  4. js-controller 3.3 jetzt im Beta
    apollon77A
791 Beiträge 75 Kommentatoren 329.4k Aufrufe 56 Beobachtet
  • JB_SullivanJ
    JB_SullivanJ
    JB_Sullivan
    #522
    Habe noch einen Adapter gefunden. Auch nur Entwickler oder ggf. ebenfalls Community?
    spotify-premium.0	2021-07-16 21:03:46.219	info	(10336) State value to set for "spotify-premium.0.authorization.token" has to be stringified but received type "object"
    apollon77A 2 Antworten Letzte Antwort
    • L luie
      @apollon77
      Ich hoffe das ist so richtig.
      https://github.com/iobroker-community-adapters/ioBroker.rpi2/issues/72#issuecomment-881637186
      apollon77A
      apollon77A
      #523
      @luie Perfekt, da war noch ne zweite Code-Stelle ... Bitte GitHub Version testen
      L 1 Antwort Letzte Antwort
      • JB_SullivanJ JB_Sullivan
        @apollon77 NOPE
        Roomba läuft immer noch nicht
        roomba.0	2021-07-16 20:40:13.405	info	(15356) State value to set for "roomba.0.missions.current.runtime" has to be type "string" but received type "number"
        roomba.0	2021-07-16 20:40:12.603	info	(15356) State value to set for "roomba.0.missions.current.runtime" has to be type "string" but received type "number"
        roomba.0	2021-07-16 20:40:11.028	info	(15356) State value to set for "roomba.0.missions.current.runtime" has to be type "string" but received type "number"
        roomba.0	2021-07-16 20:40:11.025	info	(15356) State value to set for "roomba.0.missions.current.started" has to be type "string" but received type "number"
        roomba.0	2021-07-16 20:40:11.024	info	(15356) State value to set for "roomba.0.missions.current.id" has to be type "string" but received type "number"
        roomba.0	2021-07-16 20:40:10.994	info	(15356) Roomba has started a new mission (#434).
        roomba.0	2021-07-16 20:40:09.775	info	(15356) Triggered action -start- on Roomba.
        web.0	2021-07-16 20:39:36.732	info	(14512) ==>Connected system.user.admin from
        apollon77A
        apollon77A
        #524
        @jb_sullivan Na du kommst ja auch immer mit neuen IDs die vorher nie in den Logs waren. Ich muss JEDE ID einzeln definieren!!
        Geändert auf GitHub ... dann die nächsten Bitte? ;-)
        • apollon77A apollon77
          L
          L
          luie
          #525
          @apollon77
          rpi2 - keine Fehler mehr. Danke👍
          debian13-x64, docker, SONOFF ZigBee 3.0 USB DONGLE PLUS, Admin 7.8.29, Node.js v22.22.2, NPM 10.9.7, js-controller 7.1.2
          • L luie
            @apollon77
            Und mit dem Info-Adapter sieht das jetzt so aus. Der Fehler liegt wohl an meinem System?
            2021-07-16 20:35:00.822 - info: host.raspi "system.adapter.info.0" enabled
            2021-07-16 20:35:01.356 - info: host.raspi instance system.adapter.info.0 started with pid 6020
            2021-07-16 20:35:04.549 - info: info.0 (6020) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
            2021-07-16 20:35:04.567 - info: info.0 (6020) starting. Version 1.8.0 in /opt/iobroker/node_modules/iobroker.info, node: v14.17.2, js-controller: 3.3.14
            2021-07-16 20:35:04.636 - info: info.0 (6020) Reading/updating systemdata.
            2021-07-16 20:35:06.007 - error: info.0 (6020) uncaught exception: EACCES: permission denied, scandir '/var/lib/bluetooth/'
            2021-07-16 20:35:06.013 - error: info.0 (6020) Error: EACCES: permission denied, scandir '/var/lib/bluetooth/'
            at readdirSync (fs.js:1043:3)
            at getDirectories (/opt/iobroker/node_modules/systeminformation/lib/util.js:680:12)
            at getFilesRecursively (/opt/iobroker/node_modules/systeminformation/lib/util.js:687:16)
            at Object.getFilesInPath (/opt/iobroker/node_modules/systeminformation/lib/util.js:695:12)
            at /opt/iobroker/node_modules/systeminformation/lib/bluetooth.js:98:30
            at processTicksAndRejections (internal/process/task_queues.js:77:11)
            2021-07-16 20:35:06.015 - error: info.0 (6020) Exception-Code: EACCES: EACCES: permission denied, scandir '/var/lib/bluetooth/'
            2021-07-16 20:35:07.224 - info: info.0 (6020) cleaned everything up...
            2021-07-16 20:35:07.226 - info: info.0 (6020) terminating
            2021-07-16 20:35:07.230 - warn: info.0 (6020) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2021-07-16 20:35:07.378 - info: info.0 (6020) State value to set for "info.0.sysinfo.cpu.currentLoad.cpus-0" has to be stringified but received type "object"
            2021-07-16 20:35:07.379 - info: info.0 (6020) State value to set for "info.0.sysinfo.cpu.currentLoad.cpus-1" has to be stringified but received type "object"
            2021-07-16 20:35:07.381 - info: info.0 (6020) State value to set for "info.0.sysinfo.cpu.currentLoad.cpus-2" has to be stringified but received type "object"
            2021-07-16 20:35:07.385 - info: info.0 (6020) State value to set for "info.0.sysinfo.cpu.currentLoad.cpus-3" has to be stringified but received type "object"
            2021-07-16 20:35:08.094 - warn: info.0 (6020) get state error: Connection is closed.
            2021-07-16 20:35:08.095 - warn: info.0 (6020) get state error: DB closed
            2021-07-16 20:35:08.148 - warn: info.0 (6020) get state error: DB closed
            2021-07-16 20:35:08.150 - warn: info.0 (6020) get state error: DB closed
            2021-07-16 20:35:08.164 - warn: info.0 (6020) get state error: Connection is closed.
            2021-07-16 20:35:08.257 - warn: info.0 (6020) Could not perform strict object check of state info.0.newsfeed_filtered: Connection is closed.
            2021-07-16 20:35:08.259 - warn: info.0 (6020) get state error: Connection is closed.
            2021-07-16 20:35:08.357 - error: host.raspi instance system.adapter.info.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2021-07-16 20:35:08.359 - info: host.raspi Restart adapter system.adapter.info.0 because enabled
            apollon77A
            apollon77A
            #526
            @luie Ok, die Exception habe ich an den einen Library Dev weitergegeben - der ist an sich recht fix.
            Ansonsten hab ich GitHub nochmal aktualisierrt für den Rest
              apollon77A
              apollon77A
              #527
              @jb_sullivan Immer GitHub issues machen!!! Aber ja den kann ich mir ansehen
                apollon77A
                apollon77A
                #528
                @jb_sullivan Github update bitte versuchen
                  JB_SullivanJ
                  JB_SullivanJ
                  JB_Sullivan
                  schrieb am zuletzt editiert von JB_Sullivan
                  #529
                  @apollon77 sagte in js-controller 3.3 jetzt im Beta:
                  Ähm sorry, das kann ich ja nicht ahnen/wissen. Ich dachte das wäre irgend etwas globales was man einmal irgendwo umstellen muss.
                  D.h. aber auch im Umkehrschluss, das man im Grunde ALLE Funktionen von ALLEN Geräten testen muss, denn nur wenn sich der Datenpunkt ändert, spuckt er ggf. auch eine Fehlermeldung aus?!?
                  Na, da könnte noch einiges kommen (z.B. Heizkörper Thermostate - weil nur im Winter in Betrieb) oder Datenpunkte die nur bei bestimmten Betriebszuständen geschrieben werden, was man so ggf. gar nicht simulieren kann oder gar nicht auf dem Schirm hat.
                  M apollon77A 2 Antworten Letzte Antwort
                    M
                    M
                    Marty56
                    #530
                    Beim tr64 Adapter kommt bei mir
                    State value to set for "tr-064.0.callmonitor.outbound.callee" has to be type "number" but received type "string"
                    HW:NUC (16 GB Ram)
                    OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
                    JB_SullivanJ apollon77A 2 Antworten Letzte Antwort
                    • M Marty56
                      JB_SullivanJ
                      JB_SullivanJ
                      JB_Sullivan
                      #531
                      @marty56
                      Da ich ja gerade gelernt habe, das jeder DP einzeln angepasst werden muss, hier auch noch zwei weitere Fehlermeldungen zum tr64 Adapter.
                      web.0	2021-07-17 12:27:25.303	info	(14512) State value to set for "tr-064.0.callForwarding.7" has to be type "boolean" but received type "number"
                      web.0	2021-07-17 12:27:23.048	info	(14512) State value to set for "tr-064.0.callForwarding.7" has to be type "boolean" but received type "number"
                        Hey All,
                        so es war ein langer weg. Ich habe die letzten Woche fast nur Adapter gefixt wegen der js-controller 3.3 Warnungen. Alle Adapter die irgendwie zur ioBroker Orga oder Adapter-Community gehören von denen ich es weiss sind gefixt (Alle, fast alle ... siehe nächster Absatz...). Daher bitte aktualisiert mal auf aktuellste Latest und setzt die Error level wieder auf info und sagt was noch ist bitte. Bitte im Zweifel mal die Adapterobjekte löschen und neu anlegen lassen
                        Noch bekannte Themen:
                        • sonoff braucht Bluefox Infos. bitte hier schauen wer noch Meldungen hat und melden!
                        • statistics gibts noch eine offene zu klärende Frage, kann also auch noch Meldungen bei "avg" geben. Auch hier "bester" Stand ist GitHub, aber an sich ausser dem einen Thema soweit bestätigt
                        • rpi2: Bitte mal GitHub Version checken, weil da noch andere Dinge drin sind und sagen ob noch alles ok ist
                        Was sonst noch offen?
                        (Ich denke wled oder so hat noch was?)
                        L
                        L
                        luie
                        #532
                        @apollon77
                        Der fritzdect-Adapter ist auch noch fehlerhaft.
                        https://github.com/foxthefox/ioBroker.fritzdect/issues/187
                          apollon77A
                          apollon77A
                          #533
                          @jb_sullivan Jupp, bitte einfach wenn SIe auftauchen per GitHub Issue melden
                          • M Marty56
                            apollon77A
                            apollon77A
                            #534
                            @marty56 sagte in js-controller 3.3 jetzt im Beta:
                            callee
                            Welche Version? die aktuellste? Bitte callee Objekt löschen, wird beim nächsten Anruf neu angelegt. Dann weg?
                              @marty56
                              apollon77A
                              apollon77A
                              #535
                              @jb_sullivan sagte in js-controller 3.3 jetzt im Beta:
                              callForwarding
                              Debug Log bitte wo der Fehler drin ist als GitHub issue bitte
                                callee
                                M
                                M
                                Marty56
                                schrieb am zuletzt editiert von Marty56
                                #536
                                @apollon77 Ich habe die aktuellste (4.2.13) installiert.
                                Jetzt habe ich den ganzen Tree gelöscht und bekomme beim Start
                                State value to set for "tr-064.0.states.ab" has to be type "boolean" but received type "string"
                                Anruf habe ich noch nicht testen können.
                                HW:NUC (16 GB Ram)
                                • M Marty56
                                  apollon77A
                                  apollon77A
                                  #537
                                  @marty56 Kommt nur beim ersten start wenn er die Objekte anlegt oder immer? Bitte GitHub issue
                                    callForwarding
                                    JB_SullivanJ
                                    JB_SullivanJ
                                    JB_Sullivan
                                    #538
                                    @apollon77
                                    ist das jetzt ein tr64 Adapter oder web Adapter issue?
                                    web.0	2021-07-18 09:32:27.582	info	(6016) State value to set for "tr-064.0.callForwarding.7" has to be type "boolean" but received type "number"
                                    web.0	2021-07-18 09:32:25.614	info	(6016) State value to set for "tr-064.0.callForwarding.7" has to be type "boolean" but received type "number"
                                    Jey CeeJ apollon77A 2 Antworten Letzte Antwort
                                      @apollon77
                                      Jey CeeJ
                                      Jey CeeJ
                                      Jey Cee
                                      #539
                                      @jb_sullivan laut der Meldung soll der Wert ein boolean also true oder false sein. Über den web Adapter, also vis oder eine andere Visualisierung wird aber eine Zahl in das Objekt geschrieben.
                                      Also ist der Fehler das hier ein falschen Wert in das Objekt geschrieben wird.
                                      Schau mal in deine Visualisierung mit der du den Datenpunkt beschreibst was da für ein Wert geschrieben wird.
                                      Persönlicher Support
                                      Spenden -> paypal.me/J3YC33
                                        M
                                        M
                                        Marty56
                                        #540
                                        @apollon77
                                        Es kommt nur beim Start.
                                        Aber was auch noch kommt ist,
                                        tr-064.0	2021-07-18 10:03:07.552	info	(COMPACT) State value to set for "tr-064.0.callmonitor.lastCall.callee" has to be type "number" but received type "string"
                                        tr-064.0	2021-07-18 10:03:01.065	info	(COMPACT) State value to set for "tr-064.0.callmonitor.inbound.callee" has to be type "number" but received type "string"
                                        das ist keine Warning aber info.
                                        HW:NUC (16 GB Ram)
                                        apollon77A FeuersturmF 3 Antworten Letzte Antwort
                                        • Jey CeeJ Jey Cee
                                          JB_SullivanJ
                                          JB_SullivanJ
                                          JB_Sullivan
                                          #541
                                          @jey-cee
                                          Das ist ein jqui-radiobuttons ON/OFF, welcher mit dem Datenpunkt unten als True/False geschrieben wird. ICH sehe da jetzt keinen Fehler - oder doch?
                                          Wird im übrigen dann schon in den RAW Daten falsch vom Adapter definiert.
                                            "from": "system.adapter.tr-064.0",
                                            "user": "system.user.admin",
                                            "ts": 1608319026747,
                                            "common": {
                                              "name": "fromAll  -> eine Telefonummer",
                                              "type": "boolean",
                                              "role": "state"
                                            "native": {},
                                            "acl": {
                                              "object": 1636,
                                              "owner": "system.user.admin",
                                              "state": 1636
                                            "_id": "tr-064.0.callForwarding.7",
                                            "type": "state"
                                          84.1k
