  4. Noch ein Zigbee Problem....
    5.2k
137 Beiträge 7 Kommentatoren 24.7k Aufrufe 5 Beobachtet
    @crunchip
    Der Server heißt aber 'motion'. Und der sitzt (bzw. saß) auf dem Port.
    crunchipC Offline
    crunchipC Offline
    #81
    @thomas-braun sagte in Noch ein Zigbee Problem....:
    auf dem Port
    besser gesagt seine cam
    • B brokeling
      Zigbee macht noch Zicken.
      2023-08-17 19:31:16.406  - info: host.raspi stopInstance system.adapter.zigbee.0 (force=false, process=true)
      2023-08-17 19:31:16.412  - info: host.raspi stopInstance system.adapter.zigbee.0 send kill signal
      2023-08-17 19:31:16.414  - info: zigbee.0 (2106) Got terminate signal TERMINATE_YOURSELF
      2023-08-17 19:31:16.418  - info: zigbee.0 (2106) cleaned everything up...
      2023-08-17 19:31:17.190  - info: zigbee.0 (2106) Zigbee: disabling joining new devices.
      2023-08-17 19:31:17.225  - warn: zigbee.0 (2106) Failed to stop zigbee during startup
      2023-08-17 19:31:17.226  - info: zigbee.0 (2106) terminating
      2023-08-17 19:31:17.228  - info: zigbee.0 (2106) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-08-17 19:31:17.229  - info: zigbee.0 (2106) terminating
      2023-08-17 19:31:17.294  - info: zigbee.0 (2106) debug devices set to []
      2023-08-17 19:31:17.418  - info: host.raspi stopInstance system.adapter.zigbee.0 killing pid 2106
      2023-08-17 19:31:17.968  - info: host.raspi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-08-17 19:31:19.710  - info: host.raspi instance system.adapter.zigbee.0 started with pid 15172
      2023-08-17 19:31:25.073  - info: zigbee.0 (15172) starting. Version 1.8.23 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.17.1, js-controller: 5.0.11
      2023-08-17 19:31:25.244  - info: zigbee.0 (15172) delete old Backup files. keep only last 10
      2023-08-17 19:31:25.247  - info: zigbee.0 (15172) Starting Zigbee  npm ...
      2023-08-17 19:31:25.995  - error: zigbee.0 (15172) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100GB8-if00'"
      2023-08-17 19:31:25.996  - error: zigbee.0 (15172) Failed to start Zigbee
      2023-08-17 19:31:25.997  - error: zigbee.0 (15172) Error herdsman start
      2023-08-17 19:31:25.999  - info: zigbee.0 (15172) Installed Version: iobroker.zigbee@1.8.23
      2023-08-17 19:31:35.999  - info: zigbee.0 (15172) Try to reconnect. 1 attempts left
      2023-08-17 19:31:36.000  - info: zigbee.0 (15172) Starting Zigbee  npm ...
      2023-08-17 19:31:36.030  - error: zigbee.0 (15172) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100GB8-if00'"
      2023-08-17 19:31:36.032  - error: zigbee.0 (15172) Failed to start Zigbee
      2023-08-17 19:31:36.034  - error: zigbee.0 (15172) Error herdsman start
      2023-08-17 19:31:36.035  - info: zigbee.0 (15172) Installed Version: iobroker.zigbee@1.8.23
      2023-08-17 19:32:05.512  - info: javascript.0 (1204)
      #82
      @brokeling
      find /dev/serial/by-id/ -maxdepth 1 -mindepth 1
      sagt?
      B 1 Antwort Letzte Antwort
        @brokeling
        sagt?
        brokeling
        schrieb am zuletzt editiert von brokeling
        #83
        pi@raspi:~ $ find /dev/serial/by-id/ -maxdepth 1 -mindepth 1
        find: ‘/dev/serial/by-id/’: Datei oder Verzeichnis nicht gefunden
        was ist jetzt mit dem serial port?
        pi@raspi:~ $ ls -la /dev/serial/by-id/
        ls: Zugriff auf '/dev/serial/by-id/' nicht möglich: Datei oder Verzeichnis nicht gefunden
        • B brokeling
          #84
          @brokeling
          sudo apt update
          apt policy udev
            @brokeling
            sudo apt update
            apt policy udev
            brokeling
            #85
            pi@raspi:~ $ sudo apt update
            OK:1 http://phoscon.de/apt/deconz bullseye InRelease
            Holen:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15,0 kB]
            OK:3 https://deb.nodesource.com/node_12.x bullseye InRelease
            OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
            OK:5 https://deb.nodesource.com/node_14.x bullseye InRelease
            OK:6 https://deb.nodesource.com/node_16.x bullseye InRelease
            OK:7 https://deb.nodesource.com/node_18.x bullseye InRelease
            Es wurden 15,0 kB in 2 s geholt (7.010 B/s).
            Alle Pakete sind aktuell.
            pi@raspi:~ $ apt policy udev
            udev:
              Installiert:           247.3-7+rpi1+deb11u2
              Installationskandidat: 247.3-7+rpi1+deb11u2
              Versionstabelle:
             *** 247.3-7+rpi1+deb11u2 500
                    500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                    100 /var/lib/dpkg/status
            • B brokeling
              udev:
                Versionstabelle:
              #86
              @brokeling
              Das ist der udev bug. Betrifft wohl immer noch die 32bit-Raspberry-Version, alles andere ist aktueller.
              https://forum.iobroker.net/topic/65017/zigbee-conbee2-funktioniert-nach-update-nicht-mehr-udev
                @brokeling
                brokeling
                #87
                pi@raspi:/ $ sudo apt update
                Holen:2 http://deb.debian.org/debian bullseye-proposed-updates InRelease [54,0 kB]
                OK:3 http://archive.raspberrypi.org/debian bullseye InRelease
                OK:4 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                OK:5 https://deb.nodesource.com/node_12.x bullseye InRelease
                OK:6 https://deb.nodesource.com/node_14.x bullseye InRelease
                OK:7 https://deb.nodesource.com/node_16.x bullseye InRelease
                OK:8 https://deb.nodesource.com/node_18.x bullseye InRelease
                Fehl:2 http://deb.debian.org/debian bullseye-proposed-updates InRelease
                  Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
                W: GPG-Fehler: http://deb.debian.org/debian bullseye-proposed-updates InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
                E: Das Depot »http://deb.debian.org/debian bullseye-proposed-updates InRelease« ist nicht signiert.
                N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
                N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
                kann ich das übergehen?
                • B brokeling
                  #88
                  @brokeling sagte in Noch ein Zigbee Problem....:
                  Nein. Der Schlüssel muss rein.
                    brokeling
                    #89
                    wie kann ich ihn dazu bringen?
                    • B brokeling
                      #90
                      @brokeling
                      Steht wenn ich mich recht entsinne im HowTo drin. Ggfls aber mit einer andren key-ID. Musste mal schauen.
                        @brokeling
                        brokeling
                        #91
                        ja das stimmt.
                        Aber da komm ich nicht mit klar. Bei den Lösungen kommen auch noch Fehlermeldungen...
                        Ich glaub ich spiele ein Backup zurück.
                        Und dann lass ich das System erstmal, wenn Zigbee mit dem Controller-update läuft!
                        • B brokeling
                          ja das stimmt.
                          #92
                          Unbekannte, streng geheime?
                          • B brokeling
                            ja das stimmt.
                            #93
                            @brokeling
                            sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 0E98404D386FA1D9
                            sudo apt update
                            funktioniert nicht?
                              @brokeling
                              sudo apt update
                              funktioniert nicht?
                              brokeling
                              #94
                              will ich nicht vorenthalten:
                              pi@raspi:/ $ sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 648ACFD622F3D138
                              Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
                              Executing: /tmp/apt-key-gpghome.dzFpL9t6R4/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys 648ACFD622F3D138
                              gpg: Schlüssel DC30D7C23CBBABEE: Öffentlicher Schlüssel "Debian Archive Automatic Signing Key (10/buster) <ftpmaster@debian.org>" importiert
                              gpg: Anzahl insgesamt bearbeiteter Schlüssel: 1
                              gpg:                              importiert: 1
                              OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
                              Holen:3 http://deb.debian.org/debian bullseye-proposed-updates InRelease [54,0 kB]
                              Fehl:3 http://deb.debian.org/debian bullseye-proposed-updates InRelease
                              pi@raspi:/ $ sudo apt install udev=247.3-7+deb11u4 libudev1=247.3-7+deb11u4
                              E: Version »247.3-7+deb11u4« für »udev« konnte nicht gefunden werden.
                              E: Version »247.3-7+deb11u4« für »libudev1« konnte nicht gefunden werden.
                              pi@raspi:/ $
                              B Thomas BraunT 2 Antworten Letzte Antwort
                              • B brokeling
                                gpg:                              importiert: 1
                                pi@raspi:/ $
                                brokeling
                                #95
                                Ich muss zurückspielen.
                                Jetzt noch etwas Hilfe:
                                pi@raspi:/ $ sudo raspiBackup -d /dev/sda /backup/raspi/raspi-rsync-backup-20230814-050001
                                --- RBK0009I: raspi: raspiBackup.sh V0.6.8 - 2023-04-15 (f600458) Do 17. Aug 21:08:19 CEST 2023 gestartet.
                                --- RBK0116I: Konfigurationsdatei /usr/local/etc/raspiBackup.conf wird benutzt.
                                --- RBK0031I: Prüfe ob eine neue Version von raspiBackup.sh verfügbar ist.
                                /dev/sda2 on / type ext4 (rw,noatime,stripe=8191)
                                /dev/sda1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro)
                                ??? RBK0274E: Das Restoregerät /dev/sda hat gemountete Partitionen. Hinweis: Ein Restore auf das aktive System ist nicht möglich.
                                --- RBK0033I: Bitte warten bis aufgeräumt wurde.
                                ??? RBK0077E: Restore wurde fehlerhaft beendet. Siehe vorhergehende Fehlermeldungen.
                                --- RBK0010I: raspi: raspiBackup.sh V0.6.8 - 2023-04-15 (f600458) Do 17. Aug 21:08:42 CEST 2023 beendet mit Returncode 137.
                                --- RBK0026I: Debug Logdatei wurde in /home/pi/raspiBackup.logr gesichert.
                                Lautet der Befehl
                                sudo raspiBackup -d /dev/sda2 /backup/raspi/raspi-rsync-backup-20230814-050001
                                • B brokeling
                                  gpg:                              importiert: 1
                                  pi@raspi:/ $
                                  #96
                                  @brokeling
                                  Kleine Transferleistung: Die IDs der vermissten keys werden genannt. Welche ID muss man dann bei --recv-keys wohl angeben?
                                  • B brokeling
                                    Lautet der Befehl
                                    #97
                                    Wegen der fehlenden keys?????
                                      @brokeling
                                      brokeling
                                      #98
                                      Achso ich wusste nicht dass da etwas einzutragen ist...
                                      Jetzt könnte es gehen:
                                      OK:2 http://deb.debian.org/debian bullseye-proposed-updates InRelease
                                      OK:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                      Aktualisierung für 41 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                                      pi@raspi:/ $ sudo apt -t bullseye-proposed-updates install udev
                                      udev ist schon die neueste Version (247.3-7+rpi1+deb11u2).
                                      Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                                        bsdmainutils g++-8 geoip-database gsfonts libbind9-161 libboost-atomic1.67.0 libboost-iostreams1.67.0
                                        libboost-regex1.67.0 libboost-system1.67.0 libboost-thread1.67.0 libcdio18 libcodec2-0.8.1 libcroco3 libdc1394-22
                                        libdns1104 libdns1110 libdouble-conversion1 libdvdread4 libegl1-mesa libevent-2.1-6 libfl2 libfluidsynth1 libgeoip1
                                        libglade2-0 libgssdp-1.0-3 libgupnp-1.0-4 libgutenprint-common libgutenprint9 libhiredis0.14 libilmbase23
                                        libindicator3-7 libisc1100 libisc1105 libisccc161 libisccfg163 libisl19 libjemalloc2 libjim0.77 libjsoncpp1
                                        libkeybinder0 libkyotocabinet16v5 libllvm9 liblouis17 liblouisutdml8 liblwres161 libmpdec2 libmysofa0 libncursesw5
                                        libnfs12 liboauth0 libopenexr23 libperl5.28 libpgm-5.2-0 libplymouth4 libpoppler82 libpython2-dev libpython2-stdlib
                                        libpython2.7 libpython2.7-dev libpython2.7-minimal libpython2.7-stdlib libpython3.7 libpython3.7-minimal
                                        libpython3.7-stdlib libqpdf21 libreadline5 libsane libsnmp30 libstdc++-8-dev libunique-1.0-0 libusb-0.1-4
                                        libusbmuxd4 libvpx5 libwnck-common libwnck22 libx264-155 libx265-165 libxcb-util0 perl-modules-5.28
                                        printer-driver-gutenprint python-pkg-resources python2 python2-dev python2-minimal python2.7 python2.7-dev
                                        python2.7-minimal python3.7-minimal rpi.gpio-common
                                      Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                                      0 aktualisiert, 0 neu installiert, 0 zu entfernen und 65 nicht aktualisiert.
                                      pi@raspi:/ $
                                      • B brokeling
                                        pi@raspi:/ $
                                        brokeling
                                        #99
                                        also der Vorgang kann jetzt ausgeführt werden, aber ich komme noch nicht ans Ziel.
                                        Was muss ich noch machen?
                                        pi@raspi:~ $ sudo nano bullseye-proposed-updates.list
                                        pi@raspi:~ $ sudo apt -t bullseye-proposed-updates install udev
                                        udev:
                                          Versionstabelle:
                                             247.3-7+deb11u4 500
                                                500 http://deb.debian.org/debian bullseye-proposed-updates/main armhf Packages
                                        pi@raspi:~ $
                                        • B brokeling
                                          udev:
                                            Versionstabelle:
                                               247.3-7+deb11u4 500
                                          pi@raspi:~ $
                                          #100
                                          @brokeling
                                          Bitte vollständig lesen. @mickym hat sich so eine Mühe damit gemacht.
                                          EDIT 10.06.2023
                                          Falls jemand trotz allem auf dem Raspberry (vermutlich 32 bit OS) immer noch Probleme hat - beim mir hat alles gemäß Anleitung auf einem 64-bit OS auf dem Raspberry funktioniert - der kann noch folgendes versuchen:
                                          und anschliessend mit
                                          sudo apt-mark hold udev
                                          auf hold setzen.
