  3. Marktplatz
  4. [Verkaufe] Zigbee LAN/USB/WLAN Gateway CC2652P
    5.8k
Geplant Angeheftet Gesperrt Verschoben Marktplatz
236 Beiträge 54 Kommentatoren 75.4k Aufrufe 53 Beobachtet
  • qqolliQ qqolli
    @dimaiv
    Ok, sorry:
    zigbee.0
    2022-07-23 16:41:49.738	error	Error herdsman start
    zigbee.0
    2022-07-23 16:41:49.738	error	Failed to start Zigbee
    zigbee.0
    2022-07-23 16:41:49.737	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
    zigbee.0
    2022-07-23 16:41:49.736	error	Re-commissioning your network will require re-pairing of all devices!
    zigbee.0
    2022-07-23 16:41:49.736	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
    zigbee.0
    2022-07-23 16:41:49.736	error	Please update configuration to prevent further issues.
    zigbee.0
    2022-07-23 16:41:49.736	error	- Channel List: configured=11, adapter=11
    zigbee.0
    2022-07-23 16:41:49.736	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
    zigbee.0
    2022-07-23 16:41:49.736	error	- Extended PAN ID: configured=4d1517db8593869a, adapter=00124b00257910df
    zigbee.0
    2022-07-23 16:41:49.735	error	- PAN ID: configured=6745, adapter=6754
    zigbee.0
    2022-07-23 16:41:49.735	error	Configuration is not consistent with adapter state/backup!
    zigbee.0
    2022-07-23 16:41:48.537	info	Installed Version: iobroker.zigbee@1.7.5
    zigbee.0
    2022-07-23 16:41:48.535	debug	Starting zigbee-herdsman...
    zigbee.0
    2022-07-23 16:41:48.535	info	Starting Zigbee npm ...
    zigbee.0
    2022-07-23 16:41:48.534	info	Try to reconnect.
    Wie gesagt, Hatte die erweiterte Pan ID und Pan ID geändert, Transportschlüssel erstmal so gelassen. Jetzt meckert er deswegen :-)
    Edit: Oder soll ich mal, wie weiter oben empfohlen die unter /opt/iobroker/iobroker-data/zigbee_0 die vorhandenen Dateien (shepherd.db, nvbackup.json) löschen und Adapter neu starten?
    Dominik F.D Offline
    Dominik F.D Offline
    Dominik F.
    schrieb am zuletzt editiert von Dominik F.
    #181
    @qqolli
    Trag mal das als erweiterte Pan-ID ein:00124b00257910df
    und das als Pan-ID: 6754
    • qqolliQ qqolli
      @dimaiv
      Ok, sorry:
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      dimaiv
      #182
      @qqolli
      1. Stoppen Zigbee Adapter!!!
      2. Mach das was im Log steht "If you wish to...."
      3. Starte Zigbee Gateway neu.
      4. Starte Zigbee Adapter.
      ioBroker- NUC8i3 / Proxmox / VM
      Node.js v22.21.0
      NPM v10.9.4
      JS controller 7.1.0
      Admin 7.7.20
      ZigBee Adapter 3.3.1alpha.0
      Zigbee LAN Gateway CC2652P
      Zigbee Firmware 20250321
      qqolliQ 1 Antwort Letzte Antwort
      • qqolliQ qqolli
        @dimaiv
        Ok, sorry:
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        Dominik F.D Offline
        Dominik F.D Offline
        Dominik F.
        #183
        @qqolli
        Ich hatte auch folgende Unterschiede gehabt und hab das die genommen, die der Adapter hatte und dann hat es funktioniert:
        zigbee.0
        zigbee.0
        • D dimaiv
          @qqolli
          qqolliQ Offline
          qqolliQ Offline
          qqolli
          #184
          @dimaiv
          Na super! Jetzt geht er. Und die Werte von @Dominik-F hatte ich auch noch eingetragen:
          Vielen Dank!
          • BananaJoeB Offline
            BananaJoeB Offline
            BananaJoe
            #185
            @qqolli eines von beiden hätte es getan :-) Aber so ist auch ok
            • BananaJoeB BananaJoe
              qqolliQ Offline
              qqolliQ Offline
              qqolli
              #186
              @bananajoe
              Stimmt, aber du weißt ja: Viel hilft viel 😀
              Jetzt graut es mir nur noch vor der Umstellung, da ich mein Produktivsystem immer noch auf Raspi mit ConBee 2 laufen habe. ioB auf Proxmox mit dem Gateway läuft super und die Umstellung wird interessant :-) Obwohl es eigentlich per BackitUp "einfach" gehen müsste; soweit die Theorie.
              • D dimaiv
                Hersteller " Ich "
                Model "CC2652P + WT32-ETH01, Einsatzbereit"
                Anzahl 1, Sofort verfügbar
                *Preis pro Stück 60 €, Anfragen über Chat Nachricht oder Telegramm: https://t.me/Zigbee1
                Versand "in DE inkl., mit Verfolgungsnummer"
                Beschreibung "Leistungsstarke ZigBee Stick / LAN Gateway mit Z-Stack 3.x.0, Update über LAN/USB, mit 3 dBi Antenne und Gehäuse"
                Es gibt ab sofort Diskussion-Thread:
                FAQ. Zigbee Gateway
                M Online
                M Online
                michihorn
                schrieb am zuletzt editiert von michihorn
                #187
                @dimaiv Danke für die super schnelle Lieferung.
                Installation war einfach, klappte auf Anhieb, dass Übertragen der Daten dauert zuerst ein paar Minuten.
                Der Leistungsgewinn ist überragend.
                Habe den Stick im übrigen im Ferienhaus installiert, das ist über VPN mit der Heimat verbunden ist. Ich habe eine zusätzliche Zigbee Instance aufgelegt. So entfällt die MQTT Übertragung. 👍
                  Rushmed
                  schrieb am zuletzt editiert von Rushmed
                  #188
                  @dimaiv Danke für die schnelle Lieferung. Stick läuft. Danke auch für die Anleitung.
                  Das Ding hat ja sogar WiFi.
                    Tobias 0
                    schrieb am zuletzt editiert von Tobias 0
                    #189
                    @dimaiv Danke für die schnelle Lieferung und die Erklärung vorab per telegram. Es war schon fast zu einfach. Anstecken, IP-Eintragen und warten bis der Adapter Grün wurde. Alle geräte blieben erhalten beim Wechsel und die angezeigte Leistung hat sich beim schwächsten Empfänger um 50 verbessert. Also was soll man sagen einfach perfekt! 👍
                    • D dimaiv
                      Hersteller " Ich "
                      FAQ. Zigbee Gateway
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      liv-in-sky
                      #190
                      @dimaiv
                      erstmal vielen dank für die schnelle lieferung :-)
                      ich wollte das ganze nun mit zigbee2mqtt installieren
                      meine configuration.yaml sieht so aus:
                      homeassistant: false
                      permit_join: true
                      frontend:
                         port: 8080
                         host: 0.0.0.0
                      mqtt:
                         base_topic: zigbee2mqtt
                         server: mqtt://192.168.178.59:1890
                      serial:
                         port: 'tcp://192.168.178.141:6638'
                      advanced:
                         pan_id: 0x1A79
                         ext_pan_id: [0xDD, 0xDD, 0xDD, 0xDD, 0xAA, 0xAD, 0xDD, 0xDD]
                         channel: 14
                         network_key: [0x01, 0x03, 0x05, 0x07, 0x09, 0x0B, 0x0D, 0x0F, 0x00, 0x02, 0x04, 0x06, 0x08, 0x0A>
                         last_seen: ISO_8601_local
                         homeassistant_legacy_entity_attributes: false
                         legacy_api: false
                         legacy_availability_payload: false
                         output: json
                         transmit_power: 20
                         log_level: warn
                      device_options:
                         legacy: false
                      availability: true
                      beim aufruf des servers kommt aber:
                      $ npm start
                      > zigbee2mqtt@1.28.2 start
                      > node index.js
                      Zigbee2MQTT:info  2022-11-20 08:33:09: Logging to console and directory: '/opt/zigbee2mqtt/data/log/2022-11-20.08-33-09' filename: log.txt
                      Zigbee2MQTT:info  2022-11-20 08:33:09: Starting Zigbee2MQTT version 1.28.2 (commit #e66fe85)
                      Zigbee2MQTT:info  2022-11-20 08:33:09: Starting zigbee-herdsman (0.14.68)
                      Zigbee2MQTT:error 2022-11-20 08:33:09: Error while starting zigbee-herdsman
                      Zigbee2MQTT:error 2022-11-20 08:33:09: Failed to start zigbee
                      Zigbee2MQTT:error 2022-11-20 08:33:09: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
                      Zigbee2MQTT:error 2022-11-20 08:33:09: Exiting...
                      Zigbee2MQTT:error 2022-11-20 08:33:09: Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
                          at SerialPort.<anonymous> (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:146:28)
                          at SerialPort._error (/opt/zigbee2mqtt/node_modules/@serialport/stream/lib/index.js:198:14)
                          at /opt/zigbee2mqtt/node_modules/@serialport/stream/lib/index.js:242:12
                      irgendwie will er /dev/ttyACM0 - ist aber anders konfiguriert - hättest du eine idee für mich
                      crunchipC D 2 Antworten Letzte Antwort
                      • liv-in-skyL liv-in-sky
                        @dimaiv
                        permit_join: true
                        frontend:
                           port: 8080
                           host: 0.0.0.0
                        mqtt:
                        serial:
                        advanced:
                           pan_id: 0x1A79
                           channel: 14
                           legacy_api: false
                           output: json
                           transmit_power: 20
                           log_level: warn
                        device_options:
                           legacy: false
                        availability: true
                        $ npm start
                        > node index.js
                        crunchipC Offline
                        crunchipC Offline
                        #191
                        @liv-in-sky hast du z2m auch neu gestartet?
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          liv-in-sky
                          #192
                          @crunchip ja - habe ich
                            crunchipC Offline
                            crunchipC Offline
                            #193
                            @liv-in-sky sagte in [Verkaufe] Zigbee LAN/USB/WLAN Gateway CC2652P:
                            bei mir ist das so eingetragen, vllt liegts daran
                            serial:
                              port: tcp://10.1.20.7:20108
                              serial:
                              liv-in-skyL Offline
                              liv-in-skyL Offline
                              liv-in-sky
                              #194
                              @crunchip habe es lt: https://forum.iobroker.net/post/693392 gemacht
                              aber habe auch mal deines getestet - kommt leider die selbe fehlermeldung
                                crunchipC Offline
                                crunchipC Offline
                                #195
                                @liv-in-sky na ich meine ohne die ' '
                                stick ist erreichbar?
                                liv-in-skyL 3 Antworten Letzte Antwort
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  liv-in-sky
                                  #196
                                  @crunchip ohne und mit probiert - mit habe probiert, weil hier:
                                  aber ich denke da fehlt was anderes, weil im fehler immer auf den cannot open /dev/ttyACM0 hingewiesen wird
                                    liv-in-skyL Offline
                                    liv-in-skyL Offline
                                    liv-in-sky
                                    #197
                                    @crunchip sagte in [Verkaufe] Zigbee LAN/USB/WLAN Gateway CC2652P:
                                    wie stell ich das fest - weiß nur er ist im netzwerk mit ip
                                      liv-in-skyL Offline
                                      liv-in-skyL Offline
                                      liv-in-sky
                                      #198
                                      @crunchip
                                      könnte es ein problem sein, weil proxmox lxc ??
                                        crunchipC Offline
                                        crunchipC Offline
                                        #199
                                        @liv-in-sky vllt passt der port nicht
                                        weil proxmox lxc
                                        hab ich auch
                                        hab von hier installiert
                                          @dimaiv
                                          permit_join: true
                                          frontend:
                                             port: 8080
                                             host: 0.0.0.0
                                          mqtt:
                                          serial:
                                          advanced:
                                             pan_id: 0x1A79
                                             channel: 14
                                             legacy_api: false
                                             output: json
                                             transmit_power: 20
                                             log_level: warn
                                          device_options:
                                             legacy: false
                                          availability: true
                                          $ npm start
                                          > node index.js
                                          dimaiv
                                          #200
                                          @liv-in-sky
                                          Hier werden nur Verkaufsfragen beantwortet.
                                          Bitte für Z2M ein eigenen Thread auf machen.
                                          Danke.
                                          Node.js v22.21.0
                                          NPM v10.9.4
                                          JS controller 7.1.0
                                          Admin 7.7.20
                                          liv-in-skyL CodierknechtC 2 Antworten Letzte Antwort
