  4. Test Adapter luxtronik2 v0.4.x
adapterluxtronik wpwebsocket
292 Beiträge 52 Kommentatoren 94.9k Aufrufe 49 Beobachtet
  • H Offline
    Henning 1
    #161
    Das hatte ich schon probiert. Der Adapter ist nicht sichtbar.
    • H Henning 1
      #162
      @henning-1
      iobroker update -i
      • H Offline
        Henning 1
        #163
        Used repository: stable
        Adapter    "admin"        : 5.3.8    , installed 5.3.8
        Adapter    "backitup"     : 2.4.9    , installed 2.4.9
        Adapter    "discovery"    : 3.0.3    , installed 3.0.3
        Adapter    "fronius"      : 1.1.3    , installed 1.1.3
        Adapter    "gruenbeck"    : 0.0.34   , installed 0.0.34
        Adapter    "javascript"   : 5.7.0    , installed 5.7.0
        Controller "js-controller": 4.0.23   , installed 4.0.23
        Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
        Adapter    "openknx"      : 0.2.5    , installed 0.1.22 [Updatable]
        Adapter    "ping"         : 1.5.3    , installed 1.5.3
        Adapter    "pvforecast"   : 2.1.4    , installed 2.1.4
        Adapter    "unifi"        : 0.5.10   , installed 0.5.10
        Adapter    "valloxmv"     : 1.1.3    , installed 1.1.3
        Adapter    "zwave2"       : 2.5.0    , installed 2.5.0
        • H Henning 1
          Hmm, ging auch nicht:
          pi@iobroker-pi:~ $ iobroker add luxtronik2
          host.iobroker-pi Unknown packetName luxtronik2. Please install packages from outside the repository using npm!
          pi@iobroker-pi:~ $ iobroker add iobroker.luxtronik2
          Ich versuchs jetzt nochmal im opt/iobroker mittels npm. Geht auch nicht :-(
          npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/common@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
          npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/core@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
          npm ERR! code EACCES
          npm ERR! syscall access
          npm ERR! path /opt/iobroker/node_modules
          npm ERR! errno -13
          npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules'
          npm ERR!  [Error: EACCES: permission denied, access '/opt/iobroker/node_modules'] {
          npm ERR!   errno: -13,
          npm ERR!   code: 'EACCES',
          npm ERR!   syscall: 'access',
          npm ERR!   path: '/opt/iobroker/node_modules'
          npm ERR! }
          npm ERR!
          npm ERR! The operation was rejected by your operating system.
          npm ERR! It is likely you do not have the permissions to access this file as the current user
          npm ERR!
          npm ERR! If you believe this might be a permissions issue, please double-check the
          npm ERR! permissions of the file and its containing directories, or try running
          npm ERR! the command again as root/Administrator.
          npm ERR!     /home/pi/.npm/_logs/2022-07-03T11_29_51_613Z-debug.log
          #164
          @henning-1 sagte in Test Adapter luxtronik2 v0.4.x:
          Was genau hast du da eingegeben?
          Bitte IMMER vollständige Ein- wie Ausgaben zeigen.
          • H Offline
            Henning 1
            #165
            Hier inkl. eingegebenes Kommando:
            pi@iobroker-pi:/opt/iobroker $ npm i iobroker.luxtronik2                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules
            npm ERR! errno -13
            npm ERR! }
            npm ERR!
            npm ERR!
            npm ERR!     /home/pi/.npm/_logs/2022-07-03T12_13_16_514Z-debug.log
            • H Henning 1
              npm ERR! errno -13
              npm ERR! }
              npm ERR!
              npm ERR!
              #166
              @henning-1
              groups
              als pi ausgeführt liefert?
              • H Offline
                Henning 1
                #167
                pi@iobroker-pi:/opt/iobroker $ groups
                pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi
                • H Henning 1
                  npm ERR! errno -13
                  npm ERR! }
                  npm ERR!
                  npm ERR!
                  #168
                  Alternativ:
                  cd /opt/iobroker
                  sudo -H -u iobroker npm i iobroker.luxtronik2
                  • H Henning 1
                    #169
                    @henning-1
                    Der pi fehlt in der Gruppe 'iobroker'
                    sudo usermod -aG iobroker pi
                    H 1 Antwort Letzte Antwort
                    • H Offline
                      Henning 1
                      #170
                      @thomas-braun sagte in Test Adapter luxtronik2 v0.4.x:
                      Das liefert er:
                      pi@iobroker-pi:/opt/iobroker $ sudo -H -u iobroker npm i iobroker.luxtronik2
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                      + iobroker.luxtronik2@0.4.2
                      added 7 packages from 82 contributors in 29.319s
                      50 packages are looking for funding
                        run `npm fund` for details
                      Den Adapter sehe ich noch nicht. Gruppe mache ich gleich
                        @henning-1
                        Henning 1
                        #171
                        Sieht besser aus. Habe nach der Gruppenanpassung den add Befehr ausgeführt
                        pi@iobroker-pi:/opt/iobroker $ sudo usermod -aG iobroker pi
                        pi@iobroker-pi:/opt/iobroker $ iobroker add luxtronik2
                        host.iobroker-pi install adapter luxtronik2
                        upload [4] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/admin.d.ts admin.d.ts video/mp2t
                        upload [3] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/index_m.html index_m.html text/html
                        upload [2] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/luxtronik2.png luxtronik2.png image/png
                        upload [1] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/style.css style.css text/css
                        upload [0] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/words.js words.js application/javascript
                        host.iobroker-pi object system.adapter.luxtronik2 created/updated
                        host.iobroker-pi create instance luxtronik2
                        host.iobroker-pi object system.adapter.luxtronik2.0.alive created
                        host.iobroker-pi object system.adapter.luxtronik2.0.connected created
                        host.iobroker-pi object system.adapter.luxtronik2.0.compactMode created
                        host.iobroker-pi object system.adapter.luxtronik2.0.cpu created
                        host.iobroker-pi object system.adapter.luxtronik2.0.cputime created
                        host.iobroker-pi object system.adapter.luxtronik2.0.memHeapUsed created
                        host.iobroker-pi object system.adapter.luxtronik2.0.memHeapTotal created
                        host.iobroker-pi object system.adapter.luxtronik2.0.memRss created
                        host.iobroker-pi object system.adapter.luxtronik2.0.uptime created
                        host.iobroker-pi object system.adapter.luxtronik2.0.inputCount created
                        host.iobroker-pi object system.adapter.luxtronik2.0.outputCount created
                        host.iobroker-pi object system.adapter.luxtronik2.0.eventLoopLag created
                        host.iobroker-pi object system.adapter.luxtronik2.0.sigKill created
                        host.iobroker-pi object system.adapter.luxtronik2.0.logLevel created
                        host.iobroker-pi object luxtronik2.0.info created
                        host.iobroker-pi object luxtronik2.0.info.connection created
                        host.iobroker-pi Set default value of luxtronik2.0.info.connection: false
                        host.iobroker-pi object system.adapter.luxtronik2.0 created
                        Ich mache mal nen Reboot und schaue dann, was ich sehe.
                        • H Henning 1
                          Das liefert er:
                          Henning 1
                          #172
                          Vielen Dank für Diene Zeit eben!!! Das hat geholfen und der Adapter ist sichtbar und scheint mit Port 8889 und PWD 0000 zu funktionieren. Ich spiele jetzt bzw. heute Abend erstmal und versuche Logiken im Zusammenspiel mit dem Fronius WR zu basteln.
                          Schönes WE soweit noch :-)
                          • H Offline
                            Henning 1
                            #173
                            ich habe jede Menge Fehlermeldungen im Protokoll. Liegt das an mir oder an der Adapter Version? Anbei ein Ausschnitt:
                            2022-07-05 10:49:51.478 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.Ausgänge.51-0°C-53-1°C changed to luxtronik2.0.Informationen.Ausgänge.51-0_C-53-1_C
                            2022-07-05 10:49:51.553 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.Wärmemenge.51-0°C-53-1°C changed to luxtronik2.0.Informationen.Wärmemenge.51-0_C-53-1_C
                            2022-07-05 10:49:51.562 - warn: luxtronik2.0 (15011) State "luxtronik2.0.Informationen.Wärmemenge.51-0°C-53-1°C" has no existing object, this might lead to an error in future versions
                            2022-07-05 10:50:02.620 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.Ausgänge.51-0°C-53-2°C changed to luxtronik2.0.Informationen.Ausgänge.51-0_C-53-2_C
                            2022-07-05 10:50:02.685 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.Wärmemenge.51-0°C-53-2°C changed to luxtronik2.0.Informationen.Wärmemenge.51-0_C-53-2_C
                            2022-07-05 10:50:02.697 - warn: luxtronik2.0 (15011) State "luxtronik2.0.Informationen.Wärmemenge.51-0°C-53-2°C" has no existing object, this might lead to an error in future versions
                            • H Henning 1
                              #174
                              @henning-1
                              Die Gradzeichen sind nicht zulässig und werden ersetzt. Wenn der Datenpunkt von dir so angelegt wurde: Ändere es ab.
                              • H Offline
                                Henning 1
                                #175
                                Das ist es ja. Ich hab da gar nichts angelegt. Nur die Instanz. Alles andere ist so, wie vom Adapter vorgegeben. Und das sieht bei Ausgängen so aus:
                                und geht so weiter bis 57. Danach kommt AV-Abtauventil...
                                • H Offline
                                  Henning 1
                                  #176
                                  Das Ganze steht bei Wärmemenge auch nochmal drin
                                  • H Offline
                                    Henning 1
                                    #177
                                    Ich habe mal das Webinterface mit den Adapterwerten verglichen. Neben dieses Vielen Temperaturwerten gibt es noch andere Unterschiede. Bei Eingänge fehlt bsw. Durchfluss 2 etc
                                    Bei Temperaturen fehlen auch Parameter. Kann es sein, dass der Adapter da irgendwie durcheinander kommt?
                                    • H Offline
                                      Henning 1
                                      #178
                                      @UncleSam Soll ich da ein Ticket aufmachen? Ich habe nämlich zwei Außeneinheiten an einer Steuerung. Daher gibt's bei mir einige Werte doppelt. Mit manchen schien der Adapter klar zu kommen ,mit anderen nicht.
                                        pgBroker
                                        schrieb am zuletzt editiert von pgBroker
                                        #179
                                        Musste meinen ioBroker nach einem Crash neu aufsetzen und bekomme jetzt im log im Sekundentakt diese Warnung:
                                        Unknown data item parameters.mk1_curve_parallel_offset
                                        Unknown data item parameters.mk1_curve_end_point
                                        Unknown data item parameters.deltaMk1Reduction
                                        Wie kriege ich die weg?
                                        P 1 Antwort Letzte Antwort
                                        • P pgBroker
                                          pgBroker
                                          #180
                                          Hmmm, hat niemand ne idee? 😕
