  4. Untersuchung: code 25 fehlerlösung
    2.7k
    4.7k
    4.0k
255 Beiträge 34 Kommentatoren 70.9k Aufrufe 31 Beobachtet
  • hoepps2802 0H hoepps2802 0
    @apollon77 beim Versuch node-red zu installieren bekommen ich
    iobroker host.raspberrypi Cannot install iobroker.node-red@4.0.0: 217
    und
    for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do echo ${i%}; done
    /opt/iobroker/node_modules/.node-red-node-feedparser-BvY866YR
    /opt/iobroker/node_modules/.multer-zsSYw8fD
    /opt/iobroker/node_modules/.argparse-S5zfMSQi
    /opt/iobroker/node_modules/.js-yaml-mxBLENxb
    /opt/iobroker/node_modules/.socks-Ly3eN6mV
    /opt/iobroker/node_modules/.esprima-TKIwiasy
    /opt/iobroker/node_modules/.i18next-VFNyugyK
    /opt/iobroker/node_modules/.moment-YVTvHlwl
    /opt/iobroker/node_modules/.uglify-js-UrZ3Klfa
    /opt/iobroker/node_modules/@babel/.runtime-cSN2FFol
    /opt/iobroker/node_modules/@node-red/.registry-ccnbcuRd
    /opt/iobroker/node_modules/@node-red/.util-sbKUIGKV
    /opt/iobroker/node_modules/@node-red/.runtime-1jQRdxlO
    /opt/iobroker/node_modules/@node-red/.nodes-oC2yqxJN
    /opt/iobroker/node_modules/@node-red/.editor-client-FpqhSpDH
    /opt/iobroker/node_modules/@node-red/.editor-api-Xk7v1FU7
    /opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi
    /opt/iobroker/node_modules/@types/.webidl-conversions-sTwlFPEN
    /opt/iobroker/node_modules/.node-red-admin-97cICUzY
    /opt/iobroker/node_modules/.hpagent-PUXuWBzq
    /opt/iobroker/node_modules/.sprintf-js-NEkm8GpH
    /opt/iobroker/node_modules/iobroker.worx/node_modules/.ms-gKD4yxG7
    /opt/iobroker/node_modules/iobroker.worx/node_modules/.string_decoder-7WG8ZZzJ
    /opt/iobroker/node_modules/iobroker.worx/node_modules/.debug-g1vdTaRH
    /opt/iobroker/node_modules/iobroker.worx/node_modules/.readable-stream-Qsfpwrzm
    /opt/iobroker/node_modules/iobroker.worx/node_modules/.ws-14EKPmTY
    /opt/iobroker/node_modules/iobroker.worx/node_modules/.mqtt-UaPggZUW
    /opt/iobroker/node_modules/iobroker.worx/node_modules/.safe-buffer-Es0FmdFm
    /opt/iobroker/node_modules/.mongodb-9LMcV19S
    /opt/iobroker/node_modules/.bson-a4WfR2fa
    /opt/iobroker/node_modules/.mqtt-uuzoX3iL
    /opt/iobroker/node_modules/.node-red-Kvc6EPdV
    /opt/iobroker/node_modules/.mongodb-connection-string-url-iEu3f9Lf
    /opt/iobroker/node_modules/.iobroker.node-red-lv0iVi6J
    /opt/iobroker/node_modules/.dicer-vvDk7wqs
    jetzt kann ich keine Adapter mehr updaten
    Und bei Node-Red steht:
    Installierte Instanzen:
    Verfügbare Version:
    4.0.0
    Installierte Version:
    4.0.0
    Ist es aber nicht
    #221
    @hoepps2802-0 Ok Du hast nur das Skript hier gezeigt was die ausgiubt welche komischen verzeichnisse da sind. Hast Du auch die "Lösch" Variante aus dem ersten Post mal genutzt? Gehts dann?
    Wenn nicht starte den upgrade Befehl mit --debug
    hoepps2802 0H 1 Antwort Letzte Antwort
      @hoepps2802-0 sagte in Untersuchung: code 25 fehlerlösung:
      Ist es aber nicht
      Sondern?
      hoepps2802 0H Offline
      hoepps2802 0
      #222
      nachdem ich die Löschvariante nutze und IOB neustarte ist es wieder 3.3.1
        #223
        @hoepps2802-0
        iobroker stop
        iobroker fix
        iobroker update
        iobroker upgrade
        iobroker start
        • apollon77A apollon77
          hoepps2802 0
          #224
          @apollon77
          Installing iobroker.node-red@4.0.0... (System call)
          npm ERR! code ENOTEMPTY
          npm ERR! syscall rename
          npm ERR! path /opt/iobroker/node_modules/node-red-node-email/node_modules/encoding-japanese/src
          npm ERR! dest /opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi/node_modules/encoding-japanese/src
          npm ERR! errno -39
          npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/node-red-node-email/node_modules/encoding-japanese/src' -> '/opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi/node_modules/encoding-japanese/src'
          npm ERR!     /home/iobroker/.npm/_logs/2022-10-13T10_52_26_189Z-debug-0.log
          hier das Log
            @apollon77
            npm ERR! errno -39
            hier das Log
            hoepps2802 0
            #225
            @apollon77 @Thomas-Braun
            keine Ahnung warum aber nachdem Node-Red im Debug installiert habe und das Log abgezogen habe,
            habe ich das Löschskript nochmal ausgeführt .
            Dann habeich mit der Anleitung von Thomas begonnen.
            bei Iobroker update sagte er mir das alle Adapter aktuell sind.
            Es ist kein Fehler mehr zu sehen und auch Node-Red ist als 4.0.0 vorhanden.
            Wenn ich es öffne steht dort auch 3.0.2: Maintenance Release
            Neue Adapter lassen sich auch installieren. Scheint also alles zu laufen.
              hoepps2802 0
              schrieb am zuletzt editiert von hoepps2802 0
              #226
              Leider doch nicht, nachdem ich einen Adapter installiert und wieder deinstalliert habe steht Node-Red wieder als 3.3.1 da
              Installation schlägt fehl:
              This upgrade of "node-red" will introduce the following changes:
              -> 4.0.0:
              IMPORTANT: Node.js 14.x now needed at least
              Upgrade to node-red 3.0.2, enable runtime-state features and switch editor to monaco-editor
              Correctly escape backslashes when writing setting file on Windows
              BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
              Would you like to upgrade node-red from @3.3.1 to @4.0.0 now? [(y)es, (n)o]: y
              Update node-red from @3.3.1 to @4.0.0
              host.raspberrypi Adapter "system.adapter.node-red.0" is stopped.
              NPM version: 8.15.0
                -> 4.0.0:
                NPM version: 8.15.0
                mickymM Offline
                mickymM Offline
                mickym
                #227
                @hoepps2802-0 https://forum.iobroker.net/topic/57353/untersuchung-code-25-fehlerlösung/49
                • mickymM mickym
                  hoepps2802 0
                  #228
                  @mickym
                  was soll mir der Eintrag sagen?
                  Node.js: v16.17.1
                  NPM: v8.15.0
                    @mickym
                    Node.js: v16.17.1
                    NPM: v8.15.0
                    mickymM Offline
                    mickymM Offline
                    mickym
                    #229
                    @hoepps2802-0 Ich wollte eigentlich ohne zu kommentieren - nur das wiederholen bzw. auf den Link verweisen, den Dir @jupzup schon zitiert hat - das hat wohl nicht geklappt.
                    @jupzup sagte in Untersuchung: code 25 fehlerlösung:
                    @mickym sagte in Untersuchung: code 25 fehlerlösung:
                    Ich kanns immer wieder betonen - haut halt den alten Mist raus und macht das neu, wenn ihr keine Lust habt ewig zu suchen. Macht vorher eine Imagesicherung - dann kommt ihr wieder dahin zurück oder nennt das node_modules Verzeichnis um - und macht es neu:
                    https://forum.iobroker.net/topic/56543/nach-nodejs-update-kein-adapter-mehr-updatebar/23?_=1658914381795
                    Diese Diskussionen sind doch unsinnig . Jemand der NodeRed nutzen will, wird das tun - egal ob das binär im node_modules Verzeichnis rumliegt. Das Hauptproblem ist npm mit seinen geänderten Formaten.
                    Dem kann ich zustimmen bzw. hat bei mir nichts wirklich dauerhaft den Fehler behoben bis ich letztlich das komplette node_modules Verzeichnis gelöscht und neu aufbauen lies anhand der Anleitung von mickym
                    Besten Dank dafür aber natürlich auch an alle anderen Beteiligten !!
                    Darauf kam von Dir
                    @jupzup ist die Anleitung im Form zu finden ?
                    habe das gleiche Problem und bekomme es durch löschen der Temp Ordner nicht hin.
                    Matthias
                    Entweder liest Du nicht - aber da ist doch ein Link drin mit der Beschreibung - wie ich es gemacht habe. Kannst auch Dein node_modules Verzeichnis vorher umbenennen (im /opt/iobroker Verzeichnis - mv node_modules node_modules.bak) . Aber Du scheinst das entweder nicht richtig zu lesen - oder willst halt lieber Ursachenforschung betreiben. Deswegen war nur noch mal der Link zur Erinnerung.
                    • mickymM mickym
                      Darauf kam von Dir
                      Matthias
                      hoepps2802 0
                      #230
                      @mickym
                      konnte mir schon sowas denken, aber im thread steht mittlerweile so viel das ich da nicht mehr so richtig durchblicke.
                      ne einfach Anleitung wäre super - finde deine Anleitung nicht ?
                      Ok- meinst du diese ?
                      https://forum.iobroker.net/topic/56543/nach-nodejs-update-kein-adapter-mehr-updatebar/46?_=1665664659274
                        @mickym
                        mickymM Offline
                        mickymM Offline
                        mickym
                        #231
                        @hoepps2802-0
                        Ich habe den Link angepasst - so müsste es gehen: https://forum.iobroker.net/post/831638
                        also anstelle von:
                        sudo rm -rf node_modules
                        Dann hast da noch eine Sicherung:
                        Also nochmal:
                        @mickym sagte in Nach Nodejs Update kein Adapter mehr updatebar:
                        @tilly sagte in Nach Nodejs Update kein Adapter mehr updatebar:
                        @mickym
                        wie würde ich da vorgehen?
                        also in das /opt/iobroker Verzeichnis wechseln.
                        IOB stoppen natürlich:
                        iob stop
                        cd /opt/iobroker
                        komplettes node_modules Verzeichnis löschen
                        etwaige package-lock.json löschen
                        sudo rm package-lock.json
                        Den cache sicherheitshalber noch leeren:
                        npm cache clean --force
                        Dann das node_modules neu aufbauen lassen:
                        npm install
                        Die ganzen Informationen über die Adapter und deren Abhängigkeiten stehen in der package.json.
                        Eine datensicherung oder ein Image würde ich aber in jedem Fall machen, falls was nicht geht. Ist aber noch schneller, als das ganze System neu aufzubauen.
                        zum Schluss in dem Verzeichnis /opt/iobroker noch den Befehl
                        npm list
                        und schauen, ob Du einen sauberen Baum hast. npm cache hast ja soweit ich sehe schon gelöscht.
                        • mickymM mickym
                          @hoepps2802-0
                          also anstelle von:
                          Also nochmal:
                          @mickym
                          iob stop
                          cd /opt/iobroker
                          npm install
                          npm list
                          #232
                          @mickym du darfst nicht die Links von oben rechts kopieren. Korrekt bei denen kann sortiering anders sein. Die Links im Post bei der Zeit wann er gepostet hat ist anderer Typ Link mit langer post Id. Der geht.
                            mickymM Offline
                            mickymM Offline
                            mickym
                            #233
                            @apollon77 sagte in Untersuchung: code 25 fehlerlösung:
                            Also den Link bei der Zeitangabe im jeweiligen Post (also ... vor 3 Stunden? ) - ich hatte immer den Link aus der Eingabeleiste des Browsers genommen.
                            also so: https://forum.iobroker.net/post/872599
                            Vielen Dank!!! - Wieder was gelernt - mich hat das nämlich genervt - da sich die Links ja mit jedem neuen Post geändert haben.
                            • mickymM mickym
                              #234
                              @mickym genau der Link ist der richtige.
                              • liv-in-skyL liv-in-sky
                                @apollon77
                                sind schon 2 user mit dem puppeteer problem daher würde ich eine änderung deiner beschreibung - zumindest vorübergehend dahin ändern
                                zuerst ausführen:
                                cd /opt/iobroker/node_modules && for i in $(find -type d -iname ".*-*"); do echo ${i%%/}; done
                                dann ausgabedurchsehen, ob das gefundene diese "wirren" namen am ende hat hat z.b.: "./.node-red-admin-97cICUzY"
                                dann den befehl mit rm ändern mit den ausnahmen (bei mir: ! -iname ".ts-node" ! -iname ".local-chromium" )
                                cd /opt/iobroker/node_modules && for i in $(find -type d -iname ".*-*" ! -iname ".ts-node" ! -iname ".local-chromium" ); do rm -rf ${i%%/}; done
                                weiß nicht, ob dir das gefällt - umständlich - aber sicherer um spätere fehlersuche zu vermeiden - wird wahrsheinlich eh nicht bei allzu vielen usern sein - puppeteer user und evtl noch user mit zusätzlichen npm modulen
                                oder ihr habt bessere idee
                                jans_ios
                                #235
                                Moin!
                                Geil, Leute - hab mein Problem dank Eurer Arbeit hier im Thread fixen können - also: DANKE!!
                                Schönes Wochenende und cheers!
                                • David G.D Online
                                  David G.D Online
                                  David G.
                                  #236
                                  Gibt es für den ein Zeiler
                                  for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                                  auch eine Variante für Windows?
                                  Habe einen Adapter der dort mit Fehler 25 die Installation verweigert.
                                  Unter Windows kommt bei Fix:
                                  PS C:\iobroker> for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                                  In Zeile:1 Zeichen:4
                                  + for i in $(find /opt/iobroker/node_modules -type d -iname ".*-??????? ...
                                  Öffnende "(" fehlt nach dem Schlüsselwort "for".
                                  In Zeile:1 Zeichen:104
                                  + ...  -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf  ...
                                  Anweisungstext fehlt in der "do"-Schleife.
                                      + CategoryInfo          : ParserError: (:) [], ParentContainsErrorRecordException
                                      + FullyQualifiedErrorId : MissingOpenParenthesisAfterKeyword
                                  Der Adapter zeigt im node Log:
                                  0 verbose cli C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js
                                  1 info using npm@9.5.0
                                  2 info using node@v18.15.0
                                  3 timing npm:load:whichnode Completed in 3ms
                                  4 timing config:load:defaults Completed in 3ms
                                  5 timing config:load:file:C:\Program Files\nodejs\node_modules\npm\npmrc Completed in 4ms
                                  6 timing config:load:builtin Completed in 4ms
                                  7 timing config:load:cli Completed in 4ms
                                  8 timing config:load:env Completed in 1ms
                                  9 timing config:load:file:C:\ioBroker\.npmrc Completed in 0ms
                                  10 timing config:load:project Completed in 3ms
                                  11 timing config:load:file:C:\WINDOWS\system32\config\systemprofile\.npmrc Completed in 0ms
                                  12 timing config:load:user Completed in 0ms
                                  13 timing config:load:file:C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm\etc\npmrc Completed in 1ms
                                  14 timing config:load:global Completed in 1ms
                                  15 timing config:load:setEnvs Completed in 2ms
                                  16 timing config:load Completed in 19ms
                                  17 timing npm:load:configload Completed in 20ms
                                  18 timing npm:load:mkdirpcache Completed in 1ms
                                  19 timing npm:load:mkdirplogs Completed in 0ms
                                  20 verbose title npm install copystring/ioBroker.roborock#dev
                                  21 verbose argv "install" "copystring/ioBroker.roborock#dev"
                                  22 timing npm:load:setTitle Completed in 4ms
                                  23 timing config:load:flatten Completed in 6ms
                                  24 timing npm:load:display Completed in 7ms
                                  25 verbose logfile logs-max:10 dir:C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2023-03-30T08_57_07_607Z-
                                  26 verbose logfile C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2023-03-30T08_57_07_607Z-debug-0.log
                                  27 timing npm:load:logFile Completed in 9ms
                                  28 timing npm:load:timers Completed in 0ms
                                  29 timing npm:load:configScope Completed in 0ms
                                  30 timing npm:load Completed in 45ms
                                  31 timing arborist:ctor Completed in 1ms
                                  32 silly logfile start cleaning logs, removing 8 files
                                  33 timing idealTree:init Completed in 565ms
                                  34 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.js-controller
                                  35 timing idealTree Completed in 645ms
                                  36 timing command:install Completed in 659ms
                                  37 verbose stack Error: An unknown git error occurred
                                  37 verbose stack     at makeError (C:\Program Files\nodejs\node_modules\npm\node_modules\@npmcli\git\lib\make-error.js:28:13)
                                  37 verbose stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\@npmcli\git\lib\spawn.js:37:26
                                  37 verbose stack     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                                  38 verbose cwd C:\ioBroker
                                  39 verbose Windows_NT 10.0.22621
                                  40 verbose node v18.15.0
                                  41 verbose npm  v9.5.0
                                  42 error code ENOENT
                                  43 error syscall spawn git
                                  44 error path git
                                  45 error errno -4058
                                  46 error enoent An unknown git error occurred
                                  47 error enoent This is related to npm not being able to find a file.
                                  47 error enoent
                                  48 verbose exit -4058
                                  49 timing npm Completed in 750ms
                                  50 verbose unfinished npm timer reify 1680166627692
                                  51 verbose unfinished npm timer reify:loadTrees 1680166627699
                                  52 verbose unfinished npm timer idealTree:userRequests 1680166628267
                                  53 verbose code -4058
                                  54 error A complete log of this run can be found in:
                                  54 error     C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2023-03-30T08_57_07_607Z-debug-0.log
                                  • David G.D David G.
                                    44 error path git
                                    47 error enoent
                                    #237
                                    @david-g
                                    Das sind Kommandos für die bash, da kannste unter Windows natürlich nichts mit anfangen.
                                    Mir wäre auch neu, dass da das Phänomen mir den nicht gelöschten Verzeichnissen auftaucht.
                                    Fehler 25 bedeutet nur, das irgendwas nicht funktioniert hat. Die ausführliche Meldung lautet?
                                      @david-g
                                      David G.D Online
                                      David G.D Online
                                      David G.
                                      #238
                                      Hab die Meldung grad eben ergänzt.
                                      Hier ist Sie nochmal:
                                      44 error path git
                                      47 error enoent
                                      Thomas BraunT arteckA apollon77A 3 Antworten Letzte Antwort
                                        44 error path git
                                        47 error enoent
                                        #239
                                        @david-g sagte in Untersuchung: code 25 fehlerlösung:
                                        Das ist ein anderer Fehler, den bekämst du mit dem bash-Kommando auch nicht beigeflickt.
                                          44 error path git
                                          47 error enoent
                                          arteckA Offline
                                          arteckA Offline
                                          arteck
                                          #240
                                          npm v9.5.0
                                          in verbindung mit
