  4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
    6.8k
17trackamazonbriefedhldpdglsups
1.6k Beiträge 129 Kommentatoren 737.9k Aufrufe 117 Beobachtet
  • ThisoftT Thisoft
    @thomas-braun sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
    Und schau mal danach:
    du -h /opt/iobroker/iobroker-data/backup-objects/
    109M    /opt/iobroker/iobroker-data/backup-objects/
    Und hier die Langfassung von iob diag:
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: iob-ubuntu
           Icon name: computer-vm
             Chassis: vm
      Virtualization: kvm
    Operating System: Ubuntu 22.04.4 LTS
              Kernel: Linux 5.15.0-97-generic
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    model name      : Common KVM processor
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     10:28:27 up 10:25,  2 users,  load average: 0.19, 0.29, 0.21
    CPU threads: 8
    *** Time and Time Zones ***
                   Local time: Sat 2024-02-24 10:28:27 CET
               Universal time: Sat 2024-02-24 09:28:27 UTC
                     RTC time: Sat 2024-02-24 09:28:27
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    iobroker
    /home/iobroker
    iobroker adm tty dialout cdrom sudo audio dip video plugdev lxd
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            7.9G        2.9G        3.3G        1.0M        1.8G        4.8G
    Swap:           3.1G          0B        3.1G
    Total:           11G        2.9G        6.4G
             7937 M total memory
             2872 M used memory
              748 M active memory
             3401 M inactive memory
             3262 M free memory
              269 M buffer memory
             1532 M swap cache
             3114 M total swap
                0 M used swap
             3114 M free swap
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                        Type   Size  Used Avail Use% Mounted on
    tmpfs                             tmpfs  794M  1.1M  793M   1% /run
    /dev/mapper/ubuntu--vg-ubuntu--lv ext4    15G   12G  2.3G  84% /
    tmpfs                             tmpfs  3.9G     0  3.9G   0% /dev/shm
    tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
    /dev/sda2                         ext4   2.0G  251M  1.6G  14% /boot
    //192.168.137.42/motion           cifs   869G  840G   30G  97% /var/lib/motion/NAS
    tmpfs                             tmpfs  794M  4.0K  794M   1% /run/user/1000
    [Sat Feb 24 00:03:06 2024] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Sat Feb 24 00:03:07 2024] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none.
    [Sat Feb 24 00:03:08 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    Show mounted filesystems \(real ones only\):
    TARGET                SOURCE                            FSTYPE   OPTIONS
    /                     /dev/mapper/ubuntu--vg-ubuntu--lv ext4     rw,relatime
    |-/snap/core20/2105   /dev/loop0                        squashfs ro,nodev,relatime,errors=continue
    |-/snap/core20/2182   /dev/loop1                        squashfs ro,nodev,relatime,errors=continue
    |-/snap/lxd/27037     /dev/loop2                        squashfs ro,nodev,relatime,errors=continue
    |-/snap/lxd/26975     /dev/loop3                        squashfs ro,nodev,relatime,errors=continue
    |-/snap/snapd/20671   /dev/loop5                        squashfs ro,nodev,relatime,errors=continue
    |-/snap/snapd/20290   /dev/loop4                        squashfs ro,nodev,relatime,errors=continue
    |-/boot               /dev/sda2                         ext4     rw,relatime
    `-/var/lib/motion/NAS //192.168.137.42/motion           cifs     rw,relatime,vers=default,cache=strict,username=motion,uid=1001,forceuid,gid=0,noforcegid,addr=192.168.137.42,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=1048576,wsize=1048576,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=1
    /var:
    3.9G    /var/
    3.0G    /var/lib
    2.2G    /var/lib/motion/NAS
    1.9G    /var/lib/motion/NAS/Cam4
    Archived and active journals take up 384.1M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    346M    /opt/iobroker/iobroker-data/
    199M    /opt/iobroker/iobroker-data/files
    57M     /opt/iobroker/iobroker-data/files/javascript.admin
    38M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    31M     /opt/iobroker/iobroker-data/objects.jsonl
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
    8.2M    /opt/iobroker/iobroker-data/states.jsonl
    7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.1
    /usr/bin/node           v18.19.1
    /usr/bin/npm            10.2.4
    /usr/bin/npx            10.2.4
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.1-1nodesource1
      Candidate: 18.19.1-1nodesource1
      Version table:
     *** 18.19.1-1nodesource1 100
            100 /var/lib/dpkg/status
         12.22.9~dfsg-1ubuntu3.3 500
            500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
            500 http://de.archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
         12.22.9~dfsg-1ubuntu3 500
            500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.19
    admin:          6.14.1
    javascript:     7.8.0
    Adapters from github:   1
    Adapter State
    + system.adapter.admin.0                  : admin                 : iob-ubuntu                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alias-manager.0          : alias-manager         : iob-ubuntu                               - disabled
    + system.adapter.backitup.0               : backitup              : iob-ubuntu                               -  enabled
      system.adapter.daswetter.0              : daswetter             : iob-ubuntu                               -  enabled
      system.adapter.daswetter.1              : daswetter             : iob-ubuntu                               - disabled
      system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : iob-ubuntu                               - disabled
      system.adapter.feiertage.0              : feiertage             : iob-ubuntu                               -  enabled
      system.adapter.flot.0                   : flot                  : iob-ubuntu                               - disabled
      system.adapter.gruenbeck.0              : gruenbeck             : iob-ubuntu                               - disabled
    + system.adapter.hm-rega.0                : hm-rega               : iob-ubuntu                               -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iob-ubuntu                               -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iob-ubuntu                               -  enabled, port: 0
      system.adapter.homeconnect.0            : homeconnect           : iob-ubuntu                               - disabled
      system.adapter.ical.0                   : ical                  : iob-ubuntu                               -  enabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : iob-ubuntu                               - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iob-ubuntu                               - disabled
    + system.adapter.info.0                   : info                  : iob-ubuntu                               -  enabled
    + system.adapter.javascript.0             : javascript            : iob-ubuntu                               -  enabled
    + system.adapter.javascript.1             : javascript            : iob-ubuntu                               -  enabled
    + system.adapter.javascript.2             : javascript            : iob-ubuntu                               -  enabled
    + system.adapter.javascript.3             : javascript            : piPivCCU                                 -  enabled
    + system.adapter.javascript.4             : javascript            : doorpi                                   -  enabled
    + system.adapter.link.0                   : link                  : iob-ubuntu                               -  enabled
      system.adapter.mielecloudservice.0      : mielecloudservice     : iob-ubuntu                               - disabled
    + system.adapter.mqtt.0                   : mqtt                  : iob-ubuntu                               -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.onvif.0                  : onvif                 : iob-ubuntu                               - disabled
    + system.adapter.parcel.0                 : parcel                : iob-ubuntu                               -  enabled
    + system.adapter.ping.0                   : ping                  : iob-ubuntu                               -  enabled
      system.adapter.pollenflug.0             : pollenflug            : iob-ubuntu                               - disabled
      system.adapter.pvforecast.0             : pvforecast            : iob-ubuntu                               - disabled
      system.adapter.repetierserver.0         : repetierserver        : iob-ubuntu                               - disabled
    + system.adapter.rpi2.0                   : rpi2                  : piPivCCU                                 -  enabled
      system.adapter.sayit.0                  : sayit                 : VISFlur                                  - disabled
    + system.adapter.shelly.0                 : shelly                : iob-ubuntu                               -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : iob-ubuntu                               -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartmeter.0             : smartmeter            : piPivCCU                                 -  enabled
    + system.adapter.smartmeter.1             : smartmeter            : piPivCCU                                 -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iob-ubuntu                               -  enabled
    + system.adapter.sql.0                    : sql                   : iob-ubuntu                               -  enabled, port: 3306
      system.adapter.sql.1                    : sql                   : iob-ubuntu                               - disabled, port: 3306
    + system.adapter.statistics.0             : statistics            : iob-ubuntu                               -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iob-ubuntu                               -  enabled
    + system.adapter.telegram.0               : telegram              : iob-ubuntu                               -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.terminal.0               : terminal              : doorpi                                   -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
      system.adapter.terminal.1               : terminal              : iob-ubuntu                               - disabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.tr-064.0                 : tr-064                : iob-ubuntu                               -  enabled
    + system.adapter.tuya.0                   : tuya                  : iob-ubuntu                               -  enabled
    + system.adapter.upnp.0                   : upnp                  : iob-ubuntu                               -  enabled
      system.adapter.vis-bars.0               : vis-bars              : iob-ubuntu                               - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iob-ubuntu                               - disabled
      system.adapter.vis-history.0            : vis-history           : iob-ubuntu                               - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iob-ubuntu                               - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : iob-ubuntu                               - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iob-ubuntu                               - disabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : iob-ubuntu                               - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : iob-ubuntu                               - disabled
      system.adapter.vis-material.0           : vis-material          : iob-ubuntu                               - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iob-ubuntu                               - disabled
      system.adapter.vis-metro.0              : vis-metro             : iob-ubuntu                               - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : iob-ubuntu                               - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iob-ubuntu                               - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iob-ubuntu                               - disabled
      system.adapter.vis-weather.0            : vis-weather           : iob-ubuntu                               - disabled
      system.adapter.vis.0                    : vis                   : iob-ubuntu                               -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : iob-ubuntu                               -  enabled
      system.adapter.weatherunderground.1     : weatherunderground    : doorpi                                   - disabled
    + system.adapter.web.0                    : web                   : iob-ubuntu                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iob-ubuntu                               -  enabled
      system.adapter.windows-control.0        : windows-control       : iob-ubuntu                               - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 6.14.1   , installed 6.14.1
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.10.11  , installed 2.10.11
    Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
    Adapter    "ecovacs-deebot": 1.4.14  , installed 1.4.14
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "gruenbeck"    : 0.0.42   , installed 0.0.42
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
    Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
    Adapter    "ical"         : 1.14.2   , installed 1.14.2
    Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "link"         : 0.5.12   , installed 0.5.12
    Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "onvif"        : 1.1.2    , installed 1.1.2
    Adapter    "parcel"       : 0.2.7    , installed 0.2.7
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
    Adapter    "shelly"       : 6.8.0    , installed 6.8.0
    Adapter    "socketio"     : 6.6.1    , installed 6.6.1
    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
    Adapter    "sql"          : 2.2.0    , installed 2.2.0
    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
    Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
    Adapter    "telegram"     : 3.1.0    , installed 3.1.0
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
    Adapter    "tuya"         : 3.15.0   , installed 3.15.0
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-material" : 0.1.3    , installed 0.1.3
    Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
    Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "windows-control": 0.1.5  , installed 0.1.5
    Adapter    "ws"           : 2.5.11   , installed 2.5.11
    Objects and States
    Objects:        16680
    States:         12396
    W: GPG error: https://deb.nodesource.com/node_18.x jammy InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 1655A0AB68576280
    E: The repository 'https://deb.nodesource.com/node_18.x jammy InRelease' is not signed.
    Pending Updates: 1
    *** Listening Ports ***
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        22581      634/systemd-resolve
    tcp        0      0 192.168.137.9:2001      0.0.0.0:*               LISTEN      1000       74428      9493/io.hm-rpc.0
    tcp        0      0 192.168.137.9:2010      0.0.0.0:*               LISTEN      1000       76092      9512/io.hm-rpc.1
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          19150      1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          2924       696/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       74988      9317/iobroker.js-co
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       74995      9317/iobroker.js-co
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       76117      9545/io.mqtt.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       76116      9545/io.mqtt.0
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       181646     13688/io.shelly.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1000       77176      10186/io.simple-api
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       73464      9637/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       75045      9335/io.admin.0
    tcp6       0      0 :::111                  :::*                    LISTEN      0          2295       1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          2926       696/sshd: /usr/sbin
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        22580      634/systemd-resolve
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          19663      1/init
    udp        0      0 192.168.137.9:5353      0.0.0.0:*                           1000       167139     13352/io.tr-064.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       78958      10248/io.upnp.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       75347      9622/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       75348      9622/io.tuya.0
    udp6       0      0 :::111                  :::*                                0          19151      1/init
    2024-02-24 10:08:08.699  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T3.VOLTAGEist 23.5°C // 2.55V
    2024-02-24 10:08:08.699  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
    2024-02-24 10:10:00.004  - info: javascript.1 (9377) script.js.Stable.Wassertank: Regenwasser: RawLevel=38 / Korr Proz:100% / Liter:5714
    2024-02-24 10:15:00.004  - info: javascript.1 (9377) script.js.Stable.Wassertank: Regenwasser: RawLevel=38 / Korr Proz:100% / Liter:5714
    2024-02-24 10:15:00.362  - info: statistics.0 (10216) State value to set for "statistics.0.save.avg.upnp.0.WANDevice_-_FRITZ!Box_6842_LTE.WANDevice.WANCommonInterfaceConfig.GetAddonInfos.NewTotalBytesReceived.15MinAvg" has to be type "number" but received type "string"
    2024-02-24 10:15:00.409  - info: statistics.0 (10216) State value to set for "statistics.0.temp.avg.upnp.0.WANDevice_-_FRITZ!Box_6842_LTE.WANDevice.WANCommonInterfaceConfig.GetAddonInfos.NewTotalBytesReceived.15MinAvg" has to be type "number" but received type "string"
    2024-02-24 10:15:00.457  - info: statistics.0 (10216) State value to set for "statistics.0.temp.avg.upnp.0.WANDevice_-_FRITZ!Box_6842_LTE.WANDevice.WANCommonInterfaceConfig.GetAddonInfos.NewTotalBytesReceived.15MinSum" has to be type "number" but received type "string"
    2024-02-24 10:15:24.548  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T0.VOLTAGEist 35.5°C // 3.74V
    2024-02-24 10:15:24.548  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
    2024-02-24 10:15:25.339  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T1.VOLTAGEist 23.7°C // 2.57V
    2024-02-24 10:15:25.339  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
    2024-02-24 10:15:25.354  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T2.VOLTAGEist 24.1°C // 2.61V
    2024-02-24 10:15:25.354  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
    2024-02-24 10:15:25.443  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T3.VOLTAGEist 23.4°C // 2.54V
    2024-02-24 10:15:25.443  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
    2024-02-24 10:20:00.005  - info: javascript.1 (9377) script.js.Stable.Wassertank: Regenwasser: RawLevel=38 / Korr Proz:100% / Liter:5714
    2024-02-24 10:22:42.339  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T0.VOLTAGEist 35.6°C // 3.75V
    2024-02-24 10:22:42.340  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
    2024-02-24 10:22:42.543  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T1.VOLTAGEist 23.8°C // 2.58V
    2024-02-24 10:22:42.544  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
    2024-02-24 10:22:42.545  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T2.VOLTAGEist 23.7°C // 2.57V
    2024-02-24 10:22:42.546  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
    2024-02-24 10:22:42.550  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T3.VOLTAGEist 23.4°C // 2.54V
    2024-02-24 10:22:42.550  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
    2024-02-24 10:25:00.006  - info: javascript.1 (9377) script.js.Stable.Wassertank: Regenwasser: RawLevel=38 / Korr Proz:100% / Liter:5714
    Danke für's Checken.
    #1321
    @thisoft
    sudo systemctl set-default multi-user.target
    iob nodejs-update 18
    Und meld dich nicht als user iobroker an sondern als der user mit der UserID 1000. Wie auch immer der heißt.
    grep 1000 /etc/passwd
    sagt dir das.
    ThisoftT 2 Antworten Letzte Antwort
      @thisoft
      sagt dir das.
      ThisoftT Offline
      ThisoftT Offline
      Thisoft
      #1322
      sagt mir:
      iobroker@iob-ubuntu:~$ grep 1000 /etc/passwd
      iobroker:x:1000:1000:iobroker:/home/iobroker:/bin/bash
      muss ich irgendwie nicht verstehen... wüsste auch nicht dass ich bewusst einen anderen User angelegt hätte...
        @thisoft
        sagt dir das.
        ThisoftT Offline
        ThisoftT Offline
        Thisoft
        schrieb am zuletzt editiert von Thisoft
        #1323
        sorry, aber was soll mir das sagen?
        • ThisoftT Thisoft
          #1324
          @thisoft sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
          Das sollst du in deinem Terminal ausführen.
          ThisoftT 1 Antwort Letzte Antwort
            ThisoftT Offline
            ThisoftT Offline
            Thisoft
            #1325
            OK. Hab ich. Und jetzt nochmal iob diag
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                     Chassis: vm
              Virtualization: kvm
            Docker          : false
            Kernel          : x86_64
            Userland        : amd64
             16:00:27 up 6 min,  2 users,  load average: 0.29, 0.30, 0.15
            CPU threads: 8
                           Local time: Sat 2024-02-24 16:00:27 CET
                       Universal time: Sat 2024-02-24 15:00:27 UTC
                             RTC time: Sat 2024-02-24 15:00:27
                          NTP service: active
                      RTC in local TZ: no
            iobroker
            /home/iobroker
            X-Server:       false
            Desktop:
            Terminal:       tty
            Boot Target:    multi-user.target
            *** MEMORY ***
            Mem:            7.9G        189M        7.2G        1.0M        580M        7.5G
            Swap:           3.1G          0B        3.1G
            Total:           11G        189M         10G
                     7937 M total memory
                      190 M used memory
                      240 M active memory
                      345 M inactive memory
                     7166 M free memory
                       53 M buffer memory
                      527 M swap cache
                     3114 M total swap
                        0 M used swap
                     3114 M free swap
              UNIT             LOAD   ACTIVE SUB    DESCRIPTION
            * iobroker.service loaded failed failed ioBroker Server
            1 loaded units listed.
            *** FILESYSTEM ***
            [sudo] password for iobroker:
            [Sat Feb 24 15:54:27 2024] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
            [Sat Feb 24 15:54:28 2024] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none.
            [Sat Feb 24 15:54:28 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
            |-/snap/lxd/26975     /dev/loop2                        squashfs ro,nodev,relatime,errors=continue
            |-/snap/snapd/20290   /dev/loop3                        squashfs ro,nodev,relatime,errors=continue
            |-/snap/lxd/27037     /dev/loop4                        squashfs ro,nodev,relatime,errors=continue
            /var:
            3.9G    /var/
            3.0G    /var/lib
            Archived and active journals take up 392.1M in the file system.
            352M    /opt/iobroker/iobroker-data/
            33M     /opt/iobroker/iobroker-data/objects.jsonl
            11M     /opt/iobroker/iobroker-data/states.jsonl
            USB-Devices by-id:
            /usr/bin/npm            10.2.4
            /usr/bin/npx            10.2.4
            nodejs:
              Version table:
             *** 18.19.1-1nodesource1 1001
                    500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                 18.19.0-1nodesource1 1001
                 18.18.2-1nodesource1 1001
                 18.18.1-1nodesource1 1001
                 18.18.0-1nodesource1 1001
                 18.17.1-1nodesource1 1001
                 18.17.0-1nodesource1 1001
                 18.16.1-1nodesource1 1001
                 18.16.0-1nodesource1 1001
                 18.15.0-1nodesource1 1001
                 18.14.2-1nodesource1 1001
                 18.14.1-1nodesource1 1001
                 18.14.0-1nodesource1 1001
                 18.13.0-1nodesource1 1001
                 18.12.0-1nodesource1 1001
                 18.11.0-1nodesource1 1001
                 18.10.0-1nodesource1 1001
                 18.9.1-1nodesource1 1001
                 18.9.0-1nodesource1 1001
                 18.8.0-1nodesource1 1001
                 18.7.0-1nodesource1 1001
                 18.6.0-1nodesource1 1001
                 18.5.0-1nodesource1 1001
                 18.4.0-1nodesource1 1001
                 18.3.0-1nodesource1 1001
                 18.2.0-1nodesource1 1001
                 18.1.0-1nodesource1 1001
                 18.0.0-1nodesource1 1001
            Errors in npm tree:
            ioBroker Status
            Server Configured backup period 7200000 is larger than the supported maximum of 35791 minutes. Defaulting to 120 minutes.
            iobroker is not running on this host.
            Objects type: jsonl
            States  type: jsonl
            admin:          6.14.1
            javascript:     7.8.0
            Adapter State
            + instance is alive
            Objects and States
            Objects:        16682
            States:         12104
            Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
            Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
            Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
            Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
            Hit:5 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
            Reading package lists...
            Pending Updates: 0
            tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        2695       637/systemd-resolve
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          16297      1/init
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          23780      699/sshd: /usr/sbin
            tcp6       0      0 :::111                  :::*                    LISTEN      0          19827      1/init
            tcp6       0      0 :::22                   :::*                    LISTEN      0          23791      699/sshd: /usr/sbin
            udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        2694       637/systemd-resolve
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2340       1/init
            udp6       0      0 :::111                  :::*                                0          2343       1/init
            2024-02-24 15:59:34.769  - info: host.iob-ubuntu instance system.adapter.javascript.1 terminated with code 0 (NO_ERROR)
            2024-02-24 15:59:34.811  - info: host.iob-ubuntu instance system.adapter.javascript.2 terminated with code 0 (NO_ERROR)
            2024-02-24 15:59:34.812  - info: host.iob-ubuntu instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
            2024-02-24 15:59:34.848  - info: host.iob-ubuntu instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
            2024-02-24 15:59:34.848  - info: host.iob-ubuntu instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
            2024-02-24 15:59:34.861  - info: host.iob-ubuntu instance system.adapter.statistics.0 terminated with code 0 (NO_ERROR)
            2024-02-24 15:59:34.874  - info: host.iob-ubuntu instance system.adapter.tankerkoenig.0 terminated with code 0 (NO_ERROR)
            2024-02-24 15:59:35.068  - warn: host.iob-ubuntu instance system.adapter.telegram.0 terminated due to SIGTERM
            2024-02-24 15:59:35.068  - info: host.iob-ubuntu instance system.adapter.telegram.0 terminated with code null ()
            2024-02-24 15:59:35.092  - warn: host.iob-ubuntu instance system.adapter.whatsapp-cmb.0 terminated due to SIGTERM
            2024-02-24 15:59:35.092  - info: host.iob-ubuntu instance system.adapter.whatsapp-cmb.0 terminated with code null ()
            2024-02-24 15:59:35.092  - warn: host.iob-ubuntu instance system.adapter.hm-rega.0 terminated due to SIGTERM
            2024-02-24 15:59:35.092  - info: host.iob-ubuntu instance system.adapter.hm-rega.0 terminated with code null ()
            2024-02-24 15:59:35.122  - warn: host.iob-ubuntu instance system.adapter.hm-rpc.1 terminated due to SIGTERM
            2024-02-24 15:59:35.122  - info: host.iob-ubuntu instance system.adapter.hm-rpc.1 terminated with code null ()
            2024-02-24 15:59:35.122  - warn: host.iob-ubuntu instance system.adapter.ping.0 terminated due to SIGTERM
            2024-02-24 15:59:35.122  - info: host.iob-ubuntu instance system.adapter.ping.0 terminated with code null ()
            2024-02-24 15:59:35.143  - warn: host.iob-ubuntu instance system.adapter.web.0 terminated due to SIGTERM
            2024-02-24 15:59:35.143  - info: host.iob-ubuntu instance system.adapter.web.0 terminated with code null ()
            2024-02-24 15:59:35.188  - info: host.iob-ubuntu instance system.adapter.sql.0 terminated with code 0 (NO_ERROR)
            2024-02-24 15:59:36.360  - info: tuya.0 (1198) terminating
            2024-02-24 15:59:36.361  - info: tuya.0 (1198) Terminated (NO_ERROR): Without reason
            2024-02-24 15:59:36.913  - info: host.iob-ubuntu instance system.adapter.tuya.0 terminated with code 0 (NO_ERROR)
            2024-02-24 15:59:36.913  - info: host.iob-ubuntu All instances are stopped.
            2024-02-24 15:59:37.111  - info: host.iob-ubuntu terminated
            • ThisoftT Thisoft
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                       Chassis: vm
                Virtualization: kvm
              Docker          : false
              Kernel          : x86_64
              Userland        : amd64
              CPU threads: 8
                            NTP service: active
                        RTC in local TZ: no
              iobroker
              /home/iobroker
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:           3.1G          0B        3.1G
              Total:           11G        189M         10G
                       7937 M total memory
                        190 M used memory
                        240 M active memory
                       7166 M free memory
                         53 M buffer memory
                        527 M swap cache
                       3114 M total swap
                          0 M used swap
                       3114 M free swap
              *** FILESYSTEM ***
              /var:
              3.9G    /var/
              3.0G    /var/lib
              USB-Devices by-id:
              /usr/bin/npm            10.2.4
              /usr/bin/npx            10.2.4
              nodejs:
                Version table:
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.14.1
              javascript:     7.8.0
              Adapter State
              + instance is alive
              Objects and States
              Objects:        16682
              States:         12104
              Pending Updates: 0
              #1326
              @thisoft
              https://forum.iobroker.net/topic/54655/probleme-von-4-0-21-auf-4-0-23/16
              Und dann den iobroker wieder starten.
                @thisoft
                ThisoftT Offline
                ThisoftT Offline
                Thisoft
                #1327
                Hab ich gemacht. Das wäre dann alles?
                • ThisoftT Thisoft
                  #1328
                  @thisoft
                  Läuft der iobroker denn nun wieder ohne Meldungen?
                    @thisoft
                    ThisoftT Offline
                    ThisoftT Offline
                    Thisoft
                    #1329
                    Ja tut er. Er hatte auch vorher nur das Problem dass der Parcel-Adapter sich nicht bei DHL eingeloggt hat. Was ja offensichtlich erst ab nodejs 18.19.1 wieder funktioniert. Ansonsten hatte ich kein Problem damit. Aber wenn das jetzt alles sauber gefixt ist umso besser.
                    • bahnuhrB Online
                      bahnuhrB Online
                      bahnuhr
                      #1330
                      Guten Abend,
                      muss jetzt auch mal fragen zur grundsätzlichen Vorgehensweise
                      a) DHL
                      Habe meinen Benutzer und Pass eingegeben und die Daten kommen.
                      Für was ist der Pin-Code ?
                      Braucht man den und für was?
                      Daten kommen ja an.
                      b) Hermes
                      Habe mich dort angemeldet. Aber die Lieferung war nicht automatisch drin. Musste die Nr. manuell einpflegen.
                      Braucht man dafür dann 17Track?
                      Also die Mails weiter leiten an 17Track und diese analysieren die Mails und senden dann die Daten an den Adapter.
                      Richtig ?
                      c) Wie funktioniert dies bei DPD, GLS, UPS, Amazon?
                      Hier habe ich noch nichts.
                      Muss ich einen Benutzer überall anmelden und dann jedesmal 17Track ?
                      mfg
                      Dieter
                      Danke.
                      • bahnuhrB Online
                        bahnuhrB Online
                        bahnuhr
                        #1331
                        Datum, Uhrzeit anzeigen:
                        Habe hier des öfteren schon gesehen, dass auch das Datum + Uhrzeit in VIS angezeigt wird.
                        Bei mir nicht.
                        Aber im DP sind die Daten wohl drin.
                        Frage:
                        Wie bekomme ich Datum und Uhrzeit angezeigt ?
                        Danke.
                        • bahnuhrB Online
                          bahnuhrB Online
                          bahnuhr
                          #1332
                          So, und nun letzte Frage zu Hermes
                          Hatte ja die Nr. manuell bei Hermes eingetragen. Dies wurde dann auch übertragen.
                          Im DP steht auch der Absender:
                          In VIS nicht, dort "undefined"
                          So, das wars erst einmal.
                          Danke.
                          • bahnuhrB bahnuhr
                            DJMarc75D Offline
                            DJMarc75D Offline
                            DJMarc75
                            #1333
                            @bahnuhr
                            Im Prinzip empfängt der Adapter nur die Daten vom jeweiligen Provider.
                            Und die Provider sind schon zeitweise recht "kacke" ;)
                            Da ändert jeder Provider öfter mal die Daten und der Developer kommt da fast nicht nach.
                            Ich verlasse mich schon ewig nur noch auf DHL, der Rest ist für mich nur "Spass" da es meist nicht zuverlässig klappt (GLS ist eine Katastrophe)
                            Amazon nutze ich nicht da dies ja anscheinend zum Ko**en ist, da die Vögel da immer was ändern.
                            Ist aber nur meine eigene Erfahrung und kann bei anderen Usern auch besser funktionieren.
                            Lehrling seit 1975 !!!
                            • DJMarc75D DJMarc75
                              @bahnuhr
                              bahnuhrB Online
                              bahnuhrB Online
                              bahnuhr
                              #1334
                              @djmarc75
                              Muss man sich bei gls anmelden ?
                              Oder reicht die Mail Weiterleitung an 17track ?
                              Danke.
                              • bahnuhrB bahnuhr
                                @djmarc75
                                DJMarc75D Offline
                                DJMarc75D Offline
                                DJMarc75
                                #1335
                                @bahnuhr sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                                Na man muss sich mMn schon bei jedem Provider anmelden.
                                Mit 17track hab ich keine Erfahrungen.
                                  bahnuhrB Online
                                  bahnuhrB Online
                                  bahnuhr
                                  #1336
                                  @djmarc75 sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                                  Ich habe das so verstanden, dass man eine Mail Weiterleitung an 17track macht. Und diese nehmen die Mail dann auseinander und der Adapter holt die Daten von 17track.
                                  Dann würde es keine Anmeldung beim provider brauchen.
                                  Danke.
                                  • bahnuhrB bahnuhr
                                    DJMarc75D Offline
                                    DJMarc75D Offline
                                    DJMarc75
                                    #1337
                                    @bahnuhr Da musst Du mal im ersten Beitrag nachlesen, das weiß ich leider nicht.
                                      bahnuhrB Online
                                      bahnuhrB Online
                                      bahnuhr
                                      #1338
                                      Der ist gut.
                                      Da hab ich schon 50x gelesen. Aber offensichtlich nicht die richtigen Infos gefunden.
                                      Danke.
                                      • bahnuhrB bahnuhr
                                        Der ist gut.
                                        DJMarc75D Offline
                                        DJMarc75D Offline
                                        DJMarc75
                                        #1339
                                        @bahnuhr
                                        17Track User maximal 40 Pakete gleichzeitig:
                                        https://buyer.17track.net/en/myshipment?ob=1
                                        17Track Api developer maximal 100 Anfragen dann muss bezahlt werden
                                        Hier ein Security Key beantragen und in die Einstellungen eingeben geht nur wenn man kein 17Track User ist
                                        https://user.17track.net/de/register?gb=%23maybe%3D16
                                        https://api.17track.net/en/admin/settings
                                        Aber ich hab das noch nie genutzt 🤡
                                        Bin da eher Retro 😁
                                        ? 1 Antwort Letzte Antwort
                                          @bahnuhr
                                          Bin da eher Retro 😁
                                          #1340
                                          @djmarc75
                                          ist es jetzt möglich Sich das Bild der Briefankündigung per Telegramm zuschicken zu lassen bzw. die Daten der Briefankündigung?
