  4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
17trackamazonbriefedhldpdglsups
1.6k Beiträge 129 Kommentatoren 748.3k Aufrufe 117 Beobachtet
  • G Offline
    Gruter
    #561
    Hallo, habe gerade ein Fehler im Log gefunden bzgl Amazon:
    parcel.0
    2022-03-09 09:10:22.003	info	starting. Version 0.0.10 (non-npm: TA2k/ioBroker.parcel#f0b05683d32a7dbdecbbbdd93b1bb45736903364) in /opt/iobroker/node_modules/iobroker.parcel, node: v12.22.10, js-controller: 4.0.15
    parcel.0
    2022-03-09 09:09:44.480	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    parcel.0
    2022-03-09 09:09:44.478	info	terminating
    parcel.0
    2022-03-09 09:09:44.473	error	Cannot read property 'length' of undefined
    parcel.0
    2022-03-09 09:09:44.472	error	TypeError: Cannot read property 'length' of undefined at Parcel.getAmazonPackages (/opt/iobroker/node_modules/iobroker.parcel/main.js:1477:42) at processTicksAndRejections (internal/process/task_queues.js:97:5)
    parcel.0
    2022-03-09 09:09:44.471	error	unhandled promise rejection: Cannot read property 'length' of undefined
    parcel.0
    2022-03-09 09:09:44.470	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    parcel.0
    2022-03-09 09:09:44.463	error	Error: getaddrinfo EAI_AGAIN www.amazon.de
    Mod-Edit: Code in </> Code-Tag gepackt!
    • G Gruter
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      parcel.0
      tombox
      #562
      @gruter Danke für den hinweis
      • NashraN Offline
        NashraN Offline
        Nashra
        Most Active Forum Testing
        #563
        Wenn der Adapter per Schedule neu startet geht alles auf rot und bekomme dies
        parcel.0
        	794152	2022-03-09 18:00:00.062	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        parcel.0
        	794152	2022-03-09 18:00:00.061	info	terminating
        host.ioBroker
        		2022-03-09 18:00:00.060	info	instance system.adapter.ical.0 started with pid 804678
        parcel.0
        	794152	2022-03-09 18:00:00.010	info	Scheduled restart.
        Gruß Ralf
        Mir egal, wer Dein Vater ist! Wenn ich hier angel, wird nicht übers Wasser gelaufen!!
        Christoph1337C 1 Antwort Letzte Antwort
        • NashraN Nashra
          parcel.0
          parcel.0
          host.ioBroker
          parcel.0
          Christoph1337C Offline
          Christoph1337
          #564
          Nach dem letzten Update habe ich folgende Fehler im Log.
          parcel.0
          2022-03-10 11:33:21.527	warn	State "parcel.0.amazon.json" has no existing object, this might lead to an error in future versions
          parcel.0
          2022-03-10 11:33:13.441	error	[object Object],[object Object]
          parcel.0
          2022-03-10 11:33:13.437	error	SyntaxError: Unexpected token o in JSON at position 1
          parcel.0
          2022-03-10 11:30:28.803	warn	State "parcel.0.amazon.json" has no existing object, this might lead to an error in future versions
          parcel.0
          2022-03-10 11:30:28.801	warn	State "parcel.0.amazon.json" has no existing object, this might lead to an error in future versions
          parcel.0
          2022-03-10 11:30:19.587	error	[object Object],[object Object]
          parcel.0
          2022-03-10 11:30:19.587	error	SyntaxError: Unexpected token o in JSON at position 1
          parcel.0
          2022-03-10 11:30:19.088	error	[object Object],[object Object]
          parcel.0
          2022-03-10 11:30:19.085	error	SyntaxError: Unexpected token o in JSON at position 1
          • Christoph1337C Christoph1337
            parcel.0
            parcel.0
            parcel.0
            parcel.0
            parcel.0
            parcel.0
            parcel.0
            parcel.0
            parcel.0
            tombox
            #565
            @christoph1337 ist behoben
            XsevX 1 Antwort Letzte Antwort
            • Bastian LahrmannB Offline
              Bastian Lahrmann
              #566
              Parcel: v0.0.10
              Nodejs: 14.19.0
              NPM: 6.14.16
              1. Ich habe im Parcer immer einen Syntax-Error. Wahrscheinlich kommt das von Hermes. Das stört dem Adapter nicht und er funktioniert trotzdem (wobei ich das bisher mit Hermes nicht ausprobieren konnte), aber im Log taucht es auf.
              parcel.0 2022-03-11 07:52:28.242	debug	hermes merge provider json
              parcel.0 2022-03-11 07:52:28.216	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
              parcel.0 2022-03-11 07:52:28.211	error
              parcel.0 2022-03-11 07:52:28.211	error	SyntaxError: Unexpected end of JSON input
              parcel.0 2022-03-11 07:52:28.210	debug	[]
              parcel.0 2022-03-11 07:52:27.852	debug	https://mobile-api.myhermes.de/mobile-api-web/v2/shipments
              parcel.0 2022-03-11 07:52:27.852	debug	ups merge provider json
              1. Jeden Morgen bekomme ich über Telegram alle Pakete von DHL einmal zugeschickt, obwohl sich am Status (abgeschlossen/zugeschickt) nichts geändert hat. Vielleicht kann man diese Meldung noch unterdrücken.
              • T tombox
                XsevX Offline
                XsevX Offline
                Xsev
                #567
                @tombox Hi tombox, ich hab heute mal aktualisiert um zu schauen ob das Problem weg ist aber anscheinend nicht.
                DPD aktualisiert den Status nicht mehr automatisch, nur wenn man den Adapter neu startet aktualisiert er die Daten, da scheint evtl. was faul zu sein.
                • David G.D Online
                  David G.D Online
                  David G.
                  #568
                  Habe jetzt mein erstes DPD Paket.
                  Da wollte ich mal fragen, wie oft der Adapter das aktualisiert.
                  Die App hat mir vor ca 30min einen neuen Status gesendet. Im Adapter ist dieser noch nicht angekommen.
                  Bei den verbundenen Geräten sehe ich den Adapter nicht (nur mein Smartphone).
                  Edit: Erste Frage hat sich erledigt.
                  • DJMarc75D Offline
                    DJMarc75D Offline
                    DJMarc75
                    #569
                    Falls ihr Fehler im LOG bzgl DHL habt, DHL hat grad Probleme .... hat nix mit dem Adapter zu tun
                    Lehrling seit 1975 !!!
                    • Bastian LahrmannB Bastian Lahrmann
                      Parcel: v0.0.10
                      Nodejs: 14.19.0
                      NPM: 6.14.16
                      tombox
                      #570
                      @bastian-lahrmann Ja ich bin noch auf der Suche was da manchmal bei hermes schief geht.
                      Mal die aktuelle Version installieren und schauen ob es weg geht.
                      Es wird der ganze Status überprüft ist der exakt der gleiche. Gerade wenn sich was von heute auf Datum ändert
                      Bastian LahrmannB 1 Antwort Letzte Antwort
                      • XsevX Xsev
                        tombox
                        #571
                        @xsev Ich habe bei dpd noch anpassungen gemacht bitte mal prüfen. Und schauen ob die Aktualisierung sofort kommt oder erst nach 1h.
                        • T tombox
                          Bastian Lahrmann
                          #572
                          @tombox
                          Zumindest sind die Json-Meldungen weg, dafür kommt bei mir seit gestern abend DHL dazu. Mein Anfrageintervall steht auf 20min.
                          parcel.0
                          2022-03-12 06:11:59.540	error	[{"message":"Bitte versuchen Sie es zu einem späteren Zeitpunkt erneut.","headline":"Es ist leider ein Fehler aufgetreten."}]
                          parcel.0
                          2022-03-12 06:11:59.540	error	Error: Request failed with status code 500
                          parcel.0
                          2022-03-12 06:11:59.538	error	https://www.dhl.de/int-aviseanzeigen/advices?width=414
                          • T tombox
                            XsevX Offline
                            XsevX Offline
                            Xsev
                            #573
                            @tombox Danke! Ich kanns aktuell nur nicht testen, da ich grad keine Sendung mehr im Zulauf habe.
                            • DJMarc75D Offline
                              DJMarc75D Offline
                              DJMarc75
                              #574
                              @bastian-lahrmann
                              Seit gestern Störung bei DHL
                              https://allestörungen.de/stoerung/dhl/
                                @tombox
                                parcel.0
                                parcel.0
                                parcel.0
                                #575
                                @bastian-lahrmann
                                https://stadt-bremerhaven.de/post-dhl-app-briefankuendigung-ausgesetzt-datenschutzpanne/
                                @tombox
                                Kann man die Briefankündigung nicht optional in den Einstellungen machen?
                                Bastian LahrmannB ChaotC T 3 Antworten Letzte Antwort
                                  @bastian-lahrmann
                                  @tombox
                                  Bastian Lahrmann
                                  #576
                                  @thomas-braun Interessant, danke. Über GMX habe ich weiterhin die Briefankündigung erhalten, deshalb meine Verwirrung. Dann hat sich das ja jetzt geklärt.
                                    @bastian-lahrmann
                                    @tombox
                                    ChaotC Offline
                                    ChaotC Offline
                                    Chaot
                                    #577
                                    @thomas-braun Hihi, habe ich auch schon gestern gelesen.
                                    Lustigerweise kann ich bestätigen das es auch bei Paketen zu solchen Pannen kommt. Ich hatte kürzlich ein Paket meiner Lebensgefährtin in der Ankündigung. Gleiche Adresse, aber anderer Name.
                                    • DJMarc75D Offline
                                      DJMarc75D Offline
                                      DJMarc75
                                      #578
                                      @tombox
                                      Meinste man könnte im Backend die Briefankündigung bei DHL schaltbar machen ? Wer weiss wie lange die "Störung" noch existiert. Es wird halt der LOG je nach Intervall immer leicht belastet 😊
                                        @bastian-lahrmann
                                        @tombox
                                        tombox
                                        #579
                                        @thomas-braun Habe eine Erkennung eingebaut falls die Briefankündigung nicht geht wird sie für updates ignoriert.
                                        • T tombox
                                          DJMarc75D Offline
                                          DJMarc75D Offline
                                          DJMarc75
                                          #580
                                          @tombox
                                          Sehr gut gemacht !
