  4. Anfänger sucht Hilfe bei Install. proxmox auf INTELNUC8i3BEK
    2.5k
    4.5k
1.0k Beiträge 16 Kommentatoren 291.7k Aufrufe 15 Beobachtet
  • dslraserD dslraser
    @crunchip sagte in Anfänger sucht Hilfe bei Install. proxmox auf INTELNUC8i3BEK:
    show series
    hast du das dashboard gespeichert?
    ja
    > use proxmox
    Using database proxmox
    > show series
    key
    ballooninfo,host=RaspberryMatic,nodename=pve,object=qemu,vmid=220
    blockstat,host=RaspberryMatic,instance=sata0,nodename=pve,object=qemu,vmid=220
    blockstat,host=pve,object=nodes
    cpustat,host=pve,object=nodes
    memory,host=pve,object=nodes
    nics,host=RaspberryMatic,instance=tap220i0,nodename=pve,object=qemu,vmid=220
    nics,host=pve,instance=eno1,object=nodes
    nics,host=pve,instance=fwbr220i0,object=nodes
    nics,host=pve,instance=fwbr230i0,object=nodes
    nics,host=pve,instance=fwbr240i0,object=nodes
    nics,host=pve,instance=fwbr250i0,object=nodes
    nics,host=pve,instance=fwln220i0,object=nodes
    nics,host=pve,instance=fwln230i0,object=nodes
    nics,host=pve,instance=fwln240i0,object=nodes
    nics,host=pve,instance=fwln250i0,object=nodes
    nics,host=pve,instance=fwpr220p0,object=nodes
    nics,host=pve,instance=fwpr230p0,object=nodes
    nics,host=pve,instance=fwpr240p0,object=nodes
    nics,host=pve,instance=fwpr250p0,object=nodes
    nics,host=pve,instance=lo,object=nodes
    nics,host=pve,instance=tap220i0,object=nodes
    nics,host=pve,instance=veth230i0,object=nodes
    nics,host=pve,instance=veth240i0,object=nodes
    nics,host=pve,instance=veth250i0,object=nodes
    nics,host=pve,instance=vmbr0,object=nodes
    nics,host=pve,instance=wlp0s20f3,object=nodes
    proxmox-support,host=RaspberryMatic,nodename=pve,object=qemu,vmid=220
    system,host=Backup,nodename=pve,object=storages,type=cifs
    system,host=Grafana,nodename=pve,object=lxc,vmid=250
    system,host=INFLUXDB,nodename=pve,object=lxc,vmid=240
    system,host=RaspberryMatic,nodename=pve,object=qemu,vmid=220
    system,host=iobroker,nodename=pve,object=lxc,vmid=230
    system,host=local,nodename=pve,object=storages,type=dir
    system,host=local-lvm,nodename=pve,object=storages,type=lvmthin
    system,host=pve,object=nodes
    crunchipC Abwesend
    crunchipC Abwesend
    #681
    @dslraser da fehlt aber einiges an Daten
    eventuell mal neustarten, Influx und Grafana
      @goetschhofer hab mal in google nachgesehen
      error unable to read tail (got 0 bytes)
      finde aber spontan nichts Treffendes, da es mehrere Ursachen haben kann
      • kernel bug (passthrough)
      • bios (efi/legacy boot)
      • Speicherproblem
      • Problem mit deiner VM selbst
      ich weiß auch nicht was du gestern um 8:54, bzw 15:45 gemacht hast
      @goetschhofer sagte in Anfänger sucht Hilfe bei Install. proxmox auf INTELNUC8i3BEK:
      Im /var/log sehe ich nichts Auffälliges.
      wenn, dann musst du dir das jeweilige log ansehen
      gegebenenfalls solltest dich besser mal im FORUM anmelden, da es dann doch eher speziell um Proxmox geht.
      GOETSCHHOFER
      schrieb am zuletzt editiert von GOETSCHHOFER
      #682
      @crunchip said in Anfänger sucht Hilfe bei Install. proxmox auf INTELNUC8i3BEK:
      • Speicherproblem
      Gestern um 8 h 54 habe ich alte backups gelöscht, da ich schon 6 backups am USB-backup-Stick hatte.
      • G GOETSCHHOFER
        • Speicherproblem
        crunchipC Abwesend
        crunchipC Abwesend
        #683
        aber das hast du doch eingestellt, da muss man nichts mehr manuell löschen, das geht automatisch
        die Frage bleibt aber, was war bei 15:45:03
        G 3 Antworten Letzte Antwort
          GOETSCHHOFER
          #684
          Es waren schon 6 backups am Stick und da habe ich das letzte gelöscht, da war mal ein händisches Zwischendurch, da ich ja vor 2 Tagen das gleiche Problem hatte, wo er kein backup gemacht hat.
          08:54 alte backups löschen.
          Ja, um ca. 15:45:03 habe ich gestern im BIOS den Autostart nach Stromausfall eingestellt.
            dslraserD Offline
            dslraserD Offline
            dslraser
            #685
            @crunchip
            das habe ich noch vergessen. Wie lege ich mit nano eine Datei an ?
              @crunchip
              crunchipC Abwesend
              crunchipC Abwesend
              #686
              @dslraser sagte in Anfänger sucht Hilfe bei Install. proxmox auf INTELNUC8i3BEK:
              das ist genau das, was du direkt in der gui eingestellt hast (Metrikserver) früher musste man das händisch anlegen, daher schrieb ich zu beginn, das fällt weg bei der Anleitung
              • G GOETSCHHOFER
                crunchipC Abwesend
                crunchipC Abwesend
                #687
                da stimmt aber was nicht, denn 7 sec später starten deine Maschine ja schon wieder??
                  dslraserD Offline
                  dslraserD Offline
                  dslraser
                  #688
                  @crunchip
                  Ich habe mal komplett neu gestartet. (also nicht nur Grafana und die DB) 👍
                    GOETSCHHOFER
                    #689
                    @crunchip
                    Ich hätte Zwischendurch eine andere Frage zu Grafana:
                    Aktuell habe ich 7.0.0.
                    Auf welche Version würdest du mir empfehlen soll ich updaten ?
                    Es gibt ja offenbar mehrere Möglichkeiten für ein update ?
                    Ich bekomme bei Neuanlage eines Dasboards links oben folgende Fehlermeldung:
                    Cannot read property "toFixed" of undefined.
                    Laut meiner Recherche wird dieses Problem bei Version 7.0.3 gelöst.
                      @crunchip
                      crunchipC Abwesend
                      crunchipC Abwesend
                      #690
                      @dslraser je nachdem was du als storage verwendest, musst du im dashboard ganz noch entsprechend anpassen(falls du anderweitigen storage verwendest)
                      Beispiel bei mir
                      • G GOETSCHHOFER
                        @crunchip
                        crunchipC Abwesend
                        crunchipC Abwesend
                        #691
                        solltest eigentlich 7.5.4 haben
                        G 1 Antwort Letzte Antwort
                          Beispiel bei mir
                          dslraserD Offline
                          dslraserD Offline
                          dslraser
                          #692
                          @crunchip
                          ja, backup wird z.B. mit NA dargestellt, muß ich mal schauen wo/wie ich das ändere. Erstmal vielen Dank bis hierhin schonmal.👍 😊
                            @crunchip
                            crunchipC Abwesend
                            crunchipC Abwesend
                            #693
                            @dslraser das musst du den query editieren
                            Beispiel
                            das storage heisst datashare
                            SELECT last("used") / last("total") FROM "system" WHERE ("host" = 'datashare' AND "nodename" =~ /^$server$/) AND $timeFilter GROUP BY time($__interval) fill(null)
                            wenn du mehrere Laufwerke hast, kannst du eine duplizieren, und dann "datashare" ersetzen
                              Beispiel
                              dslraserD Offline
                              dslraserD Offline
                              dslraser
                              #694
                              datashare
                              Perfekt (bei mir heißt es Backup)
                                GOETSCHHOFER
                                #695
                                7.5.7 ist aktuell vor 8.00 Beta-01.
                                https://grafana.com/grafana/download?utm_source=grafana_footer
                                Kann ich damit Grafana updaten ohne auf die Nase zu fliegen oder gibt es auch eine andere Möglichkeit upzudaten ?
                                Ubuntu und Debian(64 Bit)SHA256: f98d7b75fd269414233e8a0e751e0dcf7d687e576220a86df570b78ef3d798ce
                                sudo apt-get install -y adduser
                                libfontconfig1wget https://dl.grafana.com/oss/release/grafana_7.5.7_amd64.deb
                                sudo dpkg -i grafana_7.5.7_amd64.deb
                                • G GOETSCHHOFER
                                  #696
                                  @goetschhofer
                                  Man installiert unter Linux/Debian nix manuell von irgendwoher. Man nutzt seinen Paketmanager.
                                  apt policy grafana
                                  liefert?
                                    @goetschhofer
                                    apt policy grafana
                                    liefert?
                                    GOETSCHHOFER
                                    #697
                                    @thomas-braun said in Anfänger sucht Hilfe bei Install. proxmox auf INTELNUC8i3BEK:
                                    apt policy grafana
                                    • G GOETSCHHOFER
                                      crunchipC Abwesend
                                      crunchipC Abwesend
                                      #698
                                      @goetschhofer du hattest doch per apt installiert????
                                      • G GOETSCHHOFER
                                        apt policy grafana
                                        #699
                                        @goetschhofer
                                        Warum Enterprise? Das ist keine Version für Privatiers.
                                        Leg da ein Repo für die OSS-Version an.
                                        Müsste
                                        https://packages.grafana.com/oss/deb stable main
                                        sein.
                                        • G GOETSCHHOFER
                                          apt policy grafana
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          #700
                                          @goetschhofer du brauchst dieses
