          0B         99M
                                                  admin                   6.7.2
                          Objects type: jsonl
                          States  type: redis
                          Objects:                17066
                          States:                 12808
                          lange Version:
                          Skript v.2023-04-16
                          *** BASE SYSTEM ***
                          Docker          : false
                          Release:        10
                          Codename:       buster
                          VERSION_ID="10"
                          ID=raspbian
                          ID_LIKE=debian
                          CPU threads: 4
                          Raspberry only:
                          throttled=0x0
                          temp=64.2'C
                          volt=0.8375V
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          /home/pi
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:           99M          0B         99M
                                   3786 M total memory
                                   1568 M used memory
                                    363 M active memory
                                   1298 M free memory
                                    109 M buffer memory
                                    809 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /var:
                          5.8G    /var/
                          3.4G    /var/cache
                          3.3G    /var/cache/apt
                          2.4G    /var/lib
                          /usr/bin/npm            9.6.7
                          /usr/bin/npx            9.6.7
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: redis
                          admin:          6.7.2
                          javascript:     7.1.4
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        17066
                          States:         12808
                          Pending Updates: 8
                          Moin,
                          Moin,
                          laut iob diag bist Du im Beta Universum vom ioBroker unterwegs
                          VG
                          Bernd
                            Moin,
                            Moin,
                            VG
                            Bernd
                            brokeling
                            @dp20eic
                            wie komme ich da wieder raus und nicht wieder hinein?
                            • B brokeling
                              @dp20eic
                              Du meinst den Beta-Bereich?
                              iob repo unset beta
                              iob repo set stable
                              iob update
                                iob repo unset beta
                                iob repo set stable
                                iob update
                                brokeling
                                ok danke.
                                Aber jetzt komme ich am update zum bullseye.
                                Alles gemacht, aber ich komme jetzt in die admin Oberfläche nicht rein.
                                auch
                                iobroker start admin
                                bringt nichts
                                • B brokeling
                                  ok danke.
                                  auch
                                  bringt nichts
                                  @brokeling
                                  Wir bist du da jetzt genau unterwegs?
                                  iob diag
                                  anschauen.
                                    @brokeling
                                    iob diag
                                    anschauen.
                                    brokeling
                                    Skript v.2023-04-16
                                    *** BASE SYSTEM ***
                                    Docker          : false
                                    Description:    Raspbian GNU/Linux 11 (bullseye)
                                    Release:        11
                                    Codename:       bullseye
                                    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
                                    VERSION_ID="11"
                                    VERSION="11 (bullseye)"
                                    VERSION_CODENAME=bullseye
                                    ID=raspbian
                                    ID_LIKE=debian
                                     16:42:38 up 3 min,  1 user,  load average: 7.83, 3.25, 1.25
                                    CPU threads: 4
                                    Raspberry only:
                                    throttled=0x0
                                    temp=68.6'C
                                    volt=0.8375V
                                                   Local time: Thu 2023-08-17 16:42:39 CEST
                                               Universal time: Thu 2023-08-17 14:42:39 UTC
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    pi
                                    /home/pi
                                    X-Server:       false
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Mem:            3.8G        1.9G        1.1G        0.0K        778M        1.8G
                                    Swap:            99M          0B         99M
                                    Total:          3.9G        1.9G        1.2G
                                             3786 M total memory
                                             1875 M used memory
                                              240 M active memory
                                             2294 M inactive memory
                                             1132 M free memory
                                               73 M buffer memory
                                              704 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FILESYSTEM ***
                                    /dev/root      ext4      117G   18G   94G  16% /
                                    tmpfs          tmpfs     758M  864K  757M   1% /run
                                    tmpfs          tmpfs     379M   16K  379M   1% /run/user/1000
                                    [Thu Aug 17 16:38:50 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:40:0F:7D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                    [Thu Aug 17 16:38:52 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                                    [Thu Aug 17 16:38:52 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                    [Thu Aug 17 16:38:54 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
                                    [Thu Aug 17 16:38:56 2023] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)
                                    `-/boot   /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                                    /var:
                                    5.9G    /var/
                                    3.4G    /var/cache/apt
                                    3.4G    /var/cache
                                    2.4G    /var/lib
                                    Archived and active journals take up 40.0M in the file system.
                                    31M     /opt/iobroker/iobroker-data/objects.jsonl
                                    /usr/bin/npm            9.6.7
                                    /usr/bin/npx            9.6.7
                                    nodejs:
                                      Version table:
                                            500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
                                            500 https://deb.nodesource.com/node_12.x bullseye/main armhf Packages
                                         12.22.12~dfsg-1~deb11u4 500
                                            500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: redis
                                    admin:          6.7.2
                                    javascript:     7.1.4
                                    Adapter State
                                    + system.adapter.zigbee.0                 : zigbee                : raspi                                    -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100GB8-if00
                                    + instance is alive
                                    Adapter    "admin"        : 6.8.2    , installed 6.7.2  [Updatable]
                                    Objects and States
                                    Objects:        17061
                                    States:         12802
                                    Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
                                    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                                    Hit:4 https://deb.nodesource.com/node_12.x bullseye InRelease
                                    Hit:5 https://deb.nodesource.com/node_14.x bullseye InRelease
                                    Pending Updates: 0
                                    tcp        0      0 127.0.0.1:8080          0.0.0.0:*               LISTEN      119        15505      393/motion
                                    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       13397      376/deCONZ
                                    tcp        0      0 127.0.0.1:8081          0.0.0.0:*               LISTEN      119        15504      393/motion
                                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15448      544/sshd: /usr/sbin
                                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15509      529/cupsd
                                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       20690      2004/io.sonoff.0
                                    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       15588      376/deCONZ
                                    tcp        0      0 192.168.178.53:9092     0.0.0.0:*               LISTEN      1001       23103      2718/io.nuki.0
                                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13587      602/iobroker.js-con
                                    tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      110        13451      618/mariadbd
                                    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      118        14601      532/redis-server 12
                                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21194      2452/io.web.0
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          15450      544/sshd: /usr/sbin
                                    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       31661      3739/io.simple-api.
                                    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15508      529/cupsd
                                    tcp6       0      0 ::1:6379                :::*                    LISTEN      118        14602      532/redis-server 12
                                    udp        0      0 0.0.0.0:51718           0.0.0.0:*                           108        13333      369/avahi-daemon: r
                                    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       21832      2408/io.shelly.0
                                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14733      988/dhcpcd
                                    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          10205      642/cups-browsed
                                    udp        0      0 0.0.0.0:55934           0.0.0.0:*                           1001       48081      2408/io.shelly.0
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       18145      2194/io.chromecast.
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13331      369/avahi-daemon: r
                                    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       14732      376/deCONZ
                                    udp6       0      0 :::546                  :::*                                0          14885      988/dhcpcd
                                    udp6       0      0 :::60506                :::*                                108        13334      369/avahi-daemon: r
                                    udp6       0      0 :::5353                 :::*                                108        13332      369/avahi-daemon: r
                                    2023-08-17 16:42:28.713  - info: onvif.0 (3793) Found Adapter Device: onvif.0.192_168_178_119_8000 Manufacturer IPC_523128M5MP 192.168.178.119:8000
                                    2023-08-17 16:42:31.896  - error: onvif.0 (3793) Data: null XML: undefined
                                    2023-08-17 16:42:31.896  - error: onvif.0 (3793) Error initializing device: Error: connect EHOSTUNREACH 192.168.178.119:8000 device: {"id":"192_168_178_119_8000","name":"Manufacturer IPC_523128M5MP 192.168.178.119:8000","ip":"192.168.178.119","port":"8000","hostname":"192.168.178.119","user":"admin","password":"fCmqvxM4ZCJMY7Tpv51SSlsso","snapshotUrl":"http://192.168.178.119:80/cgi-bin/api.cgi?cmd=onvifSnapPic&channel=0","majorStreamUrl":"rtsp://admin:fCmqvxM4ZCJMY7Tpv51SSlsso@192.168.178.119:554/","minorStreamUrl":"rtsp://admin:fCmqvxM4ZCJMY7Tpv51SSlsso@192.168.178.119:554/h264Preview_01_sub"}
                                    2023-08-17 16:42:31.897  - error: onvif.0 (3793) You can change user and password under object and edit device or delete device under objects and restart adapter
                                    2023-08-17 16:42:31.897  - error: onvif.0 (3793) Error: connect EHOSTUNREACH 192.168.178.119:8000
                                        at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1495:16)
                                    2023-08-17 16:42:31.898  - info: onvif.0 (3793) Found Adapter Device: onvif.0.192_168_178_127_8000 ManufacturerE1 Outdoor 192.168.178.127:8000
                                    2023-08-17 16:42:33.300  - info: onvif.0 (3793) Device successful initialized: 192.168.178.127:8000
                                    2023-08-17 16:42:34.075  - info: sourceanalytix.0 (3641) Initialization of 0_userdata.0.Holger2.Energie_Haus.SolarErzeugung successfully
                                    2023-08-17 16:42:34.076  - info: sourceanalytix.0 (3641) Initialising (7 of 7) "0_userdata.0.Holger2.Energie_Haus.Strombezug_STAWA"
                                    2023-08-17 16:42:37.306  - info: onvif.0 (3793) Start onvif discovery
                                    2023-08-17 16:42:37.331  - warn: onvif.0 (3793) Used invalid characters: onvif.0.192_168_178_127_8000.infos.presets.Geländer changed to onvif.0.192_168_178_127_8000.infos.presets.GelÃ_nder
                                    2023-08-17 16:42:37.382  - info: onvif.0 (3793) Discovery Reply from 192.168.178.127 (name,IPC) (E1Outdoor) (http://192.168.178.127:8000/onvif/device_service) (urn:uuid:2419d68a-2dd2-21b2-a205-c4:3c:b0:9c:12:34)
                                    2023-08-17 16:42:37.383  - info: onvif.0 (3793) Skip device 192.168.178.127 because it is already configured via iobroker object. Delete the device under objects for reconfigure.
                                    2023-08-17 16:42:37.457  - info: onvif.0 (3793) Discovery Reply from 192.168.178.128 (name,IPC) (E1Outdoor) (http://192.168.178.128:8000/onvif/device_service) (urn:uuid:2419d68a-2dd2-21b2-a205-68:39:43:f8:6c:69)
                                    2023-08-17 16:42:37.457  - info: onvif.0 (3793) Skip device 192.168.178.128 because it is already configured via iobroker object. Delete the device under objects for reconfigure.
                                    2023-08-17 16:42:37.475  - info: onvif.0 (3793) Discovery Reply from 192.168.178.132 (name,IPC) (E1Outdoor) (http://192.168.178.132:8000/onvif/device_service) (urn:uuid:2419d68a-2dd2-21b2-a205-5c:c3:36:2e:0e:73)
                                    2023-08-17 16:42:37.476  - info: onvif.0 (3793) Skip device 192.168.178.132 because it is already configured via iobroker object. Delete the device under objects for reconfigure.
                                    2023-08-17 16:42:37.535  - warn: onvif.0 (3793) State "onvif.0.192_168_178_127_8000.infos.presets.Geländer" has no existing object, this might lead to an error in future versions
                                    2023-08-17 16:42:42.316  - info: onvif.0 (3793) Finished onvif discovery
                                    2023-08-17 16:42:51.240  - info: sourceanalytix.0 (3641) Initialization of 0_userdata.0.Holger2.Energie_Haus.Strombezug_STAWA successfully
                                    2023-08-17 16:42:51.283  - warn: sourceanalytix.0 (3641) Cannot handle calculations for 1 of 7 enabled states, check error messages
                                    2023-08-17 16:42:51.303  - info: sourceanalytix.0 (3641) Successfully activated SourceAnalytix for 6 of 7 states, will do my Job until you stop me!
                                    2023-08-17 16:44:03.228  - info: javascript.0 (910) script.js.common.Akustischer_Alarm____Steuerung_Haus._Alarmauslösung_Cams: Alarm durch Reolink
                                    2023-08-17 16:44:25.874  - info: javascript.0 (910) script.js.common.Akustischer_Alarm____Steuerung_Haus._Alarmauslösung_Cams: Alarm durch Reolink
                                    • B brokeling
                                      Skript v.2023-04-16
                                      *** BASE SYSTEM ***
                                      Docker          : false
                                      Release:        11
                                      Codename:       bullseye
                                      VERSION_ID="11"
                                      ID=raspbian
                                      ID_LIKE=debian
                                      CPU threads: 4
                                      Raspberry only:
                                      throttled=0x0
                                      temp=68.6'C
                                      volt=0.8375V
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      pi
                                      /home/pi
                                      X-Server:       false
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Swap:            99M          0B         99M
                                               3786 M total memory
                                               1875 M used memory
                                                240 M active memory
                                               1132 M free memory
                                                 73 M buffer memory
                                                704 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      Raspberry only:
                                      oom events: 0
                                      *** FILESYSTEM ***
                                      /var:
                                      5.9G    /var/
                                      3.4G    /var/cache/apt
                                      3.4G    /var/cache
                                      2.4G    /var/lib
                                      /usr/bin/npm            9.6.7
                                      /usr/bin/npx            9.6.7
                                      nodejs:
                                        Version table:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: redis
                                      admin:          6.7.2
                                      javascript:     7.1.4
                                      Adapter State
                                      + instance is alive
                                      Objects and States
                                      Objects:        17061
                                      States:         12802
                                      Pending Updates: 0
                                      DJMarc75D Offline
                                      DJMarc75D Offline
                                      DJMarc75
                                      js-controller: js-controller: 5.0.11
                                      admin: 6.7.2
                                      javascript: 7.1.4
                                      jetzt sogar überall Betauser
                                      Hammer... über 7 sieht man selten
                                      temp=68.6'C
                                      grenzwertig
                                      volt=0.8375V
                                      hm...
                                      Objects type: jsonl
                                      States  type: redis
                                      • B brokeling
                                        ok danke.
                                        auch
                                        bringt nichts
                                        @brokeling
                                        Warum hast du den Beta-Kram nicht ausgeschaltet?
                                        iob start admin.1
                                        sagt was im LogFile?
                                        • DJMarc75D DJMarc75
                                          admin: 6.7.2
                                          javascript: 7.1.4
                                          temp=68.6'C
                                          grenzwertig
                                          volt=0.8375V
                                          hm...
                                          Objects type: jsonl
                                          States  type: redis
                                          @djmarc75 sagte in Noch ein Zigbee Problem....:
                                          Systemstart und dann Motion mit mehreren Kameras aktiv kann schonmal für so eine Auslastung sorgen.
