  4. js-controller 3.3 jetzt im Beta
791 Beiträge 75 Kommentatoren 331.4k Aufrufe 56 Beobachtet
  • apollon77A apollon77
    @jb_sullivan Roomba ebenso GitHub bitte checken
    JB_SullivanJ
    JB_SullivanJ
    JB_Sullivan
    #507
    @apollon77
    Roomba funktioniert noch nicht - Innogy schon.
    roomba.0	2021-07-16 17:17:09.743	info	(15004) State value to set for "roomba.0.statistics.missions.failed" has to be type "string" but received type "number"
    roomba.0	2021-07-16 17:17:09.743	info	(15004) State value to set for "roomba.0.statistics.missions.succeed" has to be type "string" but received type "number"
    roomba.0	2021-07-16 17:17:09.742	info	(15004) State value to set for "roomba.0.statistics.missions.total" has to be type "string" but received type "number"
    roomba.0	2021-07-16 17:17:09.742	info	(15004) State value to set for "roomba.0.statistics.time.nDocks" has to be type "string" but received type "number"
    roomba.0	2021-07-16 17:17:09.742	info	(15004) State value to set for "roomba.0.statistics.time.nNimhChrg" has to be type "string" but received type "number"
    roomba.0	2021-07-16 17:17:09.741	info	(15004) State value to set for "roomba.0.statistics.time.nLithChrg" has to be type "string" but received type "number"
    roomba.0	2021-07-16 17:17:09.741	info	(15004) State value to set for "roomba.0.statistics.time.estCap" has to be type "string" but received type "number"
    roomba.0	2021-07-16 17:17:09.740	info	(15004) State value to set for "roomba.0.statistics.time.nAvail" has to be type "string" but received type "number"
    roomba.0	2021-07-16 17:17:09.740	info	(15004) State value to set for "roomba.0.statistics.time.avgMin" has to be type "string" but received type "number"
    roomba.0	2021-07-16 17:17:09.739	info	(15004) State value to set for "roomba.0.states.battery" has to be type "string" but received type "number"
    roomba.0	2021-07-16 17:17:09.737	info	(15004) State value to set for "roomba.0.device.versions.hardwareRev" has to be type "string" but received type "number"
    roomba.0	2021-07-16 17:17:09.736	info	(15004) State value to set for "roomba.0.device.network.dhcp" has to be type "string" but received type "boolean"
    roomba.0	2021-07-16 17:17:09.735	info	(15004) State value to set for "roomba.0.commands.last.timestamp" has to be type "string" but received type "number"
    apollon77A 2 Antworten Letzte Antwort
      @diginix sagte in js-controller 3.3 jetzt im Beta:
      Und beim statistics kommt alles als boolean obwohl es number sein müsste.
      ok, da bitte log posten ... so nen fehler hab ich egrade nicht auf dem radar dort. ggf mal Objekte löschen !!
      DiginixD
      DiginixD
      Diginix
      #508
      @apollon77 sagte in js-controller 3.3 jetzt im Beta:
      Das ist immer die letzte und schlechteste Variante. Denn statistics hat man idR weil man Werte erfasst und historisch mitmeiselt. Wenn ich die Objekte lösche, gehen auch alle influx/history Einstellungen verloren.
      Ein Adapter sollte in der Lage sein den Datentyp usw. seiner Objekte on-the-fly glatt zu ziehen.
      Ich schau mir das mal bei Gelegenheit an ob der Typ vom Objekt oder im Adapter Code falsch ist.
      ..:: So long! Tom ::..
      JB_SullivanJ apollon77A 2 Antworten Letzte Antwort
        @luie rpi2 ... neueste version von "vorhin"? Ansonsten hol mal von GitHub.
        Info checke ich
        L
        L
        luie
        schrieb am zuletzt editiert von luie
        #509
        @apollon77
        ja, die neuste Version und nochmal von GitHub geholt und getestet.
        021-07-16 17:25:23.374 - info: rpi2.0 (4929) starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.rpi2, node: v14.17.2, js-controller: 3.3.14
        2021-07-16 17:25:24.159 - info: rpi2.0 (4929) State value to set for "rpi2.0.cpu.load1" has to be type "number" but received type "string"
        2021-07-16 17:25:24.163 - info: rpi2.0 (4929) State value to set for "rpi2.0.cpu.load5" has to be type "number" but received type "string"
        2021-07-16 17:25:24.165 - info: rpi2.0 (4929) State value to set for "rpi2.0.cpu.load15" has to be type "number" but received type "string"
        2021-07-16 17:25:24.189 - warn: rpi2.0 (4929) State "rpi2.0.raspberry.cpu_voltage" has no existing object, this might lead to an error in future versions
        2021-07-16 17:25:24.191 - warn: rpi2.0 (4929) State "rpi2.0.raspberry.mem_arm" has no existing object, this might lead to an error in future versions
        2021-07-16 17:25:24.192 - warn: rpi2.0 (4929) State "rpi2.0.raspberry.mem_gpu" has no existing object, this might lead to an error in future versions
        2021-07-16 17:25:30.180 - info: info.0 (2978) State value to set for "info.0.sysinfo.cpu.currentspeed.coresSpeed" has to be stringified but received type "object"
        2021-07-16 17:25:32.128 - info: info.0 (2978) State value to set for "info.0.sysinfo.cpu.temperature.cores" has to be stringified but received type "object"
        2021-07-16 17:26:23.753 - info: rpi2.0 (4929) State value to set for "rpi2.0.cpu.load1" has to be type "number" but received type "string"
        2021-07-16 17:26:23.755 - info: rpi2.0 (4929) State value to set for "rpi2.0.cpu.load5" has to be type "number" but received type "string"
        2021-07-16 17:26:23.756 - info: rpi2.0 (4929) State value to set for "rpi2.0.cpu.load15" has to be type "number" but received type "string"
        debian13-x64, docker, SONOFF ZigBee 3.0 USB DONGLE PLUS, Admin 7.8.29, Node.js v22.22.2, NPM 10.9.7, js-controller 7.1.2
        • DiginixD Diginix
          JB_SullivanJ
          JB_SullivanJ
          JB_Sullivan
          #510
          Ich habe das gleiche Problem (siehe oben) Das ist aber grundsätzlich nicht sooo schlimm. OK, dir fehlen ein paar Minuten wenn du die Objekte neu generieren lässt. In InfluxDB oder so, wird aber danach der gleiche DP Name wieder angelegt, sobald du den Harken gesetzt hast.
          In einem Grafana Grafik Trend hast du dann kurz eine "Flat Line" drin. Das sollte nicht soo schlimm sein. Wir dokumentieren hier ja keine Temperaturen von Impfstoff Kühlschränken ;)
          Grundsätzlich stimme ich dir zu. Gerade wenn man sehr viele Datenbank Einträge aus den Objekten generiert, vergisst man nach einer Adapter Neu Anlage schonmal den einen oder anderen Harken zu setzen.
          • JB_SullivanJ JB_Sullivan
            @apollon77
            apollon77A
            apollon77A
            #511
            @jb_sullivan Kommt davon wenn die GitHub issues unvollstndig sind .... grmpf ... ja heute abend mach ich noch ne Runde. Melde mich
            • L luie
              @apollon77
              apollon77A
              apollon77A
              #512
              @luie Für rpi bitte ein Issue im Github mit Debug log. Info Adapter bitte GitHub testen
              L 2 Antworten Letzte Antwort
                @apollon77
                apollon77A
                apollon77A
                #513
                @jb_sullivan Mach mir bitte mitt dem Log ein GitHub Issue für später damits nicht runterfällt
                • DiginixD Diginix
                  apollon77A
                  apollon77A
                  #514
                  Ja das könnte er, aber die meisten sind dafür nicht vorbereitet und wenn Sie das tun würden gäbe es ggf andere probleme wie "Hohe I/O weil ständig Objekte neu geschrieben werden". Haben wir auf dem Zettel da was zu überlegen
                    apollon77A
                    apollon77A
                    #515
                    @jb_sullivan Na macht doch mal einen Admin Feature Request für "custom import/export" ... das wäre doch Eure Lösung
                      Hey All,
                      so es war ein langer weg. Ich habe die letzten Woche fast nur Adapter gefixt wegen der js-controller 3.3 Warnungen. Alle Adapter die irgendwie zur ioBroker Orga oder Adapter-Community gehören von denen ich es weiss sind gefixt (Alle, fast alle ... siehe nächster Absatz...). Daher bitte aktualisiert mal auf aktuellste Latest und setzt die Error level wieder auf info und sagt was noch ist bitte. Bitte im Zweifel mal die Adapterobjekte löschen und neu anlegen lassen
                      Noch bekannte Themen:
                      • sonoff braucht Bluefox Infos. bitte hier schauen wer noch Meldungen hat und melden!
                      • statistics gibts noch eine offene zu klärende Frage, kann also auch noch Meldungen bei "avg" geben. Auch hier "bester" Stand ist GitHub, aber an sich ausser dem einen Thema soweit bestätigt
                      • rpi2: Bitte mal GitHub Version checken, weil da noch andere Dinge drin sind und sagen ob noch alles ok ist
                      Was sonst noch offen?
                      (Ich denke wled oder so hat noch was?)
                      Dr. BakteriusD
                      Dr. BakteriusD
                      Dr. Bakterius
                      #516
                      Nuki-Extended (https://github.com/Zefau/ioBroker.nuki-extended/issues/145) unverändert bisher (v2.3.0).
                      apollon77A Dr. BakteriusD 2 Antworten Letzte Antwort
                        apollon77A
                        apollon77A
                        #517
                        @dr-bakterius Bei dem habe ich keinen echten Zugriff, daher schwierig. habe gefragt was ist ...
                        • apollon77A
                          apollon77A
                          #518
                          Also:
                          • Roomba: Bitte nochmal GitHub version checken, sollte alles weg sein
                          • Info Adapter: Siehe Issue ... ich behaupte Ihr nutzt nicht den Code von GitHub :-)
                            L
                            L
                            luie
                            #519
                            @apollon77
                            Ich hoffe das ist so richtig.
                            https://github.com/iobroker-community-adapters/ioBroker.rpi2/issues/72#issuecomment-881637186
                              Also:
                              JB_SullivanJ
                              JB_SullivanJ
                              JB_Sullivan
                              #520
                              @apollon77 NOPE
                              Roomba läuft immer noch nicht
                              roomba.0	2021-07-16 20:40:13.405	info	(15356) State value to set for "roomba.0.missions.current.runtime" has to be type "string" but received type "number"
                              roomba.0	2021-07-16 20:40:12.603	info	(15356) State value to set for "roomba.0.missions.current.runtime" has to be type "string" but received type "number"
                              roomba.0	2021-07-16 20:40:11.028	info	(15356) State value to set for "roomba.0.missions.current.runtime" has to be type "string" but received type "number"
                              roomba.0	2021-07-16 20:40:11.025	info	(15356) State value to set for "roomba.0.missions.current.started" has to be type "string" but received type "number"
                              roomba.0	2021-07-16 20:40:11.024	info	(15356) State value to set for "roomba.0.missions.current.id" has to be type "string" but received type "number"
                              roomba.0	2021-07-16 20:40:10.994	info	(15356) Roomba has started a new mission (#434).
                              roomba.0	2021-07-16 20:40:09.775	info	(15356) Triggered action -start- on Roomba.
                              web.0	2021-07-16 20:39:36.732	info	(14512) ==>Connected system.user.admin from
                                L
                                L
                                luie
                                #521
                                @apollon77
                                Und mit dem Info-Adapter sieht das jetzt so aus. Der Fehler liegt wohl an meinem System?
                                2021-07-16 20:35:00.822 - info: host.raspi "system.adapter.info.0" enabled
                                2021-07-16 20:35:01.356 - info: host.raspi instance system.adapter.info.0 started with pid 6020
                                2021-07-16 20:35:04.549 - info: info.0 (6020) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                2021-07-16 20:35:04.567 - info: info.0 (6020) starting. Version 1.8.0 in /opt/iobroker/node_modules/iobroker.info, node: v14.17.2, js-controller: 3.3.14
                                2021-07-16 20:35:04.636 - info: info.0 (6020) Reading/updating systemdata.
                                2021-07-16 20:35:06.007 - error: info.0 (6020) uncaught exception: EACCES: permission denied, scandir '/var/lib/bluetooth/'
                                2021-07-16 20:35:06.013 - error: info.0 (6020) Error: EACCES: permission denied, scandir '/var/lib/bluetooth/'
                                at readdirSync (fs.js:1043:3)
                                at getDirectories (/opt/iobroker/node_modules/systeminformation/lib/util.js:680:12)
                                at getFilesRecursively (/opt/iobroker/node_modules/systeminformation/lib/util.js:687:16)
                                at Object.getFilesInPath (/opt/iobroker/node_modules/systeminformation/lib/util.js:695:12)
                                at /opt/iobroker/node_modules/systeminformation/lib/bluetooth.js:98:30
                                at processTicksAndRejections (internal/process/task_queues.js:77:11)
                                2021-07-16 20:35:06.015 - error: info.0 (6020) Exception-Code: EACCES: EACCES: permission denied, scandir '/var/lib/bluetooth/'
                                2021-07-16 20:35:07.224 - info: info.0 (6020) cleaned everything up...
                                2021-07-16 20:35:07.226 - info: info.0 (6020) terminating
                                2021-07-16 20:35:07.230 - warn: info.0 (6020) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                2021-07-16 20:35:07.378 - info: info.0 (6020) State value to set for "info.0.sysinfo.cpu.currentLoad.cpus-0" has to be stringified but received type "object"
                                2021-07-16 20:35:07.379 - info: info.0 (6020) State value to set for "info.0.sysinfo.cpu.currentLoad.cpus-1" has to be stringified but received type "object"
                                2021-07-16 20:35:07.381 - info: info.0 (6020) State value to set for "info.0.sysinfo.cpu.currentLoad.cpus-2" has to be stringified but received type "object"
                                2021-07-16 20:35:07.385 - info: info.0 (6020) State value to set for "info.0.sysinfo.cpu.currentLoad.cpus-3" has to be stringified but received type "object"
                                2021-07-16 20:35:08.094 - warn: info.0 (6020) get state error: Connection is closed.
                                2021-07-16 20:35:08.095 - warn: info.0 (6020) get state error: DB closed
                                2021-07-16 20:35:08.148 - warn: info.0 (6020) get state error: DB closed
                                2021-07-16 20:35:08.150 - warn: info.0 (6020) get state error: DB closed
                                2021-07-16 20:35:08.164 - warn: info.0 (6020) get state error: Connection is closed.
                                2021-07-16 20:35:08.257 - warn: info.0 (6020) Could not perform strict object check of state info.0.newsfeed_filtered: Connection is closed.
                                2021-07-16 20:35:08.259 - warn: info.0 (6020) get state error: Connection is closed.
                                2021-07-16 20:35:08.357 - error: host.raspi instance system.adapter.info.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                2021-07-16 20:35:08.359 - info: host.raspi Restart adapter system.adapter.info.0 because enabled
                                • JB_SullivanJ
                                  JB_SullivanJ
                                  JB_Sullivan
                                  #522
                                  Habe noch einen Adapter gefunden. Auch nur Entwickler oder ggf. ebenfalls Community?
                                  spotify-premium.0	2021-07-16 21:03:46.219	info	(10336) State value to set for "spotify-premium.0.authorization.token" has to be stringified but received type "object"
                                  • L luie
                                    @apollon77
                                    apollon77A
                                    apollon77A
                                    #523
                                    @luie Perfekt, da war noch ne zweite Code-Stelle ... Bitte GitHub Version testen
                                    L 1 Antwort Letzte Antwort
                                      @apollon77 NOPE
                                      apollon77A
                                      apollon77A
                                      #524
                                      @jb_sullivan Na du kommst ja auch immer mit neuen IDs die vorher nie in den Logs waren. Ich muss JEDE ID einzeln definieren!!
                                      Geändert auf GitHub ... dann die nächsten Bitte? ;-)
                                        L
                                        L
                                        luie
                                        #525
                                        @apollon77
                                        rpi2 - keine Fehler mehr. Danke👍
                                        • L luie
                                          @apollon77
                                          apollon77A
                                          apollon77A
                                          #526
                                          @luie Ok, die Exception habe ich an den einen Library Dev weitergegeben - der ist an sich recht fix.
                                          Ansonsten hab ich GitHub nochmal aktualisierrt für den Rest
                                          84.1k
