  4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
17trackamazonbriefedhldpdglsups
1.6k Beiträge 129 Kommentatoren 737.9k Aufrufe 117 Beobachtet
  • ThisoftT Thisoft
    @thomas-braun sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
    sudo systemctl set-default multi-user.target
    iob nodejs-update 18
    sorry, aber was soll mir das sagen?
    #1324
    @thisoft sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
    Das sollst du in deinem Terminal ausführen.
    ThisoftT 1 Antwort Letzte Antwort
      ThisoftT Offline
      ThisoftT Offline
      Thisoft
      #1325
      OK. Hab ich. Und jetzt nochmal iob diag
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: iob-ubuntu
             Icon name: computer-vm
               Chassis: vm
        Virtualization: kvm
      Operating System: Ubuntu 22.04.4 LTS
                Kernel: Linux 5.15.0-97-generic
          Architecture: x86-64
       Hardware Vendor: QEMU
        Hardware Model: Standard PC _i440FX + PIIX, 1996_
      model name      : Common KVM processor
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       16:00:27 up 6 min,  2 users,  load average: 0.29, 0.30, 0.15
      CPU threads: 8
      *** Time and Time Zones ***
                     Local time: Sat 2024-02-24 16:00:27 CET
                 Universal time: Sat 2024-02-24 15:00:27 UTC
                       RTC time: Sat 2024-02-24 15:00:27
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      iobroker
      /home/iobroker
      iobroker adm tty dialout cdrom sudo audio dip video plugdev lxd
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            7.9G        189M        7.2G        1.0M        580M        7.5G
      Swap:           3.1G          0B        3.1G
      Total:           11G        189M         10G
               7937 M total memory
                190 M used memory
                240 M active memory
                345 M inactive memory
               7166 M free memory
                 53 M buffer memory
                527 M swap cache
               3114 M total swap
                  0 M used swap
               3114 M free swap
      *** FAILED SERVICES ***
        UNIT             LOAD   ACTIVE SUB    DESCRIPTION
      * iobroker.service loaded failed failed ioBroker Server
      1 loaded units listed.
      *** FILESYSTEM ***
      Filesystem                        Type   Size  Used Avail Use% Mounted on
      tmpfs                             tmpfs  794M  1.1M  793M   1% /run
      /dev/mapper/ubuntu--vg-ubuntu--lv ext4    15G   12G  2.3G  84% /
      tmpfs                             tmpfs  3.9G     0  3.9G   0% /dev/shm
      tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
      /dev/sda2                         ext4   2.0G  251M  1.6G  14% /boot
      //192.168.137.42/motion           cifs   869G  840G   30G  97% /var/lib/motion/NAS
      tmpfs                             tmpfs  794M  4.0K  794M   1% /run/user/1000
      [sudo] password for iobroker:
      [Sat Feb 24 15:54:27 2024] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sat Feb 24 15:54:28 2024] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none.
      [Sat Feb 24 15:54:28 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      TARGET                SOURCE                            FSTYPE   OPTIONS
      /                     /dev/mapper/ubuntu--vg-ubuntu--lv ext4     rw,relatime
      |-/snap/core20/2182   /dev/loop1                        squashfs ro,nodev,relatime,errors=continue
      |-/snap/core20/2105   /dev/loop0                        squashfs ro,nodev,relatime,errors=continue
      |-/snap/lxd/26975     /dev/loop2                        squashfs ro,nodev,relatime,errors=continue
      |-/snap/snapd/20290   /dev/loop3                        squashfs ro,nodev,relatime,errors=continue
      |-/snap/snapd/20671   /dev/loop5                        squashfs ro,nodev,relatime,errors=continue
      |-/snap/lxd/27037     /dev/loop4                        squashfs ro,nodev,relatime,errors=continue
      |-/boot               /dev/sda2                         ext4     rw,relatime
      `-/var/lib/motion/NAS //192.168.137.42/motion           cifs     rw,relatime,vers=default,cache=strict,username=motion,uid=1001,forceuid,gid=0,noforcegid,addr=192.168.137.42,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=1048576,wsize=1048576,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=1
      /var:
      3.9G    /var/
      3.0G    /var/lib
      2.2G    /var/lib/motion/NAS
      1.9G    /var/lib/motion/NAS/Cam4
      Archived and active journals take up 392.1M in the file system.
      /opt/iobroker/backups:
      4.0K    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      352M    /opt/iobroker/iobroker-data/
      199M    /opt/iobroker/iobroker-data/files
      109M    /opt/iobroker/iobroker-data/backup-objects
      57M     /opt/iobroker/iobroker-data/files/javascript.admin
      38M     /opt/iobroker/iobroker-data/files/javascript.admin/static
      33M     /opt/iobroker/iobroker-data/objects.jsonl
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      11M     /opt/iobroker/iobroker-data/states.jsonl
      8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
      7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
      USB-Devices by-id:
      find: '/dev/serial/by-id/': No such file or directory
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.1
      /usr/bin/node           v18.19.1
      /usr/bin/npm            10.2.4
      /usr/bin/npx            10.2.4
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.1-1nodesource1
        Candidate: 18.19.1-1nodesource1
        Version table:
       *** 18.19.1-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
           18.19.0-1nodesource1 1001
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.9~dfsg-1ubuntu3.3 500
              500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
              500 http://de.archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
           12.22.9~dfsg-1ubuntu3 500
              500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Server Configured backup period 7200000 is larger than the supported maximum of 35791 minutes. Defaulting to 120 minutes.
      iobroker is not running on this host.
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.19
      admin:          6.14.1
      javascript:     7.8.0
      Adapters from github:   1
      Adapter State
        system.adapter.admin.0                  : admin                 : iob-ubuntu                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alias-manager.0          : alias-manager         : iob-ubuntu                               - disabled
        system.adapter.backitup.0               : backitup              : iob-ubuntu                               -  enabled
        system.adapter.daswetter.0              : daswetter             : iob-ubuntu                               -  enabled
        system.adapter.daswetter.1              : daswetter             : iob-ubuntu                               - disabled
        system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : iob-ubuntu                               - disabled
        system.adapter.feiertage.0              : feiertage             : iob-ubuntu                               -  enabled
        system.adapter.flot.0                   : flot                  : iob-ubuntu                               - disabled
        system.adapter.gruenbeck.0              : gruenbeck             : iob-ubuntu                               - disabled
        system.adapter.hm-rega.0                : hm-rega               : iob-ubuntu                               -  enabled
        system.adapter.hm-rpc.0                 : hm-rpc                : iob-ubuntu                               -  enabled, port: 0
        system.adapter.hm-rpc.1                 : hm-rpc                : iob-ubuntu                               -  enabled, port: 0
        system.adapter.homeconnect.0            : homeconnect           : iob-ubuntu                               - disabled
        system.adapter.ical.0                   : ical                  : iob-ubuntu                               -  enabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : iob-ubuntu                               - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iob-ubuntu                               - disabled
        system.adapter.info.0                   : info                  : iob-ubuntu                               -  enabled
        system.adapter.javascript.0             : javascript            : iob-ubuntu                               -  enabled
        system.adapter.javascript.1             : javascript            : iob-ubuntu                               -  enabled
        system.adapter.javascript.2             : javascript            : iob-ubuntu                               -  enabled
        system.adapter.javascript.3             : javascript            : piPivCCU                                 -  enabled
        system.adapter.javascript.4             : javascript            : doorpi                                   -  enabled
        system.adapter.link.0                   : link                  : iob-ubuntu                               -  enabled
        system.adapter.mielecloudservice.0      : mielecloudservice     : iob-ubuntu                               - disabled
        system.adapter.mqtt.0                   : mqtt                  : iob-ubuntu                               -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.onvif.0                  : onvif                 : iob-ubuntu                               - disabled
        system.adapter.parcel.0                 : parcel                : iob-ubuntu                               -  enabled
        system.adapter.ping.0                   : ping                  : iob-ubuntu                               -  enabled
        system.adapter.pollenflug.0             : pollenflug            : iob-ubuntu                               - disabled
        system.adapter.pvforecast.0             : pvforecast            : iob-ubuntu                               - disabled
        system.adapter.repetierserver.0         : repetierserver        : iob-ubuntu                               - disabled
        system.adapter.rpi2.0                   : rpi2                  : piPivCCU                                 -  enabled
        system.adapter.sayit.0                  : sayit                 : VISFlur                                  - disabled
        system.adapter.shelly.0                 : shelly                : iob-ubuntu                               -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.simple-api.0             : simple-api            : iob-ubuntu                               -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.smartmeter.0             : smartmeter            : piPivCCU                                 -  enabled
        system.adapter.smartmeter.1             : smartmeter            : piPivCCU                                 -  enabled
        system.adapter.sourceanalytix.0         : sourceanalytix        : iob-ubuntu                               -  enabled
        system.adapter.sql.0                    : sql                   : iob-ubuntu                               -  enabled, port: 3306
        system.adapter.sql.1                    : sql                   : iob-ubuntu                               - disabled, port: 3306
        system.adapter.statistics.0             : statistics            : iob-ubuntu                               -  enabled
        system.adapter.tankerkoenig.0           : tankerkoenig          : iob-ubuntu                               -  enabled
        system.adapter.telegram.0               : telegram              : iob-ubuntu                               -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.terminal.0               : terminal              : doorpi                                   -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
        system.adapter.terminal.1               : terminal              : iob-ubuntu                               - disabled, port: 8088, bind: 0.0.0.0, run as: admin
        system.adapter.tr-064.0                 : tr-064                : iob-ubuntu                               -  enabled
        system.adapter.tuya.0                   : tuya                  : iob-ubuntu                               -  enabled
        system.adapter.upnp.0                   : upnp                  : iob-ubuntu                               -  enabled
        system.adapter.vis-bars.0               : vis-bars              : iob-ubuntu                               - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iob-ubuntu                               - disabled
        system.adapter.vis-history.0            : vis-history           : iob-ubuntu                               - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iob-ubuntu                               - disabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : iob-ubuntu                               - disabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iob-ubuntu                               - disabled
        system.adapter.vis-keyboard.0           : vis-keyboard          : iob-ubuntu                               - disabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : iob-ubuntu                               - disabled
        system.adapter.vis-material.0           : vis-material          : iob-ubuntu                               - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iob-ubuntu                               - disabled
        system.adapter.vis-metro.0              : vis-metro             : iob-ubuntu                               - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : iob-ubuntu                               - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : iob-ubuntu                               - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iob-ubuntu                               - disabled
        system.adapter.vis-weather.0            : vis-weather           : iob-ubuntu                               - disabled
        system.adapter.vis.0                    : vis                   : iob-ubuntu                               -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : iob-ubuntu                               -  enabled
        system.adapter.weatherunderground.1     : weatherunderground    : doorpi                                   - disabled
        system.adapter.web.0                    : web                   : iob-ubuntu                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iob-ubuntu                               -  enabled
        system.adapter.windows-control.0        : windows-control       : iob-ubuntu                               - disabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): beta
      Installed ioBroker-Instances
      Used repository: beta
      Adapter    "admin"        : 6.14.1   , installed 6.14.1
      Adapter    "alias-manager": 1.2.6    , installed 1.2.6
      Adapter    "backitup"     : 2.10.11  , installed 2.10.11
      Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
      Adapter    "ecovacs-deebot": 1.4.14  , installed 1.4.14
      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
      Adapter    "gruenbeck"    : 0.0.42   , installed 0.0.42
      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
      Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
      Adapter    "ical"         : 1.14.2   , installed 1.14.2
      Adapter    "info"         : 2.0.0    , installed 2.0.0
      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
      Controller "js-controller": 5.0.19   , installed 5.0.19
      Adapter    "link"         : 0.5.12   , installed 0.5.12
      Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "onvif"        : 1.1.2    , installed 1.1.2
      Adapter    "parcel"       : 0.2.7    , installed 0.2.7
      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
      Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
      Adapter    "shelly"       : 6.8.0    , installed 6.8.0
      Adapter    "socketio"     : 6.6.1    , installed 6.6.1
      Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
      Adapter    "statistics"   : 2.4.0    , installed 2.4.0
      Adapter    "telegram"     : 3.1.0    , installed 3.1.0
      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
      Adapter    "tuya"         : 3.15.0   , installed 3.15.0
      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      Adapter    "vis"          : 1.5.4    , installed 1.5.4
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
      Adapter    "vis-material" : 0.1.3    , installed 0.1.3
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      Adapter    "weatherunderground": 3.6.0, installed 3.6.0
      Adapter    "web"          : 6.2.5    , installed 6.2.5
      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
      Adapter    "windows-control": 0.1.5  , installed 0.1.5
      Adapter    "ws"           : 2.5.11   , installed 2.5.11
      Objects and States
      Objects:        16682
      States:         12104
      Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
      Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
      Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
      Hit:5 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        2695       637/systemd-resolve
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          16297      1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          23780      699/sshd: /usr/sbin
      tcp6       0      0 :::111                  :::*                    LISTEN      0          19827      1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          23791      699/sshd: /usr/sbin
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        2694       637/systemd-resolve
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2340       1/init
      udp6       0      0 :::111                  :::*                                0          2343       1/init
      2024-02-24 15:59:34.769  - info: host.iob-ubuntu instance system.adapter.javascript.1 terminated with code 0 (NO_ERROR)
      2024-02-24 15:59:34.811  - info: host.iob-ubuntu instance system.adapter.javascript.2 terminated with code 0 (NO_ERROR)
      2024-02-24 15:59:34.812  - info: host.iob-ubuntu instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
      2024-02-24 15:59:34.848  - info: host.iob-ubuntu instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
      2024-02-24 15:59:34.848  - info: host.iob-ubuntu instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
      2024-02-24 15:59:34.861  - info: host.iob-ubuntu instance system.adapter.statistics.0 terminated with code 0 (NO_ERROR)
      2024-02-24 15:59:34.874  - info: host.iob-ubuntu instance system.adapter.tankerkoenig.0 terminated with code 0 (NO_ERROR)
      2024-02-24 15:59:35.068  - warn: host.iob-ubuntu instance system.adapter.telegram.0 terminated due to SIGTERM
      2024-02-24 15:59:35.068  - info: host.iob-ubuntu instance system.adapter.telegram.0 terminated with code null ()
      2024-02-24 15:59:35.092  - warn: host.iob-ubuntu instance system.adapter.whatsapp-cmb.0 terminated due to SIGTERM
      2024-02-24 15:59:35.092  - info: host.iob-ubuntu instance system.adapter.whatsapp-cmb.0 terminated with code null ()
      2024-02-24 15:59:35.092  - warn: host.iob-ubuntu instance system.adapter.hm-rega.0 terminated due to SIGTERM
      2024-02-24 15:59:35.092  - info: host.iob-ubuntu instance system.adapter.hm-rega.0 terminated with code null ()
      2024-02-24 15:59:35.122  - warn: host.iob-ubuntu instance system.adapter.hm-rpc.1 terminated due to SIGTERM
      2024-02-24 15:59:35.122  - info: host.iob-ubuntu instance system.adapter.hm-rpc.1 terminated with code null ()
      2024-02-24 15:59:35.122  - warn: host.iob-ubuntu instance system.adapter.ping.0 terminated due to SIGTERM
      2024-02-24 15:59:35.122  - info: host.iob-ubuntu instance system.adapter.ping.0 terminated with code null ()
      2024-02-24 15:59:35.143  - warn: host.iob-ubuntu instance system.adapter.web.0 terminated due to SIGTERM
      2024-02-24 15:59:35.143  - info: host.iob-ubuntu instance system.adapter.web.0 terminated with code null ()
      2024-02-24 15:59:35.188  - info: host.iob-ubuntu instance system.adapter.sql.0 terminated with code 0 (NO_ERROR)
      2024-02-24 15:59:36.360  - info: tuya.0 (1198) terminating
      2024-02-24 15:59:36.361  - info: tuya.0 (1198) Terminated (NO_ERROR): Without reason
      2024-02-24 15:59:36.913  - info: host.iob-ubuntu instance system.adapter.tuya.0 terminated with code 0 (NO_ERROR)
      2024-02-24 15:59:36.913  - info: host.iob-ubuntu All instances are stopped.
      2024-02-24 15:59:37.111  - info: host.iob-ubuntu terminated
      22 HM-Geräte; PivCCU2 auf RasPi
      ioBroker-Multihost; Ubuntu-Master auf Intel-Atom und 3 RasPi-Clients
      • ThisoftT Thisoft
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                 Chassis: vm
          Virtualization: kvm
        Docker          : false
        Kernel          : x86_64
        Userland        : amd64
        CPU threads: 8
                      NTP service: active
                  RTC in local TZ: no
        iobroker
        /home/iobroker
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           3.1G          0B        3.1G
        Total:           11G        189M         10G
                 7937 M total memory
                  190 M used memory
                  240 M active memory
                 7166 M free memory
                   53 M buffer memory
                  527 M swap cache
                 3114 M total swap
                    0 M used swap
                 3114 M free swap
        *** FILESYSTEM ***
        /var:
        3.9G    /var/
        3.0G    /var/lib
        USB-Devices by-id:
        /usr/bin/npm            10.2.4
        /usr/bin/npx            10.2.4
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.14.1
        javascript:     7.8.0
        Adapter State
        + instance is alive
        Objects and States
        Objects:        16682
        States:         12104
        Pending Updates: 0
        #1326
        @thisoft
        https://forum.iobroker.net/topic/54655/probleme-von-4-0-21-auf-4-0-23/16
        Und dann den iobroker wieder starten.
          @thisoft
          ThisoftT Offline
          ThisoftT Offline
          Thisoft
          #1327
          Hab ich gemacht. Das wäre dann alles?
          • ThisoftT Thisoft
            #1328
            @thisoft
            Läuft der iobroker denn nun wieder ohne Meldungen?
              @thisoft
              ThisoftT Offline
              ThisoftT Offline
              Thisoft
              #1329
              Ja tut er. Er hatte auch vorher nur das Problem dass der Parcel-Adapter sich nicht bei DHL eingeloggt hat. Was ja offensichtlich erst ab nodejs 18.19.1 wieder funktioniert. Ansonsten hatte ich kein Problem damit. Aber wenn das jetzt alles sauber gefixt ist umso besser.
              • bahnuhrB Online
                bahnuhrB Online
                bahnuhr
                #1330
                Guten Abend,
                muss jetzt auch mal fragen zur grundsätzlichen Vorgehensweise
                a) DHL
                Habe meinen Benutzer und Pass eingegeben und die Daten kommen.
                Für was ist der Pin-Code ?
                Braucht man den und für was?
                Daten kommen ja an.
                b) Hermes
                Habe mich dort angemeldet. Aber die Lieferung war nicht automatisch drin. Musste die Nr. manuell einpflegen.
                Braucht man dafür dann 17Track?
                Also die Mails weiter leiten an 17Track und diese analysieren die Mails und senden dann die Daten an den Adapter.
                Richtig ?
                c) Wie funktioniert dies bei DPD, GLS, UPS, Amazon?
                Hier habe ich noch nichts.
                Muss ich einen Benutzer überall anmelden und dann jedesmal 17Track ?
                mfg
                Dieter
                Danke.
                • bahnuhrB Online
                  bahnuhrB Online
                  bahnuhr
                  #1331
                  Datum, Uhrzeit anzeigen:
                  Habe hier des öfteren schon gesehen, dass auch das Datum + Uhrzeit in VIS angezeigt wird.
                  Bei mir nicht.
                  Aber im DP sind die Daten wohl drin.
                  Frage:
                  Wie bekomme ich Datum und Uhrzeit angezeigt ?
                  Danke.
                  • bahnuhrB Online
                    bahnuhrB Online
                    bahnuhr
                    #1332
                    So, und nun letzte Frage zu Hermes
                    Hatte ja die Nr. manuell bei Hermes eingetragen. Dies wurde dann auch übertragen.
                    Im DP steht auch der Absender:
                    In VIS nicht, dort "undefined"
                    So, das wars erst einmal.
                    Danke.
                    • bahnuhrB bahnuhr
                      DJMarc75D Offline
                      DJMarc75D Offline
                      DJMarc75
                      #1333
                      @bahnuhr
                      Im Prinzip empfängt der Adapter nur die Daten vom jeweiligen Provider.
                      Und die Provider sind schon zeitweise recht "kacke" ;)
                      Da ändert jeder Provider öfter mal die Daten und der Developer kommt da fast nicht nach.
                      Ich verlasse mich schon ewig nur noch auf DHL, der Rest ist für mich nur "Spass" da es meist nicht zuverlässig klappt (GLS ist eine Katastrophe)
                      Amazon nutze ich nicht da dies ja anscheinend zum Ko**en ist, da die Vögel da immer was ändern.
                      Ist aber nur meine eigene Erfahrung und kann bei anderen Usern auch besser funktionieren.
                      Lehrling seit 1975 !!!
                      • DJMarc75D DJMarc75
                        @bahnuhr
                        bahnuhrB Online
                        bahnuhrB Online
                        bahnuhr
                        #1334
                        @djmarc75
                        Muss man sich bei gls anmelden ?
                        Oder reicht die Mail Weiterleitung an 17track ?
                        Danke.
                        • bahnuhrB bahnuhr
                          @djmarc75
                          DJMarc75D Offline
                          DJMarc75D Offline
                          DJMarc75
                          #1335
                          @bahnuhr sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                          Na man muss sich mMn schon bei jedem Provider anmelden.
                          Mit 17track hab ich keine Erfahrungen.
                            bahnuhrB Online
                            bahnuhrB Online
                            bahnuhr
                            #1336
                            @djmarc75 sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                            Ich habe das so verstanden, dass man eine Mail Weiterleitung an 17track macht. Und diese nehmen die Mail dann auseinander und der Adapter holt die Daten von 17track.
                            Dann würde es keine Anmeldung beim provider brauchen.
                            Danke.
                            • bahnuhrB bahnuhr
                              DJMarc75D Offline
                              DJMarc75D Offline
                              DJMarc75
                              #1337
                              @bahnuhr Da musst Du mal im ersten Beitrag nachlesen, das weiß ich leider nicht.
                                bahnuhrB Online
                                bahnuhrB Online
                                bahnuhr
                                #1338
                                Der ist gut.
                                Da hab ich schon 50x gelesen. Aber offensichtlich nicht die richtigen Infos gefunden.
                                Danke.
                                • bahnuhrB bahnuhr
                                  Der ist gut.
                                  DJMarc75D Offline
                                  DJMarc75D Offline
                                  DJMarc75
                                  #1339
                                  @bahnuhr
                                  17Track User maximal 40 Pakete gleichzeitig:
                                  https://buyer.17track.net/en/myshipment?ob=1
                                  17Track Api developer maximal 100 Anfragen dann muss bezahlt werden
                                  Hier ein Security Key beantragen und in die Einstellungen eingeben geht nur wenn man kein 17Track User ist
                                  https://user.17track.net/de/register?gb=%23maybe%3D16
                                  https://api.17track.net/en/admin/settings
                                  Aber ich hab das noch nie genutzt 🤡
                                  Bin da eher Retro 😁
                                    @bahnuhr
                                    Bin da eher Retro 😁
                                    #1340
                                    @djmarc75
                                    ist es jetzt möglich Sich das Bild der Briefankündigung per Telegramm zuschicken zu lassen bzw. die Daten der Briefankündigung?
                                      @djmarc75
                                      DJMarc75D Offline
                                      DJMarc75D Offline
                                      DJMarc75
                                      #1341
                                      @olli_m sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                                      Ja klar, muss in der Instanzeinstellung natürlich auch konfiguriert sein.
                                      • ? Offline
                                        #1342
                                        @djmarc75
                                        achso weil gerade hab ich gelesen dass das mit den Bildern mal deaktiviert wurde im versionstext...?
                                          @djmarc75
                                          DJMarc75D Offline
                                          DJMarc75D Offline
                                          DJMarc75
                                          #1343
                                          keine Ahnung, das kann Dir der Entwickler sicher beantworten ( @tombox )
