  4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
    6.6k
17trackamazonbriefedhldpdglsups
1.6k Beiträge 129 Kommentatoren 727.8k Aufrufe 117 Beobachtet
  • NashraN Offline
    NashraN Offline
    Nashra
    Most Active Forum Testing
    #563
    Wenn der Adapter per Schedule neu startet geht alles auf rot und bekomme dies
    parcel.0
    	794152	2022-03-09 18:00:00.062	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    parcel.0
    	794152	2022-03-09 18:00:00.061	info	terminating
    host.ioBroker
    		2022-03-09 18:00:00.060	info	instance system.adapter.ical.0 started with pid 804678
    parcel.0
    	794152	2022-03-09 18:00:00.010	info	Scheduled restart.
    Gruß Ralf
    Christoph1337C 1 Antwort Letzte Antwort
    • NashraN Nashra
      parcel.0
      parcel.0
      host.ioBroker
      parcel.0
      Christoph1337C Offline
      Christoph1337
      #564
      Nach dem letzten Update habe ich folgende Fehler im Log.
      parcel.0
      2022-03-10 11:33:21.527	warn	State "parcel.0.amazon.json" has no existing object, this might lead to an error in future versions
      parcel.0
      2022-03-10 11:33:13.441	error	[object Object],[object Object]
      parcel.0
      2022-03-10 11:33:13.437	error	SyntaxError: Unexpected token o in JSON at position 1
      parcel.0
      2022-03-10 11:30:28.803	warn	State "parcel.0.amazon.json" has no existing object, this might lead to an error in future versions
      parcel.0
      2022-03-10 11:30:28.801	warn	State "parcel.0.amazon.json" has no existing object, this might lead to an error in future versions
      parcel.0
      2022-03-10 11:30:19.587	error	[object Object],[object Object]
      parcel.0
      2022-03-10 11:30:19.587	error	SyntaxError: Unexpected token o in JSON at position 1
      parcel.0
      2022-03-10 11:30:19.088	error	[object Object],[object Object]
      parcel.0
      2022-03-10 11:30:19.085	error	SyntaxError: Unexpected token o in JSON at position 1
      • Christoph1337C Christoph1337
        parcel.0
        parcel.0
        parcel.0
        parcel.0
        parcel.0
        parcel.0
        parcel.0
        parcel.0
        parcel.0
        tombox
        #565
        @christoph1337 ist behoben
        XsevX 1 Antwort Letzte Antwort
        • Bastian LahrmannB Offline
          Bastian Lahrmann
          #566
          Parcel: v0.0.10
          Nodejs: 14.19.0
          NPM: 6.14.16
          1. Ich habe im Parcer immer einen Syntax-Error. Wahrscheinlich kommt das von Hermes. Das stört dem Adapter nicht und er funktioniert trotzdem (wobei ich das bisher mit Hermes nicht ausprobieren konnte), aber im Log taucht es auf.
          parcel.0 2022-03-11 07:52:28.242	debug	hermes merge provider json
          parcel.0 2022-03-11 07:52:28.216	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
          parcel.0 2022-03-11 07:52:28.211	error
          parcel.0 2022-03-11 07:52:28.211	error	SyntaxError: Unexpected end of JSON input
          parcel.0 2022-03-11 07:52:28.210	debug	[]
          parcel.0 2022-03-11 07:52:27.852	debug	https://mobile-api.myhermes.de/mobile-api-web/v2/shipments
          parcel.0 2022-03-11 07:52:27.852	debug	ups merge provider json
          1. Jeden Morgen bekomme ich über Telegram alle Pakete von DHL einmal zugeschickt, obwohl sich am Status (abgeschlossen/zugeschickt) nichts geändert hat. Vielleicht kann man diese Meldung noch unterdrücken.
          • T tombox
            XsevX Offline
            XsevX Offline
            Xsev
            #567
            @tombox Hi tombox, ich hab heute mal aktualisiert um zu schauen ob das Problem weg ist aber anscheinend nicht.
            DPD aktualisiert den Status nicht mehr automatisch, nur wenn man den Adapter neu startet aktualisiert er die Daten, da scheint evtl. was faul zu sein.
            • David G.D Online
              David G.D Online
              David G.
              #568
              Habe jetzt mein erstes DPD Paket.
              Da wollte ich mal fragen, wie oft der Adapter das aktualisiert.
              Die App hat mir vor ca 30min einen neuen Status gesendet. Im Adapter ist dieser noch nicht angekommen.
              Bei den verbundenen Geräten sehe ich den Adapter nicht (nur mein Smartphone).
              Edit: Erste Frage hat sich erledigt.
              • DJMarc75D Offline
                DJMarc75D Offline
                DJMarc75
                #569
                Falls ihr Fehler im LOG bzgl DHL habt, DHL hat grad Probleme .... hat nix mit dem Adapter zu tun
                Lehrling seit 1975 !!!
                • Bastian LahrmannB Bastian Lahrmann
                  Parcel: v0.0.10
                  Nodejs: 14.19.0
                  NPM: 6.14.16
                  tombox
                  #570
                  @bastian-lahrmann Ja ich bin noch auf der Suche was da manchmal bei hermes schief geht.
                  Mal die aktuelle Version installieren und schauen ob es weg geht.
                  Es wird der ganze Status überprüft ist der exakt der gleiche. Gerade wenn sich was von heute auf Datum ändert
                  Bastian LahrmannB 1 Antwort Letzte Antwort
                  • XsevX Xsev
                    tombox
                    #571
                    @xsev Ich habe bei dpd noch anpassungen gemacht bitte mal prüfen. Und schauen ob die Aktualisierung sofort kommt oder erst nach 1h.
                    • T tombox
                      Bastian Lahrmann
                      #572
                      @tombox
                      Zumindest sind die Json-Meldungen weg, dafür kommt bei mir seit gestern abend DHL dazu. Mein Anfrageintervall steht auf 20min.
                      parcel.0
                      2022-03-12 06:11:59.540	error	[{"message":"Bitte versuchen Sie es zu einem späteren Zeitpunkt erneut.","headline":"Es ist leider ein Fehler aufgetreten."}]
                      parcel.0
                      2022-03-12 06:11:59.540	error	Error: Request failed with status code 500
                      parcel.0
                      2022-03-12 06:11:59.538	error	https://www.dhl.de/int-aviseanzeigen/advices?width=414
                      • T tombox
                        XsevX Offline
                        XsevX Offline
                        Xsev
                        #573
                        @tombox Danke! Ich kanns aktuell nur nicht testen, da ich grad keine Sendung mehr im Zulauf habe.
                        • DJMarc75D Offline
                          DJMarc75D Offline
                          DJMarc75
                          #574
                          @bastian-lahrmann
                          Seit gestern Störung bei DHL
                          https://allestörungen.de/stoerung/dhl/
                            @tombox
                            parcel.0
                            parcel.0
                            parcel.0
                            #575
                            @bastian-lahrmann
                            https://stadt-bremerhaven.de/post-dhl-app-briefankuendigung-ausgesetzt-datenschutzpanne/
                            @tombox
                            Kann man die Briefankündigung nicht optional in den Einstellungen machen?
                            Bastian LahrmannB ChaotC T 3 Antworten Letzte Antwort
                              @bastian-lahrmann
                              @tombox
                              Bastian Lahrmann
                              #576
                              @thomas-braun Interessant, danke. Über GMX habe ich weiterhin die Briefankündigung erhalten, deshalb meine Verwirrung. Dann hat sich das ja jetzt geklärt.
                                @bastian-lahrmann
                                @tombox
                                ChaotC Offline
                                ChaotC Offline
                                Chaot
                                #577
                                @thomas-braun Hihi, habe ich auch schon gestern gelesen.
                                Lustigerweise kann ich bestätigen das es auch bei Paketen zu solchen Pannen kommt. Ich hatte kürzlich ein Paket meiner Lebensgefährtin in der Ankündigung. Gleiche Adresse, aber anderer Name.
                                • DJMarc75D Offline
                                  DJMarc75D Offline
                                  DJMarc75
                                  #578
                                  @tombox
                                  Meinste man könnte im Backend die Briefankündigung bei DHL schaltbar machen ? Wer weiss wie lange die "Störung" noch existiert. Es wird halt der LOG je nach Intervall immer leicht belastet 😊
                                    @bastian-lahrmann
                                    @tombox
                                    tombox
                                    #579
                                    @thomas-braun Habe eine Erkennung eingebaut falls die Briefankündigung nicht geht wird sie für updates ignoriert.
                                    • T tombox
                                      DJMarc75D Offline
                                      DJMarc75D Offline
                                      DJMarc75
                                      #580
                                      @tombox
                                      Sehr gut gemacht !
                                      • DJMarc75D Offline
                                        DJMarc75D Offline
                                        DJMarc75
                                        #581
                                        @tombox
                                        Kosmetik im Backend:
                                        Doppelter Scrollbalken 😁
                                        • ChaotC Offline
                                          ChaotC Offline
                                          Chaot
                                          #582
                                          Könnte man eventuell einen Datenpunkt einbauen der Anzeigt ob ein Paket in der Zustellung ist?
                                          Ich habe einen Button der die Unterseite mit der Paketinfo aufruft. Jetzt wäre es natürlich schön wenn ich den Button per Datenpunkt kennzeichnen könnte. Also sobald der auf "True" geht blinkt das Symbol oder sowas.
                                          Ich brauche hier dann nicht die Anzahl der Pakete sondern schlicht true/false ob überhaupt eines unterwegs ist.
