  4. Noch ein Zigbee Problem....
    5.2k
137 Beiträge 7 Kommentatoren 24.7k Aufrufe 5 Beobachtet
  • B brokeling
    @djmarc75
    Summary:
                         v.2023-04-16
    Operatingsystem:        Raspbian GNU/Linux 10 (buster)
    Kernel:                 5.10.103-v7l+
    Installation:           Native
    User-ID:                1000
    X-Server:               false
    Boot Target:            multi-user.target
    Pending OS-Updates:     8
    Pending iob updates:    5
    Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                            /usr/bin/node           v18.17.1
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:           3.8G        1.6G        1.2G        8.0M        921M        2.0G
    Swap:           99M          0B         99M
    Total:         3.9G        1.6G        1.3G
    Active iob-Instances:   33
    Active repo(s): beta
    ioBroker Core:          js-controller           5.0.11
                            admin                   6.7.2
    Objects type: jsonl
    States  type: redis
    + system.adapter.admin.1                  : admin                 : raspi                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.web.0                    : web                   : raspi                                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects:                17066
    States:                 12808
    Size of iob-Database:
    22M     /opt/iobroker/iobroker-data/objects.jsonl
    8.4M    /opt/iobroker/iobroker-data/objects.json.migrated
    8.4M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    12K     /opt/iobroker/iobroker-data/objects.json.old
    41M     /opt/iobroker/iobroker-data/states.json.old
    41M     /opt/iobroker/iobroker-data/states.json.bak
    0       /opt/iobroker/iobroker-data/states.json
    lange Version:
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Architecture    : armv7l
    Docker          : false
    Virtualization  : none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 10 (buster)
    Release:        10
    Codename:       buster
    PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="10"
    VERSION="10 (buster)"
    VERSION_CODENAME=buster
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     14:19:25 up 5 min,  1 user,  load average: 4.56, 4.04, 1.85
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=64.2'C
    volt=0.8375V
    *** Time and Time Zones ***
                   Local time: Thu 2023-08-17 14:19:25 CEST
               Universal time: Thu 2023-08-17 12:19:25 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           3.8G        1.6G        1.3G        8.0M        918M        2.1G
    Swap:           99M          0B         99M
    Total:         3.9G        1.6G        1.4G
             3786 M total memory
             1568 M used memory
              363 M active memory
             1974 M inactive memory
             1298 M free memory
              109 M buffer memory
              809 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4      117G   17G   94G  16% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     1.9G  8.6M  1.9G   1% /run
    tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
    /dev/sdb1      ext4      113G   71G   37G  66% /backup
    /dev/sda1      vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     379M     0  379M   0% /run/user/1000
    [Thu Aug 17 14:13:40 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:40:0F:7D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Thu Aug 17 14:13:42 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    [Thu Aug 17 14:13:42 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Thu Aug 17 14:13:43 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
    [Thu Aug 17 14:13:46 2023] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)
    TARGET        SOURCE    FSTYPE OPTIONS
    /             /dev/sda2 ext4   rw,noatime,stripe=8191
    |-/sys/fs/bpf none      bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    |-/backup     /dev/sdb1 ext4   rw,noatime
    `-/boot       /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    5.8G    /var/
    3.4G    /var/cache
    3.3G    /var/cache/apt/archives
    3.3G    /var/cache/apt
    2.4G    /var/lib
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    2.9G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.1G    /opt/iobroker/iobroker-data/
    541M    /opt/iobroker/iobroker-data/backup-objects
    383M    /opt/iobroker/iobroker-data/files
    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js.map
    *** NodeJS-Installation ***
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
         16.20.2-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
         14.21.3-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
         12.22.12-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: redis
    Core adapters versions
    js-controller:  5.0.11
    admin:          6.7.2
    javascript:     7.1.4
    Adapters from github:   3
    Adapter State
      system.adapter.alias-manager.0          : alias-manager         : raspi                                    -  enabled
    + system.adapter.backitup.0               : backitup              : raspi                                    -  enabled
    + system.adapter.chromecast.0             : chromecast            : raspi                                    -  enabled
    + system.adapter.cloud.0                  : cloud                 : raspi                                    -  enabled
      system.adapter.deconz.0                 : deconz                : raspi                                    - disabled, port: 80
      system.adapter.devices.0                : devices               : raspi                                    -  enabled
    + system.adapter.discovery.0              : discovery             : raspi                                    -  enabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspi                                    - disabled
      system.adapter.feiertage.0              : feiertage             : raspi                                    -  enabled
      system.adapter.flot.0                   : flot                  : raspi                                    -  enabled
      system.adapter.fritzdect.0              : fritzdect             : raspi                                    - disabled
      system.adapter.hue-extended.0           : hue-extended          : raspi                                    - disabled
      system.adapter.hue.0                    : hue                   : raspi                                    - disabled, port: 443
      system.adapter.ical.0                   : ical                  : raspi                                    -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : raspi                                    -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspi                                    -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspi                                    -  enabled
      system.adapter.iqontrol.0               : iqontrol              : raspi                                    - disabled
    + system.adapter.javascript.0             : javascript            : raspi                                    -  enabled
      system.adapter.luftdaten.0              : luftdaten             : raspi                                    -  enabled
      system.adapter.luftdaten.1              : luftdaten             : raspi                                    -  enabled
      system.adapter.mqtt.0                   : mqtt                  : raspi                                    - disabled, port: 1884, bind: 0.0.0.0
    + system.adapter.net-tools.0              : net-tools             : raspi                                    -  enabled
    + system.adapter.netatmo-crawler.0        : netatmo-crawler       : raspi                                    -  enabled
    + system.adapter.nuki.0                   : nuki                  : raspi                                    -  enabled
    + system.adapter.onvif.0                  : onvif                 : raspi                                    -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
    + system.adapter.ping.0                   : ping                  : raspi                                    -  enabled
    + system.adapter.pushover.0               : pushover              : raspi                                    -  enabled
    + system.adapter.reolink.0                : reolink               : raspi                                    -  enabled
    + system.adapter.reolink.1                : reolink               : raspi                                    -  enabled
    + system.adapter.reolink.2                : reolink               : raspi                                    -  enabled
    + system.adapter.reolink.3                : reolink               : raspi                                    -  enabled
    + system.adapter.reolink.4                : reolink               : raspi                                    -  enabled
      system.adapter.samsung_tizen.0          : samsung_tizen         : raspi                                    -  enabled, port: 8002
    + system.adapter.sayit.0                  : sayit                 : raspi                                    -  enabled
    + system.adapter.sayit.1                  : sayit                 : raspi                                    -  enabled
    + system.adapter.sayit.2                  : sayit                 : raspi                                    -  enabled
    + system.adapter.sayit.3                  : sayit                 : raspi                                    -  enabled
    + system.adapter.sayit.4                  : sayit                 : raspi                                    -  enabled
    + system.adapter.sayit.5                  : sayit                 : raspi                                    -  enabled
    + system.adapter.shelly.0                 : shelly                : raspi                                    -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : raspi                                    -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.smartcontrol.0           : smartcontrol          : raspi                                    - disabled
    + system.adapter.sonoff.0                 : sonoff                : raspi                                    -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : raspi                                    -  enabled
    + system.adapter.spotify-premium.0        : spotify-premium       : raspi                                    -  enabled
    + system.adapter.sql.0                    : sql                   : raspi                                    -  enabled, port: 0
      system.adapter.statistics.0             : statistics            : raspi                                    -  enabled
    + system.adapter.telegram.0               : telegram              : raspi                                    -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.text2command.0           : text2command          : raspi                                    - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspi                                    -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspi                                    -  enabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspi                                    -  enabled
      system.adapter.vis-history.0            : vis-history           : raspi                                    -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspi                                    -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspi                                    -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspi                                    -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : raspi                                    -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspi                                    -  enabled
      system.adapter.vis-metro.0              : vis-metro             : raspi                                    -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : raspi                                    -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspi                                    -  enabled
      system.adapter.vis.0                    : vis                   : raspi                                    -  enabled
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspi                                    -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspi                                    -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.18__Embed_with_CMSIS-DAP_L1100GB8-if00
    + instance is alive
    ioBroker-Repositories
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 6.8.3    , installed 6.7.2  [Updatable]
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "asterisk"     : 1.0.6    , installed 1.0.6
    Adapter    "backitup"     : 2.7.0    , installed 2.6.23 [Updatable]
    Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "countdown"    : 2.1.0    , installed 2.0.1  [Updatable]
    Adapter    "deconz"       : 1.3.21   , installed 1.3.21
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "digitalstrom" : 2.3.0    , installed 2.3.0
    Adapter    "discovery"    : 3.2.0    , installed 3.2.0
    Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "hue"          : 3.9.6    , installed 3.9.3  [Updatable]
    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "iqontrol"     : 2.3.0    , installed 2.2.0  [Updatable]
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.11   , installed 5.0.11
    Adapter    "luftdaten"    : 3.0.0    , installed 3.0.0
    Adapter    "moma"         : 1.2.9    , installed 1.2.9
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "mydlink"      : 1.3.2    , installed 1.3.2
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
    Adapter    "nuki"         : 1.6.0    , installed 1.6.0
    Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
    Adapter    "octoprint"    : 5.0.1    , installed 5.0.1
    Adapter    "onvif"        : 1.0.5    , installed 1.0.5
    Adapter    "owntracks"    : 1.0.5    , installed 1.0.5
    Adapter    "paw"          : 0.3.2    , installed 0.3.2
    Adapter    "ph803w"       : 1.1.1    , installed 1.1.1
    Adapter    "pushover"     : 3.0.4    , installed 3.0.4
    Adapter    "samsung"      : 0.5.11   , installed 0.5.11
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "smartcontrol" : 1.3.2    , installed 1.3.2
    Adapter    "socketio"     : 6.5.2    , installed 6.5.2
    Adapter    "sonoff"       : 2.5.7    , installed 2.5.7
    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
    Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
    Adapter    "statistics"   : 2.3.0    , installed 2.3.0
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "web"          : 6.1.0    , installed 6.1.0
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "wiobrowser"   : 2.0.1    , installed 2.0.1
    Adapter    "ws"           : 2.5.3    , installed 2.5.3
    Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
    Objects and States
    Objects:        17066
    States:         12808
    Hit:1 http://phoscon.de/apt/deconz buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 http://archive.raspberrypi.org/debian buster InRelease
    Hit:4 https://deb.nodesource.com/node_12.x buster InRelease
    Hit:5 https://deb.nodesource.com/node_14.x buster InRelease
    Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
    Hit:7 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 8
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:8080          0.0.0.0:*               LISTEN      119        19462      568/motion
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       18473      374/deCONZ
    tcp        0      0 0.0.0.0:8083            0.0.0.0:*               LISTEN      119        18490      568/motion
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20173      709/sshd
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          18483      388/cupsd
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       22385      1418/io.sonoff.0
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       17607      374/deCONZ
    tcp        0      0 192.168.178.53:9092     0.0.0.0:*               LISTEN      1001       28921      2139/io.nuki.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18204      736/iobroker.js-con
    tcp        0      0 0.0.0.0:3306            0.0.0.0:*               LISTEN      110        20247      764/mysqld
    tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      118        17803      717/redis-server 0.
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18345      1042/io.admin.1
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       25805      1789/io.web.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          20175      709/sshd
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       31564      3271/io.simple-api.
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          18482      388/cupsd
    tcp6       0      0 ::1:6379                :::*                    LISTEN      118        17804      717/redis-server 0.
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       24368      1753/io.shelly.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16243      698/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          17398      491/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       24971      1499/io.chromecast.
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16027      382/avahi-daemon: r
    udp        0      0 0.0.0.0:55070           0.0.0.0:*                           108        16029      382/avahi-daemon: r
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       17630      374/deCONZ
    udp6       0      0 :::546                  :::*                                0          16265      698/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        16028      382/avahi-daemon: r
    udp6       0      0 :::49038                :::*                                108        16030      382/avahi-daemon: r
    2023-08-17 14:20:07.253  - info: netatmo-crawler.0 (7697) Getting data for stationid:70:ee:50:29:08:fe
    2023-08-17 14:20:08.850  - info: netatmo-crawler.0 (7697) Getting data for stationid:70:ee:50:3f:34:04
    2023-08-17 14:20:09.919  - info: netatmo-crawler.0 (7697) Getting data for stationid:70:ee:50:52:e9:96
    2023-08-17 14:20:10.497  - info: javascript.0 (1115) script.js.common.Akustischer_Alarm____Steuerung_Haus._Alarmauslösung_Cams: Alarm durch Reolink
    2023-08-17 14:20:10.952  - info: netatmo-crawler.0 (7697) Getting data for stationid:70:ee:50:05:53:68
    2023-08-17 14:20:12.503  - info: netatmo-crawler.0 (7697) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2023-08-17 14:20:13.056  - info: host.raspi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-08-17 14:20:15.074  - info: javascript.0 (1115) script.js.common.Akustischer_Alarm____Steuerung_Haus._Alarmauslösung_Cams: Alarm durch Reolink
    2023-08-17 14:20:33.803  - info: vis.0 (8140) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.17.1, js-controller: 5.0.11
    2023-08-17 14:20:34.515  - info: vis.0 (8140) vis license is OK.
    2023-08-17 14:20:34.919  - info: sayit.0 (8113) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.sayit, node: v18.17.1, js-controller: 5.0.11
    2023-08-17 14:20:34.934  - info: sayit.0 (8113) Install process. Upload files and stop.
    2023-08-17 14:20:34.937  - info: sayit.0 (8113) Upload announce mp3 files
    2023-08-17 14:20:35.236  - info: sayit.0 (8113) stopping...
    2023-08-17 14:20:35.243  - info: sayit.0 (8113) terminating
    2023-08-17 14:20:35.287  - info: sayit.0 (8113) Terminated (NO_ERROR): Without reason
    2023-08-17 14:20:35.745  - info: sayit.0 (8113) terminating
    2023-08-17 14:20:35.831  - info: sayit.0 (8113) stopping...
    2023-08-17 14:20:36.803  - info: vis.0 (8140) Terminated (NO_ERROR): Without reason
    2023-08-17 14:20:41.997  - info: vis-google-fonts.0 (8334) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.vis-google-fonts, node: v18.17.1, js-controller: 5.0.11
    2023-08-17 14:20:42.567  - info: javascript.0 (1115) script.js.common.Akustischer_Alarm____Steuerung_Haus._Alarmauslösung_Cams: Alarm durch Reolink
    2023-08-17 14:20:42.796  - info: vis-google-fonts.0 (8334) Terminated (NO_ERROR): Without reason
    2023-08-17 14:20:46.080  - info: javascript.0 (1115) script.js.common.Akustischer_Alarm____Steuerung_Haus._Alarmauslösung_Cams: Alarm durch Reolink
    2023-08-17 14:20:54.716  - info: javascript.0 (1115) script.js.common.Akustischer_Alarm____Steuerung_Haus._Alarmauslösung_Cams: Alarm durch Reolink
    2023-08-17 14:21:06.846  - info: javascript.0 (1115) script.js.common.Akustischer_Alarm____Steuerung_Haus._Alarmauslösung_Cams: Alarm durch Reolink
    iob diag has finished.
    crunchipC Offline
    crunchipC Offline
    #72
    @brokeling sagte in Noch ein Zigbee Problem....:
    127.0.0.1:8081 0.0.0.0:* LISTEN 119 15504 393/motion
    keine Ahnung was bei dir da läuft, einmal so einmal so🤔
    • B brokeling
      @crunchip
      ich glaube ich habe kein motion...
      pi@raspi:~ $ sudo systemctl stop motioneye
      Failed to stop motioneye.service: Unit motioneye.service not loaded.
      pi@raspi:~ $ sudo systemctl disable motioneye
      Failed to disable unit: Unit file motioneye.service does not exist.
      #73
      @brokeling
      Der Service dürfte 'motion' heißen.
      Also
      sudo systemctl mask motion
      crunchipC B 2 Antworten Letzte Antwort
      • Ro75R Offline
        Ro75R Offline
        Ro75
        #74
        Also wenn es ein Backup vom ioBroker gäbe, wäre dann die Kiste neu aufsetzen nicht schneller?
        Ro75.
        • Ro75R Ro75
          Ro75.
          brokeling
          #75
          @ro75 said in Noch ein Zigbee Problem....:
          Ro75.
          Manno so schlecht ist doch mein System nicht, oder???
          Dachte immer das ist sauber.
          Ro75R 1 Antwort Letzte Antwort
            @brokeling
            Also
            crunchipC Offline
            crunchipC Offline
            #76
            @thomas-braun eingeschalten und gestartet wird aber eigentlich motioneye, somit bin ich von motioneye zum stoppen und ausschalten, ausgegangen
            • B brokeling
              Ro75.
              Ro75R Offline
              Ro75R Offline
              Ro75
              #77
              @brokeling motioneye, Ports, Beta, Hieroglyphen, nodejs, .......
                @brokeling
                Also
                brokeling
                schrieb am zuletzt editiert von brokeling
                #78
                @thomas-braun said in Noch ein Zigbee Problem....:
                @brokeling
                Also
                Admin läuft wieder :)!!!
                  #79
                  @crunchip
                  Der Server heißt aber 'motion'. Und der sitzt (bzw. saß) auf dem Port.
                  • B brokeling
                    @brokeling
                    Also
                    brokeling
                    #80
                    Zigbee macht noch Zicken.
                    2023-08-17 19:31:16.406  - info: host.raspi stopInstance system.adapter.zigbee.0 (force=false, process=true)
                    2023-08-17 19:31:16.412  - info: host.raspi stopInstance system.adapter.zigbee.0 send kill signal
                    2023-08-17 19:31:16.414  - info: zigbee.0 (2106) Got terminate signal TERMINATE_YOURSELF
                    2023-08-17 19:31:16.418  - info: zigbee.0 (2106) cleaned everything up...
                    2023-08-17 19:31:17.190  - info: zigbee.0 (2106) Zigbee: disabling joining new devices.
                    2023-08-17 19:31:17.225  - warn: zigbee.0 (2106) Failed to stop zigbee during startup
                    2023-08-17 19:31:17.226  - info: zigbee.0 (2106) terminating
                    2023-08-17 19:31:17.228  - info: zigbee.0 (2106) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-08-17 19:31:17.229  - info: zigbee.0 (2106) terminating
                    2023-08-17 19:31:17.294  - info: zigbee.0 (2106) debug devices set to []
                    2023-08-17 19:31:17.418  - info: host.raspi stopInstance system.adapter.zigbee.0 killing pid 2106
                    2023-08-17 19:31:17.968  - info: host.raspi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-08-17 19:31:19.710  - info: host.raspi instance system.adapter.zigbee.0 started with pid 15172
                    2023-08-17 19:31:25.073  - info: zigbee.0 (15172) starting. Version 1.8.23 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.17.1, js-controller: 5.0.11
                    2023-08-17 19:31:25.244  - info: zigbee.0 (15172) delete old Backup files. keep only last 10
                    2023-08-17 19:31:25.247  - info: zigbee.0 (15172) Starting Zigbee  npm ...
                    2023-08-17 19:31:25.995  - error: zigbee.0 (15172) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100GB8-if00'"
                    2023-08-17 19:31:25.996  - error: zigbee.0 (15172) Failed to start Zigbee
                    2023-08-17 19:31:25.997  - error: zigbee.0 (15172) Error herdsman start
                    2023-08-17 19:31:25.999  - info: zigbee.0 (15172) Installed Version: iobroker.zigbee@1.8.23
                    2023-08-17 19:31:35.999  - info: zigbee.0 (15172) Try to reconnect. 1 attempts left
                    2023-08-17 19:31:36.000  - info: zigbee.0 (15172) Starting Zigbee  npm ...
                    2023-08-17 19:31:36.030  - error: zigbee.0 (15172) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100GB8-if00'"
                    2023-08-17 19:31:36.032  - error: zigbee.0 (15172) Failed to start Zigbee
                    2023-08-17 19:31:36.034  - error: zigbee.0 (15172) Error herdsman start
                    2023-08-17 19:31:36.035  - info: zigbee.0 (15172) Installed Version: iobroker.zigbee@1.8.23
                    2023-08-17 19:32:05.512  - info: javascript.0 (1204)
                      @crunchip
                      crunchipC Offline
                      crunchipC Offline
                      #81
                      @thomas-braun sagte in Noch ein Zigbee Problem....:
                      auf dem Port
                      besser gesagt seine cam
                      • B brokeling
                        #82
                        @brokeling
                        find /dev/serial/by-id/ -maxdepth 1 -mindepth 1
                        sagt?
                          @brokeling
                          sagt?
                          brokeling
                          #83
                          pi@raspi:~ $ find /dev/serial/by-id/ -maxdepth 1 -mindepth 1
                          find: ‘/dev/serial/by-id/’: Datei oder Verzeichnis nicht gefunden
                          was ist jetzt mit dem serial port?
                          pi@raspi:~ $ ls -la /dev/serial/by-id/
                          ls: Zugriff auf '/dev/serial/by-id/' nicht möglich: Datei oder Verzeichnis nicht gefunden
                          • B brokeling
                            #84
                            @brokeling
                            sudo apt update
                            apt policy udev
                              @brokeling
                              sudo apt update
                              apt policy udev
                              brokeling
                              #85
                              pi@raspi:~ $ sudo apt update
                              OK:1 http://phoscon.de/apt/deconz bullseye InRelease
                              Holen:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15,0 kB]
                              OK:3 https://deb.nodesource.com/node_12.x bullseye InRelease
                              OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
                              OK:5 https://deb.nodesource.com/node_14.x bullseye InRelease
                              OK:6 https://deb.nodesource.com/node_16.x bullseye InRelease
                              OK:7 https://deb.nodesource.com/node_18.x bullseye InRelease
                              Es wurden 15,0 kB in 2 s geholt (7.010 B/s).
                              Alle Pakete sind aktuell.
                              pi@raspi:~ $ apt policy udev
                              udev:
                                Installiert:           247.3-7+rpi1+deb11u2
                                Installationskandidat: 247.3-7+rpi1+deb11u2
                                Versionstabelle:
                               *** 247.3-7+rpi1+deb11u2 500
                              • B brokeling
                                udev:
                                  Versionstabelle:
                                #86
                                @brokeling
                                Das ist der udev bug. Betrifft wohl immer noch die 32bit-Raspberry-Version, alles andere ist aktueller.
                                https://forum.iobroker.net/topic/65017/zigbee-conbee2-funktioniert-nach-update-nicht-mehr-udev
                                  @brokeling
                                  brokeling
                                  #87
                                  pi@raspi:/ $ sudo apt update
                                  Holen:2 http://deb.debian.org/debian bullseye-proposed-updates InRelease [54,0 kB]
                                  OK:3 http://archive.raspberrypi.org/debian bullseye InRelease
                                  OK:4 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                  OK:5 https://deb.nodesource.com/node_12.x bullseye InRelease
                                  OK:6 https://deb.nodesource.com/node_14.x bullseye InRelease
                                  OK:7 https://deb.nodesource.com/node_16.x bullseye InRelease
                                  OK:8 https://deb.nodesource.com/node_18.x bullseye InRelease
                                  Fehl:2 http://deb.debian.org/debian bullseye-proposed-updates InRelease
                                    Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
                                  W: GPG-Fehler: http://deb.debian.org/debian bullseye-proposed-updates InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
                                  E: Das Depot »http://deb.debian.org/debian bullseye-proposed-updates InRelease« ist nicht signiert.
                                  N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
                                  N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
                                  kann ich das übergehen?
                                  • B brokeling
                                    #88
                                    Nein. Der Schlüssel muss rein.
                                      brokeling
                                      #89
                                      wie kann ich ihn dazu bringen?
                                      • B brokeling
                                        #90
                                        @brokeling
                                        Steht wenn ich mich recht entsinne im HowTo drin. Ggfls aber mit einer andren key-ID. Musste mal schauen.
                                          @brokeling
                                          brokeling
                                          #91
                                          ja das stimmt.
                                          Aber da komm ich nicht mit klar. Bei den Lösungen kommen auch noch Fehlermeldungen...
                                          Ich glaub ich spiele ein Backup zurück.
                                          Und dann lass ich das System erstmal, wenn Zigbee mit dem Controller-update läuft!
