  4. [Neuer Adapter] EuSec
adaptercamerasdoorbelleufyeufycamsecurity
1.2k Beiträge 160 Kommentatoren 620.1k Aufrufe 147 Beobachtet
  • TbsJahT TbsJah
    Eventuell für jemanden interessant
    Recht zügiger Weg um ein aktuelles Bild per Telegram zu senden
    var Path_Pic;
    var URL_CAM;
    const fs = require('fs');
    async function create_pic(Path_Pic, URL_CAM) {
    //check if picture exists - if yes delete
    if (fs.existsSync(Path_Pic)) {
        exec(('rm  ' + String(Path_Pic)));
        await wait(1000);  //just to be sure that the picture is deleted
      // Start Stream
      await wait(1000);  //just to be sure that the stream has started
      exec((['ffmpeg -loglevel fatal -rtsp_transport tcp -i ',URL_CAM,' -f image2 -vframes 1 -pix_fmt yuvj420p ',Path_Pic].join('')));
      await wait(2000); //ffmpeg needs time for creation
    if (!(fs.existsSync(Path_Pic))) {
       await wait(2000);  //ffmpeg needs more time for creation
       log('nicht vorhanden');
      sendTo("telegram.0", "send", {
          text: Path_Pic,
          user: ''
    //Example how to use function
    //If rtsp exist use rtsp
    setState('eusec.0.XXXXXXXXXXXXX.cameras.XXXXXXXXXXXXXX.rtsp_stream' /* Start stream */, true); //normally already switched on
    await create_pic('/opt/XXXXXX/XXXXXXX/Pic.jpeg', 'rtsp://USR:PWD@192.168.XXX.XXX/live0'); //Store path picture - rtsp url
    //If rtsp not exist use go2rtc  but much slower
    setState('eusec.0.XXXXXXXXXXXXX.cameras.XXXXXXXXXXXXXX.start_stream' /* Start stream */, true);
    await create_pic('/opt/XXXXXX/XXXXXXX/Pic.jpeg', 'rtsp://raspberrypi:8554/XXXXXXXXXXXXXX'); //Store path picture - o2rtc   url
    Gonzokalle
    #781
    @tbsjah
    Sogar sehr interessant.
    Kannst du das für die Blockly Anhänger übersetzen?😊
    TbsJahT 1 Antwort Letzte Antwort
    • G Gonzokalle
      @tbsjah
      TbsJahT Offline
      TbsJahT Offline
      TbsJah
      #782
      @gonzokalle
        <variables>
          <variable id=".5kR@*@BVv1O7noIe(3G">XXXXXXXXXXXXXXXX_Pic</variable>
          <variable id="HG,5+Q1IK)XD#v$T4*hl">URL_CAM</variable>
          <variable id="oN*3XW_?QS7$:FwR$CbD">Check</variable>
        </variables>
        <block type="procedures_defcustomreturn" id="J!Bvoqs}(Lq/G?ZW,-(]" x="188" y="263">
          <mutation statements="false">
            <arg name="XXXXXXXXXXXXXXXX_Pic" varid=".5kR@*@BVv1O7noIe(3G"></arg>
            <arg name="URL_CAM" varid="HG,5+Q1IK)XD#v$T4*hl"></arg>
          </mutation>
          <field name="NAME">create_pic</field>
          <field name="SCRIPT">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</field>
          <comment pinned="false" h="80" w="160">Describe this function...</comment>
        </block>
        <block type="control" id="lN7OPGS,BYEuQ@]tdjAV" x="188" y="313">
          <field name="OID">eusec.0.XXXXXXXXXXXXXXXX.cameras.XXXXXXXXXXXXXXXX.rtsp_stream</field>
          <value name="VALUE">
            <block type="logic_boolean" id="pBb4#,2FShkMf9DWMg6D">
            </block>
          </value>
          <next>
            <block type="variables_set" id="f~O~*,YL5.W@65-.lGf9">
              <field name="VAR" id="oN*3XW_?QS7$:FwR$CbD">Check</field>
                <block type="procedures_callcustomreturn" id="HRD7cJ{40v0Y%W3MkFuW">
                  <mutation name="create_pic">
                    <arg name="XXXXXXXXXXXXXXXX_Pic"></arg>
                    <arg name="URL_CAM"></arg>
                  </mutation>
                  <value name="ARG0">
                    <block type="text" id="0]6j[8=u`;kcgni7!oT`">
                      <field name="TEXT">PATH/Pic.jpeg</field>
                    </block>
                  </value>
                  <value name="ARG1">
                    <block type="convert_tostring" id="L9g6b9r{-+K?NdU3s$G=">
                        <block type="get_value" id="mgW_61f13,(6M{4~:-`n">
                          <field name="OID">eusec.0.XXXXXXXXXXXXXXXX.cameras.XXXXXXXXXXXXXXXX.rtsp_stream_url</field>
                        </block>
                      </value>
                    </block>
                  </value>
                </block>
              </value>
              <next>
                <block type="controls_if" id="AH%upH|y(afK(2}sVr#7">
                  <value name="IF0">
                    <block type="logic_compare" id="D_;;c_hk!dF83JX[p/M`">
                      <field name="OP">EQ</field>
                      <value name="A">
                        <block type="variables_get" id="zO@w4w~4LFmb1,p)l*vs">
                        </block>
                      </value>
                      <value name="B">
                        <block type="logic_boolean" id="~934R*fRj3g6d~/JEX.p">
                        </block>
                      </value>
                    </block>
                  </value>
                  <statement name="DO0">
                    <block type="telegram" id="8r90W{b2|I21hZT)$_*`">
                      <field name="LOG"></field>
                      <field name="ESCAPING">FALSE</field>
                      <field name="DISABLE_WEB_PAGE_PREVIEW">FALSE</field>
                      <value name="MESSAGE">
                        <shadow type="text" id="rO)Fwr+*@@m~T-KRk6HO">
                        </shadow>
                      </value>
                      <value name="USERNAME">
                        <block type="text" id="RQQ)]z?_{Q7yj}xKs=rL">
                          <field name="TEXT">User</field>
                        </block>
                      </value>
                    </block>
                  </statement>
                </block>
              </next>
            </block>
          </next>
        </block>
      </xml>
      G 1 Antwort Letzte Antwort
      • TbsJahT TbsJah
        @gonzokalle
          <variables>
          </variables>
            </mutation>
          </block>
              </block>
            </value>
            <next>
                    </mutation>
                    <value name="ARG0">
                      </block>
                    </value>
                    <value name="ARG1">
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
                <next>
                    <value name="IF0">
                        <value name="A">
                          </block>
                        </value>
                        <value name="B">
                          </block>
                        </value>
                      </block>
                    </value>
                          </shadow>
                        </value>
                          </block>
                        </value>
                      </block>
                    </statement>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </xml>
        Gonzokalle
        #783
        @tbsjah
        Importieren hat gut geklappt.
        Was muss ich denn wo eintragen?
        • B bropat
          Hallo an alle,
          ich möchte euch meinen ersten ioBroker Adapter "euSec", an dem ich gerade Arbeite, vorstellen:
          https://github.com/bropat/ioBroker.euSec
          Dieser Adapter ermöglicht die Steuerung von Eufy-Sicherheitsgeräten (https://www.eufylife.com/de/products/643/sicherheit) durch die Verbindung mit der Eufy-Cloud.
          Nähere Infos findet ihr hier: https://bropat.github.io/ioBroker.eusec
          Für jeweiligen Ratschläge und Verbesserungen bin ich sehr dankbar!
          Grüße
          FabioF Offline
          FabioF Offline
          Fabio
          #784
          @bropat vielen Dank für deine Mühen, die neue v 1.1.0 läuft bei mir super.👍
          Grüße
          Fabio
          Iobroker:
          • Matter over Thread Hilfe
          • freakyfreakyF Offline
            freakyfreaky
            #785
            Vielen Dank für das Update. Leider klappt der Datenpunkt "motion_detected" bei allen Kameras nur einmal direkt nach dem Neustart des Adapters. Sobald dieser einmal ausgelöst hat werden keine weiteren Bewegungen erfasst und keine neuen Bilder abgelegt. Auch der Stream lässt sich wegen der ffmpeg Meldung nicht starten
            • freakyfreakyF freakyfreaky
              FabioF Offline
              FabioF Offline
              Fabio
              #786
              @freakyfreaky hab das gerade getestet, stimmt geht leider nicht mehr.
              Mach doch bitte ein issue auf bei github. https://github.com/bropat/ioBroker.eusec/issues damit @bropat es dann fixen kann soweit das möglich ist. Evtl. liegt es auch an Eufy selber.
              Grüße
              Fabio
              Iobroker:
              freakyfreakyF 1 Antwort Letzte Antwort
              • FabioF Fabio
                Grüße
                Fabio
                freakyfreaky
                #787
                @fa-bio habe die beiden Issues die es schon gab um die neuen Adapter Versionen aktualisiert
                  mick70
                  #788
                  Ich vermute mal, ich bin nicht der einzige, der plötzlich vor dem captcha oder 2fa Problem mit eufy / eusec steht. Deshalb für die Forensuche dieser Beitrag mit entsprechenden Stichworten und von hier nochmal der link zu github, wo das Thema sauber aufgearbeitet ist ;)
                  • B bropat
                    Hallo an alle,
                    Grüße
                    FabioF Offline
                    FabioF Offline
                    Fabio
                    #789
                    Hallo @bropat vielen Dank für die neue Version 1.1.1 läuft bei mir bis jetzt fehlerfrei. 👍 👍
                    Grüße
                    Fabio
                    Iobroker:
                    • B bropat
                      Hallo an alle,
                      Grüße
                      Minta79
                      #790
                      @bropat
                      Hallo. Sorry, aber ich komme einfach nicht weiter. Adapter in Version 1.1.0 installiert, angemeldet und wurde grün. Es kommt aber kein Code per Email.
                      Was mache ich falsch?
                      FabioF M 2 Antworten Letzte Antwort
                      • M Minta79
                        @bropat
                        FabioF Offline
                        FabioF Offline
                        Fabio
                        #791
                        @minta79 les dir das mal bitte durch evtl. hilft das dir. https://bropat.github.io/ioBroker.eusec/#/authentication
                        Iobroker:
                        • FabioF Fabio
                          Minta79
                          #792
                          Das hilft mir leider nicht weiter. Der Adapter ist grün, aber einen Code habe ich nicht eingegeben. Connection steht auf true, Captcha auf null.
                          Im Log steht sowas wie: "Push token OK", "Push notification connection successfully established", "No stations found.", "No devices found."
                          Mein iobroker läuft in einer proxmox Umgebung - kann es da was mit zu tun haben?
                          • WG25W Online
                            WG25W Online
                            WG25
                            #793
                            Moin, ich habe immer folgende Error Meldung im LOG stehen: error: JSON parse error [{"data":"{"r","error":{}}]
                            Das ganze immer gefolgt von einer Warung: warn: Non-parsable parameter value received from eufy cloud. Will be ignored. [{"type":2708,"value":"{"r"}]
                            Ist das bekannt?
                            • M Minta79
                              FabioF Offline
                              FabioF Offline
                              Fabio
                              schrieb am zuletzt editiert von Fabio
                              #794
                              @minta79 bei Promox bin ich raus keine Ahnung. Wenn der Adapter ja überall grün hat scheint ja das anmelden zu klappen da bekommt er wohl keine Verbindung zu den Geräten.
                              Evtl. ein Port Problem. Aber wie gesagt, da kenne ich mich nicht mit aus.
                              Iobroker:
                              C 1 Antwort Letzte Antwort
                                mick70
                                schrieb am zuletzt editiert von mick70
                                #795
                                [kann weg, erledigt]
                                • LongbowL Offline
                                  LongbowL Offline
                                  Longbow
                                  #796
                                  Mal eine erneute blöde Frage, sicherlich ist die schon längst gestellt worden, aber nur so mal nochmals.
                                  Hat jemandes die Cam von Eufy sauber und richtig in den iobroker drin, so dass er diese in der VIS darstellen kann. Ich finde keine Möglichkeit, bin dabei die Dinge in den Müll zu schmeißen.
                                  Bin für jeden Tipp oder jede Hilfe dankbar.
                                  • M Minta79
                                    @bropat
                                    Minta79
                                    #797
                                    @minta79 said in [Neuer Adapter] EuSec:
                                    Kann mir hier niemand helfen?
                                    • M Minta79
                                      FabioF Offline
                                      FabioF Offline
                                      Fabio
                                      #798
                                      @minta79 hängt die Email im Spam Filter?
                                      Oder hast du Zwei-Faktor-Authentifizierung in der Euf App eingestellt dann bekommst du eigentlich keine Email sondern eine Push aufs Handy.
                                      Iobroker:
                                      LongbowL M 2 Antworten Letzte Antwort
                                      • FabioF Fabio
                                        LongbowL Offline
                                        LongbowL Offline
                                        Longbow
                                        #799
                                        Hallo
                                        ich habe gestern mir einmal ein neues System im Promox aufgesetzt und den Adapter neu installiert.
                                        Aufeinmal klappt das Einbinden des HTTP Stream perferkt, man wählt vorher den Datenpunkt Start Stream aus, dann fängt der Stream an zu laufen, die Zeit, die im Adapter eingestellt ist.
                                        Nur bei den SolarCamS40 da spinnt es, bin echt überrascht...
                                        BanditFGB 1 Antwort Letzte Antwort
                                        • FabioF Fabio
                                          Minta79
                                          schrieb am zuletzt editiert von Minta79
                                          #800
                                          @fa-bio said in [Neuer Adapter] EuSec:
                                          Nein, die ist aus. Es kam sonst immer eine Email mit dem Code. Kommt aber nichts.
                                          Email Spam Ordner ist leer.
