  4. js-controller 3.3 jetzt im Beta
    apollon77A
791 Beiträge 75 Kommentatoren 324.4k Aufrufe 56 Beobachtet
  • L luie
    @apollon77
    ja, die neuste Version und nochmal von GitHub geholt und getestet.
    021-07-16 17:25:23.374 - info: rpi2.0 (4929) starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.rpi2, node: v14.17.2, js-controller: 3.3.14
    2021-07-16 17:25:24.159 - info: rpi2.0 (4929) State value to set for "rpi2.0.cpu.load1" has to be type "number" but received type "string"
    2021-07-16 17:25:24.163 - info: rpi2.0 (4929) State value to set for "rpi2.0.cpu.load5" has to be type "number" but received type "string"
    2021-07-16 17:25:24.165 - info: rpi2.0 (4929) State value to set for "rpi2.0.cpu.load15" has to be type "number" but received type "string"
    2021-07-16 17:25:24.189 - warn: rpi2.0 (4929) State "rpi2.0.raspberry.cpu_voltage" has no existing object, this might lead to an error in future versions
    2021-07-16 17:25:24.191 - warn: rpi2.0 (4929) State "rpi2.0.raspberry.mem_arm" has no existing object, this might lead to an error in future versions
    2021-07-16 17:25:24.192 - warn: rpi2.0 (4929) State "rpi2.0.raspberry.mem_gpu" has no existing object, this might lead to an error in future versions
    2021-07-16 17:25:30.180 - info: info.0 (2978) State value to set for "info.0.sysinfo.cpu.currentspeed.coresSpeed" has to be stringified but received type "object"
    2021-07-16 17:25:32.128 - info: info.0 (2978) State value to set for "info.0.sysinfo.cpu.temperature.cores" has to be stringified but received type "object"
    2021-07-16 17:26:23.753 - info: rpi2.0 (4929) State value to set for "rpi2.0.cpu.load1" has to be type "number" but received type "string"
    2021-07-16 17:26:23.755 - info: rpi2.0 (4929) State value to set for "rpi2.0.cpu.load5" has to be type "number" but received type "string"
    2021-07-16 17:26:23.756 - info: rpi2.0 (4929) State value to set for "rpi2.0.cpu.load15" has to be type "number" but received type "string"
    apollon77A
    apollon77A
    #512
    @luie Für rpi bitte ein Issue im Github mit Debug log. Info Adapter bitte GitHub testen
    L 2 Antworten Letzte Antwort
    • JB_SullivanJ JB_Sullivan
      @apollon77
      Roomba funktioniert noch nicht - Innogy schon.
      roomba.0	2021-07-16 17:17:09.743	info	(15004) State value to set for "roomba.0.statistics.missions.failed" has to be type "string" but received type "number"
      roomba.0	2021-07-16 17:17:09.743	info	(15004) State value to set for "roomba.0.statistics.missions.succeed" has to be type "string" but received type "number"
      roomba.0	2021-07-16 17:17:09.742	info	(15004) State value to set for "roomba.0.statistics.missions.total" has to be type "string" but received type "number"
      roomba.0	2021-07-16 17:17:09.742	info	(15004) State value to set for "roomba.0.statistics.time.nDocks" has to be type "string" but received type "number"
      roomba.0	2021-07-16 17:17:09.742	info	(15004) State value to set for "roomba.0.statistics.time.nNimhChrg" has to be type "string" but received type "number"
      roomba.0	2021-07-16 17:17:09.741	info	(15004) State value to set for "roomba.0.statistics.time.nLithChrg" has to be type "string" but received type "number"
      roomba.0	2021-07-16 17:17:09.741	info	(15004) State value to set for "roomba.0.statistics.time.estCap" has to be type "string" but received type "number"
      roomba.0	2021-07-16 17:17:09.740	info	(15004) State value to set for "roomba.0.statistics.time.nAvail" has to be type "string" but received type "number"
      roomba.0	2021-07-16 17:17:09.740	info	(15004) State value to set for "roomba.0.statistics.time.avgMin" has to be type "string" but received type "number"
      roomba.0	2021-07-16 17:17:09.739	info	(15004) State value to set for "roomba.0.states.battery" has to be type "string" but received type "number"
      roomba.0	2021-07-16 17:17:09.737	info	(15004) State value to set for "roomba.0.device.versions.hardwareRev" has to be type "string" but received type "number"
      roomba.0	2021-07-16 17:17:09.736	info	(15004) State value to set for "roomba.0.device.network.dhcp" has to be type "string" but received type "boolean"
      roomba.0	2021-07-16 17:17:09.735	info	(15004) State value to set for "roomba.0.commands.last.timestamp" has to be type "string" but received type "number"
      apollon77A
      apollon77A
      #513
      @jb_sullivan Mach mir bitte mitt dem Log ein GitHub Issue für später damits nicht runterfällt
      • DiginixD Diginix
        @apollon77 sagte in js-controller 3.3 jetzt im Beta:
        @diginix sagte in js-controller 3.3 jetzt im Beta:
        Und beim statistics kommt alles als boolean obwohl es number sein müsste.
        ok, da bitte log posten ... so nen fehler hab ich egrade nicht auf dem radar dort. ggf mal Objekte löschen !!
        Das ist immer die letzte und schlechteste Variante. Denn statistics hat man idR weil man Werte erfasst und historisch mitmeiselt. Wenn ich die Objekte lösche, gehen auch alle influx/history Einstellungen verloren.
        Ein Adapter sollte in der Lage sein den Datentyp usw. seiner Objekte on-the-fly glatt zu ziehen.
        Ich schau mir das mal bei Gelegenheit an ob der Typ vom Objekt oder im Adapter Code falsch ist.
        apollon77A
        apollon77A
        #514
        Ja das könnte er, aber die meisten sind dafür nicht vorbereitet und wenn Sie das tun würden gäbe es ggf andere probleme wie "Hohe I/O weil ständig Objekte neu geschrieben werden". Haben wir auf dem Zettel da was zu überlegen
          Ich habe das gleiche Problem (siehe oben) Das ist aber grundsätzlich nicht sooo schlimm. OK, dir fehlen ein paar Minuten wenn du die Objekte neu generieren lässt. In InfluxDB oder so, wird aber danach der gleiche DP Name wieder angelegt, sobald du den Harken gesetzt hast.
          In einem Grafana Grafik Trend hast du dann kurz eine "Flat Line" drin. Das sollte nicht soo schlimm sein. Wir dokumentieren hier ja keine Temperaturen von Impfstoff Kühlschränken ;)
          Grundsätzlich stimme ich dir zu. Gerade wenn man sehr viele Datenbank Einträge aus den Objekten generiert, vergisst man nach einer Adapter Neu Anlage schonmal den einen oder anderen Harken zu setzen.
          apollon77A
          apollon77A
          #515
          @jb_sullivan Na macht doch mal einen Admin Feature Request für "custom import/export" ... das wäre doch Eure Lösung
          • apollon77A apollon77
            Hey All,
            so es war ein langer weg. Ich habe die letzten Woche fast nur Adapter gefixt wegen der js-controller 3.3 Warnungen. Alle Adapter die irgendwie zur ioBroker Orga oder Adapter-Community gehören von denen ich es weiss sind gefixt (Alle, fast alle ... siehe nächster Absatz...). Daher bitte aktualisiert mal auf aktuellste Latest und setzt die Error level wieder auf info und sagt was noch ist bitte. Bitte im Zweifel mal die Adapterobjekte löschen und neu anlegen lassen
            Noch bekannte Themen:
            • sonoff braucht Bluefox Infos. bitte hier schauen wer noch Meldungen hat und melden!
            • statistics gibts noch eine offene zu klärende Frage, kann also auch noch Meldungen bei "avg" geben. Auch hier "bester" Stand ist GitHub, aber an sich ausser dem einen Thema soweit bestätigt
            • rpi2: Bitte mal GitHub Version checken, weil da noch andere Dinge drin sind und sagen ob noch alles ok ist
            Was sonst noch offen?
            (Ich denke wled oder so hat noch was?)
            Dr. BakteriusD
            Dr. BakteriusD
            Dr. Bakterius
            #516
            Nuki-Extended (https://github.com/Zefau/ioBroker.nuki-extended/issues/145) unverändert bisher (v2.3.0).
            apollon77A Dr. BakteriusD 2 Antworten Letzte Antwort
              apollon77A
              apollon77A
              #517
              @dr-bakterius Bei dem habe ich keinen echten Zugriff, daher schwierig. habe gefragt was ist ...
              • apollon77A
                apollon77A
                #518
                Also:
                • Roomba: Bitte nochmal GitHub version checken, sollte alles weg sein
                • Info Adapter: Siehe Issue ... ich behaupte Ihr nutzt nicht den Code von GitHub :-)
                  L
                  L
                  luie
                  schrieb am zuletzt editiert von luie
                  #519
                  @apollon77
                  Ich hoffe das ist so richtig.
                  https://github.com/iobroker-community-adapters/ioBroker.rpi2/issues/72#issuecomment-881637186
                  debian13-x64, docker, SONOFF ZigBee 3.0 USB DONGLE PLUS, Admin 7.8.29, Node.js v22.22.2, NPM 10.9.7, js-controller 7.1.2
                    Also:
                    JB_SullivanJ
                    JB_SullivanJ
                    JB_Sullivan
                    #520
                    @apollon77 NOPE
                    Roomba läuft immer noch nicht
                    roomba.0	2021-07-16 20:40:13.405	info	(15356) State value to set for "roomba.0.missions.current.runtime" has to be type "string" but received type "number"
                    roomba.0	2021-07-16 20:40:12.603	info	(15356) State value to set for "roomba.0.missions.current.runtime" has to be type "string" but received type "number"
                    roomba.0	2021-07-16 20:40:11.028	info	(15356) State value to set for "roomba.0.missions.current.runtime" has to be type "string" but received type "number"
                    roomba.0	2021-07-16 20:40:11.025	info	(15356) State value to set for "roomba.0.missions.current.started" has to be type "string" but received type "number"
                    roomba.0	2021-07-16 20:40:11.024	info	(15356) State value to set for "roomba.0.missions.current.id" has to be type "string" but received type "number"
                    roomba.0	2021-07-16 20:40:10.994	info	(15356) Roomba has started a new mission (#434).
                    roomba.0	2021-07-16 20:40:09.775	info	(15356) Triggered action -start- on Roomba.
                    web.0	2021-07-16 20:39:36.732	info	(14512) ==>Connected system.user.admin from
                      L
                      L
                      luie
                      #521
                      @apollon77
                      Und mit dem Info-Adapter sieht das jetzt so aus. Der Fehler liegt wohl an meinem System?
                      2021-07-16 20:35:00.822 - info: host.raspi "system.adapter.info.0" enabled
                      2021-07-16 20:35:01.356 - info: host.raspi instance system.adapter.info.0 started with pid 6020
                      2021-07-16 20:35:04.549 - info: info.0 (6020) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                      2021-07-16 20:35:04.567 - info: info.0 (6020) starting. Version 1.8.0 in /opt/iobroker/node_modules/iobroker.info, node: v14.17.2, js-controller: 3.3.14
                      2021-07-16 20:35:04.636 - info: info.0 (6020) Reading/updating systemdata.
                      2021-07-16 20:35:06.007 - error: info.0 (6020) uncaught exception: EACCES: permission denied, scandir '/var/lib/bluetooth/'
                      2021-07-16 20:35:06.013 - error: info.0 (6020) Error: EACCES: permission denied, scandir '/var/lib/bluetooth/'
                      at readdirSync (fs.js:1043:3)
                      at getDirectories (/opt/iobroker/node_modules/systeminformation/lib/util.js:680:12)
                      at getFilesRecursively (/opt/iobroker/node_modules/systeminformation/lib/util.js:687:16)
                      at Object.getFilesInPath (/opt/iobroker/node_modules/systeminformation/lib/util.js:695:12)
                      at /opt/iobroker/node_modules/systeminformation/lib/bluetooth.js:98:30
                      at processTicksAndRejections (internal/process/task_queues.js:77:11)
                      2021-07-16 20:35:06.015 - error: info.0 (6020) Exception-Code: EACCES: EACCES: permission denied, scandir '/var/lib/bluetooth/'
                      2021-07-16 20:35:07.224 - info: info.0 (6020) cleaned everything up...
                      2021-07-16 20:35:07.226 - info: info.0 (6020) terminating
                      2021-07-16 20:35:07.230 - warn: info.0 (6020) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2021-07-16 20:35:07.378 - info: info.0 (6020) State value to set for "info.0.sysinfo.cpu.currentLoad.cpus-0" has to be stringified but received type "object"
                      2021-07-16 20:35:07.379 - info: info.0 (6020) State value to set for "info.0.sysinfo.cpu.currentLoad.cpus-1" has to be stringified but received type "object"
                      2021-07-16 20:35:07.381 - info: info.0 (6020) State value to set for "info.0.sysinfo.cpu.currentLoad.cpus-2" has to be stringified but received type "object"
                      2021-07-16 20:35:07.385 - info: info.0 (6020) State value to set for "info.0.sysinfo.cpu.currentLoad.cpus-3" has to be stringified but received type "object"
                      2021-07-16 20:35:08.094 - warn: info.0 (6020) get state error: Connection is closed.
                      2021-07-16 20:35:08.095 - warn: info.0 (6020) get state error: DB closed
                      2021-07-16 20:35:08.148 - warn: info.0 (6020) get state error: DB closed
                      2021-07-16 20:35:08.150 - warn: info.0 (6020) get state error: DB closed
                      2021-07-16 20:35:08.164 - warn: info.0 (6020) get state error: Connection is closed.
                      2021-07-16 20:35:08.257 - warn: info.0 (6020) Could not perform strict object check of state info.0.newsfeed_filtered: Connection is closed.
                      2021-07-16 20:35:08.259 - warn: info.0 (6020) get state error: Connection is closed.
                      2021-07-16 20:35:08.357 - error: host.raspi instance system.adapter.info.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                      2021-07-16 20:35:08.359 - info: host.raspi Restart adapter system.adapter.info.0 because enabled
                      • JB_SullivanJ
                        JB_SullivanJ
                        JB_Sullivan
                        #522
                        Habe noch einen Adapter gefunden. Auch nur Entwickler oder ggf. ebenfalls Community?
                        spotify-premium.0	2021-07-16 21:03:46.219	info	(10336) State value to set for "spotify-premium.0.authorization.token" has to be stringified but received type "object"
                        apollon77A 2 Antworten Letzte Antwort
                        • L luie
                          @apollon77
                          apollon77A
                          apollon77A
                          #523
                          @luie Perfekt, da war noch ne zweite Code-Stelle ... Bitte GitHub Version testen
                          L 1 Antwort Letzte Antwort
                            @apollon77 NOPE
                            apollon77A
                            apollon77A
                            #524
                            @jb_sullivan Na du kommst ja auch immer mit neuen IDs die vorher nie in den Logs waren. Ich muss JEDE ID einzeln definieren!!
                            Geändert auf GitHub ... dann die nächsten Bitte? ;-)
                              L
                              L
                              luie
                              #525
                              @apollon77
                              rpi2 - keine Fehler mehr. Danke👍
                              • L luie
                                @apollon77
                                apollon77A
                                apollon77A
                                #526
                                @luie Ok, die Exception habe ich an den einen Library Dev weitergegeben - der ist an sich recht fix.
                                Ansonsten hab ich GitHub nochmal aktualisierrt für den Rest
                                  apollon77A
                                  apollon77A
                                  #527
                                  @jb_sullivan Immer GitHub issues machen!!! Aber ja den kann ich mir ansehen
                                    apollon77A
                                    apollon77A
                                    #528
                                    @jb_sullivan Github update bitte versuchen
                                      JB_SullivanJ
                                      JB_SullivanJ
                                      JB_Sullivan
                                      schrieb am zuletzt editiert von JB_Sullivan
                                      #529
                                      Ähm sorry, das kann ich ja nicht ahnen/wissen. Ich dachte das wäre irgend etwas globales was man einmal irgendwo umstellen muss.
                                      D.h. aber auch im Umkehrschluss, das man im Grunde ALLE Funktionen von ALLEN Geräten testen muss, denn nur wenn sich der Datenpunkt ändert, spuckt er ggf. auch eine Fehlermeldung aus?!?
                                      Na, da könnte noch einiges kommen (z.B. Heizkörper Thermostate - weil nur im Winter in Betrieb) oder Datenpunkte die nur bei bestimmten Betriebszuständen geschrieben werden, was man so ggf. gar nicht simulieren kann oder gar nicht auf dem Schirm hat.
                                      M apollon77A 2 Antworten Letzte Antwort
                                        M
                                        M
                                        Marty56
                                        #530
                                        Beim tr64 Adapter kommt bei mir
                                        State value to set for "tr-064.0.callmonitor.outbound.callee" has to be type "number" but received type "string"
                                        HW:NUC (16 GB Ram)
                                        OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
                                        JB_SullivanJ apollon77A 2 Antworten Letzte Antwort
                                        • M Marty56
                                          JB_SullivanJ
                                          JB_SullivanJ
                                          JB_Sullivan
                                          #531
                                          @marty56
                                          Da ich ja gerade gelernt habe, das jeder DP einzeln angepasst werden muss, hier auch noch zwei weitere Fehlermeldungen zum tr64 Adapter.
                                          web.0	2021-07-17 12:27:25.303	info	(14512) State value to set for "tr-064.0.callForwarding.7" has to be type "boolean" but received type "number"
                                          web.0	2021-07-17 12:27:23.048	info	(14512) State value to set for "tr-064.0.callForwarding.7" has to be type "boolean" but received type "number"
                                          83.9k
