  4. Influx arbeitet nicht mehr stabil
    6.0k
influx grafana vis
214 Beiträge 9 Kommentatoren 29.2k Aufrufe 7 Beobachtet
    @altersrentner und was ergibt oben genannter Befehl
    Altersrentner
    #41
    @crunchip
    pi@raspberrypi:~ $ systemctl status influxdb
    ● influxdb.service - InfluxDB is an open-source, distributed, time series database
       Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
       Active: active (running) since Sun 2021-12-26 12:42:21 CET; 1 day 6h ago
         Docs: man:influxd(1)
     Main PID: 31517 (influxd)
        Tasks: 12 (limit: 4915)
       CGroup: /system.slice/influxdb.service
               └─31517 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
    Dec 26 12:42:29 raspberrypi influxd[31517]: ts=2021-12-26T11:42:29.832169Z lvl=info msg="Reading file" log_id=0YedcTRl000 eng
    Dec 26 12:42:29 raspberrypi influxd[31517]: ts=2021-12-26T11:42:29.848178Z lvl=info msg="Reading file" log_id=0YedcTRl000 eng
    Dec 26 12:42:29 raspberrypi influxd[31517]: ts=2021-12-26T11:42:29.850544Z lvl=info msg="Reading file" log_id=0YedcTRl000 eng
    Dec 26 12:42:29 raspberrypi influxd[31517]: ts=2021-12-26T11:42:29.852423Z lvl=info msg="Reading file" log_id=0YedcTRl000 eng
    Dec 26 12:42:29 raspberrypi influxd[31517]: ts=2021-12-26T11:42:29.964367Z lvl=info msg="Opened shard" log_id=0YedcTRl000 ser
    Dec 26 12:42:31 raspberrypi influxd[31517]: ts=2021-12-26T11:42:31.059900Z lvl=info msg="Reading file" log_id=0YedcTRl000 eng
    Dec 26 12:42:31 raspberrypi influxd[31517]: ts=2021-12-26T11:42:31.881537Z lvl=info msg="Opened shard" log_id=0YedcTRl000 ser
    Dec 26 12:42:32 raspberrypi influxd[31517]: ts=2021-12-26T11:42:32.217254Z lvl=info msg="Opened shard" log_id=0YedcTRl000 ser
    Dec 26 12:42:32 raspberrypi influxd[31517]: ts=2021-12-26T11:42:32.403288Z lvl=info msg="Opened shard" log_id=0YedcTRl000 ser
    Dec 26 12:42:32 raspberrypi influxd[31517]: ts=2021-12-26T11:42:32.895490Z lvl=info msg="Opened shard" log_id=0YedcTRl000 ser
    lines 1-19/19 (END)
    • A Altersrentner
      @crunchip
      lines 1-19/19 (END)
      crunchipC Offline
      crunchipC Offline
      #42
      @altersrentner ok, läuft
      und der Port stimmt auch?
      netstat -tulpen
      A 1 Antwort Letzte Antwort
        netstat -tulpen
        Altersrentner
        #43
        @crunchip sagte in Influx arbeitet nicht mehr stabil:
        netstat -tulpen
        pi@raspberrypi:~ $ netstat -tulpen
        (Not all processes could be identified, non-owned process info
         will not be shown, you would have to be root to see it all.)
        tcp        0      0 192.168.178.41:2000     0.0.0.0:*               LISTEN      1001       438847355  -
        tcp        0      0 192.168.178.41:2001     0.0.0.0:*               LISTEN      1001       438847342  -
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18629      -
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          440637079  -
        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        438413446  -
        tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1000       444599966  -
        tcp        0      0 192.168.178.41:8701     0.0.0.0:*               LISTEN      1001       438847340  -
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       438846252  -
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       438846245  -
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       438848082  -
        tcp6       0      0 :::8083                 :::*                    LISTEN      1001       438853955  -
        tcp6       0      0 :::8084                 :::*                    LISTEN      1001       438852854  -
        tcp6       0      0 :::22                   :::*                    LISTEN      0          18631      -
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          440637078  -
        tcp6       0      0 :::3000                 :::*                    LISTEN      115        21031      -
        tcp6       0      0 ::1:6010                :::*                    LISTEN      1000       444599965  -
        udp        0      0 0.0.0.0:35316           0.0.0.0:*                           108        13988      -
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       438852962  -
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          19477      -
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          440634218  -
        udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       438851959  -
        udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       438849204  -
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13986      -
        udp6       0      0 :::546                  :::*                                0          20423      -
        udp6       0      0 :::58981                :::*                                108        13989      -
        udp6       0      0 :::5353                 :::*                                108        13987      -
        pi@raspberrypi:~ $
        • A Altersrentner
          netstat -tulpen
          pi@raspberrypi:~ $
          crunchipC Offline
          crunchipC Offline
          #44
          @altersrentner nochmal mit sudo davor
            Altersrentner
            #45
            pi@raspberrypi:~ $ sudo netstat -tulpen
            tcp        0      0 192.168.178.41:2000     0.0.0.0:*               LISTEN      1001       438847355  19873/io.hm-rpc.2
            tcp        0      0 192.168.178.41:2001     0.0.0.0:*               LISTEN      1001       438847342  19839/io.hm-rpc.0
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18629      545/sshd
            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          440637079  1343/cupsd
            tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        438413446  31517/influxd
            tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1000       444599966  12996/sshd: pi@pts/
            tcp        0      0 192.168.178.41:8701     0.0.0.0:*               LISTEN      1001       438847340  19846/io.hm-rpc.1
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       438846252  19548/iobroker.js-c
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       438846245  19548/iobroker.js-c
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       438848082  19596/io.admin.0
            tcp6       0      0 :::8083                 :::*                    LISTEN      1001       438853955  20892/io.web.0
            tcp6       0      0 :::8084                 :::*                    LISTEN      1001       438852854  20598/io.socketio.0
            tcp6       0      0 :::22                   :::*                    LISTEN      0          18631      545/sshd
            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          440637078  1343/cupsd
            tcp6       0      0 :::3000                 :::*                    LISTEN      115        21031      512/grafana-server
            tcp6       0      0 ::1:6010                :::*                    LISTEN      1000       444599965  12996/sshd: pi@pts/
            udp        0      0 0.0.0.0:35316           0.0.0.0:*                           108        13988      426/avahi-daemon: r
            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       438852962  20517/io.shelly.0
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          19477      476/dhcpcd
            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          440634218  1344/cups-browsed
            udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       438851959  20510/io.mihome.0
            udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       438849204  19949/io.mihome-vac
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13986      426/avahi-daemon: r
            udp6       0      0 :::546                  :::*                                0          20423      476/dhcpcd
            udp6       0      0 :::58981                :::*                                108        13989      426/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                108        13987      426/avahi-daemon: r
            pi@raspberrypi:~ $
            • A Altersrentner
              pi@raspberrypi:~ $
              #46
              @altersrentner sagte in Influx arbeitet nicht mehr stabil:
              Der lauscht ja auch auf 8088
                crunchipC Offline
                crunchipC Offline
                #47
                @thomas-braun das ist schon richtig, den braucht man doch fürs backup/rdp
                aber es fehlt udp6
                udp6       0      0 :::8089                 :::*                                999        35805      140/influxd
                Thomas BraunT A 2 Antworten Letzte Antwort
                  aber es fehlt udp6
                  #48
                  @crunchip
                  Aber hier wird doch bei Hausnummer 8086 geklingelt?
                  influx 192.168.178.41:8086
                  Aber ich hab influxdb auch nicht im Einsatz... Da bin ich besser mal ruhig. :-D
                    aber es fehlt udp6
                    Altersrentner
                    #49
                    aber es fehlt udp6
                    Und was heißt das jetzt?
                    MfG Michael
                      @crunchip
                      crunchipC Offline
                      crunchipC Offline
                      #50
                      @thomas-braun braucht man fürs backup , z.b mit dem backitup, dafür muss das aktiv sein(in meinem Fall nicht, da ich das nicht nutze)
                      # Bind address to use for the RPC service for backup and restore.
                      # bind-address = "127.0.0.1:8088"
                      • A Altersrentner
                        aber es fehlt udp6
                        MfG Michael
                        crunchipC Offline
                        crunchipC Offline
                        #51
                        @altersrentner seh mal in der config nach, ein wenig nach unten blättern, bei [http]
                        da müsste folgendes stehen
                         # The bind address used by the HTTP service.
                           bind-address = ":8086"
                        die config rufst du so auf
                        nano /etc/influxdb/influxdb.conf
                          Altersrentner
                          #52
                          @crunchip Was soll ich damit machen?
                          Backitup ist bei mir nicht aktiviert
                          • A Altersrentner
                            crunchipC Offline
                            crunchipC Offline
                            #53
                            @altersrentner du sollst in die config sehen, ob es so aussieht wie gezeigt
                              Altersrentner
                              #54
                              [http]
                                # Determines whether HTTP endpoint is enabled.
                                # enabled = true
                                # bind-address = ":8086"
                                # Determines whether user authentication is enabled over HTTP/HTTPS.
                                # auth-enabled = false
                                # The default realm sent back when issuing a basic auth challenge.
                                # realm = "InfluxDB"
                              • A Altersrentner
                                [http]
                                  # enabled = true
                                crunchipC Offline
                                crunchipC Offline
                                #55
                                @altersrentner aus dieser Zeile
                                #bind-address = ":8086"
                                machst du
                                  machst du
                                  #56
                                  @Altersrentner
                                  Und dann influxdb neustarten.
                                    @Altersrentner
                                    crunchipC Offline
                                    crunchipC Offline
                                    #57
                                    @Altersrentner
                                    sudo service influxdb restart
                                      machst du
                                      Altersrentner
                                      #58
                                      machst du
                                      OK habe ich gemacht,
                                      Wie speichern und wie conf verlassen?
                                      • A Altersrentner
                                        machst du
                                        #59
                                        @altersrentner
                                        Strg-X, Rückfrage bestätigen.
                                        • A Altersrentner
                                          machst du
                                          crunchipC Offline
                                          crunchipC Offline
                                          #60
                                          @altersrentner sehe gerade, diese muss auch aktiviert werden
                                             enabled = true
                                          also auch die # davor entfernen
