  4. Untersuchung: code 25 fehlerlösung
    2.7k
    4.7k
    4.0k
255 Beiträge 34 Kommentatoren 70.9k Aufrufe 31 Beobachtet
  • David G.D David G.
    Hab die Meldung grad eben ergänzt.
    Hier ist Sie nochmal:
    0 verbose cli C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js
    1 info using npm@9.5.0
    2 info using node@v18.15.0
    3 timing npm:load:whichnode Completed in 3ms
    4 timing config:load:defaults Completed in 3ms
    5 timing config:load:file:C:\Program Files\nodejs\node_modules\npm\npmrc Completed in 4ms
    6 timing config:load:builtin Completed in 4ms
    7 timing config:load:cli Completed in 4ms
    8 timing config:load:env Completed in 1ms
    9 timing config:load:file:C:\ioBroker\.npmrc Completed in 0ms
    10 timing config:load:project Completed in 3ms
    11 timing config:load:file:C:\WINDOWS\system32\config\systemprofile\.npmrc Completed in 0ms
    12 timing config:load:user Completed in 0ms
    13 timing config:load:file:C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm\etc\npmrc Completed in 1ms
    14 timing config:load:global Completed in 1ms
    15 timing config:load:setEnvs Completed in 2ms
    16 timing config:load Completed in 19ms
    17 timing npm:load:configload Completed in 20ms
    18 timing npm:load:mkdirpcache Completed in 1ms
    19 timing npm:load:mkdirplogs Completed in 0ms
    20 verbose title npm install copystring/ioBroker.roborock#dev
    21 verbose argv "install" "copystring/ioBroker.roborock#dev"
    22 timing npm:load:setTitle Completed in 4ms
    23 timing config:load:flatten Completed in 6ms
    24 timing npm:load:display Completed in 7ms
    25 verbose logfile logs-max:10 dir:C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2023-03-30T08_57_07_607Z-
    26 verbose logfile C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2023-03-30T08_57_07_607Z-debug-0.log
    27 timing npm:load:logFile Completed in 9ms
    28 timing npm:load:timers Completed in 0ms
    29 timing npm:load:configScope Completed in 0ms
    30 timing npm:load Completed in 45ms
    31 timing arborist:ctor Completed in 1ms
    32 silly logfile start cleaning logs, removing 8 files
    33 timing idealTree:init Completed in 565ms
    34 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.js-controller
    35 timing idealTree Completed in 645ms
    36 timing command:install Completed in 659ms
    37 verbose stack Error: An unknown git error occurred
    37 verbose stack     at makeError (C:\Program Files\nodejs\node_modules\npm\node_modules\@npmcli\git\lib\make-error.js:28:13)
    37 verbose stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\@npmcli\git\lib\spawn.js:37:26
    37 verbose stack     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    38 verbose cwd C:\ioBroker
    39 verbose Windows_NT 10.0.22621
    40 verbose node v18.15.0
    41 verbose npm  v9.5.0
    42 error code ENOENT
    43 error syscall spawn git
    44 error path git
    45 error errno -4058
    46 error enoent An unknown git error occurred
    47 error enoent This is related to npm not being able to find a file.
    47 error enoent
    48 verbose exit -4058
    49 timing npm Completed in 750ms
    50 verbose unfinished npm timer reify 1680166627692
    51 verbose unfinished npm timer reify:loadTrees 1680166627699
    52 verbose unfinished npm timer idealTree:userRequests 1680166628267
    53 verbose code -4058
    54 error A complete log of this run can be found in:
    54 error     C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2023-03-30T08_57_07_607Z-debug-0.log
    #241
    @david-g Diese Meldung besagt das Du einen Adapter installieren willst der ein installiertes "git" braucht. Bitte git installieren und sicherstellen das es im Pfad ist
    • apollon77A apollon77
      David G.D Online
      David G.D Online
      David G.
      #242
      @apollon77
      Weißt du zufällig, wie ich das unter Windows entsprechend mache?
      Gleich schreibe ich zusätzlich mal im Thread vom neuen Windows installer ob man es dort ggf Optional mit installiert bekommt.
        @liv-in-sky
        Funktionert der?
        Schließt schon mal alles aus, was nicht 8 Zeichen hinter dem Bindestrich hat (also z. B. .ts-node) und .local-chromium heißt.
        for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%/}; done
        [Edit: Es ist jetzt egal in welchem Verzeichnis der Befehl verwendet wird.
        #243
        Nachdem ich mit NPM 9.5.0 erhebliche Probleme (ENOEMPTY, Code 217) hatte, verwende ich diese Kombination:
        type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        /usr/bin/npx
        v18.15.0
        v18.15.0
        6.14.18
        6.14.18
        Das funktioniert bisher problemlos.
        Thomas BraunT apollon77A 2 Antworten Letzte Antwort
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          /usr/bin/npx
          v18.15.0
          v18.15.0
          6.14.18
          6.14.18
          #244
          Würde ich nicht machen. Mittlerweile ist die Korrektur auch im
          iob fix
          enthalten
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            /usr/bin/npx
            v18.15.0
            v18.15.0
            6.14.18
            6.14.18
            #245
            @paul53 Jupp, AM Ende ist das Problem wir irgendwo in npm 8+ drin. npm 6 wird generell gehen ... ist nur die Farge warum es bei dir immer passiert,.
            Mal eine Bitte an alle die die diese Issues haben: Installiert/updated mal den nächsten Adapter mit "--debug" per Kommandozeile und posted hier die Ausgaben.
            Wir wissen inzwischen das diese Verzeichnisse wohl angelegt werden wenn irgendwelche Nativen Teile gebaut werden müssen. Da wa aber am Ende eher wenige User betrifft: Erweiterte Annahme: Irgendwo ist ein optionales Paket was bei euch nicht gebaut werden kann und damit immer wieder failed und vllt hat in dem Fall npm einen Bug und die Verzeichnisse bleiben da.
              iob fix
              enthalten
              #246
              @thomas-braun sagte: Mittlerweile ist die Korrektur auch im
              iob fix
              enthalten.
              NPM 9.5.0 hatte einige Verzeichnisse in "node_modules" versaut. Ich möchte nicht eine nachträgliche Korrektur vornehmen, sondern gleich richtig installieren / updaten. Deshalb hatte ich das Verzeichnis "node_modules" unter "iobroker" komplett gelöscht und ioBroker mit NPM 6.14.18 neu installiert.
                mayer
                #247
                @apollon77 Ich habe das selbe Problem unter Windows nach dem Update auf Node Version 19.9.0.
                Auf der Command line werden die Verzeichnisse nicht angezeigt. Im Explorer werden die Verzeichnisse zwar angezeigt, aber bei Zugriff als nicht vorhanden gemeldet.
                Update backitup from @2.5.12 to @2.6.16
                host.OptiPlex Adapter "system.adapter.backitup.0" is stopped.
                NPM version: 9.6.3
                Installing iobroker.backitup@2.6.16... (System call)
                npm notice
                npm notice New patch version of npm available! 9.6.3 -> 9.6.4
                npm notice Changelog: <https://github.com/npm/cli/releases/tag/v9.6.4>
                npm notice Run `npm install -g npm@9.6.4` to update!
                npm notice
                npm ERR! code EBUSY
                npm ERR! syscall rename
                npm ERR! path C:\ioBroker\node_modules\iobroker
                npm ERR! dest C:\ioBroker\node_modules\.iobroker-hewf7iLQ
                npm ERR! errno -4082
                npm ERR! EBUSY: resource busy or locked, rename 'C:\ioBroker\node_modules\iobroker' -> 'C:\ioBroker\node_modules\.iobroker-hewf7iLQ'
                GlasfaserG apollon77A 2 Antworten Letzte Antwort
                • M mayer
                  NPM version: 9.6.3
                  npm notice
                  npm notice
                  npm ERR! code EBUSY
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Glasfaser
                  #248
                  @mayer sagte in Untersuchung: code 25 fehlerlösung:
                  Warum 19 !?
                  18 ist empfohlen !
                  • M mayer
                    NPM version: 9.6.3
                    npm notice
                    npm notice
                    npm ERR! code EBUSY
                    #249
                    @mayer also ja, warum 19 … am Ende ist EBUSY irgend etwas mit filesystem Zugriffssperren. Versuch mal iobroker zu stoppen und das Update dann zu machen per cli.
                      mayer
                      #250
                      @apollon77 Ich habe jetzt mit den Versionen 16, 17 und 18 getestet. Immer das gleiche Ergebnis.
                      Wenn ich ioBroker stoppe und das das Update mache, läuft es zwar durch, aber mit jeder Menge npm Fehlermeldungen. Anschließend lässt sich ioBroker nicht mehr starten.
                      Ich werde wohl alles neu aufsetzen.
                      • M mayer
                        #251
                        @mayer Könntest mal so ein Log hier posten ... dann könnten wir vllt mit überlegen?
                          mayer
                          #252
                          @apollon77 Ich habe ioBroker jetzt mal neu installiert. Hatte ich schon lange mal vor. Mit dem neuen Windows-Installer hat dies ohne Probleme funktioniert. Leider bekam ich beim Nachinstallieren der Adapter die gleichen Fehlermeldungen. Ich habe dann noch ein Downgrade von NPM auf die Version 6.14.18 gemacht und konnte anschließend alle Adapter installieren. Seltsam ist nur, dass mir ioBroker immer noch die NPM Version 9.5.1 anzeigt, ein npm -v aber die Version 6.14.18 ausgibt.
                          • M mayer
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Glasfaser
                            #253
                            Was machst du da !?
                            das ist dann :
                            dann hast du alles quer installiert ..
                            das hat aber alles nichts mit diesem Thread mehr zu tun " Untersuchung: code 25 fehlerlösung "
                            • GlasfaserG Glasfaser
                              Was machst du da !?
                              das ist dann :
                              mayer
                              #254
                              @glasfaser sagte in Untersuchung: code 25 fehlerlösung:
                              Doch, hatte es. Wie schon gesagt, selbst nach Neuinstallation mit Node.js v18.16.0 und NPM v9.5.1 konnte ich keine Adapter installieren oder updaten. Abbruch mit Fehler 25. Erst ein Downgrade der NPM Version auf 6.14.18 (Node Version ist weiterhin 18.16.10) löste dieses Problem. Meine, nicht gerade kleine, ioBroker Konfiguration läuft jetzt wieder fehlerfrei.
                              • M mayer
                                #255
                                Doch, hatte es
                                was?
                                wo ist das Untersuchungsergebnis von dir zur Ursache dass ein Fehler 25 ausgeworfen wird?
