  4. js-controller 3.3 jetzt im Beta
    2.4k
    4.3k
791 Beiträge 75 Kommentatoren 275.2k Aufrufe 56 Beobachtet
  • apollon77A apollon77
    @luie Für rpi bitte ein Issue im Github mit Debug log. Info Adapter bitte GitHub testen
    luie
    #521
    @apollon77
    Und mit dem Info-Adapter sieht das jetzt so aus. Der Fehler liegt wohl an meinem System?
    2021-07-16 20:35:00.822 - info: host.raspi "system.adapter.info.0" enabled
    2021-07-16 20:35:01.356 - info: host.raspi instance system.adapter.info.0 started with pid 6020
    2021-07-16 20:35:04.549 - info: info.0 (6020) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2021-07-16 20:35:04.567 - info: info.0 (6020) starting. Version 1.8.0 in /opt/iobroker/node_modules/iobroker.info, node: v14.17.2, js-controller: 3.3.14
    2021-07-16 20:35:04.636 - info: info.0 (6020) Reading/updating systemdata.
    2021-07-16 20:35:06.007 - error: info.0 (6020) uncaught exception: EACCES: permission denied, scandir '/var/lib/bluetooth/'
    2021-07-16 20:35:06.013 - error: info.0 (6020) Error: EACCES: permission denied, scandir '/var/lib/bluetooth/'
    at readdirSync (fs.js:1043:3)
    at getDirectories (/opt/iobroker/node_modules/systeminformation/lib/util.js:680:12)
    at getFilesRecursively (/opt/iobroker/node_modules/systeminformation/lib/util.js:687:16)
    at Object.getFilesInPath (/opt/iobroker/node_modules/systeminformation/lib/util.js:695:12)
    at /opt/iobroker/node_modules/systeminformation/lib/bluetooth.js:98:30
    at processTicksAndRejections (internal/process/task_queues.js:77:11)
    2021-07-16 20:35:06.015 - error: info.0 (6020) Exception-Code: EACCES: EACCES: permission denied, scandir '/var/lib/bluetooth/'
    2021-07-16 20:35:07.224 - info: info.0 (6020) cleaned everything up...
    2021-07-16 20:35:07.226 - info: info.0 (6020) terminating
    2021-07-16 20:35:07.230 - warn: info.0 (6020) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2021-07-16 20:35:07.378 - info: info.0 (6020) State value to set for "info.0.sysinfo.cpu.currentLoad.cpus-0" has to be stringified but received type "object"
    2021-07-16 20:35:07.379 - info: info.0 (6020) State value to set for "info.0.sysinfo.cpu.currentLoad.cpus-1" has to be stringified but received type "object"
    2021-07-16 20:35:07.381 - info: info.0 (6020) State value to set for "info.0.sysinfo.cpu.currentLoad.cpus-2" has to be stringified but received type "object"
    2021-07-16 20:35:07.385 - info: info.0 (6020) State value to set for "info.0.sysinfo.cpu.currentLoad.cpus-3" has to be stringified but received type "object"
    2021-07-16 20:35:08.094 - warn: info.0 (6020) get state error: Connection is closed.
    2021-07-16 20:35:08.095 - warn: info.0 (6020) get state error: DB closed
    2021-07-16 20:35:08.148 - warn: info.0 (6020) get state error: DB closed
    2021-07-16 20:35:08.150 - warn: info.0 (6020) get state error: DB closed
    2021-07-16 20:35:08.164 - warn: info.0 (6020) get state error: Connection is closed.
    2021-07-16 20:35:08.257 - warn: info.0 (6020) Could not perform strict object check of state info.0.newsfeed_filtered: Connection is closed.
    2021-07-16 20:35:08.259 - warn: info.0 (6020) get state error: Connection is closed.
    2021-07-16 20:35:08.357 - error: host.raspi instance system.adapter.info.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2021-07-16 20:35:08.359 - info: host.raspi Restart adapter system.adapter.info.0 because enabled
    debian13-x64, docker, SONOFF ZigBee 3.0 USB DONGLE PLUS, Admin 7.8.29, Node.js v22.22.2, NPM 10.9.7, js-controller 7.1.2
    • JB_SullivanJ Offline
      JB_Sullivan
      #522
      Habe noch einen Adapter gefunden. Auch nur Entwickler oder ggf. ebenfalls Community?
      spotify-premium.0	2021-07-16 21:03:46.219	info	(10336) State value to set for "spotify-premium.0.authorization.token" has to be stringified but received type "object"
      apollon77A 2 Antworten Letzte Antwort
      • L luie
        @apollon77
        Ich hoffe das ist so richtig.
        https://github.com/iobroker-community-adapters/ioBroker.rpi2/issues/72#issuecomment-881637186
        #523
        @luie Perfekt, da war noch ne zweite Code-Stelle ... Bitte GitHub Version testen
        L 1 Antwort Letzte Antwort
        • JB_SullivanJ JB_Sullivan
          @apollon77 NOPE
          Roomba läuft immer noch nicht
          roomba.0	2021-07-16 20:40:13.405	info	(15356) State value to set for "roomba.0.missions.current.runtime" has to be type "string" but received type "number"
          roomba.0	2021-07-16 20:40:12.603	info	(15356) State value to set for "roomba.0.missions.current.runtime" has to be type "string" but received type "number"
          roomba.0	2021-07-16 20:40:11.028	info	(15356) State value to set for "roomba.0.missions.current.runtime" has to be type "string" but received type "number"
          roomba.0	2021-07-16 20:40:11.025	info	(15356) State value to set for "roomba.0.missions.current.started" has to be type "string" but received type "number"
          roomba.0	2021-07-16 20:40:11.024	info	(15356) State value to set for "roomba.0.missions.current.id" has to be type "string" but received type "number"
          roomba.0	2021-07-16 20:40:10.994	info	(15356) Roomba has started a new mission (#434).
          roomba.0	2021-07-16 20:40:09.775	info	(15356) Triggered action -start- on Roomba.
          web.0	2021-07-16 20:39:36.732	info	(14512) ==>Connected system.user.admin from
          #524
          @jb_sullivan Na du kommst ja auch immer mit neuen IDs die vorher nie in den Logs waren. Ich muss JEDE ID einzeln definieren!!
          Geändert auf GitHub ... dann die nächsten Bitte? ;-)
          JB_SullivanJ 1 Antwort Letzte Antwort
            luie
            #525
            @apollon77
            rpi2 - keine Fehler mehr. Danke👍
            • L luie
              @apollon77
              #526
              @luie Ok, die Exception habe ich an den einen Library Dev weitergegeben - der ist an sich recht fix.
              Ansonsten hab ich GitHub nochmal aktualisierrt für den Rest
                #527
                @jb_sullivan Immer GitHub issues machen!!! Aber ja den kann ich mir ansehen
                  #528
                  @jb_sullivan Github update bitte versuchen
                    JB_Sullivan
                    schrieb am zuletzt editiert von JB_Sullivan
                    #529
                    @apollon77 sagte in js-controller 3.3 jetzt im Beta:
                    Ähm sorry, das kann ich ja nicht ahnen/wissen. Ich dachte das wäre irgend etwas globales was man einmal irgendwo umstellen muss.
                    D.h. aber auch im Umkehrschluss, das man im Grunde ALLE Funktionen von ALLEN Geräten testen muss, denn nur wenn sich der Datenpunkt ändert, spuckt er ggf. auch eine Fehlermeldung aus?!?
                    Na, da könnte noch einiges kommen (z.B. Heizkörper Thermostate - weil nur im Winter in Betrieb) oder Datenpunkte die nur bei bestimmten Betriebszuständen geschrieben werden, was man so ggf. gar nicht simulieren kann oder gar nicht auf dem Schirm hat.
                    M apollon77A 2 Antworten Letzte Antwort
                      Marty56
                      #530
                      Beim tr64 Adapter kommt bei mir
                      State value to set for "tr-064.0.callmonitor.outbound.callee" has to be type "number" but received type "string"
                      HW:NUC (16 GB Ram)
                      OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
                      JB_SullivanJ apollon77A 2 Antworten Letzte Antwort
                      • M Marty56
                        JB_Sullivan
                        #531
                        @marty56
                        Da ich ja gerade gelernt habe, das jeder DP einzeln angepasst werden muss, hier auch noch zwei weitere Fehlermeldungen zum tr64 Adapter.
                        web.0	2021-07-17 12:27:25.303	info	(14512) State value to set for "tr-064.0.callForwarding.7" has to be type "boolean" but received type "number"
                        web.0	2021-07-17 12:27:23.048	info	(14512) State value to set for "tr-064.0.callForwarding.7" has to be type "boolean" but received type "number"
                          Hey All,
                          so es war ein langer weg. Ich habe die letzten Woche fast nur Adapter gefixt wegen der js-controller 3.3 Warnungen. Alle Adapter die irgendwie zur ioBroker Orga oder Adapter-Community gehören von denen ich es weiss sind gefixt (Alle, fast alle ... siehe nächster Absatz...). Daher bitte aktualisiert mal auf aktuellste Latest und setzt die Error level wieder auf info und sagt was noch ist bitte. Bitte im Zweifel mal die Adapterobjekte löschen und neu anlegen lassen
                          Noch bekannte Themen:
                          • sonoff braucht Bluefox Infos. bitte hier schauen wer noch Meldungen hat und melden!
                          • statistics gibts noch eine offene zu klärende Frage, kann also auch noch Meldungen bei "avg" geben. Auch hier "bester" Stand ist GitHub, aber an sich ausser dem einen Thema soweit bestätigt
                          • rpi2: Bitte mal GitHub Version checken, weil da noch andere Dinge drin sind und sagen ob noch alles ok ist
                          Was sonst noch offen?
                          (Ich denke wled oder so hat noch was?)
                          luie
                          #532
                          @apollon77
                          Der fritzdect-Adapter ist auch noch fehlerhaft.
                          https://github.com/foxthefox/ioBroker.fritzdect/issues/187
                            #533
                            @jb_sullivan Jupp, bitte einfach wenn SIe auftauchen per GitHub Issue melden
                            • M Marty56
                              #534
                              @marty56 sagte in js-controller 3.3 jetzt im Beta:
                              callee
                              Welche Version? die aktuellste? Bitte callee Objekt löschen, wird beim nächsten Anruf neu angelegt. Dann weg?
                                @marty56
                                #535
                                @jb_sullivan sagte in js-controller 3.3 jetzt im Beta:
                                callForwarding
                                Debug Log bitte wo der Fehler drin ist als GitHub issue bitte
                                  callee
                                  Marty56
                                  schrieb am zuletzt editiert von Marty56
                                  #536
                                  @apollon77 Ich habe die aktuellste (4.2.13) installiert.
                                  Jetzt habe ich den ganzen Tree gelöscht und bekomme beim Start
                                  State value to set for "tr-064.0.states.ab" has to be type "boolean" but received type "string"
                                  Anruf habe ich noch nicht testen können.
                                  HW:NUC (16 GB Ram)
                                  • M Marty56
                                    #537
                                    @marty56 Kommt nur beim ersten start wenn er die Objekte anlegt oder immer? Bitte GitHub issue
                                      callForwarding
                                      JB_Sullivan
                                      #538
                                      @apollon77
                                      ist das jetzt ein tr64 Adapter oder web Adapter issue?
                                      web.0	2021-07-18 09:32:27.582	info	(6016) State value to set for "tr-064.0.callForwarding.7" has to be type "boolean" but received type "number"
                                      web.0	2021-07-18 09:32:25.614	info	(6016) State value to set for "tr-064.0.callForwarding.7" has to be type "boolean" but received type "number"
                                      Jey CeeJ apollon77A 2 Antworten Letzte Antwort
                                        @apollon77
                                        Jey CeeJ Offline
                                        Jey CeeJ Offline
                                        Jey Cee
                                        #539
                                        @jb_sullivan laut der Meldung soll der Wert ein boolean also true oder false sein. Über den web Adapter, also vis oder eine andere Visualisierung wird aber eine Zahl in das Objekt geschrieben.
                                        Also ist der Fehler das hier ein falschen Wert in das Objekt geschrieben wird.
                                        Schau mal in deine Visualisierung mit der du den Datenpunkt beschreibst was da für ein Wert geschrieben wird.
                                        Persönlicher Support
                                        Spenden -> paypal.me/J3YC33
                                          Marty56
                                          #540
                                          @apollon77
                                          Es kommt nur beim Start.
                                          Aber was auch noch kommt ist,
                                          tr-064.0	2021-07-18 10:03:07.552	info	(COMPACT) State value to set for "tr-064.0.callmonitor.lastCall.callee" has to be type "number" but received type "string"
                                          tr-064.0	2021-07-18 10:03:01.065	info	(COMPACT) State value to set for "tr-064.0.callmonitor.inbound.callee" has to be type "number" but received type "string"
                                          das ist keine Warning aber info.
                                          HW:NUC (16 GB Ram)
                                          apollon77A FeuersturmF 3 Antworten Letzte Antwort
