  4. Test Adapter Mihome-vacuum v3.1.6 Next Generarition
    2.4k
    4.3k
1.2k Beiträge 100 Kommentatoren 462.9k Aufrufe 82 Beobachtet
  • B blackeagle998
    @Meistertr @dirkhe
    ich habe von Version 3.1.1. auf Version 3.3.3 geupdatet und bekomme seit dem diverse Fehlermeldungen.
    js-controller: 4.0.15
    Admin: 5.3.1
    node: 14.19.0
    nodejs: 14.19.0
    npm: 8.3.1
    Auszüge:
    2022-03-03 00:52:50.638  - error: mihome-vacuum.0 (5038) Error when receiving map url: hX@!{\|%$?XV *1<b)Qal)n9fs+5N1R)P,%X2Fl68	%e`aI$	Pwmm'`)<XT\_,%
    ;!lT%%
    \2DHB"\B
    (]>ch!&&$3{
    M6elBXS)"6.&usJO!JW<5R\(Ec1UB5koJ3 7o7Jy*6`	_PaF7iu|T<HD.3
    ZA3E[] .:u}uad%U8$]o:Byd!4YneLH^`(p4@H.f!$RJ
    Fb.]75FWJ@+#}
    2022-03-03 00:52:50.641  - warn: mihome-vacuum.0 (5038) map error:SyntaxError: Unexpected token h in JSON at position 0
    2022-03-03 01:18:00.668  - error: host.raspi-master Caught by controller[0]: #
    2022-03-03 01:18:00.676  - error: host.raspi-master Caught by controller[0]: # Fatal error in , line 0
    2022-03-03 01:18:00.677  - error: host.raspi-master Caught by controller[0]: # Check failed: map_object.IsMap().
    2022-03-03 01:18:00.678  - error: host.raspi-master Caught by controller[0]: #
    2022-03-03 01:18:00.679  - error: host.raspi-master Caught by controller[0]: #
    2022-03-03 01:18:00.679  - error: host.raspi-master Caught by controller[0]: #FailureMessage Object: 0xf54fb9d8
    2022-03-03 01:18:00.680  - warn: host.raspi-master instance system.adapter.mihome-vacuum.0 terminated due to SIGILL
    2022-03-03 01:18:00.681  - info: host.raspi-master instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
    2022-03-03 01:18:00.681  - info: host.raspi-master Restart adapter system.adapter.mihome-vacuum.0 because enabled
    2022-03-03 04:32:19.535  - error: host.raspi-master Caught by controller[0]: #
    2022-03-03 04:32:19.542  - error: host.raspi-master Caught by controller[0]: # Fatal error in , line 0
    2022-03-03 04:32:19.542  - error: host.raspi-master Caught by controller[0]: # Check failed: len > 0.
    2022-03-03 04:32:19.543  - error: host.raspi-master Caught by controller[0]: #
    2022-03-03 04:32:19.544  - error: host.raspi-master Caught by controller[0]: #FailureMessage Object: 0xff8a6fc0
    2022-03-03 04:32:19.544  - warn: host.raspi-master instance system.adapter.mihome-vacuum.0 terminated due to SIGILL
    2022-03-03 04:32:19.545  - info: host.raspi-master instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
    2022-03-03 04:32:19.545  - info: host.raspi-master Restart adapter system.adapter.mihome-vacuum.0 because enabled
    2022-03-04 08:12:44.295  - debug: mihome-vacuum.0 (1947) Mappointer_updated
    2022-03-04 08:12:44.295  - debug: mihome-vacuum.0 (1947) update_Map Mimap enabled
    2022-03-04 08:12:44.296  - debug: mihome-vacuum.0 (1947) update_Map use old mapurl
    2022-03-04 08:12:44.296  - debug: mihome-vacuum.0 (1947) Message= {"id":775,"method":"get_carpet_mode"}
    2022-03-04 08:12:44.316  - debug: mihome-vacuum.0 (1947) MIIO RECIVE: {"result":[{"enable":1,"current_integral":0,"current_high":0,"current_low":0,"stall_time":0}],"id":775}
    2022-03-04 08:12:44.823  - debug: mihome-vacuum.0 (1947) 25563
    2022-03-04 08:12:45.596  - debug: host.raspi-master-Server States 127.0.0.1:60286 Redis Socket error: Error: read ECONNRESET
    2022-03-04 08:12:45.603  - debug: host.raspi-master-Server Objects 127.0.0.1:48364 Redis Socket error: Error: read ECONNRESET
    2022-03-04 08:12:45.966  - error: host.raspi-master Caught by controller[0]: corrupted double-linked list
    2022-03-04 08:12:45.971  - warn: host.raspi-master instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
    2022-03-04 08:12:45.972  - info: host.raspi-master instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
    2022-03-04 08:12:45.973  - debug: host.raspi-master Reset crash count of system.adapter.mihome-vacuum.0, because non-crash exit
    2022-03-04 08:12:45.973  - info: host.raspi-master Restart adapter system.adapter.mihome-vacuum.0 because enabled
    2022-03-04 08:13:16.345  - debug: host.raspi-master added notifications configuration of system.adapter.mihome-vacuum.0
    2022-03-04 08:13:16.350  - debug: host.raspi-master startInstance mihome-vacuum.0 loglevel=debug, compact=false
    2022-03-04 08:13:16.440  - info: host.raspi-master instance system.adapter.mihome-vacuum.0 started with pid 6962
    2022-03-04 08:13:18.479  - debug: mihome-vacuum.0 (6962) Redis Objects: Use Redis connection: 0.0.0.0:9001
    2022-03-04 08:13:18.547  - debug: mihome-vacuum.0 (6962) Objects client ready ... initialize now
    2022-03-04 08:13:18.549  - debug: mihome-vacuum.0 (6962) Objects create System PubSub Client
    2022-03-04 08:13:18.551  - debug: mihome-vacuum.0 (6962) Objects create User PubSub Client
    2022-03-04 08:13:18.707  - debug: mihome-vacuum.0 (6962) Objects client initialize lua scripts
    2022-03-04 08:13:18.735  - debug: mihome-vacuum.0 (6962) Objects connected to redis: 0.0.0.0:9001
    2022-03-04 08:13:18.787  - debug: mihome-vacuum.0 (6962) Redis States: Use Redis connection: 0.0.0.0:9000
    2022-03-04 08:13:18.826  - debug: mihome-vacuum.0 (6962) States create System PubSub Client
    2022-03-04 08:13:18.827  - debug: mihome-vacuum.0 (6962) States create User PubSub Client
    2022-03-04 08:13:18.895  - debug: mihome-vacuum.0 (6962) States connected to redis: 0.0.0.0:9000
    2022-03-04 08:13:19.203  - debug: mihome-vacuum.0 (6962) Plugin sentry Initialize Plugin (enabled=true)
    2022-03-04 08:13:19.211  - info: mihome-vacuum.0 (6962) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2022-03-04 08:13:19.489  - info: mihome-vacuum.0 (6962) starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.19.0, js-controller: 4.0.15
    2022-03-04 08:13:19.580  - debug: mihome-vacuum.0 (6962) load Map creator... true
    2022-03-04 08:13:19.642  - debug: mihome-vacuum.0 (6962) Create State for deviceInfo
    2022-03-04 08:13:19.643  - debug: mihome-vacuum.0 (6962) Create State for deviceInfomac
    2022-03-04 08:13:19.645  - debug: mihome-vacuum.0 (6962) Create State for deviceInfomodel
    2022-03-04 08:13:19.646  - debug: mihome-vacuum.0 (6962) Create State for deviceInfofw_ver
    2022-03-04 08:13:19.647  - debug: mihome-vacuum.0 (6962) Create State for deviceInfowifi_signal
    2022-03-04 10:23:11.755  - debug: mihome-vacuum.0 (4214) Message= {"id":958,"method":"get_carpet_mode"}
    2022-03-04 10:23:11.792  - debug: mihome-vacuum.0 (4214) MIIO RECIVE: {"result":[{"enable":1,"current_integral":0,"current_high":0,"current_low":0,"stall_time":0}],"id":958}
    2022-03-04 10:23:11.865  - debug: mihome-vacuum.0 (4214) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/74488275/0?Expires=1646387591000&GalaxyAccessKeyId=xxx
    2022-03-04 10:23:11.866  - debug: mihome-vacuum.0 (4214) update_Map got new expires:1646387591
    2022-03-04 10:23:11.866  - debug: mihome-vacuum.0 (4214) update_Map got new time:1646385791
    2022-03-04 10:23:12.384  - debug: mihome-vacuum.0 (4214) 25563
    2022-03-04 10:23:13.553  - error: host.raspi-master Caught by controller[0]: munmap_chunk(): invalid pointer
    2022-03-04 10:23:13.561  - warn: host.raspi-master instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
    2022-03-04 10:23:13.562  - info: host.raspi-master instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
    2022-03-04 10:23:13.563  - debug: host.raspi-master Reset crash count of system.adapter.mihome-vacuum.0, because non-crash exit
    2022-03-04 10:23:13.564  - info: host.raspi-master Restart adapter system.adapter.mihome-vacuum.0 because enabled
    2022-03-04 10:23:43.933  - debug: host.raspi-master added notifications configuration of system.adapter.mihome-vacuum.0
    2022-03-04 10:23:43.935  - debug: host.raspi-master startInstance mihome-vacuum.0 loglevel=debug, compact=false
    2022-03-04 10:23:43.995  - info: host.raspi-master instance system.adapter.mihome-vacuum.0 started with pid 18519
    2022-03-04 10:23:45.987  - debug: mihome-vacuum.0 (18519) Redis Objects: Use Redis connection: 0.0.0.0:9001
    2022-03-04 10:23:46.055  - debug: mihome-vacuum.0 (18519) Objects client ready ... initialize now
    2022-03-04 10:23:46.058  - debug: mihome-vacuum.0 (18519) Objects create System PubSub Client
    2022-03-04 10:23:46.059  - debug: mihome-vacuum.0 (18519) Objects create User PubSub Client
    2022-03-04 10:23:46.184  - debug: mihome-vacuum.0 (18519) Objects client initialize lua scripts
    2022-03-04 10:23:46.212  - debug: mihome-vacuum.0 (18519) Objects connected to redis: 0.0.0.0:9001
    2022-03-04 10:23:46.295  - debug: mihome-vacuum.0 (18519) Redis States: Use Redis connection: 0.0.0.0:9000
    2022-03-04 10:23:46.361  - debug: mihome-vacuum.0 (18519) States create System PubSub Client
    2022-03-04 10:23:46.363  - debug: mihome-vacuum.0 (18519) States create User PubSub Client
    2022-03-04 10:23:46.517  - debug: mihome-vacuum.0 (18519) States connected to redis: 0.0.0.0:9000
    2022-03-04 10:23:46.744  - debug: mihome-vacuum.0 (18519) Plugin sentry Initialize Plugin (enabled=true)
    2022-03-04 10:23:46.751  - info: mihome-vacuum.0 (18519) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2022-03-04 10:23:47.074  - info: mihome-vacuum.0 (18519) starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.19.0, js-controller: 4.0.15
    2022-03-04 10:23:47.160  - debug: mihome-vacuum.0 (18519) load Map creator... true
    2022-03-04 10:23:47.218  - debug: mihome-vacuum.0 (18519) Create State for deviceInfo
    2022-03-04 10:23:47.219  - debug: mihome-vacuum.0 (18519) Create State for deviceInfomac
    2022-03-04 10:23:47.220  - debug: mihome-vacuum.0 (18519) Create State for deviceInfomodel
    2022-03-04 10:23:47.221  - debug: mihome-vacuum.0 (18519) Create State for deviceInfofw_ver
    2022-03-04 10:23:47.223  - debug: mihome-vacuum.0 (18519) Create State for deviceInfowifi_signal
    Sobald ich den Staubsauger (Roborock S5) starte verliert der Adapter die Verbindung und geht auf rot.
    Ausprobiert habe ich bereits folgendes:
    • neue Adapter-Instanz
    • Server von Germany auf China gewechselt und zurück
    • Adapater komplett neu installiert
    • downgrade auf Version 3.1.1
    Nichts davon hat geholfen und ich komme nicht mehr weiter.
    Könnt ihr mal bitte einen Blick drauf werfen, ob ihr was erkennen könnt?
    D Nicht stören
    D Nicht stören
    dirkhe
    #801
    @blackeagle998 stell mal die map aus, ob er dann auch noch crascht.
    Wenn du mal ein paar Beiträge zurück genst, gab es da auch schon mal Probleme, wenn die falsche canvas Bibliothek installiert war. Ich glaube das Problem tritt bei 32bit pi's auf
    B 1 Antwort Letzte Antwort
    • K Offline
      Krys
      #802
      @blackeagle998
      so sah es bei mir vorher auch aus (Debian Buster). Nach dem Update auf Debian Bullseye lief alles Absturz-/Fehlerfrei auf nem Rpi4 4GB.
      B B 2 Antworten Letzte Antwort
      • K Krys
        @blackeagle998
        bob der 1.
        schrieb am zuletzt editiert von bob der 1.
        #803
        Schade das niemand Antworten mag .
        • K Krys
          @blackeagle998
          blackeagle998
          #804
          @krys
          Danke für deine Rückmeldung!
          Wenn ich es richtig verstanden habe geht es darum, das OS auf 64-Bit umzustellen, richtig?
          Dafür fehlt mir momentan die Zeit, zumal der Rest sauber funktioniert.
          Soweit ich das sehen kann, arbeitet auch ein 64-Bit Kernel (aarch64):
          pi@RasPImaster:~ $ uname -a
          Linux RasPImaster 5.10.63-v8+ #1496 SMP PREEMPT Wed Dec 1 15:59:46 GMT 2021 aarch64 GNU/Linux
          • B blackeagle998
            @krys
            #805
            @blackeagle998
            Ja, der Kernel ist 64bit.
            Aber auch der Rest? Userland? Oder nur den 64bit-Kernel ins System gedübelt? Gibt dazu ein paar schwachsinnige Anleitungen im Netz.
              @blackeagle998
              blackeagle998
              #806
              Vermutlich nur der Kernel.
              Die Einstellung ist in der /boot/config.txt die folgende:
              arm_64bit=1
              • B blackeagle998
                arm_64bit=1
                haselchenH Offline
                haselchenH Offline
                haselchen
                #807
                So, nun habe ich anscheinend auch ein canvas Problem.
                Warum weiss der liebe Gott.
                canvas package not installed......
                erscheint sekündlich im log.
                Adapter Version 3.3.3
                Hab auch schon neu - und drüber installiert.
                Canvas ist installiert. (sorry für den Screenshot, aus dem Container kann man leider nix kopieren)
                • haselchenH haselchen
                  #808
                  @haselchen
                  cd /opt/iobroker
                  npm ls canvas
                    @haselchen
                    cd /opt/iobroker
                    npm ls canvas
                    haselchenH Offline
                    haselchenH Offline
                    haselchen
                    #809
                      #810
                      @haselchen
                      Zeig mal das Log. Und geh mit einem Terminal / per SSH in den Container. Dann kann man auch Text kopieren.
                      Ich habe nämlich keine Meldungen im Log, Installation aber wohl gleich:
                      echad@chet:/opt/iobroker $ npm ls canvas
                      iobroker.inst@3.0.0 /opt/iobroker
                      ├─┬ iobroker.echarts@1.0.3
                      │ ├── canvas@2.9.0
                      │ └─┬ jsdom@16.7.0
                      │   └── canvas@2.9.0 deduped
                      ├─┬ iobroker.iot@1.9.7
                      │ ├── canvas@2.9.0 deduped
                      │ └─┬ jsdom@19.0.0
                      ├─┬ iobroker.mihome-vacuum@3.3.3
                      • haselchenH Offline
                        haselchenH Offline
                        haselchen
                        #811
                        Was auch immer diese Meldung ausgelöst hat, habe den Fixer drüberlaufen lassen.
                        Jetzt sind die Meldungen weg.
                        Hab im Log noch gesehen , dass der Parcel Adapter ebenfalls nach Canvas gerufen hat.
                        Merkwürdig , merkwürdig.
                        • D dirkhe
                          blackeagle998
                          #812
                          @dirkhe
                          Map gestern abend ausgeschaltet, seitdem ist im LOG Ruhe. Starten kann ich den Staubi erst Montag wieder, dann sehen wir weiter. Danke erstmal!
                          • D3ltoroxpD Offline
                            D3ltoroxpD Offline
                            D3ltoroxp
                            #813
                            Hm eine Frage, ich habe gestern per App einen Raum reinigen lassen, seither sehe ich in der VIS nur noch die Map weiß mit dem einen Raum gelb.
                            Wie bekomme ich das wieder zurück, das er die Map bunt anzeigt ?
                            • wendy2702W wendy2702
                              @wendy2702 sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                              @bahnuhr zu deinem Script frage ich im anderen Thread.
                              Hier versuche ich den Adapter zu verstehen.
                              OK.
                              clean room ist der Name und .roomClean die ID vom DP aber es reicht nicht aus den Entsprechenden Button zu betätigen.
                              Wenn ich diesen Button betätige oder den Wert auf "true" bestätigt ändere passiert bei mir nichts, sollte doch aber oder nicht?
                              Und wieso stehen die jetzt alle auf "true" obwohl der Sauger in der Station steht?
                              Sorry,
                              ich muss mich nochmal selber zitieren.
                              Kann mir jemand sagen ob die als "Button" definierten Objekte auch als Button funktionieren sollten?
                              Sprich, ich klicke auf den Button für Room clean und der Sauger sollte los fahren und den entsprechenden Raum reinigen.
                              Dann noch eine andere Frage, ich weiß das irgendwo beschrieben steht wie ich rausfinde welcher Raum sich hinter der entsprechenden Nummer in den Objekten befindet... wo steht das nochmal oder wie ging das nochmal?
                              Danke und Gruß
                              bahnuhrB Offline
                              bahnuhrB Offline
                              bahnuhr
                              #814
                              Sorry,
                              Danke und Gruß
                              Hatte ich alles schon beantwortet.
                              • du schreibst true in den DP und der Sauger fährt los
                                Dann weist du wo er hinfährt; und dieser Raum ist dann die entsprechende nr.
                              Danke.
                              • bahnuhrB bahnuhr
                                Sorry,
                                Danke und Gruß
                                wendy2702W Offline
                                wendy2702W Offline
                                wendy2702
                                #815
                                @bahnuhr Ja,
                                Habe ich mittlerweile wieder gefunden und auch so ermittelt.
                                  TobiasF78
                                  #816
                                  Ich nutze den Adapter mit einem Roborock S5max. iobroker läuft auf einem Raspi4, 4GB Ram.
                                  Momentan hab ich das Problem, dass der Adapter nach Start des Reinigungsvorgangs ständig abstürzt (rot wird). Nach einer Weile wird er wieder grün und dann wieder rot.
                                  Dazu hab ich auch das ein oder andere hier gefunden, aber so wirklich schlau bin ich nicht geworden bzw. weiß ich nicht wie ich das Problem behebe.
                                  Gibt es diesbezüglich neue Erkenntnisse oder Lösungen, die ich nicht gefunden habe?
                                  Vielen Dank an die Entwickler und alle, die sich hier um die Probleme von anderen kümmern und versuchen jedem weiterzuhelfen. Großes Lob!
                                  • T TobiasF78
                                    #817
                                    @tobiasf78 sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                                    Im LogFile steht dann jeweils was drin?
                                      TobiasF78
                                      #818
                                      gibt es eine Möglich das Log nur für den einen Adapter herunterzuladen?
                                      • T TobiasF78
                                        #819
                                        @tobiasf78
                                        Ja, macht aber wenig Sinn, es wird der Kontext benötigt.
                                        T 3 Antworten Letzte Antwort
                                          @tobiasf78
                                          TobiasF78
                                          #820
                                          das log zum Start des Reinigungsvorgangs
                                          2022-04-07 20:11:03.686 - debug: mihome-vacuum.0 (17152) Receive <<< Helo <<< 21310020000000001317ff30624f2938ffffffffffffffffffffffffffffffff
                                          2022-04-07 20:11:03.687 - debug: mihome-vacuum.0 (17152) Time difference between Mihome Vacuum and ioBroker: 1 sec
                                          2022-04-07 20:11:13.690 - debug: mihome-vacuum.0 (17152) Receive <<< Helo <<< 21310020000000001317ff30624f2942ffffffffffffffffffffffffffffffff
                                          2022-04-07 20:11:13.691 - debug: mihome-vacuum.0 (17152) Time difference between Mihome Vacuum and ioBroker: 1 sec
                                          2022-04-07 20:11:17.217 - debug: mihome-vacuum.0 (17152) get params for stock Vacuum
                                          2022-04-07 20:11:17.219 - debug: mihome-vacuum.0 (17152) Message= {"id":69,"method":"get_status"}
                                          2022-04-07 20:11:17.228 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":3477,"state":18,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":101,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0}],"id":69}
                                          2022-04-07 20:11:17.233 - debug: mihome-vacuum.0 (17152) setGetStatus {"msg_ver":2,"msg_seq":3477,"state":18,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":101,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"error_text":"No error"}
                                          2022-04-07 20:11:17.237 - debug: mihome-vacuum.0 (17152) Message= {"id":70,"method":"get_map_v1"}
                                          2022-04-07 20:11:17.239 - debug: mihome-vacuum.0 (17152) Message= {"id":71,"method":"get_network_info"}
                                          2022-04-07 20:11:17.254 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":["retry"],"id":70}
                                          2022-04-07 20:11:17.266 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":{"ssid":"froehlich.unifi","ip":"192.168.229.31","mac":"64:90:c1:01:fb:13","bssid":"4a:d9:e7:fa:7f:d0","rssi":-49},"id":71}
                                          2022-04-07 20:11:17.382 - debug: mihome-vacuum.0 (17152) Message= {"id":72,"method":"get_sound_volume"}
                                          2022-04-07 20:11:17.388 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":[30],"id":72}
                                          2022-04-07 20:11:17.389 - debug: mihome-vacuum.0 (17152) Message= {"id":73,"method":"get_carpet_mode"}
                                          2022-04-07 20:11:17.395 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":73}
                                          2022-04-07 20:11:17.557 - debug: mihome-vacuum.0 (17152) Message= {"id":74,"method":"get_map_v1"}
                                          2022-04-07 20:11:17.563 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":["retry"],"id":74}
                                          2022-04-07 20:11:17.866 - debug: mihome-vacuum.0 (17152) Message= {"id":75,"method":"get_map_v1"}
                                          2022-04-07 20:11:17.871 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":["retry"],"id":75}
                                          2022-04-07 20:11:18.172 - debug: mihome-vacuum.0 (17152) Message= {"id":76,"method":"get_map_v1"}
                                          2022-04-07 20:11:18.179 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":["retry"],"id":76}
                                          2022-04-07 20:11:18.480 - debug: mihome-vacuum.0 (17152) Message= {"id":77,"method":"get_map_v1"}
                                          2022-04-07 20:11:18.488 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":["retry"],"id":77}
                                          2022-04-07 20:11:20.165 - info: javascript.0 (4683) script.js.Rollläden.Helligkeit_Durchschnittswert: [15,17,20,23,26,30,34,39,44,50,57,65,73,83,94,106,119,134,151,170,191,215,245,275,309,275,313,353,399,350]
                                          2022-04-07 20:11:20.189 - debug: shuttercontrol.0 (1726) Lightsensor changed: 0_userdata.0.Rollladen.Helligkeit_Durchschnitt Value: 143
                                          2022-04-07 20:11:20.791 - debug: mihome-vacuum.0 (17152) Get Mappointer while cleaning
                                          2022-04-07 20:11:20.792 - debug: mihome-vacuum.0 (17152) Message= {"id":78,"method":"get_map_v1"}
                                          2022-04-07 20:11:20.800 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":["rubyslite%2F320339760%2F0"],"id":78}
                                          2022-04-07 20:11:20.801 - debug: mihome-vacuum.0 (17152) Mappointer_updated
                                          2022-04-07 20:11:20.804 - debug: mihome-vacuum.0 (17152) update_Map Mimap enabled
                                          2022-04-07 20:11:20.805 - debug: mihome-vacuum.0 (17152) update_Map need new mapurl
                                          2022-04-07 20:11:21.030 - debug: mihome-vacuum.0 (17152) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320339760/0?Expires=1649356881000&GalaxyAccessKeyId=5271733786445&Signature=JkhvPTmkB1NFoq+B3JmwCidC99E=
                                          2022-04-07 20:11:21.030 - debug: mihome-vacuum.0 (17152) update_Map got new expires:1649356881
                                          2022-04-07 20:11:21.031 - debug: mihome-vacuum.0 (17152) update_Map got new time:1649355080
                                          2022-04-07 20:11:21.538 - debug: mihome-vacuum.0 (17152) 25609
                                          2022-04-07 20:11:23.696 - debug: mihome-vacuum.0 (17152) Receive <<< Helo <<< 21310020000000001317ff30624f294cffffffffffffffffffffffffffffffff
                                          2022-04-07 20:11:23.697 - debug: mihome-vacuum.0 (17152) Time difference between Mihome Vacuum and ioBroker: 1 sec
                                          2022-04-07 20:11:24.575 - debug: mihome-vacuum.0 (17152) Get Mappointer while cleaning
                                          2022-04-07 20:11:24.576 - debug: mihome-vacuum.0 (17152) Message= {"id":79,"method":"get_map_v1"}
                                          2022-04-07 20:11:24.583 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":["rubyslite%2F320339760%2F3"],"id":79}
                                          2022-04-07 20:11:24.584 - debug: mihome-vacuum.0 (17152) Mappointer_updated
                                          2022-04-07 20:11:24.584 - debug: mihome-vacuum.0 (17152) update_Map Mimap enabled
                                          2022-04-07 20:11:24.585 - debug: mihome-vacuum.0 (17152) update_Map need new mapurl
                                          2022-04-07 20:11:24.754 - debug: mihome-vacuum.0 (17152) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320339760/3?Expires=1649356884000&GalaxyAccessKeyId=5271733786445&Signature=JeC2mvYHId0bO95JgWd8AJHM5ig=
                                          2022-04-07 20:11:24.755 - debug: mihome-vacuum.0 (17152) update_Map got new expires:1649356884
                                          2022-04-07 20:11:24.757 - debug: mihome-vacuum.0 (17152) update_Map got new time:1649355084
                                          2022-04-07 20:11:25.368 - debug: mihome-vacuum.0 (17152) 25751
                                          2022-04-07 20:11:27.898 - debug: mihome-vacuum.0 (17152) Get Mappointer while cleaning
                                          2022-04-07 20:11:27.899 - debug: mihome-vacuum.0 (17152) Message= {"id":80,"method":"get_map_v1"}
                                          2022-04-07 20:11:27.906 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":["rubyslite%2F320339760%2F4"],"id":80}
                                          2022-04-07 20:11:27.907 - debug: mihome-vacuum.0 (17152) Mappointer_updated
                                          2022-04-07 20:11:27.907 - debug: mihome-vacuum.0 (17152) update_Map Mimap enabled
                                          2022-04-07 20:11:27.907 - debug: mihome-vacuum.0 (17152) update_Map need new mapurl
                                          2022-04-07 20:11:28.059 - debug: mihome-vacuum.0 (17152) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320339760/4?Expires=1649356888000&GalaxyAccessKeyId=5271733786445&Signature=pxITU76k0a7x/gZU3EzewZ3Akwo=
                                          2022-04-07 20:11:28.059 - debug: mihome-vacuum.0 (17152) update_Map got new expires:1649356888
                                          2022-04-07 20:11:28.060 - debug: mihome-vacuum.0 (17152) update_Map got new time:1649355087
                                          2022-04-07 20:11:28.629 - debug: mihome-vacuum.0 (17152) 25909
                                          2022-04-07 20:11:28.864 - warn: host.SmarthomeRaspi instance system.adapter.mihome-vacuum.0 terminated due to SIGSEGV
                                          2022-04-07 20:11:28.865 - info: host.SmarthomeRaspi instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
                                          2022-04-07 20:11:28.865 - info: host.SmarthomeRaspi Restart adapter system.adapter.mihome-vacuum.0 because enabled
                                          2022-04-07 20:11:40.493 - info: unifi.0 (2213) State value to set for "unifi.0.default.clients.ae:2d:74:9e:b6:86.noted" has to be type "boolean" but received type "string"
                                          2022-04-07 20:11:40.621 - info: unifi.0 (2213) State value to set for "unifi.0.default.clients.94:e7:0b:61:00:58.noted" has to be type "boolean" but received type "string"
                                          2022-04-07 20:11:51.834 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0019DA49A70E58:0,CONFIG_PENDING,false
                                          2022-04-07 20:11:51.834 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0019DA49A70E58:0","CONFIG_PENDING",false]
                                          2022-04-07 20:11:51.834 - debug: hm-rpc.1 (1169) hm-rpc.1.0019DA49A70E58.0.CONFIG_PENDING ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
                                          2022-04-07 20:11:51.835 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0019DA49A70E58:0,RSSI_DEVICE,-72
                                          2022-04-07 20:11:51.835 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0019DA49A70E58:0","RSSI_DEVICE",-72]
                                          2022-04-07 20:11:51.835 - debug: hm-rpc.1 (1169) hm-rpc.1.0019DA49A70E58.0.RSSI_DEVICE ==> UNIT: "undefined" (min: -128, max: 127) From "-72" => "-72"
                                          2022-04-07 20:11:51.835 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0019DA49A70E58:0,DUTY_CYCLE,false
                                          2022-04-07 20:11:51.835 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0019DA49A70E58:0","DUTY_CYCLE",false]
                                          2022-04-07 20:11:51.836 - debug: hm-rpc.1 (1169) hm-rpc.1.0019DA49A70E58.0.DUTY_CYCLE ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
                                          2022-04-07 20:11:51.836 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0019DA49A70E58:0,UNREACH,false
                                          2022-04-07 20:11:51.836 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0019DA49A70E58:0","UNREACH",false]
                                          2022-04-07 20:11:51.836 - debug: hm-rpc.1 (1169) hm-rpc.1.0019DA49A70E58.0.UNREACH ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
                                          2022-04-07 20:11:53.009 - debug: hm-rpc.0 (1147) xml multicall : SmarthomeRaspi:hm-rpc.0:86e5c28de60614468b710549803c5777,NEQ0862527:1,BOOT,false
                                          2022-04-07 20:11:53.010 - debug: hm-rpc.0 (1147) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.0:86e5c28de60614468b710549803c5777","NEQ0862527:1","BOOT",false]
                                          2022-04-07 20:11:53.011 - debug: hm-rpc.0 (1147) hm-rpc.0.NEQ0862527.1.BOOT ==> UNIT: "" (min: undefined, max: undefined) From "false" => "false"
                                          2022-04-07 20:11:53.012 - debug: hm-rpc.0 (1147) xml multicall : SmarthomeRaspi:hm-rpc.0:86e5c28de60614468b710549803c5777,NEQ0862527:1,ENERGY_COUNTER,562640
                                          2022-04-07 20:11:53.013 - debug: hm-rpc.0 (1147) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.0:86e5c28de60614468b710549803c5777","NEQ0862527:1","ENERGY_COUNTER",562640]
                                          2022-04-07 20:11:53.013 - debug: hm-rpc.0 (1147) hm-rpc.0.NEQ0862527.1.ENERGY_COUNTER ==> UNIT: "Wh" (min: 0, max: 838860.7) From "562640" => "562640"
                                          2022-04-07 20:11:53.014 - debug: hm-rpc.0 (1147) xml multicall : SmarthomeRaspi:hm-rpc.0:86e5c28de60614468b710549803c5777,NEQ0862527:1,POWER,252
                                          2022-04-07 20:11:53.015 - debug: hm-rpc.0 (1147) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.0:86e5c28de60614468b710549803c5777","NEQ0862527:1","POWER",252]
                                          2022-04-07 20:11:53.016 - debug: hm-rpc.0 (1147) hm-rpc.0.NEQ0862527.1.POWER ==> UNIT: "W" (min: 0, max: 167772.15) From "252" => "252"
                                          2022-04-07 20:11:59.312 - info: host.SmarthomeRaspi instance system.adapter.mihome-vacuum.0 started with pid 17390
                                          2022-04-07 20:12:00.918 - debug: mihome-vacuum.0 (17390) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                          2022-04-07 20:12:00.999 - debug: mihome-vacuum.0 (17390) Objects client ready ... initialize now
                                          2022-04-07 20:12:01.002 - debug: mihome-vacuum.0 (17390) Objects create System PubSub Client
                                          2022-04-07 20:12:01.003 - debug: mihome-vacuum.0 (17390) Objects create User PubSub Client
                                          2022-04-07 20:12:01.153 - debug: mihome-vacuum.0 (17390) Objects client initialize lua scripts
                                          2022-04-07 20:12:01.160 - debug: mihome-vacuum.0 (17390) Objects connected to redis: 127.0.0.1:9001
                                          2022-04-07 20:12:01.227 - debug: mihome-vacuum.0 (17390) Redis States: Use Redis connection: 127.0.0.1:9000
                                          2022-04-07 20:12:01.269 - debug: mihome-vacuum.0 (17390) States create System PubSub Client
                                          2022-04-07 20:12:01.271 - debug: mihome-vacuum.0 (17390) States create User PubSub Client
                                          2022-04-07 20:12:01.358 - debug: mihome-vacuum.0 (17390) States connected to redis: 127.0.0.1:9000
                                          2022-04-07 20:12:01.640 - debug: mihome-vacuum.0 (17390) Plugin sentry Initialize Plugin (enabled=true)
                                          2022-04-07 20:12:02.117 - info: mihome-vacuum.0 (17390) starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.19.1, js-controller: 4.0.21
                                          2022-04-07 20:12:02.207 - debug: mihome-vacuum.0 (17390) load Map creator... true
                                          2022-04-07 20:12:02.240 - debug: mihome-vacuum.0 (17390) Create State for deviceInfo
                                          2022-04-07 20:12:02.241 - debug: mihome-vacuum.0 (17390) Create State for deviceInfomac
                                          2022-04-07 20:12:02.241 - debug: mihome-vacuum.0 (17390) Create State for deviceInfomodel
                                          2022-04-07 20:12:02.242 - debug: mihome-vacuum.0 (17390) Create State for deviceInfofw_ver
                                          2022-04-07 20:12:02.243 - debug: mihome-vacuum.0 (17390) Create State for deviceInfowifi_signal
                                          2022-04-07 20:12:02.244 - debug: mihome-vacuum.0 (17390) MIIO: Config: ip:192.168.229.31 token: 6a62485744456c466c766f6d45535473
                                          2022-04-07 20:12:02.248 - info: mihome-vacuum.0 (17390) IOT enabled, create state
                                          2022-04-07 20:12:02.253 - debug: mihome-vacuum.0 (17390) server started on 0.0.0.0:53421
                                          2022-04-07 20:12:02.262 - debug: mihome-vacuum.0 (17390) Receive <<< Helo <<< 21310020000000001317ff30624f2972ffffffffffffffffffffffffffffffff
                                          2022-04-07 20:12:02.263 - debug: mihome-vacuum.0 (17390) MAIN: Connected to device, try to get model..
                                          2022-04-07 20:12:02.270 - debug: mihome-vacuum.0 (17390) GETMODELFROMAPI: objModel: {"val":"roborock.vacuum.s5e","ack":true,"ts":1649354893615,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1649165771511}
                                          2022-04-07 20:12:02.272 - debug: mihome-vacuum.0 (17390) Message= {"id":1,"method":"miIO.info"}
                                          2022-04-07 20:12:02.280 - debug: mihome-vacuum.0 (17390) MIIO RECIVE: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_1566","ap":{"ssid":"froehlich.unifi","bssid":"4a:d9:e7:fa:7f:d0","rssi":-48},"netif":{"localIp":"192.168.229.31","mask":"255.255.255.0","gw":"192.168.229.1"},"miio_ver":"miio-client 3.5.8","model":"roborock.vacuum.s5e","mac":"64:90:C1:01:FB:13","token":"6a62485744456c466c766f6d45535473","life":59894}}
                                          2022-04-07 20:12:02.281 - debug: mihome-vacuum.0 (17390) GETMODELFROMAPI:Data: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_1566","ap":{"ssid":"froehlich.unifi","bssid":"4a:d9:e7:fa:7f:d0","rssi":-48},"netif":{"localIp":"192.168.229.31","mask":"255.255.255.0","gw":"192.168.229.1"},"miio_ver":"miio-client 3.5.8","model":"roborock.vacuum.s5e","mac":"64:90:C1:01:FB:13","token":"6a62485744456c466c766f6d45535473","life":59894}}
                                          2022-04-07 20:12:02.281 - debug: mihome-vacuum.0 (17390) Get Device data..0
                                          2022-04-07 20:12:02.282 - debug: mihome-vacuum.0 (17390) Get Device data from robot..
                                          2022-04-07 20:12:02.356 - debug: mihome-vacuum.0 (17390) DeviceModel selected to: roborock.vacuum.s5e
                                          2022-04-07 20:12:02.358 - info: mihome-vacuum.0 (17390) select standard vacuum protocol....
                                          2022-04-07 20:12:02.364 - debug: mihome-vacuum.0 (17390) Xiaomi Cloud: Logging in
                                          2022-04-07 20:12:02.430 - debug: mihome-vacuum.0 (17390) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                                          2022-04-07 20:12:02.671 - debug: mihome-vacuum.0 (17390) Login step1: &&&START&&&{"serviceParam":"{\"checkSafePhone\":false,\"checkSafeAddress\":false,\"lsrp_score\":0.0}","qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","code":70016,"description":"登录验证失败","securityStatus":0,"_sign":"0psXfr43eNI0IX6q9Suk3qWbRqU=","sid":"xiaomiio","result":"error","captchaUrl":null,"callback":"https://sts.api.io.mi.com/sts","location":"https://account.xiaomi.com/fe/service/login?_json=true&sid=xiaomiio&qs=%253Fsid%253Dxiaomiio%2526_json%253Dtrue&callback=https%3A%2F%2Fsts.api.io.mi.com%2Fsts&_sign=0psXfr43eNI0IX6q9Suk3qWbRqU%3D&serviceParam=%7B%22checkSafePhone%22%3Afalse%2C%22checkSafeAddress%22%3Afalse%2C%22lsrp_score%22%3A0.0%7D&showActiveX=false&theme=&needTheme=false&bizDeviceType=","pwd":0,"desc":"登录验证失败"}
                                          2022-04-07 20:12:02.948 - debug: mihome-vacuum.0 (17390) Login step2: &&&START&&&{"qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","ssecurity":"tE7q7k02rgKQ42yy2WalqA==","code":0,"passToken":"V1:DXmurwq2/R1BHTELu6obCXvd/vywyWq/UW16QZKE2LY36WsipSmLX8xvdc9l4OQkwWYESIe+Rc2goHwDTHdGYGBJKS+Vnufh9+l/x+Gdlr8m8Vzva4JSnhMtAcOnzTCXZnvZCqxjqLueX5qS0HeAtHdHLcIxgIMJquyX9PuPJCqYaIMpCRhCPzC7tLG5dMVoYGZBkjWt6p+HYlkkuPlDUrXZ/MQUNu3UFWFRjUm/zJj92wwKldCgRNOJTBTe+YhWPM/AhoND4EJ8vymQOkCnmFTdbvAfpe/yO+7FrM/0jyQ=","description":"成功","securityStatus":0,"nonce":5937468700529491968,"userId":8161011682,"cUserId":"d7BvRzpJp2fIp_BmYH4fXAU23E8","result":"ok","psecurity":"SLnzQYnjD1y92+AtNj1WIA==","captchaUrl":null,"location":"https://sts.api.io.mi.com/sts?d=hcvyd&ticket=0&pwd=1&p_ts=1649355122000&fid=0&p_lm=1&auth=EIZ7Zp2Kjae53RtQ1qPkDDdDyYz%2B%2B%2BLPCf35MeIhU%2BDPuJ7g3zbcoUrpIKZpX9Hb9XMNIDfW5LX45JH%2FUZLyO8POuYUg7x2Bn49fd6vuJkNR9pH9tdOwOEfsP9nOwaaA6fbAvQW8KUWnLcQSsOzopEdWXUBtT340qhGEWsuKdlw%3D&m=1&tsl=0&nonce=3aPnnH6vLo0Bo3Pk&_ssign=OvZlP59LAGWExkueSkOSI5HqXGU%3D","pwd":1,"desc":"成功"}
                                          2022-04-07 20:12:03.141 - info: mihome-vacuum.0 (17390) settest next timer: not available
                                          2022-04-07 20:12:03.279 - debug: mihome-vacuum.0 (17390) Login step3: [{"key":"userId","value":"8161011682","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-04-07T18:12:03.250Z","lastAccessed":"2022-04-07T18:12:03.278Z"},{"key":"cUserId","value":"d7BvRzpJp2fIp_BmYH4fXAU23E8","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-04-07T18:12:03.264Z","lastAccessed":"2022-04-07T18:12:03.278Z"},{"key":"serviceToken","value":"pE4bcLhDVytuM1iPXebrZ6dawOhvMI6QrHgeacnK/IrLVvbWt8PtRK2CBnZ/y6F6SctDx7G6lg2nN3V+ofLBhZdoyrAz0Li4CctGekhhu04aKOHlS5kzgukNiRolAoxADIopSqiTlcFY76PCK41ARVw1QrvNnrvajb9pGkRQTgo=","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-04-07T18:12:03.270Z","lastAccessed":"2022-04-07T18:12:03.278Z"}]
                                          2022-04-07 20:12:03.280 - debug: mihome-vacuum.0 (17390) Xiaomi Cloud: Login successful
                                          2022-04-07 20:12:03.301 - debug: mihome-vacuum.0 (17390) Create State for Queue: queue
                                          2022-04-07 20:12:03.302 - debug: mihome-vacuum.0 (17390) Create State for Queue: clearQueue
                                          2022-04-07 20:12:03.306 - info: mihome-vacuum.0 (17390) Map selected create states...
                                          2022-04-07 20:12:03.309 - debug: mihome-vacuum.0 (17390) Create State for map:
                                          2022-04-07 20:12:03.310 - debug: mihome-vacuum.0 (17390) Create State for map: map64
                                          2022-04-07 20:12:03.311 - debug: mihome-vacuum.0 (17390) Create State for map: actualMap
                                          2022-04-07 20:12:03.313 - debug: mihome-vacuum.0 (17390) Create State for map: mapStatus
                                          2022-04-07 20:12:03.314 - debug: mihome-vacuum.0 (17390) Create State for map: mapURL
                                          2022-04-07 20:12:03.315 - debug: mihome-vacuum.0 (17390) Create State for map: loadMap
                                          2022-04-07 20:12:03.315 - debug: mihome-vacuum.0 (17390) Create State done!
                                          2022-04-07 20:12:03.316 - debug: mihome-vacuum.0 (17390) get params for stock Vacuum
                                          2022-04-07 20:12:03.317 - debug: mihome-vacuum.0 (17390) Message= {"id":2,"method":"get_status"}
                                          2022-04-07 20:12:03.326 - debug: mihome-vacuum.0 (17390) MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":3481,"state":18,"battery":100,"clean_time":51,"clean_area":1615000,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":101,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0}],"id":2}
                                          2022-04-07 20:12:03.327 - debug: mihome-vacuum.0 (17390) setGetStatus {"msg_ver":2,"msg_seq":3481,"state":18,"battery":100,"clean_time":51,"clean_area":1615000,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":101,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"error_text":"No error"}
                                          2022-04-07 20:12:03.328 - info: mihome-vacuum.0 (17390) change states from State control.fan_power
                                          2022-04-07 20:12:03.342 - info: mihome-vacuum.0 (17390) create states for water box
                                          2022-04-07 20:12:03.345 - info: mihome-vacuum.0 (17390) create states for water box mode
                                          2022-04-07 20:12:03.348 - info: mihome-vacuum.0 (17390) create states for mop
                                          2022-04-07 20:12:03.419 - debug: mihome-vacuum.0 (17390) Message= {"id":3,"method":"get_map_v1"}
                                          2022-04-07 20:12:03.426 - debug: mihome-vacuum.0 (17390) MIIO RECIVE: {"result":["retry"],"id":3}
                                          2022-04-07 20:12:03.728 - debug: mihome-vacuum.0 (17390) Message= {"id":4,"method":"get_map_v1"}
                                          2022-04-07 20:12:03.736 - debug: mihome-vacuum.0 (17390) MIIO RECIVE: {"result":["rubyslite%2F320339760%2F6"],"id":4}
                                          2022-04-07 20:12:03.738 - debug: mihome-vacuum.0 (17390) Mappointer_updated
                                          2022-04-07 20:12:03.740 - debug: mihome-vacuum.0 (17390) update_Map Mimap enabled
                                          2022-04-07 20:12:03.741 - debug: mihome-vacuum.0 (17390) update_Map need new mapurl
                                          2022-04-07 20:12:03.753 - debug: mihome-vacuum.0 (17390) Message= {"id":5,"method":"get_room_mapping"}
                                          2022-04-07 20:12:03.765 - debug: mihome-vacuum.0 (17390) MIIO RECIVE: {"result":[[20,"281001038309"],[16,"281001038371"],[17,"281001038308"],[18,"281001038310"],[19,"281001038295"]],"id":5}
                                          2022-04-07 20:12:03.769 - debug: mihome-vacuum.0 (17390) Message= {"id":6,"method":"get_map_v1"}
                                          2022-04-07 20:12:03.771 - debug: mihome-vacuum.0 (17390) Message= {"id":7,"method":"get_network_info"}
                                          2022-04-07 20:12:03.779 - debug: mihome-vacuum.0 (17390) MIIO RECIVE: {"result":["rubyslite%2F320339760%2F6"],"id":6}
                                          2022-04-07 20:12:03.780 - debug: mihome-vacuum.0 (17390) Mappointer_updated
                                          2022-04-07 20:12:03.782 - debug: mihome-vacuum.0 (17390) update_Map Mimap enabled
                                          2022-04-07 20:12:03.782 - debug: mihome-vacuum.0 (17390) update_Map need new mapurl
                                          2022-04-07 20:12:03.831 - debug: mihome-vacuum.0 (17390) MIIO RECIVE: {"result":{"ssid":"froehlich.unifi","ip":"192.168.229.31","mac":"64:90:c1:01:fb:13","bssid":"4a:d9:e7:fa:7f:d0","rssi":-49},"id":7}
                                          2022-04-07 20:12:03.911 - debug: mihome-vacuum.0 (17390) Message= {"id":8,"method":"get_sound_volume"}
                                          2022-04-07 20:12:03.917 - debug: mihome-vacuum.0 (17390) MIIO RECIVE: {"result":[30],"id":8}
                                          2022-04-07 20:12:03.918 - debug: mihome-vacuum.0 (17390) Message= {"id":9,"method":"get_multi_maps_list"}
                                          2022-04-07 20:12:03.925 - debug: mihome-vacuum.0 (17390) MIIO RECIVE: {"result":[{"max_multi_map":1,"max_bak_map":0,"multi_map_count":1,"map_info":[{"mapFlag":0,"add_time":1645100692,"length":0,"name":"","bak_maps":[]}]}],"id":9}
                                          2022-04-07 20:12:03.926 - debug: mihome-vacuum.0 (17390) States for 1 Map: [{"mapFlag":0,"add_time":1645100692,"length":0,"name":"","bak_maps":[]}]
                                          2022-04-07 20:12:03.927 - debug: mihome-vacuum.0 (17390) States for Map: {"0":"0"}
                                          2022-04-07 20:12:03.929 - debug: mihome-vacuum.0 (17390) Startup: getMultiMapsList Answer: true
                                          2022-04-07 20:12:03.930 - debug: mihome-vacuum.0 (17390) Startup: Delete getMultiMapsList
                                          2022-04-07 20:12:03.931 - debug: mihome-vacuum.0 (17390) Message= {"id":10,"method":"get_clean_summary"}
                                          2022-04-07 20:12:03.941 - error: mihome-vacuum.0 (17390) Error when receiving map url: ,q^QzuH \I87*XacZYDi&9_2@%ELks>]lIB H,QK`w\u_G?201k #r':="" mihome-vacuum.0="" (17390)="" map="" error:syntaxerror:="" unexpected="" token="" ,="" in="" json="" at="" position="" 0="" 20:12:03.944="" debug:="" xiaomi="" cloud:="" logging="" 20:12:03.949="" update_map="" got="" new="" url:https:="" awsde0.fds.api.xiaomi.com="" robomap="" rubyslite="" 320339760="" 6?expires="1649356923000&GalaxyAccessKeyId=5271733786445&Signature=ejbVApzz4Rfo8K+C66r9MfbH7FA=" 20:12:03.950="" expires:1649356923="" 20:12:03.951="" time:1649355123="" 20:12:03.969="" miio="" recive:="" {"result":[137508,2615415000,262,[1649354396,1649353781,1649347353,1649345161,1649344894,1649340240,1649247640,1649166646,1649165186,1649164160,1649163821,1649160739,1649159455,1649158426,1649154359,1649153775,1649152468,1649151540,1649148317,1649146933]],"id":10}="" 20:12:03.971="" message="{"id":11,"method":"get_clean_record","params":[1649354396]}" 20:12:03.979="" {"result":[[1649354396,1649354851,212,7417500,0,0,2,3,60]],"id":11}="" 20:12:03.981="" 20:12:03.991="" {"result":[[1649353781,1649353821,36,647500,0,0,2,3,60]],"id":12}="" 20:12:03.993="" 20:12:04.001="" {"result":[[1649347353,1649347937,580,12275000,0,0,2,3,60]],"id":13}="" 20:12:04.002="" 20:12:04.010="" {"result":[[1649345161,1649345243,10,0,0,0,2,3,60]],"id":14}="" 20:12:04.012="" 20:12:04.019="" {"result":[[1649344894,1649345083,10,0,0,0,2,3,60]],"id":15}="" 20:12:04.020="" 20:12:04.026="" {"result":[[1649340240,1649341269,1029,19720000,0,1,2,3,56]],"id":16}="" 20:12:04.027="" 20:12:04.033="" {"result":[[1649247640,1649248754,1114,20080000,0,1,2,3,56]],"id":17}="" 20:12:04.034="" 20:12:04.040="" {"result":[[1649166646,1649166833,183,5045000,0,0,2,3,60]],"id":18}="" 20:12:04.041="" 20:12:04.048="" {"result":[[1649165186,1649166304,89,1582500,0,0,2,3,60]],"id":19}="" 20:12:04.058="" {"result":[[1649164160,1649164352,188,5327500,0,0,2,3,60]],"id":20}="" 20:12:04.059="" 20:12:04.065="" {"result":[[1649163821,1649163939,118,1637500,0,1,2,3,56]],"id":21}="" 20:12:04.066="" 20:12:04.073="" {"result":[[1649160739,1649160785,42,910000,0,0,2,3,60]],"id":22}="" 20:12:04.075="" 20:12:04.083="" {"result":[[1649159455,1649159580,125,1657500,0,1,2,3,56]],"id":23}="" 20:12:04.084="" 20:12:04.093="" {"result":[[1649158426,1649158524,94,3512500,0,0,2,3,60]],"id":24}="" 20:12:04.094="" 20:12:04.100="" {"result":[[1649154359,1649154901,542,10960000,0,1,2,3,56]],"id":25}="" 20:12:04.101="" 20:12:04.110="" {"result":[[1649153775,1649153893,118,1577500,0,1,2,3,56]],"id":26}="" 20:12:04.111="" 20:12:04.116="" {"result":[[1649152468,1649152670,198,5975000,0,0,2,3,60]],"id":27}="" 20:12:04.118="" 20:12:04.124="" {"result":[[1649151540,1649151651,111,1605000,0,1,2,3,56]],"id":28}="" 20:12:04.125="" 20:12:04.131="" {"result":[[1649148317,1649148868,356,9850000,0,0,2,3,60]],"id":29}="" 20:12:04.132="" 20:12:04.138="" {"result":[[1649146933,1649147053,120,1755000,0,1,2,3,56]],"id":30}="" 20:12:04.139="" finish="" logs="" all="" [{"datum":"7.4","start":"19:59","saugzeit":"4="" min","fläche":"7.42="" m²","error":0,"ende":false},{"datum":"7.4","start":"19:49","saugzeit":"1="" min","fläche":"0.65="" m²","error":0,"ende":false},{"datum":"7.4","start":"18:02","saugzeit":"10="" min","fläche":"12.28="" m²","error":0,"ende":false},{"datum":"7.4","start":"17:26","saugzeit":"0="" min","fläche":"0="" m²","error":0,"ende":false},{"datum":"7.4","start":"17:21","saugzeit":"0="" m²","error":0,"ende":false},{"datum":"7.4","start":"16:04","saugzeit":"17="" min","fläche":"19.72="" m²","error":0,"ende":true},{"datum":"6.4","start":"14:20","saugzeit":"19="" min","fläche":"20.08="" m²","error":0,"ende":true},{"datum":"5.4","start":"15:50","saugzeit":"3="" min","fläche":"5.05="" m²","error":0,"ende":false},{"datum":"5.4","start":"15:26","saugzeit":"1="" min","fläche":"1.58="" m²","error":0,"ende":false},{"datum":"5.4","start":"15:09","saugzeit":"3="" min","fläche":"5.33="" m²","error":0,"ende":false},{"datum":"5.4","start":"15:03","saugzeit":"2="" min","fläche":"1.64="" m²","error":0,"ende":true},{"datum":"5.4","start":"14:12","saugzeit":"1="" min","fläche":"0.91="" m²","error":0,"ende":false},{"datum":"5.4","start":"13:50","saugzeit":"2="" min","fläche":"1.66="" m²","error":0,"ende":true},{"datum":"5.4","start":"13:33","saugzeit":"2="" min","fläche":"3.51="" m²","error":0,"ende":false},{"datum":"5.4","start":"12:25","saugzeit":"9="" min","fläche":"10.96="" m²","error":0,"ende":true},{"datum":"5.4","start":"12:16","saugzeit":"2="" m²","error":0,"ende":true},{"datum":"5.4","start":"11:54","saugzeit":"3="" min","fläche":"5.98="" m²","error":0,"ende":false},{"datum":"5.4","start":"11:39","saugzeit":"2="" min","fläche":"1.61="" m²","error":0,"ende":true},{"datum":"5.4","start":"10:45","saugzeit":"6="" min","fläche":"9.85="" m²","error":0,"ende":false},{"datum":"5.4","start":"10:22","saugzeit":"2="" min","fläche":"1.76="" m²","error":0,"ende":true}]="" 20:12:04.141="" startup:="" setgetcleansummary="" answer:="" true="" delete="" 20:12:04.142="" 20:12:04.150="" {"result":[{"main_brush_work_time":137508,"side_brush_work_time":137508,"filter_work_time":137508,"filter_element_work_time":11733,"sensor_dirty_time":28763}],"id":31}="" 20:12:04.152="" setgetconsumable="" 20:12:04.153="" 20:12:04.154="" 20:12:04.171="" {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":32}="" 20:12:04.172="" info:="" create="" state="" for="" carpet_mode="" 20:12:04.173="" 20:12:04.183="" login="" step1:="" &&&start&&&{"serviceparam":"{\"checksafephone\":false,\"checksafeaddress\":false,\"lsrp_score\":0.0}","qs":"%3fsid%3dxiaomiio%26_json%3dtrue","code":70016,"description":"登录验证失败","securitystatus":0,"_sign":"0psxfr43eni0ix6q9suk3qwbrqu="," sid":"xiaomiio","result":"error","captchaurl":null,"callback":"https:="" sts.api.io.mi.com="" sts","location":"https:="" account.xiaomi.com="" fe="" service="" login?_json="true&sid=xiaomiio&qs=%253Fsid%253Dxiaomiio%2526_json%253Dtrue&callback=https%3A%2F%2Fsts.api.io.mi.com%2Fsts&_sign=0psXfr43eNI0IX6q9Suk3qWbRqU%3D&serviceParam=%7B%22checkSafePhone%22%3Afalse%2C%22checkSafeAddress%22%3Afalse%2C%22lsrp_score%22%3A0.0%7D&showActiveX=false&theme=&needTheme=false&bizDeviceType=","pwd":0,"desc":"登录验证失败"}" 20:12:04.187="" {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":33}="" 20:12:04.511="" 26984="" 20:12:04.679="" host.smarthomeraspi="" instance="" system.adapter.mihome-vacuum.0="" terminated="" due="" to="" sigsegv="" 20:12:04.680="" with="" code="" nan="" ()="" restart="" adapter="" because="" enabled="" 20:12:09.889="" javascript.0="" (4683)="" script.js.rollläden.helligkeit_durchschnittswert:="" [13,15,17,20,23,26,30,34,39,44,50,57,65,73,83,94,106,119,134,151,170,191,215,245,275,309,275,313,353,399]="" 20:12:09.898="" shuttercontrol.0="" (1726)="" lightsensor="" changed:="" 0_userdata.0.rollladen.helligkeit_durchschnitt="" value:="" 131="" 20:12:20.782="" hm-rpc.0="" (1147)="" [keepalive]="" check="" if="" connection="" is="" alive="" 20:12:20.783="" send="" ping...="" 20:12:20.806="" ping="" ok="" 20:12:20.810="" xml="" multicall="" : SmarthomeRaspi:hm-rpc.0:86e5c28de60614468b710549803c5777,CENTRAL,PONG,SmarthomeRaspi:hm-rpc.0:86e5c28de60614468b710549803c5777
                                          2022-04-07 20:12:20.811 - debug: hm-rpc.0 (1147) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.0:86e5c28de60614468b710549803c5777","CENTRAL","PONG","SmarthomeRaspi:hm-rpc.0:86e5c28de60614468b710549803c5777"]
                                          2022-04-07 20:12:20.812 - debug: hm-rpc.0 (1147) xmlrpc <- event: hm-rpc.0.CENTRAL.PONG:SmarthomeRaspi:hm-rpc.0:86e5c28de60614468b710549803c5777 discarded, no matching device
                                          2022-04-07 20:12:23.564 - debug: hm-rpc.1 (1169) [KEEPALIVE] Check if connection is alive
                                          2022-04-07 20:12:23.564 - debug: hm-rpc.1 (1169) Send PING...
                                          2022-04-07 20:12:23.582 - debug: hm-rpc.1 (1169) PING ok
                                          2022-04-07 20:12:23.584 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","CENTRAL:0","PONG","SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31"]
                                          2022-04-07 20:12:23.585 - debug: hm-rpc.1 (1169) xmlrpc <- event: hm-rpc.1.CENTRAL.0.PONG:SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31 discarded, no matching device
                                          2022-04-07 20:12:35.263 - info: host.SmarthomeRaspi instance system.adapter.mihome-vacuum.0 started with pid 17461
                                          2022-04-07 20:12:36.815 - debug: mihome-vacuum.0 (17461) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                          2022-04-07 20:12:36.896 - debug: mihome-vacuum.0 (17461) Objects client ready ... initialize now
                                          2022-04-07 20:12:36.899 - debug: mihome-vacuum.0 (17461) Objects create System PubSub Client
                                          2022-04-07 20:12:36.900 - debug: mihome-vacuum.0 (17461) Objects create User PubSub Client
                                          2022-04-07 20:12:37.046 - debug: mihome-vacuum.0 (17461) Objects client initialize lua scripts
                                          2022-04-07 20:12:37.053 - debug: mihome-vacuum.0 (17461) Objects connected to redis: 127.0.0.1:9001
                                          2022-04-07 20:12:37.119 - debug: mihome-vacuum.0 (17461) Redis States: Use Redis connection: 127.0.0.1:9000
                                          2022-04-07 20:12:37.183 - debug: mihome-vacuum.0 (17461) States create System PubSub Client
                                          2022-04-07 20:12:37.185 - debug: mihome-vacuum.0 (17461) States create User PubSub Client
                                          2022-04-07 20:12:37.261 - debug: mihome-vacuum.0 (17461) States connected to redis: 127.0.0.1:9000
                                          2022-04-07 20:12:37.523 - debug: mihome-vacuum.0 (17461) Plugin sentry Initialize Plugin (enabled=true)
                                          2022-04-07 20:12:38.030 - info: mihome-vacuum.0 (17461) starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.19.1, js-controller: 4.0.21
                                          2022-04-07 20:12:38.130 - debug: mihome-vacuum.0 (17461) load Map creator... true
                                          2022-04-07 20:12:38.167 - debug: mihome-vacuum.0 (17461) Create State for deviceInfo
                                          2022-04-07 20:12:38.168 - debug: mihome-vacuum.0 (17461) Create State for deviceInfomac
                                          2022-04-07 20:12:38.169 - debug: mihome-vacuum.0 (17461) Create State for deviceInfomodel
                                          2022-04-07 20:12:38.170 - debug: mihome-vacuum.0 (17461) Create State for deviceInfofw_ver
                                          2022-04-07 20:12:38.174 - debug: mihome-vacuum.0 (17461) Create State for deviceInfowifi_signal
                                          2022-04-07 20:12:38.176 - debug: mihome-vacuum.0 (17461) MIIO: Config: ip:192.168.229.31 token: 6a62485744456c466c766f6d45535473
                                          2022-04-07 20:12:38.183 - info: mihome-vacuum.0 (17461) IOT enabled, create state
                                          2022-04-07 20:12:38.189 - debug: mihome-vacuum.0 (17461) server started on 0.0.0.0:53421
                                          2022-04-07 20:12:38.197 - debug: mihome-vacuum.0 (17461) Receive <<< Helo <<< 21310020000000001317ff30624f2996ffffffffffffffffffffffffffffffff
                                          2022-04-07 20:12:38.199 - debug: mihome-vacuum.0 (17461) MAIN: Connected to device, try to get model..
                                          2022-04-07 20:12:38.227 - debug: mihome-vacuum.0 (17461) GETMODELFROMAPI: objModel: {"val":"roborock.vacuum.s5e","ack":true,"ts":1649355122288,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1649165771511}
                                          2022-04-07 20:12:38.230 - debug: mihome-vacuum.0 (17461) Message= {"id":1,"method":"miIO.info"}
                                          2022-04-07 20:12:40.237 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "miIO.info" <<<
                                          2022-04-07 20:12:40.238 - debug: mihome-vacuum.0 (17461) Get Device data..0
                                          2022-04-07 20:12:40.238 - debug: mihome-vacuum.0 (17461) Message= {"id":2,"method":"miIO.info"}
                                          2022-04-07 20:12:40.589 - info: unifi.0 (2213) State value to set for "unifi.0.default.clients.ae:2d:74:9e:b6:86.noted" has to be type "boolean" but received type "string"
                                          2022-04-07 20:12:40.685 - info: unifi.0 (2213) State value to set for "unifi.0.default.clients.94:e7:0b:61:00:58.noted" has to be type "boolean" but received type "string"
                                          2022-04-07 20:12:42.240 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "miIO.info" <<<
                                          2022-04-07 20:12:42.241 - debug: mihome-vacuum.0 (17461) Get Device data..1
                                          2022-04-07 20:12:42.241 - debug: mihome-vacuum.0 (17461) Message= {"id":3,"method":"miIO.info"}
                                          2022-04-07 20:12:44.243 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "miIO.info" <<<
                                          2022-04-07 20:12:44.243 - debug: mihome-vacuum.0 (17461) Get Device data..2
                                          2022-04-07 20:12:44.244 - debug: mihome-vacuum.0 (17461) Message= {"id":4,"method":"miIO.info"}
                                          2022-04-07 20:12:46.246 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "miIO.info" <<<
                                          2022-04-07 20:12:46.247 - debug: mihome-vacuum.0 (17461) Get Device data..3
                                          2022-04-07 20:12:46.247 - debug: mihome-vacuum.0 (17461) Message= {"id":5,"method":"miIO.info"}
                                          2022-04-07 20:12:48.207 - debug: mihome-vacuum.0 (17461) Receive <<< Helo <<< 21310020000000001317ff30624f29a0ffffffffffffffffffffffffffffffff
                                          2022-04-07 20:12:48.249 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "miIO.info" <<<
                                          2022-04-07 20:12:48.251 - debug: mihome-vacuum.0 (17461) Get Device data..4
                                          2022-04-07 20:12:48.252 - warn: mihome-vacuum.0 (17461) YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER YET - CONNECTION CAN TAKE UP TO 10 MINUTES - PLEASE BE PATIENT AND DO NOT TURN THE ADAPTER OFF
                                          2022-04-07 20:12:48.253 - warn: mihome-vacuum.0 (17461) No Answer for DeviceModel use old one
                                          2022-04-07 20:12:48.254 - warn: mihome-vacuum.0 (17461) No Answer for DeviceModel use model from Config
                                          2022-04-07 20:12:48.286 - debug: mihome-vacuum.0 (17461) DeviceModel selected to: roborock.vacuum.s5e
                                          2022-04-07 20:12:48.289 - info: mihome-vacuum.0 (17461) select standard vacuum protocol....
                                          2022-04-07 20:12:48.299 - debug: mihome-vacuum.0 (17461) Xiaomi Cloud: Logging in
                                          2022-04-07 20:12:48.395 - debug: mihome-vacuum.0 (17461) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                                          2022-04-07 20:12:48.618 - debug: mihome-vacuum.0 (17461) Login step1: &&&START&&&{"serviceParam":"{\"checkSafePhone\":false,\"checkSafeAddress\":false,\"lsrp_score\":0.0}","qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","code":70016,"description":"登录验证失败","securityStatus":0,"_sign":"0psXfr43eNI0IX6q9Suk3qWbRqU=","sid":"xiaomiio","result":"error","captchaUrl":null,"callback":"https://sts.api.io.mi.com/sts","location":"https://account.xiaomi.com/fe/service/login?_json=true&sid=xiaomiio&qs=%253Fsid%253Dxiaomiio%2526_json%253Dtrue&callback=https%3A%2F%2Fsts.api.io.mi.com%2Fsts&_sign=0psXfr43eNI0IX6q9Suk3qWbRqU%3D&serviceParam=%7B%22checkSafePhone%22%3Afalse%2C%22checkSafeAddress%22%3Afalse%2C%22lsrp_score%22%3A0.0%7D&showActiveX=false&theme=&needTheme=false&bizDeviceType=","pwd":0,"desc":"登录验证失败"}
                                          2022-04-07 20:12:48.886 - debug: mihome-vacuum.0 (17461) Login step2: &&&START&&&{"qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","ssecurity":"SepRPCb5Gp3xHlMGTDMc6w==","code":0,"passToken":"V1:DXmurwq2/R1BHTELu6obCWKEFrEUGTARxOslPX6sxFF2Q8OlltPlCwT/UWqRgzdB0dLMMvcPG8AkDj4/+A82UV7DMirIabZ3FerW1PO6f5O67G9v0w978SPbJFPYfZjinxUAaHyGnjv7OHBePMBqVEB0h/QYglsEKHJGUbmzEm+3QgFc0wPvnjF6DZgahfTvBBA+TwZ/xrKw40MYUbsHcDnJwLuh6hNjmwkt6eMpLAoQE1NL261T6RVBpeWNH3pYqxwNZMZ9aeJRB71X8Ygj63GPXuM91zTS514w1SA2ppA=","description":"成功","securityStatus":0,"nonce":3032190925820327936,"userId":8161011682,"cUserId":"d7BvRzpJp2fIp_BmYH4fXAU23E8","result":"ok","psecurity":"qwnCZNR1XvS8GflT4azUJA==","captchaUrl":null,"location":"https://sts.api.io.mi.com/sts?d=gzwnnq&ticket=0&pwd=1&p_ts=1649355168000&fid=0&p_lm=1&auth=rCDOR5U3EDvAjqyhbqZTnqchvMFu25Yc5vxN1QIjYLOmFxvRocYln04TlM0e3aYti4XTfapSU4G5zEP4vKAvZqlP7brrRgLlQi0fbdpd2JSDH84sMRl6i8qWPjUuGj9X3OcRDhkm12XuDZT9pjbRYw64I7xfbnYGezBXSEJ8WwY%3D&m=1&tsl=0&nonce=lvi8eHbKkg8Bo3Pk&_ssign=U08FSkqWBO%2FhVOJXffR50pBC5SQ%3D","pwd":1,"desc":"成功"}
                                          2022-04-07 20:12:49.029 - info: mihome-vacuum.0 (17461) settest next timer: not available
                                          2022-04-07 20:12:49.251 - debug: mihome-vacuum.0 (17461) Login step3: [{"key":"userId","value":"8161011682","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-04-07T18:12:49.194Z","lastAccessed":"2022-04-07T18:12:49.248Z"},{"key":"cUserId","value":"d7BvRzpJp2fIp_BmYH4fXAU23E8","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-04-07T18:12:49.219Z","lastAccessed":"2022-04-07T18:12:49.248Z"},{"key":"serviceToken","value":"PlyQUW9q7aeZNtWORxesgsriRJJGvLPk3oTyMSaP2wG45oBiDVK6ZiHNX5KCwQup0RFhxEzTkYwbZWG1Nuquo7V9V0JKWRleagwbEJ1X/4JODW27+AVy+MHqsmjwE1fRxUmADb3JYCGd+g74Weydjv4ptbnbFL9QhR6BMLwNRHo=","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-04-07T18:12:49.233Z","lastAccessed":"2022-04-07T18:12:49.248Z"}]
                                          2022-04-07 20:12:49.266 - debug: mihome-vacuum.0 (17461) Xiaomi Cloud: Login successful
                                          2022-04-07 20:12:49.336 - debug: mihome-vacuum.0 (17461) Create State for Queue: queue
                                          2022-04-07 20:12:49.337 - debug: mihome-vacuum.0 (17461) Create State for Queue: clearQueue
                                          2022-04-07 20:12:49.341 - info: mihome-vacuum.0 (17461) Map selected create states...
                                          2022-04-07 20:12:49.344 - debug: mihome-vacuum.0 (17461) Create State for map:
                                          2022-04-07 20:12:49.345 - debug: mihome-vacuum.0 (17461) Create State for map: map64
                                          2022-04-07 20:12:49.346 - debug: mihome-vacuum.0 (17461) Create State for map: actualMap
                                          2022-04-07 20:12:49.348 - debug: mihome-vacuum.0 (17461) Create State for map: mapStatus
                                          2022-04-07 20:12:49.349 - debug: mihome-vacuum.0 (17461) Create State for map: mapURL
                                          2022-04-07 20:12:49.350 - debug: mihome-vacuum.0 (17461) Create State for map: loadMap
                                          2022-04-07 20:12:49.350 - debug: mihome-vacuum.0 (17461) Create State done!
                                          2022-04-07 20:12:49.351 - debug: mihome-vacuum.0 (17461) get params for stock Vacuum
                                          2022-04-07 20:12:49.352 - debug: mihome-vacuum.0 (17461) Message= {"id":6,"method":"get_status"}
                                          2022-04-07 20:12:51.353 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "get_status" <<<
                                          2022-04-07 20:12:51.354 - debug: mihome-vacuum.0 (17461) ERROR at setGetStatus: MESSAGE TIMEOUT
                                          2022-04-07 20:12:51.355 - debug: mihome-vacuum.0 (17461) Message= {"id":7,"method":"get_network_info"}
                                          2022-04-07 20:12:53.356 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "get_network_info" <<<
                                          2022-04-07 20:12:53.357 - debug: mihome-vacuum.0 (17461) Error at getSetNetwork: MESSAGE TIMEOUT
                                          2022-04-07 20:12:53.358 - debug: mihome-vacuum.0 (17461) Message= {"id":8,"method":"get_sound_volume"}
                                          2022-04-07 20:12:55.360 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "get_sound_volume" <<<
                                          2022-04-07 20:12:55.361 - debug: mihome-vacuum.0 (17461) ERROR at setGetSoundVolume: MESSAGE TIMEOUT
                                          2022-04-07 20:12:55.363 - debug: mihome-vacuum.0 (17461) Message= {"id":9,"method":"get_multi_maps_list"}
                                          2022-04-07 20:12:57.365 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "get_multi_maps_list" <<<
                                          2022-04-07 20:12:57.367 - debug: mihome-vacuum.0 (17461) Startup: getMultiMapsList Answer: false
                                          2022-04-07 20:12:57.368 - debug: mihome-vacuum.0 (17461) Message= {"id":10,"method":"get_clean_summary"}
                                          2022-04-07 20:12:58.212 - debug: mihome-vacuum.0 (17461) Receive <<< Helo <<< 21310020000000001317ff30624f29aaffffffffffffffffffffffffffffffff
                                          2022-04-07 20:12:59.370 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "get_clean_summary" <<<
                                          2022-04-07 20:12:59.371 - debug: mihome-vacuum.0 (17461) ERROR at setGetCleanSummary: MESSAGE TIMEOUT
                                          2022-04-07 20:12:59.372 - debug: mihome-vacuum.0 (17461) Startup: setGetCleanSummary Answer: false
                                          2022-04-07 20:12:59.373 - debug: mihome-vacuum.0 (17461) Message= {"id":11,"method":"get_consumable"}
                                          2022-04-07 20:13:01.374 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "get_consumable" <<<
                                          2022-04-07 20:13:01.377 - debug: mihome-vacuum.0 (17461) ERROR at setGetConsumable: MESSAGE TIMEOUT
                                          2022-04-07 20:13:01.378 - debug: mihome-vacuum.0 (17461) Startup: setGetConsumable Answer: false
                                          2022-04-07 20:13:01.380 - debug: mihome-vacuum.0 (17461) Message= {"id":12,"method":"get_map_v1"}
                                          2022-04-07 20:13:03.384 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "get_map_v1" <<<
