Test Adapter eufy Home Robovac
@tombox habe den Adapter mal neugestartet
euhome.0 6654 2023-02-10 11:01:14.675 info Device: Sauger (bfee2150a08c0ff746anta) euhome.0 6654 2023-02-10 11:01:14.675 info Found 1 devices euhome.0 6654 2023-02-10 11:00:52.793 info Login successful euhome.0 6654 2023-02-10 11:00:51.864 info Login to Eufy Home euhome.0 6654 2023-02-10 11:00:51.844 info starting. Version 0.0.3 (non-npm: TA2k/ioBroker.euhome#f94964ce32a8d0ef5e388462990840bafa67cc27) in /opt/iobroker/node_modules/iobroker.euhome, node: v14.20.0, js-controller: 4.0.23 host.iobroker-iobroker1 2023-02-10 11:00:50.729 info instance system.adapter.euhome.0 started with pid 6654 host.iobroker-iobroker1 2023-02-10 11:00:50.666 info "system.adapter.euhome.0" enabled host.iobroker-iobroker1 2023-02-10 11:00:49.655 info instance system.adapter.euhome.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) host.iobroker-iobroker1 2023-02-10 11:00:49.158 info stopInstance system.adapter.euhome.0 send kill signal euhome.0 6331 2023-02-10 11:00:49.120 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason euhome.0 6331 2023-02-10 11:00:49.120 info terminating euhome.0 6331 2023-02-10 11:00:49.118 info Got terminate signal TERMINATE_YOURSELF host.iobroker-iobroker1 2023-02-10 11:00:49.114 info stopInstance system.adapter.euhome.0 (force=false, process=true)wenn ich dann nochaml den status ändere von work_mode dann kommt das hier:
euhome.0 6654 2023-02-10 11:01:15.335 error No IP found for bfee2150a08c0ff746anta cannot send command euhome.0 6654 2023-02-10 11:01:15.205 error Failed to find to device please close the app or check your network. Please allow port 6667 and 6666 via UDP from the device IP to 255.255.255.255. Error: bind EADDRINUSE 0.0.0.0:6666 euhome.0 6654 2023-02-10 11:01:15.204 error Error All! Error: bind EADDRINUSE 0.0.0.0:6666 -
@emptykai Irgendwas blockiert port 6666 hast du den tuya adapter am laufen? Vielleicht mal iobroker neustarten
@emptykai sagte in Test Adapter eufy Home Robovac:
Die ports sind frei
sudo netstat -tulpenanschauen.
Alternativsudo ss -tulpe -
Die ports sind frei
Alternativsudo ss -tulpe@thomas-braun was bewirkt das?
was bewirkt das?
Dein Computer explodiert und die Katze stirbt...
Es werden die verwendeten Sockets / Ports aufgelistet.
Hey , das ist ja ganz hervorragend , dass du diesen Adapter in Angriff genommen hast. War einwandfrei zu installieren und hat meinen Eufy auch tadellos gefunden.
Ich scheine aber das gleiche Problem mit dem Tuya Adapter zu haben wenn der auch läuft.
Gibt es da einen Workaround o.Ä. um die Port Problematik zu beheben oder kannst du eine Möglichkeit schaffen den Port zu wechseln ?! Vielen Dank für die Arbeit
Gruß mad
Hi ich habe ein neuen Adapter für eufy home und Robovac geschrieben
Aktueller status:
euhome.0.id.dpsZum Installieren:
https://github.com/TA2k/ioBroker.euhomeFür die aktuelle Version
bitte das latest Repo auswählen:
Loginablauf:
Die e-Home App Zugangsdaten eingebenSteuerung
euhome.0.id.dps
euhome.0.id.dps.WORK_MODE = Auto um zu startenRaumreinigung
euhome.0.id.remote.sendCommand
damit kann man dann{ "method": "selectRoomsClean", "data": { "roomIds": [ 2 ], "cleanTimes": 1 } }Zonenreinigung
{"method":"selectZonesClean","data":{"zones":[{"x0":-1130,"y0":646,"x1":-830,"y1":646,"x2":-830,"y2":346,"x3":-1130,"y3":346,"cleanTimes":1,"type":"sweep"}]}}Spotreinigung
{"method":"goto","data":{"cleanTimes":1,"target":"spot","x":-179,"y":36}}Die Verbindung wird lokal aufgebaut und ist bisher ungetestet. Ein log nach der Installation wäre hier hilfreich
@tombox Guten Abend, vielen Dank für deinen Adapter! Ich habe diesen Adapter inzwischen seit einigen Wochen in Nutzung und bin super zufrieden. Leider habe ich seit etwa 2-3 Tagen erhebliche Probleme mit dem Adapter. Ich kriege fast minütlich im Protokoll den Error:
2023-07-17 20:43:14.889 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET 2023-07-17 20:43:44.944 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET 2023-07-17 20:44:14.960 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET 2023-07-17 20:44:44.986 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET 2023-07-17 20:45:15.549 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET 2023-07-17 20:45:45.760 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET 2023-07-17 20:46:15.835 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET 2023-07-17 20:46:45.890 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET 2023-07-17 20:47:16.671 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET 2023-07-17 20:47:46.963 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET 2023-07-17 20:48:17.133 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET 2023-07-17 20:48:47.194 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET 2023-07-17 20:49:17.252 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET 2023-07-17 20:49:47.270 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET 2023-07-17 20:50:17.289 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET 2023-07-17 20:50:47.307 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET 2023-07-17 20:51:17.339 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET 2023-07-17 20:51:47.359 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET 2023-07-17 20:52:17.374 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET 2023-07-17 20:52:47.401 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET 2023-07-17 20:53:17.422 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESETIst das Problem bekannt und gibt es dazu Abhilfe?
@theray2k sagte in Test Adapter eufy Home Robovac:
und was hast Du an Deinem System "seit etwa 2-3 Tagen" geändert?
@djmarc75 Das einzige was geändert wurde, dass ein Script den Saugrobotor 1x täglich startet sobald das Haus verlassen wurde. Ich hatte das Problem aber auch zwischendurch schon ein paar mal bevor ich etwas hinzugefügt habe, aber nicht in dem Ausmaß wie inzwischen. Sonst hatte ich dieses Problem vereinzelnd im Log stehen. Ein Neustart des Adapters hat dann aber Abhilfe für etwa 1 Woche geschaffen. Nur ist dieses Problem inzwischen etwa jeden morgen, was natürlich relativ nervenaufreibend ist, wenn jeden morgen der Adapter neu gestartet werden muss. Zum Abgleich füge ich einfach mal das Script hinzu, welches über Blockly hinzugefügt wurde:
var T_C3_A4gliche_Reinigung, heute_gereinigt, Kurzes_verlassen; T_C3_A4gliche_Reinigung = schedule('{"time":{"exactTime":true,"start":"23:59"},"period":{"days":1}}', async () => { heute_gereinigt = false; }); on({ id: '0_userdata.0.Alarmanlage_S/US' /* Alarmanlage S/US */, change: 'ne' }, async (obj) => { let value = obj.state.val; let oldValue = obj.oldState.val; if (getState('0_userdata.0.Alarmanlage_S/US').val == true && heute_gereinigt == false) { Kurzes_verlassen = setTimeout(async () => { Kurzes_verlassen = null; heute_gereinigt = true; setStateDelayed('0_userdata.0.Robovac-State', true, true, parseInt(((0) || '').toString(), 10), false); (() => { if (Kurzes_verlassen) { clearTimeout(Kurzes_verlassen); Kurzes_verlassen = null; }})(); }, 900000); } else { (() => { if (Kurzes_verlassen) { clearTimeout(Kurzes_verlassen); Kurzes_verlassen = null; }})(); setStateDelayed('0_userdata.0.Robovac-State', false, true, parseInt(((0) || '').toString(), 10), false); } });``` -
Hi
Erstmal vielen Dank an den Adapter.
Wollte mal fragen ob es eine lösung wegen der tuya und eufy port schwierigkeiten gibt ? wenn ich tuya deaktiviere dann bekommt eufy die ports wenn ich tuya dann wieder aktiviere sind beide tot ;)Danke im voraus
@smilie108 Schwierig sehe jetzt keine Möglichkeit
Mahlzeit @tombox
Also die Raumreinigung haut gut hin, und ich hab mir meine Vis so gebaut das mir taugt, starker Job mit dem Adapter, danke dir!
Aber eine Frage hät ich noch:
Wenn ich in der App einen (oder merhere) Raum starte und auf CLeanTimes 2x stelle, fährt der Eufy den raum im Rautenmuster ab #
Also erst einmal längs, und beim zweiten Durchgang quer.
In der sauberkeit merkt man das enorm - zumindest bei uns.
Wenn ich per IOB/deinen Adapter einen Raum auf 2x stelle, fährt er nur 2x längs (oder quer, wie mans sehen mag).
Siehst du ne Möglichkeit da iwie ran zu kommen?
