  4. Test Adapter Mihome-vacuum v3.1.6 Next Generarition
    6.6k
1.2k Beiträge 100 Kommentatoren 503.7k Aufrufe 82 Beobachtet
    @tobiasf78
    Ja, macht aber wenig Sinn, es wird der Kontext benötigt.
    TobiasF78
    #820
    das log zum Start des Reinigungsvorgangs
    2022-04-07 20:11:03.686 - debug: mihome-vacuum.0 (17152) Receive <<< Helo <<< 21310020000000001317ff30624f2938ffffffffffffffffffffffffffffffff
    2022-04-07 20:11:03.687 - debug: mihome-vacuum.0 (17152) Time difference between Mihome Vacuum and ioBroker: 1 sec
    2022-04-07 20:11:13.690 - debug: mihome-vacuum.0 (17152) Receive <<< Helo <<< 21310020000000001317ff30624f2942ffffffffffffffffffffffffffffffff
    2022-04-07 20:11:13.691 - debug: mihome-vacuum.0 (17152) Time difference between Mihome Vacuum and ioBroker: 1 sec
    2022-04-07 20:11:17.217 - debug: mihome-vacuum.0 (17152) get params for stock Vacuum
    2022-04-07 20:11:17.219 - debug: mihome-vacuum.0 (17152) Message= {"id":69,"method":"get_status"}
    2022-04-07 20:11:17.228 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":3477,"state":18,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":101,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0}],"id":69}
    2022-04-07 20:11:17.233 - debug: mihome-vacuum.0 (17152) setGetStatus {"msg_ver":2,"msg_seq":3477,"state":18,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":101,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"error_text":"No error"}
    2022-04-07 20:11:17.237 - debug: mihome-vacuum.0 (17152) Message= {"id":70,"method":"get_map_v1"}
    2022-04-07 20:11:17.239 - debug: mihome-vacuum.0 (17152) Message= {"id":71,"method":"get_network_info"}
    2022-04-07 20:11:17.254 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":["retry"],"id":70}
    2022-04-07 20:11:17.266 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":{"ssid":"froehlich.unifi","ip":"192.168.229.31","mac":"64:90:c1:01:fb:13","bssid":"4a:d9:e7:fa:7f:d0","rssi":-49},"id":71}
    2022-04-07 20:11:17.382 - debug: mihome-vacuum.0 (17152) Message= {"id":72,"method":"get_sound_volume"}
    2022-04-07 20:11:17.388 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":[30],"id":72}
    2022-04-07 20:11:17.389 - debug: mihome-vacuum.0 (17152) Message= {"id":73,"method":"get_carpet_mode"}
    2022-04-07 20:11:17.395 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":73}
    2022-04-07 20:11:17.557 - debug: mihome-vacuum.0 (17152) Message= {"id":74,"method":"get_map_v1"}
    2022-04-07 20:11:17.563 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":["retry"],"id":74}
    2022-04-07 20:11:17.866 - debug: mihome-vacuum.0 (17152) Message= {"id":75,"method":"get_map_v1"}
    2022-04-07 20:11:17.871 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":["retry"],"id":75}
    2022-04-07 20:11:18.172 - debug: mihome-vacuum.0 (17152) Message= {"id":76,"method":"get_map_v1"}
    2022-04-07 20:11:18.179 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":["retry"],"id":76}
    2022-04-07 20:11:18.480 - debug: mihome-vacuum.0 (17152) Message= {"id":77,"method":"get_map_v1"}
    2022-04-07 20:11:18.488 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":["retry"],"id":77}
    2022-04-07 20:11:20.165 - info: javascript.0 (4683) script.js.Rollläden.Helligkeit_Durchschnittswert: [15,17,20,23,26,30,34,39,44,50,57,65,73,83,94,106,119,134,151,170,191,215,245,275,309,275,313,353,399,350]
    2022-04-07 20:11:20.189 - debug: shuttercontrol.0 (1726) Lightsensor changed: 0_userdata.0.Rollladen.Helligkeit_Durchschnitt Value: 143
    2022-04-07 20:11:20.791 - debug: mihome-vacuum.0 (17152) Get Mappointer while cleaning
    2022-04-07 20:11:20.792 - debug: mihome-vacuum.0 (17152) Message= {"id":78,"method":"get_map_v1"}
    2022-04-07 20:11:20.800 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":["rubyslite%2F320339760%2F0"],"id":78}
    2022-04-07 20:11:20.801 - debug: mihome-vacuum.0 (17152) Mappointer_updated
    2022-04-07 20:11:20.804 - debug: mihome-vacuum.0 (17152) update_Map Mimap enabled
    2022-04-07 20:11:20.805 - debug: mihome-vacuum.0 (17152) update_Map need new mapurl
    2022-04-07 20:11:21.030 - debug: mihome-vacuum.0 (17152) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320339760/0?Expires=1649356881000&GalaxyAccessKeyId=5271733786445&Signature=JkhvPTmkB1NFoq+B3JmwCidC99E=
    2022-04-07 20:11:21.030 - debug: mihome-vacuum.0 (17152) update_Map got new expires:1649356881
    2022-04-07 20:11:21.031 - debug: mihome-vacuum.0 (17152) update_Map got new time:1649355080
    2022-04-07 20:11:21.538 - debug: mihome-vacuum.0 (17152) 25609
    2022-04-07 20:11:23.696 - debug: mihome-vacuum.0 (17152) Receive <<< Helo <<< 21310020000000001317ff30624f294cffffffffffffffffffffffffffffffff
    2022-04-07 20:11:23.697 - debug: mihome-vacuum.0 (17152) Time difference between Mihome Vacuum and ioBroker: 1 sec
    2022-04-07 20:11:24.575 - debug: mihome-vacuum.0 (17152) Get Mappointer while cleaning
    2022-04-07 20:11:24.576 - debug: mihome-vacuum.0 (17152) Message= {"id":79,"method":"get_map_v1"}
    2022-04-07 20:11:24.583 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":["rubyslite%2F320339760%2F3"],"id":79}
    2022-04-07 20:11:24.584 - debug: mihome-vacuum.0 (17152) Mappointer_updated
    2022-04-07 20:11:24.584 - debug: mihome-vacuum.0 (17152) update_Map Mimap enabled
    2022-04-07 20:11:24.585 - debug: mihome-vacuum.0 (17152) update_Map need new mapurl
    2022-04-07 20:11:24.754 - debug: mihome-vacuum.0 (17152) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320339760/3?Expires=1649356884000&GalaxyAccessKeyId=5271733786445&Signature=JeC2mvYHId0bO95JgWd8AJHM5ig=
    2022-04-07 20:11:24.755 - debug: mihome-vacuum.0 (17152) update_Map got new expires:1649356884
    2022-04-07 20:11:24.757 - debug: mihome-vacuum.0 (17152) update_Map got new time:1649355084
    2022-04-07 20:11:25.368 - debug: mihome-vacuum.0 (17152) 25751
    2022-04-07 20:11:27.898 - debug: mihome-vacuum.0 (17152) Get Mappointer while cleaning
    2022-04-07 20:11:27.899 - debug: mihome-vacuum.0 (17152) Message= {"id":80,"method":"get_map_v1"}
    2022-04-07 20:11:27.906 - debug: mihome-vacuum.0 (17152) MIIO RECIVE: {"result":["rubyslite%2F320339760%2F4"],"id":80}
    2022-04-07 20:11:27.907 - debug: mihome-vacuum.0 (17152) Mappointer_updated
    2022-04-07 20:11:27.907 - debug: mihome-vacuum.0 (17152) update_Map Mimap enabled
    2022-04-07 20:11:27.907 - debug: mihome-vacuum.0 (17152) update_Map need new mapurl
    2022-04-07 20:11:28.059 - debug: mihome-vacuum.0 (17152) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320339760/4?Expires=1649356888000&GalaxyAccessKeyId=5271733786445&Signature=pxITU76k0a7x/gZU3EzewZ3Akwo=
    2022-04-07 20:11:28.059 - debug: mihome-vacuum.0 (17152) update_Map got new expires:1649356888
    2022-04-07 20:11:28.060 - debug: mihome-vacuum.0 (17152) update_Map got new time:1649355087
    2022-04-07 20:11:28.629 - debug: mihome-vacuum.0 (17152) 25909
    2022-04-07 20:11:28.864 - warn: host.SmarthomeRaspi instance system.adapter.mihome-vacuum.0 terminated due to SIGSEGV
    2022-04-07 20:11:28.865 - info: host.SmarthomeRaspi instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
    2022-04-07 20:11:28.865 - info: host.SmarthomeRaspi Restart adapter system.adapter.mihome-vacuum.0 because enabled
    2022-04-07 20:11:40.493 - info: unifi.0 (2213) State value to set for "unifi.0.default.clients.ae:2d:74:9e:b6:86.noted" has to be type "boolean" but received type "string"
    2022-04-07 20:11:40.621 - info: unifi.0 (2213) State value to set for "unifi.0.default.clients.94:e7:0b:61:00:58.noted" has to be type "boolean" but received type "string"
    2022-04-07 20:11:51.834 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0019DA49A70E58:0,CONFIG_PENDING,false
    2022-04-07 20:11:51.834 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0019DA49A70E58:0","CONFIG_PENDING",false]
    2022-04-07 20:11:51.834 - debug: hm-rpc.1 (1169) hm-rpc.1.0019DA49A70E58.0.CONFIG_PENDING ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
    2022-04-07 20:11:51.835 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0019DA49A70E58:0,RSSI_DEVICE,-72
    2022-04-07 20:11:51.835 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0019DA49A70E58:0","RSSI_DEVICE",-72]
    2022-04-07 20:11:51.835 - debug: hm-rpc.1 (1169) hm-rpc.1.0019DA49A70E58.0.RSSI_DEVICE ==> UNIT: "undefined" (min: -128, max: 127) From "-72" => "-72"
    2022-04-07 20:11:51.835 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0019DA49A70E58:0,DUTY_CYCLE,false
    2022-04-07 20:11:51.835 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0019DA49A70E58:0","DUTY_CYCLE",false]
    2022-04-07 20:11:51.836 - debug: hm-rpc.1 (1169) hm-rpc.1.0019DA49A70E58.0.DUTY_CYCLE ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
    2022-04-07 20:11:51.836 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0019DA49A70E58:0,UNREACH,false
    2022-04-07 20:11:51.836 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0019DA49A70E58:0","UNREACH",false]
    2022-04-07 20:11:51.836 - debug: hm-rpc.1 (1169) hm-rpc.1.0019DA49A70E58.0.UNREACH ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
    2022-04-07 20:11:53.009 - debug: hm-rpc.0 (1147) xml multicall : SmarthomeRaspi:hm-rpc.0:86e5c28de60614468b710549803c5777,NEQ0862527:1,BOOT,false
    2022-04-07 20:11:53.010 - debug: hm-rpc.0 (1147) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.0:86e5c28de60614468b710549803c5777","NEQ0862527:1","BOOT",false]
    2022-04-07 20:11:53.011 - debug: hm-rpc.0 (1147) hm-rpc.0.NEQ0862527.1.BOOT ==> UNIT: "" (min: undefined, max: undefined) From "false" => "false"
    2022-04-07 20:11:53.012 - debug: hm-rpc.0 (1147) xml multicall : SmarthomeRaspi:hm-rpc.0:86e5c28de60614468b710549803c5777,NEQ0862527:1,ENERGY_COUNTER,562640
    2022-04-07 20:11:53.013 - debug: hm-rpc.0 (1147) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.0:86e5c28de60614468b710549803c5777","NEQ0862527:1","ENERGY_COUNTER",562640]
    2022-04-07 20:11:53.013 - debug: hm-rpc.0 (1147) hm-rpc.0.NEQ0862527.1.ENERGY_COUNTER ==> UNIT: "Wh" (min: 0, max: 838860.7) From "562640" => "562640"
    2022-04-07 20:11:53.014 - debug: hm-rpc.0 (1147) xml multicall : SmarthomeRaspi:hm-rpc.0:86e5c28de60614468b710549803c5777,NEQ0862527:1,POWER,252
    2022-04-07 20:11:53.015 - debug: hm-rpc.0 (1147) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.0:86e5c28de60614468b710549803c5777","NEQ0862527:1","POWER",252]
    2022-04-07 20:11:53.016 - debug: hm-rpc.0 (1147) hm-rpc.0.NEQ0862527.1.POWER ==> UNIT: "W" (min: 0, max: 167772.15) From "252" => "252"
    2022-04-07 20:11:59.312 - info: host.SmarthomeRaspi instance system.adapter.mihome-vacuum.0 started with pid 17390
    2022-04-07 20:12:00.918 - debug: mihome-vacuum.0 (17390) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2022-04-07 20:12:00.999 - debug: mihome-vacuum.0 (17390) Objects client ready ... initialize now
    2022-04-07 20:12:01.002 - debug: mihome-vacuum.0 (17390) Objects create System PubSub Client
    2022-04-07 20:12:01.003 - debug: mihome-vacuum.0 (17390) Objects create User PubSub Client
    2022-04-07 20:12:01.153 - debug: mihome-vacuum.0 (17390) Objects client initialize lua scripts
    2022-04-07 20:12:01.160 - debug: mihome-vacuum.0 (17390) Objects connected to redis: 127.0.0.1:9001
    2022-04-07 20:12:01.227 - debug: mihome-vacuum.0 (17390) Redis States: Use Redis connection: 127.0.0.1:9000
    2022-04-07 20:12:01.269 - debug: mihome-vacuum.0 (17390) States create System PubSub Client
    2022-04-07 20:12:01.271 - debug: mihome-vacuum.0 (17390) States create User PubSub Client
    2022-04-07 20:12:01.358 - debug: mihome-vacuum.0 (17390) States connected to redis: 127.0.0.1:9000
    2022-04-07 20:12:01.640 - debug: mihome-vacuum.0 (17390) Plugin sentry Initialize Plugin (enabled=true)
    2022-04-07 20:12:02.117 - info: mihome-vacuum.0 (17390) starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.19.1, js-controller: 4.0.21
    2022-04-07 20:12:02.207 - debug: mihome-vacuum.0 (17390) load Map creator... true
    2022-04-07 20:12:02.240 - debug: mihome-vacuum.0 (17390) Create State for deviceInfo
    2022-04-07 20:12:02.241 - debug: mihome-vacuum.0 (17390) Create State for deviceInfomac
    2022-04-07 20:12:02.241 - debug: mihome-vacuum.0 (17390) Create State for deviceInfomodel
    2022-04-07 20:12:02.242 - debug: mihome-vacuum.0 (17390) Create State for deviceInfofw_ver
    2022-04-07 20:12:02.243 - debug: mihome-vacuum.0 (17390) Create State for deviceInfowifi_signal
    2022-04-07 20:12:02.244 - debug: mihome-vacuum.0 (17390) MIIO: Config: ip:192.168.229.31 token: 6a62485744456c466c766f6d45535473
    2022-04-07 20:12:02.248 - info: mihome-vacuum.0 (17390) IOT enabled, create state
    2022-04-07 20:12:02.253 - debug: mihome-vacuum.0 (17390) server started on 0.0.0.0:53421
    2022-04-07 20:12:02.262 - debug: mihome-vacuum.0 (17390) Receive <<< Helo <<< 21310020000000001317ff30624f2972ffffffffffffffffffffffffffffffff
    2022-04-07 20:12:02.263 - debug: mihome-vacuum.0 (17390) MAIN: Connected to device, try to get model..
    2022-04-07 20:12:02.270 - debug: mihome-vacuum.0 (17390) GETMODELFROMAPI: objModel: {"val":"roborock.vacuum.s5e","ack":true,"ts":1649354893615,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1649165771511}
    2022-04-07 20:12:02.272 - debug: mihome-vacuum.0 (17390) Message= {"id":1,"method":"miIO.info"}
    2022-04-07 20:12:02.280 - debug: mihome-vacuum.0 (17390) MIIO RECIVE: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_1566","ap":{"ssid":"froehlich.unifi","bssid":"4a:d9:e7:fa:7f:d0","rssi":-48},"netif":{"localIp":"192.168.229.31","mask":"255.255.255.0","gw":"192.168.229.1"},"miio_ver":"miio-client 3.5.8","model":"roborock.vacuum.s5e","mac":"64:90:C1:01:FB:13","token":"6a62485744456c466c766f6d45535473","life":59894}}
    2022-04-07 20:12:02.281 - debug: mihome-vacuum.0 (17390) GETMODELFROMAPI:Data: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_1566","ap":{"ssid":"froehlich.unifi","bssid":"4a:d9:e7:fa:7f:d0","rssi":-48},"netif":{"localIp":"192.168.229.31","mask":"255.255.255.0","gw":"192.168.229.1"},"miio_ver":"miio-client 3.5.8","model":"roborock.vacuum.s5e","mac":"64:90:C1:01:FB:13","token":"6a62485744456c466c766f6d45535473","life":59894}}
    2022-04-07 20:12:02.281 - debug: mihome-vacuum.0 (17390) Get Device data..0
    2022-04-07 20:12:02.282 - debug: mihome-vacuum.0 (17390) Get Device data from robot..
    2022-04-07 20:12:02.356 - debug: mihome-vacuum.0 (17390) DeviceModel selected to: roborock.vacuum.s5e
    2022-04-07 20:12:02.358 - info: mihome-vacuum.0 (17390) select standard vacuum protocol....
    2022-04-07 20:12:02.364 - debug: mihome-vacuum.0 (17390) Xiaomi Cloud: Logging in
    2022-04-07 20:12:02.430 - debug: mihome-vacuum.0 (17390) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    2022-04-07 20:12:02.671 - debug: mihome-vacuum.0 (17390) Login step1: &&&START&&&{"serviceParam":"{\"checkSafePhone\":false,\"checkSafeAddress\":false,\"lsrp_score\":0.0}","qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","code":70016,"description":"登录验证失败","securityStatus":0,"_sign":"0psXfr43eNI0IX6q9Suk3qWbRqU=","sid":"xiaomiio","result":"error","captchaUrl":null,"callback":"https://sts.api.io.mi.com/sts","location":"https://account.xiaomi.com/fe/service/login?_json=true&sid=xiaomiio&qs=%253Fsid%253Dxiaomiio%2526_json%253Dtrue&callback=https%3A%2F%2Fsts.api.io.mi.com%2Fsts&_sign=0psXfr43eNI0IX6q9Suk3qWbRqU%3D&serviceParam=%7B%22checkSafePhone%22%3Afalse%2C%22checkSafeAddress%22%3Afalse%2C%22lsrp_score%22%3A0.0%7D&showActiveX=false&theme=&needTheme=false&bizDeviceType=","pwd":0,"desc":"登录验证失败"}
    2022-04-07 20:12:02.948 - debug: mihome-vacuum.0 (17390) Login step2: &&&START&&&{"qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","ssecurity":"tE7q7k02rgKQ42yy2WalqA==","code":0,"passToken":"V1:DXmurwq2/R1BHTELu6obCXvd/vywyWq/UW16QZKE2LY36WsipSmLX8xvdc9l4OQkwWYESIe+Rc2goHwDTHdGYGBJKS+Vnufh9+l/x+Gdlr8m8Vzva4JSnhMtAcOnzTCXZnvZCqxjqLueX5qS0HeAtHdHLcIxgIMJquyX9PuPJCqYaIMpCRhCPzC7tLG5dMVoYGZBkjWt6p+HYlkkuPlDUrXZ/MQUNu3UFWFRjUm/zJj92wwKldCgRNOJTBTe+YhWPM/AhoND4EJ8vymQOkCnmFTdbvAfpe/yO+7FrM/0jyQ=","description":"成功","securityStatus":0,"nonce":5937468700529491968,"userId":8161011682,"cUserId":"d7BvRzpJp2fIp_BmYH4fXAU23E8","result":"ok","psecurity":"SLnzQYnjD1y92+AtNj1WIA==","captchaUrl":null,"location":"https://sts.api.io.mi.com/sts?d=hcvyd&ticket=0&pwd=1&p_ts=1649355122000&fid=0&p_lm=1&auth=EIZ7Zp2Kjae53RtQ1qPkDDdDyYz%2B%2B%2BLPCf35MeIhU%2BDPuJ7g3zbcoUrpIKZpX9Hb9XMNIDfW5LX45JH%2FUZLyO8POuYUg7x2Bn49fd6vuJkNR9pH9tdOwOEfsP9nOwaaA6fbAvQW8KUWnLcQSsOzopEdWXUBtT340qhGEWsuKdlw%3D&m=1&tsl=0&nonce=3aPnnH6vLo0Bo3Pk&_ssign=OvZlP59LAGWExkueSkOSI5HqXGU%3D","pwd":1,"desc":"成功"}
    2022-04-07 20:12:03.141 - info: mihome-vacuum.0 (17390) settest next timer: not available
    2022-04-07 20:12:03.279 - debug: mihome-vacuum.0 (17390) Login step3: [{"key":"userId","value":"8161011682","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-04-07T18:12:03.250Z","lastAccessed":"2022-04-07T18:12:03.278Z"},{"key":"cUserId","value":"d7BvRzpJp2fIp_BmYH4fXAU23E8","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-04-07T18:12:03.264Z","lastAccessed":"2022-04-07T18:12:03.278Z"},{"key":"serviceToken","value":"pE4bcLhDVytuM1iPXebrZ6dawOhvMI6QrHgeacnK/IrLVvbWt8PtRK2CBnZ/y6F6SctDx7G6lg2nN3V+ofLBhZdoyrAz0Li4CctGekhhu04aKOHlS5kzgukNiRolAoxADIopSqiTlcFY76PCK41ARVw1QrvNnrvajb9pGkRQTgo=","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-04-07T18:12:03.270Z","lastAccessed":"2022-04-07T18:12:03.278Z"}]
    2022-04-07 20:12:03.280 - debug: mihome-vacuum.0 (17390) Xiaomi Cloud: Login successful
    2022-04-07 20:12:03.301 - debug: mihome-vacuum.0 (17390) Create State for Queue: queue
    2022-04-07 20:12:03.302 - debug: mihome-vacuum.0 (17390) Create State for Queue: clearQueue
    2022-04-07 20:12:03.306 - info: mihome-vacuum.0 (17390) Map selected create states...
    2022-04-07 20:12:03.309 - debug: mihome-vacuum.0 (17390) Create State for map:
    2022-04-07 20:12:03.310 - debug: mihome-vacuum.0 (17390) Create State for map: map64
    2022-04-07 20:12:03.311 - debug: mihome-vacuum.0 (17390) Create State for map: actualMap
    2022-04-07 20:12:03.313 - debug: mihome-vacuum.0 (17390) Create State for map: mapStatus
    2022-04-07 20:12:03.314 - debug: mihome-vacuum.0 (17390) Create State for map: mapURL
    2022-04-07 20:12:03.315 - debug: mihome-vacuum.0 (17390) Create State for map: loadMap
    2022-04-07 20:12:03.315 - debug: mihome-vacuum.0 (17390) Create State done!
    2022-04-07 20:12:03.316 - debug: mihome-vacuum.0 (17390) get params for stock Vacuum
    2022-04-07 20:12:03.317 - debug: mihome-vacuum.0 (17390) Message= {"id":2,"method":"get_status"}
    2022-04-07 20:12:03.326 - debug: mihome-vacuum.0 (17390) MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":3481,"state":18,"battery":100,"clean_time":51,"clean_area":1615000,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":101,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0}],"id":2}
    2022-04-07 20:12:03.327 - debug: mihome-vacuum.0 (17390) setGetStatus {"msg_ver":2,"msg_seq":3481,"state":18,"battery":100,"clean_time":51,"clean_area":1615000,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":101,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"error_text":"No error"}
    2022-04-07 20:12:03.328 - info: mihome-vacuum.0 (17390) change states from State control.fan_power
    2022-04-07 20:12:03.342 - info: mihome-vacuum.0 (17390) create states for water box
    2022-04-07 20:12:03.345 - info: mihome-vacuum.0 (17390) create states for water box mode
    2022-04-07 20:12:03.348 - info: mihome-vacuum.0 (17390) create states for mop
    2022-04-07 20:12:03.419 - debug: mihome-vacuum.0 (17390) Message= {"id":3,"method":"get_map_v1"}
    2022-04-07 20:12:03.426 - debug: mihome-vacuum.0 (17390) MIIO RECIVE: {"result":["retry"],"id":3}
    2022-04-07 20:12:03.728 - debug: mihome-vacuum.0 (17390) Message= {"id":4,"method":"get_map_v1"}
    2022-04-07 20:12:03.736 - debug: mihome-vacuum.0 (17390) MIIO RECIVE: {"result":["rubyslite%2F320339760%2F6"],"id":4}
    2022-04-07 20:12:03.738 - debug: mihome-vacuum.0 (17390) Mappointer_updated
    2022-04-07 20:12:03.740 - debug: mihome-vacuum.0 (17390) update_Map Mimap enabled
    2022-04-07 20:12:03.741 - debug: mihome-vacuum.0 (17390) update_Map need new mapurl
    2022-04-07 20:12:03.753 - debug: mihome-vacuum.0 (17390) Message= {"id":5,"method":"get_room_mapping"}
    2022-04-07 20:12:03.765 - debug: mihome-vacuum.0 (17390) MIIO RECIVE: {"result":[[20,"281001038309"],[16,"281001038371"],[17,"281001038308"],[18,"281001038310"],[19,"281001038295"]],"id":5}
    2022-04-07 20:12:03.769 - debug: mihome-vacuum.0 (17390) Message= {"id":6,"method":"get_map_v1"}
    2022-04-07 20:12:03.771 - debug: mihome-vacuum.0 (17390) Message= {"id":7,"method":"get_network_info"}
    2022-04-07 20:12:03.779 - debug: mihome-vacuum.0 (17390) MIIO RECIVE: {"result":["rubyslite%2F320339760%2F6"],"id":6}
    2022-04-07 20:12:03.780 - debug: mihome-vacuum.0 (17390) Mappointer_updated
    2022-04-07 20:12:03.782 - debug: mihome-vacuum.0 (17390) update_Map Mimap enabled
    2022-04-07 20:12:03.782 - debug: mihome-vacuum.0 (17390) update_Map need new mapurl
    2022-04-07 20:12:03.831 - debug: mihome-vacuum.0 (17390) MIIO RECIVE: {"result":{"ssid":"froehlich.unifi","ip":"192.168.229.31","mac":"64:90:c1:01:fb:13","bssid":"4a:d9:e7:fa:7f:d0","rssi":-49},"id":7}
    2022-04-07 20:12:03.911 - debug: mihome-vacuum.0 (17390) Message= {"id":8,"method":"get_sound_volume"}
    2022-04-07 20:12:03.917 - debug: mihome-vacuum.0 (17390) MIIO RECIVE: {"result":[30],"id":8}
    2022-04-07 20:12:03.918 - debug: mihome-vacuum.0 (17390) Message= {"id":9,"method":"get_multi_maps_list"}
    2022-04-07 20:12:03.925 - debug: mihome-vacuum.0 (17390) MIIO RECIVE: {"result":[{"max_multi_map":1,"max_bak_map":0,"multi_map_count":1,"map_info":[{"mapFlag":0,"add_time":1645100692,"length":0,"name":"","bak_maps":[]}]}],"id":9}
    2022-04-07 20:12:03.926 - debug: mihome-vacuum.0 (17390) States for 1 Map: [{"mapFlag":0,"add_time":1645100692,"length":0,"name":"","bak_maps":[]}]
    2022-04-07 20:12:03.927 - debug: mihome-vacuum.0 (17390) States for Map: {"0":"0"}
    2022-04-07 20:12:03.929 - debug: mihome-vacuum.0 (17390) Startup: getMultiMapsList Answer: true
    2022-04-07 20:12:03.930 - debug: mihome-vacuum.0 (17390) Startup: Delete getMultiMapsList
    2022-04-07 20:12:03.931 - debug: mihome-vacuum.0 (17390) Message= {"id":10,"method":"get_clean_summary"}
    2022-04-07 20:12:03.941 - error: mihome-vacuum.0 (17390) Error when receiving map url: ,q^QzuH \I87*XacZYDi&9_2@%ELks>]lIB H,QK`w\u_G?201k #r':="" mihome-vacuum.0="" (17390)="" map="" error:syntaxerror:="" unexpected="" token="" ,="" in="" json="" at="" position="" 0="" 20:12:03.944="" debug:="" xiaomi="" cloud:="" logging="" 20:12:03.949="" update_map="" got="" new="" url:https:="" awsde0.fds.api.xiaomi.com="" robomap="" rubyslite="" 320339760="" 6?expires="1649356923000&GalaxyAccessKeyId=5271733786445&Signature=ejbVApzz4Rfo8K+C66r9MfbH7FA=" 20:12:03.950="" expires:1649356923="" 20:12:03.951="" time:1649355123="" 20:12:03.969="" miio="" recive:="" {"result":[137508,2615415000,262,[1649354396,1649353781,1649347353,1649345161,1649344894,1649340240,1649247640,1649166646,1649165186,1649164160,1649163821,1649160739,1649159455,1649158426,1649154359,1649153775,1649152468,1649151540,1649148317,1649146933]],"id":10}="" 20:12:03.971="" message="{"id":11,"method":"get_clean_record","params":[1649354396]}" 20:12:03.979="" {"result":[[1649354396,1649354851,212,7417500,0,0,2,3,60]],"id":11}="" 20:12:03.981="" 20:12:03.991="" {"result":[[1649353781,1649353821,36,647500,0,0,2,3,60]],"id":12}="" 20:12:03.993="" 20:12:04.001="" {"result":[[1649347353,1649347937,580,12275000,0,0,2,3,60]],"id":13}="" 20:12:04.002="" 20:12:04.010="" {"result":[[1649345161,1649345243,10,0,0,0,2,3,60]],"id":14}="" 20:12:04.012="" 20:12:04.019="" {"result":[[1649344894,1649345083,10,0,0,0,2,3,60]],"id":15}="" 20:12:04.020="" 20:12:04.026="" {"result":[[1649340240,1649341269,1029,19720000,0,1,2,3,56]],"id":16}="" 20:12:04.027="" 20:12:04.033="" {"result":[[1649247640,1649248754,1114,20080000,0,1,2,3,56]],"id":17}="" 20:12:04.034="" 20:12:04.040="" {"result":[[1649166646,1649166833,183,5045000,0,0,2,3,60]],"id":18}="" 20:12:04.041="" 20:12:04.048="" {"result":[[1649165186,1649166304,89,1582500,0,0,2,3,60]],"id":19}="" 20:12:04.058="" {"result":[[1649164160,1649164352,188,5327500,0,0,2,3,60]],"id":20}="" 20:12:04.059="" 20:12:04.065="" {"result":[[1649163821,1649163939,118,1637500,0,1,2,3,56]],"id":21}="" 20:12:04.066="" 20:12:04.073="" {"result":[[1649160739,1649160785,42,910000,0,0,2,3,60]],"id":22}="" 20:12:04.075="" 20:12:04.083="" {"result":[[1649159455,1649159580,125,1657500,0,1,2,3,56]],"id":23}="" 20:12:04.084="" 20:12:04.093="" {"result":[[1649158426,1649158524,94,3512500,0,0,2,3,60]],"id":24}="" 20:12:04.094="" 20:12:04.100="" {"result":[[1649154359,1649154901,542,10960000,0,1,2,3,56]],"id":25}="" 20:12:04.101="" 20:12:04.110="" {"result":[[1649153775,1649153893,118,1577500,0,1,2,3,56]],"id":26}="" 20:12:04.111="" 20:12:04.116="" {"result":[[1649152468,1649152670,198,5975000,0,0,2,3,60]],"id":27}="" 20:12:04.118="" 20:12:04.124="" {"result":[[1649151540,1649151651,111,1605000,0,1,2,3,56]],"id":28}="" 20:12:04.125="" 20:12:04.131="" {"result":[[1649148317,1649148868,356,9850000,0,0,2,3,60]],"id":29}="" 20:12:04.132="" 20:12:04.138="" {"result":[[1649146933,1649147053,120,1755000,0,1,2,3,56]],"id":30}="" 20:12:04.139="" finish="" logs="" all="" [{"datum":"7.4","start":"19:59","saugzeit":"4="" min","fläche":"7.42="" m²","error":0,"ende":false},{"datum":"7.4","start":"19:49","saugzeit":"1="" min","fläche":"0.65="" m²","error":0,"ende":false},{"datum":"7.4","start":"18:02","saugzeit":"10="" min","fläche":"12.28="" m²","error":0,"ende":false},{"datum":"7.4","start":"17:26","saugzeit":"0="" min","fläche":"0="" m²","error":0,"ende":false},{"datum":"7.4","start":"17:21","saugzeit":"0="" m²","error":0,"ende":false},{"datum":"7.4","start":"16:04","saugzeit":"17="" min","fläche":"19.72="" m²","error":0,"ende":true},{"datum":"6.4","start":"14:20","saugzeit":"19="" min","fläche":"20.08="" m²","error":0,"ende":true},{"datum":"5.4","start":"15:50","saugzeit":"3="" min","fläche":"5.05="" m²","error":0,"ende":false},{"datum":"5.4","start":"15:26","saugzeit":"1="" min","fläche":"1.58="" m²","error":0,"ende":false},{"datum":"5.4","start":"15:09","saugzeit":"3="" min","fläche":"5.33="" m²","error":0,"ende":false},{"datum":"5.4","start":"15:03","saugzeit":"2="" min","fläche":"1.64="" m²","error":0,"ende":true},{"datum":"5.4","start":"14:12","saugzeit":"1="" min","fläche":"0.91="" m²","error":0,"ende":false},{"datum":"5.4","start":"13:50","saugzeit":"2="" min","fläche":"1.66="" m²","error":0,"ende":true},{"datum":"5.4","start":"13:33","saugzeit":"2="" min","fläche":"3.51="" m²","error":0,"ende":false},{"datum":"5.4","start":"12:25","saugzeit":"9="" min","fläche":"10.96="" m²","error":0,"ende":true},{"datum":"5.4","start":"12:16","saugzeit":"2="" m²","error":0,"ende":true},{"datum":"5.4","start":"11:54","saugzeit":"3="" min","fläche":"5.98="" m²","error":0,"ende":false},{"datum":"5.4","start":"11:39","saugzeit":"2="" min","fläche":"1.61="" m²","error":0,"ende":true},{"datum":"5.4","start":"10:45","saugzeit":"6="" min","fläche":"9.85="" m²","error":0,"ende":false},{"datum":"5.4","start":"10:22","saugzeit":"2="" min","fläche":"1.76="" m²","error":0,"ende":true}]="" 20:12:04.141="" startup:="" setgetcleansummary="" answer:="" true="" delete="" 20:12:04.142="" 20:12:04.150="" {"result":[{"main_brush_work_time":137508,"side_brush_work_time":137508,"filter_work_time":137508,"filter_element_work_time":11733,"sensor_dirty_time":28763}],"id":31}="" 20:12:04.152="" setgetconsumable="" 20:12:04.153="" 20:12:04.154="" 20:12:04.171="" {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":32}="" 20:12:04.172="" info:="" create="" state="" for="" carpet_mode="" 20:12:04.173="" 20:12:04.183="" login="" step1:="" &&&start&&&{"serviceparam":"{\"checksafephone\":false,\"checksafeaddress\":false,\"lsrp_score\":0.0}","qs":"%3fsid%3dxiaomiio%26_json%3dtrue","code":70016,"description":"登录验证失败","securitystatus":0,"_sign":"0psxfr43eni0ix6q9suk3qwbrqu="," sid":"xiaomiio","result":"error","captchaurl":null,"callback":"https:="" sts.api.io.mi.com="" sts","location":"https:="" account.xiaomi.com="" fe="" service="" login?_json="true&sid=xiaomiio&qs=%253Fsid%253Dxiaomiio%2526_json%253Dtrue&callback=https%3A%2F%2Fsts.api.io.mi.com%2Fsts&_sign=0psXfr43eNI0IX6q9Suk3qWbRqU%3D&serviceParam=%7B%22checkSafePhone%22%3Afalse%2C%22checkSafeAddress%22%3Afalse%2C%22lsrp_score%22%3A0.0%7D&showActiveX=false&theme=&needTheme=false&bizDeviceType=","pwd":0,"desc":"登录验证失败"}" 20:12:04.187="" {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":33}="" 20:12:04.511="" 26984="" 20:12:04.679="" host.smarthomeraspi="" instance="" system.adapter.mihome-vacuum.0="" terminated="" due="" to="" sigsegv="" 20:12:04.680="" with="" code="" nan="" ()="" restart="" adapter="" because="" enabled="" 20:12:09.889="" javascript.0="" (4683)="" script.js.rollläden.helligkeit_durchschnittswert:="" [13,15,17,20,23,26,30,34,39,44,50,57,65,73,83,94,106,119,134,151,170,191,215,245,275,309,275,313,353,399]="" 20:12:09.898="" shuttercontrol.0="" (1726)="" lightsensor="" changed:="" 0_userdata.0.rollladen.helligkeit_durchschnitt="" value:="" 131="" 20:12:20.782="" hm-rpc.0="" (1147)="" [keepalive]="" check="" if="" connection="" is="" alive="" 20:12:20.783="" send="" ping...="" 20:12:20.806="" ping="" ok="" 20:12:20.810="" xml="" multicall="" : SmarthomeRaspi:hm-rpc.0:86e5c28de60614468b710549803c5777,CENTRAL,PONG,SmarthomeRaspi:hm-rpc.0:86e5c28de60614468b710549803c5777
    2022-04-07 20:12:20.811 - debug: hm-rpc.0 (1147) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.0:86e5c28de60614468b710549803c5777","CENTRAL","PONG","SmarthomeRaspi:hm-rpc.0:86e5c28de60614468b710549803c5777"]
    2022-04-07 20:12:20.812 - debug: hm-rpc.0 (1147) xmlrpc <- event: hm-rpc.0.CENTRAL.PONG:SmarthomeRaspi:hm-rpc.0:86e5c28de60614468b710549803c5777 discarded, no matching device
    2022-04-07 20:12:23.564 - debug: hm-rpc.1 (1169) [KEEPALIVE] Check if connection is alive
    2022-04-07 20:12:23.564 - debug: hm-rpc.1 (1169) Send PING...
    2022-04-07 20:12:23.582 - debug: hm-rpc.1 (1169) PING ok
    2022-04-07 20:12:23.584 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","CENTRAL:0","PONG","SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31"]
    2022-04-07 20:12:23.585 - debug: hm-rpc.1 (1169) xmlrpc <- event: hm-rpc.1.CENTRAL.0.PONG:SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31 discarded, no matching device
    2022-04-07 20:12:35.263 - info: host.SmarthomeRaspi instance system.adapter.mihome-vacuum.0 started with pid 17461
    2022-04-07 20:12:36.815 - debug: mihome-vacuum.0 (17461) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2022-04-07 20:12:36.896 - debug: mihome-vacuum.0 (17461) Objects client ready ... initialize now
    2022-04-07 20:12:36.899 - debug: mihome-vacuum.0 (17461) Objects create System PubSub Client
    2022-04-07 20:12:36.900 - debug: mihome-vacuum.0 (17461) Objects create User PubSub Client
    2022-04-07 20:12:37.046 - debug: mihome-vacuum.0 (17461) Objects client initialize lua scripts
    2022-04-07 20:12:37.053 - debug: mihome-vacuum.0 (17461) Objects connected to redis: 127.0.0.1:9001
    2022-04-07 20:12:37.119 - debug: mihome-vacuum.0 (17461) Redis States: Use Redis connection: 127.0.0.1:9000
    2022-04-07 20:12:37.183 - debug: mihome-vacuum.0 (17461) States create System PubSub Client
    2022-04-07 20:12:37.185 - debug: mihome-vacuum.0 (17461) States create User PubSub Client
    2022-04-07 20:12:37.261 - debug: mihome-vacuum.0 (17461) States connected to redis: 127.0.0.1:9000
    2022-04-07 20:12:37.523 - debug: mihome-vacuum.0 (17461) Plugin sentry Initialize Plugin (enabled=true)
    2022-04-07 20:12:38.030 - info: mihome-vacuum.0 (17461) starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.19.1, js-controller: 4.0.21
    2022-04-07 20:12:38.130 - debug: mihome-vacuum.0 (17461) load Map creator... true
    2022-04-07 20:12:38.167 - debug: mihome-vacuum.0 (17461) Create State for deviceInfo
    2022-04-07 20:12:38.168 - debug: mihome-vacuum.0 (17461) Create State for deviceInfomac
    2022-04-07 20:12:38.169 - debug: mihome-vacuum.0 (17461) Create State for deviceInfomodel
    2022-04-07 20:12:38.170 - debug: mihome-vacuum.0 (17461) Create State for deviceInfofw_ver
    2022-04-07 20:12:38.174 - debug: mihome-vacuum.0 (17461) Create State for deviceInfowifi_signal
    2022-04-07 20:12:38.176 - debug: mihome-vacuum.0 (17461) MIIO: Config: ip:192.168.229.31 token: 6a62485744456c466c766f6d45535473
    2022-04-07 20:12:38.183 - info: mihome-vacuum.0 (17461) IOT enabled, create state
    2022-04-07 20:12:38.189 - debug: mihome-vacuum.0 (17461) server started on 0.0.0.0:53421
    2022-04-07 20:12:38.197 - debug: mihome-vacuum.0 (17461) Receive <<< Helo <<< 21310020000000001317ff30624f2996ffffffffffffffffffffffffffffffff
    2022-04-07 20:12:38.199 - debug: mihome-vacuum.0 (17461) MAIN: Connected to device, try to get model..
    2022-04-07 20:12:38.227 - debug: mihome-vacuum.0 (17461) GETMODELFROMAPI: objModel: {"val":"roborock.vacuum.s5e","ack":true,"ts":1649355122288,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1649165771511}
    2022-04-07 20:12:38.230 - debug: mihome-vacuum.0 (17461) Message= {"id":1,"method":"miIO.info"}
    2022-04-07 20:12:40.237 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "miIO.info" <<<
    2022-04-07 20:12:40.238 - debug: mihome-vacuum.0 (17461) Get Device data..0
    2022-04-07 20:12:40.238 - debug: mihome-vacuum.0 (17461) Message= {"id":2,"method":"miIO.info"}
    2022-04-07 20:12:40.589 - info: unifi.0 (2213) State value to set for "unifi.0.default.clients.ae:2d:74:9e:b6:86.noted" has to be type "boolean" but received type "string"
    2022-04-07 20:12:40.685 - info: unifi.0 (2213) State value to set for "unifi.0.default.clients.94:e7:0b:61:00:58.noted" has to be type "boolean" but received type "string"
    2022-04-07 20:12:42.240 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "miIO.info" <<<
    2022-04-07 20:12:42.241 - debug: mihome-vacuum.0 (17461) Get Device data..1
    2022-04-07 20:12:42.241 - debug: mihome-vacuum.0 (17461) Message= {"id":3,"method":"miIO.info"}
    2022-04-07 20:12:44.243 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "miIO.info" <<<
    2022-04-07 20:12:44.243 - debug: mihome-vacuum.0 (17461) Get Device data..2
    2022-04-07 20:12:44.244 - debug: mihome-vacuum.0 (17461) Message= {"id":4,"method":"miIO.info"}
    2022-04-07 20:12:46.246 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "miIO.info" <<<
    2022-04-07 20:12:46.247 - debug: mihome-vacuum.0 (17461) Get Device data..3
    2022-04-07 20:12:46.247 - debug: mihome-vacuum.0 (17461) Message= {"id":5,"method":"miIO.info"}
    2022-04-07 20:12:48.207 - debug: mihome-vacuum.0 (17461) Receive <<< Helo <<< 21310020000000001317ff30624f29a0ffffffffffffffffffffffffffffffff
    2022-04-07 20:12:48.249 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "miIO.info" <<<
    2022-04-07 20:12:48.251 - debug: mihome-vacuum.0 (17461) Get Device data..4
    2022-04-07 20:12:48.252 - warn: mihome-vacuum.0 (17461) YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER YET - CONNECTION CAN TAKE UP TO 10 MINUTES - PLEASE BE PATIENT AND DO NOT TURN THE ADAPTER OFF
    2022-04-07 20:12:48.253 - warn: mihome-vacuum.0 (17461) No Answer for DeviceModel use old one
    2022-04-07 20:12:48.254 - warn: mihome-vacuum.0 (17461) No Answer for DeviceModel use model from Config
    2022-04-07 20:12:48.286 - debug: mihome-vacuum.0 (17461) DeviceModel selected to: roborock.vacuum.s5e
    2022-04-07 20:12:48.289 - info: mihome-vacuum.0 (17461) select standard vacuum protocol....
    2022-04-07 20:12:48.299 - debug: mihome-vacuum.0 (17461) Xiaomi Cloud: Logging in
    2022-04-07 20:12:48.395 - debug: mihome-vacuum.0 (17461) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    2022-04-07 20:12:48.618 - debug: mihome-vacuum.0 (17461) Login step1: &&&START&&&{"serviceParam":"{\"checkSafePhone\":false,\"checkSafeAddress\":false,\"lsrp_score\":0.0}","qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","code":70016,"description":"登录验证失败","securityStatus":0,"_sign":"0psXfr43eNI0IX6q9Suk3qWbRqU=","sid":"xiaomiio","result":"error","captchaUrl":null,"callback":"https://sts.api.io.mi.com/sts","location":"https://account.xiaomi.com/fe/service/login?_json=true&sid=xiaomiio&qs=%253Fsid%253Dxiaomiio%2526_json%253Dtrue&callback=https%3A%2F%2Fsts.api.io.mi.com%2Fsts&_sign=0psXfr43eNI0IX6q9Suk3qWbRqU%3D&serviceParam=%7B%22checkSafePhone%22%3Afalse%2C%22checkSafeAddress%22%3Afalse%2C%22lsrp_score%22%3A0.0%7D&showActiveX=false&theme=&needTheme=false&bizDeviceType=","pwd":0,"desc":"登录验证失败"}
    2022-04-07 20:12:48.886 - debug: mihome-vacuum.0 (17461) Login step2: &&&START&&&{"qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","ssecurity":"SepRPCb5Gp3xHlMGTDMc6w==","code":0,"passToken":"V1:DXmurwq2/R1BHTELu6obCWKEFrEUGTARxOslPX6sxFF2Q8OlltPlCwT/UWqRgzdB0dLMMvcPG8AkDj4/+A82UV7DMirIabZ3FerW1PO6f5O67G9v0w978SPbJFPYfZjinxUAaHyGnjv7OHBePMBqVEB0h/QYglsEKHJGUbmzEm+3QgFc0wPvnjF6DZgahfTvBBA+TwZ/xrKw40MYUbsHcDnJwLuh6hNjmwkt6eMpLAoQE1NL261T6RVBpeWNH3pYqxwNZMZ9aeJRB71X8Ygj63GPXuM91zTS514w1SA2ppA=","description":"成功","securityStatus":0,"nonce":3032190925820327936,"userId":8161011682,"cUserId":"d7BvRzpJp2fIp_BmYH4fXAU23E8","result":"ok","psecurity":"qwnCZNR1XvS8GflT4azUJA==","captchaUrl":null,"location":"https://sts.api.io.mi.com/sts?d=gzwnnq&ticket=0&pwd=1&p_ts=1649355168000&fid=0&p_lm=1&auth=rCDOR5U3EDvAjqyhbqZTnqchvMFu25Yc5vxN1QIjYLOmFxvRocYln04TlM0e3aYti4XTfapSU4G5zEP4vKAvZqlP7brrRgLlQi0fbdpd2JSDH84sMRl6i8qWPjUuGj9X3OcRDhkm12XuDZT9pjbRYw64I7xfbnYGezBXSEJ8WwY%3D&m=1&tsl=0&nonce=lvi8eHbKkg8Bo3Pk&_ssign=U08FSkqWBO%2FhVOJXffR50pBC5SQ%3D","pwd":1,"desc":"成功"}
    2022-04-07 20:12:49.029 - info: mihome-vacuum.0 (17461) settest next timer: not available
    2022-04-07 20:12:49.251 - debug: mihome-vacuum.0 (17461) Login step3: [{"key":"userId","value":"8161011682","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-04-07T18:12:49.194Z","lastAccessed":"2022-04-07T18:12:49.248Z"},{"key":"cUserId","value":"d7BvRzpJp2fIp_BmYH4fXAU23E8","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-04-07T18:12:49.219Z","lastAccessed":"2022-04-07T18:12:49.248Z"},{"key":"serviceToken","value":"PlyQUW9q7aeZNtWORxesgsriRJJGvLPk3oTyMSaP2wG45oBiDVK6ZiHNX5KCwQup0RFhxEzTkYwbZWG1Nuquo7V9V0JKWRleagwbEJ1X/4JODW27+AVy+MHqsmjwE1fRxUmADb3JYCGd+g74Weydjv4ptbnbFL9QhR6BMLwNRHo=","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-04-07T18:12:49.233Z","lastAccessed":"2022-04-07T18:12:49.248Z"}]
    2022-04-07 20:12:49.266 - debug: mihome-vacuum.0 (17461) Xiaomi Cloud: Login successful
    2022-04-07 20:12:49.336 - debug: mihome-vacuum.0 (17461) Create State for Queue: queue
    2022-04-07 20:12:49.337 - debug: mihome-vacuum.0 (17461) Create State for Queue: clearQueue
    2022-04-07 20:12:49.341 - info: mihome-vacuum.0 (17461) Map selected create states...
    2022-04-07 20:12:49.344 - debug: mihome-vacuum.0 (17461) Create State for map:
    2022-04-07 20:12:49.345 - debug: mihome-vacuum.0 (17461) Create State for map: map64
    2022-04-07 20:12:49.346 - debug: mihome-vacuum.0 (17461) Create State for map: actualMap
    2022-04-07 20:12:49.348 - debug: mihome-vacuum.0 (17461) Create State for map: mapStatus
    2022-04-07 20:12:49.349 - debug: mihome-vacuum.0 (17461) Create State for map: mapURL
    2022-04-07 20:12:49.350 - debug: mihome-vacuum.0 (17461) Create State for map: loadMap
    2022-04-07 20:12:49.350 - debug: mihome-vacuum.0 (17461) Create State done!
    2022-04-07 20:12:49.351 - debug: mihome-vacuum.0 (17461) get params for stock Vacuum
    2022-04-07 20:12:49.352 - debug: mihome-vacuum.0 (17461) Message= {"id":6,"method":"get_status"}
    2022-04-07 20:12:51.353 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "get_status" <<<
    2022-04-07 20:12:51.354 - debug: mihome-vacuum.0 (17461) ERROR at setGetStatus: MESSAGE TIMEOUT
    2022-04-07 20:12:51.355 - debug: mihome-vacuum.0 (17461) Message= {"id":7,"method":"get_network_info"}
    2022-04-07 20:12:53.356 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "get_network_info" <<<
    2022-04-07 20:12:53.357 - debug: mihome-vacuum.0 (17461) Error at getSetNetwork: MESSAGE TIMEOUT
    2022-04-07 20:12:53.358 - debug: mihome-vacuum.0 (17461) Message= {"id":8,"method":"get_sound_volume"}
    2022-04-07 20:12:55.360 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "get_sound_volume" <<<
    2022-04-07 20:12:55.361 - debug: mihome-vacuum.0 (17461) ERROR at setGetSoundVolume: MESSAGE TIMEOUT
    2022-04-07 20:12:55.363 - debug: mihome-vacuum.0 (17461) Message= {"id":9,"method":"get_multi_maps_list"}
    2022-04-07 20:12:57.365 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "get_multi_maps_list" <<<
    2022-04-07 20:12:57.367 - debug: mihome-vacuum.0 (17461) Startup: getMultiMapsList Answer: false
    2022-04-07 20:12:57.368 - debug: mihome-vacuum.0 (17461) Message= {"id":10,"method":"get_clean_summary"}
    2022-04-07 20:12:58.212 - debug: mihome-vacuum.0 (17461) Receive <<< Helo <<< 21310020000000001317ff30624f29aaffffffffffffffffffffffffffffffff
    2022-04-07 20:12:59.370 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "get_clean_summary" <<<
    2022-04-07 20:12:59.371 - debug: mihome-vacuum.0 (17461) ERROR at setGetCleanSummary: MESSAGE TIMEOUT
    2022-04-07 20:12:59.372 - debug: mihome-vacuum.0 (17461) Startup: setGetCleanSummary Answer: false
    2022-04-07 20:12:59.373 - debug: mihome-vacuum.0 (17461) Message= {"id":11,"method":"get_consumable"}
    2022-04-07 20:13:01.374 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "get_consumable" <<<
    2022-04-07 20:13:01.377 - debug: mihome-vacuum.0 (17461) ERROR at setGetConsumable: MESSAGE TIMEOUT
    2022-04-07 20:13:01.378 - debug: mihome-vacuum.0 (17461) Startup: setGetConsumable Answer: false
    2022-04-07 20:13:01.380 - debug: mihome-vacuum.0 (17461) Message= {"id":12,"method":"get_map_v1"}
    2022-04-07 20:13:03.384 - debug: mihome-vacuum.0 (17461) MIIO Receive Timeout for "get_map_v1" <<<
      @tobiasf78
      TobiasF78
      #821
      dieser Fehler kam noch
      2022-04-07 20:15:46.409 - debug: mihome-vacuum.0 (17698) Message= {"id":6,"method":"get_map_v1"}
      2022-04-07 20:15:46.413 - debug: mihome-vacuum.0 (17698) Message= {"id":7,"method":"get_network_info"}
      2022-04-07 20:15:46.424 - debug: mihome-vacuum.0 (17698) MIIO RECIVE: {"result":["rubyslite%2F320339760%2F14"],"id":6}
      2022-04-07 20:15:46.427 - debug: mihome-vacuum.0 (17698) Mappointer_updated
      2022-04-07 20:15:46.428 - debug: mihome-vacuum.0 (17698) update_Map Mimap enabled
      2022-04-07 20:15:46.429 - debug: mihome-vacuum.0 (17698) update_Map need new mapurl
      2022-04-07 20:15:46.441 - debug: mihome-vacuum.0 (17698) MIIO RECIVE: {"result":{"ssid":"froehlich.unifi","ip":"192.168.229.31","mac":"64:90:c1:01:fb:13","bssid":"4a:d9:e7:fa:7f:d0","rssi":-49},"id":7}
      2022-04-07 20:15:46.552 - error: mihome-vacuum.0 (17698) Error when receiving map url: V/=+yvYq
      )-1z9kI@z,qiI'
      eCu40Sr]NCGHyHz>BU'<,]=sQug-,pd"in$jnf /?L)+(L\JNSIx"k;{6Ou'8u(}KMq7OGoij >"/RvMr -nRvmR9+)5Nx\i pI9]i9d-y}^"<KK1h|t,`Yi\%j<N
      /Q|h=RGu( #h)Yv`'bk6iFsPDi_B+7EJIVkb"EaZ{;"
      2022-04-07 20:15:46.554 - warn: mihome-vacuum.0 (17698) map error:SyntaxError: Unexpected token V in JSON at position 0
      2022-04-07 20:15:46.555 - debug: mihome-vacuum.0 (17698) Xiaomi Cloud: Logging in
      2022-04-07 20:15:46.565 - debug: mihome-vacuum.0 (17698) Message= {"id":8,"method":"get_sound_volume"}
      2022-04-07 20:15:46.572 - debug: mihome-vacuum.0 (17698) MIIO RECIVE: {"result":[30],"id":8}
      2022-04-07 20:15:46.575 - debug: mihome-vacuum.0 (17698) Message= {"id":9,"method":"get_multi_maps_list"}
      2022-04-07 20:15:46.581 - debug: mihome-vacuum.0 (17698) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320339760/14?Expires=1649357146000&GalaxyAccessKeyId=5271733786445&Signature=opGVwS3duRFnQWWBtkrse3j7Kr0=
      2022-04-07 20:15:46.582 - debug: mihome-vacuum.0 (17698) update_Map got new expires:1649357146
      2022-04-07 20:15:46.583 - debug: mihome-vacuum.0 (17698) update_Map got new time:1649355346
      2022-04-07 20:15:46.592 - debug: mihome-vacuum.0 (17698) MIIO RECIVE: {"result":[{"max_multi_map":1,"max_bak_map":0,"multi_map_count":1,"map_info":[{"mapFlag":0,"add_time":1645100692,"length":0,"name":"","bak_maps":[]}]}],"id":9}
      2022-04-07 20:15:46.593 - debug: mihome-vacuum.0 (17698) States for 1 Map: [{"mapFlag":0,"add_time":1645100692,"length":0,"name":"","bak_maps":[]}]
      2022-04-07 20:15:46.593 - debug: mihome-vacuum.0 (17698) States for Map: {"0":"0"}
      2022-04-07 20:15:46.595 - debug: mihome-vacuum.0 (17698) Startup: getMultiMapsList Answer: true
      2022-04-07 20:15:46.595 - debug: mihome-vacuum.0 (17698) Startup: Delete getMultiMapsList
      2022-04-07 20:15:46.596 - debug: mihome-vacuum.0 (17698) Message= {"id":10,"method":"get_clean_summary"}
        @tobiasf78
        TobiasF78
        #822
        22-04-07 20:15:46.795 - debug: mihome-vacuum.0 (17698) Login step1: &&&START&&&{"serviceParam":"{\"checkSafePhone\":false,\"checkSafeAddress\":false,\"lsrp_score\":0.0}","qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","code":70016,"description":"登录验证失败","securityStatus":0,"_sign":"0psXfr43eNI0IX6q9Suk3qWbRqU=","sid":"xiaomiio","result":"error","captchaUrl":null,"callback":"https://sts.api.io.mi.com/sts","location":"https://account.xiaomi.com/fe/service/login?_json=true&sid=xiaomiio&qs=%253Fsid%253Dxiaomiio%2526_json%253Dtrue&callback=https%3A%2F%2Fsts.api.io.mi.com%2Fsts&_sign=0psXfr43eNI0IX6q9Suk3qWbRqU%3D&serviceParam=%7B%22checkSafePhone%22%3Afalse%2C%22checkSafeAddress%22%3Afalse%2C%22lsrp_score%22%3A0.0%7D&showActiveX=false&theme=&needTheme=false&bizDeviceType=","pwd":0,"desc":"登录验证失败"}
        2022-04-07 20:15:46.798 - debug: mihome-vacuum.0 (17698) MIIO RECIVE: {"result":[{"main_brush_work_time":137508,"side_brush_work_time":137508,"filter_work_time":137508,"filter_element_work_time":11733,"sensor_dirty_time":28763}],"id":31}
        2022-04-07 20:15:46.799 - debug: mihome-vacuum.0 (17698) Startup: setGetConsumable Answer: true
        2022-04-07 20:15:46.799 - debug: mihome-vacuum.0 (17698) Startup: Delete setGetConsumable
        2022-04-07 20:15:46.800 - debug: mihome-vacuum.0 (17698) Message= {"id":32,"method":"get_carpet_mode"}
        2022-04-07 20:15:46.817 - debug: mihome-vacuum.0 (17698) MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":32}
        2022-04-07 20:15:46.818 - info: mihome-vacuum.0 (17698) create state for carpet_mode
        2022-04-07 20:15:46.819 - debug: mihome-vacuum.0 (17698) Message= {"id":33,"method":"get_carpet_mode"}
        2022-04-07 20:15:46.830 - debug: mihome-vacuum.0 (17698) MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":33}
        2022-04-07 20:15:47.111 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,CONFIG_PENDING,false
        2022-04-07 20:15:47.111 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","CONFIG_PENDING",false]
        2022-04-07 20:15:47.111 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.CONFIG_PENDING ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
        2022-04-07 20:15:47.112 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,DUTY_CYCLE,false
        2022-04-07 20:15:47.112 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","DUTY_CYCLE",false]
        2022-04-07 20:15:47.112 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.DUTY_CYCLE ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
        2022-04-07 20:15:47.112 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,LOW_BAT,false
        2022-04-07 20:15:47.112 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","LOW_BAT",false]
        2022-04-07 20:15:47.112 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.LOW_BAT ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
        2022-04-07 20:15:47.113 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,UNREACH,false
        2022-04-07 20:15:47.113 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","UNREACH",false]
        2022-04-07 20:15:47.113 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.UNREACH ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
        2022-04-07 20:15:47.113 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,RSSI_DEVICE,-79
        2022-04-07 20:15:47.113 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","RSSI_DEVICE",-79]
        2022-04-07 20:15:47.113 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.RSSI_DEVICE ==> UNIT: "undefined" (min: -128, max: 127) From "-79" => "-79"
        2022-04-07 20:15:47.113 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,OPERATING_VOLTAGE_STATUS,0
        2022-04-07 20:15:47.114 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","OPERATING_VOLTAGE_STATUS",0]
        2022-04-07 20:15:47.114 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.OPERATING_VOLTAGE_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
        2022-04-07 20:15:47.114 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,OPERATING_VOLTAGE,3
        2022-04-07 20:15:47.114 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","OPERATING_VOLTAGE",3]
        2022-04-07 20:15:47.114 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.OPERATING_VOLTAGE ==> UNIT: "undefined" (min: 0, max: 25.2) From "3" => "3"
        2022-04-07 20:15:47.114 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,ERROR_CODE,0
        2022-04-07 20:15:47.114 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","ERROR_CODE",0]
        2022-04-07 20:15:47.115 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.ERROR_CODE ==> UNIT: "undefined" (min: 0, max: 255) From "0" => "0"
        2022-04-07 20:15:47.125 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:3,MOTION,true
        2022-04-07 20:15:47.125 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:3","MOTION",true]
        2022-04-07 20:15:47.125 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.3.MOTION ==> UNIT: "undefined" (min: undefined, max: undefined) From "true" => "true"
        2022-04-07 20:15:47.125 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:3,ILLUMINATION,1.7
        2022-04-07 20:15:47.125 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:3","ILLUMINATION",1.7]
        2022-04-07 20:15:47.126 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.3.ILLUMINATION ==> UNIT: "undefined" (min: 0, max: 163830) From "1.7" => "1.7"
        2022-04-07 20:15:47.126 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:3,ILLUMINATION_STATUS,0
        2022-04-07 20:15:47.126 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:3","ILLUMINATION_STATUS",0]
        2022-04-07 20:15:47.127 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.3.ILLUMINATION_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
        2022-04-07 20:15:47.127 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:3,MOTION_DETECTION_ACTIVE,true
        2022-04-07 20:15:47.127 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:3","MOTION_DETECTION_ACTIVE",true]
        2022-04-07 20:15:47.132 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.3.MOTION_DETECTION_ACTIVE ==> UNIT: "undefined" (min: undefined, max: undefined) From "true" => "true"
        2022-04-07 20:15:47.167 - debug: mihome-vacuum.0 (17698) 22595
        2022-04-07 20:15:47.356 - error: host.SmarthomeRaspi Caught by controller[0]: corrupted double-linked list
        2022-04-07 20:15:47.357 - warn: host.SmarthomeRaspi instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
        2022-04-07 20:15:47.357 - info: host.SmarthomeRaspi instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
        2022-04-07 20:15:47.357 - info: host.SmarthomeRaspi Restart adapter system.adapter.mihome-vacuum.0 because enabled
        2022-04-07 20:15:49.608 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:0,CONFIG_PENDING,false
        2022-04-07 20:15:49.608 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:0","CONFIG_PENDING",false]
        2022-04-07 20:15:49.608 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.0.CONFIG_PENDING ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
        2022-04-07 20:15:49.608 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:0,RSSI_DEVICE,-84
        2022-04-07 20:15:49.609 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:0","RSSI_DEVICE",-84]
        2022-04-07 20:15:49.609 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.0.RSSI_DEVICE ==> UNIT: "undefined" (min: -128, max: 127) From "-84" => "-84"
        2022-04-07 20:15:49.609 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:0,DUTY_CYCLE,false
        2022-04-07 20:15:49.609 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:0","DUTY_CYCLE",false]
        2022-04-07 20:15:49.609 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.0.DUTY_CYCLE ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
        2022-04-07 20:15:49.609 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:0,UNREACH,false
        2022-04-07 20:15:49.609 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:0","UNREACH",false]
        2022-04-07 20:15:49.610 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.0.UNREACH ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
        2022-04-07 20:15:49.619 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:3,LEVEL,0
        2022-04-07 20:15:49.619 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:3","LEVEL",0]
        2022-04-07 20:15:49.619 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.3.LEVEL ==> UNIT: "100%" (min: 0, max: 1) From "0" => "0"
        2022-04-07 20:15:49.620 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:3,LEVEL_STATUS,0
        2022-04-07 20:15:49.620 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:3","LEVEL_STATUS",0]
        2022-04-07 20:15:49.620 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.3.LEVEL_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
        2022-04-07 20:15:49.620 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:3,SECTION,15
        2022-04-07 20:15:49.620 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:3","SECTION",15]
        2022-04-07 20:15:49.621 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.3.SECTION ==> UNIT: "undefined" (min: 0, max: 15) From "15" => "15"
        2022-04-07 20:15:49.621 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:3,PROCESS,0
        2022-04-07 20:15:49.621 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:3","PROCESS",0]
        2022-04-07 20:15:49.621 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.3.PROCESS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
        2022-04-07 20:15:49.621 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:3,ACTIVITY_STATE,3
        2022-04-07 20:15:49.621 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:3","ACTIVITY_STATE",3]
        2022-04-07 20:15:49.621 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.3.ACTIVITY_STATE ==> UNIT: "undefined" (min: undefined, max: undefined) From "3" => "3"
        2022-04-07 20:15:49.630 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:4,LEVEL,0
        2022-04-07 20:15:49.630 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:4","LEVEL",0]
        2022-04-07 20:15:49.631 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.4.LEVEL ==> UNIT: "100%" (min: 0, max: 1) From "0" => "0"
        2022-04-07 20:15:49.631 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:4,LEVEL_STATUS,0
        2022-04-07 20:15:49.631 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:4","LEVEL_STATUS",0]
        2022-04-07 20:15:49.632 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.4.LEVEL_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
        2022-04-07 20:15:49.632 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:4,SECTION,0
        2022-04-07 20:15:49.633 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:4","SECTION",0]
        2022-04-07 20:15:49.633 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.4.SECTION ==> UNIT: "undefined" (min: 0, max: 15) From "0" => "0"
        2022-04-07 20:15:49.634 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:4,PROCESS,0
        2022-04-07 20:15:49.634 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:4","PROCESS",0]
        2022-04-07 20:15:49.634 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.4.PROCESS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
        2022-04-07 20:15:49.634 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:4,ACTIVITY_STATE,3
        2022-04-07 20:15:49.634 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:4","ACTIVITY_STATE",3]
        2022-04-07 20:15:49.635 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.4.ACTIVITY_STATE ==> UNIT: "undefined" (min: undefined, max: undefined) From "3" => "3"
        2022-04-07 20:15:49.644 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:5,LEVEL,0
        2022-04-07 20:15:49.645 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:5","LEVEL",0]
        2022-04-07 20:15:49.645 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.5.LEVEL ==> UNIT: "100%" (min: 0, max: 1) From "0" => "0"
        2022-04-07 20:15:49.645 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:5,LEVEL_STATUS,0
        2022-04-07 20:15:49.646 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:5","LEVEL_STATUS",0]
        2022-04-07 20:15:49.646 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.5.LEVEL_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
        2022-04-07 20:15:49.646 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:5,SECTION,0
        2022-04-07 20:15:49.647 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:5","SECTION",0]
        2022-04-07 20:15:49.647 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.5.SECTION ==> UNIT: "undefined" (min: 0, max: 15) From "0" => "0"
        2022-04-07 20:15:49.647 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:5,PROCESS,0
        2022-04-07 20:15:49.647 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:5","PROCESS",0]
        2022-04-07 20:15:49.648 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.5.PROCESS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
        2022-04-07 20:15:49.649 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:5,ACTIVITY_STATE,3
        2022-04-07 20:15:49.649 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:5","ACTIVITY_STATE",3]
        2022-04-07 20:15:49.649 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.5.ACTIVITY_STATE ==> UNIT: "undefined" (min: undefined, max: undefined) From "3" => "3"
        2022-04-07 20:15:49.676 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:6,LEVEL,0
        2022-04-07 20:15:49.677 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:6","LEVEL",0]
        2022-04-07 20:15:49.678 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.6.LEVEL ==> UNIT: "100%" (min: 0, max: 1) From "0" => "0"
        2022-04-07 20:15:49.678 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:6,LEVEL_STATUS,0
        2022-04-07 20:15:49.679 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:6","LEVEL_STATUS",0]
        2022-04-07 20:15:49.679 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.6.LEVEL_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
        2022-04-07 20:15:49.679 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:6,SECTION,0
        2022-04-07 20:15:49.681 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:6","SECTION",0]
        2022-04-07 20:15:49.681 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.6.SECTION ==> UNIT: "undefined" (min: 0, max: 15) From "0" => "0"
        2022-04-07 20:15:49.681 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:6,PROCESS,0
        2022-04-07 20:15:49.682 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:6","PROCESS",0]
        2022-04-07 20:15:49.682 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.6.PROCESS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
        2022-04-07 20:15:49.683 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,001158A99CA960:6,ACTIVITY_STATE,3
        2022-04-07 20:15:49.684 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","001158A99CA960:6","ACTIVITY_STATE",3]
        2022-04-07 20:15:49.684 - debug: hm-rpc.1 (1169) hm-rpc.1.001158A99CA960.6.ACTIVITY_STATE ==> UNIT: "undefined" (min: undefined, max: undefined) From "3" => "3"
        2022-04-07 20:15:59.561 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,00085D89B13FCC:0,CONFIG_PENDING,false
        2022-04-07 20:15:59.562 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","00085D89B13FCC:0","CONFIG_PENDING",false]
        2022-04-07 20:15:59.562 - debug: hm-rpc.1 (1169) hm-rpc.1.00085D89B13FCC.0.CONFIG_PENDING ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
        2022-04-07 20:15:59.562 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,00085D89B13FCC:0,UNREACH,false
        2022-04-07 20:15:59.562 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","00085D89B13FCC:0","UNREACH",false]
        2022-04-07 20:15:59.563 - debug: hm-rpc.1 (1169) hm-rpc.1.00085D89B13FCC.0.UNREACH ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
        2022-04-07 20:15:59.563 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,00085D89B13FCC:0,RSSI_DEVICE,-73
        2022-04-07 20:15:59.563 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","00085D89B13FCC:0","RSSI_DEVICE",-73]
        2022-04-07 20:15:59.563 - debug: hm-rpc.1 (1169) hm-rpc.1.00085D89B13FCC.0.RSSI_DEVICE ==> UNIT: "undefined" (min: -128, max: 127) From "-73" => "-73"
        2022-04-07 20:15:59.568 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","00085D89B13FCC:1","PRESS_SHORT",true]
        2022-04-07 20:15:59.569 - debug: hm-rpc.1 (1169) hm-rpc.1.00085D89B13FCC.1.PRESS_SHORT ==> UNIT: "undefined" (min: undefined, max: undefined) From "true" => "true"
        2022-04-07 20:16:00.552 - debug: hm-rpc.1 (1169) xmlrpc -> setValue 2 STATE: true
        2022-04-07 20:16:00.552 - debug: hm-rpc.1 (1169) setValue ["000895699E6B0E:2","STATE",true] BOOL
        2022-04-07 20:16:00.698 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:0,CONFIG_PENDING,false
        2022-04-07 20:16:00.698 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:0","CONFIG_PENDING",false]
        2022-04-07 20:16:00.698 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.0.CONFIG_PENDING ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
        2022-04-07 20:16:00.699 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:0,RSSI_DEVICE,-77
        2022-04-07 20:16:00.699 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:0","RSSI_DEVICE",-77]
        2022-04-07 20:16:00.699 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.0.RSSI_DEVICE ==> UNIT: "undefined" (min: -128, max: 127) From "-77" => "-77"
        2022-04-07 20:16:00.699 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:0,DUTY_CYCLE,false
        2022-04-07 20:16:00.699 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:0","DUTY_CYCLE",false]
        2022-04-07 20:16:00.699 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.0.DUTY_CYCLE ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
        2022-04-07 20:16:00.700 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:0,UNREACH,false
        2022-04-07 20:16:00.700 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:0","UNREACH",false]
        2022-04-07 20:16:00.700 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.0.UNREACH ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
        2022-04-07 20:16:00.700 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:0,RSSI_PEER,-74
        2022-04-07 20:16:00.700 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:0","RSSI_PEER",-74]
        2022-04-07 20:16:00.700 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.0.RSSI_PEER ==> UNIT: "undefined" (min: -128, max: 127) From "-74" => "-74"
        2022-04-07 20:16:00.708 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:2,SECTION_STATUS,0
        2022-04-07 20:16:00.708 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:2","SECTION_STATUS",0]
        2022-04-07 20:16:00.708 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.2.SECTION_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
        2022-04-07 20:16:00.709 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:2,STATE,true
        2022-04-07 20:16:00.709 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:2","STATE",true]
        2022-04-07 20:16:00.709 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.2.STATE ==> UNIT: "undefined" (min: undefined, max: undefined) From "true" => "true"
        2022-04-07 20:16:00.709 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:2,SECTION,2
        2022-04-07 20:16:00.710 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:2","SECTION",2]
        2022-04-07 20:16:00.710 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.2.SECTION ==> UNIT: "undefined" (min: 0, max: 15) From "2" => "2"
        2022-04-07 20:16:00.710 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:2,PROCESS,0
        2022-04-07 20:16:00.710 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:2","PROCESS",0]
        2022-04-07 20:16:00.710 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.2.PROCESS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
        2022-04-07 20:16:01.552 - debug: shuttercontrol.0 (1726) Shutter state changed: Rollladen Küche.LEVEL old value = 100 new value = 0
        2022-04-07 20:16:01.557 - debug: shuttercontrol.0 (1726) Rollladen Küche.LEVEL Old value = 100. New value = 0. automatic is active
        2022-04-07 20:16:04.227 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:0,CONFIG_PENDING,false
        2022-04-07 20:16:04.228 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:0","CONFIG_PENDING",false]
        2022-04-07 20:16:04.228 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.0.CONFIG_PENDING ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
        2022-04-07 20:16:04.228 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:0,RSSI_DEVICE,-84
        2022-04-07 20:16:04.228 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:0","RSSI_DEVICE",-84]
        2022-04-07 20:16:04.228 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.0.RSSI_DEVICE ==> UNIT: "undefined" (min: -128, max: 127) From "-84" => "-84"
        2022-04-07 20:16:04.228 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:0,DUTY_CYCLE,false
        2022-04-07 20:16:04.229 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:0","DUTY_CYCLE",false]
        2022-04-07 20:16:04.229 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.0.DUTY_CYCLE ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
        2022-04-07 20:16:04.231 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:0,UNREACH,false
        2022-04-07 20:16:04.231 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:0","UNREACH",false]
        2022-04-07 20:16:04.231 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.0.UNREACH ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
        2022-04-07 20:16:04.261 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:1,SECTION_STATUS,0
        2022-04-07 20:16:04.262 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:1","SECTION_STATUS",0]
        2022-04-07 20:16:04.262 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.1.SECTION_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
        2022-04-07 20:16:04.262 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:1,STATE,true
        2022-04-07 20:16:04.262 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:1","STATE",true]
        2022-04-07 20:16:04.262 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.1.STATE ==> UNIT: "undefined" (min: undefined, max: undefined) From "true" => "true"
        2022-04-07 20:16:04.262 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:1,SECTION,2
        2022-04-07 20:16:04.262 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:1","SECTION",2]
        2022-04-07 20:16:04.263 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.1.SECTION ==> UNIT: "undefined" (min: 0, max: 15) From "2" => "2"
        2022-04-07 20:16:04.263 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:1,PROCESS,0
        2022-04-07 20:16:04.263 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:1","PROCESS",0]
        2022-04-07 20:16:04.263 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.1.PROCESS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
        2022-04-07 20:16:04.274 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:2,SECTION_STATUS,0
        2022-04-07 20:16:04.274 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:2","SECTION_STATUS",0]
        2022-04-07 20:16:04.274 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.2.SECTION_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
        2022-04-07 20:16:04.275 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:2,STATE,true
        2022-04-07 20:16:04.275 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:2","STATE",true]
        2022-04-07 20:16:04.275 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.2.STATE ==> UNIT: "undefined" (min: undefined, max: undefined) From "true" => "true"
        2022-04-07 20:16:04.275 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:2,SECTION,2
        2022-04-07 20:16:04.275 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:2","SECTION",2]
        2022-04-07 20:16:04.275 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.2.SECTION ==> UNIT: "undefined" (min: 0, max: 15) From "2" => "2"
        2022-04-07 20:16:04.275 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:2,PROCESS,0
        2022-04-07 20:16:04.276 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:2","PROCESS",0]
        2022-04-07 20:16:04.276 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.2.PROCESS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
        2022-04-07 20:16:04.283 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:3,SECTION_STATUS,0
        2022-04-07 20:16:04.283 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:3","SECTION_STATUS",0]
        2022-04-07 20:16:04.283 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.3.SECTION_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
        2022-04-07 20:16:04.284 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:3,STATE,false
        2022-04-07 20:16:04.284 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:3","STATE",false]
        2022-04-07 20:16:04.284 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.3.STATE ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
        2022-04-07 20:16:04.285 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:3,SECTION,0
        2022-04-07 20:16:04.285 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:3","SECTION",0]
        2022-04-07 20:16:04.285 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.3.SECTION ==> UNIT: "undefined" (min: 0, max: 15) From "0" => "0"
        2022-04-07 20:16:04.285 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:3,PROCESS,0
        2022-04-07 20:16:04.285 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:3","PROCESS",0]
        2022-04-07 20:16:04.286 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.3.PROCESS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
        2022-04-07 20:16:04.294 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:4,SECTION_STATUS,0
        2022-04-07 20:16:04.294 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:4","SECTION_STATUS",0]
        2022-04-07 20:16:04.294 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.4.SECTION_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
        2022-04-07 20:16:04.295 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:4,STATE,false
        2022-04-07 20:16:04.295 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:4","STATE",false]
        2022-04-07 20:16:04.295 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.4.STATE ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
        2022-04-07 20:16:04.296 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:4,SECTION,0
        2022-04-07 20:16:04.296 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:4","SECTION",0]
        2022-04-07 20:16:04.297 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.4.SECTION ==> UNIT: "undefined" (min: 0, max: 15) From "0" => "0"
        2022-04-07 20:16:04.297 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,000895699E6B0E:4,PROCESS,0
        2022-04-07 20:16:04.297 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","000895699E6B0E:4","PROCESS",0]
        2022-04-07 20:16:04.298 - debug: hm-rpc.1 (1169) hm-rpc.1.000895699E6B0E.4.PROCESS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
        2022-04-07 20:16:04.344 - debug: shuttercontrol.0 (1726) Shutter state changed: Rollladen Wohnzimmer Terrasse Schiebetür.LEVEL old value = 100 new value = 0
        2022-04-07 20:16:04.345 - debug: shuttercontrol.0 (1726) Rollladen Wohnzimmer Terrasse Schiebetür.LEVEL Old value = 100. New value = 0. automatic is active
        2022-04-07 20:16:05.303 - info: shelly.0 (1251) [CoAP] Device 192.168.229.68 (shellyrgbw2 / shellyrgbw2-1E035D / SHRGBW2#1E035D#1) connected! Polltime set to 5 sec.
        2022-04-07 20:16:10.433 - debug: shuttercontrol.0 (1726) Shutter state changed: Rollladen Wohnzimmer Seite vorn.LEVEL old value = 100 new value = 0
        2022-04-07 20:16:10.434 - debug: shuttercontrol.0 (1726) Rollladen Wohnzimmer Seite vorn.LEVEL Old value = 100. New value = 0. automatic is active
        2022-04-07 20:16:13.455 - debug: shuttercontrol.0 (1726) Shutter state changed: Rollladen Wohnzimmer Seite hinten.LEVEL old value = 100 new value = 0
        2022-04-07 20:16:13.455 - debug: shuttercontrol.0 (1726) Rollladen Wohnzimmer Seite hinten.LEVEL Old value = 100. New value = 0. automatic is active
        2022-04-07 20:16:16.720 - debug: shuttercontrol.0 (1726) Shutter state changed: Rollladen Büro.LEVEL old value = 100 new value = 0
        2022-04-07 20:16:16.720 - debug: shuttercontrol.0 (1726) Rollladen Büro.LEVEL Old value = 100. New value = 0. automatic is active
        2022-04-07 20:16:16.764 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,CONFIG_PENDING,false
        2022-04-07 20:16:16.765 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","CONFIG_PENDING",false]
        2022-04-07 20:16:16.765 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.CONFIG_PENDING ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
        2022-04-07 20:16:16.765 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,DUTY_CYCLE,false
        2022-04-07 20:16:16.766 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","DUTY_CYCLE",false]
        2022-04-07 20:16:16.766 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.DUTY_CYCLE ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
        2022-04-07 20:16:16.766 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,LOW_BAT,false
        2022-04-07 20:16:16.766 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","LOW_BAT",false]
        2022-04-07 20:16:16.766 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.LOW_BAT ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
        2022-04-07 20:16:16.767 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,UNREACH,false
        2022-04-07 20:16:16.767 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","UNREACH",false]
        2022-04-07 20:16:16.767 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.UNREACH ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
        2022-04-07 20:16:16.767 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,RSSI_DEVICE,-79
        2022-04-07 20:16:16.767 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","RSSI_DEVICE",-79]
        2022-04-07 20:16:16.768 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.RSSI_DEVICE ==> UNIT: "undefined" (min: -128, max: 127) From "-79" => "-79"
        2022-04-07 20:16:16.768 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,OPERATING_VOLTAGE_STATUS,0
        2022-04-07 20:16:16.768 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","OPERATING_VOLTAGE_STATUS",0]
        2022-04-07 20:16:16.769 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.OPERATING_VOLTAGE_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
        2022-04-07 20:16:16.769 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,OPERATING_VOLTAGE,3
        2022-04-07 20:16:16.769 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","OPERATING_VOLTAGE",3]
        2022-04-07 20:16:16.769 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.OPERATING_VOLTAGE ==> UNIT: "undefined" (min: 0, max: 25.2) From "3" => "3"
        2022-04-07 20:16:16.769 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:0,ERROR_CODE,0
        2022-04-07 20:16:16.770 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:0","ERROR_CODE",0]
        2022-04-07 20:16:16.770 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.0.ERROR_CODE ==> UNIT: "undefined" (min: 0, max: 255) From "0" => "0"
        2022-04-07 20:16:16.779 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:3,MOTION,false
        2022-04-07 20:16:16.780 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:3","MOTION",false]
        2022-04-07 20:16:16.780 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.3.MOTION ==> UNIT: "undefined" (min: undefined, max: undefined) From "false" => "false"
        2022-04-07 20:16:16.780 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:3,ILLUMINATION,0.1
        2022-04-07 20:16:16.781 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:3","ILLUMINATION",0.1]
        2022-04-07 20:16:16.781 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.3.ILLUMINATION ==> UNIT: "undefined" (min: 0, max: 163830) From "0.1" => "0.1"
        2022-04-07 20:16:16.781 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:3,ILLUMINATION_STATUS,0
        2022-04-07 20:16:16.781 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:3","ILLUMINATION_STATUS",0]
        2022-04-07 20:16:16.782 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.3.ILLUMINATION_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
        2022-04-07 20:16:16.782 - debug: hm-rpc.1 (1169) xml multicall : SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31,0014D8A98A0FD9:3,MOTION_DETECTION_ACTIVE,true
        2022-04-07 20:16:16.782 - debug: hm-rpc.1 (1169) xmlrpc <- event ["SmarthomeRaspi:hm-rpc.1:799bbd842f06e7f7d980ceec0d7d4e31","0014D8A98A0FD9:3","MOTION_DETECTION_ACTIVE",true]
        2022-04-07 20:16:16.783 - debug: hm-rpc.1 (1169) hm-rpc.1.0014D8A98A0FD9.3.MOTION_DETECTION_ACTIVE ==> UNIT: "undefined" (min: undefined, max: undefined) From "true" => "true"
        2022-04-07 20:16:17.660 - info: host.SmarthomeRaspi instance system.adapter.mihome-vacuum.0 started with pid 17770
        2022-04-07 20:16:19.313 - debug: mihome-vacuum.0 (17770) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2022-04-07 20:16:19.408 - debug: mihome-vacuum.0 (17770) Objects client ready ... initialize now
        2022-04-07 20:16:19.411 - debug: mihome-vacuum.0 (17770) Objects create System PubSub Client
        2022-04-07 20:16:19.414 - debug: mihome-vacuum.0 (17770) Objects create User PubSub Client
        2022-04-07 20:16:19.544 - debug: mihome-vacuum.0 (17770) Objects client initialize lua scripts
        2022-04-07 20:16:19.552 - debug: mihome-vacuum.0 (17770) Objects connected to redis: 127.0.0.1:9001
        2022-04-07 20:16:19.621 - debug: mihome-vacuum.0 (17770) Redis States: Use Redis connection: 127.0.0.1:9000
        2022-04-07 20:16:19.685 - debug: mihome-vacuum.0 (17770) States create System PubSub Client
        2022-04-07 20:16:19.687 - debug: mihome-vacuum.0 (17770) States create User PubSub Client
        2022-04-07 20:16:19.818 - debug: mihome-vacuum.0 (17770) States connected to redis: 127.0.0.1:9000
        2022-04-07 20:16:20.215 - debug: mihome-vacuum.0 (17770) Plugin sentry Initialize Plugin (enabled=true)
        2022-04-07 20:16:20.629 - info: mihome-vacuum.0 (17770) starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.19.1, js-controller: 4.0.21
        2022-04-07 20:16:20.719 - debug: mihome-vacuum.0 (17770) load Map creator... true
        2022-04-07 20:16:20.754 - debug: mihome-vacuum.0 (17770) Create State for deviceInfo
        2022-04-07 20:16:20.755 - debug: mihome-vacuum.0 (17770) Create State for deviceInfomac
        2022-04-07 20:16:20.756 - debug: mihome-vacuum.0 (17770) Create State for deviceInfomodel
        2022-04-07 20:16:20.757 - debug: mihome-vacuum.0 (17770) Create State for deviceInfofw_ver
        2022-04-07 20:16:20.762 - debug: mihome-vacuum.0 (17770) Create State for deviceInfowifi_signal
        2022-04-07 20:16:20.764 - debug: mihome-vacuum.0 (17770) MIIO: Config: ip:192.168.229.31 token: 6a62485744456c466c766f6d45535473
        2022-04-07 20:16:20.771 - info: mihome-vacuum.0 (17770) IOT enabled, create state
        2022-04-07 20:16:20.779 - debug: mihome-vacuum.0 (17770) server started on 0.0.0.0:53421
        2022-04-07 20:16:20.789 - debug: mihome-vacuum.0 (17770) Receive <<< Helo <<< 21310020000000001317ff30624f2a75ffffffffffffffffffffffffffffffff
        2022-04-07 20:16:20.790 - debug: mihome-vacuum.0 (17770) MAIN: Connected to device, try to get model..
        2022-04-07 20:16:20.794 - debug: mihome-vacuum.0 (17770) Time difference between Mihome Vacuum and ioBroker: 1 sec
        2022-04-07 20:16:20.797 - debug: mihome-vacuum.0 (17770) GETMODELFROMAPI: objModel: {"val":"roborock.vacuum.s5e","ack":true,"ts":1649355344903,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1649165771511}
        2022-04-07 20:16:20.799 - debug: mihome-vacuum.0 (17770) Message= {"id":1,"method":"miIO.info"}
        2022-04-07 20:16:22.803 - debug: mihome-vacuum.0 (17770) MIIO Receive Timeout for "miIO.info" <<<
        2022-04-07 20:16:22.804 - debug: mihome-vacuum.0 (17770) Get Device data..0
        • DiginixD Offline
          DiginixD Offline
          Diginix
          #823
          Funktioniert bei irgendwem mit 3.3.x noch spotclean?
          Wenn ich mihome-vacuum.0.control.spotclean auf true setze, bekomme ich nur folgende Logmeldung:
          2022-04-09 19:57:06.399 - warn: mihome-vacuum.0 (363741) Cant send command please try again "spotclean"
          Git issue: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues/556
          ..:: So long! Tom ::..
            saeft_2003
            #824
            Hat schon jemand den S7 MaxV mit dem Adapter laufen?
            Meine Ultra ist heute gekommen 😬
            @Meistertr
            Kannst du sagen ob der Adapter den S7 MaxV und evtl. die Ultrastation unterstützt?!
              saeft_2003
              #825
              @Meistertr
              Der S7 MaxV läuft soweit mit dem Adapter.
              Bekommt man auch die rot markierten Infos der Ultra Station in den iobroker?
                saeft_2003
                schrieb am zuletzt editiert von saeft_2003
                #826
                Hat irgendjemand von euch den S7 MaxV mit dem Adapter laufen? Geht bei euch der multiroomclean?
                @Meistertr
                Edit: Der Multiroomclean geht nur beim Saugen, wenn auch gewischt wird bringt die Ultra Station das ganze durcheinander. Ich habe es hier auf github beschrieben...
                https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues/570#issue-1221908175
                • S saeft_2003
                  @Meistertr
                  D Nicht stören
                  D Nicht stören
                  dirkhe
                  #827
                  @saeft_2003 ich habe gestern mal reingeschaut, ich denke die erweiterten stati sollte man hinbekommen. Icn würde da jetzt auf guthub mit dir die lösung testen wollen und nicht hier, wenn es ok ist.
                  • D dirkhe
                    saeft_2003
                    #828
                    @dirkhe
                    Alles klar machen wir so 👍
                    • DiginixD Offline
                      DiginixD Offline
                      Diginix
                      #829
                      @dirkhe Kannst du vllt auch was hier zu sagen bzw hast eine Idee? https://forum.iobroker.net/post/789063
                      Hier als issue mit debug Log: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues/556
                      Das ging alles mal mit meinem Modell und dem Adapter. Entw. im Adapter ist was "verloren" gegangen oder die API hat sich geändert.
                        Spezialtrick
                        #830
                        Besteht die Möglichkeit den Dream z10 Pro als neues Gerät im Adapter zu unterstützen? Ich habe bereits ein Issue im Github angelegt.
                        Der Dreame L10 Pro wird bereits unterstützt und ist im Grunde das gleiche Gerät wie der z10 Pro nur ohne Absaugstation. Möglicherweise ist die Einbindung daher einfach?
                          saeft_2003
                          #831
                          Ich brauche eure Hilfe. Und zwar will ich per custom command eine Raumreinigung starten. Der Befehl
                          cleansegments;[18,20]
                          Funktioniert leider nicht. Könnt ihr mir sagen wie genau der aussehen muss?
                          • S saeft_2003
                            DiginixD Offline
                            DiginixD Offline
                            Diginix
                            #832
                            @saeft_2003 Als ich das noch verwendet habe war es:
                            app_segment_clean;[20]
                            Die ID ist der mapindes des Raumes aus mihome-vacuum.0.rooms.*.mapIndex und es können kommasepariert mehrere ins Array.
                            • DiginixD Diginix
                              saeft_2003
                              #833
                              @diginix
                              Super das funktioniert 👍
                              • R Offline
                                Rushmed
                                #834
                                Meine Instanz zeigt seit Neustem mehrmals täglich diese Fehlermeldung:
                                mihome-vacuum.0
                                2022-05-28 01:10:44.883	error	Error by saving of the map
                                mihome-vacuum.0
                                2022-05-28 01:10:44.882	error	Cannot write file actualMap_0.png: mihome-vacuum.admin is not an object of type "meta"
                                Was kann ich dagegen tun?
                                R 1 Antwort Letzte Antwort
                                  saeft_2003
                                  #835
                                  An alle Ultra Besitzer:
                                  Es gibt jetzt eine Version vom Adapter die anzeigt ob das Wasser von der Ultra Station leer ist oder nicht. Wurde von mir getestet und funktioniert 👍
                                  https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tree/584-ultra-station-meldung-wenn-wasser-leer
                                  • D Nicht stören
                                    D Nicht stören
                                    dirkhe
                                    #836
                                    @saeft_2003 ist schon released, 3.4.0
                                    S S 2 Antworten Letzte Antwort
                                    • D dirkhe
                                      Spezialtrick
                                      #837
                                      @dirkhe Hallo Dirk, besteht die Möglichkeit den Dream z10 Pro als neues Gerät im Adapter zu unterstützen? Ich habe bereits ein Issue im Github angelegt.
                                      • S Spezialtrick
                                        D Nicht stören
                                        D Nicht stören
                                        dirkhe
                                        #838
                                        @spezialtrick neue hardware hinzuzufügen, ohne sie selber zu besitzen, ust immer schwierig. Ich weiß auch nicht, wie meisterTr das immer gemacht hat. Funktioniert er den grundsätzlich mit dem adapter und es fehlen einzelne feature?
                                        Wenn ich mir den issue so ansehe, scheint der ja komplett neu zu sein.
                                        • D dirkhe
                                          Spezialtrick
                                          schrieb am zuletzt editiert von Spezialtrick
                                          #839
                                          @dirkhe Ich bekomme die Meldung, dass das Gerät nicht unterstützt wird:
                                          Auf meinem Dreame läuft Valetudo.
