  • Weihnachtsangebot 2025! 🎄
    2.1k
lovelace uinspanelsonoff
  • MichaelFM MichaelF
    @armilar said in SONOFF NSPanel mit Lovelace UI:
    @tt-tom
    werfe mal alle Dateien weg:
    dann die autoexec.be neu anlegen mit diesem Inhalt:
    https://raw.githubusercontent.com/joBr99/nspanel-lovelace-ui/main/tasmota/autoexec.be
    dann Tasmota neustarten
    und erneut
    FlashNextion http://nspanel.pky.eu/lovelace-ui/github/nspanel-v4.3.1.tft
    Gemacht :
    10:59:21.111 CMD: FlashNextion http://nspanel.pky.eu/lovelace-ui/github/nspanel-v4.3.1.tft
    10:59:21.126 MQT: stat/tasmota_C82F70/RESULT = {"FlashNextion":"Done"}
    10:59:21.167 FLH: host: nspanel.pky.eu, port: 80, get: /lovelace-ui/github/nspanel-v4.3.1.tft
    10:59:23.198 FLH: Something has gone wrong flashing display firmware [bytes('55BB1F006576656E742C736C656570526561636865642C63617264456E746974...')]
    10:59:23.244 MQT: stat/tasmota_C82F70/STATUS = {"Status":{"Module":0,"DeviceName":"NSPanel","FriendlyName":["Panel1",""],"Topic":"tasmota_C82F70","ButtonTopic":"0","Power":0,"PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":0,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0,"StatusRetain":0}}
    10:59:23.284 MQT: stat/tasmota_C82F70/STATUS1 = {"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://ota.tasmota.com/tasmota32/release/tasmota32-nspanel.bin","RestartReason":"Software reset CPU","Uptime":"0T00:00:28","StartupUTC":"2023-09-24T09:58:55","Sleep":0,"CfgHolder":4617,"BootCount":95,"BCResetTime":"2022-07-07T18:59:33","SaveCount":186}}
    10:59:23.326 MQT: stat/tasmota_C82F70/STATUS2 = {"StatusFWR":{"Version":"13.1.0(nspanel)","BuildDateTime":"2023-08-15T08:01:15","Core":"2_0_11","SDK":"4.4.5.230722","CpuFrequency":160,"Hardware":"ESP32-D0WD-V3 rev.3","CR":"450/699"}}
    10:59:23.345 MQT: stat/tasmota_C82F70/STATUS3 = {"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":0,"SysLog":0,"LogHost":"192.168.178.69","LogPort":514,"SSId":["WLAN 7270",""],"TelePeriod":300,"Resolution":"558180C0","SetOption":["00008009","0505C80001000600003C5A0A192800000000","00800080","00006000","00004001","00000001"]}}
    10:59:23.385 MQT: stat/tasmota_C82F70/STATUS4 = {"StatusMEM":{"ProgramSize":1870,"Free":1009,"Heap":73,"StackLowMark":3,"PsrMax":0,"PsrFree":0,"ProgramFlashSize":4096,"FlashSize":4096,"FlashChipId":"16405E","FlashFrequency":40,"FlashMode":"DIO","Features":["00000809","9F9AD7DF","0015A001","B7F7BFCF","05DA9BC4","E0360DC7","480840D2","20200000","D4BC482D","010A80B1"],"Drivers":"1,2,3,4,5,7,8,9,10,11,12,14,16,17,20,21,24,26,27,29,34,35,38,50,52,59,60,62,63,66,67,68,82,86,87,88","Sensors":"1,2,3,5,6,7,8,9,10,11,12,13,14,15,17,18,19,20,21,22,26,31,34,37,39,40,42,43,45,51,52,55,56,58,59,64,66,67,74,85,92,95,98,103,105,109,127","I2CDriver":"7,8,9,10,11,12,13,14,15,17,18,20,24,29,31,36,41,42,44,46,48,58,62,65,69,76,77,82"}}
    10:59:23.462 MQT: stat/tasmota_C82F70/STATUS5 = {"StatusNET":{"Hostname":"tasmota-C82F70-3952","IPAddress":"192.168.178.57","Gateway":"192.168.178.1","Subnetmask":"255.255.255.0","DNSServer1":"253.0.0.0","DNSServer2":"32.3.0.223","Mac":"7C:87:CE:C8:2F:70","IP6Global":"2003:df:373f:e00:7e87:ceff:fec8:2f70","IP6Local":"fe80::7e87:ceff:fec8:2f70","Ethernet":{"Hostname":"","IPAddress":"0.0.0.0","Gateway":"0.0.0.0","Subnetmask":"0.0.0.0","DNSServer1":"253.0.0.0","DNSServer2":"32.3.0.223","Mac":"00:00:00:00:00:00","IP6Global":"","IP6Local":""},"Webserver":2,"HTTP_API":1,"WifiConfig":4,"WifiPower":17.0}}
    10:59:23.528 MQT: stat/tasmota_C82F70/STATUS6 = {"StatusMQT":{"MqttHost":"192.168.178.69","MqttPort":1886,"MqttClientMask":"NS_Panel1","MqttClient":"NS_Panel1","MqttUser":"Mikeldk","MqttCount":1,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30,"SOCKET_TIMEOUT":4}}
    10:59:23.557 MQT: stat/tasmota_C82F70/STATUS7 = {"StatusTIM":{"UTC":"2023-09-24T09:59:23","Local":"2023-09-24T10:59:23","StartDST":"2023-03-26T02:00:00","EndDST":"2023-10-29T03:00:00","Timezone":"+01:00","Sunrise":"06:39","Sunset":"18:44"}}
    10:59:23.582 MQT: stat/tasmota_C82F70/STATUS10 = {"StatusSNS":{"Time":"2023-09-24T10:59:23","ANALOG":{"Temperature1":26.6},"ESP32":{"Temperature":56.1},"TempUnit":"C"}}
    10:59:23.607 MQT: stat/tasmota_C82F70/STATUS11 = {"StatusSTS":{"Time":"2023-09-24T10:59:23","Uptime":"0T00:00:28","UptimeSec":28,"Heap":70,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":910,"MqttCount":1,"Berry":{"HeapUsed":33,"Objects":452},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"WLAN 7270","BSSId":"38:10:D5:13:AB:0E","Channel":1,"Mode":"11n","RSSI":58,"Signal":-71,"LinkCount":1,"Downtime":"0T00:00:02"}}}
    10:59:23.796 MQT: stat/tasmota_C82F70/RESULT = {"CustomSend":"Done"}
    10:59:23.862 FLH: Send (High Speed) flash start
    10:59:24.214 BRY: Exception> 'type_error' - unsupported operand type(s) for <: 'nil' and 'int'
    Kein erfolg, was ich grade in der Berry Console gesehen habe :
    Der Log nach einem Neustart, fehlt da was ?
    00:00:00.002 HDW: ESP32-D0WD-V3
    00:00:00.074 UFS: FlashFS mounted with 272 kB free
    00:00:00.106 CFG: Loaded from File, Count 191
    00:00:00.116 QPC: Count 1
    00:00:00.242 BRY: Berry initialized, RAM used=4470 bytes
    00:00:00.264 TFS: File '.drvset003' not found
    00:00:00.275 Project tasmota - NSPanel Version 13.1.0(nspanel)-2_0_11(2023-08-15T08:01:15)
    00:00:00.328 TAP: Loaded Tasmota App 'Partition_Wizard.tapp'
    00:00:01.654 NXP: Initializing Driver
    00:00:01.661 BRY: Successfully loaded 'autoexec.be'
    ArmilarA Offline
    ArmilarA Offline
    Armilar
    Most Active Forum Testing
    #3801
    @michaelf
    da ist anscheinend auch noch der Partition_Witzard auf dem Tasmota. Da die Partition bereits geändert ist, solltest du den wieder löschen und den Speicher freigeben.
    Danach nochmals versuchen
    MichaelFM 1 Antwort Letzte Antwort
    • ArmilarA Armilar
      @michaelf
      MichaelFM Offline
      MichaelFM Offline
      MichaelF
      #3802
      @michaelf
      Gelöscht, aber gleicher Fehler.
        @michaelf
        ArmilarA Offline
        ArmilarA Offline
        Armilar
        #3803
        @michaelf
        ansonsten nochmals an dieses Issue hängen:
        https://github.com/joBr99/nspanel-lovelace-ui/issues/972
        Ist meiner Auffassung nach der Grund für die BerryDriver Version 9
        Evtl. liest @joBr99 hier mit...
        • icebearI Offline
          icebearI Offline
          icebear
          #3804
          Ansonsten gerne trotzdem auf den BerryDriver 9 wechseln und wie immer den unteren Teil ersetzen.
          Hab bei mir grad das Update durchgeführt, hat alles super funktioniert und ist ohne Probleme durchgelaufen.
          • ArmilarA Armilar
            @michaelf
            MichaelFM Offline
            MichaelFM Offline
            MichaelF
            #3805
            @michaelf
            Soll ich ne neue issues aufmachen, oder einfach hier mit unten reinschreiben?
            Hilft es vielleicht tasmota über ota neu zu flashen ?
            Hier nochmal ein Bild wo das Display dann hängt.
              @michaelf
              ArmilarA Offline
              ArmilarA Offline
              Armilar
              #3806
              @michaelf
              würde ein neues aufmachen...
              • ArmilarA Armilar
                @michaelf
                MichaelFM Offline
                MichaelFM Offline
                MichaelF
                #3807
                @michaelf
                Hab ich, danke für die Hilfe
                • T TT-Tom
                  @gre4t0ne zeige bitte mal die Config von
                     mrIcon1ScreensaverEntity:
                      mrIcon2ScreensaverEntity:
                  Gre4t0ne
                  #3808
                  @tt-tom heute erst wieder Zeit gehabt - habe diese Config nicht angepasst:
                  ScreensaverEntity: NSPanel_Path + 'Relay.1',
                  ScreensaverEntityIconOn: 'lightbulb',
                  ScreensaverEntityIconOff: null,
                  ScreensaverEntityValue: null,
                  ScreensaverEntityValueDecimalPlace : 0,
                  ScreensaverEntityValueUnit: null,
                  ScreensaverEntityOnColor: On,
                  ScreensaverEntityOffColor: HMIOff
                  ScreensaverEntity: 'deconz.0.Sensors.5.open',
                  ScreensaverEntityIconOn: 'heat-wave',
                  ScreensaverEntityValue: 'deconz.0.Sensors.65.temperature',
                  ScreensaverEntityValueDecimalPlace : 1,
                  ScreensaverEntityValueUnit: '°',
                  ScreensaverEntityOnColor: MSRed,
                  ScreensaverEntityOffColor: Yellow
                  • T TT-Tom
                    @gre4t0ne
                    Ich habe dir geschrieben, was du machen solltest wenn du Tasmota updaten willst. Lies im Wiki
                    Gre4t0ne
                    #3809
                    @tt-tom Bez. Tasmota Update - habe das Wiki mittlerw. gelesen:
                    -> Auf der Tasmota Seite ist eine Kurzbeschreibung und ihr könnt dort den Wizards downloaden.
                    Direkt Link zum Download Partition Wizard Tool
                    habe jetzt das Partition Wizard Tool downgeloaded, aber wie bekomme ich das jetzt auf das NSPanel?
                    • G Gre4t0ne
                      MichaelFM Offline
                      MichaelFM Offline
                      MichaelF
                      #3810
                      @gre4t0ne said in SONOFF NSPanel mit Lovelace UI:
                      Hi, hochladen über das Filesystem :
                      • ArmilarA Offline
                        ArmilarA Offline
                        Armilar
                        #3811
                        @gre4t0ne
                        Das ist ein Beispiel aus der NSPanelTS...
                        Dir fehlen ja bestimmt die Sensoren aus dem DeConz (sind ja irgendwie meine ;-) ). Kein Wunder mit den Fehlern...
                        Nimm stattdessen die aus der
                        https://github.com/joBr99/nspanel-lovelace-ui/blob/main/ioBroker/NsPanelTs_without_Examples.ts
                                    ScreensaverEntity: NSPanel_Path + 'Relay.2',
                        • G Gre4t0ne
                          TT-Tom
                          #3812
                          @gre4t0ne
                          Beim mrIcon2ScreensaverEntity, sind das deine Datenpunkte?? Sieht mir aus wie das Beispiel aus dem Script. Bitte an deine Umgebung anpassen oder die beiden Parameter auf null setzen.
                          Gruß Tom
                          https://github.com/tt-tom17
                          NSPanel Script Wiki
                          NSPanel Adapter Wiki
                          • G Offline
                            Gre4t0ne
                            #3813
                            Danke an alle für die Hilfe!
                            Muss der Partition Wizard nach der Migration wieder entfernt werden?
                            • G Gre4t0ne
                              ArmilarA Offline
                              ArmilarA Offline
                              Armilar
                              #3814
                              @gre4t0ne
                              Nach der Umpartitionierung ist er nicht mehr erforderlich... ja - sollte wieder entfernt werden
                              • T TT-Tom
                                @manylopmy
                                zeige bitte mal die Objektdaten vom diesem Datenpunkt.
                                plenticore.0.devices.local.battery.SoC
                                eigentlich sollte das Icon eine Farbe haben und nicht weiss sein.
                                bei welchem Füllstand welche Farbe aktiviert wird
                                es wird die Farbskala aus dem Script genutzt.
                                //Dynamische Indikatoren (Abstufung grün nach gelb nach rot)
                                const colorScale0:      RGB = { red:  99, green: 190, blue: 123 };
                                const colorScale1:      RGB = { red: 129, green: 199, blue: 126 };
                                const colorScale2:      RGB = { red: 161, green: 208, blue: 127 };
                                const colorScale3:      RGB = { red: 129, green: 217, blue: 126 };
                                const colorScale4:      RGB = { red: 222, green: 226, blue: 131 };
                                const colorScale5:      RGB = { red: 254, green: 235, blue: 132 };
                                const colorScale6:      RGB = { red: 255, green: 210, blue: 129 };
                                const colorScale7:      RGB = { red: 251, green: 185, blue: 124 };
                                const colorScale8:      RGB = { red: 251, green: 158, blue: 117 };
                                const colorScale9:      RGB = { red: 248, green: 131, blue: 111 };
                                const colorScale10:     RGB = { red: 248, green: 105, blue: 107 };
                                manylopmy
                                schrieb am zuletzt editiert von manylopmy
                                #3815
                                @TT-Tom
                                Hallo Tom,
                                anbei der Datenpunkt:
                                  "type": "state",
                                  "common": {
                                    "name": "State of Charge",
                                    "desc": "Actual state of charge",
                                    "type": "number",
                                    "role": "value.battery",
                                    "unit": "%",
                                    "read": true,
                                    "write": false,
                                    "custom": {
                                      "influxdb.0": {
                                        "enabled": true,
                                        "storageType": "",
                                        "aliasId": "",
                                        "debounceTime": 0,
                                        "blockTime": 0,
                                        "changesOnly": true,
                                        "changesRelogInterval": 0,
                                        "changesMinDelta": 0,
                                        "ignoreBelowNumber": "",
                                        "disableSkippedValueLogging": false,
                                        "enableDebugLogs": false,
                                        "debounce": 1000
                                  "native": {},
                                  "_id": "plenticore.0.devices.local.battery.SoC",
                                  "acl": {
                                    "object": 1636,
                                    "state": 1636,
                                    "owner": "system.user.admin",
                                  "user": "system.user.admin",
                                  "ts": 1693377305117
                                }code_text
                                Wäre schön, wenn Du daran etwas ableiten kannst. Die Batterie ist voll, das Icon ist weiß. :confused:
                                Sorry, derzeitig (nach Neustart) ist das Icon leicht rosa. Keine schöne Farbe, aber eine andere. :blush: Der SoC Wert ist aktuell 90%. Ich sehe mal, wie er heute Nacht ist.
                                Gruß Manfred
                                Hier als Info und ein Danke an die Hilfe. Die Anzeige geht jetzt, ich habe das Rot noch etwas intensiviert, ist nun besser zu erkennen.
                                :+1:
                                • ArmilarA Armilar
                                  @michaelf
                                  was steht denn darin?
                                  MichaelFM Offline
                                  MichaelFM Offline
                                  MichaelF
                                  #3816
                                  @michaelf
                                  Wollte nur kurz bescheid geben das es wieder geht der dns war weg.......... Neu eingetragen und sofort ging die Firmware.
                                  Grüsse
                                    Tom_W
                                    #3817
                                    ich habe endlich mal mein Skript geupdatet, leider konnte ich es nicht kompilieren.
                                    Er meckerte, dass ihm "ScreensaverEntityDateFormat:", fehlt.
                                    Hab das nun in allen bottomScreensaverEntity Seiten hinzugefügt, danach konnte ich es ohne Fehler kompilieren.
                                    Hab ich das was falsch gemacht?
                                      TT-Tom
                                      #3818
                                      @tom_w
                                      Welches Script hast du genommen? Es liegen zwei auf Github.
                                      Ist kein Pflichtparameter bei bottomScreensaverEntity. Wie sieht den Deine Config von den Seiten aus?
                                      Gruß Tom
                                      NSPanel Script Wiki
                                      • T TT-Tom
                                        @tom_w
                                        Tom_W
                                        #3819
                                        @tt-tom
                                        Ich hab das ohne Beispielseiten genommen.
                                        Eigentlich gar nicht, ich habs so gelassen wie es im Skript war. Dachte ich zumindest.
                                        Ist ja eigentlich eh egal, geht ja jetzt.
                                        Habs gerade nochmal getestet, wenn ich bei der bottomScreensaverEntity 2 die ScreensaverEntityDateFormat auskommentiere, kommt:
                                        javascript.0 (1696379) script.js.NSPanels.Panel_test: TypeScript compilation failed: { ^ ERROR: Property 'ScreensaverEntityDateFormat' is missing in type '{ ScreensaverEntity: string; ScreensaverEntityFactor: number; ScreensaverEntityDecimalPlaces: number; ScreensaverEntityIconOn: string; ScreensaverEntityIconOff: null; ScreensaverEntityText: string; ScreensaverEntityUnitText: string; ScreensaverEntityIconColor: { ...; }; }' but required in type 'ScreenSaverElement'.
                                        • T Tom_W
                                          @tt-tom
                                          TT-Tom
                                          #3820
                                          @tom_w
                                          bei mir läuft das Script ohne Meldung und ich habe auch keine ScreensaverEntityDateFormat.
                                          Welche Javascript adapter Version hast du? zeige bitte mal die Config vom Entity 2
                                          Gruß Tom
                                          NSPanel Script Wiki
                                          32.6k
                                          82.1k
