  4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
17trackamazonbriefedhldpdglsups
1.6k Beiträge 129 Kommentatoren 737.9k Aufrufe 117 Beobachtet
    @thisoft sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
    Pending iob updates: 6
    Hau die Updates druff.
    Und dann die Langfassung bitte.
    Und schau mal danach:
    du -h /opt/iobroker/iobroker-data/backup-objects/
    https://forum.iobroker.net/topic/54655/probleme-von-4-0-21-auf-4-0-23/16
    ThisoftT Offline
    ThisoftT Offline
    Thisoft
    #1320
    @thomas-braun sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
    109M    /opt/iobroker/iobroker-data/backup-objects/
    Und hier die Langfassung von iob diag:
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: iob-ubuntu
           Icon name: computer-vm
             Chassis: vm
      Virtualization: kvm
    Operating System: Ubuntu 22.04.4 LTS
              Kernel: Linux 5.15.0-97-generic
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    model name      : Common KVM processor
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     10:28:27 up 10:25,  2 users,  load average: 0.19, 0.29, 0.21
    CPU threads: 8
    *** Time and Time Zones ***
                   Local time: Sat 2024-02-24 10:28:27 CET
               Universal time: Sat 2024-02-24 09:28:27 UTC
                     RTC time: Sat 2024-02-24 09:28:27
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    iobroker
    /home/iobroker
    iobroker adm tty dialout cdrom sudo audio dip video plugdev lxd
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            7.9G        2.9G        3.3G        1.0M        1.8G        4.8G
    Swap:           3.1G          0B        3.1G
    Total:           11G        2.9G        6.4G
             7937 M total memory
             2872 M used memory
              748 M active memory
             3401 M inactive memory
             3262 M free memory
              269 M buffer memory
             1532 M swap cache
             3114 M total swap
                0 M used swap
             3114 M free swap
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                        Type   Size  Used Avail Use% Mounted on
    tmpfs                             tmpfs  794M  1.1M  793M   1% /run
    /dev/mapper/ubuntu--vg-ubuntu--lv ext4    15G   12G  2.3G  84% /
    tmpfs                             tmpfs  3.9G     0  3.9G   0% /dev/shm
    tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
    /dev/sda2                         ext4   2.0G  251M  1.6G  14% /boot
    //192.168.137.42/motion           cifs   869G  840G   30G  97% /var/lib/motion/NAS
    tmpfs                             tmpfs  794M  4.0K  794M   1% /run/user/1000
    [Sat Feb 24 00:03:06 2024] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Sat Feb 24 00:03:07 2024] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none.
    [Sat Feb 24 00:03:08 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    TARGET                SOURCE                            FSTYPE   OPTIONS
    /                     /dev/mapper/ubuntu--vg-ubuntu--lv ext4     rw,relatime
    |-/snap/core20/2105   /dev/loop0                        squashfs ro,nodev,relatime,errors=continue
    |-/snap/core20/2182   /dev/loop1                        squashfs ro,nodev,relatime,errors=continue
    |-/snap/lxd/27037     /dev/loop2                        squashfs ro,nodev,relatime,errors=continue
    |-/snap/lxd/26975     /dev/loop3                        squashfs ro,nodev,relatime,errors=continue
    |-/snap/snapd/20671   /dev/loop5                        squashfs ro,nodev,relatime,errors=continue
    |-/snap/snapd/20290   /dev/loop4                        squashfs ro,nodev,relatime,errors=continue
    |-/boot               /dev/sda2                         ext4     rw,relatime
    `-/var/lib/motion/NAS //192.168.137.42/motion           cifs     rw,relatime,vers=default,cache=strict,username=motion,uid=1001,forceuid,gid=0,noforcegid,addr=192.168.137.42,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=1048576,wsize=1048576,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=1
    /var:
    3.9G    /var/
    3.0G    /var/lib
    2.2G    /var/lib/motion/NAS
    1.9G    /var/lib/motion/NAS/Cam4
    Archived and active journals take up 384.1M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    346M    /opt/iobroker/iobroker-data/
    199M    /opt/iobroker/iobroker-data/files
    57M     /opt/iobroker/iobroker-data/files/javascript.admin
    38M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    31M     /opt/iobroker/iobroker-data/objects.jsonl
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
    8.2M    /opt/iobroker/iobroker-data/states.jsonl
    7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.1
    /usr/bin/node           v18.19.1
    /usr/bin/npm            10.2.4
    /usr/bin/npx            10.2.4
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.1-1nodesource1
      Candidate: 18.19.1-1nodesource1
      Version table:
     *** 18.19.1-1nodesource1 100
         12.22.9~dfsg-1ubuntu3.3 500
            500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
            500 http://de.archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
         12.22.9~dfsg-1ubuntu3 500
            500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.19
    admin:          6.14.1
    javascript:     7.8.0
    Adapters from github:   1
    Adapter State
    + system.adapter.admin.0                  : admin                 : iob-ubuntu                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alias-manager.0          : alias-manager         : iob-ubuntu                               - disabled
    + system.adapter.backitup.0               : backitup              : iob-ubuntu                               -  enabled
      system.adapter.daswetter.0              : daswetter             : iob-ubuntu                               -  enabled
      system.adapter.daswetter.1              : daswetter             : iob-ubuntu                               - disabled
      system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : iob-ubuntu                               - disabled
      system.adapter.feiertage.0              : feiertage             : iob-ubuntu                               -  enabled
      system.adapter.flot.0                   : flot                  : iob-ubuntu                               - disabled
      system.adapter.gruenbeck.0              : gruenbeck             : iob-ubuntu                               - disabled
    + system.adapter.hm-rega.0                : hm-rega               : iob-ubuntu                               -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iob-ubuntu                               -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iob-ubuntu                               -  enabled, port: 0
      system.adapter.homeconnect.0            : homeconnect           : iob-ubuntu                               - disabled
      system.adapter.ical.0                   : ical                  : iob-ubuntu                               -  enabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : iob-ubuntu                               - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iob-ubuntu                               - disabled
    + system.adapter.info.0                   : info                  : iob-ubuntu                               -  enabled
    + system.adapter.javascript.0             : javascript            : iob-ubuntu                               -  enabled
    + system.adapter.javascript.1             : javascript            : iob-ubuntu                               -  enabled
    + system.adapter.javascript.2             : javascript            : iob-ubuntu                               -  enabled
    + system.adapter.javascript.3             : javascript            : piPivCCU                                 -  enabled
    + system.adapter.javascript.4             : javascript            : doorpi                                   -  enabled
    + system.adapter.link.0                   : link                  : iob-ubuntu                               -  enabled
      system.adapter.mielecloudservice.0      : mielecloudservice     : iob-ubuntu                               - disabled
    + system.adapter.mqtt.0                   : mqtt                  : iob-ubuntu                               -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.onvif.0                  : onvif                 : iob-ubuntu                               - disabled
    + system.adapter.parcel.0                 : parcel                : iob-ubuntu                               -  enabled
    + system.adapter.ping.0                   : ping                  : iob-ubuntu                               -  enabled
      system.adapter.pollenflug.0             : pollenflug            : iob-ubuntu                               - disabled
      system.adapter.pvforecast.0             : pvforecast            : iob-ubuntu                               - disabled
      system.adapter.repetierserver.0         : repetierserver        : iob-ubuntu                               - disabled
    + system.adapter.rpi2.0                   : rpi2                  : piPivCCU                                 -  enabled
      system.adapter.sayit.0                  : sayit                 : VISFlur                                  - disabled
    + system.adapter.shelly.0                 : shelly                : iob-ubuntu                               -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : iob-ubuntu                               -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartmeter.0             : smartmeter            : piPivCCU                                 -  enabled
    + system.adapter.smartmeter.1             : smartmeter            : piPivCCU                                 -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iob-ubuntu                               -  enabled
    + system.adapter.sql.0                    : sql                   : iob-ubuntu                               -  enabled, port: 3306
      system.adapter.sql.1                    : sql                   : iob-ubuntu                               - disabled, port: 3306
    + system.adapter.statistics.0             : statistics            : iob-ubuntu                               -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iob-ubuntu                               -  enabled
    + system.adapter.telegram.0               : telegram              : iob-ubuntu                               -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.terminal.0               : terminal              : doorpi                                   -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
      system.adapter.terminal.1               : terminal              : iob-ubuntu                               - disabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.tr-064.0                 : tr-064                : iob-ubuntu                               -  enabled
    + system.adapter.tuya.0                   : tuya                  : iob-ubuntu                               -  enabled
    + system.adapter.upnp.0                   : upnp                  : iob-ubuntu                               -  enabled
      system.adapter.vis-bars.0               : vis-bars              : iob-ubuntu                               - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iob-ubuntu                               - disabled
      system.adapter.vis-history.0            : vis-history           : iob-ubuntu                               - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iob-ubuntu                               - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : iob-ubuntu                               - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iob-ubuntu                               - disabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : iob-ubuntu                               - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : iob-ubuntu                               - disabled
      system.adapter.vis-material.0           : vis-material          : iob-ubuntu                               - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iob-ubuntu                               - disabled
      system.adapter.vis-metro.0              : vis-metro             : iob-ubuntu                               - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : iob-ubuntu                               - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iob-ubuntu                               - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iob-ubuntu                               - disabled
      system.adapter.vis-weather.0            : vis-weather           : iob-ubuntu                               - disabled
      system.adapter.vis.0                    : vis                   : iob-ubuntu                               -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : iob-ubuntu                               -  enabled
      system.adapter.weatherunderground.1     : weatherunderground    : doorpi                                   - disabled
    + system.adapter.web.0                    : web                   : iob-ubuntu                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iob-ubuntu                               -  enabled
      system.adapter.windows-control.0        : windows-control       : iob-ubuntu                               - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 6.14.1   , installed 6.14.1
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.10.11  , installed 2.10.11
    Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
    Adapter    "ecovacs-deebot": 1.4.14  , installed 1.4.14
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "gruenbeck"    : 0.0.42   , installed 0.0.42
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
    Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
    Adapter    "ical"         : 1.14.2   , installed 1.14.2
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "link"         : 0.5.12   , installed 0.5.12
    Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "onvif"        : 1.1.2    , installed 1.1.2
    Adapter    "parcel"       : 0.2.7    , installed 0.2.7
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
    Adapter    "shelly"       : 6.8.0    , installed 6.8.0
    Adapter    "socketio"     : 6.6.1    , installed 6.6.1
    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
    Adapter    "telegram"     : 3.1.0    , installed 3.1.0
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "tuya"         : 3.15.0   , installed 3.15.0
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-material" : 0.1.3    , installed 0.1.3
    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "windows-control": 0.1.5  , installed 0.1.5
    Adapter    "ws"           : 2.5.11   , installed 2.5.11
    Objects and States
    Objects:        16680
    States:         12396
    W: GPG error: https://deb.nodesource.com/node_18.x jammy InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 1655A0AB68576280
    E: The repository 'https://deb.nodesource.com/node_18.x jammy InRelease' is not signed.
    Pending Updates: 1
    *** Listening Ports ***
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        22581      634/systemd-resolve
    tcp        0      0 192.168.137.9:2001      0.0.0.0:*               LISTEN      1000       74428      9493/io.hm-rpc.0
    tcp        0      0 192.168.137.9:2010      0.0.0.0:*               LISTEN      1000       76092      9512/io.hm-rpc.1
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          19150      1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          2924       696/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       74988      9317/iobroker.js-co
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       74995      9317/iobroker.js-co
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       76117      9545/io.mqtt.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       76116      9545/io.mqtt.0
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       181646     13688/io.shelly.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1000       77176      10186/io.simple-api
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       73464      9637/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       75045      9335/io.admin.0
    tcp6       0      0 :::111                  :::*                    LISTEN      0          2295       1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          2926       696/sshd: /usr/sbin
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        22580      634/systemd-resolve
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          19663      1/init
    udp        0      0 192.168.137.9:5353      0.0.0.0:*                           1000       167139     13352/io.tr-064.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       78958      10248/io.upnp.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       75347      9622/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       75348      9622/io.tuya.0
    udp6       0      0 :::111                  :::*                                0          19151      1/init
    2024-02-24 10:08:08.699  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T3.VOLTAGEist 23.5°C // 2.55V
    2024-02-24 10:08:08.699  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
    2024-02-24 10:10:00.004  - info: javascript.1 (9377) script.js.Stable.Wassertank: Regenwasser: RawLevel=38 / Korr Proz:100% / Liter:5714
    2024-02-24 10:15:00.004  - info: javascript.1 (9377) script.js.Stable.Wassertank: Regenwasser: RawLevel=38 / Korr Proz:100% / Liter:5714
    2024-02-24 10:15:00.362  - info: statistics.0 (10216) State value to set for "statistics.0.save.avg.upnp.0.WANDevice_-_FRITZ!Box_6842_LTE.WANDevice.WANCommonInterfaceConfig.GetAddonInfos.NewTotalBytesReceived.15MinAvg" has to be type "number" but received type "string"
    2024-02-24 10:15:00.409  - info: statistics.0 (10216) State value to set for "statistics.0.temp.avg.upnp.0.WANDevice_-_FRITZ!Box_6842_LTE.WANDevice.WANCommonInterfaceConfig.GetAddonInfos.NewTotalBytesReceived.15MinAvg" has to be type "number" but received type "string"
    2024-02-24 10:15:00.457  - info: statistics.0 (10216) State value to set for "statistics.0.temp.avg.upnp.0.WANDevice_-_FRITZ!Box_6842_LTE.WANDevice.WANCommonInterfaceConfig.GetAddonInfos.NewTotalBytesReceived.15MinSum" has to be type "number" but received type "string"
    2024-02-24 10:15:24.548  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T0.VOLTAGEist 35.5°C // 3.74V
    2024-02-24 10:15:24.548  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
    2024-02-24 10:15:25.339  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T1.VOLTAGEist 23.7°C // 2.57V
    2024-02-24 10:15:25.339  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
    2024-02-24 10:15:25.354  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T2.VOLTAGEist 24.1°C // 2.61V
    2024-02-24 10:15:25.354  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
    2024-02-24 10:15:25.443  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T3.VOLTAGEist 23.4°C // 2.54V
    2024-02-24 10:15:25.443  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
    2024-02-24 10:20:00.005  - info: javascript.1 (9377) script.js.Stable.Wassertank: Regenwasser: RawLevel=38 / Korr Proz:100% / Liter:5714
    2024-02-24 10:22:42.339  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T0.VOLTAGEist 35.6°C // 3.75V
    2024-02-24 10:22:42.340  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
    2024-02-24 10:22:42.543  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T1.VOLTAGEist 23.8°C // 2.58V
    2024-02-24 10:22:42.544  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
    2024-02-24 10:22:42.545  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T2.VOLTAGEist 23.7°C // 2.57V
    2024-02-24 10:22:42.546  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
    2024-02-24 10:22:42.550  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur HzEG: FuBoPlatine_T3.VOLTAGEist 23.4°C // 2.54V
    2024-02-24 10:22:42.550  - info: javascript.1 (9377) script.js.InArbeit.FuBoHeizung: Temperatur FussbodenWoZi: 22.25
    2024-02-24 10:25:00.006  - info: javascript.1 (9377) script.js.Stable.Wassertank: Regenwasser: RawLevel=38 / Korr Proz:100% / Liter:5714
    Danke für's Checken.
    22 HM-Geräte; PivCCU2 auf RasPi
    ioBroker-Multihost; Ubuntu-Master auf Intel-Atom und 3 RasPi-Clients
    • ThisoftT Thisoft
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Chassis: vm
        Virtualization: kvm
      Docker          : false
      Kernel          : x86_64
      Userland        : amd64
      CPU threads: 8
                    NTP service: active
                RTC in local TZ: no
      iobroker
      /home/iobroker
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           3.1G          0B        3.1G
               7937 M total memory
               2872 M used memory
                748 M active memory
               3262 M free memory
                269 M buffer memory
               1532 M swap cache
               3114 M total swap
                  0 M used swap
               3114 M free swap
      *** FILESYSTEM ***
      /var:
      3.9G    /var/
      3.0G    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            10.2.4
      /usr/bin/npx            10.2.4
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.14.1
      javascript:     7.8.0
      Adapter State
      + instance is alive
      Objects and States
      Objects:        16680
      States:         12396
      Pending Updates: 1
      #1321
      @thisoft
      sudo systemctl set-default multi-user.target
      iob nodejs-update 18
      Und meld dich nicht als user iobroker an sondern als der user mit der UserID 1000. Wie auch immer der heißt.
      grep 1000 /etc/passwd
      sagt dir das.
      ThisoftT 2 Antworten Letzte Antwort
        @thisoft
        sagt dir das.
        ThisoftT Offline
        ThisoftT Offline
        Thisoft
        #1322
        sagt mir:
        iobroker@iob-ubuntu:~$ grep 1000 /etc/passwd
        iobroker:x:1000:1000:iobroker:/home/iobroker:/bin/bash
        muss ich irgendwie nicht verstehen... wüsste auch nicht dass ich bewusst einen anderen User angelegt hätte...
          @thisoft
          sagt dir das.
          ThisoftT Offline
          ThisoftT Offline
          Thisoft
          schrieb am zuletzt editiert von Thisoft
          #1323
          sorry, aber was soll mir das sagen?
          • ThisoftT Thisoft
            #1324
            Das sollst du in deinem Terminal ausführen.
            ThisoftT 1 Antwort Letzte Antwort
              ThisoftT Offline
              ThisoftT Offline
              Thisoft
              #1325
              OK. Hab ich. Und jetzt nochmal iob diag
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                       Chassis: vm
                Virtualization: kvm
              Docker          : false
              Kernel          : x86_64
              Userland        : amd64
               16:00:27 up 6 min,  2 users,  load average: 0.29, 0.30, 0.15
              CPU threads: 8
                             Local time: Sat 2024-02-24 16:00:27 CET
                         Universal time: Sat 2024-02-24 15:00:27 UTC
                               RTC time: Sat 2024-02-24 15:00:27
                            NTP service: active
                        RTC in local TZ: no
              iobroker
              /home/iobroker
              X-Server:       false
              Desktop:
              Terminal:       tty
              Boot Target:    multi-user.target
              *** MEMORY ***
              Mem:            7.9G        189M        7.2G        1.0M        580M        7.5G
              Swap:           3.1G          0B        3.1G
              Total:           11G        189M         10G
                       7937 M total memory
                        190 M used memory
                        240 M active memory
                        345 M inactive memory
                       7166 M free memory
                         53 M buffer memory
                        527 M swap cache
                       3114 M total swap
                          0 M used swap
                       3114 M free swap
                UNIT             LOAD   ACTIVE SUB    DESCRIPTION
              * iobroker.service loaded failed failed ioBroker Server
              1 loaded units listed.
              *** FILESYSTEM ***
              [sudo] password for iobroker:
              [Sat Feb 24 15:54:27 2024] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
              [Sat Feb 24 15:54:28 2024] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none.
              [Sat Feb 24 15:54:28 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
              |-/snap/lxd/26975     /dev/loop2                        squashfs ro,nodev,relatime,errors=continue
              |-/snap/snapd/20290   /dev/loop3                        squashfs ro,nodev,relatime,errors=continue
              |-/snap/lxd/27037     /dev/loop4                        squashfs ro,nodev,relatime,errors=continue
              /var:
              3.9G    /var/
              3.0G    /var/lib
              Archived and active journals take up 392.1M in the file system.
              352M    /opt/iobroker/iobroker-data/
              33M     /opt/iobroker/iobroker-data/objects.jsonl
              11M     /opt/iobroker/iobroker-data/states.jsonl
              USB-Devices by-id:
              /usr/bin/npm            10.2.4
              /usr/bin/npx            10.2.4
              nodejs:
                Version table:
               *** 18.19.1-1nodesource1 1001
                      500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                   18.19.0-1nodesource1 1001
                   18.18.2-1nodesource1 1001
                   18.18.1-1nodesource1 1001
                   18.18.0-1nodesource1 1001
                   18.17.1-1nodesource1 1001
                   18.17.0-1nodesource1 1001
                   18.16.1-1nodesource1 1001
                   18.16.0-1nodesource1 1001
                   18.15.0-1nodesource1 1001
                   18.14.2-1nodesource1 1001
                   18.14.1-1nodesource1 1001
                   18.14.0-1nodesource1 1001
                   18.13.0-1nodesource1 1001
                   18.12.0-1nodesource1 1001
                   18.11.0-1nodesource1 1001
                   18.10.0-1nodesource1 1001
                   18.9.1-1nodesource1 1001
                   18.9.0-1nodesource1 1001
                   18.8.0-1nodesource1 1001
                   18.7.0-1nodesource1 1001
                   18.6.0-1nodesource1 1001
                   18.5.0-1nodesource1 1001
                   18.4.0-1nodesource1 1001
                   18.3.0-1nodesource1 1001
                   18.2.0-1nodesource1 1001
                   18.1.0-1nodesource1 1001
                   18.0.0-1nodesource1 1001
              Errors in npm tree:
              ioBroker Status
              Server Configured backup period 7200000 is larger than the supported maximum of 35791 minutes. Defaulting to 120 minutes.
              iobroker is not running on this host.
              Objects type: jsonl
              States  type: jsonl
              admin:          6.14.1
              javascript:     7.8.0
              Adapter State
              + instance is alive
              Objects and States
              Objects:        16682
              States:         12104
              Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
              Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
              Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
              Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
              Hit:5 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
              Reading package lists...
              Pending Updates: 0
              tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        2695       637/systemd-resolve
              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          16297      1/init
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          23780      699/sshd: /usr/sbin
              tcp6       0      0 :::111                  :::*                    LISTEN      0          19827      1/init
              tcp6       0      0 :::22                   :::*                    LISTEN      0          23791      699/sshd: /usr/sbin
              udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        2694       637/systemd-resolve
              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2340       1/init
              udp6       0      0 :::111                  :::*                                0          2343       1/init
              2024-02-24 15:59:34.769  - info: host.iob-ubuntu instance system.adapter.javascript.1 terminated with code 0 (NO_ERROR)
              2024-02-24 15:59:34.811  - info: host.iob-ubuntu instance system.adapter.javascript.2 terminated with code 0 (NO_ERROR)
              2024-02-24 15:59:34.812  - info: host.iob-ubuntu instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
              2024-02-24 15:59:34.848  - info: host.iob-ubuntu instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
              2024-02-24 15:59:34.848  - info: host.iob-ubuntu instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
              2024-02-24 15:59:34.861  - info: host.iob-ubuntu instance system.adapter.statistics.0 terminated with code 0 (NO_ERROR)
              2024-02-24 15:59:34.874  - info: host.iob-ubuntu instance system.adapter.tankerkoenig.0 terminated with code 0 (NO_ERROR)
              2024-02-24 15:59:35.068  - warn: host.iob-ubuntu instance system.adapter.telegram.0 terminated due to SIGTERM
              2024-02-24 15:59:35.068  - info: host.iob-ubuntu instance system.adapter.telegram.0 terminated with code null ()
              2024-02-24 15:59:35.092  - warn: host.iob-ubuntu instance system.adapter.whatsapp-cmb.0 terminated due to SIGTERM
              2024-02-24 15:59:35.092  - info: host.iob-ubuntu instance system.adapter.whatsapp-cmb.0 terminated with code null ()
              2024-02-24 15:59:35.092  - warn: host.iob-ubuntu instance system.adapter.hm-rega.0 terminated due to SIGTERM
              2024-02-24 15:59:35.092  - info: host.iob-ubuntu instance system.adapter.hm-rega.0 terminated with code null ()
              2024-02-24 15:59:35.122  - warn: host.iob-ubuntu instance system.adapter.hm-rpc.1 terminated due to SIGTERM
              2024-02-24 15:59:35.122  - info: host.iob-ubuntu instance system.adapter.hm-rpc.1 terminated with code null ()
              2024-02-24 15:59:35.122  - warn: host.iob-ubuntu instance system.adapter.ping.0 terminated due to SIGTERM
              2024-02-24 15:59:35.122  - info: host.iob-ubuntu instance system.adapter.ping.0 terminated with code null ()
              2024-02-24 15:59:35.143  - warn: host.iob-ubuntu instance system.adapter.web.0 terminated due to SIGTERM
              2024-02-24 15:59:35.143  - info: host.iob-ubuntu instance system.adapter.web.0 terminated with code null ()
              2024-02-24 15:59:35.188  - info: host.iob-ubuntu instance system.adapter.sql.0 terminated with code 0 (NO_ERROR)
              2024-02-24 15:59:36.360  - info: tuya.0 (1198) terminating
              2024-02-24 15:59:36.361  - info: tuya.0 (1198) Terminated (NO_ERROR): Without reason
              2024-02-24 15:59:36.913  - info: host.iob-ubuntu instance system.adapter.tuya.0 terminated with code 0 (NO_ERROR)
              2024-02-24 15:59:36.913  - info: host.iob-ubuntu All instances are stopped.
              2024-02-24 15:59:37.111  - info: host.iob-ubuntu terminated
              • ThisoftT Thisoft
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                         Chassis: vm
                  Virtualization: kvm
                Docker          : false
                Kernel          : x86_64
                Userland        : amd64
                CPU threads: 8
                              NTP service: active
                          RTC in local TZ: no
                iobroker
                /home/iobroker
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:           3.1G          0B        3.1G
                Total:           11G        189M         10G
                         7937 M total memory
                          190 M used memory
                          240 M active memory
                         7166 M free memory
                           53 M buffer memory
                          527 M swap cache
                         3114 M total swap
                            0 M used swap
                         3114 M free swap
                *** FILESYSTEM ***
                /var:
                3.9G    /var/
                3.0G    /var/lib
                USB-Devices by-id:
                /usr/bin/npm            10.2.4
                /usr/bin/npx            10.2.4
                nodejs:
                  Version table:
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.14.1
                javascript:     7.8.0
                Adapter State
                + instance is alive
                Objects and States
                Objects:        16682
                States:         12104
                Pending Updates: 0
                #1326
                @thisoft
                Und dann den iobroker wieder starten.
                  @thisoft
                  ThisoftT Offline
                  ThisoftT Offline
                  Thisoft
                  #1327
                  Hab ich gemacht. Das wäre dann alles?
                  • ThisoftT Thisoft
                    #1328
                    @thisoft
                    Läuft der iobroker denn nun wieder ohne Meldungen?
                      @thisoft
                      ThisoftT Offline
                      ThisoftT Offline
                      Thisoft
                      #1329
                      Ja tut er. Er hatte auch vorher nur das Problem dass der Parcel-Adapter sich nicht bei DHL eingeloggt hat. Was ja offensichtlich erst ab nodejs 18.19.1 wieder funktioniert. Ansonsten hatte ich kein Problem damit. Aber wenn das jetzt alles sauber gefixt ist umso besser.
                      • bahnuhrB Online
                        bahnuhrB Online
                        bahnuhr
                        #1330
                        Guten Abend,
                        muss jetzt auch mal fragen zur grundsätzlichen Vorgehensweise
                        a) DHL
                        Habe meinen Benutzer und Pass eingegeben und die Daten kommen.
                        Für was ist der Pin-Code ?
                        Braucht man den und für was?
                        Daten kommen ja an.
                        b) Hermes
                        Habe mich dort angemeldet. Aber die Lieferung war nicht automatisch drin. Musste die Nr. manuell einpflegen.
                        Braucht man dafür dann 17Track?
                        Also die Mails weiter leiten an 17Track und diese analysieren die Mails und senden dann die Daten an den Adapter.
                        Richtig ?
                        c) Wie funktioniert dies bei DPD, GLS, UPS, Amazon?
                        Hier habe ich noch nichts.
                        Muss ich einen Benutzer überall anmelden und dann jedesmal 17Track ?
                        mfg
                        Dieter
                        Danke.
                        • bahnuhrB Online
                          bahnuhrB Online
                          bahnuhr
                          #1331
                          Datum, Uhrzeit anzeigen:
                          Habe hier des öfteren schon gesehen, dass auch das Datum + Uhrzeit in VIS angezeigt wird.
                          Bei mir nicht.
                          Aber im DP sind die Daten wohl drin.
                          Frage:
                          Wie bekomme ich Datum und Uhrzeit angezeigt ?
                          Danke.
                          • bahnuhrB Online
                            bahnuhrB Online
                            bahnuhr
                            #1332
                            So, und nun letzte Frage zu Hermes
                            Hatte ja die Nr. manuell bei Hermes eingetragen. Dies wurde dann auch übertragen.
                            Im DP steht auch der Absender:
                            In VIS nicht, dort "undefined"
                            So, das wars erst einmal.
                            Danke.
                            • bahnuhrB bahnuhr
                              DJMarc75D Offline
                              DJMarc75D Offline
                              DJMarc75
                              #1333
                              @bahnuhr
                              Im Prinzip empfängt der Adapter nur die Daten vom jeweiligen Provider.
                              Und die Provider sind schon zeitweise recht "kacke" ;)
                              Da ändert jeder Provider öfter mal die Daten und der Developer kommt da fast nicht nach.
                              Ich verlasse mich schon ewig nur noch auf DHL, der Rest ist für mich nur "Spass" da es meist nicht zuverlässig klappt (GLS ist eine Katastrophe)
                              Amazon nutze ich nicht da dies ja anscheinend zum Ko**en ist, da die Vögel da immer was ändern.
                              Ist aber nur meine eigene Erfahrung und kann bei anderen Usern auch besser funktionieren.
                              Lehrling seit 1975 !!!
                              • DJMarc75D DJMarc75
                                @bahnuhr
                                bahnuhrB Online
                                bahnuhrB Online
                                bahnuhr
                                #1334
                                @djmarc75
                                Muss man sich bei gls anmelden ?
                                Oder reicht die Mail Weiterleitung an 17track ?
                                Danke.
                                • bahnuhrB bahnuhr
                                  @djmarc75
                                  DJMarc75D Offline
                                  DJMarc75D Offline
                                  DJMarc75
                                  #1335
                                  @bahnuhr sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                                  Na man muss sich mMn schon bei jedem Provider anmelden.
                                  Mit 17track hab ich keine Erfahrungen.
                                    bahnuhrB Online
                                    bahnuhrB Online
                                    bahnuhr
                                    #1336
                                    @djmarc75 sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                                    Ich habe das so verstanden, dass man eine Mail Weiterleitung an 17track macht. Und diese nehmen die Mail dann auseinander und der Adapter holt die Daten von 17track.
                                    Dann würde es keine Anmeldung beim provider brauchen.
                                    Danke.
                                    • bahnuhrB bahnuhr
                                      DJMarc75D Offline
                                      DJMarc75D Offline
                                      DJMarc75
                                      #1337
                                      @bahnuhr Da musst Du mal im ersten Beitrag nachlesen, das weiß ich leider nicht.
                                        bahnuhrB Online
                                        bahnuhrB Online
                                        bahnuhr
                                        #1338
                                        Der ist gut.
                                        Da hab ich schon 50x gelesen. Aber offensichtlich nicht die richtigen Infos gefunden.
                                        Danke.
                                        • bahnuhrB bahnuhr
                                          Der ist gut.
                                          DJMarc75D Offline
                                          DJMarc75D Offline
                                          DJMarc75
                                          #1339
                                          @bahnuhr
                                          17Track User maximal 40 Pakete gleichzeitig:
                                          https://buyer.17track.net/en/myshipment?ob=1
                                          17Track Api developer maximal 100 Anfragen dann muss bezahlt werden
                                          Hier ein Security Key beantragen und in die Einstellungen eingeben geht nur wenn man kein 17Track User ist
                                          https://user.17track.net/de/register?gb=%23maybe%3D16
                                          https://api.17track.net/en/admin/settings
                                          Aber ich hab das noch nie genutzt 🤡
                                          Bin da eher Retro 😁
