  4. [Neuer Adapter] EuSec
adaptercamerasdoorbelleufyeufycamsecurity
1.2k Beiträge 160 Kommentatoren 620.1k Aufrufe 147 Beobachtet
  • L locito09
    @Marko1974
    Geht bei mir auch nicht mehr, nur in der VIS lässt sich das Bild anzeigen, bei mir wird der Personen Detected dantenpunkt auch nicht mehr aktualisiert
    Marko1974M Offline
    Marko1974M Offline
    Marko1974
    #778
    @locito09 said in [Neuer Adapter] EuSec:
    @Marko1974
    Kann man da was machen @bropat ?
    • L locito09
      @Marko1974
      Marko1974M Offline
      Marko1974M Offline
      Marko1974
      #779
      @locito09 kann man nicht von VIS an Telegram senden?
      • TbsJahT Offline
        TbsJahT Offline
        TbsJah
        #780
        Eventuell für jemanden interessant
        Recht zügiger Weg um ein aktuelles Bild per Telegram zu senden
        var Path_Pic;
        var URL_CAM;
        const fs = require('fs');
        async function create_pic(Path_Pic, URL_CAM) {
        //check if picture exists - if yes delete
        if (fs.existsSync(Path_Pic)) {
            exec(('rm  ' + String(Path_Pic)));
            await wait(1000);  //just to be sure that the picture is deleted
          // Start Stream
          await wait(1000);  //just to be sure that the stream has started
          exec((['ffmpeg -loglevel fatal -rtsp_transport tcp -i ',URL_CAM,' -f image2 -vframes 1 -pix_fmt yuvj420p ',Path_Pic].join('')));
          await wait(2000); //ffmpeg needs time for creation
        if (!(fs.existsSync(Path_Pic))) {
           await wait(2000);  //ffmpeg needs more time for creation
           log('nicht vorhanden');
          sendTo("telegram.0", "send", {
              text: Path_Pic,
              user: ''
        //Example how to use function
        //If rtsp exist use rtsp
        setState('eusec.0.XXXXXXXXXXXXX.cameras.XXXXXXXXXXXXXX.rtsp_stream' /* Start stream */, true); //normally already switched on
        await create_pic('/opt/XXXXXX/XXXXXXX/Pic.jpeg', 'rtsp://USR:PWD@192.168.XXX.XXX/live0'); //Store path picture - rtsp url
        //If rtsp not exist use go2rtc  but much slower
        setState('eusec.0.XXXXXXXXXXXXX.cameras.XXXXXXXXXXXXXX.start_stream' /* Start stream */, true);
        await create_pic('/opt/XXXXXX/XXXXXXX/Pic.jpeg', 'rtsp://raspberrypi:8554/XXXXXXXXXXXXXX'); //Store path picture - o2rtc   url
        G Marko1974M 2 Antworten Letzte Antwort
        • TbsJahT TbsJah
          var Path_Pic;
          var URL_CAM;
            // Start Stream
                text: Path_Pic,
                user: ''
          Gonzokalle
          #781
          @tbsjah
          Sogar sehr interessant.
          Kannst du das für die Blockly Anhänger übersetzen?😊
          TbsJahT 1 Antwort Letzte Antwort
          • G Gonzokalle
            @tbsjah
            TbsJahT Offline
            TbsJahT Offline
            TbsJah
            #782
            @gonzokalle
              <variables>
                <variable id=".5kR@*@BVv1O7noIe(3G">XXXXXXXXXXXXXXXX_Pic</variable>
                <variable id="HG,5+Q1IK)XD#v$T4*hl">URL_CAM</variable>
                <variable id="oN*3XW_?QS7$:FwR$CbD">Check</variable>
              </variables>
              <block type="procedures_defcustomreturn" id="J!Bvoqs}(Lq/G?ZW,-(]" x="188" y="263">
                <mutation statements="false">
                  <arg name="XXXXXXXXXXXXXXXX_Pic" varid=".5kR@*@BVv1O7noIe(3G"></arg>
                  <arg name="URL_CAM" varid="HG,5+Q1IK)XD#v$T4*hl"></arg>
                </mutation>
                <field name="NAME">create_pic</field>
                <field name="SCRIPT">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</field>
                <comment pinned="false" h="80" w="160">Describe this function...</comment>
              </block>
              <block type="control" id="lN7OPGS,BYEuQ@]tdjAV" x="188" y="313">
                <field name="OID">eusec.0.XXXXXXXXXXXXXXXX.cameras.XXXXXXXXXXXXXXXX.rtsp_stream</field>
                <value name="VALUE">
                  <block type="logic_boolean" id="pBb4#,2FShkMf9DWMg6D">
                  </block>
                </value>
                <next>
                  <block type="variables_set" id="f~O~*,YL5.W@65-.lGf9">
                    <field name="VAR" id="oN*3XW_?QS7$:FwR$CbD">Check</field>
                      <block type="procedures_callcustomreturn" id="HRD7cJ{40v0Y%W3MkFuW">
                        <mutation name="create_pic">
                          <arg name="XXXXXXXXXXXXXXXX_Pic"></arg>
                          <arg name="URL_CAM"></arg>
                        </mutation>
                        <value name="ARG0">
                          <block type="text" id="0]6j[8=u`;kcgni7!oT`">
                            <field name="TEXT">PATH/Pic.jpeg</field>
                          </block>
                        </value>
                        <value name="ARG1">
                          <block type="convert_tostring" id="L9g6b9r{-+K?NdU3s$G=">
                              <block type="get_value" id="mgW_61f13,(6M{4~:-`n">
                                <field name="OID">eusec.0.XXXXXXXXXXXXXXXX.cameras.XXXXXXXXXXXXXXXX.rtsp_stream_url</field>
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </value>
                    <next>
                      <block type="controls_if" id="AH%upH|y(afK(2}sVr#7">
                        <value name="IF0">
                          <block type="logic_compare" id="D_;;c_hk!dF83JX[p/M`">
                            <field name="OP">EQ</field>
                            <value name="A">
                              <block type="variables_get" id="zO@w4w~4LFmb1,p)l*vs">
                              </block>
                            </value>
                            <value name="B">
                              <block type="logic_boolean" id="~934R*fRj3g6d~/JEX.p">
                              </block>
                            </value>
                          </block>
                        </value>
                        <statement name="DO0">
                          <block type="telegram" id="8r90W{b2|I21hZT)$_*`">
                            <field name="LOG"></field>
                            <field name="ESCAPING">FALSE</field>
                            <field name="DISABLE_WEB_PAGE_PREVIEW">FALSE</field>
                            <value name="MESSAGE">
                              <shadow type="text" id="rO)Fwr+*@@m~T-KRk6HO">
                              </shadow>
                            </value>
                            <value name="USERNAME">
                              <block type="text" id="RQQ)]z?_{Q7yj}xKs=rL">
                                <field name="TEXT">User</field>
                              </block>
                            </value>
                          </block>
                        </statement>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </xml>
            G 1 Antwort Letzte Antwort
            • TbsJahT TbsJah
              @gonzokalle
                <variables>
                </variables>
                  </mutation>
                </block>
                    </block>
                  </value>
                  <next>
                          </mutation>
                          <value name="ARG0">
                            </block>
                          </value>
                          <value name="ARG1">
                                </block>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                      <next>
                          <value name="IF0">
                              <value name="A">
                                </block>
                              </value>
                              <value name="B">
                                </block>
                              </value>
                            </block>
                          </value>
                                </shadow>
                              </value>
                                </block>
                              </value>
                            </block>
                          </statement>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </xml>
              Gonzokalle
              #783
              @tbsjah
              Importieren hat gut geklappt.
              Was muss ich denn wo eintragen?
              • B bropat
                Hallo an alle,
                ich möchte euch meinen ersten ioBroker Adapter "euSec", an dem ich gerade Arbeite, vorstellen:
                https://github.com/bropat/ioBroker.euSec
                Dieser Adapter ermöglicht die Steuerung von Eufy-Sicherheitsgeräten (https://www.eufylife.com/de/products/643/sicherheit) durch die Verbindung mit der Eufy-Cloud.
                Nähere Infos findet ihr hier: https://bropat.github.io/ioBroker.eusec
                Für jeweiligen Ratschläge und Verbesserungen bin ich sehr dankbar!
                FabioF Offline
                FabioF Offline
                Fabio
                #784
                @bropat vielen Dank für deine Mühen, die neue v 1.1.0 läuft bei mir super.👍
                Fabio
                Iobroker:
                • Matter over Thread Hilfe
                • freakyfreakyF Offline
                  freakyfreaky
                  #785
                  Vielen Dank für das Update. Leider klappt der Datenpunkt "motion_detected" bei allen Kameras nur einmal direkt nach dem Neustart des Adapters. Sobald dieser einmal ausgelöst hat werden keine weiteren Bewegungen erfasst und keine neuen Bilder abgelegt. Auch der Stream lässt sich wegen der ffmpeg Meldung nicht starten
                  FabioF 1 Antwort Letzte Antwort
                  • freakyfreakyF freakyfreaky
                    FabioF Offline
                    FabioF Offline
                    Fabio
                    #786
                    @freakyfreaky hab das gerade getestet, stimmt geht leider nicht mehr.
                    Mach doch bitte ein issue auf bei github. https://github.com/bropat/ioBroker.eusec/issues damit @bropat es dann fixen kann soweit das möglich ist. Evtl. liegt es auch an Eufy selber.
                    Fabio
                    Iobroker:
                    freakyfreakyF 1 Antwort Letzte Antwort
                    • FabioF Fabio
                      Fabio
                      freakyfreaky
                      #787
                      @fa-bio habe die beiden Issues die es schon gab um die neuen Adapter Versionen aktualisiert
                        mick70
                        #788
                        Ich vermute mal, ich bin nicht der einzige, der plötzlich vor dem captcha oder 2fa Problem mit eufy / eusec steht. Deshalb für die Forensuche dieser Beitrag mit entsprechenden Stichworten und von hier nochmal der link zu github, wo das Thema sauber aufgearbeitet ist ;)
                        • B bropat
                          Hallo an alle,
                          FabioF Offline
                          FabioF Offline
                          Fabio
                          #789
                          Hallo @bropat vielen Dank für die neue Version 1.1.1 läuft bei mir bis jetzt fehlerfrei. 👍 👍
                          Fabio
                          Iobroker:
                          • B bropat
                            Hallo an alle,
                            Minta79
                            #790
                            @bropat
                            Hallo. Sorry, aber ich komme einfach nicht weiter. Adapter in Version 1.1.0 installiert, angemeldet und wurde grün. Es kommt aber kein Code per Email.
                            Was mache ich falsch?
                            FabioF M 2 Antworten Letzte Antwort
                            • M Minta79
                              @bropat
                              FabioF Offline
                              FabioF Offline
                              Fabio
                              #791
                              @minta79 les dir das mal bitte durch evtl. hilft das dir. https://bropat.github.io/ioBroker.eusec/#/authentication
                              Iobroker:
                              • FabioF Fabio
                                Minta79
                                #792
                                Das hilft mir leider nicht weiter. Der Adapter ist grün, aber einen Code habe ich nicht eingegeben. Connection steht auf true, Captcha auf null.
                                Im Log steht sowas wie: "Push token OK", "Push notification connection successfully established", "No stations found.", "No devices found."
                                Mein iobroker läuft in einer proxmox Umgebung - kann es da was mit zu tun haben?
                                • WG25W Online
                                  WG25W Online
                                  WG25
                                  #793
                                  Moin, ich habe immer folgende Error Meldung im LOG stehen: error: JSON parse error [{"data":"{"r","error":{}}]
                                  Das ganze immer gefolgt von einer Warung: warn: Non-parsable parameter value received from eufy cloud. Will be ignored. [{"type":2708,"value":"{"r"}]
                                  Ist das bekannt?
                                  • M Minta79
                                    FabioF Offline
                                    FabioF Offline
                                    Fabio
                                    schrieb am zuletzt editiert von Fabio
                                    #794
                                    @minta79 bei Promox bin ich raus keine Ahnung. Wenn der Adapter ja überall grün hat scheint ja das anmelden zu klappen da bekommt er wohl keine Verbindung zu den Geräten.
                                    Evtl. ein Port Problem. Aber wie gesagt, da kenne ich mich nicht mit aus.
                                    Iobroker:
                                    C 1 Antwort Letzte Antwort
                                      mick70
                                      schrieb am zuletzt editiert von mick70
                                      #795
                                      [kann weg, erledigt]
                                      • LongbowL Offline
                                        LongbowL Offline
                                        Longbow
                                        #796
                                        Mal eine erneute blöde Frage, sicherlich ist die schon längst gestellt worden, aber nur so mal nochmals.
                                        Hat jemandes die Cam von Eufy sauber und richtig in den iobroker drin, so dass er diese in der VIS darstellen kann. Ich finde keine Möglichkeit, bin dabei die Dinge in den Müll zu schmeißen.
                                        Bin für jeden Tipp oder jede Hilfe dankbar.
                                        • M Minta79
                                          @bropat
                                          Minta79
                                          #797
                                          @minta79 said in [Neuer Adapter] EuSec:
                                          Kann mir hier niemand helfen?
