  4. Noch ein Zigbee Problem....
    5.2k
137 Beiträge 7 Kommentatoren 24.7k Aufrufe 5 Beobachtet
  • DJMarc75D DJMarc75
    @brokeling
    iob stop
    iob fix
    sudo reboot
    iob diag
    brokeling
    schrieb am zuletzt editiert von brokeling
    @djmarc75
    Summary:
                         v.2023-04-16
    Operatingsystem:        Raspbian GNU/Linux 10 (buster)
    Kernel:                 5.10.103-v7l+
    Installation:           Native
    User-ID:                1000
    X-Server:               false
    Boot Target:            multi-user.target
    Pending OS-Updates:     8
    Pending iob updates:    5
    Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                            /usr/bin/node           v18.17.1
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:           3.8G        1.6G        1.2G        8.0M        921M        2.0G
    Swap:           99M          0B         99M
    Total:         3.9G        1.6G        1.3G
    Active iob-Instances:   33
    Active repo(s): beta
    ioBroker Core:          js-controller           5.0.11
                            admin                   6.7.2
    Objects type: jsonl
    States  type: redis
    + system.adapter.admin.1                  : admin                 : raspi                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.web.0                    : web                   : raspi                                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects:                17066
    States:                 12808
    Size of iob-Database:
    22M     /opt/iobroker/iobroker-data/objects.jsonl
    8.4M    /opt/iobroker/iobroker-data/objects.json.migrated
    8.4M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    12K     /opt/iobroker/iobroker-data/objects.json.old
    41M     /opt/iobroker/iobroker-data/states.json.old
    41M     /opt/iobroker/iobroker-data/states.json.bak
    0       /opt/iobroker/iobroker-data/states.json
    lange Version:
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Architecture    : armv7l
    Docker          : false
    Virtualization  : none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 10 (buster)
    Release:        10
    Codename:       buster
    PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="10"
    VERSION="10 (buster)"
    VERSION_CODENAME=buster
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     14:19:25 up 5 min,  1 user,  load average: 4.56, 4.04, 1.85
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=64.2'C
    volt=0.8375V
    *** Time and Time Zones ***
                   Local time: Thu 2023-08-17 14:19:25 CEST
               Universal time: Thu 2023-08-17 12:19:25 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           3.8G        1.6G        1.3G        8.0M        918M        2.1G
    Swap:           99M          0B         99M
    Total:         3.9G        1.6G        1.4G
             3786 M total memory
             1568 M used memory
              363 M active memory
             1974 M inactive memory
             1298 M free memory
              109 M buffer memory
              809 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4      117G   17G   94G  16% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     1.9G  8.6M  1.9G   1% /run
    tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
    /dev/sdb1      ext4      113G   71G   37G  66% /backup
    /dev/sda1      vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     379M     0  379M   0% /run/user/1000
    [Thu Aug 17 14:13:40 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:40:0F:7D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Thu Aug 17 14:13:42 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    [Thu Aug 17 14:13:42 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Thu Aug 17 14:13:43 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
    [Thu Aug 17 14:13:46 2023] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)
    TARGET        SOURCE    FSTYPE OPTIONS
    /             /dev/sda2 ext4   rw,noatime,stripe=8191
    |-/sys/fs/bpf none      bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    |-/backup     /dev/sdb1 ext4   rw,noatime
    `-/boot       /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    5.8G    /var/
    3.4G    /var/cache
    3.3G    /var/cache/apt/archives
    3.3G    /var/cache/apt
    2.4G    /var/lib
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    2.9G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.1G    /opt/iobroker/iobroker-data/
    541M    /opt/iobroker/iobroker-data/backup-objects
    383M    /opt/iobroker/iobroker-data/files
    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js.map
    *** NodeJS-Installation ***
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
         16.20.2-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
         14.21.3-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
         12.22.12-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: redis
    Core adapters versions
    js-controller:  5.0.11
    admin:          6.7.2
    javascript:     7.1.4
    Adapters from github:   3
    Adapter State
      system.adapter.alias-manager.0          : alias-manager         : raspi                                    -  enabled
    + system.adapter.backitup.0               : backitup              : raspi                                    -  enabled
    + system.adapter.chromecast.0             : chromecast            : raspi                                    -  enabled
    + system.adapter.cloud.0                  : cloud                 : raspi                                    -  enabled
      system.adapter.deconz.0                 : deconz                : raspi                                    - disabled, port: 80
      system.adapter.devices.0                : devices               : raspi                                    -  enabled
    + system.adapter.discovery.0              : discovery             : raspi                                    -  enabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspi                                    - disabled
      system.adapter.feiertage.0              : feiertage             : raspi                                    -  enabled
      system.adapter.flot.0                   : flot                  : raspi                                    -  enabled
      system.adapter.fritzdect.0              : fritzdect             : raspi                                    - disabled
      system.adapter.hue-extended.0           : hue-extended          : raspi                                    - disabled
      system.adapter.hue.0                    : hue                   : raspi                                    - disabled, port: 443
      system.adapter.ical.0                   : ical                  : raspi                                    -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : raspi                                    -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspi                                    -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspi                                    -  enabled
      system.adapter.iqontrol.0               : iqontrol              : raspi                                    - disabled
    + system.adapter.javascript.0             : javascript            : raspi                                    -  enabled
      system.adapter.luftdaten.0              : luftdaten             : raspi                                    -  enabled
      system.adapter.luftdaten.1              : luftdaten             : raspi                                    -  enabled
      system.adapter.mqtt.0                   : mqtt                  : raspi                                    - disabled, port: 1884, bind: 0.0.0.0
    + system.adapter.net-tools.0              : net-tools             : raspi                                    -  enabled
    + system.adapter.netatmo-crawler.0        : netatmo-crawler       : raspi                                    -  enabled
    + system.adapter.nuki.0                   : nuki                  : raspi                                    -  enabled
    + system.adapter.onvif.0                  : onvif                 : raspi                                    -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
    + system.adapter.ping.0                   : ping                  : raspi                                    -  enabled
    + system.adapter.pushover.0               : pushover              : raspi                                    -  enabled
    + system.adapter.reolink.0                : reolink               : raspi                                    -  enabled
    + system.adapter.reolink.1                : reolink               : raspi                                    -  enabled
    + system.adapter.reolink.2                : reolink               : raspi                                    -  enabled
    + system.adapter.reolink.3                : reolink               : raspi                                    -  enabled
    + system.adapter.reolink.4                : reolink               : raspi                                    -  enabled
      system.adapter.samsung_tizen.0          : samsung_tizen         : raspi                                    -  enabled, port: 8002
    + system.adapter.sayit.0                  : sayit                 : raspi                                    -  enabled
    + system.adapter.sayit.1                  : sayit                 : raspi                                    -  enabled
    + system.adapter.sayit.2                  : sayit                 : raspi                                    -  enabled
    + system.adapter.sayit.3                  : sayit                 : raspi                                    -  enabled
    + system.adapter.sayit.4                  : sayit                 : raspi                                    -  enabled
    + system.adapter.sayit.5                  : sayit                 : raspi                                    -  enabled
    + system.adapter.shelly.0                 : shelly                : raspi                                    -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : raspi                                    -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.smartcontrol.0           : smartcontrol          : raspi                                    - disabled
    + system.adapter.sonoff.0                 : sonoff                : raspi                                    -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : raspi                                    -  enabled
    + system.adapter.spotify-premium.0        : spotify-premium       : raspi                                    -  enabled
    + system.adapter.sql.0                    : sql                   : raspi                                    -  enabled, port: 0
      system.adapter.statistics.0             : statistics            : raspi                                    -  enabled
    + system.adapter.telegram.0               : telegram              : raspi                                    -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.text2command.0           : text2command          : raspi                                    - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspi                                    -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspi                                    -  enabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspi                                    -  enabled
      system.adapter.vis-history.0            : vis-history           : raspi                                    -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspi                                    -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspi                                    -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspi                                    -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : raspi                                    -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspi                                    -  enabled
      system.adapter.vis-metro.0              : vis-metro             : raspi                                    -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : raspi                                    -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspi                                    -  enabled
      system.adapter.vis.0                    : vis                   : raspi                                    -  enabled
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspi                                    -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspi                                    -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.18__Embed_with_CMSIS-DAP_L1100GB8-if00
    + instance is alive
    ioBroker-Repositories
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 6.8.3    , installed 6.7.2  [Updatable]
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "asterisk"     : 1.0.6    , installed 1.0.6
    Adapter    "backitup"     : 2.7.0    , installed 2.6.23 [Updatable]
    Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "countdown"    : 2.1.0    , installed 2.0.1  [Updatable]
    Adapter    "deconz"       : 1.3.21   , installed 1.3.21
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "digitalstrom" : 2.3.0    , installed 2.3.0
    Adapter    "discovery"    : 3.2.0    , installed 3.2.0
    Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "hue"          : 3.9.6    , installed 3.9.3  [Updatable]
    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "iqontrol"     : 2.3.0    , installed 2.2.0  [Updatable]
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.11   , installed 5.0.11
    Adapter    "luftdaten"    : 3.0.0    , installed 3.0.0
    Adapter    "moma"         : 1.2.9    , installed 1.2.9
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "mydlink"      : 1.3.2    , installed 1.3.2
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
    Adapter    "nuki"         : 1.6.0    , installed 1.6.0
    Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
    Adapter    "octoprint"    : 5.0.1    , installed 5.0.1
    Adapter    "onvif"        : 1.0.5    , installed 1.0.5
    Adapter    "owntracks"    : 1.0.5    , installed 1.0.5
    Adapter    "paw"          : 0.3.2    , installed 0.3.2
    Adapter    "ph803w"       : 1.1.1    , installed 1.1.1
    Adapter    "pushover"     : 3.0.4    , installed 3.0.4
    Adapter    "samsung"      : 0.5.11   , installed 0.5.11
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "smartcontrol" : 1.3.2    , installed 1.3.2
    Adapter    "socketio"     : 6.5.2    , installed 6.5.2
    Adapter    "sonoff"       : 2.5.7    , installed 2.5.7
    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
    Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
    Adapter    "statistics"   : 2.3.0    , installed 2.3.0
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "web"          : 6.1.0    , installed 6.1.0
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "wiobrowser"   : 2.0.1    , installed 2.0.1
    Adapter    "ws"           : 2.5.3    , installed 2.5.3
    Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
    Objects and States
    Objects:        17066
    States:         12808
    Hit:1 http://phoscon.de/apt/deconz buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 http://archive.raspberrypi.org/debian buster InRelease
    Hit:4 https://deb.nodesource.com/node_12.x buster InRelease
    Hit:5 https://deb.nodesource.com/node_14.x buster InRelease
    Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
    Hit:7 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 8
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:8080          0.0.0.0:*               LISTEN      119        19462      568/motion
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       18473      374/deCONZ
    tcp        0      0 0.0.0.0:8083            0.0.0.0:*               LISTEN      119        18490      568/motion
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20173      709/sshd
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          18483      388/cupsd
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       22385      1418/io.sonoff.0
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       17607      374/deCONZ
    tcp        0      0 192.168.178.53:9092     0.0.0.0:*               LISTEN      1001       28921      2139/io.nuki.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18204      736/iobroker.js-con
    tcp        0      0 0.0.0.0:3306            0.0.0.0:*               LISTEN      110        20247      764/mysqld
    tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      118        17803      717/redis-server 0.
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18345      1042/io.admin.1
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       25805      1789/io.web.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          20175      709/sshd
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       31564      3271/io.simple-api.
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          18482      388/cupsd
    tcp6       0      0 ::1:6379                :::*                    LISTEN      118        17804      717/redis-server 0.
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       24368      1753/io.shelly.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16243      698/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          17398      491/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       24971      1499/io.chromecast.
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16027      382/avahi-daemon: r
    udp        0      0 0.0.0.0:55070           0.0.0.0:*                           108        16029      382/avahi-daemon: r
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       17630      374/deCONZ
    udp6       0      0 :::546                  :::*                                0          16265      698/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        16028      382/avahi-daemon: r
    udp6       0      0 :::49038                :::*                                108        16030      382/avahi-daemon: r
    2023-08-17 14:20:07.253  - info: netatmo-crawler.0 (7697) Getting data for stationid:70:ee:50:29:08:fe
    2023-08-17 14:20:08.850  - info: netatmo-crawler.0 (7697) Getting data for stationid:70:ee:50:3f:34:04
    2023-08-17 14:20:09.919  - info: netatmo-crawler.0 (7697) Getting data for stationid:70:ee:50:52:e9:96
    2023-08-17 14:20:10.497  - info: javascript.0 (1115) script.js.common.Akustischer_Alarm____Steuerung_Haus._Alarmauslösung_Cams: Alarm durch Reolink
    2023-08-17 14:20:10.952  - info: netatmo-crawler.0 (7697) Getting data for stationid:70:ee:50:05:53:68
    2023-08-17 14:20:12.503  - info: netatmo-crawler.0 (7697) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2023-08-17 14:20:13.056  - info: host.raspi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-08-17 14:20:15.074  - info: javascript.0 (1115) script.js.common.Akustischer_Alarm____Steuerung_Haus._Alarmauslösung_Cams: Alarm durch Reolink
    2023-08-17 14:20:33.803  - info: vis.0 (8140) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.17.1, js-controller: 5.0.11
    2023-08-17 14:20:34.515  - info: vis.0 (8140) vis license is OK.
    2023-08-17 14:20:34.919  - info: sayit.0 (8113) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.sayit, node: v18.17.1, js-controller: 5.0.11
    2023-08-17 14:20:34.934  - info: sayit.0 (8113) Install process. Upload files and stop.
    2023-08-17 14:20:34.937  - info: sayit.0 (8113) Upload announce mp3 files
    2023-08-17 14:20:35.236  - info: sayit.0 (8113) stopping...
    2023-08-17 14:20:35.243  - info: sayit.0 (8113) terminating
    2023-08-17 14:20:35.287  - info: sayit.0 (8113) Terminated (NO_ERROR): Without reason
    2023-08-17 14:20:35.745  - info: sayit.0 (8113) terminating
    2023-08-17 14:20:35.831  - info: sayit.0 (8113) stopping...
    2023-08-17 14:20:36.803  - info: vis.0 (8140) Terminated (NO_ERROR): Without reason
    2023-08-17 14:20:41.997  - info: vis-google-fonts.0 (8334) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.vis-google-fonts, node: v18.17.1, js-controller: 5.0.11
    2023-08-17 14:20:42.567  - info: javascript.0 (1115) script.js.common.Akustischer_Alarm____Steuerung_Haus._Alarmauslösung_Cams: Alarm durch Reolink
    2023-08-17 14:20:42.796  - info: vis-google-fonts.0 (8334) Terminated (NO_ERROR): Without reason
    2023-08-17 14:20:46.080  - info: javascript.0 (1115) script.js.common.Akustischer_Alarm____Steuerung_Haus._Alarmauslösung_Cams: Alarm durch Reolink
    2023-08-17 14:20:54.716  - info: javascript.0 (1115) script.js.common.Akustischer_Alarm____Steuerung_Haus._Alarmauslösung_Cams: Alarm durch Reolink
    2023-08-17 14:21:06.846  - info: javascript.0 (1115) script.js.common.Akustischer_Alarm____Steuerung_Haus._Alarmauslösung_Cams: Alarm durch Reolink
    iob diag has finished.
    DJMarc75D ? crunchipC 4 Antworten Letzte Antwort
    • B brokeling
      @djmarc75
      Summary:
                           v.2023-04-16
      User-ID:                1000
      X-Server:               false
                              /usr/bin/npm            9.6.7
                              /usr/bin/npx            9.6.7
      MEMORY:
      Swap:           99M          0B         99M
                              admin                   6.7.2
      Objects type: jsonl
      States  type: redis
      Objects:                17066
      States:                 12808
      lange Version:
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        10
      Codename:       buster
      VERSION_ID="10"
      ID=raspbian
      ID_LIKE=debian
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      temp=64.2'C
      volt=0.8375V
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           99M          0B         99M
               3786 M total memory
               1568 M used memory
                363 M active memory
               1298 M free memory
                109 M buffer memory
                809 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      5.8G    /var/
      3.4G    /var/cache
      3.3G    /var/cache/apt
      2.4G    /var/lib
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: redis
      admin:          6.7.2
      javascript:     7.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        17066
      States:         12808
      Pending Updates: 8
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @brokeling bitte auch die lange Version in Codetags packen ;)
      Lehrling seit 1975 !!!
        @brokeling sagte in Noch ein Zigbee Problem....:
        Ich habe jetzt auch ein Zigbee Problem, das mit einem Update zusammenhängen könnte.
        Moin,
        vielleicht solltest Du nochmals genauer beschreiben, was Du gemacht hast, also welche Updates und wie!
        Dann einmal auch die Langfassung von
        iob diag
        Dann den Adapter mal im Debug Mode starten.
        Das senetry für den Adapter ausschalten.
        Bernd
        brokeling
        @dp20eic
        Adapter Neustart mit senetry aus, folgende logs:
        zigbee.0
        2023-08-17 14:25:05.278	info	Installed Version: iobroker.zigbee@1.8.23
        zigbee.0
        2023-08-17 14:25:05.278	error	Error herdsman start
        zigbee.0
        2023-08-17 14:25:05.277	error	Failed to start Zigbee
        zigbee.0
        2023-08-17 14:25:05.276	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.18__Embed_with_CMSIS-DAP_L1100GB8-if00'"
        zigbee.0
        2023-08-17 14:25:05.264	info	Starting Zigbee npm ...
        zigbee.0
        2023-08-17 14:25:05.263	info	Try to reconnect. 1 attempts left
        netatmo-crawler.0
        2023-08-17 14:25:05.038	info	Getting data for stationid:70:ee:50:3f:34:04
        netatmo-crawler.0
        2023-08-17 14:25:04.148	info	Getting data for stationid:70:ee:50:29:08:fe
        netatmo-crawler.0
        2023-08-17 14:25:04.053	info	starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.11
        host.raspi
        2023-08-17 14:25:00.054	info	instance system.adapter.netatmo-crawler.0 started with pid 12682
        zigbee.0
        2023-08-17 14:24:55.262	info	Installed Version: iobroker.zigbee@1.8.23
        zigbee.0
        2023-08-17 14:24:55.261	error	Error herdsman start
        zigbee.0
        2023-08-17 14:24:55.260	error	Failed to start Zigbee
        zigbee.0
        2023-08-17 14:24:55.259	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.18__Embed_with_CMSIS-DAP_L1100GB8-if00'"
        zigbee.0
        2023-08-17 14:24:54.480	info	Starting Zigbee npm ...
        zigbee.0
        2023-08-17 14:24:54.477	info	delete old Backup files. keep only last 10
        zigbee.0
        2023-08-17 14:24:54.334	info	starting. Version 1.8.23 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.17.1, js-controller: 5.0.11
        host.raspi
        2023-08-17 14:24:48.573	info	instance system.adapter.zigbee.0 started with pid 12524
        host.raspi
        2023-08-17 14:24:46.855	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        host.raspi
        2023-08-17 14:24:46.307	info	stopInstance system.adapter.zigbee.0 killing pid 1469
        zigbee.0
        2023-08-17 14:24:46.224	info	debug devices set to []
        zigbee.0
        2023-08-17 14:24:46.159	info	terminating
        zigbee.0
        2023-08-17 14:24:46.158	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        zigbee.0
        2023-08-17 14:24:46.157	info	terminating
        zigbee.0
        2023-08-17 14:24:46.156	warn	Failed to stop zigbee during startup
        zigbee.0
        2023-08-17 14:24:46.127	info	Zigbee: disabling joining new devices.
        zigbee.0
        2023-08-17 14:24:45.313	info	cleaned everything up...
        zigbee.0
        2023-08-17 14:24:45.306	info	Got terminate signal TERMINATE_YOURSELF
        host.raspi
        2023-08-17 14:24:45.304	info	stopInstance system.adapter.zigbee.0 send kill signal
        host.raspi
        2023-08-17 14:24:45.296	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
        • B brokeling
          @djmarc75
          Summary:
                               v.2023-04-16
          User-ID:                1000
          X-Server:               false
                                  /usr/bin/npm            9.6.7
                                  /usr/bin/npx            9.6.7
          MEMORY:
          Swap:           99M          0B         99M
                                  admin                   6.7.2
          Objects type: jsonl
          States  type: redis
          Objects:                17066
          States:                 12808
          lange Version:
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Docker          : false
          Release:        10
          Codename:       buster
          VERSION_ID="10"
          ID=raspbian
          ID_LIKE=debian
          CPU threads: 4
          Raspberry only:
          throttled=0x0
          temp=64.2'C
          volt=0.8375V
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:           99M          0B         99M
                   3786 M total memory
                   1568 M used memory
                    363 M active memory
                   1298 M free memory
                    109 M buffer memory
                    809 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /var:
          5.8G    /var/
          3.4G    /var/cache
          3.3G    /var/cache/apt
          2.4G    /var/lib
          /usr/bin/npm            9.6.7
          /usr/bin/npx            9.6.7
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: redis
          admin:          6.7.2
          javascript:     7.1.4
          Adapter State
          + instance is alive
          Objects and States
          Objects:        17066
          States:         12808
          Pending Updates: 8
          DJMarc75D Offline
          DJMarc75D Offline
          DJMarc75
          So auf die Schnelle:
          alt
          Da läuft was aus dem Ruder
          volt=0.8375V
          Original Netzteil ?
          Warum ? Da kann es noch Problemchen geben.
          Pending Updates: 8
          mal updaten
          • B brokeling
            @dp20eic
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            netatmo-crawler.0
            netatmo-crawler.0
            netatmo-crawler.0
            host.raspi
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            host.raspi
            host.raspi
            host.raspi
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            host.raspi
            host.raspi
            Moin,
            ist das korrekt, bei Dir,
            was kommt, wenn Du, ein ls auf das Verzeichnis machst?
            ls -la /dev/serial/by-id/
            Bei mir sieht das so aus
            # ls -la /dev/serial/by-id/
            total 0
            lrwxrwxrwx 1 root root  13 Aug 17 10:46 usb-Texas_Instruments_XDS110__03.00.00.12__Embed_with_CMSIS-DAP_L1100FRC-if00 -> ../../ttyACM0
            lrwxrwxrwx 1 root root  13 Aug 17 10:46 usb-Texas_Instruments_XDS110__03.00.00.12__Embed_with_CMSIS-DAP_L1100FRC-if03 -> ../../ttyACM1
            Bernd
              brokeling
              @djmarc75
              na, ich mach doch immer schön brav die updates
              sudo apt update
              sudo apt dist-upgrade
              warum ist dann nicht die neueste Version drauf?
              Dann Netzteil: Da habt ihr mich wieder. Ich hatte es umgesteckt auf eine USV.
              Ich habe es SOFORT wieder zurück auf das ORIGINAL.
              Und was ist mit dem js-controller: 5.0.11?
              Ist der nicht stable?
              Hab gerade gesehen, der ist ja noch ganz jung...
              Ich führe regelmäßig diese Routine durch:
              iobroker stop
              iobroker update
              iobroker upgrade self
              iobroker upgrade
              iobroker start
              DJMarc75D Thomas BraunT B 3 Antworten Letzte Antwort
                Moin,
                total 0
                Bernd
                brokeling
                @dp20eic
                pi@raspi:~ $ ls -la /dev/serial/by-id/
                insgesamt 0
                drwxr-xr-x 2 root root 80 Aug 17 14:13 .
                drwxr-xr-x 4 root root 80 Aug 17 14:13 ..
                lrwxrwxrwx 1 root root 13 Aug 17 14:13 usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100GB8-if00 -> ../../ttyACM0
                lrwxrwxrwx 1 root root 13 Aug 17 14:13 usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100GB8-if03 -> ../../ttyACM1
                pi@raspi:~ $
                Die Zahlen stimmen nicht überein.
                Muss ich die im Adapter ändern? 18->26?
                • B brokeling
                  @djmarc75
                  sudo apt update
                  iobroker stop
                  iobroker update
                  iobroker upgrade
                  iobroker start
                  DJMarc75D Offline
                  DJMarc75D Offline
                  DJMarc75
                  Das führt lediglich dazu dass Du den Host auf Beta upgradest.
                  Warum auch immer man den Tester spielen will 🤔
                  • B brokeling
                    @djmarc75
                    sudo apt update
                    iobroker stop
                    iobroker update
                    iobroker upgrade
                    iobroker start
                    Weil Ugrades der Distribution nicht so funktionieren.
                    Da muss man anders herangehen. So z. B.
                    https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
                    • B brokeling
                      @dp20eic
                      insgesamt 0
                      pi@raspi:~ $
                      Moin,
                      genau, es sollte schon so da stehen, wie es auch im Dateisystem steht ;)
                      Bernd
                        Moin,
                        Bernd
                        brokeling
                        @dp20eic
                        zigbee jetzt auf alle Fälle grün 👍
                          brokeling
                          das bullseye update mache ich dann gleich.
                          • B brokeling
                            @djmarc75
                            Summary:
                                                 v.2023-04-16
                            User-ID:                1000
                            X-Server:               false
                                                    /usr/bin/npm            9.6.7
                                                    /usr/bin/npx            9.6.7
                            MEMORY:
                            Swap:           99M          0B         99M
                                                    admin                   6.7.2
                            Objects type: jsonl
                            States  type: redis
                            Objects:                17066
                            States:                 12808
                            lange Version:
                            Skript v.2023-04-16
                            *** BASE SYSTEM ***
                            Docker          : false
                            Release:        10
                            Codename:       buster
                            VERSION_ID="10"
                            ID=raspbian
                            ID_LIKE=debian
                            CPU threads: 4
                            Raspberry only:
                            throttled=0x0
                            temp=64.2'C
                            volt=0.8375V
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            pi
                            /home/pi
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Swap:           99M          0B         99M
                                     3786 M total memory
                                     1568 M used memory
                                      363 M active memory
                                     1298 M free memory
                                      109 M buffer memory
                                      809 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            /var:
                            5.8G    /var/
                            3.4G    /var/cache
                            3.3G    /var/cache/apt
                            2.4G    /var/lib
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: redis
                            admin:          6.7.2
                            javascript:     7.1.4
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        17066
                            States:         12808
                            Pending Updates: 8
                            Moin,
                            Moin,
                            laut iob diag bist Du im Beta Universum vom ioBroker unterwegs
                            Bernd
                              Moin,
                              Moin,
                              Bernd
                              brokeling
                              @dp20eic
                              wie komme ich da wieder raus und nicht wieder hinein?
                              • B brokeling
                                @dp20eic
                                Du meinst den Beta-Bereich?
                                iob repo unset beta
                                iob repo set stable
                                iob update
                                  iob repo unset beta
                                  iob repo set stable
                                  iob update
                                  brokeling
                                  ok danke.
                                  Aber jetzt komme ich am update zum bullseye.
                                  Alles gemacht, aber ich komme jetzt in die admin Oberfläche nicht rein.
                                  auch
                                  iobroker start admin
                                  bringt nichts
                                  • B brokeling
                                    ok danke.
                                    auch
                                    bringt nichts
                                    @brokeling
                                    Wir bist du da jetzt genau unterwegs?
                                    iob diag
                                    anschauen.
                                      @brokeling
                                      iob diag
                                      anschauen.
                                      brokeling
                                      Skript v.2023-04-16
                                      *** BASE SYSTEM ***
                                      Docker          : false
                                      Description:    Raspbian GNU/Linux 11 (bullseye)
                                      Release:        11
                                      Codename:       bullseye
                                      PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
                                      VERSION_ID="11"
                                      VERSION="11 (bullseye)"
                                      VERSION_CODENAME=bullseye
                                      ID=raspbian
                                      ID_LIKE=debian
                                       16:42:38 up 3 min,  1 user,  load average: 7.83, 3.25, 1.25
                                      CPU threads: 4
                                      Raspberry only:
                                      throttled=0x0
                                      temp=68.6'C
                                      volt=0.8375V
                                                     Local time: Thu 2023-08-17 16:42:39 CEST
                                                 Universal time: Thu 2023-08-17 14:42:39 UTC
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      pi
                                      /home/pi
                                      X-Server:       false
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Mem:            3.8G        1.9G        1.1G        0.0K        778M        1.8G
                                      Swap:            99M          0B         99M
                                      Total:          3.9G        1.9G        1.2G
                                               3786 M total memory
                                               1875 M used memory
                                                240 M active memory
                                               2294 M inactive memory
                                               1132 M free memory
                                                 73 M buffer memory
                                                704 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      Raspberry only:
                                      oom events: 0
                                      *** FILESYSTEM ***
                                      /dev/root      ext4      117G   18G   94G  16% /
                                      tmpfs          tmpfs     758M  864K  757M   1% /run
                                      tmpfs          tmpfs     379M   16K  379M   1% /run/user/1000
                                      [Thu Aug 17 16:38:50 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:40:0F:7D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                      [Thu Aug 17 16:38:52 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                                      [Thu Aug 17 16:38:52 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                      [Thu Aug 17 16:38:54 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
                                      [Thu Aug 17 16:38:56 2023] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)
                                      `-/boot   /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                                      /var:
                                      5.9G    /var/
                                      3.4G    /var/cache/apt
                                      3.4G    /var/cache
                                      2.4G    /var/lib
                                      Archived and active journals take up 40.0M in the file system.
                                      31M     /opt/iobroker/iobroker-data/objects.jsonl
                                      /usr/bin/npm            9.6.7
                                      /usr/bin/npx            9.6.7
                                      nodejs:
                                        Version table:
                                              500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
                                              500 https://deb.nodesource.com/node_12.x bullseye/main armhf Packages
                                           12.22.12~dfsg-1~deb11u4 500
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: redis
                                      admin:          6.7.2
                                      javascript:     7.1.4
                                      Adapter State
                                      + system.adapter.zigbee.0                 : zigbee                : raspi                                    -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100GB8-if00
                                      + instance is alive
                                      Adapter    "admin"        : 6.8.2    , installed 6.7.2  [Updatable]
                                      Objects and States
                                      Objects:        17061
                                      States:         12802
                                      Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
                                      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                      Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                                      Hit:4 https://deb.nodesource.com/node_12.x bullseye InRelease
                                      Hit:5 https://deb.nodesource.com/node_14.x bullseye InRelease
                                      Pending Updates: 0
                                      tcp        0      0 127.0.0.1:8080          0.0.0.0:*               LISTEN      119        15505      393/motion
                                      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       13397      376/deCONZ
                                      tcp        0      0 127.0.0.1:8081          0.0.0.0:*               LISTEN      119        15504      393/motion
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15448      544/sshd: /usr/sbin
                                      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15509      529/cupsd
                                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       20690      2004/io.sonoff.0
                                      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       15588      376/deCONZ
                                      tcp        0      0 192.168.178.53:9092     0.0.0.0:*               LISTEN      1001       23103      2718/io.nuki.0
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13587      602/iobroker.js-con
                                      tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      110        13451      618/mariadbd
                                      tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      118        14601      532/redis-server 12
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21194      2452/io.web.0
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          15450      544/sshd: /usr/sbin
                                      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       31661      3739/io.simple-api.
                                      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15508      529/cupsd
                                      tcp6       0      0 ::1:6379                :::*                    LISTEN      118        14602      532/redis-server 12
                                      udp        0      0 0.0.0.0:51718           0.0.0.0:*                           108        13333      369/avahi-daemon: r
                                      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       21832      2408/io.shelly.0
                                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14733      988/dhcpcd
                                      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          10205      642/cups-browsed
                                      udp        0      0 0.0.0.0:55934           0.0.0.0:*                           1001       48081      2408/io.shelly.0
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       18145      2194/io.chromecast.
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13331      369/avahi-daemon: r
                                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       14732      376/deCONZ
                                      udp6       0      0 :::546                  :::*                                0          14885      988/dhcpcd
                                      udp6       0      0 :::60506                :::*                                108        13334      369/avahi-daemon: r
                                      udp6       0      0 :::5353                 :::*                                108        13332      369/avahi-daemon: r
                                      2023-08-17 16:42:28.713  - info: onvif.0 (3793) Found Adapter Device: onvif.0.192_168_178_119_8000 Manufacturer IPC_523128M5MP 192.168.178.119:8000
                                      2023-08-17 16:42:31.896  - error: onvif.0 (3793) Data: null XML: undefined
                                      2023-08-17 16:42:31.896  - error: onvif.0 (3793) Error initializing device: Error: connect EHOSTUNREACH 192.168.178.119:8000 device: {"id":"192_168_178_119_8000","name":"Manufacturer IPC_523128M5MP 192.168.178.119:8000","ip":"192.168.178.119","port":"8000","hostname":"192.168.178.119","user":"admin","password":"fCmqvxM4ZCJMY7Tpv51SSlsso","snapshotUrl":"http://192.168.178.119:80/cgi-bin/api.cgi?cmd=onvifSnapPic&channel=0","majorStreamUrl":"rtsp://admin:fCmqvxM4ZCJMY7Tpv51SSlsso@192.168.178.119:554/","minorStreamUrl":"rtsp://admin:fCmqvxM4ZCJMY7Tpv51SSlsso@192.168.178.119:554/h264Preview_01_sub"}
                                      2023-08-17 16:42:31.897  - error: onvif.0 (3793) You can change user and password under object and edit device or delete device under objects and restart adapter
                                      2023-08-17 16:42:31.897  - error: onvif.0 (3793) Error: connect EHOSTUNREACH 192.168.178.119:8000
                                          at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1495:16)
                                      2023-08-17 16:42:31.898  - info: onvif.0 (3793) Found Adapter Device: onvif.0.192_168_178_127_8000 ManufacturerE1 Outdoor 192.168.178.127:8000
                                      2023-08-17 16:42:33.300  - info: onvif.0 (3793) Device successful initialized: 192.168.178.127:8000
                                      2023-08-17 16:42:34.075  - info: sourceanalytix.0 (3641) Initialization of 0_userdata.0.Holger2.Energie_Haus.SolarErzeugung successfully
                                      2023-08-17 16:42:34.076  - info: sourceanalytix.0 (3641) Initialising (7 of 7) "0_userdata.0.Holger2.Energie_Haus.Strombezug_STAWA"
                                      2023-08-17 16:42:37.306  - info: onvif.0 (3793) Start onvif discovery
                                      2023-08-17 16:42:37.331  - warn: onvif.0 (3793) Used invalid characters: onvif.0.192_168_178_127_8000.infos.presets.Geländer changed to onvif.0.192_168_178_127_8000.infos.presets.GelÃ_nder
                                      2023-08-17 16:42:37.382  - info: onvif.0 (3793) Discovery Reply from 192.168.178.127 (name,IPC) (E1Outdoor) (http://192.168.178.127:8000/onvif/device_service) (urn:uuid:2419d68a-2dd2-21b2-a205-c4:3c:b0:9c:12:34)
                                      2023-08-17 16:42:37.383  - info: onvif.0 (3793) Skip device 192.168.178.127 because it is already configured via iobroker object. Delete the device under objects for reconfigure.
                                      2023-08-17 16:42:37.457  - info: onvif.0 (3793) Discovery Reply from 192.168.178.128 (name,IPC) (E1Outdoor) (http://192.168.178.128:8000/onvif/device_service) (urn:uuid:2419d68a-2dd2-21b2-a205-68:39:43:f8:6c:69)
                                      2023-08-17 16:42:37.457  - info: onvif.0 (3793) Skip device 192.168.178.128 because it is already configured via iobroker object. Delete the device under objects for reconfigure.
                                      2023-08-17 16:42:37.475  - info: onvif.0 (3793) Discovery Reply from 192.168.178.132 (name,IPC) (E1Outdoor) (http://192.168.178.132:8000/onvif/device_service) (urn:uuid:2419d68a-2dd2-21b2-a205-5c:c3:36:2e:0e:73)
                                      2023-08-17 16:42:37.476  - info: onvif.0 (3793) Skip device 192.168.178.132 because it is already configured via iobroker object. Delete the device under objects for reconfigure.
                                      2023-08-17 16:42:37.535  - warn: onvif.0 (3793) State "onvif.0.192_168_178_127_8000.infos.presets.Geländer" has no existing object, this might lead to an error in future versions
                                      2023-08-17 16:42:42.316  - info: onvif.0 (3793) Finished onvif discovery
                                      2023-08-17 16:42:51.240  - info: sourceanalytix.0 (3641) Initialization of 0_userdata.0.Holger2.Energie_Haus.Strombezug_STAWA successfully
                                      2023-08-17 16:42:51.283  - warn: sourceanalytix.0 (3641) Cannot handle calculations for 1 of 7 enabled states, check error messages
                                      2023-08-17 16:42:51.303  - info: sourceanalytix.0 (3641) Successfully activated SourceAnalytix for 6 of 7 states, will do my Job until you stop me!
                                      2023-08-17 16:44:03.228  - info: javascript.0 (910) script.js.common.Akustischer_Alarm____Steuerung_Haus._Alarmauslösung_Cams: Alarm durch Reolink
                                      2023-08-17 16:44:25.874  - info: javascript.0 (910) script.js.common.Akustischer_Alarm____Steuerung_Haus._Alarmauslösung_Cams: Alarm durch Reolink
                                      • B brokeling
                                        Skript v.2023-04-16
                                        *** BASE SYSTEM ***
                                        Docker          : false
                                        Release:        11
                                        Codename:       bullseye
                                        VERSION_ID="11"
                                        ID=raspbian
                                        ID_LIKE=debian
                                        CPU threads: 4
                                        Raspberry only:
                                        throttled=0x0
                                        temp=68.6'C
                                        volt=0.8375V
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        pi
                                        /home/pi
                                        X-Server:       false
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Swap:            99M          0B         99M
                                                 3786 M total memory
                                                 1875 M used memory
                                                  240 M active memory
                                                 1132 M free memory
                                                   73 M buffer memory
                                                  704 M swap cache
                                                   99 M total swap
                                                    0 M used swap
                                                   99 M free swap
                                        Raspberry only:
                                        oom events: 0
                                        *** FILESYSTEM ***
                                        /var:
                                        5.9G    /var/
                                        3.4G    /var/cache/apt
                                        3.4G    /var/cache
                                        2.4G    /var/lib
                                        /usr/bin/npm            9.6.7
                                        /usr/bin/npx            9.6.7
                                        nodejs:
                                          Version table:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: redis
                                        admin:          6.7.2
                                        javascript:     7.1.4
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects:        17061
                                        States:         12802
                                        Pending Updates: 0
                                        DJMarc75D Offline
                                        DJMarc75D Offline
                                        DJMarc75
                                        js-controller: js-controller: 5.0.11
                                        admin: 6.7.2
                                        javascript: 7.1.4
                                        jetzt sogar überall Betauser
                                        Hammer... über 7 sieht man selten
                                        temp=68.6'C
                                        grenzwertig
                                        volt=0.8375V
                                        hm...
                                        Objects type: jsonl
                                        States  type: redis
                                        • B brokeling
                                          ok danke.
                                          auch
                                          bringt nichts
                                          @brokeling
                                          Warum hast du den Beta-Kram nicht ausgeschaltet?
                                          iob start admin.1
                                          sagt was im LogFile?
