  4. Test Adapter vis 2.0 (Alpha)
780 Beiträge 108 Kommentatoren 345.4k Aufrufe 140 Beobachtet
  • sigi234S sigi234
    @apollon77
    Hallo, beim Materialdesign Widget Line History Chart werden keine Daten mehr angezeigt. Hat das noch wer?
    web.0
    2022-11-28 08:25:16.931	error	15 - at sentryWrapped (http://localhost:8082/vis-2-beta/widgets/materialdesign/lib/raw/sentry/bundle.min.js:2:53837)
    web.0
    2022-11-28 08:25:16.929	error	14 - at http://localhost:8082/vis-2-beta/static/js/720.4ad6ca16.chunk.js:17:458
    web.0
    2022-11-28 08:25:16.929	error	13 - at Qe.renderWidget (http://localhost:8082/vis-2-beta/static/js/720.4ad6ca16.chunk.js:16:68581)
    web.0
    2022-11-28 08:25:16.928	error	12 - at e.view.e.template (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1401:47)
    web.0
    2022-11-28 08:25:16.927	error	11 - at Function.renderAs (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1465:39)
    web.0
    2022-11-28 08:25:16.926	error	10 - at Function.renderTo (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1449:63)
    web.0
    2022-11-28 08:25:16.925	error	9 - at r (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1370:22)
    web.0
    2022-11-28 08:25:16.925	error	8 - at Function.frag (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1405:22)
    web.0
    2022-11-28 08:25:16.925	error	7 - at Function.hookup (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1418:19)
    web.0
    2022-11-28 08:25:16.924	error	6 - at a.each (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:343:211)
    web.0
    2022-11-28 08:25:16.924	error	5 - at HTMLDivElement.<anonymous> (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1419:98)
    web.0
    2022-11-28 08:25:16.923	error	4 - at http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1727:17
    web.0
    2022-11-28 08:25:16.923	error	3 - at a.each (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:343:211)
    web.0
    2022-11-28 08:25:16.922	error	2 - at Function.<anonymous> (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1728:17)
    web.0
    2022-11-28 08:25:16.922	error	1 - at Object.eval (tplMfdSocket.js:54:65)
    web.0
    2022-11-28 08:25:16.921	error	0 - TypeError: vis.preloadImages is not a functionTypeError: vis.preloadImages is not a function
    web.0
    2022-11-28 08:25:16.920	error	can't render tplMfdSocket w00935 on "Yamaha_RX-V481":
    #81
    @sigi234 GitHub issue anlegen - ich sehe in jedem Fall vom Widget in Sentry fehler die denke damit was zu tun haben
    • apollon77A apollon77
      sigi234S Online
      sigi234S Online
      sigi234
      #82
      @apollon77 sagte in Test Adapter vis 2.0 (Alpha):
      Angelegt:
      https://github.com/ioBroker/ioBroker.vis/issues/581
      Immer Daten sichern!
      • skvarelS Offline
        skvarelS Offline
        skvarel
        #83
        Wir schauen uns das die Tage an.
        Die icontwo Icons werden angezeigt, die inventwo Widgets leider (noch) nicht.
        #TeamInventwo
        Unsere Adapter:
        • skvarelS Offline
          skvarelS Offline
          skvarel
          schrieb am zuletzt editiert von skvarel
          #84
          inventwo scheint zu funktionieren. Widgest werden angezeigt und lassen sich in der Runtime auch bedienen.
          #TeamInventwo
          Unsere Adapter:
          apollon77A crunchipC 2 Antworten Letzte Antwort
          • skvarelS Offline
            skvarelS Offline
            skvarel
            #85
            Das Binding funktioniert allerdings in der Runtime nicht. Im Editor sieht es gut aus.
            #TeamInventwo
            Unsere Adapter:
            • skvarelS skvarel
              #86
              @skvarel Thank you for your fast check!!
              • skvarelS skvarel
                #87
                @skvarel Ich glaube zu Binding in Runtime gabs schonmal ein issue? Wenn nicht bitte eins anlegen
                skvarelS 1 Antwort Letzte Antwort
                • skvarelS skvarel
                  crunchipC Abwesend
                  crunchipC Abwesend
                  #88
                  @skvarel sagte in Test Adapter vis 2.0 (Alpha):
                  vis-inventwo
                  Multi
                  Switch - State/Button - Navigation - Background
                  funktioniert das View in Popup (navigieren zu einer anderen View) nicht, es passiert gar nichts beim betätigen
                  skvarelS amg_666A 3 Antworten Letzte Antwort
                    vis-inventwo
                    Multi
                    skvarelS Offline
                    skvarelS Offline
                    skvarel
                    #89
                    @crunchip .. PopUp funktioniert wirklich nicht, sehe ich gerade! Alle anderen Widget laufen hier sehr gut.
                    Ein paar Schönheitsfehler in den Beschreibungen und Übersetzungsfehler in den Einstellungen sind auf jeden Fall noch zu beheben
                    Meine sehr aufwendige VIS mit rund 2.000 inventwo Widgets (35 Views mit je ca. 60 Widgets) läuft soweit sehr gut mit dem vis2 Adapter.
                    #TeamInventwo
                    Unsere Adapter:
                      skvarelS Offline
                      skvarelS Offline
                      skvarel
                      #90
                      @apollon77 ..ja, es gibt mehrere Issues zum Thema Binding.
                      #TeamInventwo
                      Unsere Adapter:
                        vis-inventwo
                        Multi
                        amg_666A Offline
                        amg_666A Offline
                        amg_666
                        #91
                        Nur ne Kleinigkeit, links werden unter "Palette" die installierten widgets dargestellt. Wenn ich das Fenster zuklappe habe ich oben ein Palettensymbol zum Wiederöffnen, Mouseover zeigt den Text "Palette"
                        Rechts stehen unter "Attribute", die Attribute des gewählten widgets, wenn ich das Fenster zuklappe dann steht da ein Listensymbol, mouseover zeigt auch den Text "Palette", hier wäre "Attribute" sinnvoller.
                        Dann noch etwas was mir aufgefallen ist: Wenn ich links "Palette" zuklappe dann wird bei mir auch die aktuelle View geschlossen (??)
                        • amg_666A amg_666
                          #92
                          @amg_666 GitHub issue am besten mit nem Screenshot der das "zeigt" :-) Danke
                            vis-inventwo
                            Multi
                            skvarelS Offline
                            skvarelS Offline
                            skvarel
                            #93
                            @crunchip .. wir werden uns unseren Widget Adapter aber noch genauer angucken und dann überarbeiten. Das wird aber keine Hau-Ruck-Aktion. Erstmal muss sichergestellt sein, das die 'Fehler' an unserem Adapter liegen und nicht ggf. an dem vis2 Adapter.
                            Ich habe gerade nur erstmal den Adapter installiert und meine VIS durchgeguckt. Den Rest muss ich eh mit @jkvarel besprechen.
                            #TeamInventwo
                            Unsere Adapter:
                            • skvarelS skvarel
                              crunchipC Abwesend
                              crunchipC Abwesend
                              #94
                              @skvarel ich wollte es ja nur anmerken, bzw hatte es in meinem issue zu vis2 erwähnt.
                              hab auch erst gestern vis2 installiert und schnell mal grob durchgeblättert/getestet.
                              • apollon77A Offline
                                #95
                                Passend zum Thema ;-)) https://m.youtube.com/watch?v=zBFCmcCidhA
                                  denjo
                                  #96
                                  Hab jetzt zum testen alles eingerichtet und finde das es irgendwie langsamer läuft wie das alte vis, kann das sein?
                                  • D denjo
                                    #97
                                    @denjo Hmm .... <ironie>Heute ists irgendwie kälter in der Wohnung als gestern ...</ironie>
                                    Kannst Du deine Aussage vllt ein klein bisschen weiter mit Details ausschmücken? ;-)
                                      denjo
                                      #98
                                      @apollon77 die Seite baut sich langsamer auf wie im alten vis finde ich
                                      apollon77A FeuersturmF 2 Antworten Letzte Antwort
                                      • D denjo
                                        #99
                                        @denjo Sorry, aber fühlt sich gerade wie aus der Nase ziehen an ...
                                        Editor oder Runtime? Was genau fühlt sich "langsamer" an? Mal gemessen mit Stoppuhr oder nur gefühlt? Welcher Browser? Mal andere gecheckt? ... ... ... ... ...
                                          denjo
                                          #100
                                          @apollon77 runtime, ich habe zwei Bildschirme und hatte vis und vis2 offen und vis war schneller im Aufbau. Es war ja erst mal nur eine Frage ob das noch jemand hat oder bestätigen kann.
