  4. ...nicht in offiziellem Repo
  5. Test Adapter eufy Home Robovac
    6.4k
Geplant Angeheftet Gesperrt Verschoben ...nicht in offiziellem Repo
151 Beiträge 29 Kommentatoren 40.9k Aufrufe 31 Beobachtet
  • E emptykai
    @tombox habe den Adapter mal neugestartet
    euhome.0
    	6654	2023-02-10 11:01:14.675	info	Device: Sauger (bfee2150a08c0ff746anta)
    euhome.0
    	6654	2023-02-10 11:01:14.675	info	Found 1 devices
    euhome.0
    	6654	2023-02-10 11:00:52.793	info	Login successful
    euhome.0
    	6654	2023-02-10 11:00:51.864	info	Login to Eufy Home
    euhome.0
    	6654	2023-02-10 11:00:51.844	info	starting. Version 0.0.3 (non-npm: TA2k/ioBroker.euhome#f94964ce32a8d0ef5e388462990840bafa67cc27) in /opt/iobroker/node_modules/iobroker.euhome, node: v14.20.0, js-controller: 4.0.23
    host.iobroker-iobroker1
    		2023-02-10 11:00:50.729	info	instance system.adapter.euhome.0 started with pid 6654
    		2023-02-10 11:00:50.666	info	"system.adapter.euhome.0" enabled
    		2023-02-10 11:00:49.655	info	instance system.adapter.euhome.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    		2023-02-10 11:00:49.158	info	stopInstance system.adapter.euhome.0 send kill signal
    euhome.0
    	6331	2023-02-10 11:00:49.120	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    euhome.0
    	6331	2023-02-10 11:00:49.120	info	terminating
    euhome.0
    	6331	2023-02-10 11:00:49.118	info	Got terminate signal TERMINATE_YOURSELF
    		2023-02-10 11:00:49.114	info	stopInstance system.adapter.euhome.0 (force=false, process=true)
    wenn ich dann nochaml den status ändere von work_mode dann kommt das hier:
    euhome.0
    	6654	2023-02-10 11:01:15.335	error	No IP found for bfee2150a08c0ff746anta cannot send command
    euhome.0
    	6654	2023-02-10 11:01:15.205	error	Failed to find to device please close the app or check your network. Please allow port 6667 and 6666 via UDP from the device IP to 255.255.255.255. Error: bind EADDRINUSE 0.0.0.0:6666
    euhome.0
    	6654	2023-02-10 11:01:15.204	error	Error All! Error: bind EADDRINUSE 0.0.0.0:6666
    tombox
    @emptykai Irgendwas blockiert port 6666 hast du den tuya adapter am laufen? Vielleicht mal iobroker neustarten
    E 2 Antworten Letzte Antwort
    • T tombox
      emptykai
      @tombox habs gesehen gerade.. Ja habe Tuya laufen - aber die ports sind freigeschaltet .. ich starte mal neu und schaue dann nochaml
      • T tombox
        emptykai
        @tombox trotz neustart, gleicher Port Fehler.. wodran kann das liegen?
        Die ports sind frei
        Thomas BraunT T 2 Antworten Letzte Antwort
        • E emptykai
          Die ports sind frei
          @emptykai sagte in Test Adapter eufy Home Robovac:
          Die ports sind frei
          sudo netstat -tulpen
          anschauen.
          Alternativ
          sudo ss -tulpe
          E 1 Antwort Letzte Antwort
          • E emptykai
            Die ports sind frei
            tombox
            @emptykai Mal den tuya adapter abschalten und euhome neustarten ob es dann geht
              Die ports sind frei
              anschauen.
              Alternativ
              sudo ss -tulpe
              emptykai
              #66
              @thomas-braun was bewirkt das?
              • T tombox
                emptykai
                schrieb am zuletzt editiert von emptykai
                #67
                @tombox Hey, ja dann funktioniert es (Y) - aber stoppen kann ich nicht mehr?
                • E emptykai
                  #68
                  was bewirkt das?
                  Dein Computer explodiert und die Katze stirbt...
                  Es werden die verwendeten Sockets / Ports aufgelistet.
                  • E emptykai
                    tombox
                    #69
                    @emptykai Ok ich werde noch einbauen das man manuell eine IP setzen kann
                    • T tombox
                      emptykai
                      #70
                      @tombox okay, aber aktuell kann ich den sauger nicht stoppen, korrekt?
                      • E emptykai
                        tombox
                        #71
                        @emptykai Entweder GO_HOME oder PLAYPAUSE
                        • T tombox
                          emptykai
                          #72
                          @tombox klasse, klappt :-)
                            madman1602
                            #73
                            Hey , das ist ja ganz hervorragend , dass du diesen Adapter in Angriff genommen hast. War einwandfrei zu installieren und hat meinen Eufy auch tadellos gefunden.
                            Ich scheine aber das gleiche Problem mit dem Tuya Adapter zu haben wenn der auch läuft.
                            Gibt es da einen Workaround o.Ä. um die Port Problematik zu beheben oder kannst du eine Möglichkeit schaffen den Port zu wechseln ?! Vielen Dank für die Arbeit 👍
                            Gruß mad
                            • T tombox
                              Hi ich habe ein neuen Adapter für eufy home und Robovac geschrieben
                              Aktueller status:
                              euhome.0.id.dps
                              Zum Installieren:
                              https://github.com/TA2k/ioBroker.euhome
                              Loginablauf:
                              Die e-Home App Zugangsdaten eingeben
                              Steuerung
                              euhome.0.id.dps
                              euhome.0.id.dps.WORK_MODE = Auto um zu starten
                              Raumreinigung
                              euhome.0.id.remote.sendCommand
                              damit kann man dann
                                "method": "selectRoomsClean",
                                "data": {
                                  "roomIds": [
                                  "cleanTimes": 1
                              Zonenreinigung
                              {"method":"selectZonesClean","data":{"zones":[{"x0":-1130,"y0":646,"x1":-830,"y1":646,"x2":-830,"y2":346,"x3":-1130,"y3":346,"cleanTimes":1,"type":"sweep"}]}}
                              Spotreinigung
                              {"method":"goto","data":{"cleanTimes":1,"target":"spot","x":-179,"y":36}}
                              Die Verbindung wird lokal aufgebaut und ist bisher ungetestet. Ein log nach der Installation wäre hier hilfreich
                              theRay2K
                              #74
                              @tombox Guten Abend, vielen Dank für deinen Adapter! Ich habe diesen Adapter inzwischen seit einigen Wochen in Nutzung und bin super zufrieden. Leider habe ich seit etwa 2-3 Tagen erhebliche Probleme mit dem Adapter. Ich kriege fast minütlich im Protokoll den Error:
                              2023-07-17 20:43:14.889 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                              2023-07-17 20:43:44.944 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                              2023-07-17 20:44:14.960 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                              2023-07-17 20:44:44.986 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                              2023-07-17 20:45:15.549 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                              2023-07-17 20:45:45.760 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                              2023-07-17 20:46:15.835 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                              2023-07-17 20:46:45.890 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                              2023-07-17 20:47:16.671 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                              2023-07-17 20:47:46.963 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                              2023-07-17 20:48:17.133 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                              2023-07-17 20:48:47.194 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                              2023-07-17 20:49:17.252 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                              2023-07-17 20:49:47.270 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                              2023-07-17 20:50:17.289 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                              2023-07-17 20:50:47.307 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                              2023-07-17 20:51:17.339 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                              2023-07-17 20:51:47.359 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                              2023-07-17 20:52:17.374 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                              2023-07-17 20:52:47.401 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                              2023-07-17 20:53:17.422 - error: euhome.0 (694904) Error! Error: Error from socket: read ECONNRESET
                              Ist das Problem bekannt und gibt es dazu Abhilfe?
                              • T theRay2K
                                DJMarc75D Offline
                                DJMarc75D Offline
                                DJMarc75
                                #75
                                @theray2k sagte in Test Adapter eufy Home Robovac:
                                und was hast Du an Deinem System "seit etwa 2-3 Tagen" geändert?
                                Lehrling seit 1975 !!!
                                • DJMarc75D DJMarc75
                                  theRay2K
                                  #76
                                  @djmarc75 Das einzige was geändert wurde, dass ein Script den Saugrobotor 1x täglich startet sobald das Haus verlassen wurde. Ich hatte das Problem aber auch zwischendurch schon ein paar mal bevor ich etwas hinzugefügt habe, aber nicht in dem Ausmaß wie inzwischen. Sonst hatte ich dieses Problem vereinzelnd im Log stehen. Ein Neustart des Adapters hat dann aber Abhilfe für etwa 1 Woche geschaffen. Nur ist dieses Problem inzwischen etwa jeden morgen, was natürlich relativ nervenaufreibend ist, wenn jeden morgen der Adapter neu gestartet werden muss. Zum Abgleich füge ich einfach mal das Script hinzu, welches über Blockly hinzugefügt wurde:
                                  var T_C3_A4gliche_Reinigung, heute_gereinigt, Kurzes_verlassen;
                                  T_C3_A4gliche_Reinigung = schedule('{"time":{"exactTime":true,"start":"23:59"},"period":{"days":1}}', async () => {
                                    heute_gereinigt = false;
                                  on({ id: '0_userdata.0.Alarmanlage_S/US' /* Alarmanlage S/US */, change: 'ne'  }, async (obj) => {
                                    let value = obj.state.val;
                                    let oldValue = obj.oldState.val;
                                    if (getState('0_userdata.0.Alarmanlage_S/US').val == true && heute_gereinigt == false) {
                                      Kurzes_verlassen = setTimeout(async () => {
                                        Kurzes_verlassen = null;
                                        heute_gereinigt = true;
                                        setStateDelayed('0_userdata.0.Robovac-State', true, true, parseInt(((0) || '').toString(), 10), false);
                                        (() => { if (Kurzes_verlassen) { clearTimeout(Kurzes_verlassen); Kurzes_verlassen = null; }})();
                                      }, 900000);
                                    } else {
                                      setStateDelayed('0_userdata.0.Robovac-State', false, true, parseInt(((0) || '').toString(), 10), false);
                                  • C Offline
                                    Chris982
                                    #77
                                    Guten Morgen,
                                    hat schon jemand den Eufy RoboVac X9 Pro am laufen? Habe ihn zwar in Euhome drin, finde keinen Datenpunkt um die Reinigung starten zu könnnen.
                                    • Smilie108S Offline
                                      Smilie108S Offline
                                      Smilie108
                                      #78
                                      Hi
                                      Erstmal vielen Dank an den Adapter.
                                      Wollte mal fragen ob es eine lösung wegen der tuya und eufy port schwierigkeiten gibt ? wenn ich tuya deaktiviere dann bekommt eufy die ports wenn ich tuya dann wieder aktiviere sind beide tot ;)
                                      Danke im voraus
                                      • Smilie108S Smilie108
                                        Hi
                                        Danke im voraus
                                        tombox
                                        #79
                                        @smilie108 Schwierig sehe jetzt keine Möglichkeit
                                          amiethaner
                                          #80
                                          Mahlzeit @tombox
                                          Also die Raumreinigung haut gut hin, und ich hab mir meine Vis so gebaut das mir taugt, starker Job mit dem Adapter, danke dir!
                                          Aber eine Frage hät ich noch:
                                          Wenn ich in der App einen (oder merhere) Raum starte und auf CLeanTimes 2x stelle, fährt der Eufy den raum im Rautenmuster ab #
                                          Also erst einmal längs, und beim zweiten Durchgang quer.
                                          In der sauberkeit merkt man das enorm - zumindest bei uns.
                                          Wenn ich per IOB/deinen Adapter einen Raum auf 2x stelle, fährt er nur 2x längs (oder quer, wie mans sehen mag).
                                          Siehst du ne Möglichkeit da iwie ran zu kommen?
                                          T Smilie108S 2 Antworten Letzte Antwort
