  4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
    6.6k
17trackamazonbriefedhldpdglsups
1.6k Beiträge 129 Kommentatoren 727.8k Aufrufe 117 Beobachtet
  • NashraN Offline
    NashraN Offline
    Nashra
    Most Active Forum Testing
    schrieb am zuletzt editiert von Nashra
    #558
    Update vom js-controller gemacht, container neu gestartet
    und Parcel will nicht mehr
    host.ioBroker
    		2022-03-08 17:37:56.148	info	Rebuild for adapter system.adapter.parcel.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    host.ioBroker
    		2022-03-08 17:37:56.148	error	instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.ioBroker
    		2022-03-08 17:37:56.148	error	Caught by controller[0]: }
    host.ioBroker
    		2022-03-08 17:37:56.148	error	Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
    host.ioBroker
    		2022-03-08 17:37:56.148	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12) {
    host.ioBroker
    		2022-03-08 17:37:56.148	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
    host.ioBroker
    		2022-03-08 17:37:56.148	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
    host.ioBroker
    		2022-03-08 17:37:56.148	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
    host.ioBroker
    		2022-03-08 17:37:56.148	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
    host.ioBroker
    		2022-03-08 17:37:56.148	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
    host.ioBroker
    		2022-03-08 17:37:56.148	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
    host.ioBroker
    host.ioBroker
    host.ioBroker
    		2022-03-08 17:37:56.148	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1144:18)
    host.ioBroker
    		2022-03-08 17:37:56.148	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    host.ioBroker
    		2022-03-08 17:37:56.148	error	Caught by controller[0]: NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
    host.ioBroker
    		2022-03-08 17:37:56.148	error	Caught by controller[0]: NODE_MODULE_VERSION 72. This version of Node.js requires
    host.ioBroker
    		2022-03-08 17:37:56.148	error	Caught by controller[0]: was compiled against a different Node.js version using
    host.ioBroker
    		2022-03-08 17:37:56.147	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
    host.ioBroker
    		2022-03-08 17:37:56.147	error	Caught by controller[0]: ^
    host.ioBroker
    		2022-03-08 17:37:56.147	error	Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
    host.ioBroker
    		2022-03-08 17:37:56.147	error	Caught by controller[0]: internal/modules/cjs/loader.js:1144
    host.ioBroker
    		2022-03-08 17:37:55.784	info	instance system.adapter.parcel.0 started with pid 4446
    host.ioBroker
    		2022-03-08 17:37:55.671	info	"system.adapter.parcel.0" enabled
    host.ioBroker
    		2022-03-08 17:37:47.134	info	"system.adapter.parcel.0" disabled
    Oben steht ja "npm install --production", soll ich das im Ordner von Parcel ausführen?
    Gruß Ralf
    • NashraN Nashra
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      #559
      @nashra
      wie oben beschrieben:
      cd /opt/iobroker
      npm install canvas
      Lehrling seit 1975 !!!
      • DJMarc75D DJMarc75
        @nashra
        cd /opt/iobroker
        npm install canvas
        NashraN Offline
        NashraN Offline
        Nashra
        #560
        @djmarc75 sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
        @nashra
        cd /opt/iobroker
        npm install canvas
        installiert, läuft, danke 👍
        Gruß Ralf
        • G Offline
          Gruter
          #561
          Hallo, habe gerade ein Fehler im Log gefunden bzgl Amazon:
          parcel.0
          2022-03-09 09:10:22.003	info	starting. Version 0.0.10 (non-npm: TA2k/ioBroker.parcel#f0b05683d32a7dbdecbbbdd93b1bb45736903364) in /opt/iobroker/node_modules/iobroker.parcel, node: v12.22.10, js-controller: 4.0.15
          parcel.0
          2022-03-09 09:09:44.480	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
          parcel.0
          2022-03-09 09:09:44.478	info	terminating
          parcel.0
          2022-03-09 09:09:44.473	error	Cannot read property 'length' of undefined
          parcel.0
          2022-03-09 09:09:44.472	error	TypeError: Cannot read property 'length' of undefined at Parcel.getAmazonPackages (/opt/iobroker/node_modules/iobroker.parcel/main.js:1477:42) at processTicksAndRejections (internal/process/task_queues.js:97:5)
          parcel.0
          2022-03-09 09:09:44.471	error	unhandled promise rejection: Cannot read property 'length' of undefined
          parcel.0
          2022-03-09 09:09:44.470	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          parcel.0
          2022-03-09 09:09:44.463	error	Error: getaddrinfo EAI_AGAIN www.amazon.de
          Mod-Edit: Code in </> Code-Tag gepackt!
          • G Gruter
            parcel.0
            parcel.0
            parcel.0
            parcel.0
            parcel.0
            parcel.0
            parcel.0
            parcel.0
            tombox
            #562
            @gruter Danke für den hinweis
            • NashraN Offline
              NashraN Offline
              Nashra
              #563
              Wenn der Adapter per Schedule neu startet geht alles auf rot und bekomme dies
              parcel.0
              	794152	2022-03-09 18:00:00.062	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
              parcel.0
              	794152	2022-03-09 18:00:00.061	info	terminating
              host.ioBroker
              		2022-03-09 18:00:00.060	info	instance system.adapter.ical.0 started with pid 804678
              parcel.0
              	794152	2022-03-09 18:00:00.010	info	Scheduled restart.
              Gruß Ralf
              Christoph1337C 1 Antwort Letzte Antwort
              • NashraN Nashra
                parcel.0
                parcel.0
                host.ioBroker
                parcel.0
                Christoph1337C Offline
                Christoph1337
                #564
                Nach dem letzten Update habe ich folgende Fehler im Log.
                parcel.0
                2022-03-10 11:33:21.527	warn	State "parcel.0.amazon.json" has no existing object, this might lead to an error in future versions
                parcel.0
                2022-03-10 11:33:13.441	error	[object Object],[object Object]
                parcel.0
                2022-03-10 11:33:13.437	error	SyntaxError: Unexpected token o in JSON at position 1
                parcel.0
                2022-03-10 11:30:28.803	warn	State "parcel.0.amazon.json" has no existing object, this might lead to an error in future versions
                parcel.0
                2022-03-10 11:30:28.801	warn	State "parcel.0.amazon.json" has no existing object, this might lead to an error in future versions
                parcel.0
                2022-03-10 11:30:19.587	error	[object Object],[object Object]
                parcel.0
                2022-03-10 11:30:19.587	error	SyntaxError: Unexpected token o in JSON at position 1
                parcel.0
                2022-03-10 11:30:19.088	error	[object Object],[object Object]
                parcel.0
                2022-03-10 11:30:19.085	error	SyntaxError: Unexpected token o in JSON at position 1
                • Christoph1337C Christoph1337
                  parcel.0
                  parcel.0
                  parcel.0
                  parcel.0
                  parcel.0
                  parcel.0
                  parcel.0
                  parcel.0
                  parcel.0
                  tombox
                  #565
                  @christoph1337 ist behoben
                  XsevX 1 Antwort Letzte Antwort
                  • Bastian LahrmannB Offline
                    Bastian Lahrmann
                    #566
                    Parcel: v0.0.10
                    Nodejs: 14.19.0
                    NPM: 6.14.16
                    1. Ich habe im Parcer immer einen Syntax-Error. Wahrscheinlich kommt das von Hermes. Das stört dem Adapter nicht und er funktioniert trotzdem (wobei ich das bisher mit Hermes nicht ausprobieren konnte), aber im Log taucht es auf.
                    parcel.0 2022-03-11 07:52:28.242	debug	hermes merge provider json
                    parcel.0 2022-03-11 07:52:28.216	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                    parcel.0 2022-03-11 07:52:28.211	error
                    parcel.0 2022-03-11 07:52:28.211	error	SyntaxError: Unexpected end of JSON input
                    parcel.0 2022-03-11 07:52:28.210	debug	[]
                    parcel.0 2022-03-11 07:52:27.852	debug	https://mobile-api.myhermes.de/mobile-api-web/v2/shipments
                    parcel.0 2022-03-11 07:52:27.852	debug	ups merge provider json
                    1. Jeden Morgen bekomme ich über Telegram alle Pakete von DHL einmal zugeschickt, obwohl sich am Status (abgeschlossen/zugeschickt) nichts geändert hat. Vielleicht kann man diese Meldung noch unterdrücken.
                    • T tombox
                      XsevX Offline
                      XsevX Offline
                      Xsev
                      #567
                      @tombox Hi tombox, ich hab heute mal aktualisiert um zu schauen ob das Problem weg ist aber anscheinend nicht.
                      DPD aktualisiert den Status nicht mehr automatisch, nur wenn man den Adapter neu startet aktualisiert er die Daten, da scheint evtl. was faul zu sein.
                      • David G.D Online
                        David G.D Online
                        David G.
                        #568
                        Habe jetzt mein erstes DPD Paket.
                        Da wollte ich mal fragen, wie oft der Adapter das aktualisiert.
                        Die App hat mir vor ca 30min einen neuen Status gesendet. Im Adapter ist dieser noch nicht angekommen.
                        Bei den verbundenen Geräten sehe ich den Adapter nicht (nur mein Smartphone).
                        Edit: Erste Frage hat sich erledigt.
                        • DJMarc75D Offline
                          DJMarc75D Offline
                          DJMarc75
                          #569
                          Falls ihr Fehler im LOG bzgl DHL habt, DHL hat grad Probleme .... hat nix mit dem Adapter zu tun
                          • Bastian LahrmannB Bastian Lahrmann
                            Parcel: v0.0.10
                            Nodejs: 14.19.0
                            NPM: 6.14.16
                            tombox
                            #570
                            @bastian-lahrmann Ja ich bin noch auf der Suche was da manchmal bei hermes schief geht.
                            Mal die aktuelle Version installieren und schauen ob es weg geht.
                            Es wird der ganze Status überprüft ist der exakt der gleiche. Gerade wenn sich was von heute auf Datum ändert
                            Bastian LahrmannB 1 Antwort Letzte Antwort
                            • XsevX Xsev
                              tombox
                              #571
                              @xsev Ich habe bei dpd noch anpassungen gemacht bitte mal prüfen. Und schauen ob die Aktualisierung sofort kommt oder erst nach 1h.
                              • T tombox
                                Bastian Lahrmann
                                #572
                                @tombox
                                Zumindest sind die Json-Meldungen weg, dafür kommt bei mir seit gestern abend DHL dazu. Mein Anfrageintervall steht auf 20min.
                                parcel.0
                                2022-03-12 06:11:59.540	error	[{"message":"Bitte versuchen Sie es zu einem späteren Zeitpunkt erneut.","headline":"Es ist leider ein Fehler aufgetreten."}]
                                parcel.0
                                2022-03-12 06:11:59.540	error	Error: Request failed with status code 500
                                parcel.0
                                2022-03-12 06:11:59.538	error	https://www.dhl.de/int-aviseanzeigen/advices?width=414
                                • T tombox
                                  XsevX Offline
                                  XsevX Offline
                                  Xsev
                                  #573
                                  @tombox Danke! Ich kanns aktuell nur nicht testen, da ich grad keine Sendung mehr im Zulauf habe.
                                  • DJMarc75D Offline
                                    DJMarc75D Offline
                                    DJMarc75
                                    #574
                                    @bastian-lahrmann
                                    Seit gestern Störung bei DHL
                                    https://allestörungen.de/stoerung/dhl/
                                      @tombox
                                      parcel.0
                                      parcel.0
                                      parcel.0
                                      #575
                                      @bastian-lahrmann
                                      https://stadt-bremerhaven.de/post-dhl-app-briefankuendigung-ausgesetzt-datenschutzpanne/
                                      @tombox
                                      Kann man die Briefankündigung nicht optional in den Einstellungen machen?
                                      Bastian LahrmannB ChaotC T 3 Antworten Letzte Antwort
                                        @bastian-lahrmann
                                        @tombox
                                        Bastian Lahrmann
                                        #576
                                        @thomas-braun Interessant, danke. Über GMX habe ich weiterhin die Briefankündigung erhalten, deshalb meine Verwirrung. Dann hat sich das ja jetzt geklärt.
                                          @bastian-lahrmann
                                          @tombox
                                          ChaotC Offline
                                          ChaotC Offline
                                          Chaot
                                          #577
                                          @thomas-braun Hihi, habe ich auch schon gestern gelesen.
                                          Lustigerweise kann ich bestätigen das es auch bei Paketen zu solchen Pannen kommt. Ich hatte kürzlich ein Paket meiner Lebensgefährtin in der Ankündigung. Gleiche Adresse, aber anderer Name.
