  4. [How-to] Node.js ioBroker richtig updaten-2021/22 Edition
    5.8k
812 Beiträge 97 Kommentatoren 446.1k Aufrufe 83 Beobachtet
  • E ecki945
    Guten Morgen. Bin gerade dabei meinen neuen NUC hochzuziehen. Proxmox 7.1-10 ist installiert. Ein neuer unpreviligiert Container mit akutellem debian ist erstellt. Doch nach der Installation meckert er herum.
    Ist iobroker nun richtig installiert trotz der Fehlermeldung?
    root@Iobroker:~# cat /etc/debian_version
    11.2
    root@Iobroker:~# node -v
    v14.19.0
    root@Iobroker:~# nodejs -v
    -bash: nodejs: command not found
    root@Iobroker:~# npm -v
    6.14.16
    root@Iobroker:~# curl -sLf https://iobroker.net/install.sh | bash -
    library: loaded
    Library version=2022-02-10
        Welcome to the ioBroker installer!
        Installer version: 2022-02-10
        Installing prerequisites (1/4)
    Hit:1 http://security.debian.org bullseye-security InRelease
    Hit:2 http://ftp.debian.org/debian bullseye InRelease
    Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
    Hit:4 https://deb.nodesource.com/node_14.x bullseye InRelease
    Reading package lists... Done
    Changing npm registry to https://registry.npmjs.org
    Installed acl
    Installed build-essential
    Installed gcc-c++
    Installed libavahi-compat-libdnssd-dev
    Installed libudev-dev
    Installed libpam0g-dev
    Installed git
    Installed unzip
    Installed libcairo2-dev
    Installed libpango1.0-dev
    Installed libjpeg-dev
    Installed libgif-dev
    Installed librsvg2-dev
    Installed net-tools
    Installed python-dev
    Installed cmake
        Creating ioBroker user and directory (2/4)
    User iobroker created
    Created /etc/sudoers.d/iobroker
    Directory /opt/iobroker created
        Installing ioBroker (3/4)
    In file included from ../../nan/nan.h:58,
                     from ../src/main.cpp:3:
    /root/.cache/node-gyp/14.19.0/include/node/node.h:793:7: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>)' to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]
      793 |       (node::addon_register_func) (regfunc),                          \
    /root/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro 'NODE_MODULE_X'
      827 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/main.cpp:42:1: note: in expansion of macro 'NODE_MODULE'
       42 | NODE_MODULE(diskusage, Init)
                     from ../src/unix_dgram.cc:5:
    ../src/unix_dgram.cc:404:1: note: in expansion of macro 'NODE_MODULE'
      404 | NODE_MODULE(unix_dgram, Initialize)
    ATTENTION: Error reporting via Sentry will be activated on next start of ioBroker
    ioBroker wants to make sure to deliver the most stable smart home system.
    To allow this we decided to implement an automatic error and crash reporting solution into the js-controller and also into adapters.
    THIS REPORTING WILL BE ENABLED WITH THE NEXT START OF YOUR IOBROKER!
    For any error that leads to the crash of the js-controller or one of the relevant adapters the error details are send to a server. For the js-controller and core adapters this server is located and operated in germany. For community adapters please check the Github Readme of the affected adapter for details which Sentry server is used.
    If you want to disable the error reporting you can use the command
    'iobroker plugin disable sentry'
    This command will also make sure that no adapter that runs on this host will send crash reporting data to sentry.
        Finalizing installation (4/4)
    Enabling autostart...
    Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service -> /lib/systemd/system/iobroker.service.
    Autostart enabled!
        ioBroker was installed successfully
        Open http://192.168.178.11:8081 in a browser and start configuring!
    You need to re-login before doing anything else on the console!
    #321
    @ecki945 da meckert nix tun. Ist doch alles ok.
      Rockfox
      #322
      Hallo bekomme beim Laden der Node.js 14 folgendes (Fehler) angezeigt. Kann ich die Installation trotzdem anstoßen.
      /opt/iobroker $ curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash -
      ## Installing the NodeSource Node.js 14.x repo...
      ## Populating apt-get cache...
      + apt-get update
      Holen:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
      Holen:2 http://archive.raspberrypi.org/debian buster InRelease [32,6 kB]
      Ign:3 https://phoscon.de/apt/deconz buster InRelease
      Holen:4 https://deb.nodesource.com/node_12.x buster InRelease [4.584 B]
      Fehl:5 https://phoscon.de/apt/deconz buster Release
        Certificate verification failed: The certificate is NOT trusted. The certificate chain uses expired certificate.  Could not handshake: Error in the certificate verification.
      Holen:6 https://deb.nodesource.com/node_12.x buster/main armhf Packages [783 B]
      E: Das Depot »https://phoscon.de/apt/deconz buster Release« enthält keine Release-Datei mehr.
      N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
      N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
      E: Für das Depot »http://raspbian.raspberrypi.org/raspbian buster InRelease« wurde der »Suite«-Wert von »stable« in »oldstable« geändert.
      N: Sie müssen dies explizit bestätigen, bevor Aktualisierungen von diesem Depot angewendet werden können. Lesen Sie die apt-secure(8)-Handbuchseite, wenn Sie weitere Informationen benötigen.
      E: Für das Depot »http://archive.raspberrypi.org/debian buster InRelease« wurde der »Suite«-Wert von »testing« in »oldstable« geändert.
      Error executing command, exiting
      • R Rockfox
        + apt-get update
        #323
        @rockfox
        sudo apt update
        sudo apt full-upgrade
        sudo reboot
        Rückfragen bejahen.
        R 1 Antwort Letzte Antwort
          @rockfox
          sudo apt update
          sudo reboot
          Rückfragen bejahen.
          Rockfox
          #324
          • J Jan1
            @ecki945
            Der Doku kann man so folgen, wobei die mal erweiter werden müsste, mit dem Hinweis, das IOBroker Node mit installiert.
            Mit dem Proxmox Zeug kenne ich mich nicht aus, wobei ich davon ausgehe, das die Pfade für Node identisch sein sollten und die sind bei Dir bei der Abfrage schon angemeckert worden ;)
            Ich würde das jetzt einfach mal wieder alles löschen und schlicht die IOBroker Installation durchführen, danach mal die Node kontrollieren.
            #325
            @jan1 sagte in [How-to] Node.js für ioBroker richtig updaten - 2021 Edition:
            das steht doch drin -in großem roten Kasten vorweg:
            mit dem aktuellen Installer von ioBroker (siehe unten) wird auf einem System ohne node.js automatisch die aktuell empfohlene Version von node.js mit installiert! Eine vorherige separate Installation von node.js ist somit nicht mehr nötig.
              AlCalzoneA Offline
              AlCalzoneA Offline
              AlCalzone
              #326
              @homoran sagte in [How-to] Node.js für ioBroker richtig updaten - 2021 Edition:
              das steht doch drin
              <marquee><blink> ... </blink></marquee>
              Könnte nötig sein 🤣
              • R Rockfox
                #327
                @rockfox
                Läuft das jetzt sauber durch? Inkl. phoscon-Repo?
                sudo apt update
                wirft dir jetzt was genau um die Ohren?
                • portyP Offline
                  portyP Offline
                  porty
                  #328
                  Guten Morgen, ich verzweifel gerade an dem Problem welcher im Eingangspost beschrieben wurde (Serialport).
                  Gestern habe ich ein Update vom Sytem / Nodejs gemacht auf die aktuelle 14.x
                  Der Zigbee adapter hatte die gleiche Probleme, läuft jedoch inzwischen,
                  Sobald ich den Jeelink Adapter jedoch starte bekomme ich Fehlermeldungen im Log.
                  host.NUC
                  2022-03-20 11:24:39.556	error	instance system.adapter.jeelink.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  host.NUC
                  2022-03-20 11:24:39.556	error	Caught by controller[0]: }
                  host.NUC
                  2022-03-20 11:24:39.556	error	Caught by controller[0]: ]
                  host.NUC
                  2022-03-20 11:24:39.556	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/lib/binding/node-v83-linux-x64/bindings.node'
                  host.NUC
                  2022-03-20 11:24:39.555	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node',
                  host.NUC
                  2022-03-20 11:24:39.555	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node',
                  host.NUC
                  2022-03-20 11:24:39.555	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node',
                  host.NUC
                  2022-03-20 11:24:39.555	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/compiled/14.19.1/linux/x64/bindings.node',
                  host.NUC
                  2022-03-20 11:24:39.555	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/default/bindings.node',
                  host.NUC
                  2022-03-20 11:24:39.555	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/Release/bindings.node',
                  host.NUC
                  2022-03-20 11:24:39.554	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/out/Release/bindings.node',
                  host.NUC
                  2022-03-20 11:24:39.554	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/Debug/bindings.node',
                  host.NUC
                  2022-03-20 11:24:39.554	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/out/Debug/bindings.node',
                  host.NUC
                  2022-03-20 11:24:39.554	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node',
                  host.NUC
                  2022-03-20 11:24:39.554	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/Debug/bindings.node',
                  host.NUC
                  2022-03-20 11:24:39.553	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/bindings.node',
                  host.NUC
                  2022-03-20 11:24:39.553	error	Caught by controller[0]: tries: [
                  host.NUC
                  2022-03-20 11:24:39.553	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14) {
                  host.NUC
                  2022-03-20 11:24:39.553	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/index.js:14:22)
                  host.NUC
                  2022-03-20 11:24:39.553	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
                  host.NUC
                  2022-03-20 11:24:39.553	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
                  host.NUC
                  2022-03-20 11:24:39.552	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                  host.NUC
                  2022-03-20 11:24:39.552	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                  host.NUC
                  2022-03-20 11:24:39.552	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                  host.NUC
                  2022-03-20 11:24:39.552	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
                  host.NUC
                  2022-03-20 11:24:39.552	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:1:36)
                  host.NUC
                  2022-03-20 11:24:39.552	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/@serialport/bindings/node_modules/bindings/bindings.js:126:9)
                  host.NUC
                  2022-03-20 11:24:39.551	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/lib/binding/node-v83-linux-x64/bindings.node
                  host.NUC
                  2022-03-20 11:24:39.551	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node
                  host.NUC
                  2022-03-20 11:24:39.551	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node
                  host.NUC
                  2022-03-20 11:24:39.551	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node
                  host.NUC
                  2022-03-20 11:24:39.551	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/compiled/14.19.1/linux/x64/bindings.node
                  host.NUC
                  2022-03-20 11:24:39.551	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/default/bindings.node
                  host.NUC
                  2022-03-20 11:24:39.550	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/Release/bindings.node
                  host.NUC
                  2022-03-20 11:24:39.550	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/out/Release/bindings.node
                  host.NUC
                  2022-03-20 11:24:39.550	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/Debug/bindings.node
                  host.NUC
                  2022-03-20 11:24:39.550	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/out/Debug/bindings.node
                  host.NUC
                  2022-03-20 11:24:39.550	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node
                  host.NUC
                  2022-03-20 11:24:39.550	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/Debug/bindings.node
                  host.NUC
                  2022-03-20 11:24:39.549	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/bindings.node
                  host.NUC
                  2022-03-20 11:24:39.549	error	Caught by controller[0]: Error: Could not locate the bindings file. Tried:
                  host.NUC
                  2022-03-20 11:24:39.549	error	Caught by controller[0]: ^
                  host.NUC
                  2022-03-20 11:24:39.549	error	Caught by controller[0]: throw err;
                  host.NUC
                  2022-03-20 11:24:39.548	error	Caught by controller[0]: /opt/iobroker/node_modules/@serialport/bindings/node_modules/bindings/bindings.js:135
                  ein "npm install --production" funktioniert jedoch auch nicht
                  porty@NUC:~$ cd /opt/iobroker/node_modules/@serialport/bindings
                  porty@NUC:/opt/iobroker/node_modules/@serialport/bindings$ npm install --production
                  [sudo] Passwort für porty:
                  > @serialport/bindings@2.0.8 install /opt/iobroker/node_modules/@serialport/bindings
                  > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
                  prebuild-install WARN install No prebuilt binaries found (target=14.19.1 runtime=node arch=x64 libc= platform=linux)
                  make: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird betreten
                   CXX(target) Release/obj.target/bindings/src/serialport.o
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                    uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                    uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                    uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                    uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                    uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                    uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
                  ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
                  ../src/serialport.cpp:329:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
                      results->Set(Nan::New<v8::String>("cts").ToLocalChecked(), Nan::New<v8::Boolean>(data->cts));
                  In file included from /home/iobroker/.cache/node-gyp/14.19.1/include/node/node.h:67,
                                  from ../node_modules/nan/nan.h:58,
                                  from ../src/./serialport.h:6,
                                  from ../src/serialport.cpp:1:
                  /home/iobroker/.cache/node-gyp/14.19.1/include/node/v8.h:3670:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, v8::Local<v8::Value>, v8::Local<v8::Value>)’
                    V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context,
                  /home/iobroker/.cache/node-gyp/14.19.1/include/node/v8.h:3670:37: note:   candidate expects 3 arguments, 2 provided
                  /home/iobroker/.cache/node-gyp/14.19.1/include/node/v8.h:3673:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, uint32_t, v8::Local<v8::Value>)’
                    V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index,
                  /home/iobroker/.cache/node-gyp/14.19.1/include/node/v8.h:3673:37: note:   candidate expects 3 arguments, 2 provided
                  ../src/serialport.cpp:330:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
                      results->Set(Nan::New<v8::String>("dsr").ToLocalChecked(), Nan::New<v8::Boolean>(data->dsr));
                  ../src/serialport.cpp:331:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
                      results->Set(Nan::New<v8::String>("dcd").ToLocalChecked(), Nan::New<v8::Boolean>(data->dcd));
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                    uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
                  ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
                  ../src/serialport.cpp:378:106: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::IntegerFactory<v8::Integer>::return_t)’
                      results->Set(Nan::New<v8::String>("baudRate").ToLocalChecked(), Nan::New<v8::Integer>(data->baudRate));
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                    uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
                  ../src/serialport.cpp: At global scope:
                  ../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
                  SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
                  ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
                  SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
                  In file included from ../node_modules/nan/nan.h:58,
                  /home/iobroker/.cache/node-gyp/14.19.1/include/node/node.h:793:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                  /home/iobroker/.cache/node-gyp/14.19.1/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
                  ../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’
                  NODE_MODULE(serialport, init);
                  make: *** [bindings.target.mk:114: Release/obj.target/bindings/src/serialport.o] Fehler 1
                  make: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird verlassen
                  gyp ERR! build error
                  gyp ERR! stack Error: `make` failed with exit code: 2
                  gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
                  gyp ERR! stack     at ChildProcess.emit (events.js:400:28)
                  gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)
                  gyp ERR! System Linux 4.19.0-19-amd64
                  gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                  gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindings
                  gyp ERR! node -v v14.19.1
                  gyp ERR! node-gyp -v v5.1.0
                  gyp ERR! not ok
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno 1
                  npm ERR! @serialport/bindings@2.0.8 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`
                  npm ERR! Exit status 1
                  npm ERR!
                  npm ERR! Failed at the @serialport/bindings@2.0.8 install script.
                  npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                  npm ERR!     /home/iobroker/.npm/_logs/2022-03-20T10_27_29_791Z-debug.log
                  und das passende Logfile:
                  0 info it worked if it ends with ok
                  1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'install', '--production' ]
                  2 info using npm@6.14.16
                  3 info using node@v14.19.1
                  4 verbose npm-session 376e18a5e07bd759
                  5 silly install runPreinstallTopLevelLifecycles
                  6 silly preinstall @serialport/bindings@2.0.8
                  7 info lifecycle @serialport/bindings@2.0.8~preinstall: @serialport/bindings@2.0.8
                  8 silly install loadCurrentTree
                  9 silly install readLocalPackageData
                  10 timing stage:loadCurrentTree Completed in 498ms
                  11 silly install loadIdealTree
                  12 silly install cloneCurrentTreeToIdealTree
                  13 timing stage:loadIdealTree:cloneCurrentTree Completed in 6ms
                  14 silly install loadShrinkwrap
                  15 timing stage:loadIdealTree:loadShrinkwrap Completed in 154ms
                  16 silly install loadAllDepsIntoIdealTree
                  17 http fetch GET 304 https://registry.npmjs.org/@serialport%2fbinding-mock 445ms (from cache)
                  18 silly pacote range manifest for @serialport/binding-mock@^2.0.5 fetched in 480ms
                  19 silly pacote range manifest for @serialport/binding-mock@^2.0.5 fetched in 4ms
                  20 silly resolveWithNewModule @serialport/binding-mock@2.0.5 checking installable status
                  21 timing stage:loadIdealTree:loadAllDepsIntoIdealTree Completed in 882ms
                  22 timing stage:loadIdealTree Completed in 1151ms
                  23 silly currentTree @serialport/bindings@2.0.8
                  23 silly currentTree ├── @serialport/binding-abstract@2.0.5
                  23 silly currentTree ├── @serialport/parser-delimiter@2.0.2
                  23 silly currentTree ├── @serialport/parser-readline@2.0.2
                  23 silly currentTree ├── ansi-regex@2.1.1
                  23 silly currentTree ├── aproba@1.2.0
                  23 silly currentTree ├─┬ are-we-there-yet@1.1.7
                  23 silly currentTree │ └── readable-stream@2.3.7
                  23 silly currentTree ├── bindings@1.5.0
                  23 silly currentTree ├── bl@3.0.0
                  23 silly currentTree ├── chownr@1.1.4
                  23 silly currentTree ├── code-point-at@1.1.0
                  23 silly currentTree ├── console-control-strings@1.1.0
                  23 silly currentTree ├── core-util-is@1.0.3
                  23 silly currentTree ├── debug@4.1.1
                  23 silly currentTree ├── decompress-response@4.2.1
                  23 silly currentTree ├── deep-extend@0.6.0
                  23 silly currentTree ├── delegates@1.0.0
                  23 silly currentTree ├── detect-libc@1.0.3
                  23 silly currentTree ├── end-of-stream@1.4.4
                  23 silly currentTree ├── expand-template@2.0.3
                  23 silly currentTree ├── file-uri-to-path@1.0.0
                  23 silly currentTree ├── fs-constants@1.0.0
                  23 silly currentTree ├── gauge@2.7.4
                  23 silly currentTree ├── github-from-package@0.0.0
                  23 silly currentTree ├── has-unicode@2.0.1
                  23 silly currentTree ├── inherits@2.0.4
                  23 silly currentTree ├── ini@1.3.8
                  23 silly currentTree ├── is-fullwidth-code-point@1.0.0
                  23 silly currentTree ├── isarray@1.0.0
                  23 silly currentTree ├── mimic-response@2.0.0
                  23 silly currentTree ├── minimist@1.2.5
                  23 silly currentTree ├── mkdirp@0.5.5
                  23 silly currentTree ├── ms@2.1.2
                  23 silly currentTree ├── nan@2.15.0
                  23 silly currentTree ├── napi-build-utils@1.0.2
                  23 silly currentTree ├── node-abi@2.30.1
                  23 silly currentTree ├── noop-logger@0.1.1
                  23 silly currentTree ├── npmlog@4.1.2
                  23 silly currentTree ├── number-is-nan@1.0.1
                  23 silly currentTree ├── object-assign@4.1.1
                  23 silly currentTree ├── once@1.4.0
                  23 silly currentTree ├── prebuild-install@5.3.3
                  23 silly currentTree ├── process-nextick-args@2.0.1
                  23 silly currentTree ├── pump@3.0.0
                  23 silly currentTree ├── rc@1.2.8
                  23 silly currentTree ├── readable-stream@3.4.0
                  23 silly currentTree ├── safe-buffer@5.1.2
                  23 silly currentTree ├── semver@5.7.1
                  23 silly currentTree ├── set-blocking@2.0.0
                  23 silly currentTree ├── signal-exit@3.0.7
                  23 silly currentTree ├── simple-concat@1.0.1
                  23 silly currentTree ├── simple-get@3.1.0
                  23 silly currentTree ├── string_decoder@1.1.1
                  23 silly currentTree ├── string-width@1.0.2
                  23 silly currentTree ├── strip-ansi@3.0.1
                  23 silly currentTree ├── strip-json-comments@2.0.1
                  23 silly currentTree ├── tar-fs@2.0.0
                  23 silly currentTree ├── tar-stream@2.1.0
                  23 silly currentTree ├── tunnel-agent@0.6.0
                  23 silly currentTree ├── util-deprecate@1.0.2
                  23 silly currentTree ├── which-pm-runs@1.1.0
                  23 silly currentTree ├── wide-align@1.1.5
                  23 silly currentTree └── wrappy@1.0.2
                  24 silly idealTree @serialport/bindings@2.0.8
                  24 silly idealTree ├── @serialport/binding-abstract@2.0.5
                  24 silly idealTree ├── @serialport/binding-mock@2.0.5
                  24 silly idealTree ├── @serialport/parser-delimiter@2.0.2
                  24 silly idealTree ├── @serialport/parser-readline@2.0.2
                  24 silly idealTree ├── ansi-regex@2.1.1
                  24 silly idealTree ├── aproba@1.2.0
                  24 silly idealTree ├─┬ are-we-there-yet@1.1.7
                  24 silly idealTree │ └── readable-stream@2.3.7
                  24 silly idealTree ├── bindings@1.5.0
                  24 silly idealTree ├── bl@3.0.0
                  24 silly idealTree ├── chownr@1.1.4
                  24 silly idealTree ├── code-point-at@1.1.0
                  24 silly idealTree ├── console-control-strings@1.1.0
                  24 silly idealTree ├── core-util-is@1.0.3
                  24 silly idealTree ├── debug@4.1.1
                  24 silly idealTree ├── decompress-response@4.2.1
                  24 silly idealTree ├── deep-extend@0.6.0
                  24 silly idealTree ├── delegates@1.0.0
                  24 silly idealTree ├── detect-libc@1.0.3
                  24 silly idealTree ├── end-of-stream@1.4.4
                  24 silly idealTree ├── expand-template@2.0.3
                  24 silly idealTree ├── file-uri-to-path@1.0.0
                  24 silly idealTree ├── fs-constants@1.0.0
                  24 silly idealTree ├── gauge@2.7.4
                  24 silly idealTree ├── github-from-package@0.0.0
                  24 silly idealTree ├── has-unicode@2.0.1
                  24 silly idealTree ├── inherits@2.0.4
                  24 silly idealTree ├── ini@1.3.8
                  24 silly idealTree ├── is-fullwidth-code-point@1.0.0
                  24 silly idealTree ├── isarray@1.0.0
                  24 silly idealTree ├── mimic-response@2.0.0
                  24 silly idealTree ├── minimist@1.2.5
                  24 silly idealTree ├── mkdirp@0.5.5
                  24 silly idealTree ├── ms@2.1.2
                  24 silly idealTree ├── nan@2.15.0
                  24 silly idealTree ├── napi-build-utils@1.0.2
                  24 silly idealTree ├── node-abi@2.30.1
                  24 silly idealTree ├── noop-logger@0.1.1
                  24 silly idealTree ├── npmlog@4.1.2
                  24 silly idealTree ├── number-is-nan@1.0.1
                  24 silly idealTree ├── object-assign@4.1.1
                  24 silly idealTree ├── once@1.4.0
                  24 silly idealTree ├── prebuild-install@5.3.3
                  24 silly idealTree ├── process-nextick-args@2.0.1
                  24 silly idealTree ├── pump@3.0.0
                  24 silly idealTree ├── rc@1.2.8
                  24 silly idealTree ├── readable-stream@3.4.0
                  24 silly idealTree ├── safe-buffer@5.1.2
                  24 silly idealTree ├── semver@5.7.1
                  24 silly idealTree ├── set-blocking@2.0.0
                  24 silly idealTree ├── signal-exit@3.0.7
                  24 silly idealTree ├── simple-concat@1.0.1
                  24 silly idealTree ├── simple-get@3.1.0
                  24 silly idealTree ├── string_decoder@1.1.1
                  24 silly idealTree ├── string-width@1.0.2
                  24 silly idealTree ├── strip-ansi@3.0.1
                  24 silly idealTree ├── strip-json-comments@2.0.1
                  24 silly idealTree ├── tar-fs@2.0.0
                  24 silly idealTree ├── tar-stream@2.1.0
                  24 silly idealTree ├── tunnel-agent@0.6.0
                  24 silly idealTree ├── util-deprecate@1.0.2
                  24 silly idealTree ├── which-pm-runs@1.1.0
                  24 silly idealTree ├── wide-align@1.1.5
                  24 silly idealTree └── wrappy@1.0.2
                  25 silly install generateActionsToTake
                  26 silly diff-trees filtering actions: includeDev false includeProd true includeOpt true
                  27 timing stage:generateActionsToTake Completed in 31ms
                  28 silly diffTrees action count 0
                  29 silly decomposeActions action count 0
                  30 silly install executeActions
                  31 silly doSerial global-install 0
                  32 verbose correctMkdir /home/iobroker/.npm/_locks correctMkdir not in flight; initializing
                  33 verbose lock using /home/iobroker/.npm/_locks/staging-5acb500a3727b98a.lock for /opt/iobroker/node_modules/@serialport/bindings/node_modules/.staging
                  34 silly doParallel extract 0
                  35 silly doReverseSerial unbuild 0
                  36 silly doSerial remove 0
                  37 silly doSerial move 0
                  38 silly doSerial finalize 0
                  39 silly doParallel refresh-package-json 0
                  40 silly doParallel preinstall 0
                  41 silly doSerial build 0
                  42 silly doSerial global-link 0
                  43 silly doParallel update-linked 0
                  44 silly doSerial install 0
                  45 silly doSerial postinstall 0
                  46 verbose unlock done using /home/iobroker/.npm/_locks/staging-5acb500a3727b98a.lock for /opt/iobroker/node_modules/@serialport/bindings/node_modules/.staging
                  47 timing stage:executeActions Completed in 79ms
                  48 timing stage:rollbackFailedOptional Completed in 1ms
                  49 silly install runPostinstallTopLevelLifecycles
                  50 silly build @serialport/bindings@2.0.8
                  51 info linkStuff @serialport/bindings@2.0.8
                  52 silly linkStuff @serialport/bindings@2.0.8 has /opt/iobroker/node_modules as its parent node_modules
                  53 silly install @serialport/bindings@2.0.8
                  54 info lifecycle @serialport/bindings@2.0.8~install: @serialport/bindings@2.0.8
                  55 verbose lifecycle @serialport/bindings@2.0.8~install: unsafe-perm in lifecycle true
                  56 verbose lifecycle @serialport/bindings@2.0.8~install: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/opt/iobroker/node_modules/@serialport/bindings/node_modules/.bin:/opt/iobroker/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
                  57 verbose lifecycle @serialport/bindings@2.0.8~install: CWD: /opt/iobroker/node_modules/@serialport/bindings
                  58 silly lifecycle @serialport/bindings@2.0.8~install: Args: [
                  58 silly lifecycle   '-c',
                  58 silly lifecycle   'prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild'
                  58 silly lifecycle ]
                  59 timing audit submit Completed in 291ms
                  60 http fetch POST 200 https://registry.npmjs.org/-/npm/v1/security/audits/quick 292ms
                  61 timing audit body Completed in 2ms
                  62 silly lifecycle @serialport/bindings@2.0.8~install: Returned: code: 1  signal: null
                  63 info lifecycle @serialport/bindings@2.0.8~install: Failed to exec install script
                  64 verbose stack Error: @serialport/bindings@2.0.8 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`
                  64 verbose stack Exit status 1
                  64 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
                  64 verbose stack     at EventEmitter.emit (events.js:400:28)
                  64 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                  64 verbose stack     at ChildProcess.emit (events.js:400:28)
                  64 verbose stack     at maybeClose (internal/child_process.js:1058:16)
                  64 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)
                  65 verbose pkgid @serialport/bindings@2.0.8
                  66 verbose cwd /opt/iobroker/node_modules/@serialport/bindings
                  67 verbose Linux 4.19.0-19-amd64
                  68 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "--production"
                  69 verbose node v14.19.1
                  70 verbose npm  v6.14.16
                  71 error code ELIFECYCLE
                  72 error errno 1
                  73 error @serialport/bindings@2.0.8 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`
                  73 error Exit status 1
                  74 error Failed at the @serialport/bindings@2.0.8 install script.
                  74 error This is probably not a problem with npm. There is likely additional logging output above.
                  75 verbose exit [ 1, true ]
                  Kann mir da jemand einen Denkanstoß geben?
                  VG
                  Thomas BraunT apollon77A 2 Antworten Letzte Antwort
                  • portyP porty
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    host.NUC
                    gyp ERR! not ok
                    npm ERR! errno 1
                    npm ERR!
                    72 error errno 1
                    VG
                    #329
                    @porty sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
                    Möglich das der Code nicht mehr gegen einen so alten Kernel gebaut werden kann. Ich würde das Betriebssystem aktualisieren.
                    • portyP porty
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      host.NUC
                      gyp ERR! not ok
                      npm ERR! errno 1
                      npm ERR!
                      72 error errno 1
                      VG
                      #330
                      @porty Die wichtigsten Infos fehlen:
                      1.) Welcher js-controller?
                      2.) Aktuellste Adapter versionen? Welche jeelink version?
                      Jeelink stable 0.1.3 hat ein serialport 7.x drin, das wird mit nodejs 14 raus sein. Brauchst jeelink denke ich mindestens die 0.1.4
                      • AlCalzoneA AlCalzone
                        das steht doch drin
                        Könnte nötig sein 🤣
                        crunchipC Abwesend
                        crunchipC Abwesend
                        #331
                        @alcalzone @Homoran wobei es etwas unglücklich formuliert ist, im ganzen betrachtet.
                        sollte man eventuell darauf hinweisen/ umformulieren, das man direkt zur iobroker installation bei einem Neu-install übergeht, da scheinbar der ein oder andere user nach der Reihe abgearbeitet hat und installiert sich dadurch trotzdem node.js im Vorfeld.
                          #332
                          @crunchip sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
                          bin für jede Idee dankbar.
                          Ein roter Kasten ganz zu Anfang war/ist für mich das größtmögliche
                          • portyP Offline
                            portyP Offline
                            porty
                            #333
                            hmm bekomme beim Antworten immer die Meldung "Forbidden"
                            @Thomas-Braun
                            dann muss ich mal schauen wie :D
                            apt update / upgrade ergibt nichts neues
                            "Linux NUC 4.19.0-19-amd64 #1 SMP Debian 4.19.232-1 (2022-03-07) x86_64"
                            folgende Meldung ist mir noch aufgefallen:
                            adapter "jeelink" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                            @apollon77
                            Ups, Sorry vergessen.
                            Controller: 4.0.21
                            Jeelink Tatsächlich die 0.1.3
                            • portyP porty
                              @Thomas-Braun
                              @apollon77
                              Controller: 4.0.21
                              #334
                              @porty
                              Ich hatte mich mit den Releases vertan. Kernel 4.19 dürfte aus einem Buster kommen. Das wird im Moment noch als 'oldstable' unterstützt, sieht aber in absehbarer Zeit dem End-of-Life entgegen. Also auf Bullseye gehen musst du in absehbarer Zeit ohne hin.
                              Installier die jeelink 0.1.4 aus dem Beta-Bereich.
                              portyP 1 Antwort Letzte Antwort
                              • portyP porty
                                @Thomas-Braun
                                @apollon77
                                Controller: 4.0.21
                                #335
                                Seite reloaden
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  #336
                                  @homoran sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
                                  ich seh mir das zeitnah mal an, dann kann ich die Seite auch gleich Zeitgemäß anpassen.
                                    @porty
                                    portyP Offline
                                    portyP Offline
                                    porty
                                    #337
                                    habe die 0.1.4 installiert, läuft Problemlos.
                                    Zum System, sollte ich mich dann mal zeitnah mit beschäftigen wie man das bei linux am besten macht :D
                                    Danke schonmal
                                    @apollon77
                                    hatte ich gemacht. Sobald ich jedoch auf Antworten bzw Zitieren gegangen bin und 2 verschiedene Personen markiert habe ging es nicht.
                                    Habe es dann von Hand gemacht was problemlos funktionierte.
                                    Browser wurde neben reload natürlich auch neu gestartet. Aber egal, ging ja :)
                                    • apollon77A apollon77
                                      MOD-EDIT: Diese Anleitung ist veraltet. Update und Fix der nodejs Installation ist mittlerweile in dem Befehl iob nodejs-update enthalten
                                      in diesem Artikel möchte ich einen Überblick geben, wie inzwischen (meint anno 2021 mit einem js-controller 3.x bzw 4.x) Node.js Updates bei ioBroker ausgeführt werden sollten bzw können.
                                      Was ist Node.js und warum muss man es updaten?
                                      Node.js ist die Laufzeitumgebung der Programmiersprache JavaScript, in der ioBroker geschrieben ist. Ohne Node.js funktioniert ioBroker nicht. Node.js hast Du initial selbst installiert oder der ioBroker-Installer hat dies für dich getan.
                                      Wie bei vielen Open-Source-Technologien üblich, entwickelt sich Node.js schnell weiter. Kleinere Updates, die die Stabilität und Sicherheit steigern oder gar neue Funktionen hinzufügen, erscheinen regelmäßig.
                                      Node.js-Versionen mit gerader Hauptversionsnummer werden als LTS-Versionen (Long Term Support) bezeichnet und einige Jahre gepflegt (z.B. 12.x). Jedes Jahr kommt eine neue Version ins LTS - in diesem Jahr (2021) ist das Node.js 16, welche im April veröffentlicht wurde und ab Oktober 2021 eine LTS Version wird.
                                      Im gleichem Zug erreichen frühere LTS-Versionen ihr Lebensende (EOL, End of Life). So hat Node.js 8 im April 2020 den EOL-Status erhalten und bekommt damit keine Updates mehr, Nodejs 10.x wird Ende April 2021 Ihr Lebensende erreichen. Es wird also keine Sicherheits-Updates mehr geben! Node.js 12.x wird im April 2022 eol geben.
                                      Alle Node.js-Versionen mit ungeraden Versionsnummern sind Entwicklungsversionen und sollten nicht produktiv genutzt werden.
                                      ioBroker nutzt viele Module und Erweiterungen aus der JavaScript Open-Source Szene, und dort kommt es regelmäßig vor, dass Versionen die EOL gehen zeitnah danach auch nicht weiter unterstützt werden. Das hat im ersten Schritt keine echte Auswirkung, aber mittelfristig wird es also Adapter, und später auch den js-controller geben, der EOL Versionen von Node.js nicht mehr unterstützt.
                                      Node.js 10 wird mit dem js-controller 3.x voll unterstützt. Ab dem js-controller 4.0 (Februar 2022) ist Node.js 10.x nicht mehr untertsützt.
                                      Auf welche Node.js Version updaten?
                                      Aktuell empfiehlt ioBroker die Nutzung von Node.js 16.x.
                                      Folgende Adapter haben momentan Probleme mit Node.js 14:
                                      • jeelink
                                      Folgende Adapter haben momentan Probleme mit Node.js 16:
                                      • jeelink?
                                      *Node.js 16.x wird auch vom js-controller 3.3 grundsätzlich unterstützt, aber nur mit npm 6! npm 7 bzw 8 sind mit dem js-controller 4.0 nutzbar.
                                      Update vorbereiten
                                      Node.js Version prüfen
                                      Bevor man beginnt, sollte man in der Befehlszeile mit dem Befehl
                                      node -v
                                      überprüfen, welche Version von Node.js gerade installiert ist. Eine gute Idee ist es, diese Versionsangabe auch mit der Node.js-Version im Übersichts-Fenster des ioBroker-Admins für diesen Host zu vergleichen. Sollten sich die Versionen unterscheiden, sind mehrere Node.js-Varianten installiert, was zu Problemen führen kann. Diese Probleme müssen VOR dem Update dann behoben werden! Anleitung zB unter https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian/2
                                      Betriebssystem prüfen
                                      Dann auch prüfen was man für ein Betriebssystem hat. Vor allem im Raspi Umfeld sind gern auch älterer Systeme auf basis von "Debian jessie" oder "Debian wheezy" im Einsatz. Für die gibt es nichts was höher ist als Nodejs 10, da steht dann ggf auch ein Betriebssystemupdate an, was wir hier aber nicht behandeln können.
                                      Unterstützte Linux Distributionen sind unter https://github.com/nodesource/distributions#debian-and-ubuntu-based-distributions aufgelistet.
                                      Unter Debian und Ubuntu gibt es mit lsb_release -a eine Ausgabe was man aktuell nutzt.
                                      js-controller Version prüfen
                                      Weiterhin bitte prüfen welche js-controller Version Installiert ist (ebenfalls auf dem Host-Tab im Admin einsehbar).
                                      Bei Versionen VOR js-controller 3.x, wenn möglich bitte zuerst den js-controller aktualisieren. Am besten auf mindestens die 3.2! Hierzu gibt es extra Threads im Forum wie z.B. https://forum.iobroker.net/topic/42385/js-controller-3-2-jetzt-im-stable bzw https://forum.iobroker.net/topic/52886/js-controller-4-0-x-jetzt-für-alle-user-im-stable
                                      Adapter aktualisieren
                                      Damit es nach dem Update zu keinen Inkompatibilitäten oder Probleme kommt, sollte man alle Adapter prüfen und aktualisieren. Vor allem Adapter mit nativen Bestandteilen, wie alles mit Serialport oder Bluetooth können Probleme bereiten. Hier am besten die Adapter-Readme's per Admin oder im GitHub prüfen, ob neue Versionen zur Verfügung stehen die die geplante Node.js Version explizit erst unterstützen.
                                      Bei Updates wo es größere Versionssprünge bei npm gibt (zb Node.js 14->16 updated npm von 6.x auf 8.x) kann es sehr hilfreich sein wenn man schaut ob Adapter die von GitHub installiert wurden inzwischen in der gleichen version auf auf npm liegen und dann ggf von dort nochmals installieren oder updaten. Im Admin werden Adapter die per GitHub installiert wurden gesondert mit einem GitHub Symbol angezeigt. Das hilft auch im Vorfeld Probleme zu vermeiden.
                                      Wenn man diesen Schritt nicht durchführt kann es zu unnötigen Problemen beim update der Adapter kommen!
                                      Backup erstellen
                                      Zuerst muss natürlich unbedingt ein Backup erstellt werden. Dazu kann z.B. der BackItUp-Adapter genutzt oder der Kommandozeilenbefehl
                                      cd /opt/iobroker
                                      iobroker backup
                                      ausgeführt werden. Das Backup sollte aktuell sein, damit möglichst keine Daten verloren gehen.
                                      Node.js updaten
                                      Für Windows-Systeme kann ich leider gerade nichts genaues sagen, wir schauen das wir das noch ergänzen. Aufruf an die Community: Wer Schritte hat gern als eigener Post oder hier einbringen :-) Danke
                                      Einen Post aus der Community gab es dazu: https://forum.iobroker.net/post/624003
                                      Linux-Systeme
                                      ioBroker stoppen
                                      Zuerst ioBroker stoppen, damit Updates keine Nebeneffekte oder Abstürze verursachen.
                                      iobroker stop
                                      Bitte anschließend im Webbrowser prüfen, dass der ioBroker-Admin danach wirklich nicht mehr läuft. Sollte er weiterhin aufrufbar sein, dann den Rechner neu starten und nochmals „iobroker stop“ ausführen und erneut testen. Für die Techniker unter uns: Man kann auch mit einem Tool wie "top" prüfen, ob noch Prozesse existieren, die mit "io." beginnen. Die dann am besten mit einem beherzten "sudo kill -9 <ProzessID>" zwangsbeenden.
                                      Node.js updaten
                                      Jetzt aktualisiert man Node.js auf die gewünschte neue Version.
                                      Unter Linux reicht es, dazu den Nodesource-Installationsbefehl für das jeweilige Betriebssystem auszuführen. Verschiedene Varianten (auch Root und Nicht-Root) sind unter https://github.com/nodesource/distributions#debinstall gelistet.
                                      Zum Beispiel lauten die Befehle für einen Raspberry Pi der ein Debian bzw. Raspbian-Image verwendet wie folgt, wenn man nicht als root-User (z.B. richtig mit dem User "pi") angemeldet ist:
                                      sudo apt install -y nodejs
                                      Für Node.js 16 einfach in der URL oben anstelle der 14 eine 16 reinschreiben.
                                      Für macOS gibt einen Installer auf https://nodejs.org/en/download/ , den man einfach ausführt.
                                      Ob die Aktualisierung geklappt hat, kann man wieder mit dem Befehl
                                      node -v
                                      überprüfen.
                                      Auch die npm Version sollte mit
                                      npm -v
                                      geprüft werden. Mit einem js-controller <4 sicherstellen das idealerweise keine 7.x/8.x von npm installiert ist!
                                      ioBroker fixer ausführen
                                      Da die Installation von Node.js einige Einstellungen am System verändert haben kann, ist es jetzt ratsam, den ioBroker-Installationsfixer aufzurufen. Das geschieht mit dem Befehl
                                      iobroker fix
                                      Er stellt unter anderem die für den Betrieb von ioBroker notwendigen Sicherheitseinstellungen wieder her und prüft und korrigiert alle Berechtigungen. Das kann einen Augenblick dauern, bitte Geduld haben.
                                      Erster ioBroker Neustart NACH Update
                                      Einige genutzte JavaScript Module haben binäre Teile, welche bei einem Node.js Update nicht mehr kompatibel sind und neu erstellt werden müssen.
                                      Automatische Rebuilds
                                      ioBroker versucht seit dem js-controller 3.0 automatisch die Adapter zu erkennen die nicht starten weil Sie aktualisiert werden müssen. Dies funktioniert so das die typischen Fehlermeldungen erkannt werden und ioBroker dann die Aktualisierung versucht.
                                      js-controller 3.x
                                      Zuerst wird ein "rebuild" des betroffenen Adapters ausgeführt, falls das nicht hilft werden die Adapter-Abhängigkeiten aktualisiert.
                                      js-controller 4.0
                                      Zuerst wird versucht alle Adapter zu rebuilden, falls das nicht hilft wird versucht zielgerichtet die relevanten Module neu zu bauen.
                                      Daher kann es sein das der Adapter mehrfach ersucht wird neu zu starten. Hier bitte UNBEDINGT Geduld haben! Erst wenn der Adapter dauerhaft rot bleibt und auch im Log steht das der Rebuild nicht geklappt hat aktiv werden!
                                      Bei einigen Adaptern (zB iot die optionale native Abhängigkeiten haben) funktioniert die automatische Erkennung nicht und das rebuild muss manuell angestoßen werden. Dies kann dadurch erkannt werden das der Adapter "Rot" bleibt und nicht startet oder einzelne Funktionen nicht gehen und das als Fehler im Log steht. Dann sollte das Log geprüft werden (neben Admin stehen Logfiles auch unter /opt/iobroker/log/... zur Verfügung.
                                      Manuelle Rebuilds
                                      Hier zu gibt es iobroker rebuild, bzw die Kommandos die im Log angezeigt werden falls der Automatische Rebuild nicht funktioniert.
                                      Sonderfälle (z.B. Serialport)
                                      Leider gibt es Sonderfälle, wo auch die obigen Optionen das Rebuild nicht erledigen, einer davon ist Serialport.
                                      Dort kann ein Log zB (auch nach allen Rebuild Versuchen) wie folgt aussehen
                                      host.SmartHomeCenter | 2020-05-10 09:28:01.788 | error | Caught by controller[0]: }
                                      host.SmartHomeCenter | 2020-05-10 09:28:01.788 | error | Caught by controller[0]: ]
                                      host.SmartHomeCenter | 2020-05-10 09:28:01.788 | error | Caught by controller[0]: '/opt/iobroker/node_modules/serialport/compiled/12.16.3/linux/arm/serialport.node'
                                      host.SmartHomeCenter | 2020-05-10 09:28:01.787 | error | Caught by controller[0]: '/opt/iobroker/node_modules/serialport/build/default/serialport.node',
                                      host.SmartHomeCenter | 2020-05-10 09:28:01.787 | error | Caught by controller[0]: '/opt/iobroker/node_modules/serialport/Release/serialport.node',
                                      host.SmartHomeCenter | 2020-05-10 09:28:01.787 | error | Caught by controller[0]: '/opt/iobroker/node_modules/serialport/out/Release/serialport.node',
                                      host.SmartHomeCenter | 2020-05-10 09:28:01.787 | error | Caught by controller[0]: '/opt/iobroker/node_modules/serialport/Debug/serialport.node',
                                      host.SmartHomeCenter | 2020-05-10 09:28:01.787 | error | Caught by controller[0]: '/opt/iobroker/node_modules/serialport/out/Debug/serialport.node',
                                      host.SmartHomeCenter | 2020-05-10 09:28:01.786 | error | Caught by controller[0]: '/opt/iobroker/node_modules/serialport/build/Release/serialport.node',
                                      host.SmartHomeCenter | 2020-05-10 09:28:01.786 | error | Caught by controller[0]: '/opt/iobroker/node_modules/serialport/build/Debug/serialport.node',
                                      host.SmartHomeCenter | 2020-05-10 09:28:01.786 | error | Caught by controller[0]: '/opt/iobroker/node_modules/serialport/build/serialport.node',
                                      host.SmartHomeCenter | 2020-05-10 09:28:01.786 | error | Caught by controller[0]: tries: [
                                      host.SmartHomeCenter | 2020-05-10 09:28:01.786 | error | Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1133:30) {
                                      host.SmartHomeCenter | 2020-05-10 09:28:01.785 | error | Caught by controller[0]: at Object. (/opt/iobroker/node_modules/serialport/lib/bindings/auto-detect.js:16:22)
                                      host.SmartHomeCenter | 2020-05-10 09:28:01.785 | error | Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
                                      host.SmartHomeCenter | 2020-05-10 09:28:01.785 | error | Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1019:19)
                                      host.SmartHomeCenter | 2020-05-10 09:28:01.785 | error | Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                                      host.SmartHomeCenter | 2020-05-10 09:28:01.785 | error | Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:977:32)
                                      host.SmartHomeCenter | 2020-05-10 09:28:01.784 | error | Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
                                      host.SmartHomeCenter | 2020-05-10 09:28:01.784 | error | Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1133:30)
                                      host.SmartHomeCenter | 2020-05-10 09:28:01.784 | error | Caught by controller[0]: at Object. (/opt/iobroker/node_modules/serialport/lib/bindings/linux.js:2:36)
                                      host.SmartHomeCenter | 2020-05-10 09:28:01.784 | error | Caught by controller[0]: at bindings (/opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:93:9)
                                      host.SmartHomeCenter | 2020-05-10 09:28:01.783 | error | Caught by controller[0]: → /opt/iobroker/node_modules/serialport/compiled/12.16.3/linux/arm/serialport.node
                                      host.SmartHomeCenter | 2020-05-10 09:28:01.783 | error | Caught by controller[0]: → /opt/iobroker/node_modules/serialport/build/default/serialport.node
                                      host.SmartHomeCenter | 2020-05-10 09:28:01.783 | error | Caught by controller[0]: → /opt/iobroker/node_modules/serialport/Release/serialport.node
                                      host.SmartHomeCenter | 2020-05-10 09:28:01.783 | error | Caught by controller[0]: → /opt/iobroker/node_modules/serialport/out/Release/serialport.node
                                      host.SmartHomeCenter | 2020-05-10 09:28:01.782 | error | Caught by controller[0]: → /opt/iobroker/node_modules/serialport/Debug/serialport.node
                                      host.SmartHomeCenter | 2020-05-10 09:28:01.782 | error | Caught by controller[0]: → /opt/iobroker/node_modules/serialport/out/Debug/serialport.node
                                      host.SmartHomeCenter | 2020-05-10 09:28:01.782 | error | Caught by controller[0]: → /opt/iobroker/node_modules/serialport/build/Release/serialport.node
                                      host.SmartHomeCenter | 2020-05-10 09:28:01.782 | error | Caught by controller[0]: → /opt/iobroker/node_modules/serialport/build/Debug/serialport.node
                                      host.SmartHomeCenter | 2020-05-10 09:28:01.781 | error | Caught by controller[0]: → /opt/iobroker/node_modules/serialport/build/serialport.node
                                      host.SmartHomeCenter | 2020-05-10 09:28:01.781 | error | Caught by controller[0]: Error: Could not locate the bindings file. Tried:
                                      host.SmartHomeCenter | 2020-05-10 09:28:01.781 | error | Caught by controller[0]: ^
                                      host.SmartHomeCenter | 2020-05-10 09:28:01.780 | error | Caught by controller[0]: throw err
                                      host.SmartHomeCenter | 2020-05-10 09:28:01.780 | error | Caught by controller[0]: /opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:96
                                      Es gibt auch andere Fehlermeldungen die aber alle auf das gleiche hinauslaufen.
                                      Die einfachste Option ist es dann manuell im richtigen Verzeichnis neu zu bauen.
                                      In dem Fall das Verzeichenis mit "bindings" suchen - oben ist das /opt/iobroker/node_modules/serialport/node_modules/bindings ... bei neueren Versionen kann es auch etwas wie /opt/iobroker/node_modules/serialport/node_modules/@serialport/bindings sein.
                                      Dann in dieses Verzeichnis wechseln und npm install --production ausführen. Danach den Adapter nochmal sneu starten, das sollte dann tun.
                                      Ein weiterer Fall sind Adapter mit canvas Modul (ggf echarts oder Mihome-vacuum) wo es Probleme gebe kann.
                                      Andere Sonderfälle muss man sich im Detail ansehen. Bitte unten Posten und wir unterstützen.
                                      Weitere Notfall Optionen
                                      Im früheren Artikel unter https://forum.iobroker.net/topic/22867/how-to-node-js-für-iobroker-richtig-updaten sind noch weitere manuelle Möglichkeiten beschrieben ioBroker wieder zum laufen zu bekommen, aber diese sollten an sich nicht mehr nötig sein, gehen aber natürlich auch noch!
                                      Dieser Artikel gilt also auch weiterhin.
                                      Jetzt viel Erfolg und gebt bitte Feedback wie git es geklappt hat oder welche Probleme Ihr habt.
                                      Ingo
                                      ReGe77
                                      schrieb am zuletzt editiert von ReGe77
                                      #338
                                      @apollon77
                                      erledigt
                                      Vielen lieben Dank für die (sogar für mich ;) ) sehr verständlichen Erläuterungen.
                                      Allerdings bekomme ich die node.js Version nicht höher als 10.24.1.
                                      Mich wundert, dass er die Version 10.x holen will, obwohl ich ja den Link auf die 14er Version eingegeben habe.
                                      Oder muss ich zunächst den JS-controller auf > 4 bringen?
                                      Lieben Dank vorab und viele Grüße,
                                      Reiner
                                      Hier der Code:
                                      pi@iobroker:~ $ curl -fsSL https://deb.nodesource.com/setup_14.x | sudo bash -
                                      + apt-get update
                                      Holen:1 http://archive.raspberrypi.org/debian buster InRelease [32,6 kB]
                                      OK:2 https://deb.nodesource.com/node_10.x buster InRelease
                                      Holen:3 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                                      pi@iobroker:~ $ sudo apt-get install -y nodejs
                                      nodejs ist schon die neueste Version (10.24.1-1nodesource1).
                                      0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                      Meister MopperM Thomas BraunT 2 Antworten Letzte Antwort
                                      • R ReGe77
                                        @apollon77
                                        erledigt
                                        Reiner
                                        Hier der Code:
                                        + apt-get update
                                        Meister MopperM Online
                                        Meister Mopper
                                        #339
                                        @rege77
                                        Der sucht ja auch nach 10.x.
                                        Es kommt darauf an, wo es bei Dir konfiguriert ist:
                                        Entweder
                                        sudo nano /etc/apt/sources.list
                                        oder
                                        sudo nano /etc/apt/sources.list.d/nodesource.list
                                        die 10 in 14 ändern
                                        deb https://deb.nodesource.com/node_14.x bullseye main
                                        deb-src https://deb.nodesource.com/node_14.x bullseye main
                                        Proxmox und HA ...
                                          @rege77
                                          Entweder
                                          oder
                                          die 10 in 14 ändern
                                          #340
                                          @meister-mopper sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
                                          nee, nich wirklich:
                                          @rege77 sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
                                          curl -fsSL https://deb.nodesource.com/**setup_14.x** | sudo bash - ## Installing the NodeSource Node.js 14.x repo...
                                          aber dann switched er auf 10.x um.
                                          Da ist wohl der Pfad krumm
