  4. Test Adapter Mihome-vacuum v3.1.6 Next Generarition
    2.4k
    4.3k
1.2k Beiträge 100 Kommentatoren 462.7k Aufrufe 82 Beobachtet
    @tobiasf78
    Ja, macht aber wenig Sinn, es wird der Kontext benötigt.
    TobiasF78
    #821
    dieser Fehler kam noch
    2022-04-07 20:15:46.409 - debug: mihome-vacuum.0 (17698) Message= {"id":6,"method":"get_map_v1"}
    2022-04-07 20:15:46.413 - debug: mihome-vacuum.0 (17698) Message= {"id":7,"method":"get_network_info"}
    2022-04-07 20:15:46.424 - debug: mihome-vacuum.0 (17698) MIIO RECIVE: {"result":["rubyslite%2F320339760%2F14"],"id":6}
    2022-04-07 20:15:46.427 - debug: mihome-vacuum.0 (17698) Mappointer_updated
    2022-04-07 20:15:46.428 - debug: mihome-vacuum.0 (17698) update_Map Mimap enabled
    2022-04-07 20:15:46.429 - debug: mihome-vacuum.0 (17698) update_Map need new mapurl
    2022-04-07 20:15:46.441 - debug: mihome-vacuum.0 (17698) MIIO RECIVE: {"result":{"ssid":"froehlich.unifi","ip":"192.168.229.31","mac":"64:90:c1:01:fb:13","bssid":"4a:d9:e7:fa:7f:d0","rssi":-49},"id":7}
    2022-04-07 20:15:46.552 - error: mihome-vacuum.0 (17698) Error when receiving map url: V/=+yvYq
    )-1z9kI@z,qiI'
    eCu40Sr]NCGHyHz>BU'<,]=sQug-,pd"in$jnf /?L)+(L\JNSIx"k;{6Ou'8u(}KMq7OGoij >"/RvMr -nRvmR9+)5Nx\i pI9]i9d-y}^"<KK1h|t,`Yi\%j<N
    /Q|h=RGu( #h)Yv`'bk6iFsPDi_B+7EJIVkb"EaZ{;"
    2022-04-07 20:15:46.554 - warn: mihome-vacuum.0 (17698) map error:SyntaxError: Unexpected token V in JSON at position 0
    2022-04-07 20:15:46.555 - debug: mihome-vacuum.0 (17698) Xiaomi Cloud: Logging in
    2022-04-07 20:15:46.565 - debug: mihome-vacuum.0 (17698) Message= {"id":8,"method":"get_sound_volume"}
    2022-04-07 20:15:46.572 - debug: mihome-vacuum.0 (17698) MIIO RECIVE: {"result":[30],"id":8}
    2022-04-07 20:15:46.575 - debug: mihome-vacuum.0 (17698) Message= {"id":9,"method":"get_multi_maps_list"}
    2022-04-07 20:15:46.581 - debug: mihome-vacuum.0 (17698) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320339760/14?Expires=1649357146000&GalaxyAccessKeyId=5271733786445&Signature=opGVwS3duRFnQWWBtkrse3j7Kr0=
    2022-04-07 20:15:46.582 - debug: mihome-vacuum.0 (17698) update_Map got new expires:1649357146
    2022-04-07 20:15:46.583 - debug: mihome-vacuum.0 (17698) update_Map got new time:1649355346
    2022-04-07 20:15:46.592 - debug: mihome-vacuum.0 (17698) MIIO RECIVE: {"result":[{"max_multi_map":1,"max_bak_map":0,"multi_map_count":1,"map_info":[{"mapFlag":0,"add_time":1645100692,"length":0,"name":"","bak_maps":[]}]}],"id":9}
    2022-04-07 20:15:46.593 - debug: mihome-vacuum.0 (17698) States for 1 Map: [{"mapFlag":0,"add_time":1645100692,"length":0,"name":"","bak_maps":[]}]
    2022-04-07 20:15:46.593 - debug: mihome-vacuum.0 (17698) States for Map: {"0":"0"}
    2022-04-07 20:15:46.595 - debug: mihome-vacuum.0 (17698) Startup: getMultiMapsList Answer: true
    2022-04-07 20:15:46.595 - debug: mihome-vacuum.0 (17698) Startup: Delete getMultiMapsList
    2022-04-07 20:15:46.596 - debug: mihome-vacuum.0 (17698) Message= {"id":10,"method":"get_clean_summary"}
      @tobiasf78
      TobiasF78
      #822
      22-04-07 20:15:46.795 - debug: mihome-vacuum.0 (17698) Login step1: &&&START&&&{"serviceParam":"{\"checkSafePhone\":false,\"checkSafeAddress\":false,\"lsrp_score\":0.0}","qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","code":70016,"description":"登录验证失败","securityStatus":0,"_sign":"0psXfr43eNI0IX6q9Suk3qWbRqU=","sid":"xiaomiio","result":"error","captchaUrl":null,"callback":"https://sts.api.io.mi.com/sts","location":"https://account.xiaomi.com/fe/service/login?_json=true&sid=xiaomiio&qs=%253Fsid%253Dxiaomiio%2526_json%253Dtrue&callback=https%3A%2F%2Fsts.api.io.mi.com%2Fsts&_sign=0psXfr43eNI0IX6q9Suk3qWbRqU%3D&serviceParam=%7B%22checkSafePhone%22%3Afalse%2C%22checkSafeAddress%22%3Afalse%2C%22lsrp_score%22%3A0.0%7D&showActiveX=false&theme=&needTheme=false&bizDeviceType=","pwd":0,"desc":"登录验证失败"}
      2022-04-07 20:15:46.798 - debug: mihome-vacuum.0 (17698) MIIO RECIVE: {"result":[{"main_brush_work_time":137508,"side_brush_work_time":137508,"filter_work_time":137508,"filter_element_work_time":11733,"sensor_dirty_time":28763}],"id":31}
      2022-04-07 20:15:46.799 - debug: mihome-vacuum.0 (17698) Startup: setGetConsumable Answer: true
      2022-04-07 20:15:46.799 - debug: mihome-vacuum.0 (17698) Startup: Delete setGetConsumable
      2022-04-07 20:15:46.800 - debug: mihome-vacuum.0 (17698) Message= {"id":32,"method":"get_carpet_mode"}
      2022-04-07 20:15:46.817 - debug: mihome-vacuum.0 (17698) MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":32}
      2022-04-07 20:15:46.818 - info: mihome-vacuum.0 (17698) create state for carpet_mode
      2022-04-07 20:15:46.819 - debug: mihome-vacuum.0 (17698) Message= {"id":33,"method":"get_carpet_mode"}
      2022-04-07 20:15:46.830 - debug: mihome-vacuum.0 (17698) MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":33}
      2022-04-07 20:15:47.111 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,CONFIG_PENDING,false
      2022-04-07 20:15:47.111 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","CONFIG_PENDING",false]
      2022-04-07 20:15:47.111 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.CONFIG_PENDING ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
      2022-04-07 20:15:47.112 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,DUTY_CYCLE,false
      2022-04-07 20:15:47.112 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","DUTY_CYCLE",false]
      2022-04-07 20:15:47.112 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.DUTY_CYCLE ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
      2022-04-07 20:15:47.112 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,LOW_BAT,false
      2022-04-07 20:15:47.112 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","LOW_BAT",false]
      2022-04-07 20:15:47.112 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.LOW_BAT ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
      2022-04-07 20:15:47.113 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,UNREACH,false
      2022-04-07 20:15:47.113 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","UNREACH",false]
      2022-04-07 20:15:47.113 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.UNREACH ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
      2022-04-07 20:15:47.113 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,RSSI_DEVICE,-79
      2022-04-07 20:15:47.113 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","RSSI_DEVICE",-79]
      2022-04-07 20:15:47.113 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.RSSI_DEVICE ==> UNIT: "undefined" (min: -128, max: 127) From "-79" => "-79"
      2022-04-07 20:15:47.113 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,OPERATING_VOLTAGE_STATUS,0
      2022-04-07 20:15:47.114 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","OPERATING_VOLTAGE_STATUS",0]
      2022-04-07 20:15:47.114 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.OPERATING_VOLTAGE_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
      2022-04-07 20:15:47.114 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,OPERATING_VOLTAGE,3
      2022-04-07 20:15:47.114 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","OPERATING_VOLTAGE",3]
      2022-04-07 20:15:47.114 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.OPERATING_VOLTAGE ==> UNIT: "undefined" (min: 0, max: 25.2) From "3" => "3"
      2022-04-07 20:15:47.114 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,ERROR_CODE,0
      2022-04-07 20:15:47.114 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","ERROR_CODE",0]
      2022-04-07 20:15:47.115 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.ERROR_CODE ==> UNIT: "undefined" (min: 0, max: 255) From "0" => "0"
      2022-04-07 20:15:47.125 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:3,MOTION,true
      2022-04-07 20:15:47.125 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:3","MOTION",true]
      2022-04-07 20:15:47.125 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.3.MOTION ==> UNIT: "undefined" (min: undefined, max: undefined) From "true" => "true"
      2022-04-07 20:15:47.125 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:3,ILLUMINATION,1.7
      2022-04-07 20:15:47.125 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:3","ILLUMINATION",1.7]
      2022-04-07 20:15:47.126 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.3.ILLUMINATION ==> UNIT: "undefined" (min: 0, max: 163830) From "1.7" => "1.7"
      2022-04-07 20:15:47.126 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:3,ILLUMINATION_STATUS,0
      2022-04-07 20:15:47.126 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:3","ILLUMINATION_STATUS",0]
      2022-04-07 20:15:47.127 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.3.ILLUMINATION_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
      2022-04-07 20:15:47.127 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:3,MOTION_DETECTION_ACTIVE,true
      2022-04-07 20:15:47.127 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:3","MOTION_DETECTION_ACTIVE",true]
      2022-04-07 20:15:47.132 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.3.MOTION_DETECTION_ACTIVE ==> UNIT: "undefined" (min: undefined, max: undefined) From "true" => "true"
      2022-04-07 20:15:47.167 - debug: mihome-vacuum.0 (17698) 22595
      2022-04-07 20:15:47.356 - error: host.SmarthomeRaspi Caught by controller[0]: corrupted double-linked list
      2022-04-07 20:15:47.357 - warn: host.SmarthomeRaspi instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
      2022-04-07 20:15:47.357 - info: host.SmarthomeRaspi instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
      2022-04-07 20:15:47.357 - info: host.SmarthomeRaspi Restart adapter system.adapter.mihome-vacuum.0 because enabled
      2022-04-07 20:15:49.608 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:0,CONFIG_PENDING,false
      2022-04-07 20:15:49.608 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:0","CONFIG_PENDING",false]
      2022-04-07 20:15:49.608 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.0.CONFIG_PENDING ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
      2022-04-07 20:15:49.608 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:0,RSSI_DEVICE,-84
      2022-04-07 20:15:49.609 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:0","RSSI_DEVICE",-84]
      2022-04-07 20:15:49.609 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.0.RSSI_DEVICE ==> UNIT: "undefined" (min: -128, max: 127) From "-84" => "-84"
      2022-04-07 20:15:49.609 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:0,DUTY_CYCLE,false
      2022-04-07 20:15:49.609 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:0","DUTY_CYCLE",false]
      2022-04-07 20:15:49.609 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.0.DUTY_CYCLE ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
      2022-04-07 20:15:49.609 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:0,UNREACH,false
      2022-04-07 20:15:49.609 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:0","UNREACH",false]
      2022-04-07 20:15:49.610 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.0.UNREACH ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
      2022-04-07 20:15:49.619 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:3,LEVEL,0
      2022-04-07 20:15:49.619 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:3","LEVEL",0]
      2022-04-07 20:15:49.619 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.3.LEVEL ==> UNIT: "100%" (min: 0, max: 1) From "0" => "0"
      2022-04-07 20:15:49.620 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:3,LEVEL_STATUS,0
      2022-04-07 20:15:49.620 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:3","LEVEL_STATUS",0]
      2022-04-07 20:15:49.620 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.3.LEVEL_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
      2022-04-07 20:15:49.620 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:3,SECTION,15
      2022-04-07 20:15:49.620 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:3","SECTION",15]
      2022-04-07 20:15:49.621 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.3.SECTION ==> UNIT: "undefined" (min: 0, max: 15) From "15" => "15"
      2022-04-07 20:15:49.621 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:3,PROCESS,0
      2022-04-07 20:15:49.621 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:3","PROCESS",0]
      2022-04-07 20:15:49.621 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.3.PROCESS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
      2022-04-07 20:15:49.621 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:3,ACTIVITY_STATE,3
      2022-04-07 20:15:49.621 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:3","ACTIVITY_STATE",3]
      2022-04-07 20:15:49.621 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.3.ACTIVITY_STATE ==> UNIT: "undefined" (min: undefined, max: undefined) From "3" => "3"
      2022-04-07 20:15:49.630 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:4,LEVEL,0
      2022-04-07 20:15:49.630 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:4","LEVEL",0]
      2022-04-07 20:15:49.631 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.4.LEVEL ==> UNIT: "100%" (min: 0, max: 1) From "0" => "0"
      2022-04-07 20:15:49.631 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:4,LEVEL_STATUS,0
      2022-04-07 20:15:49.631 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:4","LEVEL_STATUS",0]
      2022-04-07 20:15:49.632 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.4.LEVEL_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
      2022-04-07 20:15:49.632 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:4,SECTION,0
      2022-04-07 20:15:49.633 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:4","SECTION",0]
      2022-04-07 20:15:49.633 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.4.SECTION ==> UNIT: "undefined" (min: 0, max: 15) From "0" => "0"
      2022-04-07 20:15:49.634 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:4,PROCESS,0
      2022-04-07 20:15:49.634 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:4","PROCESS",0]
      2022-04-07 20:15:49.634 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.4.PROCESS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
      2022-04-07 20:15:49.634 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:4,ACTIVITY_STATE,3
      2022-04-07 20:15:49.634 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:4","ACTIVITY_STATE",3]
      2022-04-07 20:15:49.635 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.4.ACTIVITY_STATE ==> UNIT: "undefined" (min: undefined, max: undefined) From "3" => "3"
      2022-04-07 20:15:49.644 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:5,LEVEL,0
      2022-04-07 20:15:49.645 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:5","LEVEL",0]
      2022-04-07 20:15:49.645 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.5.LEVEL ==> UNIT: "100%" (min: 0, max: 1) From "0" => "0"
      2022-04-07 20:15:49.645 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:5,LEVEL_STATUS,0
      2022-04-07 20:15:49.646 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:5","LEVEL_STATUS",0]
      2022-04-07 20:15:49.646 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.5.LEVEL_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
      2022-04-07 20:15:49.646 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:5,SECTION,0
      2022-04-07 20:15:49.647 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:5","SECTION",0]
      2022-04-07 20:15:49.647 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.5.SECTION ==> UNIT: "undefined" (min: 0, max: 15) From "0" => "0"
      2022-04-07 20:15:49.647 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:5,PROCESS,0
      2022-04-07 20:15:49.647 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:5","PROCESS",0]
      2022-04-07 20:15:49.648 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.5.PROCESS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
      2022-04-07 20:15:49.649 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:5,ACTIVITY_STATE,3
      2022-04-07 20:15:49.649 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:5","ACTIVITY_STATE",3]
      2022-04-07 20:15:49.649 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.5.ACTIVITY_STATE ==> UNIT: "undefined" (min: undefined, max: undefined) From "3" => "3"
      2022-04-07 20:15:49.676 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:6,LEVEL,0
      2022-04-07 20:15:49.677 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:6","LEVEL",0]
      2022-04-07 20:15:49.678 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.6.LEVEL ==> UNIT: "100%" (min: 0, max: 1) From "0" => "0"
      2022-04-07 20:15:49.678 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:6,LEVEL_STATUS,0
      2022-04-07 20:15:49.679 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:6","LEVEL_STATUS",0]
      2022-04-07 20:15:49.679 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.6.LEVEL_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
      2022-04-07 20:15:49.679 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:6,SECTION,0
      2022-04-07 20:15:49.681 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:6","SECTION",0]
      2022-04-07 20:15:49.681 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.6.SECTION ==> UNIT: "undefined" (min: 0, max: 15) From "0" => "0"
      2022-04-07 20:15:49.681 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:6,PROCESS,0
      2022-04-07 20:15:49.682 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:6","PROCESS",0]
      2022-04-07 20:15:49.682 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.6.PROCESS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
      2022-04-07 20:15:49.683 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:6,ACTIVITY_STATE,3
      2022-04-07 20:15:49.684 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:6","ACTIVITY_STATE",3]
      2022-04-07 20:15:49.684 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.6.ACTIVITY_STATE ==> UNIT: "undefined" (min: undefined, max: undefined) From "3" => "3"
      2022-04-07 20:15:59.561 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,00085D89B13FCC:0,CONFIG_PENDING,false
      2022-04-07 20:15:59.562 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","00085D89B13FCC:0","CONFIG_PENDING",false]
      2022-04-07 20:15:59.562 - debug: hm-rpc.1 (1169) hm-rpc.1.00085D89B13FCC.0.CONFIG_PENDING ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
      2022-04-07 20:15:59.562 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,00085D89B13FCC:0,UNREACH,false
      2022-04-07 20:15:59.562 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","00085D89B13FCC:0","UNREACH",false]
      2022-04-07 20:15:59.563 - debug: hm-rpc.1 (1169) hm-rpc.1.00085D89B13FCC.0.UNREACH ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
      2022-04-07 20:15:59.563 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,00085D89B13FCC:0,RSSI_DEVICE,-73
      2022-04-07 20:15:59.563 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","00085D89B13FCC:0","RSSI_DEVICE",-73]
      2022-04-07 20:15:59.563 - debug: hm-rpc.1 (1169) hm-rpc.1.00085D89B13FCC.0.RSSI_DEVICE ==> UNIT: "undefined" (min: -128, max: 127) From "-73" => "-73"
      2022-04-07 20:15:59.568 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","00085D89B13FCC:1","PRESS_SHORT",true]
      2022-04-07 20:15:59.569 - debug: hm-rpc.1 (1169) hm-rpc.1.00085D89B13FCC.1.PRESS_SHORT ==> UNIT: "undefined" (min: undefined, max: undefined) From "true" => "true"
      2022-04-07 20:16:00.552 - debug: hm-rpc.1 (1169) xmlrpc -> setValue 2 STATE: true
      2022-04-07 20:16:00.552 - debug: hm-rpc.1 (1169) setValue ["000895699E6B0E:2","STATE",true] BOOL
      2022-04-07 20:16:00.698 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:0,CONFIG_PENDING,false
      2022-04-07 20:16:00.698 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:0","CONFIG_PENDING",false]
      2022-04-07 20:16:00.698 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.0.CONFIG_PENDING ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
      2022-04-07 20:16:00.699 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:0,RSSI_DEVICE,-77
      2022-04-07 20:16:00.699 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:0","RSSI_DEVICE",-77]
      2022-04-07 20:16:00.699 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.0.RSSI_DEVICE ==> UNIT: "undefined" (min: -128, max: 127) From "-77" => "-77"
      2022-04-07 20:16:00.699 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:0,DUTY_CYCLE,false
      2022-04-07 20:16:00.699 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:0","DUTY_CYCLE",false]
      2022-04-07 20:16:00.699 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.0.DUTY_CYCLE ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
      2022-04-07 20:16:00.700 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:0,UNREACH,false
      2022-04-07 20:16:00.700 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:0","UNREACH",false]
      2022-04-07 20:16:00.700 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.0.UNREACH ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
      2022-04-07 20:16:00.700 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:0,RSSI_PEER,-74
      2022-04-07 20:16:00.700 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:0","RSSI_PEER",-74]
      2022-04-07 20:16:00.700 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.0.RSSI_PEER ==> UNIT: "undefined" (min: -128, max: 127) From "-74" => "-74"
      2022-04-07 20:16:00.708 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:2,SECTION_STATUS,0
      2022-04-07 20:16:00.708 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:2","SECTION_STATUS",0]
      2022-04-07 20:16:00.708 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.2.SECTION_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
      2022-04-07 20:16:00.709 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:2,STATE,true
      2022-04-07 20:16:00.709 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:2","STATE",true]
      2022-04-07 20:16:00.709 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.2.STATE ==> UNIT: "undefined" (min: undefined, max: undefined) From "true" => "true"
      2022-04-07 20:16:00.709 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:2,SECTION,2
      2022-04-07 20:16:00.710 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:2","SECTION",2]
      2022-04-07 20:16:00.710 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.2.SECTION ==> UNIT: "undefined" (min: 0, max: 15) From "2" => "2"
      2022-04-07 20:16:00.710 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:2,PROCESS,0
      2022-04-07 20:16:00.710 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:2","PROCESS",0]
      2022-04-07 20:16:00.710 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.2.PROCESS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
      2022-04-07 20:16:01.552 - debug: shuttercontrol.0 (1726) Shutter state changed: Rollladen Küche.LEVEL old value = 100 new value = 0
      2022-04-07 20:16:01.557 - debug: shuttercontrol.0 (1726) Rollladen Küche.LEVEL Old value = 100. New value = 0. automatic is active
      2022-04-07 20:16:04.227 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:0,CONFIG_PENDING,false
      2022-04-07 20:16:04.228 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:0","CONFIG_PENDING",false]
      2022-04-07 20:16:04.228 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.0.CONFIG_PENDING ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
      2022-04-07 20:16:04.228 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:0,RSSI_DEVICE,-84
      2022-04-07 20:16:04.228 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:0","RSSI_DEVICE",-84]
      2022-04-07 20:16:04.228 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.0.RSSI_DEVICE ==> UNIT: "undefined" (min: -128, max: 127) From "-84" => "-84"
      2022-04-07 20:16:04.228 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:0,DUTY_CYCLE,false
      2022-04-07 20:16:04.229 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:0","DUTY_CYCLE",false]
      2022-04-07 20:16:04.229 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.0.DUTY_CYCLE ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
      2022-04-07 20:16:04.231 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:0,UNREACH,false
      2022-04-07 20:16:04.231 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:0","UNREACH",false]
      2022-04-07 20:16:04.231 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.0.UNREACH ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
      2022-04-07 20:16:04.261 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:1,SECTION_STATUS,0
      2022-04-07 20:16:04.262 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:1","SECTION_STATUS",0]
      2022-04-07 20:16:04.262 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.1.SECTION_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
      2022-04-07 20:16:04.262 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:1,STATE,true
      2022-04-07 20:16:04.262 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:1","STATE",true]
      2022-04-07 20:16:04.262 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.1.STATE ==> UNIT: "undefined" (min: undefined, max: undefined) From "true" => "true"
      2022-04-07 20:16:04.262 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:1,SECTION,2
      2022-04-07 20:16:04.262 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:1","SECTION",2]
      2022-04-07 20:16:04.263 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.1.SECTION ==> UNIT: "undefined" (min: 0, max: 15) From "2" => "2"
      2022-04-07 20:16:04.263 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:1,PROCESS,0
      2022-04-07 20:16:04.263 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:1","PROCESS",0]
      2022-04-07 20:16:04.263 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.1.PROCESS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
      2022-04-07 20:16:04.274 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:2,SECTION_STATUS,0
      2022-04-07 20:16:04.274 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:2","SECTION_STATUS",0]
      2022-04-07 20:16:04.274 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.2.SECTION_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
      2022-04-07 20:16:04.275 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:2,STATE,true
      2022-04-07 20:16:04.275 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:2","STATE",true]
      2022-04-07 20:16:04.275 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.2.STATE ==> UNIT: "undefined" (min: undefined, max: undefined) From "true" => "true"
      2022-04-07 20:16:04.275 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:2,SECTION,2
      2022-04-07 20:16:04.275 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:2","SECTION",2]
      2022-04-07 20:16:04.275 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.2.SECTION ==> UNIT: "undefined" (min: 0, max: 15) From "2" => "2"
      2022-04-07 20:16:04.275 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:2,PROCESS,0
      2022-04-07 20:16:04.276 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:2","PROCESS",0]
      2022-04-07 20:16:04.276 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.2.PROCESS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
      2022-04-07 20:16:04.283 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:3,SECTION_STATUS,0
      2022-04-07 20:16:04.283 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:3","SECTION_STATUS",0]
      2022-04-07 20:16:04.283 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.3.SECTION_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
      2022-04-07 20:16:04.284 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:3,STATE,false
      2022-04-07 20:16:04.284 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:3","STATE",false]
      2022-04-07 20:16:04.284 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.3.STATE ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
      2022-04-07 20:16:04.285 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:3,SECTION,0
      2022-04-07 20:16:04.285 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:3","SECTION",0]
      2022-04-07 20:16:04.285 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.3.SECTION ==> UNIT: "undefined" (min: 0, max: 15) From "0" => "0"
      2022-04-07 20:16:04.285 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:3,PROCESS,0
      2022-04-07 20:16:04.285 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:3","PROCESS",0]
      2022-04-07 20:16:04.286 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.3.PROCESS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
      2022-04-07 20:16:04.294 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:4,SECTION_STATUS,0
      2022-04-07 20:16:04.294 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:4","SECTION_STATUS",0]
      2022-04-07 20:16:04.294 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.4.SECTION_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
      2022-04-07 20:16:04.295 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:4,STATE,false
      2022-04-07 20:16:04.295 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:4","STATE",false]
      2022-04-07 20:16:04.295 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.4.STATE ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
      2022-04-07 20:16:04.296 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:4,SECTION,0
      2022-04-07 20:16:04.296 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:4","SECTION",0]
      2022-04-07 20:16:04.297 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.4.SECTION ==> UNIT: "undefined" (min: 0, max: 15) From "0" => "0"
      2022-04-07 20:16:04.297 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:4,PROCESS,0
      2022-04-07 20:16:04.297 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:4","PROCESS",0]
      2022-04-07 20:16:04.298 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.4.PROCESS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
      2022-04-07 20:16:04.344 - debug: shuttercontrol.0 (1726) Shutter state changed: Rollladen Wohnzimmer Terrasse Schiebetür.LEVEL old value = 100 new value = 0
      2022-04-07 20:16:04.345 - debug: shuttercontrol.0 (1726) Rollladen Wohnzimmer Terrasse Schiebetür.LEVEL Old value = 100. New value = 0. automatic is active
      2022-04-07 20:16:05.303 - info: shelly.0 (1251) [CoAP] Device 192.168.229.68 (shellyrgbw2 / shellyrgbw2-1E035D / SHRGBW2#1E035D#1) connected! Polltime set to 5 sec.
      2022-04-07 20:16:10.433 - debug: shuttercontrol.0 (1726) Shutter state changed: Rollladen Wohnzimmer Seite vorn.LEVEL old value = 100 new value = 0
      2022-04-07 20:16:10.434 - debug: shuttercontrol.0 (1726) Rollladen Wohnzimmer Seite vorn.LEVEL Old value = 100. New value = 0. automatic is active
      2022-04-07 20:16:13.455 - debug: shuttercontrol.0 (1726) Shutter state changed: Rollladen Wohnzimmer Seite hinten.LEVEL old value = 100 new value = 0
      2022-04-07 20:16:13.455 - debug: shuttercontrol.0 (1726) Rollladen Wohnzimmer Seite hinten.LEVEL Old value = 100. New value = 0. automatic is active
      2022-04-07 20:16:16.720 - debug: shuttercontrol.0 (1726) Shutter state changed: Rollladen Büro.LEVEL old value = 100 new value = 0
      2022-04-07 20:16:16.720 - debug: shuttercontrol.0 (1726) Rollladen Büro.LEVEL Old value = 100. New value = 0. automatic is active
      2022-04-07 20:16:16.764 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,CONFIG_PENDING,false
      2022-04-07 20:16:16.765 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","CONFIG_PENDING",false]
      2022-04-07 20:16:16.765 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.CONFIG_PENDING ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
      2022-04-07 20:16:16.765 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,DUTY_CYCLE,false
      2022-04-07 20:16:16.766 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","DUTY_CYCLE",false]
      2022-04-07 20:16:16.766 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.DUTY_CYCLE ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
      2022-04-07 20:16:16.766 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,LOW_BAT,false
      2022-04-07 20:16:16.766 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","LOW_BAT",false]
      2022-04-07 20:16:16.766 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.LOW_BAT ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
      2022-04-07 20:16:16.767 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,UNREACH,false
      2022-04-07 20:16:16.767 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","UNREACH",false]
      2022-04-07 20:16:16.767 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.UNREACH ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
      2022-04-07 20:16:16.767 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,RSSI_DEVICE,-79
      2022-04-07 20:16:16.767 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","RSSI_DEVICE",-79]
      2022-04-07 20:16:16.768 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.RSSI_DEVICE ==> UNIT: "undefined" (min: -128, max: 127) From "-79" => "-79"
      2022-04-07 20:16:16.768 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,OPERATING_VOLTAGE_STATUS,0
      2022-04-07 20:16:16.768 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","OPERATING_VOLTAGE_STATUS",0]
      2022-04-07 20:16:16.769 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.OPERATING_VOLTAGE_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
      2022-04-07 20:16:16.769 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,OPERATING_VOLTAGE,3
      2022-04-07 20:16:16.769 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","OPERATING_VOLTAGE",3]
      2022-04-07 20:16:16.769 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.OPERATING_VOLTAGE ==> UNIT: "undefined" (min: 0, max: 25.2) From "3" => "3"
      2022-04-07 20:16:16.769 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,ERROR_CODE,0
      2022-04-07 20:16:16.770 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","ERROR_CODE",0]
      2022-04-07 20:16:16.770 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.ERROR_CODE ==> UNIT: "undefined" (min: 0, max: 255) From "0" => "0"
      2022-04-07 20:16:16.779 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:3,MOTION,false
      2022-04-07 20:16:16.780 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:3","MOTION",false]
      2022-04-07 20:16:16.780 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.3.MOTION ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
      2022-04-07 20:16:16.780 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:3,ILLUMINATION,0.1
      2022-04-07 20:16:16.781 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:3","ILLUMINATION",0.1]
      2022-04-07 20:16:16.781 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.3.ILLUMINATION ==> UNIT: "undefined" (min: 0, max: 163830) From "0.1" => "0.1"
      2022-04-07 20:16:16.781 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:3,ILLUMINATION_STATUS,0
      2022-04-07 20:16:16.781 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:3","ILLUMINATION_STATUS",0]
      2022-04-07 20:16:16.782 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.3.ILLUMINATION_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
      2022-04-07 20:16:16.782 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:3,MOTION_DETECTION_ACTIVE,true
      2022-04-07 20:16:16.782 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:3","MOTION_DETECTION_ACTIVE",true]
      2022-04-07 20:16:16.783 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.3.MOTION_DETECTION_ACTIVE ==> UNIT: "undefined" (min: undefined, max: undefined) From "true" => "true"
      2022-04-07 20:16:17.660 - info: host.SmarthomeRaspi instance system.adapter.mihome-vacuum.0 started with pid 17770
      2022-04-07 20:16:19.313 - debug: mihome-vacuum.0 (17770) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2022-04-07 20:16:19.408 - debug: mihome-vacuum.0 (17770) Objects client ready ... initialize now
      2022-04-07 20:16:19.411 - debug: mihome-vacuum.0 (17770) Objects create System PubSub Client
      2022-04-07 20:16:19.414 - debug: mihome-vacuum.0 (17770) Objects create User PubSub Client
      2022-04-07 20:16:19.544 - debug: mihome-vacuum.0 (17770) Objects client initialize lua scripts
      2022-04-07 20:16:19.552 - debug: mihome-vacuum.0 (17770) Objects connected to redis: 127.0.0.1:9001
      2022-04-07 20:16:19.621 - debug: mihome-vacuum.0 (17770) Redis States: Use Redis connection: 127.0.0.1:9000
      2022-04-07 20:16:19.685 - debug: mihome-vacuum.0 (17770) States create System PubSub Client
      2022-04-07 20:16:19.687 - debug: mihome-vacuum.0 (17770) States create User PubSub Client
      2022-04-07 20:16:19.818 - debug: mihome-vacuum.0 (17770) States connected to redis: 127.0.0.1:9000
      2022-04-07 20:16:20.215 - debug: mihome-vacuum.0 (17770) Plugin sentry Initialize Plugin (enabled=true)
      2022-04-07 20:16:20.629 - info: mihome-vacuum.0 (17770) starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.19.1, js-controller: 4.0.21
      2022-04-07 20:16:20.719 - debug: mihome-vacuum.0 (17770) load Map creator... true
      2022-04-07 20:16:20.754 - debug: mihome-vacuum.0 (17770) Create State for deviceInfo
      2022-04-07 20:16:20.755 - debug: mihome-vacuum.0 (17770) Create State for deviceInfomac
      2022-04-07 20:16:20.756 - debug: mihome-vacuum.0 (17770) Create State for deviceInfomodel
      2022-04-07 20:16:20.757 - debug: mihome-vacuum.0 (17770) Create State for deviceInfofw_ver
      2022-04-07 20:16:20.762 - debug: mihome-vacuum.0 (17770) Create State for deviceInfowifi_signal
      2022-04-07 20:16:20.764 - debug: mihome-vacuum.0 (17770) MIIO: Config: ip:192.168.229.31 token: 6a62485744456c466c766f6d45535473
      2022-04-07 20:16:20.771 - info: mihome-vacuum.0 (17770) IOT enabled, create state
      2022-04-07 20:16:20.779 - debug: mihome-vacuum.0 (17770) server started on 0.0.0.0:53421
      2022-04-07 20:16:20.789 - debug: mihome-vacuum.0 (17770) Receive <<< Helo <<< 21310020000000001317ff30624f2a75ffffffffffffffffffffffffffffffff
      2022-04-07 20:16:20.790 - debug: mihome-vacuum.0 (17770) MAIN: Connected to device, try to get model..
      2022-04-07 20:16:20.794 - debug: mihome-vacuum.0 (17770) Time difference between Mihome Vacuum and ioBroker: 1 sec
      2022-04-07 20:16:20.797 - debug: mihome-vacuum.0 (17770) GETMODELFROMAPI: objModel: {"val":"roborock.vacuum.s5e","ack":true,"ts":1649355344903,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1649165771511}
      2022-04-07 20:16:20.799 - debug: mihome-vacuum.0 (17770) Message= {"id":1,"method":"miIO.info"}
      2022-04-07 20:16:22.803 - debug: mihome-vacuum.0 (17770) MIIO Receive Timeout for "miIO.info" <<<
      2022-04-07 20:16:22.804 - debug: mihome-vacuum.0 (17770) Get Device data..0
      • DiginixD Offline
        DiginixD Offline
        Diginix
        schrieb am zuletzt editiert von Diginix
        #823
        Funktioniert bei irgendwem mit 3.3.x noch spotclean?
        Wenn ich mihome-vacuum.0.control.spotclean auf true setze, bekomme ich nur folgende Logmeldung:
        2022-04-09 19:57:06.399 - warn: mihome-vacuum.0 (363741) Cant send command please try again "spotclean"
        Git issue: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues/556
        ..:: So long! Tom ::..
          saeft_2003
          #824
          Hat schon jemand den S7 MaxV mit dem Adapter laufen?
          Meine Ultra ist heute gekommen 😬
          @Meistertr
          Kannst du sagen ob der Adapter den S7 MaxV und evtl. die Ultrastation unterstützt?!
            saeft_2003
            #825
            @Meistertr
            Der S7 MaxV läuft soweit mit dem Adapter.
            Bekommt man auch die rot markierten Infos der Ultra Station in den iobroker?
              saeft_2003
              schrieb am zuletzt editiert von saeft_2003
              #826
              Hat irgendjemand von euch den S7 MaxV mit dem Adapter laufen? Geht bei euch der multiroomclean?
              @Meistertr
              Edit: Der Multiroomclean geht nur beim Saugen, wenn auch gewischt wird bringt die Ultra Station das ganze durcheinander. Ich habe es hier auf github beschrieben...
              https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues/570#issue-1221908175
              • S saeft_2003
                @Meistertr
                D Nicht stören
                D Nicht stören
                dirkhe
                #827
                @saeft_2003 ich habe gestern mal reingeschaut, ich denke die erweiterten stati sollte man hinbekommen. Icn würde da jetzt auf guthub mit dir die lösung testen wollen und nicht hier, wenn es ok ist.
                • D dirkhe
                  saeft_2003
                  #828
                  @dirkhe
                  Alles klar machen wir so 👍
                  • DiginixD Offline
                    DiginixD Offline
                    Diginix
                    #829
                    @dirkhe Kannst du vllt auch was hier zu sagen bzw hast eine Idee? https://forum.iobroker.net/post/789063
                    Hier als issue mit debug Log: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues/556
                    Das ging alles mal mit meinem Modell und dem Adapter. Entw. im Adapter ist was "verloren" gegangen oder die API hat sich geändert.
                      Spezialtrick
                      #830
                      Besteht die Möglichkeit den Dream z10 Pro als neues Gerät im Adapter zu unterstützen? Ich habe bereits ein Issue im Github angelegt.
                      Der Dreame L10 Pro wird bereits unterstützt und ist im Grunde das gleiche Gerät wie der z10 Pro nur ohne Absaugstation. Möglicherweise ist die Einbindung daher einfach?
                        saeft_2003
                        #831
                        Ich brauche eure Hilfe. Und zwar will ich per custom command eine Raumreinigung starten. Der Befehl
                        cleansegments;[18,20]
                        Funktioniert leider nicht. Könnt ihr mir sagen wie genau der aussehen muss?
                        • S saeft_2003
                          DiginixD Offline
                          DiginixD Offline
                          Diginix
                          #832
                          @saeft_2003 Als ich das noch verwendet habe war es:
                          app_segment_clean;[20]
                          Die ID ist der mapindes des Raumes aus mihome-vacuum.0.rooms.*.mapIndex und es können kommasepariert mehrere ins Array.
                          • DiginixD Diginix
                            saeft_2003
                            #833
                            @diginix
                            Super das funktioniert 👍
                              Rushmed
                              #834
                              Meine Instanz zeigt seit Neustem mehrmals täglich diese Fehlermeldung:
                              mihome-vacuum.0
                              2022-05-28 01:10:44.883	error	Error by saving of the map
                              mihome-vacuum.0
                              2022-05-28 01:10:44.882	error	Cannot write file actualMap_0.png: mihome-vacuum.admin is not an object of type "meta"
                              Was kann ich dagegen tun?
                              R 1 Antwort Letzte Antwort
                                saeft_2003
                                #835
                                An alle Ultra Besitzer:
                                Es gibt jetzt eine Version vom Adapter die anzeigt ob das Wasser von der Ultra Station leer ist oder nicht. Wurde von mir getestet und funktioniert 👍
                                https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tree/584-ultra-station-meldung-wenn-wasser-leer
                                • D Nicht stören
                                  D Nicht stören
                                  dirkhe
                                  #836
                                  @saeft_2003 ist schon released, 3.4.0
                                  S S 2 Antworten Letzte Antwort
                                  • D dirkhe
                                    Spezialtrick
                                    #837
                                    @dirkhe Hallo Dirk, besteht die Möglichkeit den Dream z10 Pro als neues Gerät im Adapter zu unterstützen? Ich habe bereits ein Issue im Github angelegt.
                                    • S Spezialtrick
                                      D Nicht stören
                                      D Nicht stören
                                      dirkhe
                                      #838
                                      @spezialtrick neue hardware hinzuzufügen, ohne sie selber zu besitzen, ust immer schwierig. Ich weiß auch nicht, wie meisterTr das immer gemacht hat. Funktioniert er den grundsätzlich mit dem adapter und es fehlen einzelne feature?
                                      Wenn ich mir den issue so ansehe, scheint der ja komplett neu zu sein.
                                      • D dirkhe
                                        Spezialtrick
                                        schrieb am zuletzt editiert von Spezialtrick
                                        #839
                                        @dirkhe Ich bekomme die Meldung, dass das Gerät nicht unterstützt wird:
                                        Auf meinem Dreame läuft Valetudo.
                                        • S Spezialtrick
                                          da_WoodyD Offline
                                          da_WoodyD Offline
                                          da_Woody
                                          #840
                                          @spezialtrick das das gerät nicht unterstütz wird, sehe ich bei meinem roborocks6 auch immer wieder. trotzdem funktioniert der astrein.
                                          meine aber, daß irgendwo stand, daß valentudo nicht mehr unterstützt wird...
                                          gruß vom Woody
